path: root/fs/binfmt_em86.c
2008-10-16Allow recursion in binfmt_script and binfmt_miscKirill A. Shutemov
binfmt_script and binfmt_misc disallow recursion to avoid stack overflow using sh_bang and misc_bang. It causes problem in some cases: $ echo '#!/bin/ls' > /tmp/t0 $ echo '#!/tmp/t0' > /tmp/t1 $ echo '#!/tmp/t1' > /tmp/t2 $ chmod +x /tmp/t* $ /tmp/t2 zsh: exec format error: /tmp/t2 Similar problem with binfmt_misc. This patch introduces field 'recursion_depth' into struct linux_binprm to track recursion level in binfmt_misc and binfmt_script. If recursion level more then BINPRM_MAX_RECURSION it generates -ENOEXEC. [akpm@linux-foundation.org: make linux_binprm.recursion_depth a uint] Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: Pavel Emelyanov <xemul@openvz.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29binfmt_misc.c: avoid potential kernel stack overflowPavel Emelyanov
This can be triggered with root help only, but... Register the ":text:E::txt::/root/cat.txt:' rule in binfmt_misc (by root) and try launching the cat.txt file (by anyone) :) The result is - the endless recursion in the load_misc_binary -> open_exec -> load_misc_binary chain and stack overflow. There's a similar problem with binfmt_script, and there's a sh_bang memner on linux_binprm structure to handle this, but simply raising this in binfmt_misc may break some setups when the interpreter of some misc binaries is a script. So the proposal is to turn sh_bang into a bit, add a new one (the misc_bang) and raise it in load_misc_binary. After this, even if we set up the misc -> script -> misc loop for binfmts one of them will step on its own bang and exit. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
