path: root/fs/binfmt_flat.c
2006-01-10[PATCH] uclinux: delay binfmt_flat traceGreg Ungerer
Modify the initial trace output (which is based on flags in the binary header) so that it is not done until after the magic number check. This may well not be a flat format binary, so the flags could be invalid. (Prime example, running a script). Changes prompted by patches from Stuart Hughs. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] dump_thread() cleanupakpm@osdl.org
) From: Adrian Bunk <bunk@stusta.de> - create one common dump_thread() prototype in kernel.h - dump_thread() is only used in fs/binfmt_aout.c and can therefore be removed on all architectures where CONFIG_BINFMT_AOUT is not available Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-29[PATCH] mm: mm_init set_mm_countersHugh Dickins
How is anon_rss initialized? In dup_mmap, and by mm_alloc's memset; but that's not so good if an mm_counter_t is a special type. And how is rss initialized? By set_mm_counter, all over the place. Come on, we just need to initialize them both at once by set_mm_counter in mm_init (which follows the memcpy when forking). Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-02[PATCH] uclinux: use MAP_PRIVATE when mmaping code regions in flat binary loaderGreg Ungerer
Use MAP_PRIVATE when calling mmap to get memory for the code region. The flat loader was using MAP_SHARED, but underlying changes to the MMUless mmap means this is now wrong. Signed-off-by: Greg Ungerer <gerg@uclinux.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-06[PATCH] binfmt_flat mmap flag fixYoshinori Sato
Make sure that binfmt_flat passes the correct flags into do_mmap(). nommu's validate_mmap_request() will simple return -EINVAL if we try and pass it a flags value of zero. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
