Instead of always assigning an increasing inode number in new_inode
move the call to assign it into those callers that actually need it.
For now callers that need it is estimated conservatively, that is
the call is added to all filesystems that do not assign an i_ino
by themselves. For a few more filesystems we can avoid assigning
any inode number given that they aren't user visible, and for others
it could be done lazily when an inode number is actually needed,
but that's left for later patches.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
Commit 74641f584da ("alpha: binfmt_aout fix") (May 2009) introduced a
regression - binfmt_misc is now consulted after binfmt_elf, which will
unfortunately break ia32el. ia32 ELF binaries on ia64 used to be matched
using binfmt_misc and executed using wrapper. As 32bit binaries are now
matched by binfmt_elf before bindmt_misc kicks in, the wrapper is ignored.
The fix increases precedence of binfmt_misc to the original state.
Signed-off-by: Jan Sembera <jsembera@suse.cz>
Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Richard Henderson <rth@twiddle.net
Cc: <stable@kernel.org> [2.6.everything.x]
Make do_execve() take a const filename pointer so that kernel_execve() compiles
correctly on ARM:
arch/arm/kernel/sys_arm.c:88: warning: passing argument 1 of 'do_execve' discards qualifiers from pointer target type
This also requires the argv and envp arguments to be consted twice, once for
the pointer array and once for the strings the array points to. This is
because do_execve() passes a pointer to the filename (now const) to
copy_strings_kernel(). A simpler alternative would be to cast the filename
pointer in do_execve() when it's passed to copy_strings_kernel().
do_execve() may not change any of the strings it is passed as part of the argv
or envp lists as they are some of them in .rodata, so marking these strings as
const should be fine.
Further kernel_execve() and sys_execve() need to be changed to match.
This has been test built on x86_64, frv, arm and mips.
Tested-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
The following is what it looks like before patching.
It is not much readable.
user@ubuntu:/proc/sys/fs/binfmt_misc$ cat status
enableduser@ubuntu:/proc/sys/fs/binfmt_misc$
Signed-off-by: Qinghuang Feng <qhfeng.kernel@gmail.com>
... and don't bother in callers. Don't bother with zeroing i_blocks,
while we are at it - it's already been zeroed.
i_mode is not worth the effort; it has no common default value.
binfmt_script and binfmt_misc disallow recursion to avoid stack overflow
using sh_bang and misc_bang. It causes problem in some cases:
$ echo '#!/bin/ls' > /tmp/t0
$ echo '#!/tmp/t0' > /tmp/t1
$ echo '#!/tmp/t1' > /tmp/t2
$ chmod +x /tmp/t*
$ /tmp/t2
zsh: exec format error: /tmp/t2
Similar problem with binfmt_misc.
This patch introduces field 'recursion_depth' into struct linux_binprm to
track recursion level in binfmt_misc and binfmt_script. If recursion
level more then BINPRM_MAX_RECURSION it generates -ENOEXEC.
[akpm@linux-foundation.org: make linux_binprm.recursion_depth a uint]
Signed-off-by: Kirill A. Shutemov <kirill@shutemov.name>
Cc: Pavel Emelyanov <xemul@openvz.org>
In case the binfmt_misc binary handler is registered *before* the e.g.
script one (when for example being compiled as a module) the following
situation may occur:
1. user launches a script, whose interpreter is a misc binary;
2. the load_misc_binary sets the misc_bang and returns -ENOEVEC,
since the binary is a script;
3. the load_script_binary loads one and calls for search_binary_hander
to run the interpreter;
4. the load_misc_binary is called again, but refuses to load the
binary due to misc_bang bit set.
The fix is to move the misc_bang setting lower - prior to the actual
call to the search_binary_handler.
Caused by the commit 3a2e7f47 (binfmt_misc.c: avoid potential kernel
stack overflow)
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Reported-by: Kirill A. Shutemov <kirill@shutemov.name>
Tested-by: Kirill A. Shutemov <kirill@shutemov.name>
Cc: <stable@kernel.org> [2.6.26.x]
This can be triggered with root help only, but...
Register the ":text:E::txt::/root/cat.txt:' rule in binfmt_misc (by root) and
try launching the cat.txt file (by anyone) :) The result is - the endless
recursion in the load_misc_binary -> open_exec -> load_misc_binary chain and
stack overflow.
There's a similar problem with binfmt_script, and there's a sh_bang memner on
linux_binprm structure to handle this, but simply raising this in binfmt_misc
may break some setups when the interpreter of some misc binaries is a script.
So the proposal is to turn sh_bang into a bit, add a new one (the misc_bang)
and raise it in load_misc_binary. After this, even if we set up the misc ->
script -> misc loop for binfmts one of them will step on its own bang and
exit.
* unshare_files() can fail; doing it after irreversible actions is wrong
and de_thread() is certainly irreversible.
* since we do it unconditionally anyway, we might as well do it in do_execve()
and save ourselves the PITA in binfmt handlers, etc.
* while we are at it, binfmt_som actually leaked files_struct on failure.
As a side benefit, unshare_files(), put_files_struct() and reset_files_struct()
become unexported.
* Convert files to UTF-8.
* Also correct some people's names
(one example is Eißfeldt, which was found in a source file.
Given that the author used an ß at all in a source file
indicates that the real name has in fact a 'ß' and not an 'ss',
which is commonly used as a substitute for 'ß' when limited to
7bit.)
* Correct town names (Goettingen -> Göttingen)
* Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313)
Signed-off-by: Jan Engelhardt <jengelh@gmx.de>
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Remove the arg+env limit of MAX_ARG_PAGES by copying the strings directly from
the old mm into the new mm.
We create the new mm before the binfmt code runs, and place the new stack at
the very top of the address space. Once the binfmt code runs and figures out
where the stack should be, we move it downwards.
It is a bit peculiar in that we have one task with two mm's, one of which is
inactive.
[a.p.zijlstra@chello.nl: limit stack size]
Signed-off-by: Ollie Wild <aaw@google.com>
Cc: <linux-arch@vger.kernel.org>
Cc: Hugh Dickins <hugh@veritas.com>
[bunk@stusta.de: unexport bprm_mm_init]
First thing mm.h does is including sched.h solely for can_do_mlock() inline
function which has "current" dereference inside. By dealing with can_do_mlock()
mm.h can be detached from sched.h which is good. See below, why.
This patch
a) removes unconditional inclusion of sched.h from mm.h
b) makes can_do_mlock() normal function in mm/mlock.c
c) exports can_do_mlock() to not break compilation
d) adds sched.h inclusions back to files that were getting it indirectly.
e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were
getting them indirectly
Net result is:
a) mm.h users would get less code to open, read, preprocess, parse, ... if
they don't need sched.h
b) sched.h stops being dependency for significant number of files:
on x86_64 allmodconfig touching sched.h results in recompile of 4083 files,
after patch it's only 3744 (-8.3%).
Cross-compile tested on
all arm defconfigs, all mips defconfigs, all powerpc defconfigs,
alpha alpha-up
arm
i386 i386-up i386-defconfig i386-allnoconfig
ia64 ia64-up
m68k
mips
parisc parisc-up
powerpc powerpc-up
s390 s390-up
sparc sparc-up
sparc64 sparc64-up
um-x86_64
x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig
as well as my two usual configs.
Cleanup using simple_read_from_buffer() in binfmt_misc, configfs, and sysfs.
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Joel Becker <joel.becker@oracle.com>
their root inodes
This patch makes it so that simple_fill_super and get_sb_pseudo assign their
root inodes to be number 1. It also fixes up a couple of callers of
simple_fill_super that were passing in files arrays that had an index at
number 1, and adds a warning for any caller that sends in such an array.
It would have been nice to have made it so that it wasn't possible to make
such a collision, but some callers need to be able to control what inode
number their entries get, so I think this is the best that can be done.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
This patch is inspired by Arjan's "Patch series to mark struct
file_operations and struct inode_operations const".
Compile tested with gcc & sparse.
Signed-off-by: Josef 'Jeff' Sipek <jsipek@cs.sunysb.edu>
Run this:
#!/bin/sh
for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do
echo "De-casting $f..."
perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f
done
And then go through and reinstate those cases where code is casting pointers
to non-pointers.
And then drop a few hunks which conflicted with outstanding work.
Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Greg KH <greg@kroah.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Paul Fulghum <paulkf@microgate.com>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Karsten Keil <kkeil@suse.de>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Ian Kent <raven@themaw.net>
Cc: Steven French <sfrench@us.ibm.com>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
This patch changes struct file to use struct path instead of having
independent pointers to struct dentry and struct vfsmount, and converts all
users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}.
Additionally, it adds two #define's to make the transition easier for users of
the f_dentry and f_vfsmnt.
Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu>
Fixed race on put_files_struct on exec with proc. Restoring files on
current on error path may lead to proc having a pointer to already kfree-d
files_struct.
->files changing at exit.c and khtread.c are safe as exit_files() makes all
things under lock.
Found during OpenVZ stress testing.
[akpm@osdl.org: add export]
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
Signed-off-by: Kirill Korotaev <dev@openvz.org>
This eliminates the i_blksize field from struct inode. Filesystems that want
to provide a per-inode st_blksize can do so by providing their own getattr
routine instead of using the generic_fillattr() function.
Note that some filesystems were providing pretty much random (and incorrect)
values for i_blksize.
[bunk@stusta.de: cleanup]
[akpm@osdl.org: generic_fillattr() fix]
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
The following patches reduce the size of the VFS inode structure by 28 bytes
on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction
in the inode size on a UP kernel that is configured in a production mode
(i.e., with no spinlock or other debugging functions enabled; if you want to
save memory taken up by in-core inodes, the first thing you should do is
disable the debugging options; they are responsible for a huge amount of bloat
in the VFS inode structure).
This patch:
The filesystem or device-specific pointer in the inode is inside a union,
which is pretty pointless given that all 30+ users of this field have been
using the void pointer. Get rid of the union and rename it to i_private, with
a comment to explain who is allowed to use the void pointer. This is just a
cleanup, but it allows us to reuse the union 'u' for something something where
the union will actually be used.
[judith@osdl.org: powerpc build fix]
Signed-off-by: Judith Lebzelter <judith@osdl.org>
fs/nfs/inode.c
fs/super.c
Fix conflicts between patch 'NFS: Split fs/nfs/inode.c' and patch
'VFS: Permit filesystem to override root dentry on mount'
Extend the get_sb() filesystem operation to take an extra argument that
permits the VFS to pass in the target vfsmount that defines the mountpoint.
The filesystem is then required to manually set the superblock and root dentry
pointers. For most filesystems, this should be done with simple_set_mnt()
which will set the superblock pointer and then set the root dentry to the
superblock's s_root (as per the old default behaviour).
The get_sb() op now returns an integer as there's now no need to return the
superblock pointer.
This patch permits a superblock to be implicitly shared amongst several mount
points, such as can be done with NFS to avoid potential inode aliasing. In
such a case, simple_set_mnt() would not be called, and instead the mnt_root
and mnt_sb would be set directly.
The patch also makes the following changes:
(*) the get_sb_*() convenience functions in the core kernel now take a vfsmount
pointer argument and return an integer, so most filesystems have to change
very little.
(*) If one of the convenience function is not used, then get_sb() should
normally call simple_set_mnt() to instantiate the vfsmount. This will
always return 0, and so can be tail-called from get_sb().
(*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the
dcache upon superblock destruction rather than shrink_dcache_anon().
This is required because the superblock may now have multiple trees that
aren't actually bound to s_root, but that still need to be cleaned up. The
currently called functions assume that the whole tree is rooted at s_root,
and that anonymous dentries are not the roots of trees which results in
dentries being left unculled.
However, with the way NFS superblock sharing are currently set to be
implemented, these assumptions are violated: the root of the filesystem is
simply a dummy dentry and inode (the real inode for '/' may well be
inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries
with child trees.
[*] Anonymous until discovered from another tree.
(*) The documentation has been adjusted, including the additional bit of
changing ext2_* into foo_* in the documentation.
[akpm@osdl.org: convert ipath_fs, do other stuff]
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Nathan Scott <nathans@sgi.com>
Cc: Roland Dreier <rolandd@cisco.com>
This patch removes the steal_locks() function.
steal_locks() doesn't work correctly with any filesystem that does it's own
lock management, including NFS, CIFS, etc.
In addition it has weird semantics on local filesystems in case tasks
sharing file-descriptor tables are doing POSIX locking operations in
parallel to execve().
The steal_locks() function has an effect on applications doing:
clone(CLONE_FILES)
/* in child */
lock
execve
lock
POSIX locks acquired before execve (by "child", "parent" or any further
task sharing files_struct) will after the execve be owned exclusively by
"child".
According to Chris Wright some LSB/LTP kind of suite triggers without the
stealing behavior, but there's no known real-world application that would
also fail.
Apps using NPTL are not affected, since all other threads are killed before
execve.
Apps using LinuxThreads are only affected if they
- have multiple threads during exec (LinuxThreads doesn't kill other
threads, the app may do it with pthread_kill_other_threads_np())
- rely on POSIX locks being inherited across exec
Both conditions are documented, but not their interaction.
Apps using clone() natively are affected if they
- use clone(CLONE_FILES)
The above scenarios are unlikely, but possible.
If the patch is vetoed, there's a plan B, that involves mostly keeping the
weird stealing semantics, but changing the way lock ownership is handled so
that network and local filesystems work consistently.
That would add more complexity though, so this solution seems to be
preferred by most people.
Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Matthew Wilcox <willy@debian.org>
Cc: Chris Wright <chrisw@sous-sol.org>
Replace all module uses with the new vfs_kern_mount() interface, and fix up
simple_pin_fs().
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
This is a conversion to make the various file_operations structs in fs/
const. Basically a regexp job, with a few manual fixups
The goal is both to increase correctness (harder to accidentally write to
shared datastructures) and reducing the false sharing of cachelines with
things that get dirty in .data (while .rodata is nicely read only and thus
cache clean)
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
Remove the "inline" keyword from a bunch of big functions in the kernel with
the goal of shrinking it by 30kb to 40kb
Acked-by: Jeff Garzik <jgarzik@pobox.com>
This patch converts the inode semaphore to a mutex. I have tested it on
XFS and compiled as much as one can consider on an ia64. Anyway your
luck with it might be different.
Modified-by: Ingo Molnar <mingo@elte.hu>
(finished the conversion)
Signed-off-by: Jes Sorensen <jes@sgi.com>
A few more callers of permission() just want to check for a different access
pattern on an already open file. This patch adds a wrapper for permission()
that takes a file in preparation of per-mount read-only support and to clean
up the callers a little. The helper is not intended for new code, everything
without the interface set in stone should use vfs_permission()
infrastructure for it.
Let it rip!
