path: root/fs/binfmt_misc.c
2008-08-20binfmt_misc: fix false -ENOEXEC when coupled with other binary handlersPavel Emelyanov
In case the binfmt_misc binary handler is registered *before* the e.g. script one (when for example being compiled as a module) the following situation may occur: 1. user launches a script, whose interpreter is a misc binary; 2. the load_misc_binary sets the misc_bang and returns -ENOEVEC, since the binary is a script; 3. the load_script_binary loads one and calls for search_binary_hander to run the interpreter; 4. the load_misc_binary is called again, but refuses to load the binary due to misc_bang bit set. The fix is to move the misc_bang setting lower - prior to the actual call to the search_binary_handler. Caused by the commit 3a2e7f47 (binfmt_misc.c: avoid potential kernel stack overflow) Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Reported-by: Kirill A. Shutemov <kirill@shutemov.name> Tested-by: Kirill A. Shutemov <kirill@shutemov.name> Cc: <stable@kernel.org> [2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24binfmt_misc: use simple_read_from_buffer()Akinobu Mita
Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29binfmt_misc.c: avoid potential kernel stack overflowPavel Emelyanov
This can be triggered with root help only, but... Register the ":text:E::txt::/root/cat.txt:' rule in binfmt_misc (by root) and try launching the cat.txt file (by anyone) :) The result is - the endless recursion in the load_misc_binary -> open_exec -> load_misc_binary chain and stack overflow. There's a similar problem with binfmt_script, and there's a sh_bang memner on linux_binprm structure to handle this, but simply raising this in binfmt_misc may break some setups when the interpreter of some misc binaries is a script. So the proposal is to turn sh_bang into a bit, add a new one (the misc_bang) and raise it in load_misc_binary. After this, even if we set up the misc -> script -> misc loop for binfmts one of them will step on its own bang and exit. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-25[PATCH] sanitize handling of shared descriptor tables in failing execve()Al Viro
* unshare_files() can fail; doing it after irreversible actions is wrong and de_thread() is certainly irreversible. * since we do it unconditionally anyway, we might as well do it in do_execve() and save ourselves the PITA in binfmt handlers, etc. * while we are at it, binfmt_som actually leaked files_struct on failure. As a side benefit, unshare_files(), put_files_struct() and reset_files_struct() become unexported. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-07-19mm: variable length argument supportOllie Wild
Remove the arg+env limit of MAX_ARG_PAGES by copying the strings directly from the old mm into the new mm. We create the new mm before the binfmt code runs, and place the new stack at the very top of the address space. Once the binfmt code runs and figures out where the stack should be, we move it downwards. It is a bit peculiar in that we have one task with two mm's, one of which is inactive. [a.p.zijlstra@chello.nl: limit stack size] Signed-off-by: Ollie Wild <aaw@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <linux-arch@vger.kernel.org> Cc: Hugh Dickins <hugh@veritas.com> [bunk@stusta.de: unexport bprm_mm_init] Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09use simple_read_from_buffer() in fs/Akinobu Mita
Cleanup using simple_read_from_buffer() in binfmt_misc, configfs, and sysfs. Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Joel Becker <joel.becker@oracle.com> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08inode numbering: change libfs sb creation routines to avoid collisions with ↵Jeff Layton
their root inodes This patch makes it so that simple_fill_super and get_sb_pseudo assign their root inodes to be number 1. It also fixes up a couple of callers of simple_fill_super that were passing in files arrays that had an index at number 1, and adds a warning for any caller that sends in such an array. It would have been nice to have made it so that it wasn't possible to make such a collision, but some callers need to be able to control what inode number their entries get, so I think this is the best that can be done. Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-13[PATCH] getting rid of all casts of k[cmz]alloc() callsRobert P. J. Day
Run this: #!/bin/sh for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do echo "De-casting $f..." perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f done And then go through and reinstate those cases where code is casting pointers to non-pointers. And then drop a few hunks which conflicted with outstanding work. Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com> Cc: Mikael Starvik <starvik@axis.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Greg KH <greg@kroah.com> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Paul Fulghum <paulkf@microgate.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Karsten Keil <kkeil@suse.de> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Ian Kent <raven@themaw.net> Cc: Steven French <sfrench@us.ibm.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Jaroslav Kysela <perex@suse.cz> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Fix unserialized task->files changingKirill Korotaev
Fixed race on put_files_struct on exec with proc. Restoring files on current on error path may lead to proc having a pointer to already kfree-d files_struct. ->files changing at exit.c and khtread.c are safe as exit_files() makes all things under lock. Found during OpenVZ stress testing. [akpm@osdl.org: add export] Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] inode_diet: Replace inode.u.generic_ip with inode.i_privateTheodore Ts'o
The following patches reduce the size of the VFS inode structure by 28 bytes on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction in the inode size on a UP kernel that is configured in a production mode (i.e., with no spinlock or other debugging functions enabled; if you want to save memory taken up by in-core inodes, the first thing you should do is disable the debugging options; they are responsible for a huge amount of bloat in the VFS inode structure). This patch: The filesystem or device-specific pointer in the inode is inside a union, which is pretty pointless given that all 30+ users of this field have been using the void pointer. Get rid of the union and rename it to i_private, with a comment to explain who is allowed to use the void pointer. This is just a cleanup, but it allows us to reuse the union 'u' for something something where the union will actually be used. [judith@osdl.org: powerpc build fix] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Judith Lebzelter <judith@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-24Merge branch 'master' of /home/trondmy/kernel/linux-2.6/Trond Myklebust
Conflicts: fs/nfs/inode.c fs/super.c Fix conflicts between patch 'NFS: Split fs/nfs/inode.c' and patch 'VFS: Permit filesystem to override root dentry on mount'
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[PATCH] remove steal_locks()Miklos Szeredi
This patch removes the steal_locks() function. steal_locks() doesn't work correctly with any filesystem that does it's own lock management, including NFS, CIFS, etc. In addition it has weird semantics on local filesystems in case tasks sharing file-descriptor tables are doing POSIX locking operations in parallel to execve(). The steal_locks() function has an effect on applications doing: clone(CLONE_FILES) /* in child */ lock execve lock POSIX locks acquired before execve (by "child", "parent" or any further task sharing files_struct) will after the execve be owned exclusively by "child". According to Chris Wright some LSB/LTP kind of suite triggers without the stealing behavior, but there's no known real-world application that would also fail. Apps using NPTL are not affected, since all other threads are killed before execve. Apps using LinuxThreads are only affected if they - have multiple threads during exec (LinuxThreads doesn't kill other threads, the app may do it with pthread_kill_other_threads_np()) - rely on POSIX locks being inherited across exec Both conditions are documented, but not their interaction. Apps using clone() natively are affected if they - use clone(CLONE_FILES) - rely on POSIX locks being inherited across exec The above scenarios are unlikely, but possible. If the patch is vetoed, there's a plan B, that involves mostly keeping the weird stealing semantics, but changing the way lock ownership is handled so that network and local filesystems work consistently. That would add more complexity though, so this solution seems to be preferred by most people. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Matthew Wilcox <willy@debian.org> Cc: Chris Wright <chrisw@sous-sol.org> Cc: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-09VFS: Unexport do_kern_mount() and clean up simple_pin_fs()Trond Myklebust
Replace all module uses with the new vfs_kern_mount() interface, and fix up simple_pin_fs(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-11-09[PATCH] add a file_permission helperChristoph Hellwig
A few more callers of permission() just want to check for a different access pattern on an already open file. This patch adds a wrapper for permission() that takes a file in preparation of per-mount read-only support and to clean up the callers a little. The helper is not intended for new code, everything without the interface set in stone should use vfs_permission() Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
