path: root/fs/bio.c
2006-11-07[PATCH] md: Make sure bi_max_vecs is set properly in bio_splitNeil Brown
Else a subsequent bio_clone might make a mess. Signed-off-by: Neil Brown <neilb@suse.de> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-08-11Fix missing ret assignment in __bio_map_user() error pathJens Axboe
If get_user_pages() returns less pages than what we asked for, we jump to out_unmap which will return ERR_PTR(ret). But ret can contain a positive number just smaller than local_nr_pages, so be sure to set it to -EFAULT always. Problem found and diagnosed by Damien Le Moal <damien@sdl.hitachi.co.jp> Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-31[BLOCK] A few kerneldoc fixupsJens Axboe
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[BLOCK] bio: init ->bi_bdev in bio_init()Jens Axboe
For SG_IO requests, bio->bi_bdev may not be explicitly initialized. So make bio_init() clear the field to make sure it's always NULL or valid. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-06[BLOCK] bio: check for same page merge possibilities in __bio_add_page()Jens Axboe
For filesystems with a blocksize < page size, we can merge same page calls into the bio_vec at the end of the bio. This saves segments on systems with a page size > the "normal" 4kb fs block size. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <axboe@suse.de>
2005-12-15[SCSI] seperate max_sectors from max_hw_sectorsMike Christie
- export __blk_put_request and blk_execute_rq_nowait needed for async REQ_BLOCK_PC requests - seperate max_hw_sectors and max_sectors for block/scsi_ioctl.c and SG_IO bio.c helpers per Jens's last comments. Since block/scsi_ioctl.c SG_IO was already testing against max_sectors and SCSI-ml was setting max_sectors and max_hw_sectors to the same value this does not change any scsi SG_IO behavior. It only prepares ll_rw_blk.c, scsi_ioctl.c and bio.c for when SCSI-ml begins to set a valid max_hw_sectors for all LLDs. Today if a LLD does not set it SCSI-ml sets it to a safe default and some LLDs set it to a artificial low value to overcome memory and feedback issues. Note: Since we now cap max_sectors to BLK_DEF_MAX_SECTORS, which is 1024, drivers that used to call blk_queue_max_sectors with a large value of max_sectors will now see the fs requests capped to BLK_DEF_MAX_SECTORS. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-14[SCSI] Convert SCSI mid-layer to scsi_execute_asyncMike Christie
Add scsi helpers to create really-large-requests and convert scsi-ml to scsi_execute_async(). Per Jens's previous comments, I placed this function in scsi_lib.c. I made it follow all the queue's limits - I think I did at least :), so I removed the warning on the function header. I think the scsi_execute_* functions should eventually take a request_queue and be placed some place where the dm-multipath hw_handler can use them if that failover code is going to stay in the kernel. That conversion patch will be sent in another mail though. Signed-off-by: Mike Christie <michaelc@cs.wisc.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-10-28[PATCH] gfp_t: fs/*Al Viro
- ->releasepage() annotated (s/int/gfp_t), instances updated - missing gfp_t in fs/* added - fixed misannotation from the original sweep caught by bitwise checks: XFS used __nocast both for gfp_t and for flags used by XFS allocator. The latter left with unsigned int __nocast; we might want to add a different type for those but for now let's leave them alone. That, BTW, is a case when __nocast use had been actively confusing - it had been used in the same code for two different and similar types, with no way to catch misuses. Switch of gfp_t to bitwise had caught that immediately... One tricky bit is left alone to be dealt with later - mapping->flags is a mix of gfp_t and error indications. Left alone for now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-08[PATCH] gfp flags annotations - part 1Al Viro
- added typedef unsigned int __nocast gfp_t; - replaced __nocast uses for gfp flags with gfp_t - it gives exactly the same warnings as far as sparse is concerned, doesn't change generated code (from gcc point of view we replaced unsigned int with typedef) and documents what's going on far better. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] bogus cast in bio.cviro@ZenIV.linux.org.uk
<qualifier> void * is not the same as void <qualifier> *... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-for-linus-2.6 Linus Torvalds
2005-09-07[PATCH] kill bio->bi_setPeter Osterlund
Jens: ->bi_set is totally unnecessary bloat of struct bio. Just define a proper destructor for the bio and it already knows what bio_set it belongs too. Peter: Fixed the bugs. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-28fix mismerge in ll_rw_blk.cJames Bottomley
2005-08-07[PATCH] __bio_clone() dead commentAndrew Morton
Remove a very wrong comment. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-28[PATCH] bio_clone fixAndrew Morton
Fix bug introduced in 2.6.11-rc2: when we clone a BIO we need to copy over the current index into it as well. It corrupts data with some MD setups. See http://bugzilla.kernel.org/show_bug.cgi?id=4946 Huuuuuuuuge thanks to Matthew Stapleton <matthew4196@gmail.com> for doggedly chasing this one down. Acked-by: Jens Axboe <axboe@suse.de> Cc: <linux-raid@vger.kernel.org> Cc: <dm-devel@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] mostly_read data sectionChristoph Lameter
Add a new section called ".data.read_mostly" for data items that are read frequently and rarely written to like cpumaps etc. If these maps are placed in the .data section then these frequenly read items may end up in cachelines with data is is frequently updated. In that case all processors in an SMP system must needlessly reload the cachelines again and again containing elements of those frequently used variables. The ability to share these cachelines will allow each cpu in an SMP system to keep local copies of those shared cachelines thereby optimizing performance. Signed-off-by: Alok N Kataria <alokk@calsoftinc.com> Signed-off-by: Shobhit Dayal <shobhit@calsoftinc.com> Signed-off-by: Christoph Lameter <christoph@scalex86.org> Signed-off-by: Shai Fultheim <shai@scalex86.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Add scatter-gather support for the block layer SG_IOJames Bottomley
2005-06-20[PATCH] Keep the bio end_io parts inside of bio.c for blk_rq_map_kern()Jens Axboe
2005-06-20[PATCH] Add blk_rq_map_kern()Mike Christie
Add blk_rq_map_kern which takes a kernel buffer and maps it into a request and bio. This can be used by the dm hw_handlers, old sg_scsi_ioctl, and one day scsi special requests so all requests comming into scsi will have bios. All requests having bios should allow scsi to use scatter lists for all IO and allow it to use block layer functions. Signed-off-by: Jens Axboe <axboe@suse.de>
2005-05-01[PATCH] DocBook: fix some descriptionsMartin Waitz
Some KernelDoc descriptions are updated to match the current code. No code changes. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
