path: root/fs/block_dev.c
2007-05-08is_power_of_2 in fs/block_dev.cVignesh Babu BM
Replace (n & (n-1)) in the context of power of 2 checks with is_power_of_2 Signed-off-by: vignesh babu <vignesh.babu@wipro.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: optimize kill_bdev()Peter Zijlstra
Remove duplicate work in kill_bdev(). It currently invalidates and then truncates the bdev's mapping. invalidate_mapping_pages() will opportunistically remove pages from the mapping. And truncate_inode_pages() will forcefully remove all pages. The only thing truncate doesn't do is flush the bh lrus. So do that explicitly. This avoids (very unlikely) but possible invalid lookup results if the same bdev is quickly re-issued. It also will prevent extreme kernel latencies which are observed when blockdevs which have a large amount of pagecache are unmounted, by avoiding invalidate_mapping_pages() on that path. invalidate_mapping_pages() has no cond_resched (it can be called under spinlock), whereas truncate_inode_pages() has one. [akpm@linux-foundation.org: restore nrpages==0 optimisation] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: remove destroy_dirty_buffers from invalidate_bdev()Peter Zijlstra
Remove the destroy_dirty_buffers argument from invalidate_bdev(), it hasn't been used in 6 years (so akpm says). find * -name \*.[ch] | xargs grep -l invalidate_bdev | while read file; do quilt add $file; sed -ie 's/invalidate_bdev(\([^,]*\),[^)]*)/invalidate_bdev(\1)/g' $file; done Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] lockdep: annotate BLKPG_DEL_PARTITIONPeter Zijlstra
>============================================= >[ INFO: possible recursive locking detected ] >2.6.19-1.2909.fc7 #1 >--------------------------------------------- >anaconda/587 is trying to acquire lock: > (&bdev->bd_mutex){--..}, at: [<c05fb380>] mutex_lock+0x21/0x24 > >but task is already holding lock: > (&bdev->bd_mutex){--..}, at: [<c05fb380>] mutex_lock+0x21/0x24 > >other info that might help us debug this: >1 lock held by anaconda/587: > #0: (&bdev->bd_mutex){--..}, at: [<c05fb380>] mutex_lock+0x21/0x24 > >stack backtrace: > [<c0405812>] show_trace_log_lvl+0x1a/0x2f > [<c0405db2>] show_trace+0x12/0x14 > [<c0405e36>] dump_stack+0x16/0x18 > [<c043bd84>] __lock_acquire+0x116/0xa09 > [<c043c960>] lock_acquire+0x56/0x6f > [<c05fb1fa>] __mutex_lock_slowpath+0xe5/0x24a > [<c05fb380>] mutex_lock+0x21/0x24 > [<c04d82fb>] blkdev_ioctl+0x600/0x76d > [<c04946b1>] block_ioctl+0x1b/0x1f > [<c047ed5a>] do_ioctl+0x22/0x68 > [<c047eff2>] vfs_ioctl+0x252/0x265 > [<c047f04e>] sys_ioctl+0x49/0x63 > [<c0404070>] syscall_call+0x7/0xb Annotate BLKPG_DEL_PARTITION's bd_mutex locking and add a little comment clarifying the bd_mutex locking, because I confused myself and initially thought the lock order was wrong too. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-03[PATCH] revert blockdev direct io back to 2.6.19 versionAndrew Morton
Andrew Vasquez is reporting as-iosched oopses and a 65% throughput slowdown due to the recent special-casing of direct-io against blockdevs. We don't know why either of these things are occurring. The patch minimally reverts us back to the 2.6.19 code for a 2.6.20 release. Cc: Andrew Vasquez <andrew.vasquez@qlogic.com> Cc: Ken Chen <kenchen@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23[PATCH] fix blk_direct_IO bio preparationChen, Kenneth W
For large size DIO that needs multiple bio, one full page worth of data was lost at the boundary of bio's maximum sector or segment limits. After a bio is full and got submitted. The outer while (nbytes) { ... } loop will allocate a new bio and just march on to index into next page. It just forgets about the page that bio_add_page() rejected when previous bio is full. Fix it by put the rejected page back to pvec so we pick it up again for the next bio. Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23[PATCH] blockdev direct_io: fix signedness bugAndrew Morton
size_t is unsigned. IO errors aren't getting through. Cc: "Chen, Kenneth W" <kenneth.w.chen@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-11[PATCH] Revert bd_mount_mutex back to a semaphoreDavid Chinner
Revert bd_mount_mutex back to a semaphore so that xfs_freeze -f /mnt/newtest; xfs_freeze -u /mnt/newtest works safely and doesn't produce lockdep warnings. (XFS unlocks the semaphore from a different task, by design. The mutex code warns about this) Signed-off-by: Dave Chinner <dgc@sgi.com> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] optimize o_direct on block devicesChen, Kenneth W
Implement block device specific .direct_IO method instead of going through generic direct_io_worker for block device. direct_io_worker() is fairly complex because it needs to handle O_DIRECT on file system, where it needs to perform block allocation, hole detection, extents file on write, and tons of other corner cases. The end result is that it takes tons of CPU time to submit an I/O. For block device, the block allocation is much simpler and a tight triple loop can be written to iterate each iovec and each page within the iovec in order to construct/prepare bio structure and then subsequently submit it to the block layer. This significantly speeds up O_D on block device. [akpm@osdl.org: small speedup] Signed-off-by: Ken Chen <kenneth.w.chen@intel.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Zach Brown <zach.brown@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] bdev: fix ->bd_part_count leakPeter Zijlstra
Don't leak a ->bd_part_count when the partition open fails with -ENXIO. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] lockdep: use mutex_lock_nested for bd_mutex to avoid lockdep warningNeilBrown
Now that the nesting in blkdev_{get,put} is simpler, adding mutex_lock_nested is trivial. Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] lockdep: simplify some aspects of bd_mutex nestingNeilBrown
When we open (actually blkdev_get) a partition we need to also open (get) the whole device that holds the partition. The involves some limited recursion. This patch tries to simplify some aspects of this. As well as opening the whole device, we need to increment ->bd_part_count when a partition is opened (this is used by rescan_partitions to avoid a rescan if any partition is active, as that would be confusing). The main change this patch makes is to move the inc/dec of bd_part_count into blkdev_{get,put} for the whole rather than doing it in blkdev_{get,put} for the partition. More specifically, we introduce __blkdev_get and __blkdev_put which do exactly what blkdev_{get,put} did, only with an extra "for_part" argument (blkget_{get,put} then call the __ version with a '0' for the extra argument). If for_part is 1, then the blkdev is being get(put) because a partition is being opened(closed) for the first(last) time, and so bd_part_count should be updated (on success). The particular advantage of pushing this function down is that the bd_mutex lock (which is needed to update bd_part_count) is already held at the lower level. Note that this slightly changes the semantics of bd_part_count. Instead of updating it whenever a partition is opened or released, it is now only updated on the first open or last release. This is an adequate semantic as it is only ever tested for "== 0". Having introduced these functions we remove the current bd_part_count updates from do_open (which is really the body of blkdev_get) and call __blkdev_get(... 1). Similarly in blkget_put we remove the old bd_part_count updates and call __blkget_put(..., 1). This call is moved to the end of __blkdev_put to avoid nested locks of bd_mutex. Finally the mutex_lock on whole->bd_mutex in do_open can be removed. It was only really needed to protect bd_part_count, and that is now managed (and protected) within the recursive call. The observation that bd_part_count is central to the locking issues, and the modifications to create __blkdev_put are from Peter Zijlstra. Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] lockdep: remove lock_key approach to managing nested bd_mutex locksNeilBrown
The extra call to get_gendisk is not good. It causes a ->probe and possible module load before it is really appropriate to do this. Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] new bd_mutex lockdep annotationPeter Zijlstra
Use the gendisk partition number to set a lock class. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Ingo Molnar <mingo@elte.hu> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] remove the old bd_mutex lockdep annotationPeter Zijlstra
Remove the old complex and crufty bd_mutex annotation. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Jason Baron <jbaron@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-31[PATCH] find_bd_holder() fixAndrew Morton
fs/block_dev.c: In function 'find_bd_holder': fs/block_dev.c:666: warning: return makes integer from pointer without a cast fs/block_dev.c:669: warning: return makes integer from pointer without a cast fs/block_dev.c: In function 'add_bd_holder': fs/block_dev.c:685: warning: unused variable 'tmp' fs/block_dev.c: In function 'bd_claim_by_kobject': fs/block_dev.c:773: warning: assignment makes pointer from integer without a cast Acked-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] clean up add_bd_holder()Jun'ichi Nomura
add_bd_holder() is called from bd_claim_by_kobject to put a given struct bd_holder in the list if there is no matching entry. There are 3 possible results of add_bd_holder(): 1. there is no matching entry and add the given one to the list 2. there is matching entry, so just increment reference count of the existing one 3. something failed during its course 1 and 2 are successful cases. But for case 2, someone has to free the unused struct bd_holder. The current code frees it inside of add_bd_holder and returns same value 0 for both cases 1 and 2. However, it's natural and less error-prone if caller frees it since it's allocated by the caller. Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-30[PATCH] fix bd_claim_by_kobject error handlingJun'ichi Nomura
This fixes bd_claim_by_kobject to release bdev correctly in case that bd_claim succeeds but following add_bd_holder fails. Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-28[PATCH] Fix potential OOPs in blkdev_open()Pavel Emelianov
blkdev_open() calls bc_acquire() to get a struct block_device. Since bc_acquire() may return NULL when system is out of memory an appropriate check is required. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Remove readv/writev methods and use aio_read/aio_write insteadBadari Pulavarty
This patch removes readv() and writev() methods and replaces them with aio_read()/aio_write() methods. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Vectorize aio_read/aio_write fileop methodsBadari Pulavarty
This patch vectorizes aio_read() and aio_write() methods to prepare for collapsing all aio & vectored operations into one interface - which is aio_read()/aio_write(). Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Michael Holzheu <HOLZHEU@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Move __invalidate_device() to block_dev.c [try #6]David Howells
Move __invalidate_device() from fs/inode.c to fs/block_dev.c so that it can more easily be disabled when the block layer is disabled. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Dissociate generic_writepages() from mpage stuff [try #6]David Howells
Dissociate the generic_writepages() function from the mpage stuff, moving its declaration to linux/mm.h and actually emitting a full implementation into mm/page-writeback.c. The implementation is a partial duplicate of mpage_writepages() with all BIO references removed. It is used by NFS to do writeback. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move extern declarations out of fs/*.c into header files [try #6]David Howells
Create a new header file, fs/internal.h, for common definitions local to the sources in the fs/ directory. Move extern definitions that should be in header files from fs/*.c to fs/internal.h or other main header files where they span directories. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-29[PATCH] block_dev.c mutex_lock_nested() fixJason Baron
In the case below we are locking the whole disk not a partition. This change simply brings the code in line with the piece above where when we are the 'first' opener, and we are a partition. Signed-off-by: Jason Baron <jbaron@redhat.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] blockdev.c: check driver layer errorsAndrew Morton
Check driver layer errors. Fix from: "Jun'ichi Nomura" <j-nomura@ce.jp.nec.com> In blockdevc-check-errors.patch, add_bd_holder() is modified to return error values when some of its operation failed. Among them, it returns -EEXIST when a given bd_holder object already exists in the list. However, in this case, the function completed its work successfully and need no action by its caller other than freeing unused bd_holder object. So I think it's better to return success after freeing by itself. Otherwise, bd_claim-ing with same claim pointer will fail. Typically, lvresize will fails with following message: device-mapper: reload ioctl failed: Invalid argument and you'll see messages like below in kernel log: device-mapper: table: 254:13: linear: dm-linear: Device lookup failed device-mapper: ioctl: error adding target to table Similarly, it should not add bd_holder to the list if either one of symlinking fails. I don't have a test case for this to happen but it should cause dereference of freed pointer. If a matching bd_holder is found in bd_holder_list, add_bd_holder() completes its job by just incrementing the reference count. In this case, it should be considered as success but it used to return 'fail' to let the caller free temporary bd_holder. Fixed it to return success and free given object by itself. Also, if either one of symlinking fails, the bd_holder should not be added to the list so that it can be discarded later. Otherwise, the caller will free bd_holder which is in the list. Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-27[PATCH] lockdep: fix blkdev_open() warningPeter Zijlstra
On Wed, 2006-08-09 at 07:57 +0200, Rolf Eike Beer wrote: > ============================================= > [ INFO: possible recursive locking detected ] > --------------------------------------------- > parted/7929 is trying to acquire lock: > (&bdev->bd_mutex){--..}, at: [<c105eb8d>] __blkdev_put+0x1e/0x13c > > but task is already holding lock: > (&bdev->bd_mutex){--..}, at: [<c105eec6>] do_open+0x72/0x3a8 > > other info that might help us debug this: > 1 lock held by parted/7929: > #0: (&bdev->bd_mutex){--..}, at: [<c105eec6>] do_open+0x72/0x3a8 > stack backtrace: > [<c1003aad>] show_trace_log_lvl+0x58/0x15b > [<c100495f>] show_trace+0xd/0x10 > [<c1004979>] dump_stack+0x17/0x1a > [<c102dee5>] __lock_acquire+0x753/0x99c > [<c102e3b0>] lock_acquire+0x4a/0x6a > [<c1204501>] mutex_lock_nested+0xc8/0x20c > [<c105eb8d>] __blkdev_put+0x1e/0x13c > [<c105ecc4>] blkdev_put+0xa/0xc > [<c105f18a>] do_open+0x336/0x3a8 > [<c105f21b>] blkdev_open+0x1f/0x4c > [<c1057b40>] __dentry_open+0xc7/0x1aa > [<c1057c91>] nameidata_to_filp+0x1c/0x2e > [<c1057cd1>] do_filp_open+0x2e/0x35 > [<c1057dd7>] do_sys_open+0x38/0x68 > [<c1057e33>] sys_open+0x16/0x18 > [<c1002845>] sysenter_past_esp+0x56/0x8d OK, I'm having a look here; its all new to me so bear with me. blkdev_open() calls do_open(bdev, ...,BD_MUTEX_NORMAL) and takes mutex_lock_nested(&bdev->bd_mutex, BD_MUTEX_NORMAL) then something fails, and we're thrown to: out_first: where if (bdev != bdev->bd_contains) blkdev_put(bdev->bd_contains) which is __blkdev_put(bdev->bd_contains, BD_MUTEX_NORMAL) which does mutex_lock_nested(&bdev->bd_contains->bd_mutex, BD_MUTEX_NORMAL) <--- lockdep trigger When going to out_first, dbev->bd_contains is either bdev or whole, and since we take the branch it must be whole. So it seems to me the following patch would be the right one: [akpm@osdl.org: compile fix] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arjan van de Ven <arjan@linux.intel.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: annotate blkdev nestingIngo Molnar
Teach special (recursive) locking code to the lock validator. Effects on non-lockdep kernels: - the introduction of the following function variants: extern struct block_device *open_partition_by_devnum(dev_t, unsigned); extern int blkdev_put_partition(struct block_device *); static int blkdev_get_whole(struct block_device *bdev, mode_t mode, unsigned flags); which on non-lockdep are the same as open_by_devnum(), blkdev_put() and blkdev_get(). - a subclass parameter to do_open(). [unused on non-lockdep] - a subclass parameter to __blkdev_put(), which is a new internal function for the main blkdev_put*() functions. [parameter unused on non-lockdep kernels, except for two sanity check WARN_ON()s] these functions carry no semantical difference - they only express object dependencies towards the lockdep subsystem. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-29Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/devfs-2.6: (22 commits) [PATCH] devfs: Remove it from the feature_removal.txt file [PATCH] devfs: Last little devfs cleanups throughout the kernel tree. [PATCH] devfs: Rename TTY_DRIVER_NO_DEVFS to TTY_DRIVER_DYNAMIC_DEV [PATCH] devfs: Remove the tty_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the line_driver devfs_name field as it's no longer needed [PATCH] devfs: Remove the videodevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the gendisk devfs_name field as it's no longer needed [PATCH] devfs: Remove the miscdevice devfs_name field as it's no longer needed [PATCH] devfs: Remove the devfs_fs_kernel.h file from the tree [PATCH] devfs: Remove devfs_remove() function from the kernel tree [PATCH] devfs: Remove devfs_mk_cdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_bdev() function from the kernel tree [PATCH] devfs: Remove devfs_mk_symlink() function from the kernel tree [PATCH] devfs: Remove devfs_mk_dir() function from the kernel tree [PATCH] devfs: Remove devfs_*_tape() functions from the kernel tree [PATCH] devfs: Remove devfs support from the sound subsystem [PATCH] devfs: Remove devfs support from the ide subsystem. [PATCH] devfs: Remove devfs support from the serial subsystem [PATCH] devfs: Remove devfs from the init code [PATCH] devfs: Remove devfs from the partition code ...
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] devfs: Remove the devfs_fs_kernel.h file from the treeGreg Kroah-Hartman
Also fixes up all files that #include it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-22[PATCH] Fix a race condition between ->i_mapping and iput()OGAWA Hirofumi
This race became a cause of oops, and can reproduce by the following. while true; do dd if=/dev/zero of=/dev/.static/dev/hdg1 bs=512 count=1000 & sync done This race condition was between __sync_single_inode() and iput(). cpu0 (fs's inode) cpu1 (bdev's inode) ----------------- ------------------- close("/dev/hda2") [...] __sync_single_inode() /* copy the bdev's ->i_mapping */ mapping = inode->i_mapping; generic_forget_inode() bdev_clear_inode() /* restre the fs's ->i_mapping */ inode->i_mapping = &inode->i_data; /* bdev's inode was freed */ destroy_inode(inode); if (wait) { /* dereference a freed bdev's mapping->host */ filemap_fdatawait(mapping); /* Oops */ Since __sync_single_inode() is only taking a ref-count of fs's inode, the another process can be close() and freeing the bdev's inode while writing fs's inode. So, __sync_signle_inode() accesses the freed ->i_mapping, oops. This patch takes a ref-count on the bdev's inode for the fs's inode before setting a ->i_mapping, and the clear_inode() of the fs's inode does iput() on the bdev's inode. So if the fs's inode is still living, bdev's inode shouldn't be freed. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-01[PATCH] Add ->splice_read/splice_write to def_blk_fopsJens Axboe
It can use the generic handlers. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] dm/md dependency tree in sysfs: convert bd_sem to bd_mutexJun'ichi Nomura
Convert bd_sem to bd_mutex Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Cc: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] dm/md dependency tree in sysfs: bd_claim_by_kobjectJun'ichi Nomura
Adding bd_claim_by_kobject() function which takes kobject as additional signature of holder device and creates sysfs symlinks between holder device and claimed device. bd_release_from_kobject() is a counterpart of bd_claim_by_kobject. Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Cc: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] remove ->get_blocks() supportBadari Pulavarty
Now that get_block() can handle mapping multiple disk blocks, no need to have ->get_blocks(). This patch removes fs specific ->get_blocks() added for DIO and makes it users use get_block() instead. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] Use __read_mostly on some hot fs variablesEric Dumazet
I discovered on oprofile hunting on a SMP platform that dentry lookups were slowed down because d_hash_mask, d_hash_shift and dentry_hashtable were in a cache line that contained inodes_stat. So each time inodes_stats is changed by a cpu, other cpus have to refill their cache line. This patch moves some variables to the __read_mostly section, in order to avoid false sharing. RCU dentry lookups can go full speed. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] sb_set_blocksize cleanupCoywolf Qi Hunt
sb_set_blocksize() cleanup: make sb_set_blocksize() use blksize_bits(). Signed-off-by: Coywolf Qi Hunt <qiyong@fc-cn.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache formatPaul Jackson
Rewrap the overly long source code lines resulting from the previous patch's addition of the slab cache flag SLAB_MEM_SPREAD. This patch contains only formatting changes, and no function change. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache filesystemsPaul Jackson
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD memory spreading. If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's in a cpuset with the 'memory_spread_slab' option enabled goes to allocate from such a slab cache, the allocations are spread evenly over all the memory nodes (task->mems_allowed) allowed to that task, instead of favoring allocation on the node local to the current cpu. The following inode and similar caches are marked SLAB_MEM_SPREAD: file cache ==== ===== fs/adfs/super.c adfs_inode_cache fs/affs/super.c affs_inode_cache fs/befs/linuxvfs.c befs_inode_cache fs/bfs/inode.c bfs_inode_cache fs/block_dev.c bdev_cache fs/cifs/cifsfs.c cifs_inode_cache fs/coda/inode.c coda_inode_cache fs/dquot.c dquot fs/efs/super.c efs_inode_cache fs/ext2/super.c ext2_inode_cache fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr fs/ext3/super.c ext3_inode_cache fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr fs/fat/cache.c fat_cache fs/fat/inode.c fat_inode_cache fs/freevxfs/vxfs_super.c vxfs_inode fs/hpfs/super.c hpfs_inode_cache fs/isofs/inode.c isofs_inode_cache fs/jffs/inode-v23.c jffs_fm fs/jffs2/super.c jffs2_i fs/jfs/super.c jfs_ip fs/minix/inode.c minix_inode_cache fs/ncpfs/inode.c ncp_inode_cache fs/nfs/direct.c nfs_direct_cache fs/nfs/inode.c nfs_inode_cache fs/ntfs/super.c ntfs_big_inode_cache_name fs/ntfs/super.c ntfs_inode_cache fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache fs/ocfs2/super.c ocfs2_inode_cache fs/proc/inode.c proc_inode_cache fs/qnx4/inode.c qnx4_inode_cache fs/reiserfs/super.c reiser_inode_cache fs/romfs/inode.c romfs_inode_cache fs/smbfs/inode.c smb_inode_cache fs/sysv/inode.c sysv_inode_cache fs/udf/super.c udf_inode_cache fs/ufs/super.c ufs_inode_cache net/socket.c sock_inode_cache net/sunrpc/rpc_pipe.c rpc_inode_cache The choice of which slab caches to so mark was quite simple. I marked those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache, inode_cache, and buffer_head, which were marked in a previous patch. Even though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same potentially large file system i/o related slab caches as we need for memory spreading. Given that the rule now becomes "wherever you would have used a SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain. Future file system writers will just copy one of the existing file system slab cache setups and tend to get it right without thinking. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
