path: root/fs/block_dev.c
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-06-23[PATCH] block: add unlocked_ioctl support for block devicesArnd Bergmann
This patch allows block device drivers to convert their ioctl functions to unlocked_ioctl() like character devices and other subsystems. All functions that were called with the BKL held before are still used that way, but I would not be surprised if it could be removed from the ioctl functions in drivers/block/ioctl.c themselves. As a side note, I found that compat_blkdev_ioctl() acquires the BKL as well, which looks like a bug. I have checked that every user of disk->fops->compat_ioctl() in the current git tree gets the BKL itself, so it could easily be removed from compat_blkdev_ioctl(). Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] remove do_sync parameter from __invalidate_deviceChristoph Hellwig
The only caller that ever sets it can call fsync_bdev itself easily. Also update some comments. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: <viro@parcelfarce.linux.theplanet.co.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
