commit 080399aaaf3531f5b8761ec0ac30ff98891e8686 upstream.
We have a bug report open where a squashfs image mounted on ppc64 would
exhibit errors due to trying to read beyond the end of the disk. It can
easily be reproduced by doing the following:
[root@ibm-p750e-02-lp3 ~]# ls -l install.img
-rw-r--r-- 1 root root 142032896 Apr 30 16:46 install.img
[root@ibm-p750e-02-lp3 ~]# mount -o loop ./install.img /mnt/test
[root@ibm-p750e-02-lp3 ~]# dd if=/dev/loop0 of=/dev/null
dd: reading `/dev/loop0': Input/output error
277376+0 records in
277376+0 records out
142016512 bytes (142 MB) copied, 0.9465 s, 150 MB/s
In dmesg, you'll find the following:
squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 43.106012] attempt to access beyond end of device
[ 43.106029] loop0: rw=0, want=277410, limit=277408
[ 43.106039] Buffer I/O error on device loop0, logical block 138704
[ 43.106053] attempt to access beyond end of device
[ 43.106057] loop0: rw=0, want=277412, limit=277408
[ 43.106061] Buffer I/O error on device loop0, logical block 138705
[ 43.106066] attempt to access beyond end of device
[ 43.106070] loop0: rw=0, want=277414, limit=277408
[ 43.106073] Buffer I/O error on device loop0, logical block 138706
[ 43.106078] attempt to access beyond end of device
[ 43.106081] loop0: rw=0, want=277416, limit=277408
[ 43.106085] Buffer I/O error on device loop0, logical block 138707
[ 43.106089] attempt to access beyond end of device
[ 43.106093] loop0: rw=0, want=277418, limit=277408
[ 43.106096] Buffer I/O error on device loop0, logical block 138708
[ 43.106101] attempt to access beyond end of device
[ 43.106104] loop0: rw=0, want=277420, limit=277408
[ 43.106108] Buffer I/O error on device loop0, logical block 138709
[ 43.106112] attempt to access beyond end of device
[ 43.106116] loop0: rw=0, want=277422, limit=277408
[ 43.106120] Buffer I/O error on device loop0, logical block 138710
[ 43.106124] attempt to access beyond end of device
[ 43.106128] loop0: rw=0, want=277424, limit=277408
[ 43.106131] Buffer I/O error on device loop0, logical block 138711
[ 43.106135] attempt to access beyond end of device
[ 43.106139] loop0: rw=0, want=277426, limit=277408
[ 43.106143] Buffer I/O error on device loop0, logical block 138712
[ 43.106147] attempt to access beyond end of device
[ 43.106151] loop0: rw=0, want=277428, limit=277408
[ 43.106154] Buffer I/O error on device loop0, logical block 138713
[ 43.106158] attempt to access beyond end of device
[ 43.106162] loop0: rw=0, want=277430, limit=277408
[ 43.106166] attempt to access beyond end of device
[ 43.106169] loop0: rw=0, want=277432, limit=277408
[ 43.106307] attempt to access beyond end of device
[ 43.106311] loop0: rw=0, want=277470, limit=2774
Squashfs manages to read in the end block(s) of the disk during the
mount operation. Then, when dd reads the block device, it leads to
block_read_full_page being called with buffers that are beyond end of
disk, but are marked as mapped. Thus, it would end up submitting read
I/O against them, resulting in the errors mentioned above. I fixed the
problem by modifying init_page_buffers to only set the buffer mapped if
it fell inside of i_size.
Cheers,
Jeff
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Acked-by: Nick Piggin <npiggin@kernel.dk>
Changes from v1->v2: re-used max_block, as suggested by Nick Piggin.
commit fe316bf2d5847bc5dd975668671a7b1067603bc7 upstream.
Since 2.6.39 (1196f8b), when a driver returns -ENOMEDIUM for open(),
__blkdev_get() calls rescan_partitions() to remove
in-kernel partition structures and raise KOBJ_CHANGE uevent.
However it ends up calling driver's revalidate_disk without open
and could cause oops.
In the case of SCSI:
process A process B
sys_open
__blkdev_get
sd_open
returns -ENOMEDIUM
scsi_remove_device
<scsi_device torn down>
rescan_partitions
sd_revalidate_disk
<oops>
Oopses are reported here:
http://marc.info/?l=linux-scsi&m=132388619710052
This patch separates the partition invalidation from rescan_partitions()
and use it for -ENOMEDIUM case.
Reported-by: Huajun Li <huajun.li.lee@gmail.com>
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Acked-by: Tejun Heo <tj@kernel.org>
commit f992ae801a7dec34a4ed99a6598bbbbfb82af4fb upstream.
The following command sequence triggers an oops.
# mount /dev/sdb1 /mnt
# echo 1 > /sys/class/scsi_device/0\:0\:1\:0/device/delete
# umount /mnt
general protection fault: 0000 [#1] PREEMPT SMP
CPU 2
Modules linked in:
Pid: 791, comm: umount Not tainted 3.1.0-rc3-work+ #8 Bochs Bochs
RIP: 0010:[<ffffffff810d0879>] [<ffffffff810d0879>] __lock_acquire+0x389/0x1d60
Call Trace:
[<ffffffff810d2845>] lock_acquire+0x95/0x140
[<ffffffff81aed87b>] _raw_spin_lock+0x3b/0x50
[<ffffffff811573bc>] bdi_lock_two+0x5c/0x70
[<ffffffff811c2f6c>] bdev_inode_switch_bdi+0x4c/0xf0
[<ffffffff811c3fcb>] __blkdev_put+0x11b/0x1d0
[<ffffffff811c4010>] __blkdev_put+0x160/0x1d0
[<ffffffff811c40df>] blkdev_put+0x5f/0x190
[<ffffffff8118f18d>] kill_block_super+0x4d/0x80
[<ffffffff8118f4a5>] deactivate_locked_super+0x45/0x70
[<ffffffff8119003a>] deactivate_super+0x4a/0x70
[<ffffffff811ac4ad>] mntput_no_expire+0xed/0x130
[<ffffffff811acf2e>] sys_umount+0x7e/0x3a0
[<ffffffff81aeeeab>] system_call_fastpath+0x16/0x1b
This is because bdev holds on to disk but disk doesn't pin the
associated queue. If a SCSI device is removed while the device is
still open, the sdev puts the base reference to the queue on release.
When the bdev is finally released, the associated queue is already
gone along with the bdi and bdev_inode_switch_bdi() ends up
dereferencing already freed bdi.
Even if it were not for this bug, disk not holding onto the associated
queue is very unusual and error-prone.
Fix it by making add_disk() take an extra reference to its queue and
put it on disk_release() and ensuring that disk and its fops owner are
put in that order after all accesses to the disk and queue are
complete.
commit 94007751bb02797ba87bac7aacee2731ac2039a3 upstream.
On the last close of an 'md' device which as been stopped, the device
is destroyed and in particular the request_queue is freed. The free
is done in a separate thread so it might happen a short time later.
__blkdev_put calls bdev_inode_switch_bdi *after* ->release has been
called.
Since commit f758eeabeb96f878c860e8f110f94ec8820822a9
bdev_inode_switch_bdi will dereference the 'old' bdi, which lives
inside a request_queue, to get a spin lock. This causes the last
close on an md device to sometime take a spin_lock which lives in
freed memory - which results in an oops.
So move the called to bdev_inode_switch_bdi before the call to
->release.
Cc: Wu Fengguang <fengguang.wu@intel.com>
Acked-by: Wu Fengguang <fengguang.wu@intel.com>
Signed-off-by: NeilBrown <neilb@suse.de>
6b4517a791 (block: implement bd_claiming and claiming block)
introduced claiming block to support O_EXCL blkdev opens properly.
bd_start_claiming() looks up the part 0 bdev and starts claiming
block. The function assumed that there is only one part 0 bdev and
always used bdget_disk(disk, 0) to look it up; unfortunately, this
isn't true for some drivers (floppy) which use multiple block devices
to denote different operating parameters for the same physical device.
There can be multiple part 0 bdev's for the same device number.
This incorrect assumption caused the wrong bdev to be used during
claiming leading to unbalanced bd_holders as reported in the following
bug.
https://bugzilla.kernel.org/show_bug.cgi?id=28522
This patch updates bd_start_claiming() such that it uses the bdev
specified as argument if its partno is zero.
Note that this means that different bdev's can be used for the same
device and O_EXCL check can be effectively bypassed. It has always
been broken that way and floppy is fortunately on its way out. Leave
that breakage alone.
Reported-by: Alex Villacis Lasso <avillaci@ceibo.fiec.espol.edu.ec>
Tested-by: Alex Villacis Lasso <avillaci@ceibo.fiec.espol.edu.ec>
Cc: stable@kernel.org # >= v2.6.36
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
d4dc210f69 (block: don't block events on excl write for non-optical
devices) added dereferencing of bdev->bd_disk to test
GENHD_FL_BLOCK_EVENTS_ON_EXCL_WRITE; however, bdev->bd_disk can be
%NULL if open failed which can lead to an oops.
Test the flag after testing open was successful, not before.
Reported-by: David Miller <davem@davemloft.net>
Tested-by: David Miller <davem@davemloft.net>
02e352287a4 (block: rescan partitions on invalidated devices on
-ENOMEDIA too) relocated partition rescan above explicit bd_set_size()
to simplify condition check. As rescan_partitions() does its own bdev
size setting, this doesn't break anything; however,
rescan_partitions() prints out the following messages when adjusting
bdev size, which can be confusing.
sda: detected capacity change from 0 to 146815737856
sdb: detected capacity change from 0 to 146815737856
This patch restores the original order and remove the warning
messages.
stable: Please apply together with 02e352287a4 (block: rescan
partitions on invalidated devices on -ENOMEDIA too).
Reported-by: Tony Luck <tony.luck@gmail.com>
Tested-by: Tony Luck <tony.luck@gmail.com>
Stable note: 2.6.39 only.
Disk event code automatically blocks events on excl write. This is
primarily to avoid issuing polling commands while burning is in
progress. This behavior doesn't fit other types of devices with
removeable media where polling commands don't have adverse side
effects and door locking usually doesn't exist.
This patch introduces new genhd flag which controls the auto-blocking
behavior and uses it to enable auto-blocking only on optical devices.
Note for stable: 2.6.38 and later only
Reported-by: Kay Sievers <kay.sievers@vrfy.org>
__blkdev_get() doesn't rescan partitions if disk->fops->open() fails,
which leads to ghost partition devices lingering after medimum removal
is known to both the kernel and userland. The behavior also creates a
subtle inconsistency where O_NONBLOCK open, which doesn't fail even if
there's no medium, clears the ghots partitions, which is exploited to
work around the problem from userland.
Fix it by updating __blkdev_get() to issue partition rescan after
-ENOMEDIA too.
This was reported in the following bz.
https://bugzilla.kernel.org/show_bug.cgi?id=13029
Reported-by: David Zeuthen <zeuthen@gmail.com>
Reported-by: Martin Pitt <martin.pitt@ubuntu.com>
Tested-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
fs: simplify iget & friends
fs: pull inode->i_lock up out of writeback_single_inode
fs: rename inode_lock to inode_hash_lock
fs: move i_wb_list out from under inode_lock
fs: move i_sb_list out from under inode_lock
fs: remove inode_lock from iput_final and prune_icache
fs: Lock the inode LRU list separately
fs: factor inode disposal
fs: protect inode->i_state with inode->i_lock
autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd()
autofs4 - remove autofs4_lock
autofs4 - fix d_manage() return on rcu-walk
autofs4 - fix autofs4_expire_indirect() traversal
autofs4 - fix dentry leak in autofs4_expire_direct()
autofs4 - reinstate last used update on access
vfs - check non-mountpoint dentry might block in __follow_mount_rcu()
Protect the inode writeback list with a new global lock
inode_wb_list_lock and use it to protect the list manipulations and
traversals. This lock replaces the inode_lock as the inodes on the
list can be validity checked while holding the inode->i_lock and
hence the inode_lock is no longer needed to protect the list.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Protect inode state transitions and validity checks with the
inode->i_lock. This enables us to make inode state transitions
independently of the inode_lock and is the first step to peeling
away the inode_lock from the code.
This requires that __iget() is done atomically with i_state checks
during list traversals so that we don't race with another thread
marking the inode I_FREEING between the state check and grabbing the
reference.
Also remove the unlock_new_inode() memory barrier optimisation
required to avoid taking the inode_lock when clearing I_NEW.
Simplify the code by simply taking the inode->i_lock around the
state change and wakeup. Because the wakeup is no longer tricky,
remove the wake_up_inode() function and open code the wakeup where
necessary.
"disk" is always NULL when we goto out. There was a check for this
before, but it was removed in 69e02c59a7d9 "block: Don't check events
while open is in progress".
Signed-off-by: Jens Axboe <axboe@carl>
block/blk-core.c
block/blk-flush.c
drivers/md/raid1.c
drivers/md/raid10.c
drivers/md/raid5.c
fs/nilfs2/btnode.c
fs/nilfs2/mdt.c
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
Not all block drivers clear events immediately after reporting. Some
do so in ->revalidate_disk() or other steps during ->open(). There is
a slim chance event poll may happen between the clearing event check
from check_disk_change() and the actual clearing of the events which
would result in spurious events.
Block event checks while block device open is in progress. There is
no need to kick explicit event check afterwards as events are always
checked during open.
-v2: The original patch could have called disk_unblock_events() with
an already released or %NULL @disk causing oops. Fixed by making
sure references are put after disk_unblock_events() is called.
It also makes the error path of __blkdev_get() a bit simpler.
This problem was reported by Jens.
Cc: Kay Sievers <kay.sievers@vrfy.org>
The block event mechanism currently always checks events when the
device is being closed regardless of the open mode. The intention was
to allow detection of EJECT_REQUEST when a device is closed whether
disk event polling is enabled or not.
This is unnecessary as, for devices of interest, events are checked
from either userland or kernel and in the former case ->check_events()
is performed on open of each poll attempt anyway. Furthermore, this
unconditional event check on close makes the code susceptible to event
loop if the block driver doesn't clear reported events correctly - an
event triggers userland to open and close the device which in turn
causes another event, rinse and repeat.
Check events on close only if it was blocked by excl write open.
Currently, disk_unblock_events() implicitly kick event check if the
block count reaches zero. This behavior is not described in the
comment and hinders with future changes. Make the unblocker
explicitly check events by calling disk_check_events() as necessary.
This patch doesn't cause any behavior difference.
Fix new kernel-doc warning in fs/block_dev.c:
Warning(fs/block_dev.c:937): No description found for parameter 'kill_dirty'
* 'for-linus' of git://neil.brown.name/md:
md: Fix - again - partition detection when array becomes active
Fix over-zealous flush_disk when changing device size.
md: avoid spinlock problem in blk_throtl_exit
md: correctly handle probe of an 'mdp' device.
md: don't set_capacity before array is active.
md: Fix raid1->raid0 takeover
The new implementation of bd_link_disk_holder() added by 49731baa41d
(block: restore multiple bd_link_disk_holder() support) didn't get an
extra reference for the holder_dir kobject of the slave bdev; however,
bdev kills holder_dir on removal, not release, so if the slave bdev is
removed while there are holder links, the holder_dir will be destroyed
while there still are holder links, which leads to oops later when
bd_unlink_disk_order() tries to remove those links.
Make bd_link_disk_holder() grab an extra reference for the slave's
holder_dir and put it in bd_unlink_disk_holder().
Reported-by: "Hawrylewicz Czarnowski, Przemyslaw" <przemyslaw.hawrylewicz.czarnowski@intel.com>
Tested-by: "Hawrylewicz Czarnowski, Przemyslaw" <przemyslaw.hawrylewicz.czarnowski@intel.com>
Cc: Neil Brown <neilb@suse.de>
There are two cases when we call flush_disk.
In one, the device has disappeared (check_disk_change) so any
data will hold becomes irrelevant.
In the oter, the device has changed size (check_disk_size_change)
so data we hold may be irrelevant.
In both cases it makes sense to discard any 'clean' buffers,
so they will be read back from the device if needed.
In the former case it makes sense to discard 'dirty' buffers
as there will never be anywhere safe to write the data. In the
second case it *does*not* make sense to discard dirty buffers
as that will lead to file system corruption when you simply enlarge
the containing devices.
flush_disk calls __invalidate_devices.
__invalidate_device calls both invalidate_inodes and invalidate_bdev.
invalidate_inodes *does* discard I_DIRTY inodes and this does lead
to fs corruption.
invalidate_bev *does*not* discard dirty pages, but I don't really care
about that at present.
So this patch adds a flag to __invalidate_device (calling it
__invalidate_device2) to indicate whether dirty buffers should be
killed, and this is passed to invalidate_inodes which can choose to
skip dirty inodes.
flusk_disk then passes true from check_disk_change and false from
check_disk_size_change.
dm avoids tripping over this problem by calling i_size_write directly
rathher than using check_disk_size_change.
md does use check_disk_size_change and so is affected.
This regression was introduced by commit 608aeef17a which causes
check_disk_size_change to call flush_disk, so it is suitable for any
kernel since 2.6.27.
Acked-by: Jeff Moyer <jmoyer@redhat.com>
Cc: Andrew Patterson <andrew.patterson@hp.com>
This reverts commit 75f1dc0d076d ("block: check bdev_read_only() from
blkdev_get()"). That commit added stricter checking to make sure
devices that were being used read-only were actually opened in that
mode.
It turns out that the change breaks a bunch of kernel code that opens
block devices. Affected systems include dm, md, and the loop device.
Because strict checking for read-only opens of block devices was not
done before this, the code that opens the devices was opening them
read-write even if they were being used read-only. Auditing all that
code will take time, and new userspace packages for dm, mdadm, etc.
will also be required.
Signed-off-by: Chuck Ebbert <cebbert@redhat.com>
Commit e09b457b (block: simplify holder symlink handling) incorrectly
assumed that there is only one link at maximum. dm may use multiple
links and expects block layer to track reference count for each link,
which is different from and unrelated to the exclusive device holder
identified by @holder when the device is opened.
Remove the single holder assumption and automatic removal of the link
and revive the per-link reference count tracking. The code
essentially behaves the same as before commit e09b457b sans the
unnecessary kobject reference count dancing.
While at it, note that this facility should not be used by anyone else
than the current ones. Sysfs symlinks shouldn't be abused like this
and the whole thing doesn't belong in the block layer at all.
Reported-by: Milan Broz <mbroz@redhat.com>
Cc: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
Cc: linux-raid@vger.kernel.org
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits)
block: ensure that completion error gets properly traced
blktrace: add missing probe argument to block_bio_complete
block cfq: don't use atomic_t for cfq_group
block cfq: don't use atomic_t for cfq_queue
block: trace event block fix unassigned field
block: add internal hd part table references
block: fix accounting bug on cross partition merges
kref: add kref_test_and_get
bio-integrity: mark kintegrityd_wq highpri and CPU intensive
block: make kblockd_workqueue smarter
Revert "sd: implement sd_check_events()"
block: Clean up exit_io_context() source code.
Fix compile warnings due to missing removal of a 'ret' variable
fs/block: type signature of major_to_index(int) to major_to_index(unsigned)
block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p)
cfq-iosched: don't check cfqg in choose_service_tree()
fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors
cdrom: export cdrom_check_events()
sr: implement sr_check_events()
RCU free the struct inode. This will allow:
- Subsequent store-free path walking patch. The inode must be consulted for
permissions when walking, so an RCU inode reference is a must.
- sb_inode_list_lock to be moved inside i_lock because sb list walkers who want
to take i_lock no longer need to take sb_inode_list_lock to walk the list in
the first place. This will simplify and optimize locking.
- Could remove some nested trylock loops in dcache code
- Could potentially simplify things a bit in VM land. Do not need to take the
page lock to follow page->mapping.
The downsides of this is the performance cost of using RCU. In a simple
creat/unlink microbenchmark, performance drops by about 10% due to inability to
reuse cache-hot slab objects. As iterations increase and RCU freeing starts
kicking over, this increases to about 20%.
In cases where inode lifetimes are longer (ie. many inodes may be allocated
during the average life span of a single inode), a lot of this cache reuse is
not applicable, so the regression caused by this patch is smaller.
The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU,
however this adds some complexity to list walking and store-free path walking,
so I prefer to implement this at a later date, if it is shown to be a win in
real situations. I haven't found a regression in any non-micro benchmark so I
doubt it will be a problem.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
Currently, media presence polling for removeable block devices is done
from userland. There are several issues with this.
* Polling is done by periodically opening the device. For SCSI
devices, the command sequence generated by such action involves a
few different commands including TEST_UNIT_READY. This behavior,
while perfectly legal, is different from Windows which only issues
single command, GET_EVENT_STATUS_NOTIFICATION. Unfortunately, some
ATAPI devices lock up after being periodically queried such command
sequences.
* There is no reliable and unintrusive way for a userland program to
tell whether the target device is safe for media presence polling.
For example, polling for media presence during an on-going burning
session can make it fail. The polling program can avoid this by
opening the device with O_EXCL but then it risks making a valid
exclusive user of the device fail w/ -EBUSY.
* Userland polling is unnecessarily heavy and in-kernel implementation
is lighter and better coordinated (workqueue, timer slack).
This patch implements framework for in-kernel disk event handling,
which includes media presence polling.
* bdops->check_events() is added, which supercedes ->media_changed().
It should check whether there's any pending event and return if so.
Currently, two events are defined - DISK_EVENT_MEDIA_CHANGE and
DISK_EVENT_EJECT_REQUEST. ->check_events() is guaranteed not to be
called parallelly.
* gendisk->events and ->async_events are added. These should be
initialized by block driver before passing the device to add_disk().
The former contains the mask of all supported events and the latter
the mask of all events which the device can report without polling.
/sys/block/*/events[_async] export these to userland.
* Kernel parameter block.events_dfl_poll_msecs controls the system
polling interval (default is 0 which means disable) and
/sys/block/*/events_poll_msecs control polling intervals for
individual devices (default is -1 meaning use system setting). Note
that if a device can report all supported events asynchronously and
its polling interval isn't explicitly set, the device won't be
polled regardless of the system polling interval.
* If a device is opened exclusively with write access, event checking
is automatically disabled until all write exclusive accesses are
released.
* There are event 'clearing' events. For example, both of currently
defined events are cleared after the device has been successfully
opened. This information is passed to ->check_events() callback
using @clearing argument as a hint.
* Event checking is always performed from system_nrt_wq and timer
slack is set to 25% for polling.
* Nothing changes for drivers which implement ->media_changed() but
not ->check_events(). Going forward, all drivers will be converted
to ->check_events() and ->media_change() will be dropped.
Cc: Jan Kara <jack@suse.cz>
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
After recent blkdev_get() modifications, open_by_devnum() and
open_bdev_exclusive() are simple wrappers around blkdev_get().
Replace them with blkdev_get_by_dev() and blkdev_get_by_path().
blkdev_get_by_dev() is identical to open_by_devnum().
blkdev_get_by_path() is slightly different in that it doesn't
automatically add %FMODE_EXCL to @mode.
All users are converted. Most conversions are mechanical and don't
introduce any behavior difference. There are several exceptions.
* btrfs now sets FMODE_EXCL in btrfs_device->mode, so there's no
reason to OR it explicitly on blkdev_put().
* gfs2, nilfs2 and the generic mount_bdev() now set FMODE_EXCL in
sb->s_mode.
* With the above changes, sb->s_mode now always should contain
FMODE_EXCL. WARN_ON_ONCE() added to kill_block_super() to detect
errors.
The new blkdev_get_*() functions are with proper docbook comments.
While at it, add function description to blkdev_get() too.
Cc: Philipp Reisner <philipp.reisner@linbit.com>
Cc: Mike Snitzer <snitzer@redhat.com>
Cc: Joern Engel <joern@lazybastard.org>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: "Theodore Ts'o" <tytso@mit.edu>
Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp>
Cc: reiserfs-devel@vger.kernel.org
Cc: xfs-masters@oss.sgi.com
bdev read-only status can be queried using bdev_read_only() and may
change while the device is being opened. Enforce it by checking it
from blkdev_get() after open succeeds.
This makes bdev_read_only() check in open_bdev_exclusive() and
fsg_lun_open() unnecessary. Drop them.
Cc: David Brownell <dbrownell@users.sourceforge.net>
Cc: linux-usb@vger.kernel.org
With claim/release rolled into blkdev_get/put(), there's no reason to
keep bd_abort/finish_claim(), __bd_claim() and bd_release() as
separate functions. It only makes the code difficult to follow.
Collapse them into blkdev_get/put(). This will ease future changes
around claim/release.
Over time, block layer has accumulated a set of APIs dealing with bdev
open, close, claim and release.
* blkdev_get/put() are the primary open and close functions.
* bd_claim/release() deal with exclusive open.
* open/close_bdev_exclusive() are combination of open and claim and
the other way around, respectively.
* bd_link/unlink_disk_holder() to create and remove holder/slave
symlinks.
* open_by_devnum() wraps bdget() + blkdev_get().
The interface is a bit confusing and the decoupling of open and claim
makes it impossible to properly guarantee exclusive access as
in-kernel open + claim sequence can disturb the existing exclusive
open even before the block layer knows the current open if for another
exclusive access. Reorganize the interface such that,
* blkdev_get() is extended to include exclusive access management.
@holder argument is added and, if is @FMODE_EXCL specified, it will
gain exclusive access atomically w.r.t. other exclusive accesses.
* blkdev_put() is similarly extended. It now takes @mode argument and
if @FMODE_EXCL is set, it releases an exclusive access. Also, when
the last exclusive claim is released, the holder/slave symlinks are
removed automatically.
* bd_claim/release() and close_bdev_exclusive() are no longer
necessary and either made static or removed.
* bd_link_disk_holder() remains the same but bd_unlink_disk_holder()
is no longer necessary and removed.
* open_bdev_exclusive() becomes a simple wrapper around lookup_bdev()
and blkdev_get(). It also has an unexpected extra bdev_read_only()
test which probably should be moved into blkdev_get().
* open_by_devnum() is modified to take @holder argument and pass it to
blkdev_get().
Most of bdev open/close operations are unified into blkdev_get/put()
and most exclusive accesses are tested atomically at the open time (as
it should). This cleans up code and removes some, both valid and
invalid, but unnecessary all the same, corner cases.
open_bdev_exclusive() and open_by_devnum() can use further cleanup -
rename to blkdev_get_by_path() and blkdev_get_by_devt() and drop
special features. Well, let's leave them for another day.
Most conversions are straight-forward. drbd conversion is a bit more
involved as there was some reordering, but the logic should stay the
same.
Acked-by: Neil Brown <neilb@suse.de>
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Acked-by: Mike Snitzer <snitzer@redhat.com>
Acked-by: Philipp Reisner <philipp.reisner@linbit.com>
Cc: Peter Osterlund <petero2@telia.com>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Joel Becker <joel.becker@oracle.com>
Cc: Alex Elder <aelder@sgi.com>
Cc: dm-devel@redhat.com
Cc: drbd-dev@lists.linbit.com
Cc: Leo Chen <leochen@broadcom.com>
Cc: Scott Branden <sbranden@broadcom.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com>
Cc: Joern Engel <joern@logfs.org>
Code to manage symlinks in /sys/block/*/{holders|slaves} are overly
complex with multiple holder considerations, redundant extra
references to all involved kobjects, unused generic kobject holder
support and unnecessary mixup with bd_claim/release functionalities.
Strip it down to what's necessary (single gendisk holder) and make it
use a separate interface. This is a step for cleaning up
bd_claim/release. This patch makes dm-table slightly more complex but
it will be simplified again with further changes.
The use of the same inode list structure (inode->i_list) for two
different list constructs with different lifecycles and purposes
makes it impossible to separate the locking of the different
operations. Therefore, to enable the separation of the locking of
the writeback and reclaim lists, split the inode->i_list into two
separate lists dedicated to their specific tracking functions.
Signed-off-by: Nick Piggin <npiggin@suse.de>
bdev inodes can remain dirty even after their last close. Hence the
BDI associated with the bdev->inode gets modified duringthe last
close to point to the default BDI. However, the bdev inode still
needs to be moved to the dirty lists of the new BDI, otherwise it
will corrupt the writeback list is was left on.
Add a new function bdev_inode_switch_bdi() to move all the bdi state
from the old bdi to the new one safely. This is only a temporary
measure until the bdev inode<->bdi lifecycle problems are sorted
out.
Clones an existing reference to inode; caller must already hold one.
All the blkdev_issue_* helpers can only sanely be used for synchronous
caller. To issue cache flushes or barriers asynchronously the caller needs
to set up a bio by itself with a completion callback to move the asynchronous
state machine ahead. So drop the BLKDEV_IFL_WAIT flag that is always
specified when calling blkdev_issue_* and also remove the now unused flags
argument to blkdev_issue_flush and blkdev_issue_zeroout. For
blkdev_issue_discard we need to keep it for the secure discard flag, which
gains a more descriptive name and loses the bitops vs flag confusion.
The cgroup device whitelist code gets confused when trying to grant
permission to a disk partition that is not currently open. Part of
blkdev_open() includes __blkdev_get() on the whole disk.
Basically, the only ways to reliably allow a cgroup access to a partition
on a block device when using the whitelist are to 1) also give it access
to the whole block device or 2) make sure the partition is already open in
a different context.
The patch avoids the cgroup check for the whole disk case when opening a
partition.
Addresses https://bugzilla.redhat.com/show_bug.cgi?id=589662
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Acked-by: Serge E. Hallyn <serue@us.ibm.com>
Tested-by: Serge E. Hallyn <serue@us.ibm.com>
Reported-by: Vivek Goyal <vgoyal@redhat.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: "Daniel P. Berrange" <berrange@redhat.com>
Cc: <stable@kernel.org>
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits)
block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n
xen-blkfront: fix missing out label
blkdev: fix blkdev_issue_zeroout return value
block: update request stacking methods to support discards
block: fix missing export of blk_types.h
writeback: fix bad _bh spinlock nesting
drbd: revert "delay probes", feature is being re-implemented differently
drbd: Initialize all members of sync_conf to their defaults [Bugz 315]
drbd: Disable delay probes for the upcomming release
writeback: cleanup bdi_register
writeback: add new tracepoints
writeback: remove unnecessary init_timer call
writeback: optimize periodic bdi thread wakeups
writeback: prevent unnecessary bdi threads wakeups
writeback: move bdi threads exiting logic to the forker thread
writeback: restructure bdi forker loop a little
writeback: move last_active to bdi
writeback: do not remove bdi from bdi_list
writeback: simplify bdi code a little
writeback: do not lose wake-ups in bdi threads
Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and
drivers/scsi/scsi_error.c as per Jens.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits)
no need for list_for_each_entry_safe()/resetting with superblock list
Fix sget() race with failing mount
vfs: don't hold s_umount over close_bdev_exclusive() call
sysv: do not mark superblock dirty on remount
sysv: do not mark superblock dirty on mount
btrfs: remove junk sb_dirt change
BFS: clean up the superblock usage
AFFS: wait for sb synchronization when needed
AFFS: clean up dirty flag usage
cifs: truncate fallout
mbcache: fix shrinker function return value
mbcache: Remove unused features
add f_flags to struct statfs(64)
pass a struct path to vfs_statfs
update VFS documentation for method changes.
All filesystems that need invalidate_inode_buffers() are doing that explicitly
convert remaining ->clear_inode() to ->evict_inode()
Make ->drop_inode() just return whether inode needs to be dropped
fs/inode.c:clear_inode() is gone
fs/inode.c:evict() doesn't care about delete vs. non-delete paths now
Fix up trivial conflicts in fs/nilfs2/super.c
Move the call to vmtruncate to get rid of accessive blocks to the callers
in preparation of the new truncate sequence and rename the non-truncating
version to block_write_begin.
While we're at it also remove several unused arguments to block_write_begin.
in prepearation of the new truncate calling sequence. This was only done
for DIO_LOCKING filesystems, so the __blockdev_direct_IO_newtrunc variant
was not needed anyway. Get rid of blockdev_direct_IO_no_locking and
its _newtrunc variant while at it as just opencoding the two additional
paramters is shorted than the name suffix.
The open and release block_device_operations are currently
called with the BKL held. In order to change that, we must
first make sure that all drivers that currently rely
on this have no regressions.
This blindly pushes the BKL into all .open and .release
operations for all block drivers to prepare for the
next step. The drivers can subsequently replace the BKL
with their own locks or remove it completely when it can
be shown that it is not needed.
The functions blkdev_get and blkdev_put are the only
remaining users of the big kernel lock in the block
layer, besides a few uses in the ioctl code, none
of which need to serialize with blkdev_{get,put}.
Most of these two functions is also under the protection
of bdev->bd_mutex, including the actual calls to
->open and ->release, and the common code does not
access any global data structures that need the BKL.
Acked-by: Christoph Hellwig <hch@infradead.org>
bd_prepare_to_claim() incorrectly allowed multiple attempts for
exclusive open to progress in parallel if the attempting holders are
identical. This triggered BUG_ON() as reported in the following bug.
https://bugzilla.kernel.org/show_bug.cgi?id=16393
__bd_abort_claiming() is used to finish claiming blocks and doesn't
work if multiple openers are inside a claiming block. Allowing
multiple parallel open attempts to continue doesn't gain anything as
those are serialized down in the call chain anyway. Fix it by always
allowing only single open attempt in a claiming block.
This problem can easily be reproduced by adding a delay after
bd_prepare_to_claim() and attempting to mount two partitions of a
disk.
stable: only applicable to v2.6.35
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
We do the same BUG_ON() just a line later when calling into
__bd_abort_claiming().
Reported-by: Tejun Heo <tj@kernel.org>
I don't like the subtle multi-context code in bd_claim (ie. detects where it
has been called based on bd_claiming). It seems clearer to just require a new
function to finish a 2-part claim.
Also improve commentary in bd_start_claiming as to how it should
be used.
