path: root/fs/btrfs/Kconfig
2010-12-22btrfs: Add lzo compression supportLi Zefan
Lzo is a much faster compression algorithm than gzib, so would allow more users to enable transparent compression, and some users can choose from compression ratio and speed for different applications Usage: # mount -t btrfs -o compress[=<zlib,lzo>] dev /mnt or # mount -t btrfs -o compress-force[=<zlib,lzo>] dev /mnt "-o compress" without argument is still allowed for compatability. Compatibility: If we mount a filesystem with lzo compression, it will not be able be mounted in old kernels. One reason is, otherwise btrfs will directly dump compressed data, which sits in inline extent, to user. Performance: The test copied a linux source tarball (~400M) from an ext4 partition to the btrfs partition, and then extracted it. (time in second) lzo zlib nocompress copy: 10.6 21.7 14.9 extract: 70.1 94.4 66.6 (data size in MB) lzo zlib nocompress copy: 185.87 108.69 394.49 extract: 193.80 132.36 381.21 Changelog: v1 -> v2: - Select LZO_COMPRESS and LZO_DECOMPRESS in btrfs Kconfig. - Add incompability flag. - Fix error handling in compress code. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
2009-12-17Revert "task_struct: make journal_info conditional"Linus Torvalds
This reverts commit e4c570c4cb7a95dbfafa3d016d2739bf3fdfe319, as requested by Alexey: "I think I gave a good enough arguments to not merge it. To iterate: * patch makes impossible to start using ext3 on EXT3_FS=n kernels without reboot. * this is done only for one pointer on task_struct" None of config options which define task_struct are tristate directly or effectively." Requested-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15task_struct: make journal_info conditionalHiroshi Shimamoto
journal_info in task_struct is used in journaling file system only. So introduce CONFIG_FS_JOURNAL_INFO and make it conditional. Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-04Btrfs: make btrfs acls selectableChristian Hesse
This patch adds a menu entry to kconfig to enable acls for btrfs. This allows you to enable FS_POSIX_ACL at kernel compile time. (updated by Jeff Mahoney to make the changes in fs/btrfs/Kconfig instead) Signed-off-by: Christian Hesse <mail@earthworm.de> Signed-off-by: Jeff Mahoney <jeffm@suse.com>
2009-01-22fs/Kconfig: move btrfs outAlexey Dobriyan
