fs/btrfs/ctree.h
Signed-off-by: Chris Mason <chris.mason@oracle.com>
We all keep getting those stupid warnings from use_block_rsv when running
stress.sh, and it's because the delayed insertion stuff is being stupid. It's
not the delayed insertion stuffs fault, it's all just stupid. When marking an
inode dirty for oh say updating the time on it, we just do a
btrfs_join_transaction, which doesn't reserve any space. This is stupid because
we're going to have to have space reserve to make this change, but we do it
because it's fast because chances are we're going to call it over and over again
and it doesn't matter. Well thanks to the delayed insertion stuff this is
mostly the case, so we do actually need to make this reservation. So if
trans->bytes_reserved is 0 then try to do a normal reservation. If not return
ENOSPC which will make the btrfs_dirty_inode start a proper transaction which
will let it do the whole ENOSPC dance and reserve enough space for the delayed
insertion to steal the reservation from the transaction.
The other stupid thing we do is not reserve space for the inode when writing to
the thing. Usually this is ok since we have to update the time so we'd have
already done all this work before we get to the endio stuff, so it doesn't
matter. But this is stupid because we could write the data after the
transaction commits where we changed the mtime of the inode so we have to cow
all the way down to the inode anyway. This used to be masked by the delalloc
reservation stuff, but because we delay the update it doesn't get masked in this
case. So again the delayed insertion stuff bites us in the ass. So if our
trans->block_rsv is delalloc, just steal the reservation from the delalloc
reserve. Hopefully this won't bite us in the ass, but I've said that before.
With this patch stress.sh no longer spits out those stupid warnings (famous last
words). Thanks,
Signed-off-by: Josef Bacik <josef@redhat.com>
I've been hitting warnings in use_block_rsv when running the delayed insertion
stuff. It's because we will readjust global block rsv based on what is in use,
which means we could end up discarding reservations that are for the delayed
insertion stuff. So instead create a seperate block rsv for the delayed
insertion stuff. This will also make it easier to debug problems with the
delayed insertion reservations since we will know that only the delayed
insertion code touches this block_rsv. Thanks,
This takes some of the free space in the btrfs super block
to record information about most of the roots in the last four
commits.
It also adds a -o recovery to use the root history log when
we're not able to read the tree of tree roots, the extent
tree root, the device tree root or the csum root.
fs_info has now ~9kb, more than fits into one page. This will cause
mount failure when memory is too fragmented. Top space consumers are
super block structures super_copy and super_for_commit, ~2.8kb each.
Allocate them dynamically. fs_info will be ~3.5kb. (measured on x86_64)
Add a wrapper for freeing fs_info and all of it's dynamically allocated
members.
Signed-off-by: David Sterba <dsterba@suse.cz>
The tree log had two important bugs that could cause corruptions after a
crash. Sometimes we were allowing tree log blocks to be reused after
the tree log was committed but before the transaction commit was done.
This allowed a future metadata write to overwrite the tree log data. It
is fixed by adding a new variant of freeing reserved extents that always
pins them. Credit goes to Stefan Behrens and Arne Jansen for many many
hours spent tracking this bug down.
During tree log replay, we do a pass through the tree log and pin all
the extents we find. This makes sure the replay code won't go in and
use any of those blocks for new allocations during replay. The problem
is the free space cache isn't honoring these pinned extents. So the
allocator can end up handing them out, leading to all kinds of problems
during replay.
The fix here is to force any free space cache to load while we pin the
extents, and then to make sure we remove the pinned extents from the
free space rbtree.
Reported-by: Stefan Behrens <sbehrens@giantdisaster.de>
Currently btrfs_block_rsv_check does 2 things, it will either refill a block
reserve like in the truncate or refill case, or it will check to see if there is
enough space in the global reserve and possibly refill it. However because of
overcommit we could be well overcommitting ourselves just to try and refill the
global reserve, when really we should just be committing the transaction. So
breack this out into btrfs_block_rsv_refill and btrfs_block_rsv_check. Refill
will try to reserve more metadata if it can and btrfs_block_rsv_check will not,
it will only tell you if the factor of the total space is still reserved.
Thanks,
Yeah yeah I know this is how we used to do it and then I changed it, but damnit
I'm changing it back. The fact is that writing out checksums will modify
metadata, which could cause us to dirty a block group we've already written out,
so we have to truncate it and all of it's checksums and re-write it which will
write new checksums which could dirty a blockg roup that has already been
written and you see where I'm going with this? This can cause unmount or really
anything that depends on a transaction to commit to take it's sweet damned time
to happen. So go back to the way it was, only this time we're specifically
setting NODATACOW because we can't go through the COW pathway anyway and we're
doing our own built-in cow'ing by truncating the free space cache. The other
new thing is once we truncate the old cache and preallocate the new space, we
don't need to do that song and dance at all for the rest of the transaction, we
can just overwrite the existing space with the new cache if the block group
changes for whatever reason, and the NODATACOW will let us do this fine. So
keep track of which transaction we last cleared our cache in and if we cleared
it in this transaction just say we're all setup and carry on. This survives
xfstests and stress.sh.
The inode cache will continue to use the normal csum infrastructure since it
only gets written once and there will be no more modifications to the fs tree in
a transaction commit.
One of the things that kills us is the fact that our ENOSPC reservations are
horribly over the top in most normal cases. There isn't too much that can be
done about this because when we are completely full we really need them to work
like this so we don't under reserve. However if there is plenty of unallocated
chunks on the disk we can use that to gauge how much we can overcommit. So this
patch adds chunk free space accounting so we always know how much unallocated
space we have. Then if we fail to make a reservation within our allocated
space, check to see if we can overcommit. In the normal flushing case (like
with delalloc metadata reservations) we'll take the free space and divide it by
2 if our metadata profile is setup for DUP or any of those, and then divide it
by 8 to make sure we don't overcommit too much. Then if we're in a non-flushing
case (we really need this reservation now!) we only limit ourselves to half of
the free space. This makes this fio test
[torrent]
filename=torrent-test
rw=randwrite
size=4g
ioengine=sync
directory=/mnt/btrfs-test
go from taking around 45 minutes to 10 seconds on my freshly formatted 3 TiB
file system. This doesn't seem to break my other enospc tests, but could really
use some more testing as this is a super scary change. Thanks,
Johannes pointed out we were allocating only kernel pages for doing writes,
which is kind of a big deal if you are on 32bit and have more than a gig of ram.
So fix our allocations to use the mapping's gfp but still clear __GFP_FS so we
don't re-enter. Thanks,
Reported-by: Johannes Weiner <jweiner@redhat.com>
The only thing that we need to have a trans handle for is in
reserve_metadata_bytes and thats to know how much flushing we can do. So
instead of passing it around, just check current->journal_info for a
trans_handle so we know if we can commit a transaction to try and free up space
or not. Thanks,
If you run xfstest 224 it you will get lots of messages about not being able to
delete inodes and that they will be cleaned up next mount. This is because
btrfs_block_rsv_check was not calling reserve_metadata_bytes with the ability to
flush, so if there was not enough space, it simply failed. But in truncate and
evict case we could easily flush space to try and get enough space to do our
work, so make btrfs_block_rsv_check take a flush argument to pass down to
reserve_metadata_bytes. Now xfstests 224 runs fine without all those
complaints. Thanks,
With btrfs_truncate_inode_items we always return if we have to go to another
leaf, which makes us do our reservation again. This means we will only ever
modify one leaf at a time, so we only need 1 items worth of slack space. Also,
since we are deleting we will not be creating nodes as we go down, if anything
we'll be free'ing them as we merge them together, so make a different
calculation for truncate which will only have the worst case useage of COW'ing
the entire path down to the leaf. Thanks,
Since we've optimized the truncate path, we no longer require this function.
The priority and refill_used flags are not used anymore, and neither is the
usage counter, so just remove them from btrfs_block_rsv.
This is confusing code and isn't used by anything anymore, so delete it.
This patch kills off the calculation for the amount of space needed for the
orphan operations during a snapshot. The thing is we only do snapshots on
commit, so any space that is in the block_rsv->freed[] isn't going to be in the
new snapshot anyway, so there isn't any reason to require that space to be
reserved for the snapshot to occur. Thanks,
We have been using bytes_reserved for metadata reservations, which is wrong
since we use that to keep track of outstanding reservations from the allocator.
This resulted in us doing a lot of silly things to make sure we don't allocate a
bunch of metadata chunks since we never had a real view of how much space was
actually in use by metadata.
This passes Arne's enospc test and xfstests as well as my own enospc tests.
Hopefully this will get us moving in the right direction. Thanks,
This is the implementation for the generic read ahead framework.
To trigger a readahead, btrfs_reada_add must be called. It will start
a read ahead for the given range [start, end) on tree root. The returned
handle can either be used to wait on the readahead to finish
(btrfs_reada_wait), or to send it to the background (btrfs_reada_detach).
The read ahead works as follows:
On btrfs_reada_add, the root of the tree is inserted into a radix_tree.
reada_start_machine will then search for extents to prefetch and trigger
some reads. When a read finishes for a node, all contained node/leaf
pointers that lie in the given range will also be enqueued. The reads will
be triggered in sequential order, thus giving a big win over a naive
enumeration. It will also make use of multi-device layouts. Each disk
will have its on read pointer and all disks will by utilized in parallel.
Also will no two disks read both sides of a mirror simultaneously, as this
would waste seeking capacity. Instead both disks will read different parts
of the filesystem.
Any number of readaheads can be started in parallel. The read order will be
determined globally, i.e. 2 parallel readaheads will normally finish faster
than the 2 started one after another.
Changes v2:
- protect root->node by transaction instead of node_lock
- fix missed branches:
The readahead had a too simple check to determine if a branch from
a node should be checked or not. It now also records the upper bound
of each node to see if the requested RA range lies within.
- use KERN_CONT to debug output, to avoid line breaks
- defer reada_start_machine to worker to avoid deadlock
Changes v3:
- protect root->node by rcu
Changes v5:
- changed EIO-semantics of reada_tree_block_flagged
- remove spin_lock from reada_control and make elems an atomic_t
- remove unused read_total from reada_control
- kill reada_key_cmp, use btrfs_comp_cpu_keys instead
- use kref-style release functions where possible
- return struct reada_control * instead of void * from btrfs_reada_add
Signed-off-by: Arne Jansen <sensille@gmx.net>
Add state information for readahead to btrfs_fs_info and btrfs_device
Changes v2:
- don't wait in radix_trees
- add own set of workers for readahead
Reviewed-by: Josef Bacik <josef@redhat.com>
We've stopped using highmem for extent buffers.
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
The filesystem turns readonly instead of returning the error to the
caller when detected error in btrfs_drop_snapshot().
and, because the caller doesn't check the error, the function type is
changed to 'void'.
Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (31 commits)
Btrfs: don't call writepages from within write_full_page
Btrfs: Remove unused variable 'last_index' in file.c
Btrfs: clean up for find_first_extent_bit()
Btrfs: clean up for wait_extent_bit()
Btrfs: clean up for insert_state()
Btrfs: remove unused members from struct extent_state
Btrfs: clean up code for merging extent maps
Btrfs: clean up code for extent_map lookup
Btrfs: clean up search_extent_mapping()
Btrfs: remove redundant code for dir item lookup
Btrfs: make acl functions really no-op if acl is not enabled
Btrfs: remove remaining ref-cache code
Btrfs: remove a BUG_ON() in btrfs_commit_transaction()
Btrfs: use wait_event()
Btrfs: check the nodatasum flag when writing compressed files
Btrfs: copy string correctly in INO_LOOKUP ioctl
Btrfs: don't print the leaf if we had an error
btrfs: make btrfs_set_root_node void
Btrfs: fix oops while writing data to SSD partitions
Btrfs: Protect the readonly flag of block group
Fix up trivial conflicts (due to acl and writeback cleanups) in
- fs/btrfs/acl.c
- fs/btrfs/ctree.h
- fs/btrfs/extent_io.c
So there's no overhead for something we don't use.
This is fairly trivial - btrfs_set_root_node() - always returns zero so we
can just make it void. All callers ignore the return code now anyway. I
also made sure to check that none of the functions that
btrfs_set_root_node() calls returns an error that we might have needed to
catch and pass back.
Signed-off-by: Mark Fasheh <mfasheh@suse.com>
We passed the wrong value to btrfs_force_ra(). Fix this by changing
the argument of btrfs_force_ra() from last_index to nr_page.
Btrfs: make sure reserve_metadata_bytes doesn't leak out strange errors
Btrfs: use the commit_root for reading free_space_inode crcs
Btrfs: reduce extent_state lock contention for metadata
Btrfs: remove lockdep magic from btrfs_next_leaf
Btrfs: make a lockdep class for each root
Btrfs: switch the btrfs tree locks to reader/writer
Btrfs: fix deadlock when throttling transactions
Btrfs: stop using highmem for extent_buffers
Btrfs: fix BUG_ON() caused by ENOSPC when relocating space
Btrfs: tag pages for writeback in sync
Btrfs: fix enospc problems with delalloc
Btrfs: don't flush delalloc arbitrarily
Btrfs: use find_or_create_page instead of grab_cache_page
Btrfs: use a worker thread to do caching
Btrfs: fix how we merge extent states and deal with cached states
Btrfs: use the normal checksumming infrastructure for free space cache
Btrfs: serialize flushers in reserve_metadata_bytes
Btrfs: do transaction space reservation before joining the transaction
Btrfs: try to only do one btrfs_search_slot in do_setxattr
The btrfs metadata btree is the source of significant
lock contention, especially in the root node. This
commit changes our locking to use a reader/writer
lock.
The lock is built on top of rw spinlocks, and it
extends the lock tracking to remember if we have a
read lock or a write lock when we go to blocking. Atomics
count the number of blocking readers or writers at any
given time.
It removes all of the adaptive spinning from the old code
and uses only the spinning/blocking hints inside of btrfs
to decide when it should continue spinning.
In read heavy workloads this is dramatically faster. In write
heavy workloads we're still faster because of less contention
on the root node lock.
We suffer slightly in dbench because we schedule more often
during write locks, but all other benchmarks so far are improved.
So I had this brilliant idea to use atomic counters for outstanding and reserved
extents, but this turned out to be a bad idea. Consider this where we have 1
outstanding extent and 1 reserved extent
Reserver Releaser
atomic_dec(outstanding) now 0
atomic_read(outstanding)+1 get 1
atomic_read(reserved) get 1
don't actually reserve anything because
they are the same
atomic_cmpxchg(reserved, 1, 0)
atomic_inc(outstanding)
atomic_add(0, reserved)
free reserved space for 1 extent
Then the reserver now has no actual space reserved for it, and when it goes to
finish the ordered IO it won't have enough space to do it's allocation and you
get those lovely warnings.
A user reported a deadlock when copying a bunch of files. This is because they
were low on memory and kthreadd got hung up trying to migrate pages for an
allocation when starting the caching kthread. The page was locked by the person
starting the caching kthread. To fix this we just need to use the async thread
stuff so that the threads are already created and we don't have to worry about
deadlocks. Thanks,
Reported-by: Roman Mamedov <rm@romanrm.ru>
Replace the ->check_acl method with a ->get_acl method that simply reads an
ACL from disk after having a cache miss. This means we can replace the ACL
checking boilerplate code with a single implementation in namei.c.
Btrfs needs to be able to control how filemap_write_and_wait_range() is called
in fsync to make it less of a painful operation, so push down taking i_mutex and
the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some
file systems can drop taking the i_mutex altogether it seems, like ext3 and
ocfs2. For correctness sake I just pushed everything down in all cases to make
sure that we keep the current behavior the same for everybody, and then each
individual fs maintainer can make up their mind about what to do from there.
Thanks,
Acked-by: Jan Kara <jack@suse.cz>
In order to handle SEEK_HOLE/SEEK_DATA we need to implement our own llseek.
Basically for the normal SEEK_*'s we will just defer to the generic helper, and
for SEEK_HOLE/SEEK_DATA we will use our fiemap helper to figure out the nearest
hole or data. Currently this helper doesn't check for delalloc bytes for
prealloc space, so for now treat prealloc as data until that is fixed. Thanks,
not used in the instances anymore.
We keep having problems with early enospc, and that's because our method of
making space is inherently racy. The problem is we can have one guy trying to
make space for himself, and in the meantime people come in and steal his
reservation. In order to stop this we make a waitqueue and put anybody who
comes into reserve_metadata_bytes on that waitqueue if somebody is trying to
make more space. Thanks,
We have to do weird things when handling enospc in the transaction joining code.
Because we've already joined the transaction we cannot commit the transaction
within the reservation code since it will deadlock, so we have to return EAGAIN
and then make sure we don't retry too many times. Instead of doing this, just
do the reservation the normal way before we join the transaction, that way we
can do whatever we want to try and reclaim space, and then if it fails we know
for sure we are out of space and we can return ENOSPC. Thanks,
btrfs: fix oops when doing space balance
Btrfs: don't panic if we get an error while balancing V2
btrfs: add missing options displayed in mount output
There are three missed mount options settable by user which are not
currently displayed in mount output.
It was pointed out by 'make versioncheck' that some includes of
linux/version.h were not needed in fs/ (fs/btrfs/ctree.h and
fs/omfs/file.c).
This patch removes them.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Acked-by: Bob Copeland <me@bobcopeland.com>
Btrfs: avoid delayed metadata items during commits
btrfs: fix uninitialized return value
btrfs: fix wrong reservation when doing delayed inode operations
btrfs: Remove unused sysfs code
btrfs: fix dereference of ERR_PTR value
Btrfs: fix relocation races
Btrfs: set no_trans_join after trying to expand the transaction
Btrfs: protect the pending_snapshots list with trans_lock
Btrfs: fix path leakage on subvol deletion
Btrfs: drop the delalloc_bytes check in shrink_delalloc
Btrfs: check the return value from set_anon_super
Removes code no longer used. The sysfs file itself is kept, because the
btrfs developers expressed interest in putting new entries to sysfs.
Signed-off-by: Maarten Lankhorst <m.b.lankhorst@gmail.com>
The recent commit to get rid of our trans_mutex introduced
some races with block group relocation. The problem is that relocation
needs to do some record keeping about each root, and it was relying
on the transaction mutex to coordinate things in subtle ways.
This fix adds a mutex just for the relocation code and makes sure
it doesn't have a big impact on normal operations. The race is
really fixed in btrfs_record_root_in_trans, which is where we
step back and wait for the relocation code to finish accounting
setup.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (25 commits)
btrfs: fix uninitialized variable warning
btrfs: add helper for fs_info->closing
Btrfs: add mount -o inode_cache
btrfs: scrub: add explicit plugging
btrfs: use btrfs_ino to access inode number
Btrfs: don't save the inode cache if we are deleting this root
btrfs: false BUG_ON when degraded
Btrfs: don't save the inode cache in non-FS roots
Btrfs: make sure we don't overflow the free space cache crc page
Btrfs: fix uninit variable in the delayed inode code
btrfs: scrub: don't reuse bios and pages
Btrfs: leave spinning on lookup and map the leaf
Btrfs: check for duplicate entries in the free space cache
Btrfs: don't try to allocate from a block group that doesn't have enough space
Btrfs: don't always do readahead
Btrfs: try not to sleep as much when doing slow caching
Btrfs: kill BTRFS_I(inode)->block_group
Btrfs: don't look at the extent buffer level 3 times in a row
Btrfs: map the node block when looking for readahead targets
Btrfs: set range_start to the right start in count_range_bits
wrap checking of filesystem 'closing' flag and fix a few missing memory
barriers.
This makes the inode map cache default to off until we
fix the overflow problem when the free space crcs don't fit
inside a single page.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (36 commits)
Cache xattr security drop check for write v2
fs: block_page_mkwrite should wait for writeback to finish
mm: Wait for writeback when grabbing pages to begin a write
configfs: remove unnecessary dentry_unhash on rmdir, dir rename
fat: remove unnecessary dentry_unhash on rmdir, dir rename
hpfs: remove unnecessary dentry_unhash on rmdir, dir rename
minix: remove unnecessary dentry_unhash on rmdir, dir rename
fuse: remove unnecessary dentry_unhash on rmdir, dir rename
coda: remove unnecessary dentry_unhash on rmdir, dir rename
afs: remove unnecessary dentry_unhash on rmdir, dir rename
affs: remove unnecessary dentry_unhash on rmdir, dir rename
9p: remove unnecessary dentry_unhash on rmdir, dir rename
ncpfs: fix rename over directory with dangling references
ncpfs: document dentry_unhash usage
ecryptfs: remove unnecessary dentry_unhash on rmdir, dir rename
hostfs: remove unnecessary dentry_unhash on rmdir, dir rename
hfsplus: remove unnecessary dentry_unhash on rmdir, dir rename
hfs: remove unnecessary dentry_unhash on rmdir, dir rename
omfs: remove unnecessary dentry_unhash on rmdir, dir rneame
udf: remove unnecessary dentry_unhash from rmdir, dir rename
git://git.kernel.org/pub/scm/linux/kernel/git/josef/btrfs-work into for-linus
fs/btrfs/disk-io.c
fs/btrfs/extent-tree.c
fs/btrfs/free-space-cache.c
fs/btrfs/inode.c
fs/btrfs/transaction.c
