As we delete large extents, we end up doing huge amounts of COW in order
to delete the corresponding crcs. This adds accounting so that we keep
track of that space and flushing of delayed refs so that we don't build
up too much delayed crc work.
This helps limit the delayed work that must be done at commit time and
tries to avoid ENOSPC aborts because the crcs eat all the global
reserves.
Signed-off-by: Chris Mason <clm@fb.com>
Currently qgroups account for space by intercepting delayed ref updates to fs
trees. It does this by adding sequence numbers to delayed ref updates so that
it can figure out how the tree looked before the update so we can adjust the
counters properly. The problem with this is that it does not allow delayed refs
to be merged, so if you say are defragging an extent with 5k snapshots pointing
to it we will thrash the delayed ref lock because we need to go back and
manually merge these things together. Instead we want to process quota changes
when we know they are going to happen, like when we first allocate an extent, we
free a reference for an extent, we add new references etc. This patch
accomplishes this by only adding qgroup operations for real ref changes. We
only modify the sequence number when we need to lookup roots for bytenrs, this
reduces the amount of churn on the sequence number and allows us to merge
delayed refs as we add them most of the time. This patch encompasses a bunch of
architectural changes
1) qgroup ref operations: instead of tracking qgroup operations through the
delayed refs we simply add new ref operations whenever we notice that we need to
when we've modified the refs themselves.
2) tree mod seq: we no longer have this separation of major/minor counters.
this makes the sequence number stuff much more sane and we can remove some
locking that was needed to protect the counter.
3) delayed ref seq: we now read the tree mod seq number and use that as our
sequence. This means each new delayed ref doesn't have it's own unique sequence
number, rather whenever we go to lookup backrefs we inc the sequence number so
we can make sure to keep any new operations from screwing up our world view at
that given point. This allows us to merge delayed refs during runtime.
With all of these changes the delayed ref stuff is a little saner and the qgroup
accounting stuff no longer goes negative in some cases like it was before.
Thanks,
Signed-off-by: Josef Bacik <jbacik@fb.com>
Currently we have two rb-trees, one for delayed ref heads and one for all of the
delayed refs, including the delayed ref heads. When we process the delayed refs
we have to hold onto the delayed ref lock for all of the selecting and merging
and such, which results in quite a bit of lock contention. This was solved by
having a waitqueue and only one flusher at a time, however this hurts if we get
a lot of delayed refs queued up.
So instead just have an rb tree for the delayed ref heads, and then attach the
delayed ref updates to an rb tree that is per delayed ref head. Then we only
need to take the delayed ref lock when adding new delayed refs and when
selecting a delayed ref head to process, all the rest of the time we deal with a
per delayed ref head lock which will be much less contentious.
The locking rules for this get a little more complicated since we have to lock
up to 3 things to properly process delayed refs, but I will address that problem
later. For now this passes all of xfstests and my overnight stress tests.
Thanks,
The way how we process delayed refs is
1) get a bunch of head refs,
2) pick up one head ref,
3) go one node back for any delayed ref updates.
The head ref is also linked in the same rbtree as the delayed ref is,
so in 1) stage, we have to walk one by one including not only head refs, but
delayed refs.
When we have a great number of delayed refs pending to process,
this'll cost time a lot.
Here we introduce a head ref specific rbtree, it only has head refs, so troubles
go away.
Signed-off-by: Liu Bo <bo.li.liu@oracle.com>
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
Chris hit a bug where we weren't finding extent records when running extent ops.
This is because we use the delayed_ref_head when running the extent op, which
means we can't use the ->type checks to see if we are metadata. We also lose
the level of the metadata we are working on. So to fix this we can just check
the ->is_data section of the extent_op, and we can store the level of the buffer
we were modifying in the extent_op. Thanks,
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
fs/btrfs/ctree.h
fs/btrfs/extent-tree.c
fs/btrfs/inode.c
fs/btrfs/volumes.c
Locking and unlocking delayed ref mutex are in the different functions,
and the name of lock functions is not uniform, so the readability is not
so good, this patch optimizes the lock logic and makes it more readable.
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
The delayed reference allocation is in the fast path of the IO, so use slabs
to improve the speed of the allocation.
And besides that, it can do check for leaked objects when the module is removed.
We batch up operations to the extent allocation tree, which allows
us to deal with the recursive nature of using the extent allocation
tree to allocate extents to the extent allocation tree.
It also provides a mechanism to sort and collect extent
operations, which makes it much more efficient to record extents
that are close together.
The delayed extent operations must all be finished before the
running transaction commits, so we have code to make sure and run a few
of the batched operations when closing our transaction handles.
This creates a great deal of contention for the locks in the
delayed extent operation tree, and also contention for the lock on the
extent allocation tree itself. All the extra contention just slows
down the operations and doesn't get things done any faster.
This commit changes things to use a wait queue instead. As procs
want to run the delayed operations, one of them races in and gets
permission to hit the tree, and the others step back and wait for
progress to be made.
Pull the trivial tree from Jiri Kosina:
"Tiny usual fixes all over the place"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits)
doc: fix old config name of kprobetrace
fs/fs-writeback.c: cleanup riteback_sb_inodes kerneldoc
btrfs: fix the commment for the action flags in delayed-ref.h
btrfs: fix trivial typo for the comment of BTRFS_FREE_INO_OBJECTID
vfs: fix kerneldoc for generic_fh_to_parent()
treewide: fix comment/printk/variable typos
ipr: fix small coding style issues
doc: fix broken utf8 encoding
nfs: comment fix
platform/x86: fix asus_laptop.wled_type module parameter
mfd: printk/comment fixes
doc: getdelays.c: remember to close() socket on error in create_nl_socket()
doc: aliasing-test: close fd on write error
mmc: fix comment typos
dma: fix comments
spi: fix comment/printk typos in spi
Coccinelle: fix typo in memdup_user.cocci
tmiofb: missing NULL pointer checks
tools: perf: Fix typo in tools/perf
tools/testing: fix comment / output typos
The action field has been merged into struct btrfs_delayed_ref_node,
and no struct btrfs_delayed_ref is available now.
Signed-off-by: Wang Sheng-Hui <shhuiw@gmail.com>
Daniel Blueman reported a bug with fio+balance on a ramdisk setup.
Basically what happens is the balance relocates a tree block which will drop
the implicit refs for all of its children and adds a full backref. Once the
block is relocated we have to add the implicit refs back, so when we cow the
block again we add the implicit refs for its children back. The problem
comes when the original drop ref doesn't get run before we add the implicit
refs back. The delayed ref stuff will specifically prefer ADD operations
over DROP to keep us from freeing up an extent that will have references to
it, so we try to add the implicit ref before it is actually removed and we
panic. This worked fine before because the add would have just canceled the
drop out and we would have been fine. But the backref walking work needs to
be able to freeze the delayed ref stuff in time so we have this ever
increasing sequence number that gets attached to all new delayed ref updates
which makes us not merge refs and we run into this issue.
So to fix this we need to merge delayed refs. So everytime we run a
clustered ref we need to try and merge all of its delayed refs. The backref
walking stuff locks the delayed ref head before processing, so if we have it
locked we are safe to merge any refs inside of the sequence number. If
there is no sequence number we can merge all refs. Doing this not only
fixes our bug but keeps the delayed ref code from adding and removing
useless refs and batching together multiple refs into one search instead of
one search per delayed ref, which will really help our commit times. I ran
this with Daniels test and 276 and I haven't seen any problems. Thanks,
Reported-by: Daniel J Blueman <daniel@quora.org>
Hooks into qgroup code to record refs and into transaction commit.
This is the main entry point for qgroup. Basically every change in
extent backrefs got accounted to the appropriate qgroups.
Signed-off-by: Arne Jansen <sensille@gmx.net>
Signed-off-by: Jan Schmidt <list.btrfs@jan-o-sch.net>
We've got two mechanisms both required for reliable backref resolving (tree
mod log and holding back delayed refs). You cannot make use of one without
the other. So instead of requiring the user of this mechanism to setup both
correctly, we join them into a single interface.
Additionally, we stop inserting non-blockers into fs_info->tree_mod_seq_list
as we did before, which was of no value.
The sequence number for delayed refs is needed to postpone certain delayed
refs for a very short period while walking backrefs. Before the tree
modification log, we thought we'd only have to hold back those references
that don't have a counter operation.
While now we've the tree mod log, we're rewinding fs tree blocks to a
defined consistent state. We cannot know in advance for which tree block
we'll be doing rewind operations later. Therefore, we must postpone all the
delayed refs for fs-tree blocks, even those having a counter operation.
Now that we may be holding back delayed refs for a limited period, we
might end up having no runnable delayed refs. Without this commit, we'd
do busy waiting in that thread until another (runnable) ref arives.
Instead, we're detecting this situation and use a waitqueue, such that
we only try to run more refs after
a) another runnable ref was added or
b) delayed refs are no longer held back
Sequence numbers are needed to reconstruct the backrefs of a given extent to
a certain point in time. The total set of backrefs consist of the set of
backrefs recorded on disk plus the enqueued delayed refs for it that existed
at that moment.
This patch also adds a list that records all delayed refs which are
currently in the process of being added.
When walking all refs of an extent in btrfs_find_all_roots(), we freeze the
current state of delayed refs, honor anythinh up to this point and prevent
processing newer delayed refs to assert consistency.
For consistent backref walking and (later) qgroup calculation the
information to which root a delayed ref belongs is useful even for shared
refs.
Add a for_cow parameter to add_delayed_*_ref and pass the appropriate value
from every call site. The for_cow parameter will later on be used to
determine if a ref will change anything with respect to qgroups.
Delayed refs coming from relocation are always counted as for_cow, as they
don't change subvol quota.
Also pass in the fs_info for later use.
btrfs_find_all_roots() will use this as an optimization, as changes that are
for_cow will not change anything with respect to which root points to a
certain leaf. Thus, we don't need to add the current sequence number to
those delayed refs.
Remove static and global declarations and/or definitions. Reduces size
of btrfs.ko by ~3.4kB.
402081 7464 200 409745 64091 btrfs.ko.base
398620 7144 200 405964 631cc btrfs.ko.remove-all
Signed-off-by: David Sterba <dsterba@suse.cz>
function prototypes without a body
Besides simplify the code, this change makes sure all metadata
reservation for normal metadata operations are released after
committing transaction.
Changes since V1:
Add code that check if unlink and rmdir will free space.
Add ENOSPC handling for clone ioctl.
Signed-off-by: Yan Zheng <zheng.yan@oracle.com>
Signed-off-by: Chris Mason <chris.mason@oracle.com>
This commit introduces a new kind of back reference for btrfs metadata.
Once a filesystem has been mounted with this commit, IT WILL NO LONGER
BE MOUNTABLE BY OLDER KERNELS.
When a tree block in subvolume tree is cow'd, the reference counts of all
extents it points to are increased by one. At transaction commit time,
the old root of the subvolume is recorded in a "dead root" data structure,
and the btree it points to is later walked, dropping reference counts
and freeing any blocks where the reference count goes to 0.
The increments done during cow and decrements done after commit cancel out,
and the walk is a very expensive way to go about freeing the blocks that
are no longer referenced by the new btree root. This commit reduces the
transaction overhead by avoiding the need for dead root records.
When a non-shared tree block is cow'd, we free the old block at once, and the
new block inherits old block's references. When a tree block with reference
count > 1 is cow'd, we increase the reference counts of all extents
the new block points to by one, and decrease the old block's reference count by
one.
This dead tree avoidance code removes the need to modify the reference
counts of lower level extents when a non-shared tree block is cow'd.
But we still need to update back ref for all pointers in the block.
This is because the location of the block is recorded in the back ref
item.
We can solve this by introducing a new type of back ref. The new
back ref provides information about pointer's key, level and in which
tree the pointer lives. This information allow us to find the pointer
by searching the tree. The shortcoming of the new back ref is that it
only works for pointers in tree blocks referenced by their owner trees.
This is mostly a problem for snapshots, where resolving one of these
fuzzy back references would be O(number_of_snapshots) and quite slow.
The solution used here is to use the fuzzy back references in the common
case where a given tree block is only referenced by one root,
and use the full back references when multiple roots have a reference
on a given block.
This commit adds per subvolume red-black tree to keep trace of cached
inodes. The red-black tree helps the balancing code to find cached
inodes whose inode numbers within a given range.
This commit improves the balancing code by introducing several data
structures to keep the state of balancing. The most important one
is the back ref cache. It caches how the upper level tree blocks are
referenced. This greatly reduce the overhead of checking back ref.
The improved balancing code scales significantly better with a large
number of snapshots.
This is a very large commit and was written in a number of
pieces. But, they depend heavily on the disk format change and were
squashed together to make sure git bisect didn't end up in a
bad state wrt space balancing or the format change.
btrfs_update_delayed_ref is optimized to add and remove different
references in one pass through the delayed ref tree. It is a zero
sum on the total number of refs on a given extent.
But, the code was recording an extra ref in the head node. This
never made it down to the disk but was used when deciding if it was
safe to free the extent while dropping snapshots.
The fix used here is to make sure the ref_mod count is unchanged
on the head ref when btrfs_update_delayed_ref is called.
The delayed reference queue maintains pending operations that need to
be done to the extent allocation tree. These are processed by
finding records in the tree that are not currently being processed one at
a time.
This is slow because it uses lots of time searching through the rbtree
and because it creates lock contention on the extent allocation tree
when lots of different procs are running delayed refs at the same time.
This commit changes things to grab a cluster of refs for processing,
using a cursor into the rbtree as the starting point of the next search.
This way we walk smoothly through the rbtree.
When extents are freed, it is likely that we've removed the last
delayed reference update for the extent. This checks the delayed
ref tree when things are freed, and if no ref updates area left it
immediately processes the delayed ref.
The extent allocation tree maintains a reference count and full
back reference information for every extent allocated in the
filesystem. For subvolume and snapshot trees, every time
a block goes through COW, the new copy of the block adds a reference
on every block it points to.
If a btree node points to 150 leaves, then the COW code needs to go
and add backrefs on 150 different extents, which might be spread all
over the extent allocation tree.
These updates currently happen during btrfs_cow_block, and most COWs
happen during btrfs_search_slot. btrfs_search_slot has locks held
on both the parent and the node we are COWing, and so we really want
to avoid IO during the COW if we can.
This commit adds an rbtree of pending reference count updates and extent
allocations. The tree is ordered by byte number of the extent and byte number
of the parent for the back reference. The tree allows us to:
1) Modify back references in something close to disk order, reducing seeks
2) Significantly reduce the number of modifications made as block pointers
are balanced around
3) Do all of the extent insertion and back reference modifications outside
of the performance critical btrfs_search_slot code.
#3 has the added benefit of greatly reducing the btrfs stack footprint.
The extent allocation tree modifications are done without the deep
(and somewhat recursive) call chains used in the past.
These delayed back reference updates must be done before the transaction
commits, and so the rbtree is tied to the transaction. Throttling is
implemented to help keep the queue of backrefs at a reasonable size.
Since there was a similar mechanism in place for the extent tree
extents, that is removed and replaced by the delayed reference tree.
Yan Zheng <yan.zheng@oracle.com> helped review and fixup this code.
