[ Upstream commit 1e1c50a929bc9e49bc3f9935b92450d9e69f8158 ]
do_chunk_alloc implements a loop checking whether there is a pending
chunk allocation and if so causes the caller do loop. Generally this
loop is executed only once, however testing with btrfs/072 on a single
core vm machines uncovered an extreme case where the system could loop
indefinitely. This is due to a missing cond_resched when loop which
doesn't give a chance to the previous chunk allocator finish its job.
The fix is to simply add the missing cond_resched.
Fixes: 6d74119f1a3e ("Btrfs: avoid taking the chunk_mutex in do_chunk_alloc")
Signed-off-by: Nikolay Borisov <nborisov@suse.com>
Reviewed-by: David Sterba <dsterba@suse.com>
Signed-off-by: David Sterba <dsterba@suse.com>
commit e19182c0fff451e3744c1107d98f072e7ca377a0 upstream.
If btrfs_del_root fails in btrfs_drop_snapshot, we'll pick up the
error but then return 0 anyway due to mixing err and ret.
Fixes: 79787eaab4612 ("btrfs: replace many BUG_ONs with proper error handling")
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
commit 8e138e0d92c6c9d3d481674fb14e3439b495be37 upstream.
We discovered a box that had double allocations, and suspected the space
cache may be to blame. While auditing the write out path I noticed that
if we've already setup the space cache we will just carry on. This
means that any error we hit after cache_save_setup before we go to
actually write the cache out we won't reset the inode generation, so
whatever was already written will be considered correct, except it'll be
stale. Fix this by _always_ resetting the generation on the block group
inode, this way we only ever have valid or invalid cache.
With this patch I was no longer able to reproduce cache corruption with
dm-log-writes and my bpf error injection tool.
Signed-off-by: Josef Bacik <jbacik@fb.com>
commit 17024ad0a0fdfcfe53043afb969b813d3e020c21 upstream.
If a lot of metadata is reserved for outstanding delayed allocations, we
rely on shrink_delalloc() to reclaim metadata space in order to fulfill
reservation tickets. However, shrink_delalloc() has a shortcut where if
it determines that space can be overcommitted, it will stop early. This
made sense before the ticketed enospc system, but now it means that
shrink_delalloc() will often not reclaim enough space to fulfill any
tickets, leading to an early ENOSPC. (Reservation tickets don't care
about being able to overcommit, they need every byte accounted for.)
Fix it by getting rid of the shortcut so that shrink_delalloc() reclaims
all of the metadata it is supposed to. This fixes early ENOSPCs we were
seeing when doing a btrfs receive to populate a new filesystem, as well
as early ENOSPCs Christoph saw when doing a big cp -r onto Btrfs.
Fixes: 957780eb2788 ("Btrfs: introduce ticketed enospc infrastructure")
Tested-by: Christoph Anton Mitterer <mail@christoph.anton.mitterer.name>
Reviewed-by: Josef Bacik <jbacik@fb.com>
Signed-off-by: Omar Sandoval <osandov@fb.com>
[ Upstream commit e321f8a801d7b4c40da8005257b05b9c2b51b072 ]
If @block_group is not @used_bg, it'll try to get @used_bg's lock without
droping @block_group 's lock and lockdep has throwed a scary deadlock warning
about it.
Fix it by using down_read_nested.
Signed-off-by: Liu Bo <bo.li.liu@oracle.com>
commit 896533a7da929136d0432713f02a3edffece2826 upstream.
If we fail to add the space_info kobject, we'll leak the memory
for the percpu counter.
Fixes: 6ab0a2029c (btrfs: publish allocation data in sysfs)
Reviewed-by: Liu Bo <bo.li.liu@oracle.com>
commit aa7c8da35d1905d80e840d075f07d26ec90144b5 upstream.
In __btrfs_run_delayed_refs, the error path when run_delayed_extent_op
fails sets locked_ref->processing = 0 but doesn't re-increment
delayed_refs->num_heads_ready. As a result, we end up triggering
the WARN_ON in btrfs_select_ref_head.
Fixes: d7df2c796d7 (Btrfs: attach delayed ref updates to delayed ref heads)
Reported-by: Jon Nelson <jnelson-suse@jamponi.net>
commit d0280996437081dd12ed1e982ac8aeaa62835ec4 upstream.
In __btrfs_run_delayed_refs, when we put back a delayed ref that's too
new, we have already dropped the lock on locked_ref when we set
->processing = 0.
This patch keeps the lock to cover that assignment.
This issue was found when testing in-band dedupe enospc behaviour,
sometimes run_one_delayed_ref() may fail for enospc reason, then
__btrfs_run_delayed_refs()will return, but forget to add num_heads_read
back, which will trigger "WARN_ON(delayed_refs->num_heads_ready == 0)" in
btrfs_select_ref_head().
Signed-off-by: Wang Xiaoguang <wangxg.fnst@cn.fujitsu.com>
This reverts commit 5d8eb6fe517583f9c6d5b94faf2254a0207a45c9.
When we remove devices, we free the device structures. Delaying
btfs_remove_chunk() ends up hitting a use-after-free on them.
Signed-off-by: Chris Mason <clm@fb.com>
Really there's lots of things that can go wrong here, kill all the
BUG_ON()'s and replace the logic ones with ASSERT()'s and return EIO
instead.
[ switched to btrfs_err, errors go to common label ]
Fixes: 7cf5b97650f2 ("btrfs: qgroup: Cleanup old inaccurate facilities")
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.com>
Code cleanup. count is already (unsgined long)-1. That is the reason
run_all was set. Do not reassign it (unsigned long)-1.
The extent buffer 'next' needs to be free'd conditionally.
For many printks, we want to know which file system issued the message.
This patch converts most pr_* calls to use the btrfs_* versions instead.
In some cases, this means adding plumbing to allow call sites access to
an fs_info pointer.
fs/btrfs/check-integrity.c is left alone for another day.
This patch converts printk(KERN_* style messages to use the pr_* versions.
One side effect is that anything that was KERN_DEBUG is now automatically
a dynamic debug message.
CodingStyle chapter 2:
"[...] never break user-visible strings such as printk messages,
because that breaks the ability to grep for them."
This patch unsplits user-visible strings.
In a corrupted btrfs image, we can come across this BUG_ON and
get an unreponsive system, but if we return errors instead,
its caller can handle everything gracefully by aborting the current
transaction.
Remove unneeded variables and assignments.
We have a lot of random ints in btrfs_fs_info that can be put into flags. This
is mostly equivalent with the exception of how we deal with quota going on or
off, now instead we set a flag when we are turning it on or off and deal with
that appropriately, rather than just having a pending state that the current
quota_enabled gets set to. Thanks,
Variable 'blocksize' in reada_walk_down() is not used since commit
d3e46fea1b1e ("btrfs: sink blocksize parameter to readahead_tree_block").
This patch simply removes this variable.
Signed-off-by: Luis Henriques <luis.henriques@canonical.com>
Currently, btrfs_relocate_chunk() is removing relocated BG by itself. But
the work can be done by btrfs_delete_unused_bgs() (and it's better since it
trim the BG). Let's dedupe the code.
While btrfs_delete_unused_bgs() is already hitting the relocated BG, it
skip the BG since the BG has "ro" flag set (to keep balancing BG intact).
On the other hand, btrfs cannot drop "ro" flag here to prevent additional
writes. So this patch make use of "removed" flag.
btrfs_delete_unused_bgs() now detect the flag to distinguish whether a
read-only BG is relocating or not.
Signed-off-by: Naohiro Aota <naohiro.aota@hgst.com>
Currently we allow inconsistence about mixed flag
(BTRFS_BLOCK_GROUP_METADATA | BTRFS_BLOCK_GROUP_DATA).
We'd get ENOSPC if block group has mixed flag and btrfs doesn't.
If that happens, we have one space_info with mixed flag and another
space_info only with BTRFS_BLOCK_GROUP_METADATA, and
global_block_rsv.space_info points to the latter one, but all bytes
from block_group contributes to the mixed space_info, thus all the
allocation will fail with ENOSPC.
This adds a check for the above case.
Reported-by: Vegard Nossum <vegard.nossum@oracle.com>
[ updated message ]
While processing delayed refs, we may update block group's statistics
and attach it to cur_trans->dirty_bgs, and later writing dirty block
groups will process the list, which happens during
btrfs_commit_transaction().
For whatever reason, the transaction is aborted and dirty_bgs
is not processed in cleanup_transaction(), we end up with memory leak
of these dirty block group cache.
Since btrfs_start_dirty_block_groups() doesn't make it go to the commit
critical section, this also adds the cleanup work inside it.
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs fixes from Chris Mason:
"Josef fixed a problem when quotas are enabled with his latest ENOSPC
rework, and Jeff added more checks into the subvol ioctls to avoid
tripping up lookup_one_len"
* 'for-linus-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
btrfs: ensure that file descriptor used with subvol ioctls is a dir
Btrfs: handle quota reserve failure properly
btrfs/022 was spitting a warning for the case that we exceed the quota. If we
fail to make our quota reservation we need to clean up our data space
reservation. Thanks,
Tested-by: Jeff Mahoney <jeffm@suse.com>
"I'm not proud of how long it took me to track down that one liner in
btrfs_sync_log(), but the good news is the patches I was trying to
blame for these problems were actually fine (sorry Filipe)"
btrfs: introduce tickets_id to determine whether asynchronous metadata reclaim work makes progress
btrfs: remove root_log_ctx from ctx list before btrfs_sync_log returns
btrfs: do not decrease bytes_may_use when replaying extents
In btrfs_async_reclaim_metadata_space(), we use ticket's address to
determine whether asynchronous metadata reclaim work is making progress.
ticket = list_first_entry(&space_info->tickets,
struct reserve_ticket, list);
if (last_ticket == ticket) {
flush_state++;
} else {
last_ticket = ticket;
flush_state = FLUSH_DELAYED_ITEMS_NR;
if (commit_cycles)
commit_cycles--;
But indeed it's wrong, we should not rely on local variable's address to
do this check, because addresses may be same. In my test environment, I
dd one 168MB file in a 256MB fs, found that for this file, every time
wait_reserve_ticket() called, local variable ticket's address is same,
For above codes, assume a previous ticket's address is addrA, last_ticket
is addrA. Btrfs_async_reclaim_metadata_space() finished this ticket and
wake up it, then another ticket is added, but with the same address addrA,
now last_ticket will be same to current ticket, then current ticket's flush
work will start from current flush_state, not initial FLUSH_DELAYED_ITEMS_NR,
which may result in some enospc issues(I have seen this in my test machine).
When replaying extents, there is no need to update bytes_may_use
in btrfs_alloc_logged_file_extent(), otherwise it'll trigger a
WARN_ON about bytes_may_use.
Fixes: ("btrfs: update btrfs_space_info's bytes_may_use timely")
"I'm still prepping a set of fixes for btrfs fsync, just nailing down a
hard to trigger memory corruption. For now, these are tested and ready."
btrfs: fix one bug that process may endlessly wait for ticket in wait_reserve_ticket()
Btrfs: fix endless loop in balancing block groups
Btrfs: kill invalid ASSERT() in process_all_refs()
If can_overcommit() in btrfs_calc_reclaim_metadata_size() returns true,
btrfs_async_reclaim_metadata_space() will not reclaim metadata space, just
return directly and also forget to wake up process which are waiting for
their tickets, so these processes will wait endlessly.
Fstests case generic/172 with mount option "-o compress=lzo" have revealed
this bug in my test machine. Here if we have tickets to handle, we must
handle them first.
"We've queued up a few different fixes in here. These range from
enospc corners to fsync and quota fixes, and a few targeted at error
handling for corrupt metadata/fuzzing"
Btrfs: fix lockdep warning on deadlock against an inode's log mutex
Btrfs: detect corruption when non-root leaf has zero item
Btrfs: check btree node's nritems
btrfs: don't create or leak aliased root while cleaning up orphans
Btrfs: fix em leak in find_first_block_group
btrfs: do not background blkdev_put()
Btrfs: clarify do_chunk_alloc()'s return value
btrfs: fix fsfreeze hang caused by delayed iputs deal
btrfs: divide btrfs_update_reserved_bytes() into two functions
btrfs: use correct offset for reloc_inode in prealloc_file_extent_cluster()
btrfs: qgroup: Fix qgroup incorrectness caused by log replay
btrfs: relocation: Fix leaking qgroups numbers on data extents
btrfs: qgroup: Refactor btrfs_qgroup_insert_dirty_extent()
btrfs: waiting on qgroup rescan should not always be interruptible
btrfs: properly track when rescan worker is running
btrfs: flush_space: treat return value of do_chunk_alloc properly
Btrfs: add ASSERT for block group's memory leak
btrfs: backref: Fix soft lockup in __merge_refs function
Btrfs: fix memory leak of reloc_root
We need to call free_extent_map() on the em we look up.
Reviewed-by: Omar Sandoval <osandov@fb.com>
Function start_transaction() can return ERR_PTR(1) when flush is
BTRFS_RESERVE_FLUSH_LIMIT, so the call graph is
start_transaction (return ERR_PTR(1))
-> btrfs_block_rsv_add (return 1)
-> reserve_metadata_bytes (return 1)
-> flush_space (return 1)
-> do_chunk_alloc (return 1)
With BTRFS_RESERVE_FLUSH_LIMIT, if flush_space is already on the
flush_state of ALLOC_CHUNK and it successfully allocates a new
chunk, then instead of trying to reserve space again,
reserve_metadata_bytes returns 1 immediately.
Eventually the callers who call start_transaction() usually just
do the IS_ERR() check which ERR_PTR(1) can pass, then it'll get
a panic when dereferencing a pointer which is ERR_PTR(1).
The following patch fixes the above problem.
"btrfs: flush_space: treat return value of do_chunk_alloc properly"
https://patchwork.kernel.org/patch/7778651/
This add comments to clarify do_chunk_alloc()'s return value.
This patch can fix some false ENOSPC errors, below test script can
reproduce one false ENOSPC error:
#!/bin/bash
dd if=/dev/zero of=fs.img bs=$((1024*1024)) count=128
dev=$(losetup --show -f fs.img)
mkfs.btrfs -f -M $dev
mkdir /tmp/mntpoint
mount $dev /tmp/mntpoint
cd /tmp/mntpoint
xfs_io -f -c "falloc 0 $((64*1024*1024))" testfile
Above script will fail for ENOSPC reason, but indeed fs still has free
space to satisfy this request. Please see call graph:
btrfs_fallocate()
|-> btrfs_alloc_data_chunk_ondemand()
| bytes_may_use += 64M
|-> btrfs_prealloc_file_range()
|-> btrfs_reserve_extent()
|-> btrfs_add_reserved_bytes()
| alloc_type is RESERVE_ALLOC_NO_ACCOUNT, so it does not
| change bytes_may_use, and bytes_reserved += 64M. Now
| bytes_may_use + bytes_reserved == 128M, which is greater
| than btrfs_space_info's total_bytes, false enospc occurs.
| Note, the bytes_may_use decrease operation will be done in
| end of btrfs_fallocate(), which is too late.
Here is another simple case for buffered write:
CPU 1 | CPU 2
|-> cow_file_range() |-> __btrfs_buffered_write()
|-> btrfs_reserve_extent() | |
| ..... | |-> btrfs_check_data_free_space()
|-> extent_clear_unlock_delalloc() |
In CPU 1, btrfs_reserve_extent()->find_free_extent()->
btrfs_add_reserved_bytes() do not decrease bytes_may_use, the decrease
operation will be delayed to be done in extent_clear_unlock_delalloc().
Assume in this case, btrfs_reserve_extent() reserved 128MB data, CPU2's
btrfs_check_data_free_space() tries to reserve 100MB data space.
If
100MB > data_sinfo->total_bytes - data_sinfo->bytes_used -
data_sinfo->bytes_reserved - data_sinfo->bytes_pinned -
data_sinfo->bytes_readonly - data_sinfo->bytes_may_use
btrfs_check_data_free_space() will try to allcate new data chunk or call
btrfs_start_delalloc_roots(), or commit current transaction in order to
reserve some free space, obviously a lot of work. But indeed it's not
necessary as long as decreasing bytes_may_use timely, we still have
free space, decreasing 128M from bytes_may_use.
To fix this issue, this patch chooses to update bytes_may_use for both
data and metadata in btrfs_add_reserved_bytes(). For compress path, real
extent length may not be equal to file content length, so introduce a
ram_bytes argument for btrfs_reserve_extent(), find_free_extent() and
btrfs_add_reserved_bytes(), it's becasue bytes_may_use is increased by
file content length. Then compress path can update bytes_may_use
correctly. Also now we can discard RESERVE_ALLOC_NO_ACCOUNT, RESERVE_ALLOC
and RESERVE_FREE.
As we know, usually EXTENT_DO_ACCOUNTING is used for error path. In
run_delalloc_nocow(), for inode marked as NODATACOW or extent marked as
PREALLOC, we also need to update bytes_may_use, but can not pass
EXTENT_DO_ACCOUNTING, because it also clears metadata reservation, so
here we introduce EXTENT_CLEAR_DATA_RESV flag to indicate btrfs_clear_bit_hook()
to update btrfs_space_info's bytes_may_use.
Meanwhile __btrfs_prealloc_file_range() will call
btrfs_free_reserved_data_space() internally for both sucessful and failed
path, btrfs_prealloc_file_range()'s callers does not need to call
btrfs_free_reserved_data_space() any more.
This patch divides btrfs_update_reserved_bytes() into
btrfs_add_reserved_bytes() and btrfs_free_reserved_bytes(), and
next patch will extend btrfs_add_reserved_bytes()to fix some
false ENOSPC error, please see later patch for detailed info.
Refactor btrfs_qgroup_insert_dirty_extent() function, to two functions:
1. btrfs_qgroup_insert_dirty_extent_nolock()
Almost the same with original code.
For delayed_ref usage, which has delayed refs locked.
Change the return value type to int, since caller never needs the
pointer, but only needs to know if they need to free the allocated
memory.
2. btrfs_qgroup_insert_dirty_extent()
The more encapsulated version.
Will do the delayed_refs lock, memory allocation, quota enabled check
and other things.
The original design is to keep exported functions to minimal, but since
more btrfs hacks exposed, like replacing path in balance, we need to
record dirty extents manually, so we have to add such functions.
Also, add comment for both functions, to info developers how to keep
qgroup correct when doing hacks.
Cc: Mark Fasheh <mfasheh@suse.de>
Signed-off-by: Qu Wenruo <quwenruo@cn.fujitsu.com>
Reviewed-and-Tested-by: Goldwyn Rodrigues <rgoldwyn@suse.com>
do_chunk_alloc returns 1 when it succeeds to allocate a new chunk.
But flush_space will not convert this to 0, and will also return 1.
As a result, reserve_metadata_bytes will think that flush_space failed,
and may potentially return this value "1" to the caller (depends how
reserve_metadata_bytes was called). The caller will also treat this as an error.
For example, btrfs_block_rsv_refill does:
int ret = -ENOSPC;
ret = reserve_metadata_bytes(root, block_rsv, num_bytes, flush);
if (!ret) {
block_rsv_add_bytes(block_rsv, num_bytes, 0);
return 0;
return ret;
So it will return -ENOSPC.
Signed-off-by: Alex Lyakas <alex@zadarastorage.com>
This adds several ASSERT()' s to report memory leak of block group cache.
Pull more btrfs updates from Chris Mason:
"This is part two of my btrfs pull, which is some cleanups and a batch
of fixes.
Most of the code here is from Jeff Mahoney, making the pointers we
pass around internally more consistent and less confusing overall. I
noticed a small problem right before I sent this out yesterday, so I
fixed it up and re-tested overnight"
* 'for-linus-4.8' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (40 commits)
Btrfs: fix __MAX_CSUM_ITEMS
btrfs: btrfs_abort_transaction, drop root parameter
btrfs: add btrfs_trans_handle->fs_info pointer
btrfs: btrfs_relocate_chunk pass extent_root to btrfs_end_transaction
btrfs: convert nodesize macros to static inlines
btrfs: introduce BTRFS_MAX_ITEM_SIZE
btrfs: cleanup, remove prototype for btrfs_find_root_ref
btrfs: copy_to_sk drop unused root parameter
btrfs: simpilify btrfs_subvol_inherit_props
btrfs: tests, use BTRFS_FS_STATE_DUMMY_FS_INFO instead of dummy root
btrfs: tests, require fs_info for root
btrfs: tests, move initialization into tests/
btrfs: btrfs_test_opt and friends should take a btrfs_fs_info
btrfs: prefix fsid to all trace events
btrfs: plumb fs_info into btrfs_work
btrfs: remove obsolete part of comment in statfs
btrfs: hide test-only member under ifdef
btrfs: Ratelimit "no csum found" info message
btrfs: Add ratelimit to btrfs printing
Btrfs: fix unexpected balance crash due to BUG_ON
Pull btrfs updates from Chris Mason:
"This pull is dedicated to Josef's enospc rework, which we've been
testing for a few releases now. It fixes some early enospc problems
and is dramatically faster.
This also includes an updated fix for the delalloc accounting that
happens after a fault in copy_from_user. My patch in v4.7 was almost
but not quite enough"
Btrfs: fix delalloc accounting after copy_from_user faults
Btrfs: avoid deadlocks during reservations in btrfs_truncate_block
Btrfs: use FLUSH_LIMIT for relocation in reserve_metadata_bytes
Btrfs: fill relocation block rsv after allocation
Btrfs: always use trans->block_rsv for orphans
Btrfs: change how we calculate the global block rsv
Btrfs: use root when checking need_async_flush
Btrfs: don't bother kicking async if there's nothing to reclaim
Btrfs: fix release reserved extents trace points
Btrfs: add fsid to some tracepoints
Btrfs: add tracepoints for flush events
Btrfs: fix delalloc reservation amount tracepoint
Btrfs: trace pinned extents
Btrfs: add tracepoint for adding block groups
Btrfs: warn_on for unaccounted spaces
Btrfs: change delayed reservation fallback behavior
Btrfs: always reserve metadata for delalloc extents
Btrfs: fix callers of btrfs_block_rsv_migrate
Btrfs: add bytes_readonly to the spaceinfo at once
Pull core block updates from Jens Axboe:
- the big change is the cleanup from Mike Christie, cleaning up our
uses of command types and modified flags. This is what will throw
some merge conflicts
- regression fix for the above for btrfs, from Vincent
- following up to the above, better packing of struct request from
Christoph
- a 2038 fix for blktrace from Arnd
- a few trivial/spelling fixes from Bart Van Assche
- a front merge check fix from Damien, which could cause issues on
SMR drives
- Atari partition fix from Gabriel
- convert cfq to highres timers, since jiffies isn't granular enough
for some devices these days. From Jan and Jeff
- CFQ priority boost fix idle classes, from me
- cleanup series from Ming, improving our bio/bvec iteration
- a direct issue fix for blk-mq from Omar
- fix for plug merging not involving the IO scheduler, like we do for
other types of merges. From Tahsin
- expose DAX type internally and through sysfs. From Toshi and Yigal
* 'for-4.8/core' of git://git.kernel.dk/linux-block: (76 commits)
block: Fix front merge check
block: do not merge requests without consulting with io scheduler
block: Fix spelling in a source code comment
block: expose QUEUE_FLAG_DAX in sysfs
block: add QUEUE_FLAG_DAX for devices to advertise their DAX support
Btrfs: fix comparison in __btrfs_map_block()
block: atari: Return early for unsupported sector size
Doc: block: Fix a typo in queue-sysfs.txt
cfq-iosched: Charge at least 1 jiffie instead of 1 ns
cfq-iosched: Fix regression in bonnie++ rewrite performance
cfq-iosched: Convert slice_resid from u64 to s64
block: Convert fifo_time from ulong to u64
blktrace: avoid using timespec
block/blk-cgroup.c: Declare local symbols static
block/bio-integrity.c: Add #include "blk.h"
block/partition-generic.c: Remove a set-but-not-used variable
block: bio: kill BIO_MAX_SIZE
cfq-iosched: temporarily boost queue priority for idle classes
block: drbd: avoid to use BIO_MAX_SIZE
block: bio: remove BIO_MAX_SECTORS
__btrfs_abort_transaction doesn't use its root parameter except to
obtain an fs_info pointer. We can obtain that from trans->root->fs_info
for now and from trans->fs_info in a later patch.
btrfs_trans_handle->root is documented as for use for confirming
that the root passed in to start the transaction is the same as the
one ending it. It's used in several places when an fs_info pointer
is needed, so let's just add an fs_info pointer directly. Eventually,
the root pointer can be removed.
We use BTRFS_LEAF_DATA_SIZE - sizeof(struct btrfs_item) in
several places. This introduces a BTRFS_MAX_ITEM_SIZE macro to do the
same.
Now that we have a dummy fs_info associated with each test that
uses a root, we don't need the DUMMY_ROOT bit anymore. This lets
us make choices without needing an actual root like in e.g.
btrfs_find_create_tree_block.
btrfs_test_opt and friends only use the root pointer to access
the fs_info. Let's pass the fs_info directly in preparation to
eliminate similar patterns all over btrfs.
When using trace events to debug a problem, it's impossible to determine
which file system generated a particular event. This patch adds a
macro to prefix standard information to the head of a trace event.
The extent_state alloc/free events are all that's left without an
fs_info available.
In btrfs, btrfs_space_info's bytes_may_use is treated as fs used
space, as what we do in reserve_metadata_bytes() or
btrfs_alloc_data_chunk_ondemand(), so in dump_space_info(), when
calculating free space, we should also subtract btrfs_space_info's
bytes_may_use.
