commit 3765fefaee2da83f10829fa64a74e6b7360350cb upstream.
Since the d_off in the first dirent for "." (that originates from
the 4th argument "offset" of filldir() for the 2nd dirent for "..")
is wrongly assigned in btrfs_real_readdir(), telldir returns same
offset for different locations.
| # mkfs.btrfs /dev/sdb1
| # mount /dev/sdb1 fs0
| # cd fs0
| # touch file0 file1
| # ../test
| telldir: 0
| readdir: d_off = 2, d_name = "."
| telldir: 2
| readdir: d_off = 2, d_name = ".."
| telldir: 2
| readdir: d_off = 3, d_name = "file0"
| telldir: 3
| readdir: d_off = 2147483647, d_name = "file1"
| telldir: 2147483647
To fix this problem, pass filp->f_pos (which is loff_t) instead.
| # ../test
| telldir: 0
| readdir: d_off = 1, d_name = "."
| telldir: 1
| telldir: 2
At the moment the "offset" for "." is unused because there is no
preceding dirent, however it is better to pass filp->f_pos to follow
grammatical usage.
Signed-off-by: Hidetoshi Seto <seto.hidetoshi@jp.fujitsu.com>
Signed-off-by: Chris Mason <chris.mason@oracle.com>
Cc: Grazvydas Ignotas <notasas@gmail.com>
commit 34f3e4f23ca3d259fe078f62a128d97ca83508ef upstream.
When btrfs recovers from a crash, it may hit the oops below:
kernel BUG at fs/btrfs/inode.c:4580!
RIP: 0010:[<ffffffffa03df251>] [<ffffffffa03df251>] btrfs_add_link+0x161/0x1c0 [btrfs]
Call Trace:
[<ffffffffa03e7b31>] ? btrfs_inode_ref_index+0x31/0x80 [btrfs]
[<ffffffffa04054e9>] add_inode_ref+0x319/0x3f0 [btrfs]
[<ffffffffa0407087>] replay_one_buffer+0x2c7/0x390 [btrfs]
[<ffffffffa040444a>] walk_down_log_tree+0x32a/0x480 [btrfs]
[<ffffffffa0404695>] walk_log_tree+0xf5/0x240 [btrfs]
[<ffffffffa0406cc0>] btrfs_recover_log_trees+0x250/0x350 [btrfs]
[<ffffffffa0406dc0>] ? btrfs_recover_log_trees+0x350/0x350 [btrfs]
[<ffffffffa03d18b2>] open_ctree+0x1442/0x17d0 [btrfs]
This comes from that while replaying an inode ref item, we forget to
check those old conflicting DIR_ITEM and DIR_INDEX items in fs/file tree,
then we will come to conflict corners which lead to BUG_ON().
Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com>
Tested-by: Andy Lutomirski <luto@mit.edu>
commit d5e2003c2bcda93a8f2e668eb4642d70c9c38301 upstream.
We have a problem where if a user specifies discard but doesn't actually support
it we will return EOPNOTSUPP from btrfs_discard_extent. This is a problem
because this gets called (in a fashion) from the tree log recovery code, which
has a nice little BUG_ON(ret) after it, which causes us to fail the tree log
replay. So instead detect wether our devices support discard when we're adding
them and then don't issue discards if we know that the device doesn't support
it. And just for good measure set ret = 0 in btrfs_issue_discard just in case
we still get EOPNOTSUPP so we don't screw anybody up like this again. Thanks,
Signed-off-by: Josef Bacik <josef@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable:
btrfs: fix oops when doing space balance
Btrfs: don't panic if we get an error while balancing V2
btrfs: add missing options displayed in mount output
We need to make sure the data relocation inode doesn't go through
the delayed metadata updates, otherwise we get an oops during balance:
kernel BUG at fs/btrfs/relocation.c:4303!
[SNIP]
Call Trace:
[<ffffffffa03143fd>] ? update_ref_for_cow+0x22d/0x330 [btrfs]
[<ffffffffa0314951>] __btrfs_cow_block+0x451/0x5e0 [btrfs]
[<ffffffffa031355d>] ? read_block_for_search+0x14d/0x4d0 [btrfs]
[<ffffffffa0314beb>] btrfs_cow_block+0x10b/0x240 [btrfs]
[<ffffffffa031acae>] btrfs_search_slot+0x49e/0x7a0 [btrfs]
[<ffffffffa032d8af>] btrfs_lookup_inode+0x2f/0xa0 [btrfs]
[<ffffffff8147bf0e>] ? mutex_lock+0x1e/0x50
[<ffffffffa0380cf1>] btrfs_update_delayed_inode+0x71/0x160 [btrfs]
[<ffffffffa037ff27>] ? __btrfs_release_delayed_node+0x67/0x190 [btrfs]
[<ffffffffa0381cf8>] btrfs_run_delayed_items+0xe8/0x120 [btrfs]
[<ffffffffa03365e0>] btrfs_commit_transaction+0x250/0x850 [btrfs]
[<ffffffff810f91d9>] ? find_get_pages+0x39/0x130
[<ffffffffa0336cd5>] ? join_transaction+0x25/0x250 [btrfs]
[<ffffffff81081de0>] ? wake_up_bit+0x40/0x40
[<ffffffffa03785fa>] prepare_to_relocate+0xda/0xf0 [btrfs]
[<ffffffffa037f2bb>] relocate_block_group+0x4b/0x620 [btrfs]
[<ffffffffa0334cf5>] ? btrfs_clean_old_snapshots+0x35/0x150 [btrfs]
[<ffffffffa037fa43>] btrfs_relocate_block_group+0x1b3/0x2e0 [btrfs]
[<ffffffffa0368ec0>] ? btrfs_tree_unlock+0x50/0x50 [btrfs]
[<ffffffffa035e39b>] btrfs_relocate_chunk+0x8b/0x670 [btrfs]
[<ffffffffa031303d>] ? btrfs_set_path_blocking+0x3d/0x50 [btrfs]
[<ffffffffa03577d8>] ? read_extent_buffer+0xd8/0x1d0 [btrfs]
[<ffffffffa031bea1>] ? btrfs_previous_item+0xb1/0x150 [btrfs]
[<ffffffffa035f5aa>] btrfs_balance+0x21a/0x2b0 [btrfs]
[<ffffffffa0368898>] btrfs_ioctl+0x798/0xd20 [btrfs]
[<ffffffff8111e358>] ? handle_mm_fault+0x148/0x270
[<ffffffff814809e8>] ? do_page_fault+0x1d8/0x4b0
[<ffffffff81160d6a>] do_vfs_ioctl+0x9a/0x540
[<ffffffff811612b1>] sys_ioctl+0xa1/0xb0
[<ffffffff81484ec2>] system_call_fastpath+0x16/0x1b
[SNIP]
RIP [<ffffffffa037c1cc>] btrfs_reloc_cow_block+0x22c/0x270 [btrfs]
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
A user reported an error where if we try to balance an fs after a device has
been removed it will blow up. This is because we get an EIO back and this is
where BUG_ON(ret) bites us in the ass. To fix we just exit. Thanks,
Reported-by: Anand Jain <Anand.Jain@oracle.com>
There are three missed mount options settable by user which are not
currently displayed in mount output.
Signed-off-by: David Sterba <dsterba@suse.cz>
btrfs: fix inconsonant inode information
Btrfs: make sure to update total_bitmaps when freeing cache V3
Btrfs: fix type mismatch in find_free_extent()
Btrfs: make sure to record the transid in new inodes
When iputting the inode, We may leave the delayed nodes if they have some
delayed items that have not been dealt with. So when the inode is read again,
we must look up the relative delayed node, and use the information in it to
initialize the inode. Or we will get inconsonant inode information, it may
cause that the same directory index number is allocated again, and hit the
following oops:
[ 5447.554187] err add delayed dir index item(name: pglog_0.965_0) into the
insertion tree of the delayed node(root id: 262, inode id: 258, errno: -17)
[ 5447.569766] ------------[ cut here ]------------
[ 5447.575361] kernel BUG at fs/btrfs/delayed-inode.c:1301!
[SNIP]
[ 5447.790721] Call Trace:
[ 5447.793191] [<ffffffffa0641c4e>] btrfs_insert_dir_item+0x189/0x1bb [btrfs]
[ 5447.800156] [<ffffffffa0651a45>] btrfs_add_link+0x12b/0x191 [btrfs]
[ 5447.806517] [<ffffffffa0651adc>] btrfs_add_nondir+0x31/0x58 [btrfs]
[ 5447.812876] [<ffffffffa0651d6a>] btrfs_create+0xf9/0x197 [btrfs]
[ 5447.818961] [<ffffffff8111f840>] vfs_create+0x72/0x92
[ 5447.824090] [<ffffffff8111fa8c>] do_last+0x22c/0x40b
[ 5447.829133] [<ffffffff8112076a>] path_openat+0xc0/0x2ef
[ 5447.834438] [<ffffffff810c58e2>] ? __perf_event_task_sched_out+0x24/0x44
[ 5447.841216] [<ffffffff8103ecdd>] ? perf_event_task_sched_out+0x59/0x67
[ 5447.847846] [<ffffffff81121a79>] do_filp_open+0x3d/0x87
[ 5447.853156] [<ffffffff811e126c>] ? strncpy_from_user+0x43/0x4d
[ 5447.859072] [<ffffffff8111f1f5>] ? getname_flags+0x2e/0x80
[ 5447.864636] [<ffffffff8111f179>] ? do_getname+0x14b/0x173
[ 5447.870112] [<ffffffff8111f1b7>] ? audit_getname+0x16/0x26
[ 5447.875682] [<ffffffff8112b1ab>] ? spin_lock+0xe/0x10
[ 5447.880882] [<ffffffff81112d39>] do_sys_open+0x69/0xae
[ 5447.886153] [<ffffffff81112db1>] sys_open+0x20/0x22
[ 5447.891114] [<ffffffff813b9aab>] system_call_fastpath+0x16/0x1b
Fix it by reusing the old delayed node.
Reported-by: Jim Schutt <jaschut@sandia.gov>
Tested-by: Jim Schutt <jaschut@sandia.gov>
A user reported this bug again where we have more bitmaps than we are supposed
to. This is because we failed to load the free space cache, but don't update
the ctl->total_bitmaps counter when we remove entries from the tree. This patch
fixes this problem and we should be good to go again. Thanks,
data parameter should be u64 because a full-sized chunk flags field is
passed instead of 0/1 for distinguishing data from metadata. All
underlying functions expect u64.
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
When we create a new inode, we aren't filling in the
field that records the transaction that last changed this
inode.
If we then go to fsync that inode, it will be skipped because the field
isn't filled in.
It was pointed out by 'make versioncheck' that some includes of
linux/version.h were not needed in fs/ (fs/btrfs/ctree.h and
fs/omfs/file.c).
This patch removes them.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Acked-by: Bob Copeland <me@bobcopeland.com>
Btrfs: avoid delayed metadata items during commits
btrfs: fix uninitialized return value
btrfs: fix wrong reservation when doing delayed inode operations
btrfs: Remove unused sysfs code
btrfs: fix dereference of ERR_PTR value
Btrfs: fix relocation races
Btrfs: set no_trans_join after trying to expand the transaction
Btrfs: protect the pending_snapshots list with trans_lock
Btrfs: fix path leakage on subvol deletion
Btrfs: drop the delalloc_bytes check in shrink_delalloc
Btrfs: check the return value from set_anon_super
Snapshot creation has two phases. One is the initial snapshot setup,
and the second is done during commit, while nobody is allowed to modify
the root we are snapshotting.
The delayed metadata insertion code can break that rule, it does a
delayed inode update on the inode of the parent of the snapshot,
and delayed directory item insertion.
This makes sure to run the pending delayed operations before we
record the snapshot root, which avoids corruptions.
When allocation fails in btrfs_read_fs_root_no_name, ret is not set
although it is returned, holding a garbage value.
Reviewed-by: Li Zefan <lizf@cn.fujitsu.com>
We have migrated the space for the delayed inode items from
trans_block_rsv to global_block_rsv, but we forgot to set trans->block_rsv to
global_block_rsv when we doing delayed inode operations, and the following Oops
happened:
[ 9792.654889] ------------[ cut here ]------------
[ 9792.654898] WARNING: at fs/btrfs/extent-tree.c:5681
btrfs_alloc_free_block+0xca/0x27c [btrfs]()
[ 9792.654899] Hardware name: To Be Filled By O.E.M.
[ 9792.654900] Modules linked in: btrfs zlib_deflate libcrc32c
ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 ip6table_filter ip6_tables
arc4 rt61pci rt2x00pci rt2x00lib snd_hda_codec_hdmi mac80211
snd_hda_codec_realtek cfg80211 snd_hda_intel edac_core snd_seq rfkill
pcspkr serio_raw snd_hda_codec eeprom_93cx6 edac_mce_amd sp5100_tco
i2c_piix4 k10temp snd_hwdep snd_seq_device snd_pcm floppy r8169 xhci_hcd
mii snd_timer snd soundcore snd_page_alloc ipv6 firewire_ohci pata_acpi
ata_generic firewire_core pata_via crc_itu_t radeon ttm drm_kms_helper
drm i2c_algo_bit i2c_core [last unloaded: scsi_wait_scan]
[ 9792.654919] Pid: 2762, comm: rm Tainted: G W 2.6.39+ #1
[ 9792.654920] Call Trace:
[ 9792.654922] [<ffffffff81053c4a>] warn_slowpath_common+0x83/0x9b
[ 9792.654925] [<ffffffff81053c7c>] warn_slowpath_null+0x1a/0x1c
[ 9792.654933] [<ffffffffa038e747>] btrfs_alloc_free_block+0xca/0x27c [btrfs]
[ 9792.654945] [<ffffffffa03b8562>] ? map_extent_buffer+0x6e/0xa8 [btrfs]
[ 9792.654953] [<ffffffffa038189b>] __btrfs_cow_block+0xfc/0x30c [btrfs]
[ 9792.654963] [<ffffffffa0396aa6>] ? btrfs_buffer_uptodate+0x47/0x58 [btrfs]
[ 9792.654970] [<ffffffffa0382e48>] ? read_block_for_search+0x94/0x368 [btrfs]
[ 9792.654978] [<ffffffffa0381ba9>] btrfs_cow_block+0xfe/0x146 [btrfs]
[ 9792.654986] [<ffffffffa03848b0>] btrfs_search_slot+0x14d/0x4b6 [btrfs]
[ 9792.654997] [<ffffffffa03b8562>] ? map_extent_buffer+0x6e/0xa8 [btrfs]
[ 9792.655022] [<ffffffffa03938e8>] btrfs_lookup_inode+0x2f/0x8f [btrfs]
[ 9792.655025] [<ffffffff8147afac>] ? _cond_resched+0xe/0x22
[ 9792.655027] [<ffffffff8147b892>] ? mutex_lock+0x29/0x50
[ 9792.655039] [<ffffffffa03d41b1>] btrfs_update_delayed_inode+0x72/0x137 [btrfs]
[ 9792.655051] [<ffffffffa03d4ea2>] btrfs_run_delayed_items+0x90/0xdb [btrfs]
[ 9792.655062] [<ffffffffa039a69b>] btrfs_commit_transaction+0x228/0x654 [btrfs]
[ 9792.655064] [<ffffffff8106e8da>] ? remove_wait_queue+0x3a/0x3a
[ 9792.655075] [<ffffffffa03a2fa5>] btrfs_evict_inode+0x14d/0x202 [btrfs]
[ 9792.655077] [<ffffffff81132bd6>] evict+0x71/0x111
[ 9792.655079] [<ffffffff81132de0>] iput+0x12a/0x132
[ 9792.655081] [<ffffffff8112aa3a>] do_unlinkat+0x106/0x155
[ 9792.655083] [<ffffffff81127b83>] ? path_put+0x1f/0x23
[ 9792.655085] [<ffffffff8109c53c>] ? audit_syscall_entry+0x145/0x171
[ 9792.655087] [<ffffffff81128410>] ? putname+0x34/0x36
[ 9792.655090] [<ffffffff8112b441>] sys_unlinkat+0x29/0x2b
[ 9792.655092] [<ffffffff81482c42>] system_call_fastpath+0x16/0x1b
[ 9792.655093] ---[ end trace 02b696eb02b3f768 ]---
This patch fix it by setting the reservation of the transaction handle to the
correct one.
Reported-by: Josef Bacik <josef@redhat.com>
Removes code no longer used. The sysfs file itself is kept, because the
btrfs developers expressed interest in putting new entries to sysfs.
Signed-off-by: Maarten Lankhorst <m.b.lankhorst@gmail.com>
smatch reports:
btrfs_recover_log_trees error: 'wc.replay_dest' dereferencing
possible ERR_PTR()
git://git.kernel.org/pub/scm/linux/kernel/git/josef/btrfs-work into for-linus
fs/btrfs/transaction.c
The recent commit to get rid of our trans_mutex introduced
some races with block group relocation. The problem is that relocation
needs to do some record keeping about each root, and it was relying
on the transaction mutex to coordinate things in subtle ways.
This fix adds a mutex just for the relocation code and makes sure
it doesn't have a big impact on normal operations. The race is
really fixed in btrfs_record_root_in_trans, which is where we
step back and wait for the relocation code to finish accounting
setup.
We can lockup if we try to allow new writers join the transaction and we have
flushoncommit set or have a pending snapshot. This is because we set
no_trans_join and then loop around and try to wait for ordered extents again.
The problem is the ordered endio stuff needs to join the transaction, which it
can't do because no_trans_join is set. So instead wait until after this loop to
set no_trans_join and then make sure to wait for num_writers == 1 in case
anybody got started in between us exiting the loop and setting no_trans_join.
This could easily be reproduced by mounting -o flushoncommit and running xfstest
13. It cannot be reproduced with this patch. Thanks,
Currently there is nothing protecting the pending_snapshots list on the
transaction. We only hold the directory mutex that we are snapshotting and a
read lock on the subvol_sem, so we could race with somebody else creating a
snapshot in a different directory and end up with list corruption. So protect
this list with the trans_lock. Thanks,
The delayed ref patch accidently removed the btrfs_free_path in
btrfs_unlink_subvol, this puts it back and means we don't leak a path. Thanks,
Even when delalloc_bytes is zero, we may need to sleep while waiting
for delalloc space.
Al Viro noticed we weren't checking for set_anon_super failures. This
adds the required checks.
Btrfs: use join_transaction in btrfs_evict_inode()
Btrfs - use %pU to print fsid
Btrfs: fix extent state leak on failed nodatasum reads
btrfs: fix unlocked access of delalloc_inodes
Btrfs: avoid stack bloat in btrfs_ioctl_fs_info()
btrfs: remove 64bit alignment padding to allow extent_buffer to fit into one fewer cacheline
Btrfs: clear current->journal_info on async transaction commit
Btrfs: make sure to recheck for bitmaps in clusters
btrfs: remove unneeded includes from scrub.c
btrfs: reinitialize scrub workers
btrfs: scrub: errors in tree enumeration
Btrfs: don't map extent buffer if path->skip_locking is set
Btrfs: unlock the trans lock properly
Btrfs: fix duplicate checking logic
Btrfs: fix the allocator loop logic
Btrfs: fix bitmap regression
Btrfs: don't commit the transaction if we dont have enough pinned bytes
Btrfs: noinline the cluster searching functions
Btrfs: cache bitmaps when searching for a cluster
The WARN_ON() in start_transaction() was triggered while balancing.
The cause is btrfs_relocate_chunk() started a transaction and
then called iput() on the inode that stores free space cache,
and iput() called btrfs_start_transaction() again.
Reported-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com>
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Reviewed-by: Josef Bacik <josef@redhat.com>
Get rid of FIXME comment. Uuids from dmesg are now the same as uuids
given by btrfs-progs.
When encountering an EIO while reading from a nodatasum extent, we
insert an error record into the inode's failure tree.
btrfs_readpage_end_io_hook returns early for nodatasum inodes. We'd
better clear the failure tree in that case, otherwise the kernel
complains about
BUG extent_state: Objects remaining on kmem_cache_close()
on rmmod.
Signed-off-by: Jan Schmidt <list.btrfs@jan-o-sch.net>
git://git.kernel.org/pub/scm/linux/kernel/git/arne/btrfs-unstable-arne into for-linus
list_splice_init will make delalloc_inodes empty, but without a spinlock
around, this may produce corrupted list head, accessed in many placess,
The race window is very tight and nobody seems to have hit it so far.
The size of struct btrfs_ioctl_fs_info_args is as big as 1KB, so
don't declare the variable on stack.
fewer cacheline
Reorder extent_buffer to remove 8 bytes of alignment padding on 64 bit
builds. This shrinks its size to 128 bytes allowing it to fit into one
fewer cache lines and allows more objects per slab in its kmem_cache.
slabinfo extent_buffer reports :-
before:-
Sizes (bytes) Slabs
Object : 136 Total : 123
SlabObj: 136 Full : 121
SlabSiz: 4096 Partial: 0
Loss : 0 CpuSlab: 2
Align : 8 Objects: 30
after :-
Object : 128 Total : 4
SlabObj: 128 Full : 2
Loss : 0 CpuSlab: 2
Align : 8 Objects: 32
Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk>
Normally current->jouranl_info is cleared by commit_transaction. For an
async snap or subvol creation, though, it runs in a work queue. Clear
it in btrfs_commit_transaction_async() to avoid leaking a non-NULL
journal_info when we return to userspace. When the actual commit runs in
the other thread it won't care that it's current->journal_info is already
NULL.
Signed-off-by: Sage Weil <sage@newdream.net>
Josef recently changed the free extent cache to look in
the block group cluster for any bitmaps before trying to
add a new bitmap for the same offset. This avoids BUG_ON()s due
covering duplicate ranges.
But it didn't go quite far enough. A given free range might span
between one or more bitmaps or free space entries. The code has
looping to cover this, but it doesn't check for clustered bitmaps
every time.
This shuffles our gotos to check for a bitmap in the cluster
for every new bitmap entry we try to add.
Signed-off-by: Arne Jansen <sensille@gmx.net>
Scrub starts the workers each time a scrub starts and stops them after it
finished. This patch adds an initialization for the workers before each
start, otherwise the workers behave strangely.
due to the semantics of btrfs_search_slot the path can point to an
invalid slot when ret > 0. This condition went unnoticed, which in
turn could have led to an incomplete scrubbing.
Arne's scrub stuff exposed a problem with mapping the extent buffer in
reada_for_search. He searches the commit root with multiple threads and with
skip_locking set, so we can race and overwrite node->map_token since node isn't
locked. So fix this so that we only map the extent buffer if we don't already
have a map_token and skip_locking isn't set. Without this patch scrub would
panic almost immediately, with the patch it doesn't panic anymore. Thanks,
Reported-by: Arne Jansen <sensille@gmx.net>
In btrfs_wait_for_commit if we came upon a transaction that had committed we
just exited, but that's bad since we are holding the trans_lock. So break
instead so that the lock is dropped. Thanks,
Reported-by: David Sterba <dsterba@suse.cz>
When merging my code into the integration test the second check for duplicate
entries got screwed up. This patch fixes it by dropping ret2 and just using ret
for the return value, and checking if we got an error before adding the bitmap
to the local list. Thanks,
I was testing with empty_cluster = 0 to try and reproduce a problem and kept
hitting early enospc panics. This was because our loop logic was a little
confused. So this is what I did
1) Make the loop variable the ultimate decider on wether we should loop again
isntead of checking to see if we had an uncached bg, empty size or empty
cluster.
2) Increment loop before checking to see what we are on to make the loop
definitions make more sense.
3) If we are on the chunk alloc loop don't set empty_size/empty_cluster to 0
unless we didn't actually allocate a chunk. If we did allocate a chunk we
should be able to easily setup a new cluster so clearing
empty_size/empty_cluster makes us less efficient.
This kept me from hitting panics while trying to reproduce the other problem.
Thanks,
In cleaning up the clustering code I accidently introduced a regression by
adding bitmap entries to the cluster rb tree. The problem is if we've maxed out
the number of bitmaps we can have for the block group we can only add free space
to the bitmaps, but since the bitmap is on the cluster we can't find it and we
try to create another one. This would result in a panic because the total
bitmaps was bigger than the max bitmaps that were allowed. This patch fixes
this by checking to see if we have a cluster, and then looking at the cluster rb
tree to see if it has a bitmap entry and if it does and that space belongs to
that bitmap, go ahead and add it to that bitmap.
I could hit this panic every time with an fs_mark test within a couple of
minutes. With this patch I no longer hit the panic and fs_mark goes to
completion. Thanks,
I noticed when running an enospc test that we would get stuck committing the
transaction in check_data_space even though we truly didn't have enough space.
So check to see if bytes_pinned is bigger than num_bytes, if it's not don't
commit the transaction. Thanks,
When profiling the find cluster code it's hard to tell where we are spending our
time because the bitmap and non-bitmap functions get inlined by the compiler, so
make that not happen. Thanks,
If we are looking for a cluster in a particularly sparse or fragmented block
group, we will do a lot of looping through the free space tree looking for
various things, and if we need to look at bitmaps we will endup doing the whole
dance twice. So instead add the bitmap entries to a temporary list so if we
have to do the bitmap search we can just look through the list of entries we've
found quickly instead of having to loop through the entire tree again. Thanks,
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
vfs: make unlink() and rmdir() return ENOENT in preference to EROFS
lmLogOpen() broken failure exit
usb: remove bad dput after dentry_unhash
more conservative S_NOSEC handling
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (25 commits)
btrfs: fix uninitialized variable warning
btrfs: add helper for fs_info->closing
Btrfs: add mount -o inode_cache
btrfs: scrub: add explicit plugging
btrfs: use btrfs_ino to access inode number
Btrfs: don't save the inode cache if we are deleting this root
btrfs: false BUG_ON when degraded
Btrfs: don't save the inode cache in non-FS roots
Btrfs: make sure we don't overflow the free space cache crc page
Btrfs: fix uninit variable in the delayed inode code
btrfs: scrub: don't reuse bios and pages
Btrfs: leave spinning on lookup and map the leaf
Btrfs: check for duplicate entries in the free space cache
Btrfs: don't try to allocate from a block group that doesn't have enough space
Btrfs: don't always do readahead
Btrfs: try not to sleep as much when doing slow caching
Btrfs: kill BTRFS_I(inode)->block_group
Btrfs: don't look at the extent buffer level 3 times in a row
Btrfs: map the node block when looking for readahead targets
Btrfs: set range_start to the right start in count_range_bits
