commit f2d5a94436cc7cc0221b9a81bba2276a25187dd3 upstream.
On 32-bit architectures, the legacy buffer_head functions are not always
handling the sector number with the proper 64-bit types, and will thus
fail on 4TB+ disks.
Any code that uses __getblk() (and thus bread(), breadahead(),
sb_bread(), sb_breadahead(), sb_getblk()), and calls it using a 64-bit
block on a 32-bit arch (where "long" is 32-bit) causes an inifinite loop
in __getblk_slow() with an infinite stream of errors logged to dmesg
like this:
__find_get_block_slow() failed. block=6740375944, b_blocknr=2445408648
b_state=0x00000020, b_size=512
device sda1 blocksize: 512
Note how in hex block is 0x191C1F988 and b_blocknr is 0x91C1F988 i.e. the
top 32-bits are missing (in this case the 0x1 at the top).
This is because grow_dev_page() is broken and has a 32-bit overflow due
to shifting the page index value (a pgoff_t - which is just 32 bits on
32-bit architectures) left-shifted as the block number. But the top
bits to get lost as the pgoff_t is not type cast to sector_t / 64-bit
before the shift.
This patch fixes this issue by type casting "index" to sector_t before
doing the left shift.
Note this is not a theoretical bug but has been seen in the field on a
4TiB hard drive with logical sector size 512 bytes.
This patch has been verified to fix the infinite loop problem on 3.17-rc5
kernel using a 4TB disk image mounted using "-o loop". Without this patch
doing a "find /nt" where /nt is an NTFS volume causes the inifinite loop
100% reproducibly whilst with the patch it works fine as expected.
Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
commit 227d53b397a32a7614667b3ecaf1d89902fb6c12 upstream.
To use spin_{un}lock_irq is dangerous if caller disabled interrupt.
During aio buffer migration, we have a possibility to see the following
call stack.
aio_migratepage [disable interrupt]
migrate_page_copy
clear_page_dirty_for_io
set_page_dirty
__set_page_dirty_buffers
__set_page_dirty
spin_lock_irq
This mean, current aio migration is a deadlockable. spin_lock_irqsave
is a safer alternative and we should use it.
Reported-by: David Rientjes rientjes@google.com>
Pull block core updates from Jens Axboe:
- Major bit is Kents prep work for immutable bio vecs.
- Stable candidate fix for a scheduling-while-atomic in the queue
bypass operation.
- Fix for the hang on exceeded rq->datalen 32-bit unsigned when merging
discard bios.
- Tejuns changes to convert the writeback thread pool to the generic
workqueue mechanism.
- Runtime PM framework, SCSI patches exists on top of these in James'
tree.
- A few random fixes.
* 'for-3.10/core' of git://git.kernel.dk/linux-block: (40 commits)
relay: move remove_buf_file inside relay_close_buf
partitions/efi.c: replace useless kzalloc's by kmalloc's
fs/block_dev.c: fix iov_shorten() criteria in blkdev_aio_read()
block: fix max discard sectors limit
blkcg: fix "scheduling while atomic" in blk_queue_bypass_start
Documentation: cfq-iosched: update documentation help for cfq tunables
writeback: expose the bdi_wq workqueue
writeback: replace custom worker pool implementation with unbound workqueue
writeback: remove unused bdi_pending_list
aoe: Fix unitialized var usage
bio-integrity: Add explicit field for owner of bip_buf
block: Add an explicit bio flag for bios that own their bvec
block: Add bio_alloc_pages()
block: Convert some code to bio_for_each_segment_all()
block: Add bio_for_each_segment_all()
bounce: Refactor __blk_queue_bounce to not use bi_io_vec
raid1: use bio_copy_data()
pktcdvd: Use bio_reset() in disabled code to kill bi_idx usage
pktcdvd: use bio_copy_data()
block: Add bio_copy_data()
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"Mostly performance and bug fixes, plus some cleanups. The one new
feature this merge window is a new ioctl EXT4_IOC_SWAP_BOOT which
allows installation of a hidden inode designed for boot loaders."
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (50 commits)
ext4: fix type-widening bug in inode table readahead code
ext4: add check for inodes_count overflow in new resize ioctl
ext4: fix Kconfig documentation for CONFIG_EXT4_DEBUG
ext4: fix online resizing for ext3-compat file systems
jbd2: trace when lock_buffer in do_get_write_access takes a long time
ext4: mark metadata blocks using bh flags
buffer: add BH_Prio and BH_Meta flags
ext4: mark all metadata I/O with REQ_META
ext4: fix readdir error in case inline_data+^dir_index.
ext4: fix readdir error in the case of inline_data+dir_index
jbd2: use kmem_cache_zalloc instead of kmem_cache_alloc/memset
ext4: mext_insert_extents should update extent block checksum
ext4: move quota initialization out of inode allocation transaction
ext4: reserve xattr index for Rich ACL support
jbd2: reduce journal_head size
ext4: clear buffer_uninit flag when submitting IO
ext4: use io_end for multiple bios
ext4: make ext4_bio_write_page() use BH_Async_Write flags
ext4: Use kstrtoul() instead of parse_strtoul()
ext4: defragmentation code cleanup
bh allocation uses kmem_cache_zalloc() so we needn't call
'init_buffer(bh, NULL, NULL)' and perform other set-zero-operations.
Signed-off-by: Jianpeng Ma <majianpeng@gmail.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Walking a bio's page mappings has proved problematic, so create a new
bio flag to indicate that a bio's data needs to be snapshotted in order
to guarantee stable pages during writeback. Next, for the one user
(ext3/jbd) of snapshotting, hook all the places where writes can be
initiated without PG_writeback set, and set BIO_SNAP_STABLE there.
We must also flag journal "metadata" bios for stable writeout, since
file data can be written through the journal. Finally, the
MS_SNAP_STABLE mount flag (only used by ext3) is now superfluous, so get
rid of it.
[akpm@linux-foundation.org: rename _submit_bh()'s `flags' to `bio_flags', delobotomize the _submit_bh declaration]
[akpm@linux-foundation.org: teeny cleanup]
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Add buffer_head flags so that buffer cache writebacks can be marked
with the the appropriate request flags, so that metadata blocks can be
marked appropriately in blktrace.
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
For immutable bvecs, all bi_idx usage needs to be audited - so here
we're removing all the unnecessary uses.
Most of these are places where it was being initialized on a bio that
was just allocated, a few others are conversions to standard macros.
Signed-off-by: Kent Overstreet <koverstreet@google.com>
CC: Jens Axboe <axboe@kernel.dk>
Pull block IO core bits from Jens Axboe:
"Below are the core block IO bits for 3.9. It was delayed a few days
since my workstation kept crashing every 2-8h after pulling it into
current -git, but turns out it is a bug in the new pstate code (divide
by zero, will report separately). In any case, it contains:
- The big cfq/blkcg update from Tejun and and Vivek.
- Additional block and writeback tracepoints from Tejun.
- Improvement of the should sort (based on queues) logic in the plug
flushing.
- _io() variants of the wait_for_completion() interface, using
io_schedule() instead of schedule() to contribute to io wait
properly.
- Various little fixes.
You'll get two trivial merge conflicts, which should be easy enough to
fix up"
Fix up the trivial conflicts due to hlist traversal cleanups (commit
b67bfe0d42ca: "hlist: drop the node parameter from iterators").
* 'for-3.9/core' of git://git.kernel.dk/linux-block: (39 commits)
block: remove redundant check to bd_openers()
block: use i_size_write() in bd_set_size()
cfq: fix lock imbalance with failed allocations
drivers/block/swim3.c: fix null pointer dereference
block: don't select PERCPU_RWSEM
block: account iowait time when waiting for completion of IO request
sched: add wait_for_completion_io[_timeout]
writeback: add more tracepoints
block: add block_{touch|dirty}_buffer tracepoint
buffer: make touch_buffer() an exported function
block: add @req to bio_{front|back}_merge tracepoints
block: add missing block_bio_complete() tracepoint
block: Remove should_sort judgement when flush blk_plug
block,elevator: use new hashtable implementation
cfq-iosched: add hierarchical cfq_group statistics
cfq-iosched: collect stats from dead cfqgs
cfq-iosched: separate out cfqg_stats_reset() from cfq_pd_reset_stats()
blkcg: make blkcg_print_blkgs() grab q locks instead of blkcg lock
block: RCU free request_queue
blkcg: implement blkg_[rw]stat_recursive_sum() and blkg_[rw]stat_merge()
Pull vfs pile (part one) from Al Viro:
"Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent
locking violations, etc.
The most visible changes here are death of FS_REVAL_DOT (replaced with
"has ->d_weak_revalidate()") and a new helper getting from struct file
to inode. Some bits of preparation to xattr method interface changes.
Misc patches by various people sent this cycle *and* ocfs2 fixes from
several cycles ago that should've been upstream right then.
PS: the next vfs pile will be xattr stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
saner proc_get_inode() calling conventions
proc: avoid extra pde_put() in proc_fill_super()
fs: change return values from -EACCES to -EPERM
fs/exec.c: make bprm_mm_init() static
ocfs2/dlm: use GFP_ATOMIC inside a spin_lock
ocfs2: fix possible use-after-free with AIO
ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path
get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero
target: writev() on single-element vector is pointless
export kernel_write(), convert open-coded instances
fs: encode_fh: return FILEID_INVALID if invalid fid_type
kill f_vfsmnt
vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op
nfsd: handle vfs_getattr errors in acl protocol
switch vfs_getattr() to struct path
default SET_PERSONALITY() in linux/elf.h
ceph: prepopulate inodes only when request is aborted
d_hash_and_lookup(): export, switch open-coded instances
9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate()
9p: split dropping the acls from v9fs_set_create_acl()
max_buffer_heads is calculated from nr_free_buffer_pages(), so change
its type to unsigned long in case of overflow.
Signed-off-by: Zhang Yanfei <zhangyanfei@cn.fujitsu.com>
Create a helper function to check if a backing device requires stable
page writes and, if so, performs the necessary wait. Then, make it so
that all points in the memory manager that handle making pages writable
use the helper function. This should provide stable page write support
to most filesystems, while eliminating unnecessary waiting for devices
that don't require the feature.
Before this patchset, all filesystems would block, regardless of whether
or not it was necessary. ext3 would wait, but still generate occasional
checksum errors. The network filesystems were left to do their own
thing, so they'd wait too.
After this patchset, all the disk filesystems except ext3 and btrfs will
wait only if the hardware requires it. ext3 (if necessary) snapshots
pages instead of blocking, and btrfs provides its own bdi so the mm will
never wait. Network filesystems haven't been touched, so either they
provide their own stable page guarantees or they don't block at all.
The blocking behavior is back to what it was before 3.0 if you don't
have a disk requiring stable page writes.
Here's the result of using dbench to test latency on ext2:
3.8.0-rc3:
Operation Count AvgLat MaxLat
WriteX 109347 0.028 59.817
ReadX 347180 0.004 3.391
Flush 15514 29.828 287.283
Throughput 57.429 MB/sec 4 clients 4 procs max_latency=287.290 ms
3.8.0-rc3 + patches:
WriteX 105556 0.029 4.273
ReadX 335004 0.005 4.112
Flush 14982 30.540 298.634
Throughput 55.4496 MB/sec 4 clients 4 procs max_latency=298.650 ms
As you can see, the maximum write latency drops considerably with this
patch enabled. The other filesystems (ext3/ext4/xfs/btrfs) behave
similarly, but see the cover letter for those results.
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Eric Van Hensbergen <ericvh@gmail.com>
Cc: Ron Minnich <rminnich@sandia.gov>
Cc: Latchesar Ionkov <lucho@ionkov.net>
Andrew Morton pointed this out a month ago, and then I completely forgot
about it.
If we read a partial last page of a block device, we will zero out the
end of the page, but since that page can then be mapped into user space,
we should also make sure to flush the cache on architectures that have
virtual caches. We have the flush_dcache_page() function for this, so
use it.
Now, in practice this really never matters, because nobody sane uses
virtual caches to begin with, and they largely exist on old broken RISC
arhitectures.
And even if you did run on one of those obsolete CPU's, the whole "mmap
and access the last partial page of a block device" behavior probably
doesn't actually exist. The normal IO functions (read/write) will never
see the zeroed-out part of the page that migth not be coherent in the
cache, because they honor the size of the device.
So I'm marking this for stable (3.7 only), but I'm not sure anybody will
ever care.
Pointed-out-by: Andrew Morton <akpm@linux-foundation.org>
Cc: stable@vger.kernel.org # 3.7
The former is triggered from touch_buffer() and the latter
mark_buffer_dirty().
This is part of tracepoint additions to improve visiblity into
dirtying / writeback operations for io tracer and userland.
v2: Transformed writeback_dirty_buffer to block_dirty_buffer and made
it share TP definition with block_touch_buffer.
Cc: Fengguang Wu <fengguang.wu@intel.com>
We want to add a trace point to touch_buffer() but macros and inline
functions defined in header files can't have tracing points. Move
touch_buffer() to fs/buffer.c and make it a proper function.
The new exported function is also declared inline. As most uses of
touch_buffer() are inside buffer.c with nilfs2 as the only other user,
the effect of this change should be negligible.
buffer_head comes from kmem_cache_zalloc(), no need to zero its fields.
Signed-off-by: Yan Hong <clouds.yan@gmail.com>
It makes no sense to inline an exported function.
Overhaul struct address_space.assoc_mapping renaming it to
address_space.private_data and its type is redefined to void*. By this
approach we consistently name the .private_* elements from struct
address_space as well as allow extended usage for address_space
association with other data structures through ->private_data.
Also, all users of old ->assoc_mapping element are converted to reflect
its new name and type change (->private_data).
Signed-off-by: Rafael Aquini <aquini@redhat.com>
Cc: "Michael S. Tsirkin" <mst@redhat.com>
Cc: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Minchan Kim <minchan@kernel.org>
READ is zero so the "rw & READ" test is always false. The intended test
was "((rw & RW_MASK) == READ)".
The block device access simplification that avoided accessing the (racy)
block size information (commit bbec0270bdd8: "blkdev_max_block: make
private to fs/buffer.c") no longer checks the maximum block size in the
block mapping path.
That was _almost_ as simple as just removing the code entirely, because
the readers and writers all check the size of the device anyway, so
under normal circumstances it "just worked".
However, the block size may be such that the end of the device may
straddle one single buffer_head. At which point we may still want to
access the end of the device, but the buffer we use to access it
partially extends past the end.
The 'bd_set_size()' function intentionally sets the block size to avoid
this, but mounting the device - or setting the block size by hand to
some other value - can modify that block size.
So instead, teach 'submit_bh()' about the special case of the buffer
head straddling the end of the device, and turning such an access into a
smaller IO access, avoiding the problem.
This, btw, also means that unlike before, we can now access the whole
device regardless of device block size setting. So now, even if the
device size is only 512-byte aligned, we can read and write even the
last sector even when having a much bigger block size for accessing the
rest of the device.
So with this, we could now get rid of the 'bd_set_size()' block size
code entirely - resulting in faster IO for the common case - but that
would be a separate patch.
Reported-and-tested-by: Romain Francoise <romain@orebokech.com>
Reporeted-and-tested-by: Meelis Roos <mroos@linux.ee>
Reported-by: Tony Luck <tony.luck@intel.com>
We really don't want to look at the block size for the raw block device
accesses in fs/block-dev.c, because it may be changing from under us.
So get rid of the max_block logic entirely, since the caller should
already have done it anyway.
That leaves the only user of this function in fs/buffer.c, so move the
whole function there and make it static.
This makes the buffer size handling be a per-page thing, which allows us
to not have to worry about locking too much when changing the buffer
size. If a page doesn't have buffers, we still need to read the block
size from the inode, but we can do that with ACCESS_ONCE(), so that even
if the size is changing, we get a consistent value.
This doesn't convert all functions - many of the buffer functions are
used purely by filesystems, which in turn results in the buffer size
being fixed at mount-time. So they don't have the same consistency
issues that the raw device access can have.
"The big new feature added this time is supporting online resizing
using the meta_bg feature. This allows us to resize file systems
which are greater than 16TB. In addition, the speed of online
resizing has been improved in general.
We also fix a number of races, some of which could lead to deadlocks,
in ext4's Asynchronous I/O and online defrag support, thanks to good
work by Dmitry Monakhov.
There are also a large number of more minor bug fixes and cleanups
from a number of other ext4 contributors, quite of few of which have
submitted fixes for the first time."
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (69 commits)
ext4: fix ext4_flush_completed_IO wait semantics
ext4: fix mtime update in nodelalloc mode
ext4: fix ext_remove_space for punch_hole case
ext4: punch_hole should wait for DIO writers
ext4: serialize truncate with owerwrite DIO workers
ext4: endless truncate due to nonlocked dio readers
ext4: serialize unlocked dio reads with truncate
ext4: serialize dio nonlocked reads with defrag workers
ext4: completed_io locking cleanup
ext4: fix unwritten counter leakage
ext4: give i_aiodio_unwritten a more appropriate name
ext4: ext4_inode_info diet
ext4: convert to use leXX_add_cpu()
ext4: ext4_bread usage audit
fs: reserve fallocate flag codepoint
ext4: remove redundant offset check in mext_check_arguments()
ext4: don't clear orphan list on ro mount with errors
jbd2: fix assertion failure in commit code due to lacking transaction credits
ext4: release donor reference when EXT4_IOC_MOVE_EXT ioctl fails
ext4: enable FITRIM ioctl on bigalloc file system
Commits 5e8830dc85d0 and 41c4d25f78c0 introduced a regression into
v3.6-rc1 for ext4 in nodealloc mode, such that mtime updates would not
take place for files modified via mmap if the page was already in the
page cache. This would also affect ext3 file systems mounted using
the ext4 file system driver.
The problem was that ext4_page_mkwrite() had a shortcut which would
avoid calling __block_page_mkwrite() under some circumstances, and the
above two commit transferred the responsibility of calling
file_update_time() to __block_page_mkwrite --- which woudln't get
called in some circumstances.
Since __block_page_mkwrite() only has three callers,
block_page_mkwrite(), ext4_page_mkwrite, and nilfs_page_mkwrite(), the
best way to solve this is to move the responsibility for calling
file_update_time() to its caller.
This problem was found via xfstests #215 with a file system mounted
with -o nodelalloc.
Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp>
Commit 91f68c89d8f3 ("block: fix infinite loop in __getblk_slow")
is not good: a successful call to grow_buffers() cannot guarantee
that the page won't be reclaimed before the immediate next call to
__find_get_block(), which is why there was always a loop there.
Yesterday I got "EXT4-fs error (device loop0): __ext4_get_inode_loc:3595:
inode #19278: block 664: comm cc1: unable to read itable block" on console,
which pointed to this commit.
I've been trying to bisect for weeks, why kbuild-on-ext4-on-loop-on-tmpfs
sometimes fails from a missing header file, under memory pressure on
ppc G5. I've never seen this on x86, and I've never seen it on 3.5-rc7
itself, despite that commit being in there: bisection pointed to an
irrelevant pinctrl merge, but hard to tell when failure takes between
18 minutes and 38 hours (but so far it's happened quicker on 3.6-rc2).
(I've since found such __ext4_get_inode_loc errors in /var/log/messages
from previous weeks: why the message never appeared on console until
yesterday morning is a mystery for another day.)
Revert 91f68c89d8f3, restoring __getblk_slow() to how it was (plus
a checkpatch nitfix). Simplify the interface between grow_buffers()
and grow_dev_page(), and avoid the infinite loop beyond end of device
by instead checking init_page_buffers()'s end_block there (I presume
that's more efficient than a repeated call to blkdev_max_block()),
returning -ENXIO to __getblk_slow() in that case.
And remove akpm's ten-year-old "__getblk() cannot fail ... weird"
comment, but that is worrying: are all users of __getblk() really
now prepared for a NULL bh beyond end of device, or will some oops??
Cc: stable@vger.kernel.org # 3.0 3.2 3.4 3.5
There are several entry points which dirty pages in a filesystem. mmap
(handled by block_page_mkwrite()), buffered write (handled by
__generic_file_aio_write()), splice write (generic_file_splice_write),
truncate, and fallocate (these can dirty last partial page - handled inside
each filesystem separately). Protect these places with sb_start_write() and
sb_end_write().
->page_mkwrite() calls are particularly complex since they are called with
mmap_sem held and thus we cannot use standard sb_start_write() due to lock
ordering constraints. We solve the problem by using a special freeze protection
sb_start_pagefault() which ranks below mmap_sem.
BugLink: https://bugs.launchpad.net/bugs/897421
Tested-by: Kamal Mostafa <kamal@canonical.com>
Tested-by: Peter M. Petrakis <peter.petrakis@canonical.com>
Tested-by: Dann Frazier <dann.frazier@canonical.com>
Tested-by: Massimo Morana <massimo.morana@canonical.com>
Commit 080399aaaf35 ("block: don't mark buffers beyond end of disk as
mapped") exposed a bug in __getblk_slow that causes mount to hang as it
loops infinitely waiting for a buffer that lies beyond the end of the
disk to become uptodate.
The problem was initially reported by Torsten Hilbrich here:
https://lkml.org/lkml/2012/6/18/54
and also reported independently here:
http://www.sysresccd.org/forums/viewtopic.php?f=13&t=4511
and then Richard W.M. Jones and Marcos Mello noted a few separate
bugzillas also associated with the same issue. This patch has been
confirmed to fix:
https://bugzilla.redhat.com/show_bug.cgi?id=835019
The main problem is here, in __getblk_slow:
for (;;) {
struct buffer_head * bh;
int ret;
bh = __find_get_block(bdev, block, size);
if (bh)
return bh;
ret = grow_buffers(bdev, block, size);
if (ret < 0)
return NULL;
if (ret == 0)
free_more_memory();
__find_get_block does not find the block, since it will not be marked as
mapped, and so grow_buffers is called to fill in the buffers for the
associated page. I believe the for (;;) loop is there primarily to
retry in the case of memory pressure keeping grow_buffers from
succeeding. However, we also continue to loop for other cases, like the
block lying beond the end of the disk. So, the fix I came up with is to
only loop when grow_buffers fails due to memory allocation issues
(return value of 0).
The attached patch was tested by myself, Torsten, and Rich, and was
found to resolve the problem in call cases.
Signed-off-by: Jeff Moyer <jmoyer@redhat.com>
Reported-and-Tested-by: Torsten Hilbrich <torsten.hilbrich@secunet.com>
Tested-by: Richard W.M. Jones <rjones@redhat.com>
Reviewed-by: Josh Boyer <jwboyer@redhat.com>
Cc: Stable <stable@vger.kernel.org> # 3.0+
[ Jens is on vacation, taking this directly - Linus ]
Stable Notes: this patch requires backport to 3.0, 3.2 and 3.3.
bh_cachep is only written to once on initialization, so move it to the
__read_mostly section.
Signed-off-by: Shai Fultheim <shai@scalemp.com>
Signed-off-by: Vlad Zolotarov <vlad@scalemp.com>
We have a bug report open where a squashfs image mounted on ppc64 would
exhibit errors due to trying to read beyond the end of the disk. It can
easily be reproduced by doing the following:
[root@ibm-p750e-02-lp3 ~]# ls -l install.img
-rw-r--r-- 1 root root 142032896 Apr 30 16:46 install.img
[root@ibm-p750e-02-lp3 ~]# mount -o loop ./install.img /mnt/test
[root@ibm-p750e-02-lp3 ~]# dd if=/dev/loop0 of=/dev/null
dd: reading `/dev/loop0': Input/output error
277376+0 records in
277376+0 records out
142016512 bytes (142 MB) copied, 0.9465 s, 150 MB/s
In dmesg, you'll find the following:
squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 43.106012] attempt to access beyond end of device
[ 43.106029] loop0: rw=0, want=277410, limit=277408
[ 43.106039] Buffer I/O error on device loop0, logical block 138704
[ 43.106053] attempt to access beyond end of device
[ 43.106057] loop0: rw=0, want=277412, limit=277408
[ 43.106061] Buffer I/O error on device loop0, logical block 138705
[ 43.106066] attempt to access beyond end of device
[ 43.106070] loop0: rw=0, want=277414, limit=277408
[ 43.106073] Buffer I/O error on device loop0, logical block 138706
[ 43.106078] attempt to access beyond end of device
[ 43.106081] loop0: rw=0, want=277416, limit=277408
[ 43.106085] Buffer I/O error on device loop0, logical block 138707
[ 43.106089] attempt to access beyond end of device
[ 43.106093] loop0: rw=0, want=277418, limit=277408
[ 43.106096] Buffer I/O error on device loop0, logical block 138708
[ 43.106101] attempt to access beyond end of device
[ 43.106104] loop0: rw=0, want=277420, limit=277408
[ 43.106108] Buffer I/O error on device loop0, logical block 138709
[ 43.106112] attempt to access beyond end of device
[ 43.106116] loop0: rw=0, want=277422, limit=277408
[ 43.106120] Buffer I/O error on device loop0, logical block 138710
[ 43.106124] attempt to access beyond end of device
[ 43.106128] loop0: rw=0, want=277424, limit=277408
[ 43.106131] Buffer I/O error on device loop0, logical block 138711
[ 43.106135] attempt to access beyond end of device
[ 43.106139] loop0: rw=0, want=277426, limit=277408
[ 43.106143] Buffer I/O error on device loop0, logical block 138712
[ 43.106147] attempt to access beyond end of device
[ 43.106151] loop0: rw=0, want=277428, limit=277408
[ 43.106154] Buffer I/O error on device loop0, logical block 138713
[ 43.106158] attempt to access beyond end of device
[ 43.106162] loop0: rw=0, want=277430, limit=277408
[ 43.106166] attempt to access beyond end of device
[ 43.106169] loop0: rw=0, want=277432, limit=277408
[ 43.106307] attempt to access beyond end of device
[ 43.106311] loop0: rw=0, want=277470, limit=2774
Squashfs manages to read in the end block(s) of the disk during the
mount operation. Then, when dd reads the block device, it leads to
block_read_full_page being called with buffers that are beyond end of
disk, but are marked as mapped. Thus, it would end up submitting read
I/O against them, resulting in the errors mentioned above. I fixed the
problem by modifying init_page_buffers to only set the buffer mapped if
it fell inside of i_size.
Cheers,
Jeff
Acked-by: Nick Piggin <npiggin@kernel.dk>
Changes from v1->v2: re-used max_block, as suggested by Nick Piggin.
While stressing the kernel with with failing allocations today, I hit the
following chain of events:
alloc_page_buffers():
bh = alloc_buffer_head(GFP_NOFS);
if (!bh)
goto no_grow; <= path taken
grow_dev_page():
bh = alloc_page_buffers(page, size, 0);
if (!bh)
goto failed; <= taken, consequence of the above
and then the failed path BUG()s the kernel.
The failure is inserted a litte bit artificially, but even then, I see no
reason why it should be deemed impossible in a real box.
Even though this is not a condition that we expect to see around every
time, failed allocations are expected to be handled, and BUG() sounds just
too much. As a matter of fact, grow_dev_page() can return NULL just fine
in other circumstances, so I propose we just remove it, then.
Signed-off-by: Glauber Costa <glommer@parallels.com>
In several code paths, such as when unmounting a file system (but not
only) we send an IPI to ask each cpu to invalidate its local LRU BHs.
For multi-cores systems that have many cpus that may not have any LRU BH
because they are idle or because they have not performed any file system
accesses since last invalidation (e.g. CPU crunching on high perfomance
computing nodes that write results to shared memory or only using
filesystems that do not use the bh layer.) This can lead to loss of
performance each time someone switches the KVM (the virtual keyboard and
screen type, not the hypervisor) if it has a USB storage stuck in.
This patch attempts to only send an IPI to cpus that have LRU BH.
Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com>
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map
them onto including export.h -- or if the file isn't even
using those, then just delete the include. Fix up any implicit
include dependencies that were being masked by module.h along
the way.
Move invalidate_bdev, block_sync_page into fs/block_dev.c. Export
kill_bdev as well, so brd doesn't have to open code it. Reduce
buffer_head.h requirement accordingly.
Removed a rather large comment from invalidate_bdev, as it looked a bit
obsolete to bother moving. The small comment replacing it says enough.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux
* 'writeback-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux:
writeback: Add a 'reason' to wb_writeback_work
writeback: send work item to queue_io, move_expired_inodes
writeback: trace event balance_dirty_pages
writeback: trace event bdi_dirty_ratelimit
writeback: fix ppc compile warnings on do_div(long long, unsigned long)
writeback: per-bdi background threshold
writeback: dirty position control - bdi reserve area
writeback: control dirty pause time
writeback: limit max dirty pause time
writeback: IO-less balance_dirty_pages()
writeback: per task dirty rate limit
writeback: stabilize bdi->dirty_ratelimit
writeback: dirty rate control
writeback: add bg_threshold parameter to __bdi_update_bandwidth()
writeback: account per-bdi accumulated dirtied pages
On the ext4 mailing list[1], we got some report about errors in
__find_get_block_slow(), but the information is very limited.
If the device information is given, we can know the name of the sick
volume. Futhermore, we can get the corresponding status of that
block(group, inode block etc) by analyzing the disk layout.
[1] http://marc.info/?l=linux-ext4&m=131379831421147&w=2
Signed-off-by: Tao Ma <boyu.mt@taobao.com>
This creates a new 'reason' field in a wb_writeback_work
structure, which unambiguously identifies who initiates
writeback activity. A 'wb_reason' enumeration has been
added to writeback.h, to enumerate the possible reasons.
The 'writeback_work_class' and tracepoint event class and
'writeback_queue_io' tracepoints are updated to include the
symbolic 'reason' in all trace events.
And the 'writeback_inodes_sbXXX' family of routines has had
a wb_stats parameter added to them, so callers can specify
why writeback is being started.
Acked-by: Jan Kara <jack@suse.cz>
Signed-off-by: Curt Wohlgemuth <curtw@google.com>
Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
The patch is aganist 3.1-rc3.
Signed-off-by: Wang Sheng-Hui <shhuiw@gmail.com>
I've got a report of a file corruption from fsxlinux on ext3. The important
operations to the page were:
mapwrite to a hole
partial write to the page
read - found the page zeroed from the end of the normal write
The culprit seems to be that if get_block() fails in __block_write_begin()
(e.g. transient ENOSPC in ext3), the function does ClearPageUptodate(page).
Thus when we retry the write, the logic in __block_write_begin() thinks zeroing
of the page is needed and overwrites old data. In fact, I don't see why we
should ever need to zero the uptodate bit here - either the page was uptodate
when we entered __block_write_begin() and it should stay so when we leave it,
or it was not uptodate and noone had right to set it uptodate during
__block_write_begin() so it remains !uptodate when we leave as well. So just
remove clearing of the bit.
For filesystems such as nilfs2 and xfs that use block_page_mkwrite, modify that
function to wait for pending writeback before allowing the page to become
writable. This is needed to stabilize pages during writeback for those two
filesystems.
Signed-off-by: Darrick J. Wong <djwong@us.ibm.com>
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem:
xen: cleancache shim to Xen Transcendent Memory
ocfs2: add cleancache support
ext4: add cleancache support
btrfs: add cleancache support
ext3: add cleancache support
mm/fs: add hooks to support cleancache
mm: cleancache core ops functions and config
fs: add field to superblock to support cleancache
mm/fs: cleancache documentation
Fix up trivial conflict in fs/btrfs/extent_io.c due to includes
This fourth patch of eight in this cleancache series provides the
core hooks in VFS for: initializing cleancache per filesystem;
capturing clean pages reclaimed by page cache; attempting to get
pages from cleancache before filesystem read; and ensuring coherency
between pagecache, disk, and cleancache. Note that the placement
of these hooks was stable from 2.6.18 to 2.6.38; a minor semantic
change was required due to a patchset in 2.6.39.
All hooks become no-ops if CONFIG_CLEANCACHE is unset, or become
a check of a boolean global if CONFIG_CLEANCACHE is set but no
cleancache "backend" has claimed cleancache_ops.
Details and a FAQ can be found in Documentation/vm/cleancache.txt
[v8: minchan.kim@gmail.com: adapt to new remove_from_page_cache function]
Signed-off-by: Chris Mason <chris.mason@oracle.com>
Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com>
Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Rik Van Riel <riel@redhat.com>
Cc: Jan Beulich <JBeulich@novell.com>
Cc: Andreas Dilger <adilger@sun.com>
Cc: Ted Ts'o <tytso@mit.edu>
Cc: Joel Becker <joel.becker@oracle.com>
Cc: Nitin Gupta <ngupta@vflare.org>
We should not allow file modification via mmap while the filesystem is
frozen. So block in block_page_mkwrite() while the filesystem is frozen.
We cannot do the blocking wait in __block_page_mkwrite() since e.g. ext4
will want to call that function with transaction started in some cases
and that would deadlock. But we can at least do the non-blocking reliable
check in __block_page_mkwrite() which is the hardest part anyway.
We have to check for frozen filesystem with the page marked dirty and under
page lock with which we then return from ->page_mkwrite(). Only that way we
cannot race with writeback done by freezing code - either we mark the page
dirty after the writeback has started, see freezing in progress and block, or
writeback will wait for our page lock which is released only when the fault is
done and then writeback will writeout and writeprotect the page again.
Create __block_page_mkwrite() helper which does all what block_page_mkwrite()
does except that it passes back errors from __block_write_begin /
block_commit_write calls.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
fs: simplify iget & friends
fs: pull inode->i_lock up out of writeback_single_inode
fs: rename inode_lock to inode_hash_lock
fs: move i_wb_list out from under inode_lock
fs: move i_sb_list out from under inode_lock
fs: remove inode_lock from iput_final and prune_icache
fs: Lock the inode LRU list separately
fs: factor inode disposal
fs: protect inode->i_state with inode->i_lock
autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd()
autofs4 - remove autofs4_lock
autofs4 - fix d_manage() return on rcu-walk
autofs4 - fix autofs4_expire_indirect() traversal
autofs4 - fix dentry leak in autofs4_expire_direct()
autofs4 - reinstate last used update on access
vfs - check non-mountpoint dentry might block in __follow_mount_rcu()
Protect inode state transitions and validity checks with the
inode->i_lock. This enables us to make inode state transitions
independently of the inode_lock and is the first step to peeling
away the inode_lock from the code.
This requires that __iget() is done atomically with i_state checks
during list traversals so that we don't race with another thread
marking the inode I_FREEING between the state check and grabbing the
reference.
Also remove the unlock_new_inode() memory barrier optimisation
required to avoid taking the inode_lock when clearing I_NEW.
Simplify the code by simply taking the inode->i_lock around the
state change and wakeup. Because the wakeup is no longer tricky,
remove the wake_up_inode() function and open code the wakeup where
necessary.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
It used WRITE_SYNC_PLUG before and potentially submits a batch
of IO, so lets enable plugging for this case.
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
With the plugging now being explicitly controlled by the
submitter, callers need not pass down unplugging hints
to the block layer. If they want to unplug, it's because they
manually plugged on their own - in which case, they should just
unplug at will.
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
