path: root/fs/buffer.c
2012-07-31fs: Protect write paths by sb_start_write - sb_end_writeJan Kara
There are several entry points which dirty pages in a filesystem. mmap (handled by block_page_mkwrite()), buffered write (handled by __generic_file_aio_write()), splice write (generic_file_splice_write), truncate, and fallocate (these can dirty last partial page - handled inside each filesystem separately). Protect these places with sb_start_write() and sb_end_write(). ->page_mkwrite() calls are particularly complex since they are called with mmap_sem held and thus we cannot use standard sb_start_write() due to lock ordering constraints. We solve the problem by using a special freeze protection sb_start_pagefault() which ranks below mmap_sem. BugLink: https://bugs.launchpad.net/bugs/897421 Tested-by: Kamal Mostafa <kamal@canonical.com> Tested-by: Peter M. Petrakis <peter.petrakis@canonical.com> Tested-by: Dann Frazier <dann.frazier@canonical.com> Tested-by: Massimo Morana <massimo.morana@canonical.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-31fs: Push file_update_time() into __block_page_mkwrite()Jan Kara
2012-07-13block: fix infinite loop in __getblk_slowJeff Moyer
Commit 080399aaaf35 ("block: don't mark buffers beyond end of disk as mapped") exposed a bug in __getblk_slow that causes mount to hang as it loops infinitely waiting for a buffer that lies beyond the end of the disk to become uptodate. The problem was initially reported by Torsten Hilbrich here: https://lkml.org/lkml/2012/6/18/54 and also reported independently here: http://www.sysresccd.org/forums/viewtopic.php?f=13&t=4511 and then Richard W.M. Jones and Marcos Mello noted a few separate bugzillas also associated with the same issue. This patch has been confirmed to fix: https://bugzilla.redhat.com/show_bug.cgi?id=835019 The main problem is here, in __getblk_slow: for (;;) { struct buffer_head * bh; int ret; bh = __find_get_block(bdev, block, size); if (bh) return bh; ret = grow_buffers(bdev, block, size); if (ret < 0) return NULL; if (ret == 0) free_more_memory(); } __find_get_block does not find the block, since it will not be marked as mapped, and so grow_buffers is called to fill in the buffers for the associated page. I believe the for (;;) loop is there primarily to retry in the case of memory pressure keeping grow_buffers from succeeding. However, we also continue to loop for other cases, like the block lying beond the end of the disk. So, the fix I came up with is to only loop when grow_buffers fails due to memory allocation issues (return value of 0). The attached patch was tested by myself, Torsten, and Rich, and was found to resolve the problem in call cases. Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Reported-and-Tested-by: Torsten Hilbrich <torsten.hilbrich@secunet.com> Tested-by: Richard W.M. Jones <rjones@redhat.com> Reviewed-by: Josh Boyer <jwboyer@redhat.com> Cc: Stable <stable@vger.kernel.org> # 3.0+ [ Jens is on vacation, taking this directly - Linus ] -- Stable Notes: this patch requires backport to 3.0, 3.2 and 3.3. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-30fs: Move bh_cachep to the __read_mostly sectionShai Fultheim
bh_cachep is only written to once on initialization, so move it to the __read_mostly section. Signed-off-by: Shai Fultheim <shai@scalemp.com> Signed-off-by: Vlad Zolotarov <vlad@scalemp.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-11block: don't mark buffers beyond end of disk as mappedJeff Moyer
Hi, We have a bug report open where a squashfs image mounted on ppc64 would exhibit errors due to trying to read beyond the end of the disk. It can easily be reproduced by doing the following: [root@ibm-p750e-02-lp3 ~]# ls -l install.img -rw-r--r-- 1 root root 142032896 Apr 30 16:46 install.img [root@ibm-p750e-02-lp3 ~]# mount -o loop ./install.img /mnt/test [root@ibm-p750e-02-lp3 ~]# dd if=/dev/loop0 of=/dev/null dd: reading `/dev/loop0': Input/output error 277376+0 records in 277376+0 records out 142016512 bytes (142 MB) copied, 0.9465 s, 150 MB/s In dmesg, you'll find the following: squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 43.106012] attempt to access beyond end of device [ 43.106029] loop0: rw=0, want=277410, limit=277408 [ 43.106039] Buffer I/O error on device loop0, logical block 138704 [ 43.106053] attempt to access beyond end of device [ 43.106057] loop0: rw=0, want=277412, limit=277408 [ 43.106061] Buffer I/O error on device loop0, logical block 138705 [ 43.106066] attempt to access beyond end of device [ 43.106070] loop0: rw=0, want=277414, limit=277408 [ 43.106073] Buffer I/O error on device loop0, logical block 138706 [ 43.106078] attempt to access beyond end of device [ 43.106081] loop0: rw=0, want=277416, limit=277408 [ 43.106085] Buffer I/O error on device loop0, logical block 138707 [ 43.106089] attempt to access beyond end of device [ 43.106093] loop0: rw=0, want=277418, limit=277408 [ 43.106096] Buffer I/O error on device loop0, logical block 138708 [ 43.106101] attempt to access beyond end of device [ 43.106104] loop0: rw=0, want=277420, limit=277408 [ 43.106108] Buffer I/O error on device loop0, logical block 138709 [ 43.106112] attempt to access beyond end of device [ 43.106116] loop0: rw=0, want=277422, limit=277408 [ 43.106120] Buffer I/O error on device loop0, logical block 138710 [ 43.106124] attempt to access beyond end of device [ 43.106128] loop0: rw=0, want=277424, limit=277408 [ 43.106131] Buffer I/O error on device loop0, logical block 138711 [ 43.106135] attempt to access beyond end of device [ 43.106139] loop0: rw=0, want=277426, limit=277408 [ 43.106143] Buffer I/O error on device loop0, logical block 138712 [ 43.106147] attempt to access beyond end of device [ 43.106151] loop0: rw=0, want=277428, limit=277408 [ 43.106154] Buffer I/O error on device loop0, logical block 138713 [ 43.106158] attempt to access beyond end of device [ 43.106162] loop0: rw=0, want=277430, limit=277408 [ 43.106166] attempt to access beyond end of device [ 43.106169] loop0: rw=0, want=277432, limit=277408 ... [ 43.106307] attempt to access beyond end of device [ 43.106311] loop0: rw=0, want=277470, limit=2774 Squashfs manages to read in the end block(s) of the disk during the mount operation. Then, when dd reads the block device, it leads to block_read_full_page being called with buffers that are beyond end of disk, but are marked as mapped. Thus, it would end up submitting read I/O against them, resulting in the errors mentioned above. I fixed the problem by modifying init_page_buffers to only set the buffer mapped if it fell inside of i_size. Cheers, Jeff Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Acked-by: Nick Piggin <npiggin@kernel.dk> -- Changes from v1->v2: re-used max_block, as suggested by Nick Piggin. Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-04-25fs/buffer.c: remove BUG() in possible but rare conditionGlauber Costa
While stressing the kernel with with failing allocations today, I hit the following chain of events: alloc_page_buffers(): bh = alloc_buffer_head(GFP_NOFS); if (!bh) goto no_grow; <= path taken grow_dev_page(): bh = alloc_page_buffers(page, size, 0); if (!bh) goto failed; <= taken, consequence of the above and then the failed path BUG()s the kernel. The failure is inserted a litte bit artificially, but even then, I see no reason why it should be deemed impossible in a real box. Even though this is not a condition that we expect to see around every time, failed allocations are expected to be handled, and BUG() sounds just too much. As a matter of fact, grow_dev_page() can return NULL just fine in other circumstances, so I propose we just remove it, then. Signed-off-by: Glauber Costa <glommer@parallels.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-28fs: only send IPI to invalidate LRU BH when neededGilad Ben-Yossef
In several code paths, such as when unmounting a file system (but not only) we send an IPI to ask each cpu to invalidate its local LRU BHs. For multi-cores systems that have many cpus that may not have any LRU BH because they are idle or because they have not performed any file system accesses since last invalidation (e.g. CPU crunching on high perfomance computing nodes that write results to shared memory or only using filesystems that do not use the bh layer.) This can lead to loss of performance each time someone switches the KVM (the virtual keyboard and screen type, not the hypervisor) if it has a USB storage stuck in. This patch attempts to only send an IPI to cpus that have LRU BH. Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-28fs: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-01-03fs: move code out of buffer.cAl Viro
Move invalidate_bdev, block_sync_page into fs/block_dev.c. Export kill_bdev as well, so brd doesn't have to open code it. Reduce buffer_head.h requirement accordingly. Removed a rather large comment from invalidate_bdev, as it looked a bit obsolete to bother moving. The small comment replacing it says enough. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-06Merge branch 'writeback-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux * 'writeback-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux: writeback: Add a 'reason' to wb_writeback_work writeback: send work item to queue_io, move_expired_inodes writeback: trace event balance_dirty_pages writeback: trace event bdi_dirty_ratelimit writeback: fix ppc compile warnings on do_div(long long, unsigned long) writeback: per-bdi background threshold writeback: dirty position control - bdi reserve area writeback: control dirty pause time writeback: limit max dirty pause time writeback: IO-less balance_dirty_pages() writeback: per task dirty rate limit writeback: stabilize bdi->dirty_ratelimit writeback: dirty rate control writeback: add bg_threshold parameter to __bdi_update_bandwidth() writeback: dirty position control writeback: account per-bdi accumulated dirtied pages
2011-10-31fs/buffer.c: add device information for error output in __find_get_block_slow()Tao Ma
On the ext4 mailing list[1], we got some report about errors in __find_get_block_slow(), but the information is very limited. If the device information is given, we can know the name of the sick volume. Futhermore, we can get the corresponding status of that block(group, inode block etc) by analyzing the disk layout. [1] http://marc.info/?l=linux-ext4&m=131379831421147&w=2 Signed-off-by: Tao Ma <boyu.mt@taobao.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-31writeback: Add a 'reason' to wb_writeback_workCurt Wohlgemuth
This creates a new 'reason' field in a wb_writeback_work structure, which unambiguously identifies who initiates writeback activity. A 'wb_reason' enumeration has been added to writeback.h, to enumerate the possible reasons. The 'writeback_work_class' and tracepoint event class and 'writeback_queue_io' tracepoints are updated to include the symbolic 'reason' in all trace events. And the 'writeback_inodes_sbXXX' family of routines has had a wb_stats parameter added to them, so callers can specify why writeback is being started. Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Curt Wohlgemuth <curtw@google.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com>
2011-10-28cleanup: vfs: small comment fix for block_invalidatepageWang Sheng-Hui
The patch is aganist 3.1-rc3. Signed-off-by: Wang Sheng-Hui <shhuiw@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-06-16vfs: Fix data corruption after failed write in __block_write_begin()Jan Kara
I've got a report of a file corruption from fsxlinux on ext3. The important operations to the page were: mapwrite to a hole partial write to the page read - found the page zeroed from the end of the normal write The culprit seems to be that if get_block() fails in __block_write_begin() (e.g. transient ENOSPC in ext3), the function does ClearPageUptodate(page). Thus when we retry the write, the logic in __block_write_begin() thinks zeroing of the page is needed and overwrites old data. In fact, I don't see why we should ever need to zero the uptodate bit here - either the page was uptodate when we entered __block_write_begin() and it should stay so when we leave it, or it was not uptodate and noone had right to set it uptodate during __block_write_begin() so it remains !uptodate when we leave as well. So just remove clearing of the bit. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-28fs: block_page_mkwrite should wait for writeback to finishDarrick J. Wong
For filesystems such as nilfs2 and xfs that use block_page_mkwrite, modify that function to wait for pending writeback before allowing the page to become writable. This is needed to stabilize pages during writeback for those two filesystems. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem: xen: cleancache shim to Xen Transcendent Memory ocfs2: add cleancache support ext4: add cleancache support btrfs: add cleancache support ext3: add cleancache support mm/fs: add hooks to support cleancache mm: cleancache core ops functions and config fs: add field to superblock to support cleancache mm/fs: cleancache documentation Fix up trivial conflict in fs/btrfs/extent_io.c due to includes
2011-05-26mm/fs: add hooks to support cleancacheDan Magenheimer
This fourth patch of eight in this cleancache series provides the core hooks in VFS for: initializing cleancache per filesystem; capturing clean pages reclaimed by page cache; attempting to get pages from cleancache before filesystem read; and ensuring coherency between pagecache, disk, and cleancache. Note that the placement of these hooks was stable from 2.6.18 to 2.6.38; a minor semantic change was required due to a patchset in 2.6.39. All hooks become no-ops if CONFIG_CLEANCACHE is unset, or become a check of a boolean global if CONFIG_CLEANCACHE is set but no cleancache "backend" has claimed cleancache_ops. Details and a FAQ can be found in Documentation/vm/cleancache.txt [v8: minchan.kim@gmail.com: adapt to new remove_from_page_cache function] Signed-off-by: Chris Mason <chris.mason@oracle.com> Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik Van Riel <riel@redhat.com> Cc: Jan Beulich <JBeulich@novell.com> Cc: Andreas Dilger <adilger@sun.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Nitin Gupta <ngupta@vflare.org>
2011-05-26vfs: Block mmapped writes while the fs is frozenJan Kara
We should not allow file modification via mmap while the filesystem is frozen. So block in block_page_mkwrite() while the filesystem is frozen. We cannot do the blocking wait in __block_page_mkwrite() since e.g. ext4 will want to call that function with transaction started in some cases and that would deadlock. But we can at least do the non-blocking reliable check in __block_page_mkwrite() which is the hardest part anyway. We have to check for frozen filesystem with the page marked dirty and under page lock with which we then return from ->page_mkwrite(). Only that way we cannot race with writeback done by freezing code - either we mark the page dirty after the writeback has started, see freezing in progress and block, or writeback will wait for our page lock which is released only when the fault is done and then writeback will writeout and writeprotect the page again. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: Create __block_page_mkwrite() helper passing error values backJan Kara
Create __block_page_mkwrite() helper which does all what block_page_mkwrite() does except that it passes back errors from __block_write_begin / block_commit_write calls. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: fs: simplify iget & friends fs: pull inode->i_lock up out of writeback_single_inode fs: rename inode_lock to inode_hash_lock fs: move i_wb_list out from under inode_lock fs: move i_sb_list out from under inode_lock fs: remove inode_lock from iput_final and prune_icache fs: Lock the inode LRU list separately fs: factor inode disposal fs: protect inode->i_state with inode->i_lock autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd() autofs4 - remove autofs4_lock autofs4 - fix d_manage() return on rcu-walk autofs4 - fix autofs4_expire_indirect() traversal autofs4 - fix dentry leak in autofs4_expire_direct() autofs4 - reinstate last used update on access vfs - check non-mountpoint dentry might block in __follow_mount_rcu()
2011-03-24fs: protect inode->i_state with inode->i_lockDave Chinner
Protect inode state transitions and validity checks with the inode->i_lock. This enables us to make inode state transitions independently of the inode_lock and is the first step to peeling away the inode_lock from the code. This requires that __iget() is done atomically with i_state checks during list traversals so that we don't race with another thread marking the inode I_FREEING between the state check and grabbing the reference. Also remove the unlock_new_inode() memory barrier optimisation required to avoid taking the inode_lock when clearing I_NEW. Simplify the code by simply taking the inode->i_lock around the state change and wakeup. Because the wakeup is no longer tricky, remove the wake_up_inode() function and open code the wakeup where necessary. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-17fs: make fsync_buffers_list() plugJens Axboe
It used WRITE_SYNC_PLUG before and potentially submits a batch of IO, so lets enable plugging for this case. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: kill off REQ_UNPLUGJens Axboe
With the plugging now being explicitly controlled by the submitter, callers need not pass down unplugging hints to the block layer. If they want to unplug, it's because they manually plugged on their own - in which case, they should just unplug at will. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-12-17fs: Use this_cpu_inc_return in buffer.cChristoph Lameter
__this_cpu_inc can create a single instruction with the same effect as the _get_cpu_var(..)++ construct in buffer.c. Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Christoph Hellwig <hch@lst.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-12-17fs: Use this_cpu_xx operations in buffer.cChristoph Lameter
Optimize various per cpu area operations through these new percpu operations. These operations avoid address calculations through the use of segment prefixes and multiple memory references through RMW instructions etc. Reduces code size: Before: christoph@linux-2.6$ size fs/buffer.o text data bss dec hex filename 19169 80 28 19277 4b4d fs/buffer.o After: christoph@linux-2.6$ size fs/buffer.o text data bss dec hex filename 19138 80 28 19246 4b2e fs/buffer.o V3->V4: - Move the use of this_cpu_inc_return into a later patch so that this one can go in without percpu infrastructure changes. Cc: Wu Fengguang <fengguang.wu@intel.com> Cc: Christoph Hellwig <hch@lst.de> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Tejun Heo <tj@kernel.org>
2010-10-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (52 commits) split invalidate_inodes() fs: skip I_FREEING inodes in writeback_sb_inodes fs: fold invalidate_list into invalidate_inodes fs: do not drop inode_lock in dispose_list fs: inode split IO and LRU lists fs: switch bdev inode bdi's correctly fs: fix buffer invalidation in invalidate_list fsnotify: use dget_parent smbfs: use dget_parent exportfs: use dget_parent fs: use RCU read side protection in d_validate fs: clean up dentry lru modification fs: split __shrink_dcache_sb fs: improve DCACHE_REFERENCED usage fs: use percpu counter for nr_dentry and nr_dentry_unused fs: simplify __d_free fs: take dcache_lock inside __d_path fs: do not assign default i_ino in new_inode fs: introduce a per-cpu last_ino allocator new helper: ihold() ...
2010-10-26fs/buffer.c: remove duplicated assignment to b_privateNamhyung Kim
bh->b_private is initialized within init_buffer(), thus this assignment is redundant. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-26writeback: remove nonblocking/encountered_congestion referencesWu Fengguang
This removes more dead code that was somehow missed by commit 0d99519efef (writeback: remove unused nonblocking and congestion checks). There are no behavior change except for the removal of two entries from one of the ext4 tracing interface. The nonblocking checks in ->writepages are no longer used because the flusher now prefer to block on get_request_wait() than to skip inodes on IO congestion. The latter will lead to more seeky IO. The nonblocking checks in ->writepage are no longer used because it's redundant with the WB_SYNC_NONE check. We no long set ->nonblocking in VM page out and page migration, because a) it's effectively redundant with WB_SYNC_NONE in current code b) it's old semantic of "Don't get stuck on request queues" is mis-behavior: that would skip some dirty inodes on congestion and page out others, which is unfair in terms of LRU age. Inspired by Christoph Hellwig. Thanks! Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Cc: David Howells <dhowells@redhat.com> Cc: Sage Weil <sage@newdream.net> Cc: Steve French <sfrench@samba.org> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25fs/buffer.c: call __block_write_begin() if we have pageNamhyung Kim
If we have the appropriate page already, call __block_write_begin() directly instead of releasing and regrabbing it inside of block_write_begin(). Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs/buffer.c: remove duplicated assignment on b_privateNamhyung Kim
bh->b_private is initialized within init_buffer(), thus the assignment should be redundant. Remove it. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: kill block_prepare_writeChristoph Hellwig
__block_write_begin and block_prepare_write are identical except for slightly different calling conventions. Convert all callers to the __block_write_begin calling conventions and drop block_prepare_write. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-09-10block: remove the BH_Eopnotsupp flagChristoph Hellwig
This flag was only set for barrier buffers, which we don't submit anymore. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-18remove SWRITE* I/O typesChristoph Hellwig
These flags aren't real I/O types, but tell ll_rw_block to always lock the buffer instead of giving up on a failed trylock. Instead add a new write_dirty_buffer helper that implements this semantic and use it from the existing SWRITE* callers. Note that the ll_rw_block code had a bug where it didn't promote WRITE_SYNC_PLUG properly, which this patch fixes. In the ufs code clean up the helper that used to call ll_rw_block to mirror sync_dirty_buffer, which is the function it implements for compound buffers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-18kill BH_Ordered flagChristoph Hellwig
Instead of abusing a buffer_head flag just add a variant of sync_dirty_buffer which allows passing the exact type of write flag required. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of block_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in preparation of the new truncate sequence and rename the non-truncating version to block_write_begin. While we're at it also remove several unused arguments to block_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09introduce __block_write_beginChristoph Hellwig
Split up the block_write_begin implementation - __block_write_begin is a new trivial wrapper for block_prepare_write that always takes an already allocated page and can be either called from block_write_begin or filesystem code that already has a page allocated. Remove the handling of already allocated pages from block_write_begin after switching all callers that do it to __block_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of cont_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in preparation of the new truncate sequence and rename the non-truncating version to cont_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09get rid of nobh_write_begin_newtruncChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the only remaining caller and rename the non-truncating version to nobh_write_begin. Get rid of the superflous file argument to it while we're at it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27fs: introduce new truncate sequencenpiggin@suse.de
Introduce a new truncate calling sequence into fs/mm subsystems. Rather than setattr > vmtruncate > truncate, have filesystems call their truncate sequence from ->setattr if filesystem specific operations are required. vmtruncate is deprecated, and truncate_pagecache and inode_newsize_ok helpers introduced previously should be used. simple_setattr is introduced for simple in-ram filesystems to implement the new truncate sequence. Eventually all filesystems should be converted to implement a setattr, and the default code in notify_change should go away. simple_setsize is also introduced to perform just the ATTR_SIZE portion of simple_setattr (ie. changing i_size and trimming pagecache). To implement the new truncate sequence: - filesystem specific manipulations (eg freeing blocks) must be done in the setattr method rather than ->truncate. - vmtruncate can not be used by core code to trim blocks past i_size in the event of write failure after allocation, so this must be performed in the fs code. - convert usage of helpers block_write_begin, nobh_write_begin, cont_write_begin, and *blockdev_direct_IO* to use _newtrunc postfixed variants. These avoid calling vmtruncate to trim blocks (see previous). - inode_setattr should not be used. generic_setattr is a new function to be used to copy simple attributes into the generic inode. - make use of the better opportunity to handle errors with the new sequence. Big problem with the previous calling sequence: the filesystem is not called until i_size has already changed. This means it is not allowed to fail the call, and also it does not know what the previous i_size was. Also, generic code calling vmtruncate to truncate allocated blocks in case of error had no good way to return a meaningful error (or, for example, atomically handle block deallocation). Cc: Christoph Hellwig <hch@lst.de> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (69 commits) fix handling of offsets in cris eeprom.c, get rid of fake on-stack files get rid of home-grown mutex in cris eeprom.c switch ecryptfs_write() to struct inode *, kill on-stack fake files switch ecryptfs_get_locked_page() to struct inode * simplify access to ecryptfs inodes in ->readpage() and friends AFS: Don't put struct file on the stack Ban ecryptfs over ecryptfs logfs: replace inode uid,gid,mode initialization with helper function ufs: replace inode uid,gid,mode initialization with helper function udf: replace inode uid,gid,mode init with helper ubifs: replace inode uid,gid,mode initialization with helper function sysv: replace inode uid,gid,mode initialization with helper function reiserfs: replace inode uid,gid,mode initialization with helper function ramfs: replace inode uid,gid,mode initialization with helper function omfs: replace inode uid,gid,mode initialization with helper function bfs: replace inode uid,gid,mode initialization with helper function ocfs2: replace inode uid,gid,mode initialization with helper function nilfs2: replace inode uid,gid,mode initialization with helper function minix: replace inode uid,gid,mode init with helper ext4: replace inode uid,gid,mode init with helper ... Trivial conflict in fs/fs-writeback.c (mark bitfields unsigned)
2010-05-21new helper: iterate_supers()Al Viro
... and switch the simple "loop over superblocks and do something" loops to it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21Convert simple loops over superblocks to list_for_each_entry_safeAl Viro
2010-05-21Leave superblocks on s_list until the endAl Viro
We used to remove from s_list and s_instances at the same time. So let's *not* do the former and skip superblocks that have empty s_instances in the loops over s_list. The next step, of course, will be to get rid of rescan logics in those loops. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21buffer: make invalidate_bdev() drain all percpu LRU add cachesTejun Heo
invalidate_bdev() should release all page cache pages which are clean and not being used; however, if some pages are still in the percpu LRU add caches on other cpus, those pages are considered in used and don't get released. Fix it by calling lru_add_drain_all() before trying to invalidate pages. This problem was discovered while testing block automatic native capacity unlocking. Null pages which were read before automatic unlocking didn't get released by invalidate_bdev() and ended up interfering with partition scan after unlocking. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-12fs: buffer_head: remove kmem_cache constructor to reduce memory usage under slubRichard Kennedy
When using slub, having a kmem_cache constructor forces slub to add a free pointer to the size of the cached object, which can have a significant impact to the number of small objects that can fit into a slab. As buffer_head is relatively small and we can have large numbers of them, removing the constructor is a definite win. On x86_64 removing the constructor gives me 39 objects/slab, 3 more than without the patch. And on x86_32 73 objects/slab, which is 9 more. As alloc_buffer_head() already initializes each new object there is very little difference in actual code run. Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Jens Axboe <jens.axboe@oracle.com> Acked-by: Nick Piggin <npiggin@suse.de> Cc: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-02-04Fix misspellings of "invocation" in comments.Adam Buchbinder
Some comments misspell "invocation"; this fixes them. No code changes. Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-25Merge branch 'writeback' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'writeback' of git://git.kernel.dk/linux-2.6-block: writeback: writeback_inodes_sb() should use bdi_start_writeback() writeback: don't delay inodes redirtied by a fast dirtier writeback: make the super_block pinning more efficient writeback: don't resort for a single super_block in move_expired_inodes() writeback: move inodes from one super_block together writeback: get rid to incorrect references to pdflush in comments writeback: improve readability of the wb_writeback() continue/break logic writeback: cleanup writeback_single_inode() writeback: kupdate writeback shall not stop when more io is possible writeback: stop background writeback when below background threshold writeback: balance_dirty_pages() shall write more than dirtied pages fs: Fix busyloop in wb_writeback()
2009-09-25writeback: get rid to incorrect references to pdflush in commentsJens Axboe
