[ Upstream commit 31ffa563833576bd49a8bf53120568312755e6e2 ]
Variable 'cache' is being assigned but is never used hence it is
redundant and can be removed.
Cleans up clang warning:
warning: variable 'cache' set but not used [-Wunused-but-set-variable]
[ Upstream commit 9a24ce5b66f9c8190d63b15f4473600db4935f1f ]
[Description]
In a heavily loaded system where the system pagecache is nearing memory
limits and fscache is enabled, pages can be leaked by fscache while trying
read pages from cachefiles backend. This can happen because two
applications can be reading same page from a single mount, two threads can
be trying to read the backing page at same time. This results in one of
the threads finding that a page for the backing file or netfs file is
already in the radix tree. During the error handling cachefiles does not
clean up the reference on backing page, leading to page leak.
[Fix]
The fix is straightforward, to decrement the reference when error is
encountered.
[dhowells: Note that I've removed the clearance and put of newpage as
they aren't attested in the commit message and don't appear to actually
achieve anything since a new page is only allocated is newpage!=NULL and
any residual new page is cleared before returning.]
[Testing]
I have tested the fix using following method for 12+ hrs.
1) mkdir -p /mnt/nfs ; mount -o vers=3,fsc <server_ip>:/export /mnt/nfs
2) create 10000 files of 2.8MB in a NFS mount.
3) start a thread to simulate heavy VM presssure
(while true ; do echo 3 > /proc/sys/vm/drop_caches ; sleep 1 ; done)&
4) start multiple parallel reader for data set at same time
find /mnt/nfs -type f | xargs -P 80 cat > /dev/null &
5) finally check using cat /proc/fs/fscache/stats | grep -i pages ;
free -h , cat /proc/meminfo and page-types -r -b lru
to ensure all pages are freed.
Reviewed-by: Daniel Axtens <dja@axtens.net>
Signed-off-by: Shantanu Goel <sgoel01@yahoo.com>
Signed-off-by: Kiran Kumar Modukuri <kiran.modukuri@gmail.com>
[dja: forward ported to current upstream]
Signed-off-by: Daniel Axtens <dja@axtens.net>
commit 169b803397499be85bdd1e3d07d6f5e3d4bd669e upstream.
the victim might've been rmdir'ed just before the lock_rename();
unlike the normal callers, we do not look the source up after the
parents are locked - we know it beforehand and just recheck that it's
still the child of what used to be its parent. Unfortunately,
the check is too weak - we don't spot a dead directory since its
->d_parent is unchanged, dentry is positive, etc. So we sail all
the way to ->rename(), with hosting filesystems _not_ expecting
to be asked renaming an rmdir'ed subdirectory.
The fix is easy, fortunately - the lock on parent is sufficient for
making IS_DEADDIR() on child safe.
Cc: stable@vger.kernel.org
Fixes: 9ae326a69004 (CacheFiles: A cache that backs onto a mounted filesystem)
[ Upstream commit c2412ac45a8f8f1cd582723c1a139608694d410d ]
If we meet a conflicting object that is marked FSCACHE_OBJECT_IS_LIVE in
the active object tree, we have been emitting a BUG after logging
information about it and the new object.
Instead, we should wait for the CACHEFILES_OBJECT_ACTIVE flag to be cleared
on the old object (or return an error). The ACTIVE flag should be cleared
after it has been removed from the active object tree. A timeout of 60s is
used in the wait, so we shouldn't be able to get stuck there.
Fixes: 9ae326a69004 ("CacheFiles: A cache that backs onto a mounted filesystem")
[ Upstream commit 934140ab028713a61de8bca58c05332416d037d1 ]
cachefiles_read_waiter() has the right to access a 'monitor' object by
virtue of being called under the waitqueue lock for one of the pages in its
purview. However, it has no ref on that monitor object or on the
associated operation.
What it is allowed to do is to move the monitor object to the operation's
to_do list, but once it drops the work_lock, it's actually no longer
permitted to access that object. However, it is trying to enqueue the
retrieval operation for processing - but it can only do this via a pointer
in the monitor object, something it shouldn't be doing.
If it doesn't enqueue the operation, the operation may not get processed.
If the order is flipped so that the enqueue is first, then it's possible
for the work processor to look at the to_do list before the monitor is
enqueued upon it.
Fix this by getting a ref on the operation so that we can trust that it
will still be there once we've added the monitor to the to_do list and
dropped the work_lock. The op can then be enqueued after the lock is
dropped.
The bug can manifest in one of a couple of ways. The first manifestation
looks like:
FS-Cache:
FS-Cache: Assertion failed
FS-Cache: 6 == 5 is false
kernel BUG at fs/fscache/operation.c:494!
RIP: 0010:fscache_put_operation+0x1e3/0x1f0
fscache_op_work_func+0x26/0x50
process_one_work+0x131/0x290
worker_thread+0x45/0x360
kthread+0xf8/0x130
? create_worker+0x190/0x190
? kthread_cancel_work_sync+0x10/0x10
ret_from_fork+0x1f/0x30
This is due to the operation being in the DEAD state (6) rather than
INITIALISED, COMPLETE or CANCELLED (5) because it's already passed through
fscache_put_operation().
The bug can also manifest like the following:
kernel BUG at fs/fscache/operation.c:69!
[exception RIP: fscache_enqueue_operation+246]
#7 [ffff883fff083c10] fscache_enqueue_operation at ffffffffa0b793c6
#8 [ffff883fff083c28] cachefiles_read_waiter at ffffffffa0b15a48
#9 [ffff883fff083c48] __wake_up_common at ffffffff810af028
I'm not entirely certain as to which is line 69 in Lei's kernel, so I'm not
entirely clear which assertion failed.
Reported-by: Lei Xue <carmark.dlut@gmail.com>
Reported-by: Vegard Nossum <vegard.nossum@gmail.com>
Reported-by: Anthony DeRobertis <aderobertis@metrics.net>
Reported-by: NeilBrown <neilb@suse.com>
Reported-by: Daniel Axtens <dja@axtens.net>
Reported-by: Kiran Kumar Modukuri <kiran.modukuri@gmail.com>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Firstly by applying the following with coccinelle's spatch:
@@ expression SB; @@
-SB->s_flags & MS_RDONLY
+sb_rdonly(SB)
to effect the conversion to sb_rdonly(sb), then by applying:
@@ expression A, SB; @@
-(!sb_rdonly(SB)) && A
+!sb_rdonly(SB) && A
-A != (sb_rdonly(SB))
+A != sb_rdonly(SB)
-A == (sb_rdonly(SB))
+A == sb_rdonly(SB)
-!(sb_rdonly(SB))
+!sb_rdonly(SB)
-A && (sb_rdonly(SB))
+A && sb_rdonly(SB)
-A || (sb_rdonly(SB))
+A || sb_rdonly(SB)
-(sb_rdonly(SB)) != A
+sb_rdonly(SB) != A
-(sb_rdonly(SB)) == A
+sb_rdonly(SB) == A
-(sb_rdonly(SB)) && A
+sb_rdonly(SB) && A
-(sb_rdonly(SB)) || A
+sb_rdonly(SB) || A
@@ expression A, B, SB; @@
-(sb_rdonly(SB)) ? 1 : 0
+sb_rdonly(SB)
-(sb_rdonly(SB)) ? A : B
+sb_rdonly(SB) ? A : B
to remove left over excess bracketage and finally by applying:
-(A & MS_RDONLY) != sb_rdonly(SB)
+(bool)(A & MS_RDONLY) != sb_rdonly(SB)
-(A & MS_RDONLY) == sb_rdonly(SB)
+(bool)(A & MS_RDONLY) == sb_rdonly(SB)
to make comparisons against the result of sb_rdonly() (which is a bool)
work correctly.
So I've noticed a number of instances where it was not obvious from the
code whether ->task_list was for a wait-queue head or a wait-queue entry.
Furthermore, there's a number of wait-queue users where the lists are
not for 'tasks' but other entities (poll tables, etc.), in which case
the 'task_list' name is actively confusing.
To clear this all up, name the wait-queue head and entry list structure
fields unambiguously:
struct wait_queue_head::task_list => ::head
struct wait_queue_entry::task_list => ::entry
For example, this code:
rqw->wait.task_list.next != &wait->task_list
... is was pretty unclear (to me) what it's doing, while now it's written this way:
rqw->wait.head.next != &wait->entry
... which makes it pretty clear that we are iterating a list until we see the head.
Other examples are:
list_for_each_entry_safe(pos, next, &x->task_list, task_list) {
list_for_each_entry(wq, &fence->wait.task_list, task_list) {
... where it's unclear (to me) what we are iterating, and during review it's
hard to tell whether it's trying to walk a wait-queue entry (which would be
a bug), while now it's written as:
list_for_each_entry_safe(pos, next, &x->head, entry) {
list_for_each_entry(wq, &fence->wait.head, entry) {
<linux/wait_bit.h>
The wait_bit*() types and APIs are mixed into wait.h, but they
are a pretty orthogonal extension of wait-queues.
Furthermore, only about 50 kernel files use these APIs, while
over 1000 use the regular wait-queue functionality.
So clean up the main wait.h by moving the wait-bit functionality
out of it, into a separate .h and .c file:
include/linux/wait_bit.h for types and APIs
kernel/sched/wait_bit.c for the implementation
Update all header dependencies.
This reduces the size of wait.h rather significantly, by about 30%.
Rename:
wait_queue_t => wait_queue_entry_t
'wait_queue_t' was always a slight misnomer: its name implies that it's a "queue",
but in reality it's a queue *entry*. The 'real' queue is the wait queue head,
which had to carry the name.
Start sorting this out by renaming it to 'wait_queue_entry_t'.
This also allows the real structure name 'struct __wait_queue' to
lose its double underscore and become 'struct wait_queue_entry',
which is the more canonical nomenclature for such data types.
Add #include <linux/cred.h> dependencies to all .c files rely on sched.h
doing that for them.
Note that even if the count where we need to add extra headers seems high,
it's still a net win, because <linux/sched.h> is included in over
2,200 files ...
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
Pull vfs xattr updates from Al Viro:
"xattr stuff from Andreas
This completes the switch to xattr_handler ->get()/->set() from
->getxattr/->setxattr/->removexattr"
* 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
vfs: Remove {get,set,remove}xattr inode operations
xattr: Stop calling {get,set,remove}xattr inode operations
vfs: Check for the IOP_XATTR flag in listxattr
xattr: Add __vfs_{get,set,remove}xattr helpers
libfs: Use IOP_XATTR flag for empty directory handling
vfs: Use IOP_XATTR flag for bad-inode handling
vfs: Add IOP_XATTR inode operations flag
vfs: Move xattr_resolve_name to the front of fs/xattr.c
ecryptfs: Switch to generic xattr handlers
sockfs: Get rid of getxattr iop
sockfs: getxattr: Fail with -EOPNOTSUPP for invalid attribute names
kernfs: Switch to generic xattr handlers
hfs: Switch to generic xattr handlers
jffs2: Remove jffs2_{get,set,remove}xattr macros
xattr: Remove unnecessary NULL attribute name check
Right now, various places in the kernel check for the existence of
getxattr, setxattr, and removexattr inode operations and directly call
those operations. Switch to helper functions and test for the IOP_XATTR
flag instead.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Acked-by: James Morris <james.l.morris@oracle.com>
An NULL-pointer dereference happens in cachefiles_mark_object_inactive()
when it tries to read i_blocks so that it can tell the cachefilesd daemon
how much space it's making available.
The problem is that cachefiles_drop_object() calls
cachefiles_mark_object_inactive() after calling cachefiles_delete_object()
because the object being marked active staves off attempts to (re-)use the
file at that filename until after it has been deleted. This means that
d_inode is NULL by the time we come to try to access it.
To fix the problem, have the caller of cachefiles_mark_object_inactive()
supply the number of blocks freed up.
Without this, the following oops may occur:
BUG: unable to handle kernel NULL pointer dereference at 0000000000000098
IP: [<ffffffffa06c5cc1>] cachefiles_mark_object_inactive+0x61/0xb0 [cachefiles]
CPU: 11 PID: 527 Comm: kworker/u64:4 Tainted: G I ------------ 3.10.0-470.el7.x86_64 #1
Hardware name: Hewlett-Packard HP Z600 Workstation/0B54h, BIOS 786G4 v03.19 03/11/2011
Workqueue: fscache_object fscache_object_work_func [fscache]
task: ffff880035edaf10 ti: ffff8800b77c0000 task.ti: ffff8800b77c0000
RIP: 0010:[<ffffffffa06c5cc1>] cachefiles_mark_object_inactive+0x61/0xb0 [cachefiles]
RSP: 0018:ffff8800b77c3d70 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff8800bf6cc400 RCX: 0000000000000034
RDX: 0000000000000000 RSI: ffff880090ffc710 RDI: ffff8800bf761ef8
RBP: ffff8800b77c3d88 R08: 2000000000000000 R09: 0090ffc710000000
R10: ff51005d2ff1c400 R11: 0000000000000000 R12: ffff880090ffc600
R13: ffff8800bf6cc520 R14: ffff8800bf6cc400 R15: ffff8800bf6cc498
FS: 0000000000000000(0000) GS:ffff8800bb8c0000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000000000000098 CR3: 00000000019ba000 CR4: 00000000000007e0
Stack:
ffff880090ffc600 ffff8800bf6cc400 ffff8800867df140 ffff8800b77c3db0
ffffffffa06c48cb ffff880090ffc600 ffff880090ffc180 ffff880090ffc658
ffff8800b77c3df0 ffffffffa085d846 ffff8800a96b8150 ffff880090ffc600
Call Trace:
[<ffffffffa06c48cb>] cachefiles_drop_object+0x6b/0xf0 [cachefiles]
[<ffffffffa085d846>] fscache_drop_object+0xd6/0x1e0 [fscache]
[<ffffffffa085d615>] fscache_object_work_func+0xa5/0x200 [fscache]
[<ffffffff810a605b>] process_one_work+0x17b/0x470
[<ffffffff810a6e96>] worker_thread+0x126/0x410
[<ffffffff810a6d70>] ? rescuer_thread+0x460/0x460
[<ffffffff810ae64f>] kthread+0xcf/0xe0
[<ffffffff810ae580>] ? kthread_create_on_node+0x140/0x140
[<ffffffff81695418>] ret_from_fork+0x58/0x90
The oopsing code shows:
callq 0xffffffff810af6a0 <wake_up_bit>
mov 0xf8(%r12),%rax
mov 0x30(%rax),%rax
mov 0x98(%rax),%rax <---- oops here
lock add %rax,0x130(%rbx)
where this is:
d_backing_inode(object->dentry)->i_blocks
Fixes: a5b3a80b899bda0f456f1246c4c5a1191ea01519 (CacheFiles: Provide read-and-reset release counters for cachefilesd)
Reported-by: Jianhong Yin <jiyin@redhat.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Reviewed-by: Steve Dickson <steved@redhat.com>
cc: stable@vger.kernel.org
Generated patch:
sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2`
sed -i "s/\brename2\b/rename/g" `git grep -wl rename2`
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
No in-tree uses remain.
There's a race between cachefiles_mark_object_inactive() and
cachefiles_cull():
(1) cachefiles_cull() can't delete a backing file until the cache object
is marked inactive, but as soon as that's the case it's fair game.
(2) cachefiles_mark_object_inactive() marks the object as being inactive
and *only then* reads the i_blocks on the backing inode - but
cachefiles_cull() might've managed to delete it by this point.
Fix this by making sure cachefiles_mark_object_inactive() gets any data it
needs from the backing inode before deactivating the object.
Stack:
Call Trace:
mov 0xf8(%r12),%rax
mov 0x30(%rax),%rax
where this is:
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs into work.misc
__fscache_check_consistency() calls check_consistency() callback
and return the callback's return value. But the return type of
check_consistency() is bool. So __fscache_check_consistency()
return 1 if the cache is inconsistent. This is inconsistent with
the document.
Signed-off-by: Yan, Zheng <zyan@redhat.com>
it's not needed for file_operations of inodes located on fs defined
in the hosting module and for file_operations that go into procfs.
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
Provide read-and-reset objects- and blocks-released counters for cachefilesd
to use to work out whether there's anything new that can be culled.
One of the problems cachefilesd has is that if all the objects in the cache
are pinned by inodes lying dormant in the kernel inode cache, there isn't
anything for it to cull. In such a case, it just spins around walking the
filesystem tree and scanning for something to cull. This eats up a lot of
CPU time.
By telling cachefilesd if there have been any releases, the daemon can
sleep until there is the possibility of something to do.
cachefilesd finds this information by the following means:
(1) When the control fd is read, the kernel presents a list of values of
interest. "freleased=N" and "breleased=N" are added to this list to
indicate the number of files released and number of blocks released
since the last read call. At this point the counters are reset.
(2) POLLIN is signalled if the number of files released becomes greater
than 0.
Note that by 'released' it just means that the kernel has released its
interest in those files for the moment, not necessarily that the files
should be deleted from the cache.
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
A _lot_ of ->write() instances were open-coding it; some are
converted to memdup_user_nul(), a lot more remain...
fs/cachefiles/rdwr.c: In function ‘cachefiles_write_page’:
fs/cachefiles/rdwr.c:882: warning: ‘ret’ may be used uninitialized in
this function
If the jump to label "error" is taken, "ret" will indeed be
uninitialized, and random stack data may be printed by the debug code.
Fixes: 102f4d900c9c8f5e ("FS-Cache: Handle a write to the page immediately beyond the EOF marker")
Handle a write being requested to the page immediately beyond the EOF
marker on a cache object. Currently this gets an assertion failure in
CacheFiles because the EOF marker is used there to encode information about
a partial page at the EOF - which could lead to an unknown blank spot in
the file if we extend the file over it.
The problem is actually in fscache where we check the index of the page
being written against store_limit. store_limit is set to the number of
pages that we're allowed to store by fscache_set_store_limit() - which
means it's one more than the index of the last page we're allowed to store.
The problem is that we permit writing to a page with an index _equal_ to
the store limit - when we should reject that case.
Whilst we're at it, change the triggered assertion in CacheFiles to just
return -ENOBUFS instead.
The assertion failure looks something like this:
CacheFiles: Assertion failed
1000 < 7b1 is false
kernel BUG at fs/cachefiles/rdwr.c:962!
RIP: 0010:[<ffffffffa02c9e83>] [<ffffffffa02c9e83>] cachefiles_write_page+0x273/0x2d0 [cachefiles]
Cc: stable@vger.kernel.org # v2.6.31+; earlier - that + backport of a17754f (at least)
cachefiles requires that s_blocksize in the cache is not greater than
PAGE_SIZE, and performs the check every time a block is accessed.
Move the test to the place where the file is "opened", where other
file-validity tests are performed.
Signed-off-by: NeilBrown <neilb@suse.de>
__GFP_WAIT was used to signal that the caller was in atomic context and
could not sleep. Now it is possible to distinguish between true atomic
context and callers that are not willing to sleep. The latter should
clear __GFP_DIRECT_RECLAIM so kswapd will still wake. As clearing
__GFP_WAIT behaves differently, there is a risk that people will clear the
wrong flags. This patch renames __GFP_WAIT to __GFP_RECLAIM to clearly
indicate what it does -- setting it allows all reclaim activity, clearing
them prevents it.
[akpm@linux-foundation.org: fix build]
Signed-off-by: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Vlastimil Babka <vbabka@suse.cz>
Cc: Christoph Lameter <cl@linux.com>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Vitaly Wool <vitalywool@gmail.com>
Cachefiles should perform fs modifications (eg. vfs_unlink()) on the top layer
only and should not attempt to alter the lower layer.
Count the number of objects that get culled by the cache backend and the
number of objects that the cache backend declines to instantiate due to lack
of space in the cache.
These numbers are made available through /proc/fs/fscache/stats
Acked-by: Jeff Layton <jeff.layton@primarydata.com>
Fix up the following scripted S_ISDIR/S_ISREG/S_ISLNK conversions (or lack
thereof) in cachefiles:
(1) Cachefiles mostly wants to use d_can_lookup() rather than d_is_dir() as
it doesn't want to deal with automounts in its cache.
(2) Coccinelle didn't find S_IS* expressions in ASSERT() statements in
cachefiles.
Convert the following where appropriate:
(1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry).
(2) S_ISREG(dentry->d_inode) to d_is_reg(dentry).
(3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more
complicated than it appears as some calls should be converted to
d_can_lookup() instead. The difference is whether the directory in
question is a real dir with a ->lookup op or whether it's a fake dir with
a ->d_automount op.
In some circumstances, we can subsume checks for dentry->d_inode not being
NULL into this, provided we the code isn't in a filesystem that expects
d_inode to be NULL if the dirent really *is* negative (ie. if we're going to
use d_inode() rather than d_backing_inode() to get the inode pointer).
Note that the dentry type field may be set to something other than
DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS
manages the fall-through from a negative dentry to a lower layer. In such a
case, the dentry type of the negative union dentry is set to the same as the
type of the lower dentry.
However, if you know d_inode is not NULL at the call site, then you can use
the d_is_xxx() functions even in a filesystem.
There is one further complication: a 0,0 chardev dentry may be labelled
DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was
intended for special directory entry types that don't have attached inodes.
The following perl+coccinelle script was used:
use strict;
my @callers;
open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') ||
die "Can't grep for S_ISDIR and co. callers";
@callers = <$fd>;
close($fd);
unless (@callers) {
print "No matches\n";
exit(0);
my @cocci = (
'expression E;',
'- S_ISLNK(E->d_inode->i_mode)',
'+ d_is_symlink(E)',
'expression E;',
'- S_ISDIR(E->d_inode->i_mode)',
'+ d_is_dir(E)',
'expression E;',
'- S_ISREG(E->d_inode->i_mode)',
'+ d_is_reg(E)' );
my $coccifile = "tmp.sp.cocci";
open($fd, ">$coccifile") || die $coccifile;
print($fd "$_\n") || die $coccifile foreach (@cocci);
close($fd);
foreach my $file (@callers) {
chomp $file;
print "Processing ", $file, "\n";
system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 ||
die "spatch failed";
[AV: overlayfs parts skipped]
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs
Pull fs-cache fixes from David Howells:
"Two fixes for bugs in CacheFiles and a cleanup in FS-Cache"
* tag 'fscache-fixes-20141013' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs:
fs/fscache/object-list.c: use __seq_open_private()
CacheFiles: Fix incorrect test for in-memory object collision
CacheFiles: Handle object being killed before being set up
When CacheFiles cache objects are in use, they have in-memory representations,
as defined by the cachefiles_object struct. These are kept in a tree rooted in
the cache and indexed by dentry pointer (since there's a unique mapping between
object index key and dentry).
Collisions can occur between a representation already in the tree and a new
representation being set up because it takes time to dispose of an old
representation - particularly if it must be unlinked or renamed.
When such a collision occurs, cachefiles_mark_object_active() is meant to check
to see if the old, already-present representation is in the process of being
discarded (ie. FSCACHE_OBJECT_IS_LIVE is not set on it) - and, if so, wait for
the representation to be removed (ie. CACHEFILES_OBJECT_ACTIVE is then
cleared).
However, the test for whether the old representation is still live is checking
the new object - which always will be live at this point. This leads to an
oops looking like:
CacheFiles: Error: Unexpected object collision
object: OBJ1b354
objstate=LOOK_UP_OBJECT fl=8 wbusy=2 ev=0[0]
ops=0 inp=0 exc=0
parent=ffff88053f5417c0
cookie=ffff880538f202a0 [pr=ffff8805381b7160 nd=ffff880509c6eb78 fl=27]
key=[8] '2490000000000000'
xobject: OBJ1a600
xobjstate=DROP_OBJECT fl=70 wbusy=2 ev=0[0]
xops=0 inp=0 exc=0
xparent=ffff88053f5417c0
xcookie=ffff88050f4cbf70 [pr=ffff8805381b7160 nd= (null) fl=12]
kernel BUG at fs/cachefiles/namei.c:200!
RIP: ... cachefiles_walk_to_object+0x7ea/0x860 [cachefiles]
Call Trace:
[<ffffffffa04dadd8>] ? cachefiles_lookup_object+0x58/0x100 [cachefiles]
[<ffffffffa01affe9>] ? fscache_look_up_object+0xb9/0x1d0 [fscache]
[<ffffffffa01afc4d>] ? fscache_parent_ready+0x2d/0x80 [fscache]
[<ffffffffa01b0672>] ? fscache_object_work_func+0x92/0x1f0 [fscache]
[<ffffffff8107e82b>] ? process_one_work+0x16b/0x400
[<ffffffff8107fc16>] ? worker_thread+0x116/0x380
[<ffffffff8107fb00>] ? manage_workers.isra.21+0x290/0x290
[<ffffffff81085edc>] ? kthread+0xbc/0xe0
[<ffffffff81085e20>] ? flush_kthread_worker+0x80/0x80
[<ffffffff81502d0c>] ? ret_from_fork+0x7c/0xb0
Reported-by: Manuel Schölling <manuel.schoelling@gmx.de>
Acked-by: Steve Dickson <steved@redhat.com>
If a cache object gets killed whilst in the process of being set up - for
instance if the netfs relinquishes the cookie that the object is associated
with - then the object's state machine will transit to the DROP_OBJECT state
without necessarily going through the LOOKUP_OBJECT or CREATE_OBJECT states.
This is a problem for CacheFiles because cachefiles_drop_object() assumes that
object->dentry will be set upon reaching the DROP_OBJECT state and has an
ASSERT() to that effect (see the oops below) - but object->dentry doesn't get
set until the LOOKUP_OBJECT or CREATE_OBJECT states (and not always then if
they fail).
To fix this, just make the dentry cleanup in cachefiles_drop_object()
conditional on the dentry actually being set and remove the assertion.
kernel BUG at .../fs/cachefiles/namei.c:425!
RIP: ... cachefiles_delete_object+0xcd/0x110 [cachefiles]
Call Trace:
[<ffffffffa043280f>] ? cachefiles_drop_object+0xff/0x130 [cachefiles]
[<ffffffffa02ac511>] ? fscache_drop_object+0xd1/0x1d0 [fscache]
[<ffffffffa02ac697>] ? fscache_object_work_func+0x87/0x210 [fscache]
[<ffffffff81080635>] ? process_one_work+0x155/0x450
[<ffffffff81081c44>] ? worker_thread+0x114/0x370
[<ffffffff81081b30>] ? manage_workers.isra.21+0x2c0/0x2c0
[<ffffffff81087fcc>] ? kthread+0xbc/0xe0
[<ffffffff81087f10>] ? flush_kthread_worker+0xa0/0xa0
[<ffffffff8150638c>] ? ret_from_fork+0x7c/0xb0
Commit 0227d6abb378 ("fs/cachefiles: replace kerror by pr_err") didn't
include newline featuring in original kerror definition
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Reported-by: David Howells <dhowells@redhat.com>
Cc: <stable@vger.kernel.org> [3.16.x]
Not all filesystems now provide the rename i_op - ext4 for one - but rather
provide the rename2 i_op. CacheFiles checks that the filesystem has rename
and so will reject ext4 now with EPERM:
CacheFiles: Failed to register: -1
Fix this by checking for rename2 as an alternative. The call to vfs_rename()
actually handles selection of the appropriate function, so we needn't worry
about that.
Turning on debugging shows:
[cachef] ==> cachefiles_get_directory(,,cache)
[cachef] subdir -> ffff88000b22b778 positive
[cachef] <== cachefiles_get_directory() = -1 [check]
where -1 is EPERM.
These two have been unused since
commit c4d6d8dbf335c7fa47341654a37c53a512b519bb
CacheFiles: Fix the marking of cached pages
in 3.8.
Also add pr_fmt in internal.h
Pull vfs updates from Al Viro:
"The first vfs pile, with deep apologies for being very late in this
window.
Assorted cleanups and fixes, plus a large preparatory part of iov_iter
work. There's a lot more of that, but it'll probably go into the next
merge window - it *does* shape up nicely, removes a lot of
boilerplate, gets rid of locking inconsistencie between aio_write and
splice_write and I hope to get Kent's direct-io rewrite merged into
the same queue, but some of the stuff after this point is having
(mostly trivial) conflicts with the things already merged into
mainline and with some I want more testing.
This one passes LTP and xfstests without regressions, in addition to
usual beating. BTW, readahead02 in ltp syscalls testsuite has started
giving failures since "mm/readahead.c: fix readahead failure for
memoryless NUMA nodes and limit readahead pages" - might be a false
positive, might be a real regression..."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
missing bits of "splice: fix racy pipe->buffers uses"
cifs: fix the race in cifs_writev()
ceph_sync_{,direct_}write: fix an oops on ceph_osdc_new_request() failure
kill generic_file_buffered_write()
ocfs2_file_aio_write(): switch to generic_perform_write()
ceph_aio_write(): switch to generic_perform_write()
xfs_file_buffered_aio_write(): switch to generic_perform_write()
export generic_perform_write(), start getting rid of generic_file_buffer_write()
generic_file_direct_write(): get rid of ppos argument
btrfs_file_aio_write(): get rid of ppos
kill the 5th argument of generic_file_buffered_write()
kill the 4th argument of __generic_file_aio_write()
lustre: don't open-code kernel_recvmsg()
ocfs2: don't open-code kernel_recvmsg()
drbd: don't open-code kernel_recvmsg()
constify blk_rq_map_user_iov() and friends
lustre: switch to kernel_sendmsg()
ocfs2: don't open-code kernel_sendmsg()
take iov_iter stuff to mm/iov_iter.c
process_vm_access: tidy up a bit
Pull renameat2 system call from Miklos Szeredi:
"This adds a new syscall, renameat2(), which is the same as renameat()
but with a flags argument.
The purpose of extending rename is to add cross-rename, a symmetric
variant of rename, which exchanges the two files. This allows
interesting things, which were not possible before, for example
atomically replacing a directory tree with a symlink, etc... This
also allows overlayfs and friends to operate on whiteouts atomically.
Andy Lutomirski also suggested a "noreplace" flag, which disables the
overwriting behavior of rename.
These two flags, RENAME_EXCHANGE and RENAME_NOREPLACE are only
implemented for ext4 as an example and for testing"
* 'cross-rename' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
ext4: add cross rename support
ext4: rename: split out helper functions
ext4: rename: move EMLINK check up
ext4: rename: create ext4_renament structure for local vars
vfs: add cross-rename
vfs: lock_two_nondirectories: allow directory args
security: add flags to rename hooks
vfs: add RENAME_NOREPLACE flag
vfs: add renameat2 syscall
vfs: rename: use common code for dir and non-dir
vfs: rename: move d_move() up
vfs: add d_is_dir()
This code used to have its own lru cache pagevec up until a0b8cab3 ("mm:
remove lru parameter from __pagevec_lru_add and remove parts of pagevec
API"). Now it's just add_to_page_cache() followed by lru_cache_add(),
might as well use add_to_page_cache_lru() directly.
Signed-off-by: Johannes Weiner <hannes@cmpxchg.org>
Reviewed-by: Minchan Kim <minchan@kernel.org>
Cc: Bob Liu <bob.liu@oracle.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Luigi Semenzato <semenzato@google.com>
Cc: Metin Doslu <metin@citusdata.com>
Cc: Michel Lespinasse <walken@google.com>
Cc: Ozgun Erdogan <ozgun@citusdata.com>
Cc: Roman Gushchin <klamm@yandex-team.ru>
Cc: Ryan Mallon <rmallon@gmail.com>
Cc: Tejun Heo <tj@kernel.org>
Add flags to security_path_rename() and security_inode_rename() hooks.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Reviewed-by: J. Bruce Fields <bfields@redhat.com>
