path: root/fs/ceph/Kconfig
2013-12-31ceph: add acl for cephfsGuangliang Zhao
Signed-off-by: Guangliang Zhao <lucienchao@gmail.com> Reviewed-by: Li Wang <li.wang@ubuntykylin.com> Reviewed-by: Zheng Yan <zheng.z.yan@intel.com>
2013-09-06ceph: use fscache as a local presisent cacheMilosz Tanski
Adding support for fscache to the Ceph filesystem. This would bring it to on par with some of the other network filesystems in Linux (like NFS, AFS, etc...) In order to mount the filesystem with fscache the 'fsc' mount option must be passed. Signed-off-by: Milosz Tanski <milosz@adfin.com> Signed-off-by: Sage Weil <sage@inktank.com>
2013-01-11fs/ceph: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Sage Weil <sage@inktank.com> Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Sage Weil <sage@inktank.com>
2010-10-20ceph: factor out libceph from Ceph file systemYehuda Sadeh
This factors out protocol and low-level storage parts of ceph into a separate libceph module living in net/ceph and include/linux/ceph. This is mostly a matter of moving files around. However, a few key pieces of the interface change as well: - ceph_client becomes ceph_fs_client and ceph_client, where the latter captures the mon and osd clients, and the fs_client gets the mds client and file system specific pieces. - Mount option parsing and debugfs setup is correspondingly broken into two pieces. - The mon client gets a generic handler callback for otherwise unknown messages (mds map, in this case). - The basic supported/required feature bits can be expanded (and are by ceph_fs_client). No functional change, aside from some subtle error handling cases that got cleaned up in the refactoring process. Signed-off-by: Sage Weil <sage@newdream.net>
2010-09-17ceph: select CRYPTOSage Weil
We select CRYPTO_AES, but not CRYPTO. Signed-off-by: Sage Weil <sage@newdream.net>
2010-07-24ceph: Correct obvious typo of Kconfig variable "CRYPTO_AES"Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Sage Weil <sage@newdream.net>
2010-02-10ceph: aes crypto and base64 encode/decode helpersSage Weil
Helpers to encrypt/decrypt AES and base64. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2009-10-06ceph: Kconfig, MakefileSage Weil
Kconfig options and Makefile. Signed-off-by: Sage Weil <sage@newdream.net>
