path: root/fs/ceph/Makefile
2011-01-12ceph: Makefile: Remove unnessary codeTracey Dent
Remove the if and else conditional because the code is in mainline and there is no need in it being there. Also, Changed Makefile to use <modules>-y instead of <modules>-objs because -objs is deprecated and not mentioned in Documentation/kbuild/makefiles.txt. Signed-off-by: Tracey Dent <tdent48227@gmail.com> Signed-off-by: Sage Weil <sage@newdream.net>
2010-10-20ceph: factor out libceph from Ceph file systemYehuda Sadeh
This factors out protocol and low-level storage parts of ceph into a separate libceph module living in net/ceph and include/linux/ceph. This is mostly a matter of moving files around. However, a few key pieces of the interface change as well: - ceph_client becomes ceph_fs_client and ceph_client, where the latter captures the mon and osd clients, and the fs_client gets the mds client and file system specific pieces. - Mount option parsing and debugfs setup is correspondingly broken into two pieces. - The mon client gets a generic handler callback for otherwise unknown messages (mds map, in this case). - The basic supported/required feature bits can be expanded (and are by ceph_fs_client). No functional change, aside from some subtle error handling cases that got cleaned up in the refactoring process. Signed-off-by: Sage Weil <sage@newdream.net>
2010-08-02ceph: add flock/fcntl lock supportGreg Farnum
Implement flock inode operation to support advisory file locking. All lock/unlock operations are synchronous with the MDS. Lock state is sent when reconnecting to a recovering MDS to restore the shared lock state. Signed-off-by: Greg Farnum <gregf@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2010-02-11ceph: add support for auth_x authentication protocolSage Weil
The auth_x protocol implements support for a kerberos-like mutual authentication infrastructure used by Ceph. We do not simply use vanilla kerberos because of scalability and performance issues when dealing with a large cluster of nodes providing a single logical service. Auth_x provides mutual authentication of client and server and protects against replay and man in the middle attacks. It does not encrypt the full session over the wire, however, so data payload may still be snooped. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2010-02-10ceph: aes crypto and base64 encode/decode helpersSage Weil
Helpers to encrypt/decrypt AES and base64. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2009-12-23ceph: support ceph_pagelist for message payloadSage Weil
The ceph_pagelist is a simple list of whole pages, strung together via their lru list_head. It facilitates encoding to a "buffer" of unknown size. Allow its use in place of the ceph_msg page vector. This will be used to fix the huge buffer preallocation woes of MDS reconnection. Signed-off-by: Sage Weil <sage@newdream.net>
2009-11-18ceph: negotiate authentication protocol; implement AUTH_NONE protocolSage Weil
When we open a monitor session, we send an initial AUTH message listing the auth protocols we support, our entity name, and (possibly) a previously assigned global_id. The monitor chooses a protocol and responds with an initial message. Initially implement AUTH_NONE, a dummy protocol that provides no security, but works within the new framework. It generates 'authorizers' that are used when connecting to (mds, osd) services that simply state our entity name and global_id. This is a wire protocol change. Signed-off-by: Sage Weil <sage@newdream.net>
2009-11-06ceph: make object hash a pg_pool propertySage Weil
The object will be hashed to a placement seed (ps) based on the pg_pool's hash function. This allows new hashes to be introduced into an existing object store, or selection of a hash appropriate to the objects that will be stored in a particular pool. Signed-off-by: Sage Weil <sage@newdream.net>
2009-11-06ceph: make CRUSH hash functions non-inlineSage Weil
These are way to big to be inline. I missed crush/* when doing the inline audit for akpm's review. Signed-off-by: Sage Weil <sage@newdream.net>
2009-10-06ceph: Kconfig, MakefileSage Weil
Kconfig options and Makefile. Signed-off-by: Sage Weil <sage@newdream.net>
