path: root/fs/ceph/mds_client.c
2011-07-16ceph analog of cifs build_path_from_dentry() race fixAl Viro
... unfortunately, cifs bug got copied. Fix is essentially the same. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-24ceph: fix cap flush race reentrancySage Weil
In e9964c10 we change cap flushing to do a delicate dance because some inodes on the cap_dirty list could be in a migrating state (got EXPORT but not IMPORT) in which we couldn't actually flush and move from dirty->flushing, breaking the while (!empty) { process first } loop structure. It worked for a single sync thread, but was not reentrant and triggered infinite loops when multiple syncers came along. Instead, move inodes with dirty to a separate cap_dirty_migrating list when in the limbo export-but-no-import state, allowing us to go back to the simple loop structure (which was reentrant). This is cleaner and more robust. Audited the cap_dirty users and this looks fine: list_empty(&ci->i_dirty_item) is still a reliable indicator of whether we have dirty caps (which list we're on is irrelevant) and list_del_init() calls still do the right thing. Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-19libceph: remove unused variableSage Weil
2011-05-19ceph: take reference on mds request r_unsafe_dirSage Weil
We put ourselves on an inode list for the parent directory of metadata operations so that an fsync on the directory will wait for metadata updates to commit to disk. We weren't holding a reference to that directory, however, and under certain workloads (fsstress in this case) the directory can go away. Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-11ceph: print debug message before put mds sessionHenry C Chang
The mds session, s, could be freed during ceph_put_mds_session. Move dout before ceph_put_mds_session. Signed-off-by: Henry C Chang <henry.cy.chang@gmail.com> Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-25ceph: flush msgr_wq during mds_client shutdownSage Weil
The release method for mds connections uses a backpointer to the mds_client, so we need to flush the workqueue of any pending work (and ceph_connection references) prior to freeing the mds_client. This fixes an oops easily triggered under UML by while true ; do mount ... ; umount ... ; done Also fix an outdated comment: the flush in ceph_destroy_client only flushes OSD connections out. This bug is basically an artifact of the ceph -> ceph+libceph conversion. Signed-off-by: Sage Weil <sage@newdream.net>
2011-01-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: avoid picking MDS that is not active ceph: avoid immediate cap check after import ceph: fix flushing of caps vs cap import ceph: fix erroneous cap flush to non-auth mds ceph: fix cap_wanted_delay_{min,max} mount option initialization ceph: fix xattr rbtree search ceph: fix getattr on directory when using norbytes
2011-01-25ceph: avoid picking MDS that is not activeSage Weil
Ignore replication or auth frag data if it indicates an MDS that is not active. This can happen if the MDS shuts down and the client has stale data about the namespace distribution across the MDS cluster. If that's the case, fall back to directing the request based on the auth cap (which should always be accurate). Signed-off-by: Sage Weil <sage@newdream.net>
2011-01-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: rbd: fix cleanup when trying to mount inexistent image net/ceph: make ceph_msgr_wq non-reentrant ceph: fsc->*_wq's aren't used in memory reclaim path ceph: Always free allocated memory in osdmap_decode() ceph: Makefile: Remove unnessary code ceph: associate requests with opening sessions ceph: drop redundant r_mds field ceph: implement DIRLAYOUTHASH feature to get dir layout from MDS ceph: add dir_layout to inode
2011-01-12ceph: associate requests with opening sessionsSage Weil
Associate request with sessions that aren't yep open. This makes the debugfs mdsc request list more informative. Signed-off-by: Sage Weil <sage@newdream.net>
2011-01-12ceph: drop redundant r_mds fieldSage Weil
The r_mds field is redundant, since we can find the same information at r_session->s_mds, and when r_session is NULL then r_mds is meaningless. Signed-off-by: Sage Weil <sage@newdream.net>
2011-01-12ceph: implement DIRLAYOUTHASH feature to get dir layout from MDSSage Weil
This implements the DIRLAYOUTHASH protocol feature, which passes the dir layout over the wire from the MDS. This gives the client knowledge of the correct hash function to use for mapping dentries among dir fragments. Note that if this feature is _not_ present on the client but is on the MDS, the client may misdirect requests. This will result in a forward and degrade performance. It may also result in inaccurate NFS filehandle generation, which will prevent fh resolution when the inode is not present in the client cache and the parent directories have been fragmented. Signed-off-by: Sage Weil <sage@newdream.net>
2011-01-07fs: dcache scale dentry refcountNick Piggin
Make d_count non-atomic and protect it with d_lock. This allows us to ensure a 0 refcount dentry remains 0 without dcache_lock. It is also fairly natural when we start protecting many other dentry members with d_lock. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-12-01ceph: Handle file locks in replies from the MDS.Herb Shiu
Previously the kernel client incorrectly assumed everything was a directory. Signed-off-by: Herb Shiu <herb_shiu@tcloudcomputing.com> Acked-by: Greg Farnum <gregf@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2010-11-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: fix readdir EOVERFLOW on 32-bit archs ceph: fix frag offset for non-leftmost frags ceph: fix dangling pointer ceph: explicitly specify page alignment in network messages ceph: make page alignment explicit in osd interface ceph: fix comment, remove extraneous args ceph: fix update of ctime from MDS ceph: fix version check on racing inode updates ceph: fix uid/gid on resent mds requests ceph: fix rdcache_gen usage and invalidate ceph: re-request max_size if cap auth changes ceph: only let auth caps update max_size ceph: fix open for write on clustered mds ceph: fix bad pointer dereference in ceph_fill_trace ceph: fix small seq message skipping Revert "ceph: update issue_seq on cap grant"
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-08ceph: fix uid/gid on resent mds requestsSage Weil
MDS requests can be rebuilt and resent in non-process context, but were filling in uid/gid from current_fsuid/gid. Put that information in the request struct on request setup. This fixes incorrect (and root) uid/gid getting set for requests that are forwarded between MDSs, usually due to metadata migrations. Signed-off-by: Sage Weil <sage@newdream.net>
2010-10-20ceph: switch from BKL to lock_flocks()Sage Weil
Switch from using the BKL explicitly to the new lock_flocks() interface. Eventually this will turn into a spinlock. Signed-off-by: Sage Weil <sage@newdream.net>
2010-10-20ceph: preallocate flock state without locks heldGreg Farnum
When the lock_kernel() turns into lock_flocks() and a spinlock, we won't be able to do allocations with the lock held. Preallocate space without the lock, and retry if the lock state changes out from underneath us. Signed-off-by: Greg Farnum <gregf@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2010-10-20ceph: factor out libceph from Ceph file systemYehuda Sadeh
This factors out protocol and low-level storage parts of ceph into a separate libceph module living in net/ceph and include/linux/ceph. This is mostly a matter of moving files around. However, a few key pieces of the interface change as well: - ceph_client becomes ceph_fs_client and ceph_client, where the latter captures the mon and osd clients, and the fs_client gets the mds client and file system specific pieces. - Mount option parsing and debugfs setup is correspondingly broken into two pieces. - The mon client gets a generic handler callback for otherwise unknown messages (mds map, in this case). - The basic supported/required feature bits can be expanded (and are by ceph_fs_client). No functional change, aside from some subtle error handling cases that got cleaned up in the refactoring process. Signed-off-by: Sage Weil <sage@newdream.net>
2010-09-11ceph: fix reconnect encoding for old serversSage Weil
Fix the reconnect encoding to encode the cap record when the MDS does not have the FLOCK capability (i.e., pre v0.22). Signed-off-by: Sage Weil <sage@newdream.net>
2010-08-26ceph: don't BUG on ENOMEM during mds reconnectSage Weil
We are in a position to return an error; do that instead. Signed-off-by: Sage Weil <sage@newdream.net>
2010-08-22ceph: direct requests in snapped namespace based on nonsnap parentSage Weil
When making a request in the virtual snapdir or a snapped portion of the namespace, we should choose the MDS based on the first nonsnap parent (and its caps). If that is not the best place, we will get forward hints to find the right MDS in the cluster. This fixes ESTALE errors when using the .snap directory and namespace with multiple MDSs. Signed-off-by: Sage Weil <sage@newdream.net>
2010-08-22ceph: fix multiple mds session shutdownSage Weil
The use of a completion when waiting for session shutdown during umount is inappropriate, given the complexity of the condition. For multiple MDS's, this resulted in the umount thread spinning, often preventing the session close message from being processed in some cases. Switch to a waitqueue and defined a condition helper. This cleans things up nicely. Signed-off-by: Sage Weil <sage@newdream.net>
2010-08-03ceph: whitespace cleanupSage Weil
2010-08-02ceph: add flock/fcntl lock supportGreg Farnum
Implement flock inode operation to support advisory file locking. All lock/unlock operations are synchronous with the MDS. Lock state is sent when reconnecting to a recovering MDS to restore the shared lock state. Signed-off-by: Greg Farnum <gregf@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2010-08-02ceph: support v2 reconnect encodingSage Weil
Encode either old or v2 encoding of client_reconnect message, depending on whether the peer has the FLOCK feature bit. Signed-off-by: Sage Weil <sage@newdream.net>
2010-08-01ceph: handle ESTALE properly; on receipt send to authority if it wasn'tGreg Farnum
2010-08-01ceph: connect to export targets on cap exportSage Weil
When we get a cap EXPORT message, make sure we are connected to all export targets to ensure we can handle the matching IMPORT. Signed-off-by: Sage Weil <sage@newdream.net>
2010-08-01ceph: connect to export targets if mds is laggySage Weil
If an MDS we are talking to may have failed, we need to open sessions to its potential export targets to ensure that any in-progress migration that may have involved some of our caps is properly handled. Signed-off-by: Sage Weil <sage@newdream.net>
2010-08-01ceph: introduce helper to connect to mds export targetsSage Weil
There are a few cases where we need to open sessions with a given mds's potential export targets. Signed-off-by: Sage Weil <sage@newdream.net>
2010-08-01ceph: do caps accounting per mds_clientYehuda Sadeh
Caps related accounting is now being done per mds client instead of just being global. This prepares ground work for a later revision of the caps preallocated reservation list. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2010-08-01ceph: track laggy state of mds from mdsmapSage Weil
2010-08-01ceph: simplify add_cap_releasesSage Weil
No functional change, aside from more useful debug output. Signed-off-by: Sage Weil <sage@newdream.net>
2010-08-01ceph: drop unused argumentSage Weil
2010-07-27ceph: use complete_all and wake_up_allYehuda Sadeh
This fixes an issue triggered by running concurrent syncs. One of the syncs would go through while the other would just hang indefinitely. In any case, we never actually want to wake a single waiter, so the *_all functions should be used. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2010-07-16ceph: do not include cap/dentry releases in replayed messagesSage Weil
Strip the cap and dentry releases from replayed messages. They can cause the shared state to get out of sync because they were generated (with the request message) earlier, and no longer reflect the current client state. Signed-off-by: Sage Weil <sage@newdream.net>
2010-07-16ceph: reuse request message when replaying against recovering mdsSage Weil
Replayed rename operations (after an mds failure/recovery) were broken because the request paths were regenerated from the dentry names, which get mangled when d_move() is called. Instead, resend the previous request message when replaying completed operations. Just make sure the REPLAY flag is set and the target ino is filled in. This fixes problems with workloads doing renames when the MDS restarts, where the rename operation appears to succeed, but on mds restart then fails (leading to client confusion, app breakage, etc.). Signed-off-by: Sage Weil <sage@newdream.net>
2010-06-21ceph: delay umount until all mds requests drop inode+dentry refsSage Weil
This fixes a race between handle_reply finishing an mds request, signalling completion, and then dropping the request structing and its dentry+inode refs, and pre_umount function waiting for requests to finish before letting the vfs tear down the dcache. If umount was delayed waiting for mds requests, we could race and BUG in shrink_dcache_for_umount_subtree because of a slow dput. This delays umount until the msgr queue flushes, which means handle_reply will exit and will have dropped the ceph_mds_request struct. I'm assuming the VFS has already ensured that its calls have all completed and those request refs have thus been dropped as well (I haven't seen that race, at least). Signed-off-by: Sage Weil <sage@newdream.net>
2010-06-10ceph: try to send partial cap release on cap message on missing inodeSage Weil
If we have enough memory to allocate a new cap release message, do so, so that we can send a partial release message immediately. This keeps us from making the MDS wait when the cap release it needs is in a partially full release message. If we fail because of ENOMEM, oh well, they'll just have to wait a bit longer. Signed-off-by: Sage Weil <sage@newdream.net>
2010-06-10ceph: release cap on import if we don't have the inodeSage Weil
If we get an IMPORT that give us a cap, but we don't have the inode, queue a release (and try to send it immediately) so that the MDS doesn't get stuck waiting for us. Signed-off-by: Sage Weil <sage@newdream.net>
2010-06-04ceph: fix lease revocation when seq doesn't matchSage Weil
If the client revokes a lease with a higher seq than what we have, keep the mds's seq, so that it honors our release. Otherwise, we can hang indefinitely. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-29ceph: clean up on forwarded aborted mds requestSage Weil
If an mds request is aborted (timeout, SIGKILL), it is left registered to keep our state in sync with the mds. If we get a forward notification, though, we know the request didn't succeed and we can unregister it safely. We were trying to resend it, but then bailing out (and not unregistering) in __do_request. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-29ceph: make lease code DN specificSage Weil
The lease code includes a mask in the CEPH_LOCK_* namespace, but that namespace is changing, and only one mask (formerly _DN == 1) is used, so hard code for that value for now. If we ever extend this code to handle leases over different data types we can extend it accordingly. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-29ceph: make mds requests killable, not interruptibleSage Weil
The underlying problem is that many mds requests can't be restarted. For example, a restarted create() would return -EEXIST if the original request succeeds. However, we do not want a hung MDS to hang the client too. So, use the _killable wait_for_completion variants to abort on SIGKILL but nothing else. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-21ceph: Storage class should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: all allocation functions should get gfp_maskYehuda Sadeh
This is essential, as for the rados block device we'll need to run in different contexts that would need flags that are other than GFP_NOFS. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: use common helper for aborted dir request invalidationSage Weil
We invalidate I_COMPLETE and dentry leases in two places: on aborted mds request and on request replay. Use common helper to avoid duplicate code. Signed-off-by: Sage Weil <sage@newdream.net>
2010-05-17ceph: cope with out of order (unsafe after safe) mds replySage Weil
2010-05-17ceph: throw out dirty caps metadata, data on session teardownSage Weil
The remove_session_caps() helper is called when an MDS closes out our session (either normally, or as a result of a failed reconnect), and when we tear down state for umount. If we remove the last cap, and there are no cap migrations in progress, then there is little hope of us flushing out that data to the mds (without heroic efforts to reconnect and flush). So, to avoid leaving inodes pinned (due to dirty state) and crashing after umount, throw out dirty caps state and unpin the inodes. Print a warning to the console so we know something was lost. NOTE: Although we drop wrbuffer refs, we don't actually mark pages clean; maybe a truncate should be queued? Signed-off-by: Sage Weil <sage@newdream.net>
