GFP_NOFS memory allocation is required for page writeback path.
But there is no need to use GFP_NOFS in syscall path and readpage
path
Signed-off-by: Yan, Zheng <zyan@redhat.com>
if flushing caps were revoked, we should re-send the cap flush in
client reconnect stage. This guarantees that MDS processes the cap
flush message before issuing the flushing caps to other client.
So we know TID of the oldest pending caps flushing. Later patch will
send this information to MDS, so that MDS can trim its completed caps
flush list.
Tracking pending caps flushing globally also simplifies syncfs code.
Previously we do not trace accurate TID for flushing caps. when
MDS failovers, we have no choice but to re-send all flushing caps
with a new TID. This can cause problem because MDS can has already
flushed some caps and has issued the same caps to other client.
The re-sent cap flush has a new TID, which makes MDS unable to
detect if it has already processed the cap flush.
This patch adds code to track pending caps flushing accurately.
When re-sending cap flush is needed, we use its original flush
TID.
No need to bifurcate wait now that we've got ceph_timeout_jiffies().
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Reviewed-by: Alex Elder <elder@linaro.org>
Reviewed-by: Yan, Zheng <zyan@redhat.com>
There are currently three libceph-level timeouts that the user can
specify on mount: mount_timeout, osd_idle_ttl and osdkeepalive. All of
these are in seconds and no checking is done on user input: negative
values are accepted, we multiply them all by HZ which may or may not
overflow, arbitrarily large jiffies then get added together, etc.
There is also a bug in the way mount_timeout=0 is handled. It's
supposed to mean "infinite timeout", but that's not how wait.h APIs
treat it and so __ceph_open_session() for example will busy loop
without much chance of being interrupted if none of ceph-mons are
there.
Fix all this by verifying user input, storing timeouts capped by
msecs_to_jiffies() in jiffies and using the new ceph_timeout_jiffies()
helper for all user-specified waits to handle infinite timeouts
correctly.
setfilelock requests can block for a long time, which can prevent
client from advancing its oldest tid.
Previously we pre-allocate cap release messages for each caps. This
wastes lots of memory when there are large amount of caps. This patch
make the code not pre-allocate the cap release messages. Instead,
we add the corresponding ceph_cap struct to a list when releasing a
cap. Later when flush cap releases is needed, we allocate the cap
release messages dynamically.
Pull fourth vfs update from Al Viro:
"d_inode() annotations from David Howells (sat in for-next since before
the beginning of merge window) + four assorted fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
RCU pathwalk breakage when running into a symlink overmounting something
fix I_DIO_WAKEUP definition
direct-io: only inc/dec inode->i_dio_count for file systems
fs/9p: fix readdir()
VFS: assorted d_backing_inode() annotations
VFS: fs/inode.c helpers: d_inode() annotations
VFS: fs/cachefiles: d_backing_inode() annotations
VFS: fs library helpers: d_inode() annotations
VFS: assorted weird filesystems: d_inode() annotations
VFS: normal filesystems (and lustre): d_inode() annotations
VFS: security/: d_inode() annotations
VFS: security/: d_backing_inode() annotations
VFS: net/: d_inode() annotations
VFS: net/unix: d_backing_inode() annotations
VFS: kernel/: d_inode() annotations
VFS: audit: d_backing_inode() annotations
VFS: Fix up some ->d_inode accesses in the chelsio driver
VFS: Cachefiles should perform fs modifications on the top layer only
VFS: AF_UNIX sockets should call mknod on the top layer only
sb->s_root can be null when umounting
remove_session_caps_cb() does not truncate dirty data in page
cache, but zeros i_wrbuffer_ref/i_wrbuffer_ref_head. This will
result negtive i_wrbuffer_ref/i_wrbuffer_ref_head
No i_auth_cap means reconnecting to MDS was denied. So don't
add new dirty caps.
This is only an API consolidation and should make things more readable
it replaces var * HZ / 1000 by msecs_to_jiffies(var).
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
These cap releases are stale because MDS will re-establish client
caps according to the cap reconnect messages.
Note: MDS can detect stale cap messages, so these stale cap
releases are harmless even we don't drop them.
that's the bulk of filesystem drivers dealing with inodes of their own
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
Pull Ceph changes from Sage Weil:
"On the RBD side, there is a conversion to blk-mq from Christoph,
several long-standing bug fixes from Ilya, and some cleanup from
Rickard Strandqvist.
On the CephFS side there is a long list of fixes from Zheng, including
improved session handling, a few IO path fixes, some dcache management
correctness fixes, and several blocking while !TASK_RUNNING fixes.
The core code gets a few cleanups and Chaitanya has added support for
TCP_NODELAY (which has been used on the server side for ages but we
somehow missed on the kernel client).
There is also an update to MAINTAINERS to fix up some email addresses
and reflect that Ilya and Zheng are doing most of the maintenance for
RBD and CephFS these days. Do not be surprised to see a pull request
come from one of them in the future if I am unavailable for some
reason"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (27 commits)
MAINTAINERS: update Ceph and RBD maintainers
libceph: kfree() in put_osd() shouldn't depend on authorizer
libceph: fix double __remove_osd() problem
rbd: convert to blk-mq
ceph: return error for traceless reply race
ceph: fix dentry leaks
ceph: re-send requests when MDS enters reconnecting stage
ceph: show nocephx_require_signatures and notcp_nodelay options
libceph: tcp_nodelay support
rbd: do not treat standalone as flatten
ceph: fix atomic_open snapdir
ceph: properly mark empty directory as complete
client: include kernel version in client metadata
ceph: provide seperate {inode,file}_operations for snapdir
ceph: fix request time stamp encoding
ceph: fix reading inline data when i_size > PAGE_SIZE
ceph: avoid block operation when !TASK_RUNNING (ceph_mdsc_close_sessions)
ceph: avoid block operation when !TASK_RUNNING (ceph_get_caps)
ceph: avoid block operation when !TASK_RUNNING (ceph_mdsc_sync)
rbd: fix error paths in rbd_dev_refresh()
So that MDS can check if any request is already completed and process
completed requests in clientreplay stage. When completed requests are
processed in clientreplay stage, MDS can avoid sending traceless
replies.
struct timespec uses 'long' to present second and nanosecond. 'long'
is 64 bits on 64bits machine. ceph MDS expects time stamp to be
encoded as struct ceph_timespec, which uses 'u32' to present second
and nanosecond.
use an atomic variable to track number of sessions, this can avoid block
operation inside wait loops.
check_cap_flush() calls mutex_lock(), which may block. So we can't
use it as condition check function for wait_event();
When snaprealm is created, its initial reference count is zero.
But in some rare cases, the newly created snaprealm is not referenced
by anyone. This causes snaprealm with zero reference count not freed.
The fix is set reference count of newly snaprealm to 1. The reference
is return the function who requests to create the snaprealm. When the
function finishes its job, it releases the reference.
mark session as readonly and wake up all cap waiters.
There is only a single call site for each of these functions, and the
caller takes the i_lock prior to calling them and drops it just
afterward. Move the spinlocking into the functions instead.
Signed-off-by: Jeff Layton <jlayton@primarydata.com>
Acked-by: Christoph Hellwig <hch@lst.de>
There were two places we were assigning version in host byte order
instead of network byte order.
Also in MSG_CLIENT_SESSION we weren't setting compat_version in the
header to reflect continued compatability with older MDSs.
Fixes: http://tracker.ceph.com/issues/9945
Signed-off-by: John Spray <john.spray@redhat.com>
Reviewed-by: Sage Weil <sage@redhat.com>
The functions ceph_put_snap_context() and iput() test whether their
argument is NULL and then return immediately. Thus the test around the
call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
[idryomov@redhat.com: squashed rbd.c hunk, changelog]
Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
When a lock operation is interrupted, current code sends a unlock request to
MDS to undo the lock operation. This method does not work as expected because
the unlock request can drop locks that have already been acquired.
The fix is use the newly introduced CEPH_LOCK_FCNTL_INTR/CEPH_LOCK_FLOCK_INTR
requests to interrupt blocked file lock request. These requests do not drop
locks that have alread been acquired, they only interrupt blocked file lock
request.
...so that it can be used from the ceph debugfs
code when dumping session info.
Current code uses page array to present MDS request data. Pages in the
array are allocated/freed by caller of ceph_mdsc_do_request(). If request
is interrupted, the pages can be freed while they are still being used by
the request message.
The fix is use pagelist to present MDS request data. Pagelist is
reference counted.
this allow pagelist to present data that may be sent multiple times.
Implement version 2 of CEPH_MSG_CLIENT_SESSION syntax,
which includes additional client metadata to allow
the MDS to report on clients by user-sensible names
like hostname.
ceph_find_inode() may wait on freeing inode, using it inside the s_mutex
may cause deadlock. (the freeing inode is waiting for OSD read reply, but
dispatch thread is blocked by the s_mutex)
we may corrupt waiting list if a request in the waiting list is kicked.
So the recovering MDS does not need to fetch these ununsed inodes during
cache rejoin. This may reduce MDS recovery time.
__do_request() may unregister the request. So we should update
iterator 'p' before calling __do_request()
Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com>
this makes __choose_mds() choose mds according caps
Pull Ceph updates from Sage Weil:
"This has a mix of bug fixes and cleanups.
Alex's patch fixes a rare race in RBD. Ilya's patches fix an ENOENT
check when a second rbd image is mapped and a couple memory leaks.
Zheng fixes several issues with fragmented directories and multiple
MDSs. Josh fixes a spin/sleep issue, and Josh and Guangliang's
patches fix setting and unsetting RBD images read-only.
Naturally there are several other cleanups mixed in for good measure"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (23 commits)
rbd: only set disk to read-only once
rbd: move calls that may sleep out of spin lock range
rbd: add ioctl for rbd
ceph: use truncate_pagecache() instead of truncate_inode_pages()
ceph: include time stamp in every MDS request
rbd: fix ida/idr memory leak
rbd: use reference counts for image requests
rbd: fix osd_request memory leak in __rbd_dev_header_watch_sync()
rbd: make sure we have latest osdmap on 'rbd map'
libceph: add ceph_monc_wait_osdmap()
libceph: mon_get_version request infrastructure
libceph: recognize poolop requests in debugfs
ceph: refactor readpage_nounlock() to make the logic clearer
mds: check cap ID when handling cap export message
ceph: remember subtree root dirfrag's auth MDS
ceph: introduce ceph_fill_fragtree()
ceph: handle cap import atomically
ceph: pre-allocate ceph_cap struct for ceph_add_cap()
ceph: update inode fields according to issued caps
rbd: replace IS_ERR and PTR_ERR with PTR_ERR_OR_ZERO
Update the last pr_warning callsites in fs branch
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Cc: Sage Weil <sage@inktank.com>
We recently modified the client/MDS protocol to include a timestamp in the
client request. This allows ctime updates to follow the client's clock
in most cases, which avoids subtle problems when clocks are out of sync
and timestamps are updated sometimes by the MDS clock (for most requests)
and sometimes by the client clock (for cap writeback).
Signed-off-by: Sage Weil <sage@inktank.com>
