commit c213b50b7dcbf06abcfbf1e4eee5b76586718bd9 upstream.
This patch makes the following improvements to the error handling
in the ceph_mdsmap_decode function:
- Add a NULL check for return value from kcalloc
- Make use of the variable err
Signed-off-by: Emil Goode <emilgoode@gmail.com>
Signed-off-by: Sage Weil <sage@inktank.com>
We don't need to use up entropy to choose an mds,
so use prandom_u32() to get a pseudo-random number.
Also, we don't need to choose a random mds if only
one mds is available, so add special casing for the
common case.
Fixes http://tracker.ceph.com/issues/3579
Signed-off-by: Sam Lang <sam.lang@inktank.com>
Reviewed-by: Greg Farnum <greg@inktank.com>
Reviewed-by: Alex Elder <elder@inktank.com>
Support (and require) the PGID64, PGPOOL3, and OSDENC protocol features.
These have been present in ceph.git since v0.42, Feb 2012. Require these
features to simplify support; nobody is running older userspace.
Note that the new request and reply encoding is still not in place, so the new
code is not yet functional.
This factors out protocol and low-level storage parts of ceph into a
separate libceph module living in net/ceph and include/linux/ceph. This
is mostly a matter of moving files around. However, a few key pieces
of the interface change as well:
- ceph_client becomes ceph_fs_client and ceph_client, where the latter
captures the mon and osd clients, and the fs_client gets the mds client
and file system specific pieces.
- Mount option parsing and debugfs setup is correspondingly broken into
two pieces.
- The mon client gets a generic handler callback for otherwise unknown
messages (mds map, in this case).
- The basic supported/required feature bits can be expanded (and are by
ceph_fs_client).
No functional change, aside from some subtle error handling cases that got
cleaned up in the refactoring process.
Signed-off-by: Sage Weil <sage@newdream.net>
Also, print fsid using standard format, NOT hex dump.
The mds map now uses the global_id as the 'key' (instead of the addr,
which was a poor choice).
This is protocol change.
We exchange struct ceph_entity_addr over the wire and store it on disk.
The sockaddr_storage.ss_family field, however, is host endianness. So,
fix ss_family endianness to big endian when sending/receiving over the
wire.
This avoids the fugly pass by reference and makes the code a bit easier
to read.
A misplaced sizeof() around namelen was throwing things off.
The MDS (metadata server) client is responsible for submitting
requests to the MDS cluster and parsing the response. We decide which
MDS to submit each request to based on cached information about the
current partition of the directory hierarchy across the cluster. A
stateful session is opened with each MDS before we submit requests to
it, and a mutex is used to control the ordering of messages within
each session.
An MDS request may generate two responses. The first indicates the
operation was a success and returns any result. A second reply is
sent when the operation commits to disk. Note that locking on the MDS
ensures that the results of updates are visible only to the updating
client before the operation commits. Requests are linked to the
containing directory so that an fsync will wait for them to commit.
If an MDS fails and/or recovers, we resubmit requests as needed. We
also reconnect existing capabilities to a recovering MDS to
reestablish that shared session state. Old dentry leases are
invalidated.
