[ Upstream commit eeca958dce0a9231d1969f86196653eb50fcc9b3 ]
The ceph_inode_xattr needs to be released when removing an xattr. Easily
reproducible running the 'generic/020' test from xfstests or simply by
doing:
attr -s attr0 -V 0 /mnt/test && attr -r attr0 /mnt/test
While there, also fix the error path.
Here's the kmemleak splat:
unreferenced object 0xffff88001f86fbc0 (size 64):
comm "attr", pid 244, jiffies 4294904246 (age 98.464s)
hex dump (first 32 bytes):
40 fa 86 1f 00 88 ff ff 80 32 38 1f 00 88 ff ff @........28.....
00 01 00 00 00 00 ad de 00 02 00 00 00 00 ad de ................
backtrace:
[<ffffffff81560199>] kmemleak_alloc+0x49/0xa0
[<ffffffff810f3e5b>] kmem_cache_alloc+0x9b/0xf0
[<ffffffff812b157e>] __ceph_setxattr+0x17e/0x820
[<ffffffff812b1c57>] ceph_set_xattr_handler+0x37/0x40
[<ffffffff8111fb4b>] __vfs_removexattr+0x4b/0x60
[<ffffffff8111fd37>] vfs_removexattr+0x77/0xd0
[<ffffffff8111fdd1>] removexattr+0x41/0x60
[<ffffffff8111fe65>] path_removexattr+0x75/0xa0
[<ffffffff81120aeb>] SyS_lremovexattr+0xb/0x10
[<ffffffff81564b20>] entry_SYSCALL_64_fastpath+0x13/0x94
[<ffffffffffffffff>] 0xffffffffffffffff
Cc: stable@vger.kernel.org
Signed-off-by: Luis Henriques <lhenriques@suse.com>
Reviewed-by: "Yan, Zheng" <zyan@redhat.com>
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
Pull fourth vfs update from Al Viro:
"d_inode() annotations from David Howells (sat in for-next since before
the beginning of merge window) + four assorted fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
RCU pathwalk breakage when running into a symlink overmounting something
fix I_DIO_WAKEUP definition
direct-io: only inc/dec inode->i_dio_count for file systems
fs/9p: fix readdir()
VFS: assorted d_backing_inode() annotations
VFS: fs/inode.c helpers: d_inode() annotations
VFS: fs/cachefiles: d_backing_inode() annotations
VFS: fs library helpers: d_inode() annotations
VFS: assorted weird filesystems: d_inode() annotations
VFS: normal filesystems (and lustre): d_inode() annotations
VFS: security/: d_inode() annotations
VFS: security/: d_backing_inode() annotations
VFS: net/: d_inode() annotations
VFS: net/unix: d_backing_inode() annotations
VFS: kernel/: d_inode() annotations
VFS: audit: d_backing_inode() annotations
VFS: Fix up some ->d_inode accesses in the chelsio driver
VFS: Cachefiles should perform fs modifications on the top layer only
VFS: AF_UNIX sockets should call mknod on the top layer only
Currently, there is no check for the kstrdup() for r_path2,
r_path1 and snapdir_name as various locations as there is a
possibility of failure during memory pressure. Therefore,
returning ENOMEM where the checks have been missed.
Signed-off-by: Sanidhya Kashyap <sanidhya.gatech@gmail.com>
Signed-off-by: Yan, Zheng <zyan@redhat.com>
that's the bulk of filesystem drivers dealing with inodes of their own
make sure 'value' is not null. otherwise __ceph_setxattr will remove
the extended attribute.
Reviewed-by: Sage Weil <sage@redhat.com>
Current code uses page array to present MDS request data. Pages in the
array are allocated/freed by caller of ceph_mdsc_do_request(). If request
is interrupted, the pages can be freed while they are still being used by
the request message.
The fix is use pagelist to present MDS request data. Pagelist is
reference counted.
only regular file and directory have vxattrs.
Following sequence of events can happen.
- Client releases an inode, queues cap release message.
- A 'lookup' reply brings the same inode back, but the reply
doesn't contain xattrs because MDS didn't receive the cap release
message and thought client already has up-to-data xattrs.
The fix is force sending a getattr request to MDS if xattrs_version
is 0. The getattr mask is set to CEPH_STAT_CAP_XATTR, so MDS knows client
does not have xattr.
struct ceph_xattr -> struct ceph_inode_xattr
Reported-by: Toralf Förster <toralf.foerster@gmx.de>
Signed-off-by: Ilya Dryomov <ilya.dryomov@inktank.com>
Reviewed-by: Alex Elder <elder@linaro.org>
xattrs array of pointers is allocated with kcalloc() - no need to
memset() it to 0 right after that.
This avoids 'cp -a' modifying layout of new files/directories.
Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com>
If buffer size is zero, return the size of layout vxattr. If buffer
size is not zero, check if it is large enough for layout vxattr.
The fsync(dirfd) only covers namespace operations, not inode updates.
We do not need to cover setattr variants or O_TRUNC.
Reported-by: Al Viro <viro@xeniv.linux.org.uk>
Signed-off-by: Sage Weil <sage@inktank.com>
Reviewed-by: Yan, Zheng <zheng.z.yan@intel.com>
For the setxattr request, introduce a new flag CEPH_XATTR_REMOVE
to distinguish null value case from the zero-length value case.
return -EEXIST if XATTR_CREATE is set and xattr alread exists.
return -ENODATA if XATTR_REPLACE is set but xattr does not exist.
The previous ceph-client merge resulted in ceph not even building,
because there was a merge conflict that wasn't visible as an actual data
conflict: commit 7221fe4c2ed7 ("ceph: add acl for cephfs") added support
for POSIX ACL's into Ceph, but unluckily we also had the VFS tree change
a lot of the POSIX ACL helper functions to be much more helpful to
filesystems (see for example commits 2aeccbe957d0 "fs: add generic
xattr_acl handlers", 5bf3258fd2ac "fs: make posix_acl_chmod more useful"
and 37bc15392a23 "fs: make posix_acl_create more useful")
The reason this conflict wasn't obvious was many-fold: because it was a
semantic conflict rather than a data conflict, it wasn't visible in the
git merge as a conflict. And because the VFS tree hadn't been in
linux-next, people hadn't become aware of it that way. And because I
was at jury duty this morning, I was using my laptop and as a result not
doing constant "allmodconfig" builds.
Anyway, this fixes the build and generally removes a fair chunk of the
Ceph POSIX ACL support code, since the improved helpers seem to match
really well for Ceph too. But I don't actually have any way to *test*
the end result, and I was really hoping for some ACK's for this. Oh,
well.
Not compiling certainly doesn't make things easier to test, so I'm
committing this without the acks after having waited for four hours...
Plus it's what I would have done for the merge had I noticed the
semantic conflict..
Reported-by: Dave Jones <davej@redhat.com>
Cc: Sage Weil <sage@inktank.com>
Cc: Guangliang Zhao <lucienchao@gmail.com>
Cc: Li Wang <li.wang@ubuntykylin.com>
Signed-off-by: Guangliang Zhao <lucienchao@gmail.com>
Reviewed-by: Li Wang <li.wang@ubuntykylin.com>
Reviewed-by: Zheng Yan <zheng.z.yan@intel.com>
[ 1121.231883] BUG: sleeping function called from invalid context at kernel/rwsem.c:20
[ 1121.231935] in_atomic(): 1, irqs_disabled(): 0, pid: 9831, name: mv
[ 1121.231971] 1 lock held by mv/9831:
[ 1121.231973] #0: (&(&ci->i_ceph_lock)->rlock){+.+...},at:[<ffffffffa02bbd38>] ceph_getxattr+0x58/0x1d0 [ceph]
[ 1121.231998] CPU: 3 PID: 9831 Comm: mv Not tainted 3.10.0-rc6+ #215
[ 1121.232000] Hardware name: To Be Filled By O.E.M. To Be Filled By
O.E.M./To be filled by O.E.M., BIOS 080015 11/09/2011
[ 1121.232027] ffff88006d355a80 ffff880092f69ce0 ffffffff8168348c ffff880092f69cf8
[ 1121.232045] ffffffff81070435 ffff88006d355a20 ffff880092f69d20 ffffffff816899ba
[ 1121.232052] 0000000300000004 ffff8800b76911d0 ffff88006d355a20 ffff880092f69d68
[ 1121.232056] Call Trace:
[ 1121.232062] [<ffffffff8168348c>] dump_stack+0x19/0x1b
[ 1121.232067] [<ffffffff81070435>] __might_sleep+0xe5/0x110
[ 1121.232071] [<ffffffff816899ba>] down_read+0x2a/0x98
[ 1121.232080] [<ffffffffa02baf70>] ceph_vxattrcb_layout+0x60/0xf0 [ceph]
[ 1121.232088] [<ffffffffa02bbd7f>] ceph_getxattr+0x9f/0x1d0 [ceph]
[ 1121.232093] [<ffffffff81188d28>] vfs_getxattr+0xa8/0xd0
[ 1121.232097] [<ffffffff8118900b>] getxattr+0xab/0x1c0
[ 1121.232100] [<ffffffff811704f2>] ? final_putname+0x22/0x50
[ 1121.232104] [<ffffffff81155f80>] ? kmem_cache_free+0xb0/0x260
[ 1121.232107] [<ffffffff811704f2>] ? final_putname+0x22/0x50
[ 1121.232110] [<ffffffff8109e63d>] ? trace_hardirqs_on+0xd/0x10
[ 1121.232114] [<ffffffff816957a7>] ? sysret_check+0x1b/0x56
[ 1121.232120] [<ffffffff81189c9c>] SyS_fgetxattr+0x6c/0xc0
[ 1121.232125] [<ffffffff81695782>] system_call_fastpath+0x16/0x1b
[ 1121.232129] BUG: scheduling while atomic: mv/9831/0x10000002
[ 1121.232154] 1 lock held by mv/9831:
[ 1121.232156] #0: (&(&ci->i_ceph_lock)->rlock){+.+...}, at:
I think move the ci->i_ceph_lock down is safe because we can't free
ceph_inode_info at there.
CC: stable@vger.kernel.org # 3.8+
Signed-off-by: Jianpeng Ma <majianpeng@gmail.com>
Reviewed-by: Sage Weil <sage@inktank.com>
Fix the causes for sparse warnings reported in the ceph file system
code. Here there are only two (and they're sort of silly but
they're easy to fix).
This partially resolves:
http://tracker.ceph.com/issues/4184
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Alex Elder <elder@inktank.com>
Reviewed-by: Josh Durgin <josh.durgin@inktank.com>
Allow individual fields of the layout to be fetched via getxattr.
The ceph.dir.layout.* vxattr with "disappear" if the exists_cb
indicates there no dir layout set.
Reviewed-by: Sam Lang <sam.lang@inktank.com>
This virtual xattr will only appear when there is a dir layout policy
set on the directory. It can be set via setxattr and removed via
removexattr (implemented by the MDS).
Implement a new method to generate the ceph.file.layout vxattr using
the new framework.
Use 'stripe_unit' instead of 'chunk_size'.
Include pool name, either as a string or as an integer.
Only include vxattrs in the result if they are not hidden and exist
(as determined by the exists_cb callback).
Note that the buffer size we return when 0 is passed in always includes
vxattrs that *might* exist, forming an upper bound.
Change the vxattr handling for getxattr so that vxattrs are checked
prior to any xattr content, and never after. Enforce vxattr existence
via the exists_cb callback.
Allow for a callback to dynamically determine if a vxattr exists for
the given inode.
If we do not explicitly recognized a vxattr (e.g., as readonly), pass
the request through to the MDS and deal with it there.
If we do not specifically understand a setxattr on a ceph.* virtual
xattr, send it through to the MDS. This allows us to implement new
functionality via the MDS without direct support on the client side.
Add ability to flag virtual xattrs as hidden, such that you can
getxattr them but they do not appear in listxattr.
This has been deprecated since v3.3, 114fc474. Kill it.
We re-run the loop but we don't re-set the attrs pointer back to NULL.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Reviewed-by: Alex Elder <elder@inktank.com>
This was an ill-conceived feature that has been removed from Ceph. Do
this gracefully:
- reject attempts to specify a preferred_osd via the ioctl
- stop exposing this information via virtual xattrs
- always fill in -1 for requests, in case we talk to an older server
- don't calculate preferred_osd placements/pgids
In ceph_vxattrcb_file_layout(), there is a check to determine
whether a preferred PG should be formatted into the output buffer.
That check assumes that a preferred PG number of 0 indicates "no
preference," but that is wrong. No preference is indicated by a
negative (specifically, -1) PG number.
In addition, if that condition yields true, the preferred value
is formatted into a sized buffer, but the size consumed by the
earlier snprintf() call is not accounted for, opening up the
possibilty of a buffer overrun.
Finally, in ceph_vxattrcb_dir_rctime() where the nanoseconds part of
the time displayed did not include leading 0's, which led to
erroneous (sub-second portion of) time values being shown.
This fixes these three issues:
http://tracker.newdream.net/issues/2155
http://tracker.newdream.net/issues/2156
http://tracker.newdream.net/issues/2157
Signed-off-by: Alex Elder <elder@dreamhost.com>
Reviewed-by: Sage Weil <sage@newdream.net>
This patch just rearranges a few bits of code to make more
portions of ceph_setxattr() and ceph_removexattr() identical.
Signed-off-by: Sage Weil <sage@newdream.net>
All names defined in the directory and file virtual extended
attribute tables are constant, and the size of each is known at
compile time. So there's no need to compute their length every
time any file's attribute is listed.
Record the length of each string and use it when needed to determine
the space need to represent them. In addition, compute the
aggregate size of strings in each table just once at initialization
time.
The names of the callback functions used for virtual extended
attributes are based only on the last component of the attribute
name. Because of the way these are defined, this precludes allowing
a single (lowest) attribute name for different callbacks, dependent
on the type of file being operated on. (For example, it might be
nice to support both "ceph.dir.layout" and "ceph.file.layout".)
Just change the callback names to avoid this problem.
A struct ceph_vxattr_cb does not represent a callback at all, but
rather a virtual extended attribute itself. Drop the "_cb" suffix
from its name to reflect that.
Entries in the ceph virtual extended attribute tables all follow a
distinct pattern in their definition. Enforce this pattern through
the use of a macro.
Also, a null name field signals the end of the table, so make that
be the first field in the ceph_vxattr_cb structure.
Use symbolic constants to define the top-level prefix for "ceph."
extended attribute names.
All callers of ceph_match_vxattr() determine what to pass as the
first argument by calling ceph_inode_vxattrs(inode). Just do that
inside ceph_match_vxattr() itself, changing it to take an inode
rather than the vxattr pointer as its first argument.
Also ensure the function works correctly for an empty table (i.e.,
containing only a terminating null entry).
For some reason, ceph_setxattr() allocates an extra byte in which a
'\0' is stored past the end of an extended attribute value. This is
not needed, and is potentially misleading, so get rid of it.
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
rbd: fix safety of rbd_put_client()
rbd: fix a memory leak in rbd_get_client()
ceph: create a new session lock to avoid lock inversion
ceph: fix length validation in parse_reply_info()
ceph: initialize client debugfs outside of monc->mutex
ceph: change "ceph.layout" xattr to be "ceph.file.layout"
The virtual extended attribute named "ceph.layout" is meaningful
only for regular files. Change its name to be "ceph.file.layout" to
more directly reflect that in the ceph xattr namespace. Preserve
the old "ceph.layout" name for the time being (until we decide it's
safe to get rid of it entirely).
Add a missing initializer for "readonly" in the terminating entry.
In __ceph_build_xattrs_blob(), if a ceph inode's extended attributes
are marked dirty, all attributes recorded in its rb_tree index are
formatted into a "blob" buffer. The target buffer is recorded in
ceph_inode->i_xattrs.prealloc_blob, and it is expected to exist and
be of sufficient size to hold the attributes.
The extended attributes are marked dirty in two cases: when a new
attribute is added to the inode; or when one is removed. In the
former case work is done to ensure the prealloc_blob buffer is
properly set up, but in the latter it is not.
Change the logic in ceph_removexattr() so it matches what is
done in ceph_setxattr(). Note that this is done in a way that
keeps the two blocks of code nearly identical, in anticipation
of a subsequent patch that encapsulates some of this logic into
one or more helper routines.
We have been using i_lock to protect all kinds of data structures in the
ceph_inode_info struct, including lists of inodes that we need to iterate
over while avoiding races with inode destruction. That requires grabbing
a reference to the inode with the list lock protected, but igrab() now
takes i_lock to check the inode flags.
Changing the list lock ordering would be a painful process.
However, using a ceph-specific i_ceph_lock in the ceph inode instead of
i_lock is a simple mechanical change and avoids the ordering constraints
imposed by igrab().
Reported-by: Amon Ott <a.ott@m-privacy.de>
d_parent is protected by d_lock: use it when looking up a dentry's parent
directory inode. Also take a reference and drop it in the caller to avoid
a use-after-free.
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Reviewed-by: Yehuda Sadeh <yehuda@hq.newdream.net>
We should use ihold whenever we already have a stable inode ref, even
when we aren't holding i_lock. This avoids adding new and unnecessary
locking dependencies.
The __mark_dirty_inode helper now takes i_lock as of 250df6ed. Fix the
one ceph callers that held i_lock (__ceph_mark_dirty_caps) to return the
flags value so that the callers can do it outside of i_lock.
Fix xattr name comparison in rbtree search for strings that share a prefix.
The *name argument is null terminated, but the xattr name is not, so we
need to use strncmp, but that means adjusting for the case where name is
a prefix of xattr->name.
The corresponding case in __set_xattr() already handles this properly
(although in that case *name is also not null terminated).
Reported-by: Sergiy Kibrik <sakib@meta.ua>
Convert a sequence of kmalloc and memcpy to use kmemdup.
The semantic patch that performs this transformation is:
(http://coccinelle.lip6.fr/)
// <smpl>
expression a,flag,len;
expression arg,e1,e2;
statement S;
a =
- \(kmalloc\|kzalloc\)(len,flag)
+ kmemdup(arg,len,flag)
<... when != a
if (a == NULL || ...) S
- memcpy(a,arg,len+1);
// </smpl>
