path: root/fs/ceph
2015-09-21fs: create and use seq_show_option for escapingKees Cook
commit a068acf2ee77693e0bf39d6e07139ba704f461c3 upstream. Many file systems that implement the show_options hook fail to correctly escape their output which could lead to unescaped characters (e.g. new lines) leaking into /proc/mounts and /proc/[pid]/mountinfo files. This could lead to confusion, spoofed entries (resulting in things like systemd issuing false d-bus "mount" notifications), and who knows what else. This looks like it would only be the root user stepping on themselves, but it's possible weird things could happen in containers or in other situations with delegated mount privileges. Here's an example using overlay with setuid fusermount trusting the contents of /proc/mounts (via the /etc/mtab symlink). Imagine the use of "sudo" is something more sneaky: $ BASE="ovl" $ MNT="$BASE/mnt" $ LOW="$BASE/lower" $ UP="$BASE/upper" $ WORK="$BASE/work/ 0 0 none /proc fuse.pwn user_id=1000" $ mkdir -p "$LOW" "$UP" "$WORK" $ sudo mount -t overlay -o "lowerdir=$LOW,upperdir=$UP,workdir=$WORK" none /mnt $ cat /proc/mounts none /root/ovl/mnt overlay rw,relatime,lowerdir=ovl/lower,upperdir=ovl/upper,workdir=ovl/work/ 0 0 none /proc fuse.pwn user_id=1000 0 0 $ fusermount -u /proc $ cat /proc/mounts cat: /proc/mounts: No such file or directory This fixes the problem by adding new seq_show_option and seq_show_option_n helpers, and updating the vulnerable show_option handlers to use them as needed. Some, like SELinux, need to be open coded due to unusual existing escape mechanisms. [akpm@linux-foundation.org: add lost chunk, per Kees] [keescook@chromium.org: seq_show_option should be using const parameters] Signed-off-by: Kees Cook <keescook@chromium.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Jan Kara <jack@suse.com> Acked-by: Paul Moore <paul@paul-moore.com> Cc: J. R. Okajima <hooanon05g@gmail.com> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-04-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull fourth vfs update from Al Viro: "d_inode() annotations from David Howells (sat in for-next since before the beginning of merge window) + four assorted fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: RCU pathwalk breakage when running into a symlink overmounting something fix I_DIO_WAKEUP definition direct-io: only inc/dec inode->i_dio_count for file systems fs/9p: fix readdir() VFS: assorted d_backing_inode() annotations VFS: fs/inode.c helpers: d_inode() annotations VFS: fs/cachefiles: d_backing_inode() annotations VFS: fs library helpers: d_inode() annotations VFS: assorted weird filesystems: d_inode() annotations VFS: normal filesystems (and lustre): d_inode() annotations VFS: security/: d_inode() annotations VFS: security/: d_backing_inode() annotations VFS: net/: d_inode() annotations VFS: net/unix: d_backing_inode() annotations VFS: kernel/: d_inode() annotations VFS: audit: d_backing_inode() annotations VFS: Fix up some ->d_inode accesses in the chelsio driver VFS: Cachefiles should perform fs modifications on the top layer only VFS: AF_UNIX sockets should call mknod on the top layer only
2015-04-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull Ceph updates from Sage Weil: "This time around we have a collection of CephFS fixes from Zheng around MDS failure handling and snapshots, support for a new CRUSH straw2 algorithm (to sync up with userspace) and several RBD cleanups and fixes from Ilya, an error path leak fix from Taesoo, and then an assorted collection of cleanups from others" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (28 commits) rbd: rbd_wq comment is obsolete libceph: announce support for straw2 buckets crush: straw2 bucket type with an efficient 64-bit crush_ln() crush: ensuring at most num-rep osds are selected crush: drop unnecessary include from mapper.c ceph: fix uninline data function ceph: rename snapshot support ceph: fix null pointer dereference in send_mds_reconnect() ceph: hold on to exclusive caps on complete directories libceph: simplify our debugfs attr macro ceph: show non-default options only libceph: expose client options through debugfs libceph, ceph: split ceph_show_options() rbd: mark block queue as non-rotational libceph: don't overwrite specific con error msgs ceph: cleanup unsafe requests when reconnecting is denied ceph: don't zero i_wrbuffer_ref when reconnecting is denied ceph: don't mark dirty caps when there is no auth cap ceph: keep i_snap_realm while there are writers libceph: osdmap.h: Add missing format newlines ...
2015-04-22ceph: fix uninline data functionYan, Zheng
For CEPH_OSD_CMPXATTR_MODE_U64, OSD expects the u64 to be encoded as string in object's xattr. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-04-22ceph: rename snapshot supportYan, Zheng
2015-04-22ceph: fix null pointer dereference in send_mds_reconnect()Yan, Zheng
sb->s_root can be null when umounting Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-04-20ceph: hold on to exclusive caps on complete directoriesYan, Zheng
If a directory is complete, we want to keep the exclusive cap. So that MDS does not end up revoking the shared cap on every create/unlink operation. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-04-20ceph: show non-default options onlyIlya Dryomov
Don't pollute /proc/mounts with default options (presently these are dcache, nofsc and acl). Leave the acl/noacl however - it's a bit of a special case due to CONFIG_CEPH_FS_POSIX_ACL. Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2015-04-20libceph, ceph: split ceph_show_options()Ilya Dryomov
Split ceph_show_options() into two pieces and move the piece responsible for printing client (libceph) options into net/ceph. This way people adding a libceph option wouldn't have to remember to update code in fs/ceph. Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2015-04-20ceph: cleanup unsafe requests when reconnecting is deniedYan, Zheng
2015-04-20ceph: don't zero i_wrbuffer_ref when reconnecting is deniedYan, Zheng
remove_session_caps_cb() does not truncate dirty data in page cache, but zeros i_wrbuffer_ref/i_wrbuffer_ref_head. This will result negtive i_wrbuffer_ref/i_wrbuffer_ref_head Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-04-20ceph: don't mark dirty caps when there is no auth capYan, Zheng
No i_auth_cap means reconnecting to MDS was denied. So don't add new dirty caps. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-04-20ceph: keep i_snap_realm while there are writersYan, Zheng
when reconnecting to MDS is denied, we remove session caps forcibly. But it's possible there are ongoing write, the write code needs to reference i_snap_realm. So if there are ongoing write, we keep i_snap_realm. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-04-20ceph: kstrdup() memory handlingSanidhya Kashyap
Currently, there is no check for the kstrdup() for r_path2, r_path1 and snapdir_name as various locations as there is a possibility of failure during memory pressure. Therefore, returning ENOMEM where the checks have been missed. Signed-off-by: Sanidhya Kashyap <sanidhya.gatech@gmail.com> Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-04-20ceph: properly release page upon errorTaesoo Kim
When ceph_update_writeable_page fails (including -EAGAIN), it unlocks (w/ unlock_page) the page but does not 'release' (w/ page_cache_release) properly. Upon error, properly set *pagep to NULL, indicating an error. Signed-off-by: Taesoo Kim <tsgatesv@gmail.com> Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-04-20ceph: match wait_for_completion_timeout return typeNicholas Mc Guire
return type of wait_for_completion_timeout is unsigned long not int. An appropriately named unsigned long is added and the assignment fixed up. Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org> Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-04-20ceph: use msecs_to_jiffies for time conversionNicholas Mc Guire
This is only an API consolidation and should make things more readable it replaces var * HZ / 1000 by msecs_to_jiffies(var). Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org> Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-04-20ceph: remove redundant declarationFabian Frederick
ceph_aops was already defined extern in addr.c section Signed-off-by: Fabian Frederick <fabf@skynet.be> Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-04-20ceph: fix dcache/nocache mount optionYan, Zheng
2015-04-20ceph: drop cap releases in requests composed before cap reconnectYan, Zheng
These cap releases are stale because MDS will re-establish client caps according to the cap reconnect messages. Note: MDS can detect stale cap messages, so these stale cap releases are harmless even we don't drop them. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11mirror O_APPEND and O_DIRECT into iocb->ki_flagsAl Viro
... avoiding write_iter/fcntl races. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11switch generic_write_checks() to iocb and iterAl Viro
... returning -E... upon error and amount of data left in iter after (possible) truncation upon success. Note, that normal case gives a non-zero (positive) return value, so any tests for != 0 _must_ be updated. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Conflicts: fs/ext4/file.c
2015-04-11generic_write_checks(): drop isblk argumentAl Viro
all remaining callers are passing 0; some just obscure that fact. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11direct_IO: remove rw from a_ops->direct_IO()Omar Sandoval
Now that no one is using rw, remove it completely. Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11make new_sync_{read,write}() staticAl Viro
All places outside of core VFS that checked ->read and ->write for being NULL or called the methods directly are gone now, so NULL {read,write} with non-NULL {read,write}_iter will do the right thing in all cases. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11Merge branch 'iocb' into for-nextAl Viro
2015-03-25fs: move struct kiocb to fs.hChristoph Hellwig
struct kiocb now is a generic I/O container, so move it to fs.h. Also do a #include diet for aio.h while we're at it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-03-12fs: remove ki_nbytesChristoph Hellwig
There is no need to pass the total request length in the kiocb, as we already get passed in through the iov_iter argument. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-22Merge branch 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted stuff from this cycle. The big ones here are multilayer overlayfs from Miklos and beginning of sorting ->d_inode accesses out from David" * 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (51 commits) autofs4 copy_dev_ioctl(): keep the value of ->size we'd used for allocation procfs: fix race between symlink removals and traversals debugfs: leave freeing a symlink body until inode eviction Documentation/filesystems/Locking: ->get_sb() is long gone trylock_super(): replacement for grab_super_passive() fanotify: Fix up scripted S_ISDIR/S_ISREG/S_ISLNK conversions Cachefiles: Fix up scripted S_ISDIR/S_ISREG/S_ISLNK conversions VFS: (Scripted) Convert S_ISLNK/DIR/REG(dentry->d_inode) to d_is_*(dentry) SELinux: Use d_is_positive() rather than testing dentry->d_inode Smack: Use d_is_positive() rather than testing dentry->d_inode TOMOYO: Use d_is_dir() rather than d_inode and S_ISDIR() Apparmor: Use d_is_positive/negative() rather than testing dentry->d_inode Apparmor: mediated_filesystem() should use dentry->d_sb not inode->i_sb VFS: Split DCACHE_FILE_TYPE into regular and special types VFS: Add a fallthrough flag for marking virtual dentries VFS: Add a whiteout dentry type VFS: Introduce inode-getting helpers for layered/unioned fs environments Infiniband: Fix potential NULL d_inode dereference posix_acl: fix reference leaks in posix_acl_create autofs4: Wrong format for printing dentry ...
2015-02-22VFS: (Scripted) Convert S_ISLNK/DIR/REG(dentry->d_inode) to d_is_*(dentry)David Howells
Convert the following where appropriate: (1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry). (2) S_ISREG(dentry->d_inode) to d_is_reg(dentry). (3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more complicated than it appears as some calls should be converted to d_can_lookup() instead. The difference is whether the directory in question is a real dir with a ->lookup op or whether it's a fake dir with a ->d_automount op. In some circumstances, we can subsume checks for dentry->d_inode not being NULL into this, provided we the code isn't in a filesystem that expects d_inode to be NULL if the dirent really *is* negative (ie. if we're going to use d_inode() rather than d_backing_inode() to get the inode pointer). Note that the dentry type field may be set to something other than DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS manages the fall-through from a negative dentry to a lower layer. In such a case, the dentry type of the negative union dentry is set to the same as the type of the lower dentry. However, if you know d_inode is not NULL at the call site, then you can use the d_is_xxx() functions even in a filesystem. There is one further complication: a 0,0 chardev dentry may be labelled DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was intended for special directory entry types that don't have attached inodes. The following perl+coccinelle script was used: use strict; my @callers; open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') || die "Can't grep for S_ISDIR and co. callers"; @callers = <$fd>; close($fd); unless (@callers) { print "No matches\n"; exit(0); } my @cocci = ( '@@', 'expression E;', '@@', '', '- S_ISLNK(E->d_inode->i_mode)', '+ d_is_symlink(E)', '', '@@', 'expression E;', '@@', '', '- S_ISDIR(E->d_inode->i_mode)', '+ d_is_dir(E)', '', '@@', 'expression E;', '@@', '', '- S_ISREG(E->d_inode->i_mode)', '+ d_is_reg(E)' ); my $coccifile = "tmp.sp.cocci"; open($fd, ">$coccifile") || die $coccifile; print($fd "$_\n") || die $coccifile foreach (@cocci); close($fd); foreach my $file (@callers) { chomp $file; print "Processing ", $file, "\n"; system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 || die "spatch failed"; } [AV: overlayfs parts skipped] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull Ceph changes from Sage Weil: "On the RBD side, there is a conversion to blk-mq from Christoph, several long-standing bug fixes from Ilya, and some cleanup from Rickard Strandqvist. On the CephFS side there is a long list of fixes from Zheng, including improved session handling, a few IO path fixes, some dcache management correctness fixes, and several blocking while !TASK_RUNNING fixes. The core code gets a few cleanups and Chaitanya has added support for TCP_NODELAY (which has been used on the server side for ages but we somehow missed on the kernel client). There is also an update to MAINTAINERS to fix up some email addresses and reflect that Ilya and Zheng are doing most of the maintenance for RBD and CephFS these days. Do not be surprised to see a pull request come from one of them in the future if I am unavailable for some reason" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (27 commits) MAINTAINERS: update Ceph and RBD maintainers libceph: kfree() in put_osd() shouldn't depend on authorizer libceph: fix double __remove_osd() problem rbd: convert to blk-mq ceph: return error for traceless reply race ceph: fix dentry leaks ceph: re-send requests when MDS enters reconnecting stage ceph: show nocephx_require_signatures and notcp_nodelay options libceph: tcp_nodelay support rbd: do not treat standalone as flatten ceph: fix atomic_open snapdir ceph: properly mark empty directory as complete client: include kernel version in client metadata ceph: provide seperate {inode,file}_operations for snapdir ceph: fix request time stamp encoding ceph: fix reading inline data when i_size > PAGE_SIZE ceph: avoid block operation when !TASK_RUNNING (ceph_mdsc_close_sessions) ceph: avoid block operation when !TASK_RUNNING (ceph_get_caps) ceph: avoid block operation when !TASK_RUNNING (ceph_mdsc_sync) rbd: fix error paths in rbd_dev_refresh() ...
2015-02-19ceph: return error for traceless reply raceYan, Zheng
When we receives traceless reply for request that created new inode, we re-send a lookup request to MDS get information of the newly created inode. (VFS expects FS' callback return an inode in create case) This breaks one request into two requests. Other client may modify or move to the new inode in the middle. When the race happens, ceph_handle_notrace_create() unconditionally links the dentry for 'create' operation to the inode returned by lookup. This may confuse VFS when the inode is a directory (VFS does not allow multiple linkages for directory inode). This patch makes ceph_handle_notrace_create() when it detect a race. This event should be rare and it happens only when we talk to old MDS. Recent MDS does not send traceless reply for request that creates new inode. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-02-19ceph: fix dentry leaksYan, Zheng
2015-02-19ceph: re-send requests when MDS enters reconnecting stageYan, Zheng
So that MDS can check if any request is already completed and process completed requests in clientreplay stage. When completed requests are processed in clientreplay stage, MDS can avoid sending traceless replies. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-02-19ceph: show nocephx_require_signatures and notcp_nodelay optionsIlya Dryomov
Signed-off-by: Ilya Dryomov <idryomov@redhat.com>
2015-02-19ceph: fix atomic_open snapdirYan, Zheng
ceph_handle_snapdir() checks ceph_mdsc_do_request()'s return value and creates snapdir inode if it's -ENOENT Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-02-19ceph: properly mark empty directory as completeYan, Zheng
ceph_add_cap() calls __check_cap_issue(), which clears directory inode' complete flag. so we should set the complete flag for empty directory should be set after calling ceph_add_cap(). Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-02-19client: include kernel version in client metadataYan, Zheng
2015-02-19ceph: provide seperate {inode,file}_operations for snapdirYan, Zheng
remove all unsupported operations from {inode,file}_operations. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-02-19ceph: fix request time stamp encodingYan, Zheng
struct timespec uses 'long' to present second and nanosecond. 'long' is 64 bits on 64bits machine. ceph MDS expects time stamp to be encoded as struct ceph_timespec, which uses 'u32' to present second and nanosecond. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-02-19ceph: fix reading inline data when i_size > PAGE_SIZEYan, Zheng
when inode has inline data but its size > PAGE_SIZE (it was truncated to larger size), previous direct read code return -EIO. This patch adds code to return zeros for data whose offset > PAGE_SIZE. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-02-19ceph: avoid block operation when !TASK_RUNNING (ceph_mdsc_close_sessions)Yan, Zheng
use an atomic variable to track number of sessions, this can avoid block operation inside wait loops. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-02-19ceph: avoid block operation when !TASK_RUNNING (ceph_get_caps)Yan, Zheng
we should not do block operation in wait_event_interruptible()'s condition check function, but reading inline data can block. so move the read inline data code to ceph_get_caps() Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-02-19ceph: avoid block operation when !TASK_RUNNING (ceph_mdsc_sync)Yan, Zheng
check_cap_flush() calls mutex_lock(), which may block. So we can't use it as condition check function for wait_event(); Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-02-19ceph: improve reference tracking for snaprealmYan, Zheng
When snaprealm is created, its initial reference count is zero. But in some rare cases, the newly created snaprealm is not referenced by anyone. This causes snaprealm with zero reference count not freed. The fix is set reference count of newly snaprealm to 1. The reference is return the function who requests to create the snaprealm. When the function finishes its job, it releases the reference. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-02-19ceph: properly zero data pages for file holes.Yan, Zheng
A bug is found in striped_read() of fs/ceph/file.c. striped_read() calls ceph_zero_pape_vector_range(). The first argument, page_align + read + ret, passed to ceph_zero_pape_vector_range() is wrong. When a file has holes, this wrong parameter may cause memory corruption either in kernal space or user space. Kernel space memory may be corrupted in the case of non direct IO; user space memory may be corrupted in the case of direct IO. In the latter case, the application doing direct IO may crash due to memory corruption, as we have experienced. The correct value should be initial_align + read + ret, where intial_align = o_direct ? buf_align : io_align. Compared with page_align, the current page offest, initial_align is the initial page offest, which should be used to calculate the page and offset in ceph_zero_pape_vector_range(). Reported-by: caifeng zhu <zhucaifeng@unissoft-nj.com> Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-02-19ceph: acl: Remove unused functionRickard Strandqvist
Remove the function ceph_get_cached_acl() that is not used anywhere. This was partially found by using a static code analysis program called cppcheck. Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se> Reviewed-by: Yan, Zheng <zyan@redhat.com>
2015-02-19ceph: handle SESSION_FORCE_RO messageYan, Zheng
mark session as readonly and wake up all cap waiters. Signed-off-by: Yan, Zheng <zyan@redhat.com>
2015-02-16Revert "locks: keep a count of locks on the flctx lists"Jeff Layton
This reverts commit 9bd0f45b7037fcfa8b575c7e27d0431d6e6dc3bb. Linus rightly pointed out that I failed to initialize the counters when adding them, so they don't work as expected. Just revert this patch for now. Reported-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
