path: root/fs/ceph
2012-10-21tmpfs,ceph,gfs2,isofs,reiserfs,xfs: fix fh_len checkingHugh Dickins
commit 35c2a7f4908d404c9124c2efc6ada4640ca4d5d5 upstream. Fuzzing with trinity oopsed on the 1st instruction of shmem_fh_to_dentry(), u64 inum = fid->raw[2]; which is unhelpfully reported as at the end of shmem_alloc_inode(): BUG: unable to handle kernel paging request at ffff880061cd3000 IP: [<ffffffff812190d0>] shmem_alloc_inode+0x40/0x40 Oops: 0000 [#1] PREEMPT SMP DEBUG_PAGEALLOC Call Trace: [<ffffffff81488649>] ? exportfs_decode_fh+0x79/0x2d0 [<ffffffff812d77c3>] do_handle_open+0x163/0x2c0 [<ffffffff812d792c>] sys_open_by_handle_at+0xc/0x10 [<ffffffff83a5f3f8>] tracesys+0xe1/0xe6 Right, tmpfs is being stupid to access fid->raw[2] before validating that fh_len includes it: the buffer kmalloc'ed by do_sys_name_to_handle() may fall at the end of a page, and the next page not be present. But some other filesystems (ceph, gfs2, isofs, reiserfs, xfs) are being careless about fh_len too, in fh_to_dentry() and/or fh_to_parent(), and could oops in the same way: add the missing fh_len checks to those. Reported-by: Sasha Levin <levinsasha928@gmail.com> Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Sage Weil <sage@inktank.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2011-07-16ceph analog of cifs build_path_from_dentry() race fixAl Viro
... unfortunately, cifs bug got copied. Fix is essentially the same. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-06-13ceph: fix sync and dio writes across stripe boundariesSage Weil
We were iterating across stripe boundaries properly, but not moving the write buffer pointer forward. This caused us to rewrite the same data after the break. Fix by adjusting the data pointer forward, and recalculating the io and buffer alignment after the break. Signed-off-by: Sage Weil <sage@newdream.net>
2011-06-13ceph: fix page alignment correctionsSage Weil
dd if=/dev/urandom of=/mnt/fs_depot/dd10 bs=500 seek=8388 count=1 dd if=/mnt/fs_depot/dd10 of=/root/dd10out bs=500 skip=8388 count=1 Reported-by: Henry C Chang <henry.cy.chang@gmail.com> Signed-off-by: Sage Weil <sage@newdream.net>
2011-06-07ceph: unwind canceled flock stateSage Weil
If we request a lock and then abort (e.g., ^C), we need to send a matching unlock request to the MDS to unwind our lock attempt to avoid indefinitely blocking other clients. Reported-by: Brian Chrisman <brchrisman@gmail.com> Signed-off-by: Sage Weil <sage@newdream.net>
2011-06-07ceph: fix ENOENT logic in striped_readSage Weil
Getting ENOENT is equivalent to reading 0 bytes. Make that correction before setting up the hit_stripe and was_short flags. Fixes the following case: dd if=/dev/zero of=/mnt/fs_depot/dd3 bs=1 seek=1048576 count=0 dd if=/mnt/fs_depot/dd3 of=/root/ddout1 skip=8 bs=500 count=2 iflag=direct Reported-by: Henry C Chang <henry.cy.chang@gmail.com> Signed-off-by: Sage Weil <sage@newdream.net>
2011-06-07ceph: fix short sync reads from the OSDSage Weil
If we get a short read from the OSD because the object is small, we need to zero the remainder of the buffer. For O_DIRECT reads, the attempted range is not trimmed to i_size by the VFS, so we were actually looping indefinitely. Fix by trimming by i_size, and the unconditionally zeroing the trailing range. Reported-by: Jeff Wu <cpwu@tnsoft.com.cn> Signed-off-by: Sage Weil <sage@newdream.net>
2011-06-07ceph: use ihold when we already have an inode refSage Weil
We should use ihold whenever we already have a stable inode ref, even when we aren't holding i_lock. This avoids adding new and unnecessary locking dependencies. Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-24ceph: fix cap flush race reentrancySage Weil
In e9964c10 we change cap flushing to do a delicate dance because some inodes on the cap_dirty list could be in a migrating state (got EXPORT but not IMPORT) in which we couldn't actually flush and move from dirty->flushing, breaking the while (!empty) { process first } loop structure. It worked for a single sync thread, but was not reentrant and triggered infinite loops when multiple syncers came along. Instead, move inodes with dirty to a separate cap_dirty_migrating list when in the limbo export-but-no-import state, allowing us to go back to the simple loop structure (which was reentrant). This is cleaner and more robust. Audited the cap_dirty users and this looks fine: list_empty(&ci->i_dirty_item) is still a reliable indicator of whether we have dirty caps (which list we're on is irrelevant) and list_del_init() calls still do the right thing. Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-24ceph: avoid inode lookup on nfs fh reconnectSage Weil
If we get the inode from the MDS, we have a reference in req; don't do a fresh lookup. Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-24ceph: use LOOKUPINO to make unconnected nfs fh more reliableSage Weil
If we are unable to locate an inode by ino, ask the MDS using the new LOOKUPINO command. Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-19ceph: check return value for start_request in writepagesSage Weil
Since we pass the nofail arg, we should never get an error; BUG if we do. (And fix the function to not return an error if __map_request fails.) Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-19ceph: remove useless checkSage Weil
rc is only ever 0 or negative in this method. Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-19ceph: fix broken comparison in readdir loopSage Weil
Both off and fi->offset are unsigned, so the difference is always >= 0. Compare them directly instead of the sign of the difference. Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-19ceph: fix rare potential cap leakSage Weil
If we grab new_cap, retake the lock, and find we already have a cap now for the given mds, release new_cap. Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-19ceph: use snprintf for dirstat contentSage Weil
We allocate a buffer for rstats if the dirstat option is enabled. Use snprintf. Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-19libceph: remove unused variableSage Weil
2011-05-19ceph: take reference on mds request r_unsafe_dirSage Weil
We put ourselves on an inode list for the parent directory of metadata operations so that an fsync on the directory will wait for metadata updates to commit to disk. We weren't holding a reference to that directory, however, and under certain workloads (fsstress in this case) the directory can go away. Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-11ceph: do not use i_wrbuffer_ref as refcount for Fb capHenry C Chang
We increments i_wrbuffer_ref when taking the Fb cap. This breaks the dirty page accounting and causes looping in __ceph_do_pending_vmtruncate, and ceph client hangs. This bug can be reproduced occasionally by running blogbench. Add a new field i_wb_ref to inode and dedicate it to Fb reference counting. Signed-off-by: Henry C Chang <henry.cy.chang@gmail.com> Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-11ceph: fix list_add in ceph_put_snap_realmHenry C Chang
2011-05-11ceph: print debug message before put mds sessionHenry C Chang
The mds session, s, could be freed during ceph_put_mds_session. Move dout before ceph_put_mds_session. Signed-off-by: Henry C Chang <henry.cy.chang@gmail.com> Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-04ceph: do not call __mark_dirty_inode under i_lockSage Weil
The __mark_dirty_inode helper now takes i_lock as of 250df6ed. Fix the one ceph callers that held i_lock (__ceph_mark_dirty_caps) to return the flags value so that the callers can do it outside of i_lock. Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-03ceph: handle ceph_osdc_new_request failure in ceph_writepages_startHenry C Chang
We should unlock the page and return -ENOMEM if ceph_osdc_new_request failed. Signed-off-by: Henry C Chang <henry_c_chang@tcloudcomputing.com> Signed-off-by: Sage Weil <sage@newdream.net>
2011-05-03ceph: use ihold() when i_lock is heldSage Weil
See 0444d76ae64fffc7851797fc1b6ebdbb44ac504a. Signed-off-by: Sage Weil <sage@newdream.net>
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-03-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-clientLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: libceph: Create a new key type "ceph". libceph: Get secret from the kernel keys api when mounting with key=NAME. ceph: Move secret key parsing earlier. libceph: fix null dereference when unregistering linger requests ceph: unlock on error in ceph_osdc_start_request() ceph: fix possible NULL pointer dereference ceph: flush msgr_wq during mds_client shutdown
2011-03-29ceph: Move secret key parsing earlier.Tommi Virtanen
This makes the base64 logic be contained in mount option parsing, and prepares us for replacing the homebew key management with the kernel key retention service. Signed-off-by: Tommi Virtanen <tommi.virtanen@dreamhost.com> Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-29fs: don't use igrab() while holding i_lockDave Chinner
Fix the incorrect use of igrab() inside the i_lock in NFS and Ceph‥ If we are already holding the i_lock, we have a reference to the inode so we can safely use ihold() to gain an extra reference. This avoids hangs due to lock recursion on the i_lock now that the inode_lock is gone and igrab() uses the i_lock itself. Signed-off-by: Dave Chinner <dchinner@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: linux-fsdevel@vger.kernel.org Cc: Ryan Mallon <ryan@bluewatersys.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-25ceph: flush msgr_wq during mds_client shutdownSage Weil
The release method for mds connections uses a backpointer to the mds_client, so we need to flush the workqueue of any pending work (and ceph_connection references) prior to freeing the mds_client. This fixes an oops easily triggered under UML by while true ; do mount ... ; umount ... ; done Also fix an outdated comment: the flush in ceph_destroy_client only flushes OSD connections out. This bug is basically an artifact of the ceph -> ceph+libceph conversion. Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-21ceph: rename dentry_release -> d_release, fix commentSage Weil
Just for consistency's sake. Fix obsolete comment too. Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-21ceph: add request to the tail of unsafe write listHenry C Chang
In sync_write_wait(), we assume that the newest request is at the tail of unsafe write list. We should maintain the semantics here. Signed-off-by: Henry C Chang <henry_c_chang@tcloudcomputing.com> Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-21ceph: remove request from unsafe list if it is canceled/timed outHenry C Chang
This fixes the list corruption warning like this: ------------[ cut here ]------------ WARNING: at lib/list_debug.c:30 __list_add+0x68/0x81() Hardware name: X8DTU list_add corruption. prev->next should be next (ffff880618931250), but was (null). (prev=ffff880c188b9130). Modules linked in: nfsd lockd nfs_acl auth_rpcgss exportfs ceph libceph libcrc32c sunrpc ipv6 fuse igb i2c_i801 ioatdma i2c_core iTCO_wdt iTCO_vendor_support joydev dca serio_raw usb_storage [last unloaded: scsi_wait_scan] Pid: 10977, comm: smbd Tainted: G W 2.6.32.23-170.Elaster.xendom0.fc12.x86_64 #1 Call Trace: [<ffffffff8105753c>] warn_slowpath_common+0x7c/0x94 [<ffffffff810575ab>] warn_slowpath_fmt+0x41/0x43 [<ffffffff812351a3>] __list_add+0x68/0x81 [<ffffffffa014799d>] ceph_aio_write+0x614/0x8a2 [ceph] [<ffffffff8111d2a0>] do_sync_write+0xe8/0x125 [<ffffffff81075a1f>] ? autoremove_wake_function+0x0/0x39 [<ffffffff811f21ec>] ? selinux_file_permission+0x5c/0xb3 [<ffffffff811e8521>] ? security_file_permission+0x16/0x18 [<ffffffff8111d864>] vfs_write+0xae/0x10b [<ffffffff8111d91b>] sys_pwrite64+0x5a/0x76 [<ffffffff81012d32>] system_call_fastpath+0x16/0x1b ---[ end trace 08573eb9f07ff6f4 ]--- Signed-off-by: Henry C Chang <henry_c_chang@tcloudcomputing.com> Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-21ceph: move readahead default to fs/ceph from libcephSage Weil
2011-03-21ceph: add ino32 mount optionYehuda Sadeh
The ino32 mount option forces the ceph fs to report 32 bit ino values. This is useful for 64 bit kernels with 32 bit userspace. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net>
2011-03-21ceph: remove debugfs debug cruftSage Weil
Whoops! Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-15ceph: preserve I_COMPLETE across renameSage Weil
d_move puts the renamed dentry at the end of d_subdirs, screwing with our cached dentry directory offsets. We were just clearing I_COMPLETE to avoid any possibility of trouble. However, assigning the renamed dentry an offset at the end of the directory (to match it's new d_subdirs position) is sufficient to maintain correct behavior and hold onto I_COMPLETE. This is especially important for workloads like rsync, which renames files into place. Before, we would lose I_COMPLETE and do MDS lookups for each file. With this patch we only talk to the MDS on create and rename. Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-10ceph: fix d_revalidate oopsen on NFS exportsAl Viro
can't blindly check nd->flags in ->d_revalidate() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-04ceph: no .snap inside of snapped namespaceSage Weil
Otherwise you can do things like # mkdir .snap/foo # cd .snap/foo/.snap # ls <badness> Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-03ceph: do not clear I_COMPLETE from d_releaseSage Weil
First, this was racy anyway: d_release isn't called until well after the dentry is unhashed. Second, this runs afoul of the recent dcache change that clears d_parent prior to calling d_release (949854d0), causing a NULL pointer dereference. Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-03ceph: do not set I_COMPLETESage Weil
Do not set the I_COMPLETE flag on directories until we resolve races with dcache pruning. Signed-off-by: Sage Weil <sage@newdream.net>
2011-03-03Revert "ceph: keep reference to parent inode on ceph_dentry"Sage Weil
This reverts commit 97d79b403ef03f729883246208ef5d8a2ebc4d68. This fails to account for d_parent changes due to rename or disconnected dentries due to submounts or NFS reexports. Signed-off-by: Sage Weil <sage@newdream.net>
2011-02-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: keep reference to parent inode on ceph_dentry ceph: queue cap_snaps once per realm libceph: fix socket write error handling libceph: fix socket read error handling
2011-02-19ceph: keep reference to parent inode on ceph_dentryYehuda Sadeh
When creating a new dentry we now hold a reference to the parent inode in the ceph_dentry. This is required due to the new RCU changes from 949854d0, which set dentry->d_parent to NULL in d_kill before calling the ->release() callback. If/when that behavior is changed, we can revert this hack. Signed-off-by: Yehuda Sadeh <yehuda@hq.newdream.net> Signed-off-by: Sage Weil <sage@newdream.net>
2011-02-04ceph: queue cap_snaps once per realmSage Weil
We were forming a dirty list, and then queueing cap_snaps for each realm _and_ its children, regardless of whether the children were already in the dirty list. This meant we did it twice for some realms. Which in turn meant we corrupted mdsc->snap_flush_list when the cap_snap was re-added to the list it was already on, and could trigger an infinite loop. We were also using recursion to do reach all the children, a no-no when stack is limited. Instead, (re)queue any children on the dirty list, avoiding processing anything twice and avoiding any recursion. Signed-off-by: Sage Weil <sage@newdream.net>
2011-01-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: ceph: avoid picking MDS that is not active ceph: avoid immediate cap check after import ceph: fix flushing of caps vs cap import ceph: fix erroneous cap flush to non-auth mds ceph: fix cap_wanted_delay_{min,max} mount option initialization ceph: fix xattr rbtree search ceph: fix getattr on directory when using norbytes
2011-01-25ceph: avoid picking MDS that is not activeSage Weil
Ignore replication or auth frag data if it indicates an MDS that is not active. This can happen if the MDS shuts down and the client has stale data about the namespace distribution across the MDS cluster. If that's the case, fall back to directing the request based on the auth cap (which should always be accurate). Signed-off-by: Sage Weil <sage@newdream.net>
2011-01-19ceph: avoid immediate cap check after importSage Weil
The NODELAY flag avoids the heuristics that delay cap (issued/wanted) release. There's no reason for that after we import a cap, and it kills whatever benefit we get from those delays. Signed-off-by: Sage Weil <sage@newdream.net>
2011-01-19ceph: fix flushing of caps vs cap importSage Weil
If we are mid-flush and a cap is migrated to another node, we need to resend the cap flush message to the new MDS, and do so with the original flush_seq to avoid leaking across a sync boundary. Previously we didn't redo the flush (we only flushed newly dirty data), which would cause a later sync to hang forever. Signed-off-by: Sage Weil <sage@newdream.net>
2011-01-19ceph: fix erroneous cap flush to non-auth mdsSage Weil
The int flushing is global and not clear on each iteration of the loop, which can cause a second flush of caps to any MDSs with ids greater than the auth. Signed-off-by: Sage Weil <sage@newdream.net>
