path: root/fs/cifs/cifs_fs_sb.h
2016-10-14CIFS: Add new mount option to set owner uid and gid from special sids in aclSteve French
Add "idsfromsid" mount option to indicate to cifs.ko that it should try to retrieve the uid and gid owner fields from special sids in the ACL if present. This first patch just adds the parsing for the mount option. Signed-off-by: Steve French <steve.french@primarydata.com> Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2016-07-27fs/cifs: make share unaccessible at root level mountableAurelien Aptel
if, when mounting //HOST/share/sub/dir/foo we can query /sub/dir/foo but not any of the path components above: - store the /sub/dir/foo prefix in the cifs super_block info - in the superblock, set root dentry to the subpath dentry (instead of the share root) - set a flag in the superblock to remember it - use prefixpath when building path from a dentry fixes bso#8950 Signed-off-by: Aurelien Aptel <aaptel@suse.com> CC: Stable <stable@vger.kernel.org> Reviewed-by: Pavel Shilovsky <pshilovsky@samba.org> Signed-off-by: Steve French <smfrench@gmail.com>
2014-10-16Allow conversion of characters in Mac remap range. Part 1Steve French
This allows directory listings to Mac to display filenames correctly which have been created with illegal (to Windows) characters in their filename. It does not allow converting the other direction yet ie opening files with these characters (followon patch). There are seven reserved characters that need to be remapped when mounting to Windows, Mac (or any server without Unix Extensions) which are valid in POSIX but not in the other OS. : \ < > ? * | We used the normal UCS-2 remap range for this in order to convert this to/from UTF8 as did Windows Services for Unix (basically add 0xF000 to any of the 7 reserved characters), at least when the "mapchars" mount option was specified. Mac used a very slightly different "Services for Mac" remap range 0xF021 through 0xF027. The attached patch allows cifs.ko (the kernel client) to read directories on macs containing files with these characters and display their names properly. In theory this even might be useful on mounts to Samba when the vfs_catia or new "vfs_fruit" module is loaded. Currently the 7 reserved characters look very strange in directory listings from cifs.ko to Mac server. This patch allows these file name characters to be read (requires specifying mapchars on mount). Two additional changes are needed: 1) Make it more automatic: a way of detecting enough info so that we know to try to always remap these characters or not. Various have suggested that the SFM approach be made the default when the server does not support POSIX Unix extensions (cifs mounts to Samba for example) so need to make SFM remapping the default unless mapchars (SFU style mapping) specified on mount or no mapping explicitly requested or no mapping needed (cifs mounts to Samba). 2) Adding a patch to map the characters the other direction (ie UTF-8 to UCS-2 on open). This patch does it for translating readdir entries (ie UCS-2 to UTF-8) Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
2013-10-24cifs: rcu-delay unload_nls() and freeing sbiAl Viro
makes ->d_hash(), ->d_compare() and ->permission() safety in RCU mode independent from vfsmount_lock. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-13cifs: Convert struct cifs_sb_info to use kuids and kgidsEric W. Biederman
Cc: Steve French <smfrench@gmail.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-01-03cifs: propagate umode_tAl Viro
2011-10-12cifs: Add mount options for backup intent (try #6)Shirish Pargaonkar
Add mount options backupuid and backugid. It allows an authenticated user to access files with the intent to back them up including their ACLs, who may not have access permission but has "Backup files and directories user right" on them (by virtue of being part of the built-in group Backup Operators. When mount options backupuid is specified, cifs client restricts the use of backup intents to the user whose effective user id is specified along with the mount option. When mount options backupgid is specified, cifs client restricts the use of backup intents to the users whose effective user id belongs to the group id specified along with the mount option. If an authenticated user is not part of the built-in group Backup Operators at the server, access to such files is denied, even if allowed by the client. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2011-06-24cifs: don't pass superblock to cifs_mount()Al Viro
To close sget() races we'll need to be able to set cifs_sb up before we get the superblock, so we'll want to be able to do cifs_mount() earlier. Fortunately, it's easy to do - setting ->s_maxbytes can be done in cifs_read_super(), ditto for ->s_time_gran and as for putting MS_POSIXACL into ->s_flags, we can mirror it in ->mnt_cifs_flags until cifs_read_super() is called. Kill unused 'devname' argument, while we are at it... Acked-by: Pavel Shilovsky <piastryyy@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-27CIFS: Add rwpidforward mount optionPavel Shilovsky
Add rwpidforward mount option that switches on a mode when we forward pid of a process who opened a file to any read and write operation. This can prevent applications like WINE from failing on read or write operation on a previously locked file region from the same netfd from another process if we use mandatory brlock style. It is actual for WINE because during a run of WINE program two processes work on the same netfd - share the same file struct between several VFS fds: 1) WINE-server does open and lock; 2) WINE-application does read and write. Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-05-27[CIFS] Migrate from prefixpath logicSteve French
Now we point superblock to a server share root and set a root dentry appropriately. This let us share superblock between mounts like //server/sharename/foo/bar and //server/sharename/foo further. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-05-19cifs: Unconditionally copy mount options to superblock infoSean Finney
Previously mount options were copied and updated in the cifs_sb_info struct only when CONFIG_CIFS_DFS_UPCALL was enabled. Making this information generally available allows us to remove a number of ifdefs, extra function params, and temporary variables. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Sean Finney <seanius@seanius.net> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-20CIFS: Make cifsFileInfo_put work with strict cache modePavel Shilovsky
On strict cache mode when we close the last file handle of the inode we should set invalid_mapping flag on this inode to prevent data coherency problem when we open it again but it has been modified on the server. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-12-02cifs: add attribute cache timeout (actimeo) tunableSuresh Jayaraman
Currently, the attribute cache timeout for CIFS is hardcoded to 1 second. This means that the client might have to issue a QPATHINFO/QFILEINFO call every 1 second to verify if something has changes, which seems too expensive. On the other hand, if the timeout is hardcoded to a higher value, workloads that expect strict cache coherency might see unexpected results. Making attribute cache timeout as a tunable will allow us to make a tradeoff between performance and cache metadata correctness depending on the application/workload needs. Add 'actimeo' tunable that can be used to tune the attribute cache timeout. The default timeout is set to 1 second. Also, display actimeo option value in /proc/mounts. It appears to me that 'actimeo' and the proposed (but not yet merged) 'strictcache' option cannot coexist, so care must be taken that we reset the other option if one of them is set. Changes since last post: - fix option parsing and handle possible values correcly Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-11-02cifs: convert tlink_tree to a rbtreeJeff Layton
Radix trees are ideal when you want to track a bunch of pointers and can't embed a tracking structure within the target of those pointers. The tradeoff is an increase in memory, particularly if the tree is sparse. In CIFS, we use the tlink_tree to track tcon_link structs. A tcon_link can never be in more than one tlink_tree, so there's no impediment to using a rb_tree here instead of a radix tree. Convert the new multiuser mount code to use a rb_tree instead. This should reduce the memory required to manage the tlink_tree. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-11-02cifs: store pointer to master tlink in superblock (try #2)Jeff Layton
This is the second version of this patch, the only difference between it and the first one is that this explicitly makes cifs_sb_master_tlink a static inline. Instead of keeping a tag on the master tlink in the tree, just keep a pointer to the master in the superblock. That eliminates the need for using the radix tree to look up a tagged entry. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-12cifs: don't use vfsmount to pin superblock for oplock breaksJeff Layton
Filesystems aren't really supposed to do anything with a vfsmount. It's considered a layering violation since vfsmounts are entirely managed at the VFS layer. CIFS currently keeps an active reference to a vfsmount in order to prevent the superblock vanishing before an oplock break has completed. What we really want to do instead is to keep sb->s_active high until the oplock break has completed. This patch borrows the scheme that NFS uses for handling sillyrenames. An atomic_t is added to the cifs_sb_info. When it transitions from 0 to 1, an extra reference to the superblock is taken (by bumping the s_active value). When it transitions from 1 to 0, that reference is dropped and a the superblock teardown may proceed if there are no more references to it. Also, the vfsmount pointer is removed from cifsFileInfo and from cifs_new_fileinfo, and some bogus forward declarations are removed from cifsfs.h. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-08cifs: implement recurring workqueue job to prune old tconsJeff Layton
Create a workqueue job that cleans out unused tlinks. For now, it uses a hardcoded expire time of 10 minutes. When it's done, the work rearms itself. On umount, the work is cancelled before tearing down the tlink tree. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-07cifs: add routines to build sessions and tcons on the flyJeff Layton
This patch is rather large, but it's a bit difficult to do piecemeal... For non-multiuser mounts, everything will basically work as it does today. A call to cifs_sb_tlink will return the "master" tcon link. Turn the tcon pointer in the cifs_sb into a radix tree that uses the fsuid of the process as a key. The value is a new "tcon_link" struct that contains info about a tcon that's under construction. When a new process needs a tcon, it'll call cifs_sb_tcon. That will then look up the tcon_link in the radix tree. If it exists and is valid, it's returned. If it doesn't exist, then we stuff a new tcon_link into the tree and mark it as pending and then go and try to build the session/tcon. If that works, the tcon pointer in the tcon_link is updated and the pending flag is cleared. If the construction fails, then we set the tcon pointer to an ERR_PTR and clear the pending flag. If the radix tree is searched and the tcon_link is marked pending then we go to sleep and wait for the pending flag to be cleared. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-06cifs: have find_readable/writable_file filter by fsuidJeff Layton
When we implement multiuser mounts, we'll need to filter filehandles by fsuid. Add a flag for multiuser mounts and code to filter by fsuid when it's set. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29cifs: temporarily rename cifs_sb->tcon to ptcon to catch stragglersJeff Layton
2010-09-29cifs: use Minshall+French symlink functionsStefan Metzmacher
If configured, Minshall+French Symlinks are used against all servers. If the server supports UNIX Extensions, we still create Minshall+French Symlinks on write, but on read we fallback to UNIX Extension symlinks. Signed-off-by: Stefan Metzmacher <metze@samba.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-02cifs: add mount option to enable local cachingSuresh Jayaraman
Add a mount option 'fsc' to enable local caching on CIFS. I considered adding a separate debug bit for caching, but it appears that debugging would be relatively easier with the normal CIFS_INFO level. As the cifs-utils (userspace) changes are not done yet, this patch enables 'fsc' by default to enable testing. Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-04-22cifs: add bdi backing to mount sessionJens Axboe
This ensures that dirty data gets flushed properly. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-12[CIFS] fix build errorSteve French
2009-03-12[CIFS] Add new nostrictsync cifs mount option to avoid slow SMB flushSteve French
If this mount option is set, when an application does an fsync call then the cifs client does not send an SMB Flush to the server (to force the server to write all dirty data for this file immediately to disk), although cifs still sends all dirty (cached) file data to the server and waits for the server to respond to the write write. Since SMB Flush can be very slow, and some servers may be reliable enough (to risk delaying slightly flushing the data to disk on the server), turning on this option may be useful to improve performance for applications that fsync too much, at a small risk of server crash. If this mount option is not set, by default cifs will send an SMB flush request (and wait for a response) on every fsync call. Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-12-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: (31 commits) [CIFS] Remove redundant test [CIFS] make sure that DFS pathnames are properly formed Remove an already-checked error condition in SendReceiveBlockingLock Streamline SendReceiveBlockingLock: Use "goto out:" in an error condition Streamline SendReceiveBlockingLock: Use "goto out:" in an error condition [CIFS] Streamline SendReceive[2] by using "goto out:" in an error condition Slightly streamline SendReceive[2] Check the return value of cifs_sign_smb[2] [CIFS] Cleanup: Move the check for too large R/W requests [CIFS] Slightly simplify wait_for_free_request(), remove an unnecessary "else" branch Simplify allocate_mid() slightly: Remove some unnecessary "else" branches [CIFS] In SendReceive, move consistency check out of the mutexed region cifs: store password in tcon cifs: have calc_lanman_hash take more granular args cifs: zero out session password before freeing it cifs: fix wait_for_response to time out sleeping processes correctly [CIFS] Can not mount with prefixpath if root directory of share is inaccessible [CIFS] various minor cleanups pointed out by checkpatch script [CIFS] fix typo [CIFS] remove sparse warning ... Fix trivial conflict in fs/cifs/cifs_fs_sb.h due to comment changes for the CIFS_MOUNT_xyz bit definitions between cifs updates and security updates.
2008-12-26[CIFS] add mount option to send mandatory rather than advisory locksSteve French
Some applications/subsystems require mandatory byte range locks (as is used for Windows/DOS/OS2 etc). Sending advisory (posix style) byte range lock requests (instead of mandatory byte range locks) can lead to problems for these applications (which expect that other clients be prevented from writing to portions of the file which they have locked and are updating). This mount option allows mounting cifs with the new mount option "forcemand" (or "forcemandatorylock") in order to have the cifs client use mandatory byte range locks (ie SMB/CIFS/Windows/NTFS style locks) rather than posix byte range lock requests, even if the server would support posix byte range lock requests. This has no effect if the server does not support the CIFS Unix Extensions (since posix style locks require support for the CIFS Unix Extensions), but for mounts to Samba servers this can be helpful for Wine and applications that require mandatory byte range locks. Acked-by: Jeff Layton <jlayton@redhat.com> CC: Alexander Bokovoy <ab@samba.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-11-14CRED: Wrap task credential accesses in the CIFS filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Steve French <sfrench@samba.org> Cc: linux-cifs-client@lists.samba.org Signed-off-by: James Morris <jmorris@namei.org>
2008-05-12[CIFS] CIFS currently allows for permissions to be changed on files, evenJeff Layton
when unix extensions and cifsacl support are disabled. These permissions changes are "ephemeral" however. They are lost whenever a share is mounted and unmounted, or when memory pressure forces the inode out of the cache. Because of this, we'd like to introduce a behavior change to make CIFS behave more like local DOS/Windows filesystems. When unix extensions and cifsacl support aren't enabled, then don't silently ignore changes to permission bits that can't be reflected on the server. Still, there may be people relying on the current behavior for certain applications. This patch adds a new "dynperm" (and a corresponding "nodynperm") mount option that will be intended to make the client fall back to legacy behavior when setting these modes. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-01-11[CIFS] DFS support patchset: Added mountdataIgor Mammedov
Also cifs_fs_type was made not static for ussage in dfs code. Signed-off-by: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-07-13[CIFS] whitespace/formatting fixesSteve French
This should be the last big batch of whitespace/formatting fixes. checkpatch warnings for the cifs directory are down about 90% and many of the remaining ones are harder to remove or make the code harder to read. Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-04-30[CIFS] UID/GID override on CIFS mounts to SambaSteve French
When CIFS Unix Extensions are negotiated we get the Unix uid and gid owners of the file from the server (on the Unix Query Path Info levels), but if the server's uids don't match the client uid's users were having to disable the Unix Extensions (which turned off features they still wanted). The changeset patch allows users to override uid and/or gid for file/directory owner with a default uid and/or gid specified at mount (as is often done when mounting from Linux cifs client to Windows server). This changeset also displays the uid and gid used by default in /proc/mounts (if applicable). Also cleans up code by adding some of the missing spaces after "if" keywords per-kernel style guidelines (as suggested by Randy Dunlap when he reviewed the patch). Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-09-21[CIFS] Support deep tree mounts (e.g. mounts to //server/share/path)Steve French
Samba bugzilla #4040 Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-01-12[CIFS] Add worker function for Get ACL cifs styleSteve French
2005-08-19[CIFS] Finish cifs mount option which requests case insensitive pathSteve French
name matching. Signed-off-by: Steve French (sfrench@us.ibm.com)
2005-08-18[CIFS] Add mount option for disabling sending byte range lock requestsSteve French
over the wire (to help the case when applications break with cifs mandatory lock behavior. Add part one of mount option for requesting case insensitive path name matching. Signed-off-by: Steve French (sfrench@us.ibm.com)
2005-07-14[CIFS] Add compat with SFU (part 1)Steve French
This should help the case of creating fifos and other special files to servers which do not support the Unix extensions. Signed-off-by: Steve French (sfrench@us.ibm.com) Thanks to Martin Koeppe for his suggestions and good analysis
2005-06-22[CIFS] POSIX extensions, SetFSInfo addedJeremy Allison
Signed-off-by: Steve French@sfrench@us.ibm.com Signed-off-by: Jeremy Allison (jra@samba.org)
2005-04-28[PATCH] cifs: Add new mount parm mapcharsSteve French
For handling seven special characters that shells use for filenames. This first parts implements conversions from Unicode. Signed-off-by: Steve French Signed-off-by: Linus Torvalds <torvalds@osdl.org>
