path: root/fs/cifs/cifs_spnego.c
2013-05-04[CIFS] cifs: Rename cERROR and cFYI to cifs_dbgJoe Perches
It's not obvious from reading the macro names that these macros are for debugging. Convert the names to a single more typical kernel style cifs_dbg macro. cERROR(1, ...) -> cifs_dbg(VFS, ...) cFYI(1, ...) -> cifs_dbg(FYI, ...) cFYI(DBG2, ...) -> cifs_dbg(NOISY, ...) Move the terminating format newline from the macro to the call site. Add CONFIG_CIFS_DEBUG function cifs_vfs_err to emit the "CIFS VFS: " prefix for VFS messages. Size is reduced ~ 1% when CONFIG_CIFS_DEBUG is set (default y) $ size fs/cifs/cifs.ko* text data bss dec hex filename 265245 2525 132 267902 4167e fs/cifs/cifs.ko.new 268359 2525 132 271016 422a8 fs/cifs/cifs.ko.old Other miscellaneous changes around these conversions: o Miscellaneous typo fixes o Add terminating \n's to almost all formats and remove them from the macros to be more kernel style like. A few formats previously had defective \n's o Remove unnecessary OOM messages as kmalloc() calls dump_stack o Coalesce formats to make grep easier, added missing spaces when coalescing formats o Use %s, __func__ instead of embedded function name o Removed unnecessary "cifs: " prefixes o Convert kzalloc with multiply to kcalloc o Remove unused cifswarn macro Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-05-04fs: cifs: use kmemdup instead of kmalloc + memcpySilviu-Mihai Popescu
This replaces calls to kmalloc followed by memcpy with a single call to kmemdup. This was found via make coccicheck. Signed-off-by: Silviu-Mihai Popescu <silviupopescu1990@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-02-13cifs: Convert struct cifs_ses to use a kuid_t and a kgid_tEric W. Biederman
Cc: Steve French <smfrench@gmail.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-10-08KEYS: Add payload preparsing opportunity prior to key instantiate or updateDavid Howells
Give the key type the opportunity to preparse the payload prior to the instantiation and update routines being called. This is done with the provision of two new key type operations: int (*preparse)(struct key_preparsed_payload *prep); void (*free_preparse)(struct key_preparsed_payload *prep); If the first operation is present, then it is called before key creation (in the add/update case) or before the key semaphore is taken (in the update and instantiate cases). The second operation is called to clean up if the first was called. preparse() is given the opportunity to fill in the following structure: struct key_preparsed_payload { char *description; void *type_data[2]; void *payload; const void *data; size_t datalen; size_t quotalen; }; Before the preparser is called, the first three fields will have been cleared, the payload pointer and size will be stored in data and datalen and the default quota size from the key_type struct will be stored into quotalen. The preparser may parse the payload in any way it likes and may store data in the type_data[] and payload fields for use by the instantiate() and update() ops. The preparser may also propose a description for the key by attaching it as a string to the description field. This can be used by passing a NULL or "" description to the add_key() system call or the key_create_or_update() function. This cannot work with request_key() as that required the description to tell the upcall about the key to be created. This, for example permits keys that store PGP public keys to generate their own name from the user ID and public key fingerprint in the key. The instantiate() and update() operations are then modified to look like this: int (*instantiate)(struct key *key, struct key_preparsed_payload *prep); int (*update)(struct key *key, struct key_preparsed_payload *prep); and the new payload data is passed in *prep, whether or not it was preparsed. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-01-17cifs: sanitize username handlingJeff Layton
Currently, it's not very clear whether you're allowed to have a NULL vol->username or ses->user_name. Some places check for it and some don't. Make it clear that a NULL pointer is OK in these fields, and ensure that all the callers check for that. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2011-05-27[CIFS] Rename three structures to avoid camel caseSteve French
secMode to sec_mode and cifsTconInfo to cifs_tcon and cifsSesInfo to cifs_ses Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-04-12Allow user names longer than 32 bytesSteve French
We artificially limited the user name to 32 bytes, but modern servers handle larger. Set the maximum length to a reasonable 256, and make the user name string dynamically allocated rather than a fixed size in session structure. Also clean up old checkpatch warning. Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-06CIFS: Simplify ipv*_connect functions into one (try #4)Pavel Shilovsky
Make connect logic more ip-protocol independent and move RFC1001 stuff into a separate function. Also replace union addr in TCP_Server_Info structure with sockaddr_storage. Signed-off-by: Pavel Shilovsky <piastryyy@gmail.com> Reviewed-and-Tested-by: Jeff Layton <jlayton@samba.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-05cifs: account for new creduid=0x%x parameter in spnego upcall stringJeff Layton
The commit that added the creduid=0x%x parameter failed to increase the buffer allocation to account for it. Reported-by: J. Bruce Fields <bfields@fieldses.org> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-02cifs: add separate cred_uid field to sesInfoJeff Layton
Right now, there's no clear separation between the uid that owns the credentials used to do the mount and the overriding owner of the files on that mount. Add a separate cred_uid field that is set to the real uid of the mount user. Unlike the linux_uid, the uid= option does not override this parameter. The parm is sent to cifs.upcall, which can then preferentially use the creduid= parm instead of the uid= parm for finding credentials. This is not the only way to solve this. We could try to do all of this in kernel instead by having a module parameter that affects what gets passed in the uid= field of the upcall. That said, we have a lot more flexibility to change things in userspace so I think it probably makes sense to do it this way. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-05-05cifs: have decode_negTokenInit set flags in server structJeff Layton
...rather than the secType. This allows us to get rid of the MSKerberos securityEnum. The client just makes a decision at upcall time. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-04-21[CIFS] Neaten cERROR and cFYI macros, reduce text spaceJoe Perches
Neaten cERROR and cFYI macros, reduce text space ~2.5K Convert '__FILE__ ": " fmt' to '"%s: " fmt', __FILE__' to save text space Surround macros with do {} while Add parentheses to macros Make statement expression macro from macro with assign Remove now unnecessary parentheses from cFYI and cERROR uses defconfig with CIFS support old $ size fs/cifs/built-in.o text data bss dec hex filename 156012 1760 148 157920 268e0 fs/cifs/built-in.o defconfig with CIFS support old $ size fs/cifs/built-in.o text data bss dec hex filename 153508 1760 148 155416 25f18 fs/cifs/built-in.o allyesconfig old: $ size fs/cifs/built-in.o text data bss dec hex filename 309138 3864 74824 387826 5eaf2 fs/cifs/built-in.o allyesconfig new $ size fs/cifs/built-in.o text data bss dec hex filename 305655 3864 74824 384343 5dd57 fs/cifs/built-in.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-09-01cifs: send IPv6 addr in upcall with colon delimitersJeff Layton
Make it easier on the upcall program by adding ':' delimiters between each group of hex digits. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-07-09cifs: add pid of initiating process to spnego upcall infoJeff Layton
cifs: add pid of initiating process to spnego upcall info This will allow the upcall to poke in /proc/<pid>/environ and get the value of the $KRB5CCNAME env var for the process. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-06-02cifs: fix IPv6 address length checkJeff Layton
For IPv6 the userspace mount helper sends an address in the "ip=" option. This check fails if the length is > 35 characters. I have no idea where the magic 35 character limit came from, but it's clearly not enough for IPv6. Fix it by making it use the INET6_ADDRSTRLEN #define. While we're at it, use the same #define for the address length in SPNEGO upcalls. Reported-by: Charles R. Anderson <cra@wpi.edu> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-04-17cifs: no need to use rcu_assign_pointer on immutable keysJeff Layton
cifs: no need to use rcu_assign_pointer on immutable keys Neither keytype in use by CIFS has an "update" method. This means that the keys are immutable once instantiated. We don't need to use RCU to set the payload data pointers. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-11-18Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: drivers/isdn/i4l/isdn_net.c fs/cifs/connect.c
2008-11-14[CIFS] clean up server protocol handlingSteve French
We're currently declaring both a sockaddr_in and sockaddr6_in on the stack, but we really only need storage for one of them. Declare a sockaddr struct and cast it to the proper type. Also, eliminate the protocolType field in the TCP_Server_Info struct. It's redundant since we have a sa_family field in the sockaddr anyway. We may need to revisit this if SCTP is ever implemented, but for now this will simplify the code. CIFS over IPv6 also has a number of problems currently. This fixes all of them that I found. Eventually, it would be nice to move more of the code to be protocol independent, but this is a start. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-10-31fs: replace NIPQUAD()Harvey Harrison
Using NIPQUAD() with NIPQUAD_FMT, %d.%d.%d.%d or %u.%u.%u.%u can be replaced with %pI4 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-29net: replace %#p6 format specifier with %pi6Harvey Harrison
gcc warns when using the # modifier with the %p format specifier, so we can't use this to omit the colons when needed, introduces %pi6 instead. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-10-28net: replace all current users of NIP6_SEQFMT with %#p6Harvey Harrison
The define in kernel.h can be done away with at a later time. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-09-23[CIFS] add constants for string lengths of keynames in SPNEGO upcall stringSteve French
2008-08-19[CIFS] distinguish between Kerberos and MSKerberos in upcallSteve French
Properly handle MSKRB5 by passing sec=mskrb5 to the upcall so that the spengo blob can be generated appropriately. Also, make decode_negTokenInit prefer whichever mechanism is first in the list. Needed for some NetApp servers, and possibly some older versions of Windows which treat the two KRB5 mechanisms differently. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-08-01[CIFS] properly account for new user= field in SPNEGO upcall string allocationJeff Layton
...it doesn't look like it's being accounted for at the moment. Also try to reorganize the calculation to make it a little more evident what each piece means. This should probably go to the stable series as well... Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-22Adds username in the upcall key for unattended mounts with keytabIgor Mammedov
Signed-off-by: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-02-05[CIFS] fix warning in cifs_spnego.cAndrew Morton
Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-12-31[CIFS] Only dump SPNEGO key if CONFIG_CIFS_DEBUG2 is setJeff Layton
The SPNEGO key data is not terribly interesting except in certain debugging situations. Only dump it to the ring buffer if needed. Signed-off-by: Jeff Layton <jlayton@tupile.poochiereds.net> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-11-17[CIFS] remove build warningSteve French
CC: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-11-16[CIFS] have cifs_get_spnego_key get the hostname from TCP_Server_InfoJeff Layton
2007-11-16[CIFS] add ver= prefix to upcall format versionSteve French
Acked-by: Jeff Layton <jlayton@redhat.com> Acked-by: Igor Mammedov <niallan@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-11-08[CIFS] Add uid to key description so krb can handle user mountsIgor Mammedov
Adds uid to key description fro supporting user mounts and minor formating changes Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Igor Mammedov <niallain@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-11-05[CIFS] Add upcall files for cifs to use spnego/kerberosSteve French
Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
