[ Upstream commit f980d055a0f858d73d9467bb0b570721bbfcdfb8 ]
strlcpy() reads the entire source buffer first. This read may exceed the
destination size limit. This is both inefficient and can lead to linear
read overflows if a source string is not NUL-terminated.
Also, the strnlen() call does not avoid the read overflow in the strlcpy
function when a not NUL-terminated string is passed.
So, replace this block by a call to kstrndup() that avoids this type of
overflow and does the same.
Fixes: 066ce6899484d ("cifs: rename cifs_strlcpy_to_host and make it use new functions")
Signed-off-by: Len Baker <len.baker@gmx.com>
Reviewed-by: Paulo Alcantara (SUSE) <pc@cjr.nz>
Reviewed-by: Jeff Layton <jlayton@kernel.org>
Signed-off-by: Steve French <stfrench@microsoft.com>
commit 57c176074057531b249cf522d90c22313fa74b0b upstream.
When converting trailing spaces and periods in paths, do so
for every component of the path, not just the last component.
If the conversion is not done for every path component, then
subsequent operations in directories with trailing spaces or
periods (e.g. create(), mkdir()) will fail with ENOENT. This
is because on the server, the directory will have a special
symbol in its name, and the client needs to provide the same.
Signed-off-by: Boris Protopopov <pboris@amazon.com>
Acked-by: Ronnie Sahlberg <lsahlber@redhat.com>
[ Upstream commit c15e3f19a6d5c89b1209dc94b40e568177cb0921 ]
When a Mac client saves an item containing a backslash to a file server
the backslash is represented in the CIFS/SMB protocol as as U+F026.
Before this change, listing a directory containing an item with a
backslash in its name will return that item with the backslash
represented with a true backslash character (U+005C) because
convert_sfm_character mapped U+F026 to U+005C when interpretting the
CIFS/SMB protocol response. However, attempting to open or stat the
path using a true backslash will result in an error because
convert_to_sfm_char does not map U+005C back to U+F026 causing the
CIFS/SMB request to be made with the backslash represented as U+005C.
This change simply prevents the U+F026 to U+005C conversion from
happenning. This is analogous to how the code does not do any
translation of UNI_SLASH (U+F000).
Signed-off-by: Jon Kuhn <jkuhn@barracuda.com>
commit 85435d7a15294f9f7ef23469e6aaf7c5dfcc54f0 upstream.
SFM is mapping doublequote to 0xF020
Without this patch creating files with doublequote fails to Windows/Mac
Signed-off-by: Bjoern Jacke <bjacke@samba.org>
Signed-off-by: Steve French <smfrench@gmail.com>
commit 45e8a2583d97ca758a55c608f78c4cef562644d1 upstream.
POSIX allows files with trailing spaces or a trailing period but
SMB3 does not, so convert these using the normal Services For Mac
mapping as we do for other reserved characters such as
This is similar to what Macs do for the same problem over SMB3.
Signed-off-by: Steve French <steve.french@primarydata.com>
Acked-by: Pavel Shilovsky <pshilovsky@samba.org>
Garbled characters happen by using surrogate pair for filename.
(replace each 1 character to ??)
[Steps to Reproduce for bug]
client# touch $(echo -e '\xf0\x9d\x9f\xa3')
client# touch $(echo -e '\xf0\x9d\x9f\xa4')
client# ls -li
You see same inode number, same filename(=?? and ??) .
Fix the bug about these functions do not consider about surrogate pair (and IVS).
cifs_utf16_bytes()
cifs_mapchar()
cifs_from_utf16()
cifsConvertToUTF16()
Reported-by: Nakajima Akira <nakajima.akira@nttcom.co.jp>
Signed-off-by: Nakajima Akira <nakajima.akira@nttcom.co.jp>
This is a bigger patch, but its size is mostly due to
a single change for how we check for remapping illegal characters
in file names - a lot of repeated, small changes to
the way callers request converting file names.
The final patch in the series does the following:
1) changes default behavior for cifs to be more intuitive.
Currently we do not map by default to seven reserved characters,
ie those valid in POSIX but not in NTFS/CIFS/SMB3/Windows,
unless a mount option (mapchars) is specified. Change this
to by default always map and map using the SFM maping
(like the Mac uses) unless the server negotiates the CIFS Unix
Extensions (like Samba does when mounting with the cifs protocol)
when the remapping of the characters is unnecessary. This should
help SMB3 mounts in particular since Samba will likely be
able to implement this mapping with its new "vfs_fruit" module
as it will be doing for the Mac.
2) if the user specifies the existing "mapchars" mount option then
use the "SFU" (Microsoft Services for Unix, SUA) style mapping of
the seven characters instead.
3) if the user specifies "nomapposix" then disable SFM/MAC style mapping
(so no character remapping would be used unless the user specifies
"mapchars" on mount as well, as above).
4) change all the places in the code that check for the superblock
flag on the mount which is set by mapchars and passed in on all
path based operation and change it to use a small function call
instead to set the mapping type properly (and check for the
mapping type in the cifs unicode functions)
The previous patch allowed remapping reserved characters from directory
listenings, this patch adds conversion the other direction, allowing
opening of files with any of the seven reserved characters.
Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
This allows directory listings to Mac to display filenames
correctly which have been created with illegal (to Windows)
characters in their filename. It does not allow
converting the other direction yet ie opening files with
these characters (followon patch).
There are seven reserved characters that need to be remapped when
mounting to Windows, Mac (or any server without Unix Extensions) which
are valid in POSIX but not in the other OS.
We used the normal UCS-2 remap range for this in order to convert this
to/from UTF8 as did Windows Services for Unix (basically add 0xF000 to
any of the 7 reserved characters), at least when the "mapchars" mount
option was specified.
Mac used a very slightly different "Services for Mac" remap range
0xF021 through 0xF027. The attached patch allows cifs.ko (the kernel
client) to read directories on macs containing files with these
characters and display their names properly. In theory this even
might be useful on mounts to Samba when the vfs_catia or new
"vfs_fruit" module is loaded.
Currently the 7 reserved characters look very strange in directory
listings from cifs.ko to Mac server. This patch allows these file
name characters to be read (requires specifying mapchars on mount).
Two additional changes are needed:
1) Make it more automatic: a way of detecting enough info so that
we know to try to always remap these characters or not. Various
have suggested that the SFM approach be made the default when
the server does not support POSIX Unix extensions (cifs mounts
to Samba for example) so need to make SFM remapping the default
unless mapchars (SFU style mapping) specified on mount or no
mapping explicitly requested or no mapping needed (cifs mounts to Samba).
2) Adding a patch to map the characters the other direction
(ie UTF-8 to UCS-2 on open). This patch does it for translating
readdir entries (ie UCS-2 to UTF-8)
option
When we SMB3 mounted with mapchars (to allow reserved characters : \ / > < * ?
via the Unicode Windows to POSIX remap range) empty paths
(eg when we open "" to query the root of the SMB3 directory on mount) were not
null terminated so we sent garbarge as a path name on empty paths which caused
SMB2/SMB2.1/SMB3 mounts to fail when mapchars was specified. mapchars is
particularly important since Unix Extensions for SMB3 are not supported (yet)
Cc: <stable@vger.kernel.org>
Reviewed-by: David Disseldorp <ddiss@suse.de>
It's not obvious from reading the macro names that these macros
are for debugging. Convert the names to a single more typical
kernel style cifs_dbg macro.
cERROR(1, ...) -> cifs_dbg(VFS, ...)
cFYI(1, ...) -> cifs_dbg(FYI, ...)
cFYI(DBG2, ...) -> cifs_dbg(NOISY, ...)
Move the terminating format newline from the macro to the call site.
Add CONFIG_CIFS_DEBUG function cifs_vfs_err to emit the
"CIFS VFS: " prefix for VFS messages.
Size is reduced ~ 1% when CONFIG_CIFS_DEBUG is set (default y)
$ size fs/cifs/cifs.ko*
265245 2525 132 267902 4167e fs/cifs/cifs.ko.new
268359 2525 132 271016 422a8 fs/cifs/cifs.ko.old
Other miscellaneous changes around these conversions:
o Miscellaneous typo fixes
o Add terminating \n's to almost all formats and remove them
from the macros to be more kernel style like. A few formats
previously had defective \n's
o Remove unnecessary OOM messages as kmalloc() calls dump_stack
o Coalesce formats to make grep easier,
added missing spaces when coalescing formats
o Use %s, __func__ instead of embedded function name
o Removed unnecessary "cifs: " prefixes
o Convert kzalloc with multiply to kcalloc
o Remove unused cifswarn macro
Signed-off-by: Jeff Layton <jlayton@redhat.com>
wchar_t is currently 16bit so converting a utf8 encoded characters not
in plane 0 (>= 0x10000) to wchar_t (that is calling char2uni) lead to a
-EINVAL return. This patch detect utf8 in cifs_strtoUTF16 and add special
code calling utf8s_to_utf16s.
Signed-off-by: Frediano Ziglio <frediano.ziglio@citrix.com>
Acked-by: Jeff Layton <jlayton@redhat.com>
This function returns the wrong value, which causes the callers to get
the length of the resulting pathname wrong when it contains non-ASCII
characters.
This seems to fix https://bugzilla.samba.org/show_bug.cgi?id=6767
Reported-by: Baldvin Kovacs <baldvin.kovacs@gmail.com>
Reported-and-Tested-by: Nicolas Lefebvre <nico.lefebvre@gmail.com>
that needs for a successful mount through SMB2 protocol.
Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru>
to reflect the unicode encoding used by CIFS protocol.
Acked-by: Jeff Layton <jlayton@samba.org>
As Metze pointed out, commit 84cdf74e broke mapchars option:
Commit "cifs: fix unaligned accesses in cifsConvertToUCS"
(84cdf74e8096a10dd6acbb870dd404b92f07a756) does multiple steps
in just one commit (moving the function and changing it without
testing).
put_unaligned_le16(temp, &target[j]); is never called for any
codepoint the goes via the 'default' switch statement. As a result
we put just zero (or maybe uninitialized) bytes into the target
buffer.
His proposed patch looks correct, but doesn't apply to the current head
of the tree. This patch should also fix it.
Cc: <stable@kernel.org> # .38.x: 581ade4: cifs: clean up various nits in unicode routines (try #2)
Reported-by: Stefan Metzmacher <metze@samba.org>
Signed-off-by: Steve French <sfrench@us.ibm.com>
Minor revision to the original patch. Don't abuse the __le16 variable
on the stack by casting it to wchar_t and handing it off to char2uni.
Declare an actual wchar_t on the stack instead. This fixes a valid
sparse warning.
Fix the spelling of UNI_ASTERISK. Eliminate the unneeded len_remaining
variable in cifsConvertToUCS.
Also, as David Howells points out. We were better off making
cifsConvertToUCS *not* use put_unaligned_le16 since it means that we
can't optimize the mapped characters at compile time. Switch them
instead to use cpu_to_le16, and simply use put_unaligned to set them
in the string.
Reported-and-acked-by: David Howells <dhowells@redhat.com>
Move cifsConvertToUCS to cifs_unicode.c where all of the other unicode
related functions live. Have it store mapped characters in 'temp' and
then use put_unaligned_le16 to copy it to the target buffer. Also fix
the comments to match kernel coding style.
Acked-by: Pavel Shilovsky <piastryyy@gmail.com>
Make sure we use get/put_unaligned routines when accessing wide
character strings.
Neaten cERROR and cFYI macros, reduce text space
~2.5K
Convert '__FILE__ ": " fmt' to '"%s: " fmt', __FILE__' to save text space
Surround macros with do {} while
Add parentheses to macros
Make statement expression macro from macro with assign
Remove now unnecessary parentheses from cFYI and cERROR uses
defconfig with CIFS support old
$ size fs/cifs/built-in.o
156012 1760 148 157920 268e0 fs/cifs/built-in.o
153508 1760 148 155416 25f18 fs/cifs/built-in.o
allyesconfig old:
309138 3864 74824 387826 5eaf2 fs/cifs/built-in.o
allyesconfig new
305655 3864 74824 384343 5dd57 fs/cifs/built-in.o
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Check whether index is within bounds before testing the element.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
In most cases, cifs_strndup is converting from Unicode (UCS2 / UTF-32) to
the configured local code page for the Linux mount (usually UTF8), so
Jeff suggested that to make it more clear that cifs_strndup is doing
a conversion not just memory allocation and copy, rename the function
to including "from_ucs" (ie Unicode)
Rename cifs_strlcpy_to_host to cifs_strndup since that better describes
what this function really does. Then, convert it to use the new string
conversion and measurement functions that work in units of bytes rather
than wide chars.
Acked-by: Suresh Jayaraman <sjayaraman@suse.de>
Working in units of words means we do a lot of unnecessary conversion back
and forth. Standardize on bytes instead since that's more useful for
allocating buffers and such. Also, remove hostlen_fromUCS since the new
function has a similar purpose.
Add a replacement function for cifs_strtoUCS_le. cifs_from_ucs2
takes args for the source and destination length so that we can ensure
that the function is confined within the intended buffers.
This should be the last big batch of whitespace/formatting fixes.
checkpatch warnings for the cifs directory are down about 90% and
many of the remaining ones are harder to remove or make the code
harder to read.
Various coding style problems found by running the new
checkpatch.pl script against fs/cifs. 3 more files
fixed up.
Also expand debug entry to show which character on a failed Unicode
mapping.
Acked-by: Shaggy <shaggy@us.ibm.com>
Following Shaggy's suggestion, do a better job on the unicode string
handling routines in cifs in specifying that the wchar_t are really
little endian widechars (__le16).
conversion routine part 2 of 3
Signed-off-by: Steve French (sfrench@us.ibm.com)
infrastructure for it.
Let it rip!
