path: root/fs/cifs/cifsacl.c
2009-07-09cifs: convert cifs_get_inode_info and non-posix readdir to use cifs_igetJeff Layton
cifs: convert cifs_get_inode_info and non-posix readdir to use cifs_iget Rather than allocating an inode and filling it out, have cifs_get_inode_info fill out a cifs_fattr and call cifs_iget. This means a pretty hefty reorganization of cifs_get_inode_info. For the readdir codepath, add a couple of new functions for filling out cifs_fattr's from different FindFile response infolevels. Finally, remove cifs_new_inode since there are no more callers. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-05-28cifs: clean up set_cifs_acl interfacesChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-05-28cifs: reorganize get_cifs_aclChristoph Hellwig
Thus spake Christoph: "But this whole set_cifs_acl function is a real mess anyway and needs some splitting up." With this change too, it's possible to call acl_to_uid_mode() with a NULL inode pointer. That (or something close to it) will eventually be necessary when cifs_get_inode_info is reorganized. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-07-24[CIFS] Fix warnings from checkpatchShirish Pargaonkar
2008-07-24[CIFS] Fix improper endian conversion of ACL subauth fieldShirish Pargaonkar
In mode_to_acl when converting a Unix mode to a Windows ACL the subauth fields of the SID in the ACL were translated incorrectly on bigendian architectures Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-07-12cifs: fix wksidarr declaration to be big-endian friendlyJeff Layton
The current definition of wksidarr works fine on little endian arches (since cpu_to_le32 is a no-op there), but on big-endian arches, it fails to compile with this error: error: braced-group within expression allowed only inside a function The problem is that this static declaration has cpu_to_le32 embedded within it, and that expands into a function macro. We need to use __constant_cpu_to_le32() instead. Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: Steven French <sfrench@us.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-09[CIFS] fix build warningSteve French
2008-04-29[CIFS] convert usage of implicit booleans to boolSteve French
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-04-09[CIFS] Fix acl length when very short ACL being modified by chmodSteve French
Signed-off-by: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-03-30cifs: fix misannotationsAl Viro
2008-03-14[CIFS] file create with acl support enabled is slowSteve French
Shirish Pargaonkar noted: With cifsacl mount option, when a file is created on the Windows server, exclusive oplock is broken right away because the get cifs acl code again opens the file to obtain security descriptor. The client does not have the newly created file handle or inode in any of its lists yet so it does not respond to oplock break and server waits for its duration and then responds to the second open. This slows down file creation signficantly. The fix is to pass the file descriptor to the get cifsacl code wherever available so that get cifs acl code does not send second open (NT Create ANDX) and oplock is not broken. CC: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-02-12[CIFS] patch to fix incorrect encoding of number of aces on set modeShirish Pargaonkar
This patch fixes an error in the experimental cifs acl code. During chmod, set security descriptor data (num aces) is not sent with little-endian encoding. Signed-off-by: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-02-12[CIFS] clean up some hard to read ifdefsSteve French
Christoph had noticed too many ifdefs in the CIFS code making it hard to read. This patch removes about a quarter of them from the C files in cifs by improving a few key ifdefs in the .h files. Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-02-07[CIFS] reduce checkpatch warningsSteve French
2007-12-31[CIFS] Allow setting mode via cifs aclSteve French
Requires cifsacl mount flag to be on and CIFS_EXPERIMENTAL enabled CC: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-12-05regression: cifs endianness bugAl Viro
access_flags_to_mode() gets on-the-wire data (little-endian) and treats it as host-endian. Introduced in commit e01b64001359034d04c695388870936ed3d1b56b ("[CIFS] enable get mode from ACL when cifsacl mount option specified") Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-25[CIFS] Fix check after use error in ACL codeSteve French
Spotted by the coverity scanner. CC: Adrian Bunk <bunk@kernel.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-11-08[CIFS] add mode to acl conversion helper functionSteve French
Acked-by: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-11-08[CIFS] Fix incorrect mode when ACL had deny access control entriesSteve French
When mounted with the cifsacl mount option, we were treating any deny ACEs found like allow ACEs and it turns out for SFU and SUA Windows set these type of access control entries often. The order of ACEs is important too. The canonical order that most ACL tools and Windows explorer consruct ACLs with is to begin with DENY entries then follow with ALLOW, otherwise an allow entry could be encountered first, making the subsequent deny entry like "dead code which would be superflous since Windows stops when a match is made for the operation you are trying to perform for your user We start with no permissions in the mode and build up as we find permissions (ie allow ACEs). This fixes deny ACEs so they affect the mask used to set the subsequent allow ACEs. Acked-by: Shirish Pargaonkar <shirishp@us.ibm.com> CC: Alexander Bokovoy <ab@samba.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-11-05[CIFS] Fix walking out end of cifs daclSteve French
2007-11-01[CIFS] If no Access Control Entries, set mode perm bits to zeroSteve French
Also clean up ACL code Acked-by: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-10-31[CIFS] Don't request too much permission when reading an ACLSteve French
We were requesting GENERIC_READ but that fails when we do not have read permission on the file (even if we could read the ACL). Also move the dump access control entry code into debug ifdef. Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-10-30[CIFS] enable get mode from ACL when cifsacl mount option specifiedShirish Pargaonkar
Part 9 of ACL patch series. getting mode from ACL now works in some cases (and requires CIFS_EXPERIMENTAL config option). Signed-off-by: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-10-26[CIFS] ACL support part 8Steve French
Now GetACL in getinodeinfo path when cifsacl mount option used, and ACL is parsed for SIDs. Missing only one piece now to be able to retrieve the mode Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-10-26[CIFS] acl support part 7Steve French
Also fixes typo, build break Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-10-25[CIFS] acl support part 6Steve French
Acked-by: Shirish Pargaonkar <shirishp@us.ibm.com> CC: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-10-23[CIFS] acl support part 6Steve French
2007-10-19[CIFS] ACL support part 5Steve French
2007-10-17[CIFS] fix typoSteve French
2007-10-17[CIFS] acl support part 4Steve French
2007-10-17[CIFS] build breakSteve French
2007-10-17[CIFS] endian fixesSteve French
2007-10-16[CIFS] endian fixes in new acl codeDave Kleikamp
Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-10-16[CIFS] Fix some endianness problems in new acl codeSteve French
2007-10-12[CIFS] remove compile warnings when debug disabledSteve French
2007-10-12[CIFS] CIFS ACL support part 3Steve French
2007-10-03[CIFS] Cleanup formattingSteve French
2007-10-03[CIFS] CIFS ACL support (part 2)Shirish Pargaonkar
2007-10-01[CIFS] change misleading field nameSteve French
num_auth is really num_subauth in ACL terminology Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-09-25[CIFS] fix cut and paste error - missing defines cause cifsacl build errorSteve French
2007-09-25[CIFS] move cifs acl code to new file and fix build breakSteve French
