path: root/fs/cifs/cifspdu.h
2006-10-02[CIFS] Allow for 15 minute TZs (e.g. Nepal) and be more explicit aboutSteve French
not setting time on close Signed-off-by: Guenter Kukkukk <linux@kukkukk.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-09-30[CIFS] Do not send newer QFSInfo to legacy servers which can not support itSteve French
Fix dialect negotiation to save off when we have negotiated lanman. This allows us to avoid sending some somewhat newer requests that the server can not handle and go directly to the older version (infolevel) of the same call. Make sure we try to negotiate a level which allows us to get the server OS (which we check so we can detect Win9x vs. other legacy servers and eventually work around the Win9x DOS time bug (they reverse date/time fields). Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-09-30[CIFS] Rename server time zone fieldSteve French
Server time zone is not really a time zone, rather a time adjustement in seconds. CC: Guenter Kukkukk <linux@kukkukk.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-09-21[CIFS] Support deep tree mounts (e.g. mounts to //server/share/path)Steve French
Samba bugzilla #4040 Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-06-07[CIFS] Add support for readdir to legacy serversSteve French
Fixes oops to OS/2 on ls and removes redundant NTCreateX calls to servers which do not support NT SMBs. Key operations to OS/2 work. Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-06-05[CIFS] NTLMv2 support part 3Steve French
Response struct filled in exacty for 16 byte hash which we need to check more to make sure it works. Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-06-05[CIFS] NTLMv2 support part 2Steve French
Still need to fill in response structure and check that hash works Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-06-04CIFS] Support for older servers which require plaintext passwords - part 2Steve French
2006-06-01[CIFS] Support for setting up SMB sessions to legacy lanman servers part 2Steve French
2006-05-31[CIFS] Support for setting up SMB sessions to legacy lanman serversSteve French
2006-03-02[CIFS] Make POSIX CIFS Extensions SetFSInfo match exactly what we wantSteve French
not just the posix path feature. Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-02-28[CIFS] Add posix (advisory) byte range locking support to cifs clientSteve French
Samba (version 3) server support for this is also currently being done. This client code is in an experimental path (requires enabling /proc/fs/cifs/Experimental) while it is being tested. Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-01-12[CIFS] Add worker function for Get ACL cifs styleSteve French
2005-12-12[CIFS] Avoid extra large buffer allocation (and memcpy) in cifs_readpagesSteve French
2005-12-01[CIFS] Kerberos and CIFS ACL support part 1Steve French
2005-11-18[CIFS] Fix mknod of block and chardev over SFU mountsSteve French
2005-10-27[CIFS] Change pragma pack(1) to attribute(packed) to allow cifs on arm to accessSteve French
unaligned structures coming in off the wire gcc on arm processors generates very odd code with pragma pack specified - although it does pack the structures in some sense - it does not allow you to access unaligned elements in nested structures at the right offset as other architectures do. Oddly enough though, specifying the structures as packed the long way - one by one with the packed attribute does work. Rather than fighting over whether this is a gcc bug or some obscure side effect of pragma pack, it is easier to do what most (all but 96 other places in the kernel) do - and replace pragma pack with dozens of attribute(packed) structure qualifiers. Much more verbose ... but at least it works. Signed-off-by: David Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com> CG: -----------------------------------------------------------------------
2005-09-22[CIFS] Various minor bigendian fixes and sparse level 2 warning message fixesSteve French
Most important of these fixes mapchars on bigendian and a few statfs fields Signed-off-by: Shaggy (shaggy@austin.ibm.com) Signed-off-by: Steve French (sfrench@us.ibm.com)
2005-09-21[CIFS] Add support for legacy servers part nine. statfs (df and du) is nowSteve French
functional, and the length check is fixed so readdir does not throw a warning message when windows me messes up the response to FindFirst of an empty dir (with only . and ..). Signed-off-by: Steve French (sfrench@us.ibm.com)
2005-08-24[CIFS] Support for legacy servers part 3 - Add support for Open and mostSteve French
of Read support. Signed-off-by: Steve French <sfrench@us.ibm.com>
2005-08-24[CIFS] Change notify support part 2Steve French
Signed-off-by: Asser Ferno <asser@diku.dk> Signed-off-by: Steve French <sfrench@us.ibm.com> and lightly modified
2005-08-23[CIFS] Support for mounting to older servers part 2. Add support forSteve French
legacy getattr (lookup). Signed-off-by: Steve French (sfrench@us.ibm.com)
2005-08-17[CIFS] Ensure that cifs multiplex ids do not collide.Steve French
2005-07-21[CIFS] Add compat with SFU (part 2)Steve French
Creating FIFOs to non-Unix servers (with cifs mounts for which sfu option was specified) now works. Signed-off-by: Steve French (sfrench@us.ibm.com) Thanks to Martin Koeppe for his assistance
2005-06-22[CIFS] POSIX extensions, SetFSInfo addedJeremy Allison
Signed-off-by: Steve French@sfrench@us.ibm.com Signed-off-by: Jeremy Allison (jra@samba.org)
2005-04-28[PATCH] cifs: Handle multiple response transact2 part 1 of 2Steve French
Signed-off-by: Steve French (sfrench@us.ibm.com) Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-28[PATCH] cifs: CIFS ioctl needed by umount.cifs utilitySteve French
2005-04-28[PATCH] cifs: Enable ioctl support in POSIX extensions to handle lsattrSteve French
remove sparse warnings, unnecessary pad in QueryFileInfo and redundant function define. Signed-off-by: Steve French (sfrench@us.ibm.com) Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-28[PATCH] cifs: add support for chattr/lsattr in new CIFS POSIX extensionsSteve French
