error
Thanks to Adrian Bunk for debugging the problem and to Shaggy for
helping find the solution.
Also added a fix for 64K pages we found in loosely-related testing
Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org>
Fix Samba bugzilla bug 3301
In share mode encrypted password must be sent on tree connection (in our
case only the NTLM password is sent, not the older LANMAN one).
memcpy. Part 1
the request queue. Also periodically wakeup response_q so threads can
check if stuck requests have timed out. Workaround Windows server illegal smb
length on transact2 findfirst response.
(and a ppc64 compiler warning)
Following Shaggy's suggestion, do a better job on the unicode string
handling routines in cifs in specifying that the wchar_t are really
little endian widechars (__le16).
Add cifs extended stats configure option and reduce experimental code.
Signed-off-by: Steve French (sfrench@us.ibm.com)
eliminate the double copy, and improve cifs write performance and
help the server by upping the typical write size from 4K to 16K
(or even larger if wsize set explicitly) for servers which support this.
Part 1 of 2
Most important of these fixes mapchars on bigendian and a few statfs fields
Signed-off-by: Shaggy (shaggy@austin.ibm.com)
functional, and the length check is fixed so readdir does not throw a
warning message when windows me messes up the response to FindFirst
of an empty dir (with only . and ..).
ME, and do not set ctime unless explicitly requested with atime and/or
mtime (it gets thrown away by most servers anyway as there is no way to set
this via posix).
begin implementation of Win9x style set file size via open then
write of zero bytes.
Handle small negotiated read sizes (under 4K) and finish up
read and write support.
Fix WriteX support for old servers which do not support large
files.
of Read support.
Signed-off-by: Asser Ferno <asser@diku.dk>
Signed-off-by: Steve French <sfrench@us.ibm.com> and lightly modified
Make cifs_stats code conditional in the header files to avoid ifdefs in the
main code.
legacy getattr (lookup).
missing. Most importantly SMB reads were undercounted.
redundant null pointer checks before cifs_buf_release.
Found by coverity analyzer.
more than 50 (or so) of such long search entries in the directory. FindNext
could send corrupt last byte of resume name when resume key was a few hundred
bytes long file name or longer.
Fixes Samba Bug # 2932
Creating FIFOs to non-Unix servers (with cifs mounts for which sfu option
was specified) now works.
Thanks to Martin Koeppe for his assistance
rsync://rsync.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6.git
Signed-off-by: Steve French@sfrench@us.ibm.com
Signed-off-by: Jeremy Allison (jra@samba.org)
For older servers which do not support Unicode
if cifsd thread is no longer running to demultixplex responses.
Do not send FindClose request when FindFirst failed without reaching end
of search.
(part 2 of 2)
lock requests.
pointed out by Dave Stahl and Vince Negri in which cifs can update the
last modify time on a server modified file without invalidating the
local cached data due to an intervening readdir.
remove sparse warnings, unnecessary pad in QueryFileInfo and redundant
function define.
infrastructure for it.
Let it rip!
