commit b1d93356427be6f050dc55c86eb019d173700af6 upstream.
setfacl over cifs mounts can remove the default ACL when setting the
(non-default part of) the ACL and vice versa (we were leaving at 0
rather than setting to -1 the count field for the unaffected
half of the ACL. For example notice the setfacl removed
the default ACL in this sequence:
steven@steven-GA-970A-DS3:~/cifs-2.6$ getfacl /mnt/test-dir ; setfacl
-m default:user:test:rwx,user:test:rwx /mnt/test-dir
getfacl: Removing leading '/' from absolute path names
user::rwx
group::r-x
other::r-x
default:user::rwx
default:group::r-x
default:mask::rwx
default:other::r-x
user::rwx
user:test:rwx
group::r-x
mask::rwx
other::r-x
Signed-off-by: Steve French <smfrench@gmail.com>
Acked-by: Jeremy Allison <jra@samba.org>
Currently, the signing routines take a pointer to a place to store the
expected sequence number for the mid response. It then stores a value
that's one below what that sequence number should be, and then adds one
to it when verifying the signature on the response.
Increment the sequence number before storing the value in the mid, and
eliminate the "+1" when checking the signature.
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
It's not obvious from reading the macro names that these macros
are for debugging. Convert the names to a single more typical
kernel style cifs_dbg macro.
cERROR(1, ...) -> cifs_dbg(VFS, ...)
cFYI(1, ...) -> cifs_dbg(FYI, ...)
cFYI(DBG2, ...) -> cifs_dbg(NOISY, ...)
Move the terminating format newline from the macro to the call site.
Add CONFIG_CIFS_DEBUG function cifs_vfs_err to emit the
"CIFS VFS: " prefix for VFS messages.
Size is reduced ~ 1% when CONFIG_CIFS_DEBUG is set (default y)
$ size fs/cifs/cifs.ko*
265245 2525 132 267902 4167e fs/cifs/cifs.ko.new
268359 2525 132 271016 422a8 fs/cifs/cifs.ko.old
Other miscellaneous changes around these conversions:
o Miscellaneous typo fixes
o Add terminating \n's to almost all formats and remove them
from the macros to be more kernel style like. A few formats
previously had defective \n's
o Remove unnecessary OOM messages as kmalloc() calls dump_stack
o Coalesce formats to make grep easier,
added missing spaces when coalescing formats
o Use %s, __func__ instead of embedded function name
o Removed unnecessary "cifs: " prefixes
o Convert kzalloc with multiply to kcalloc
o Remove unused cifswarn macro
This replaces calls to kmalloc followed by memcpy with a single call to
kmemdup. This was found via make coccicheck.
Signed-off-by: Silviu-Mihai Popescu <silviupopescu1990@gmail.com>
We had a recent fix to fix the release of pagecache pages when
cifs_writev_requeue writes fail. Unfortunately, it releases the page
before trying to unlock it. At that point, the page might be gone by the
time the unlock comes in.
Unlock the page first before checking the value of "rc", and only then
end writeback and release the pages. The page lock isn't required for
any of those operations so this should be safe.
Reported-by: Anton Altaparmakov <aia21@cam.ac.uk>
Pages get the PG_writeback flag set before cifs sends its
request to SMB server in cifs_writepages(), if the SMB service
goes down, cifs may try to recommit the writing requests in
cifs_writev_requeue(). However, it does not clean its PG_writeback
flag and relaimed the pages even if it fails again in
cifs_writev_requeue(), which may lead to the hanging of the
processes accessing the cifs directory. This patch just cleans
the PG_writeback flags and reclaims the pages under that circumstances.
Steps to reproduce the bug(trying serveral times may trigger the issue):
1.Write from cifs client continuously.(e.g dd if=/dev/zero of=<cifs file>)
2.Stop SMB service from server.(e.g service smb stop)
3.Wait for two minutes, and then start SMB service from
server.(e.g service smb start)
4.The processes which are accessing cifs directory may hang up.
Signed-off-by: Ouyang Maochun <ouyang.maochun@zte.com.cn>
Signed-off-by: Jiang Yong <jian.yong5@zte.com.cn>
Tested-by: Zhang Xianwei <zhang.xianwei8@zte.com.cn>
Reviewed-by: Wang Liang <wang.liang82@zte.com.cn>
Reviewed-by: Cai Qu <cai.qu@zte.com.cn>
Reviewed-by: Jiang Biao <jiang.biao2@zte.com.cn>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Reviewed-by: Pavel Shilovsky <piastry@etersoft.ru>
Use INVALID_UID and INVALID_GID instead of NO_CHANGE_64 to indicate
the value should not be changed.
In cifs_fill_unix_set_info convert from kuids and kgids into uids and
gids that will fit in FILE_UNIX_BASIC_INFO.
Cc: Steve French <smfrench@gmail.com>
Rebased and resending the patch.
Path based queries can fail for lack of access, especially during lookup
during open.
open itself would actually succeed becasue of back up intent bit
but queries (either path or file handle based) do not have a means to
specifiy backup intent bit.
So query the file info during lookup using
trans2 / findfirst / file_id_full_dir_info
to obtain file info as well as file_id/inode value.
Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
Acked-by: Jeff Layton <jlayton@samba.org>
The array is no longer needed. We just need a single kvec to hold the
header for signature checking.
Replace the "marshal_iov" function with a "read_into_pages" function.
That function will copy the read data off the socket and into the
pages array, kmapping and reading pages one at a time.
Reviewed-by: Pavel Shilovsky <pshilovsky@samba.org>
For now, none of the callers populate rq_pages. That will be done for
writes in a later patch. While we're at it, change the prototype of
setup_async_request not to need a return pointer argument. Just
return the pointer to the mid_q_entry or an ERR_PTR.
We need a way to represent a call to be sent on the wire that does not
require having all of the page data kmapped. Behold the smb_rqst struct.
This new struct represents an array of kvecs immediately followed by an
array of pages.
Convert the signing routines to use these structs under the hood and
turn the existing functions for this into wrappers around that. For now,
we're just changing these functions to take different args. Later, we'll
teach them how to deal with arrays of pages.
Signed-off-by: Pavel Shilovsky <pshilovsky@samba.org>
This is help us to extend the code for future protocols that can use
another fid mechanism (as SMB2 that has it divided into two parts:
persistent and violatile).
Also rename variables and refactor the code around the changes.
Reviewed-by: Jeff Layton <jlayton@samba.org>
While trying to debug a SMB signature related issue with Windows Servers
figured out it might be easier to debug if we print the error code from
cifs_verify_signature(). Also, fix indendation while at it.
Signed-off-by: Suresh Jayaraman <sjayaraman@suse.com>
Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru>
and add negotiate request type to let set_credits know that
we are only on negotiate stage and no need to make a decision
about disabling echos and oplocks.
Acked-by: Jeff Layton <jlayton@redhat.com>
and rename variables around the code changes.
Split all requests to echos, oplocks and others - each group uses
its own credit slot. This is indicated by new flags
CIFS_ECHO_OP and CIFS_OBREAK_OP
that are not used now for CIFS. This change is required to support
SMB2 protocol because of different processing of these commands.
struct file_lock is pretty large, so we really don't want that on the
stack in a potentially long call chain. Reorganize the arguments to
CIFSSMBPosixLock to eliminate the need for that.
Eliminate the get_flag and simply use a non-NULL pLockInfo to indicate
that this is a "get" operation. In order to do that, need to add a new
loff_t argument for the start_offset.
Reported-by: Al Viro <viro@ZenIV.linux.org.uk>
Those macros add a newline on their own, so there's not any need to
embed one in the message itself.
Jian found that when he ran fsx on a 32 bit arch with a large wsize the
process and one of the bdi writeback kthreads would sometimes deadlock
with a stack trace like this:
crash> bt
PID: 2789 TASK: f02edaa0 CPU: 3 COMMAND: "fsx"
#0 [eed63cbc] schedule at c083c5b3
#1 [eed63d80] kmap_high at c0500ec8
#2 [eed63db0] cifs_async_writev at f7fabcd7 [cifs]
#3 [eed63df0] cifs_writepages at f7fb7f5c [cifs]
#4 [eed63e50] do_writepages at c04f3e32
#5 [eed63e54] __filemap_fdatawrite_range at c04e152a
#6 [eed63ea4] filemap_fdatawrite at c04e1b3e
#7 [eed63eb4] cifs_file_aio_write at f7fa111a [cifs]
#8 [eed63ecc] do_sync_write at c052d202
#9 [eed63f74] vfs_write at c052d4ee
#10 [eed63f94] sys_write at c052df4c
#11 [eed63fb0] ia32_sysenter_target at c0409a98
EAX: 00000004 EBX: 00000003 ECX: abd73b73 EDX: 012a65c6
DS: 007b ESI: 012a65c6 ES: 007b EDI: 00000000
SS: 007b ESP: bf8db178 EBP: bf8db1f8 GS: 0033
CS: 0073 EIP: 40000424 ERR: 00000004 EFLAGS: 00000246
Each task would kmap part of its address array before getting stuck, but
not enough to actually issue the write.
This patch fixes this by serializing the marshal_iov operations for
async reads and writes. The idea here is to ensure that cifs
aggressively tries to populate a request before attempting to fulfill
another one. As soon as all of the pages are kmapped for a request, then
we can unlock and allow another one to proceed.
There's no need to do this serialization on non-CONFIG_HIGHMEM arches
however, so optimize all of this out when CONFIG_HIGHMEM isn't set.
Cc: <stable@vger.kernel.org>
Reported-by: Jian Li <jiali@redhat.com>
Acked-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
As observed and suggested by Tushar Gosavi...
readdir calls these function to send TRANS2_FIND_FIRST and
TRANS2_FIND_NEXT command to the server. The current cifs module is
not specifying CIFS_SEARCH_BACKUP_SEARCH flag while sending these
command when backupuid/backupgid is specified. This can be resolved
by specifying CIFS_SEARCH_BACKUP_SEARCH flag.
Cc: <stable@kernel.org>
Reported-and-Tested-by: Tushar Gosavi <tugosavi@in.ibm.com>
This isn't strictly necessary for the async readpages code, but the
uncached version will need to be able to collect the replies after
issuing the calls. Add a kref to cifs_readdata and use change the
code to take and put references appropriately.
Cached and uncached reads will need to do different things here to
handle the difference when the pages are in pagecache and not. Abstract
out the function that marshals the page list into a kvec array.
We'll need different completion routines for an uncached read. Allow
the caller to set the one he needs at allocation time. Also, move
most of these functions to file.c so we can make more of them static.
The problem was that the first referral was parsed more than once
and so the caller tried the same referrals multiple times.
The problem was introduced partly by commit
066ce6899484d9026acd6ba3a8dbbedb33d7ae1b,
where 'ref += le16_to_cpu(ref->Size);' got lost,
but that was also wrong...
Signed-off-by: Stefan Metzmacher <metze@samba.org>
Tested-by: Björn Jacke <bj@sernet.de>
gcc-4.7.0 has started throwing these warnings when building cifs.ko.
CC [M] fs/cifs/cifssmb.o
fs/cifs/cifssmb.c: In function ‘CIFSSMBSetCIFSACL’:
fs/cifs/cifssmb.c:3905:9: warning: array subscript is above array bounds [-Warray-bounds]
fs/cifs/cifssmb.c: In function ‘CIFSSMBSetFileInfo’:
fs/cifs/cifssmb.c:5711:8: warning: array subscript is above array bounds [-Warray-bounds]
fs/cifs/cifssmb.c: In function ‘CIFSSMBUnixSetFileInfo’:
fs/cifs/cifssmb.c:6001:25: warning: array subscript is above array bounds [-Warray-bounds]
This patch cleans up the code a bit by using the offsetof macro instead
of the funky "&pSMB->hdr.Protocol" construct.
