path: root/fs/cifs/dir.c
2009-02-21[CIFS] improve posix semantics of file createSteve French
Samba server added support for a new posix open/create/mkdir operation a year or so ago, and we added support to cifs for mkdir to use it, but had not added the corresponding code to file create. The following patch helps improve the performance of the cifs create path (to Samba and servers which support the cifs posix protocol extensions). Using Connectathon basic test1, with 2000 files, the performance improved about 15%, and also helped reduce network traffic (17% fewer SMBs sent over the wire) due to saving a network round trip for the SetPathInfo on every file create. It should also help the semantics (and probably the performance) of write (e.g. when posix byte range locks are on the file) on file handles opened with posix create, and adds support for a few flags which would have to be ignored otherwise. Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-01-29[CIFS] some cleanup to dir.c prior to addition of posix_openSteve French
2008-12-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: (31 commits) [CIFS] Remove redundant test [CIFS] make sure that DFS pathnames are properly formed Remove an already-checked error condition in SendReceiveBlockingLock Streamline SendReceiveBlockingLock: Use "goto out:" in an error condition Streamline SendReceiveBlockingLock: Use "goto out:" in an error condition [CIFS] Streamline SendReceive[2] by using "goto out:" in an error condition Slightly streamline SendReceive[2] Check the return value of cifs_sign_smb[2] [CIFS] Cleanup: Move the check for too large R/W requests [CIFS] Slightly simplify wait_for_free_request(), remove an unnecessary "else" branch Simplify allocate_mid() slightly: Remove some unnecessary "else" branches [CIFS] In SendReceive, move consistency check out of the mutexed region cifs: store password in tcon cifs: have calc_lanman_hash take more granular args cifs: zero out session password before freeing it cifs: fix wait_for_response to time out sleeping processes correctly [CIFS] Can not mount with prefixpath if root directory of share is inaccessible [CIFS] various minor cleanups pointed out by checkpatch script [CIFS] fix typo [CIFS] remove sparse warning ... Fix trivial conflict in fs/cifs/cifs_fs_sb.h due to comment changes for the CIFS_MOUNT_xyz bit definitions between cifs updates and security updates.
2008-12-26[CIFS] various minor cleanups pointed out by checkpatch scriptSteve French
2008-11-14CRED: Wrap task credential accesses in the CIFS filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Steve French <sfrench@samba.org> Cc: linux-cifs-client@lists.samba.org Signed-off-by: James Morris <jmorris@namei.org>
2008-08-06[CIFS] cifs_mkdir and cifs_create should respect the setgid bit on parent dirJeff Layton
If a server supports unix extensions but does not support POSIX create routines, then the client will create a new inode with a standard SMB mkdir or create/open call and then will set the mode. When it does this, it does not take the setgid bit on the parent directory into account. This patch has CIFS flip on the setgid bit when the parent directory has it. If the share is mounted with "setuids" then also change the group owner to the gid of the parent. This patch should apply cleanly on top of the setattr cleanup patches that I sent a few weeks ago. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-08-06bundle up Unix SET_PATH_INFO args into a struct and change nameJeff Layton
We'd like to be able to use the unix SET_PATH_INFO_BASIC args to set file times as well, but that makes the argument list rather long. Bundle up the args for unix SET_PATH_INFO call into a struct. For now, we don't actually use the times fields anywhere. That will be done in a follow-on patch. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-23when creating new inodes, use file_mode/dir_mode exclusively on mount ↵Jeff Layton
without unix extensions When CIFS creates a new inode on a mount without unix extensions, it temporarily assigns the mode that was passed to it in the create/mkdir call. Eventually, when the inode is revalidated, it changes to have the file_mode or dir_mode for the mount. This is confusing to users who expect that the mode shouldn't change this way. It's also problematic since only the mode is treated this way, not the uid or gid. Suppose you have a CIFS mount that's mounted with: uid=0,gid=0,file_mode=0666,dir_mode=0777 ...if an unprivileged user comes along and does this on the mount: mkdir -m 0700 foo touch foo/bar ...there is a period of time where the touch will fail, since the dir will initially be owned by root and have mode 0700. If the user waits long enough, then "foo" will be revalidated and will get the correct dir_mode permissions. This patch changes cifs_mkdir and cifs_create to not overwrite the mode found by the initial cifs_get_inode_info call after the inode is created on the server. Legacy behavior can be reenabled with the new "dynperm" mount option. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-15[CIFS] suppress duplicate warningSteve French
fs/cifs/dir.c: In function 'cifs_ci_compare': fs/cifs/dir.c:582: warning: passing argument 1 of 'memcpy' discards qualifiers from pointer target type Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-15[CIFS] Fix paths when share is in DFS to include proper prefixSteve French
Some versions of Samba (3.2-pre e.g.) are stricter about checking to make sure that paths in DFS name spaces are sent in the form \\server\share\dir\subdir ... instead of \dir\subdir Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-11[CIFS] when not using unix extensions, check for and set ATTR_READONLY on ↵Jeff Layton
create and mkdir When creating a directory on a CIFS share without POSIX extensions, and the given mode has no write bits set, set the ATTR_READONLY bit. When creating a file, set ATTR_READONLY if the create mode has no write bits set and we're not using unix extensions. There are some comments about this being problematic due to the VFS splitting creates into 2 parts. I'm not sure what that's actually talking about, but I'm assuming that it has something to do with how mknod is implemented. In the simple case where we have no unix extensions and we're just creating a regular file, there's no reason we can't set ATTR_READONLY. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-04-29[CIFS] convert usage of implicit booleans to boolSteve French
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-03-14[CIFS] file create with acl support enabled is slowSteve French
Shirish Pargaonkar noted: With cifsacl mount option, when a file is created on the Windows server, exclusive oplock is broken right away because the get cifs acl code again opens the file to obtain security descriptor. The client does not have the newly created file handle or inode in any of its lists yet so it does not respond to oplock break and server waits for its duration and then responds to the second open. This slows down file creation signficantly. The fix is to pass the file descriptor to the get cifsacl code wherever available so that get cifs acl code does not send second open (NT Create ANDX) and oplock is not broken. CC: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-02-07[CIFS] reduce checkpatch warningsSteve French
2008-01-20[CIFS] Do not log path names in lookup errorsSteve French
Andi Kleen noticed that we were logging access denied errors (which is noisy in the dmesg log, and not needed to be logged) and that we were logging path names on that an other errors (e.g. EIO) which we should not be doing. CC: Andi Kleen <ak@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-10-23[CIFS] acl support part 6Steve French
2007-09-29[CIFS] named pipe support (part 2)Steve French
Also fixes typo which could cause build break Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-09-28[CIFS] CIFS support for named pipes (part 1)Steve French
This allows cifs to mount to ipc shares (IPC$) which will allow user space applications to layer over authenticated cifs connections (useful for Wine and others that would want to put DCE/RPC over CIFS or run CIFS named pipes) Acked-by: Rob Shearman <rob@codeweavers.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-08-31[CIFS] Fix warnings shown by newer version of sparseSteve French
2007-07-18[CIFS] Allow disabling CIFS Unix Extensions as mount optionSteve French
Previously the only way to do this was to umount all mounts to that server, turn off a proc setting (/proc/fs/cifs/LinuxExtensionsEnabled). Fixes Samba bugzilla bug number: 4582 (and also 2008) Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-07-11[CIFS] Fix oops in cifs_create when nfsd server exports cifs mountSteve French
nfsd is passing null nameidata (probably the only one doing that) on call to create - cifs was missing one check for this. Note that running nfsd over a cifs mount requires specifying fsid on the nfs exports entry and requires mounting cifs with serverino mount option. Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-07-10[CIFS] whitespace cleanupSteve French
More than halfway there Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-06-08[CIFS] CIFS should honour umaskSteve French
This patch makes CIFS honour a process' umask like other filesystems. Of course the server is still free to munge the permissions if it wants to; but the client will send the "right" permissions to begin with. A few caveats: 1) It only applies to filesystems that have CAP_UNIX (aka support unix extensions) 2) It applies the correct mode to the follow up CIFSSMBUnixSetPerms() after remote creation When mode to CIFS/NTFS ACL mapping is complete we can do the same thing for that case for servers which do not support the Unix Extensions. Signed-off-by: Matt Keenen <matt@opcode-solutions.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-06-05[CIFS] whitespace cleanup part 2Steve French
Various coding style problems found by running the new checkpatch.pl script against fs/cifs. 3 more files fixed up. Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-06-05[CIFS] whitespace cleanupSteve French
Various coding style problems found by running fs/cifs against the new checkpatch.pl script. Since there were too many to fit in one patch. Updated the first four files. Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-05-03[CIFS] Change semaphore to mutex for cifs lock_semRoland Dreier
Originally at http://lkml.org/lkml/2006/9/2/86 The recent change to "allow Windows blocking locks to be cancelled via a CANCEL_LOCK call" introduced a new semaphore in struct cifsFileInfo, lock_sem. However, semaphores used as mutexes are deprecated these days, and there's no reason to add a new one to the kernel. Therefore, convert lock_sem to a struct mutex (and also fix one indentation glitch on one of the lines changed anyway). Signed-off-by: Roland Dreier <roland@digitalvampire.org> Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-02-27[CIFS] Remove some unused functions/declarationsSteve French
2006-09-21[CIFS] Support deep tree mounts (e.g. mounts to //server/share/path)Steve French
Samba bugzilla #4040 Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-08-15[CIFS] Fix oops in cifs_close due to unitialized lock sem and list inSteve French
new POSIX locking code Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-06-07[CIFS] Add support for readdir to legacy serversSteve French
Fixes oops to OS/2 on ls and removes redundant NTCreateX calls to servers which do not support NT SMBs. Key operations to OS/2 work. Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-05-31[CIFS] Support for setting up SMB sessions to legacy lanman serversSteve French
2006-05-31[CIFS] Cleanup extra whitespace in dmesg logging. Update cifs change logSteve French
2006-04-21[CIFS] Don't allow a backslash in a path componentSteve French
Unless Posix paths have been negotiated, the backslash, "\", is not a valid character in a path component. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-04-21[CIFS] [CIFS] Do not take rename sem on most path based calls (duringSteve French
building of full path) to avoid hang rename/readdir hang Reported by Alan Tyson Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-03-31Merge with /pub/scm/linux/kernel/git/torvalds/linux-2.6.gitSteve French
2006-03-23[PATCH] sem2mutex: vfs_rename_mutexArjan van de Ven
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-09[CIFS] Fix two remaining coverity scan tool warnings.Steve French
2006-02-21[CIFS] Convert remaining places in fs/cifs fromEric Sesterhenn
kmalloc/memset to simpler kzalloc usage Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2005-12-01[CIFS] Use fsuid (fsgid) more consistently instead of uid/gid inSteve French
assembling smb requests when setuids and Linux protocol extensions enabled and in checking more matching sessions in multiuser mount mode. Pointed out by Shaggy. Signed-off-by: Steve French <sfrench@us.ibm.com>
2005-11-29[CIFS] Fix missing permission check on setattr when noperm mount option isSteve French
disabled. Also set mode, uid, gid better on mkdir and create for the case when Unix Extensions is not enabled and setuids is enabled. This is necessary to fix the hole in which chown could be allowed for non-root users in some cases if root mounted, and also to display the mode and uid properly in some cases. Signed-off-by: Steve French <sfrench@us.ibm.com>
2005-11-28[CIFS] When file is deleted locally but later recreated on the serverSteve French
fix cifs negative dentries so they are freed faster (not requiring umount or readdir e.g.) so the client recognizes the new file on the server more quickly. Signed-off-by: Steve French <sfrench@us.ibm.com>
2005-11-18[CIFS] Fix mknod of block and chardev over SFU mountsSteve French
2005-10-21Merge with /pub/scm/linux/kernel/git/sfrench/cifs-2.6.git/Steve French
2005-09-07[PATCH] cifs_create() fixMiklos Szeredi
cifs_create() did totally the wrong thing with nd->intent.open.flags: it interpreted nd->intent.open.flags as the original open flags, not the one transformed for open_namei(). Also it used the intent data even if it was not filled in (if called from sys_mknod()). Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Cc: <viro@parcelfarce.linux.theplanet.co.uk> Cc: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-30[CIFS] Remove cifs_sb argument from *build_path_from_dentrySteve French
This argument was added in a recent patch, but is unnecessary, since the superblock is easily obtained from the dentry. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2005-08-24[CIFS] Support for legacy servers part 3 - Add support for Open and mostSteve French
of Read support. Signed-off-by: Steve French <sfrench@us.ibm.com>
2005-08-22[CIFS] Finish up of case-insensitive dentry handling for cifs. ThisSteve French
will eventually (or should eventually) be common code for jfs, smbfs, etc. but in the meantime is small enough and necessary when mounting case insensitive to Windows (nocase). Signed-off-by: Shaggy (shaggy@austin.ibm.com) Signed-off-by: Steve French (sfrench@us.ibm.com)
2005-08-13[CIFS] Add missing check for path name allocation failure. Remove fourSteve French
redundant null pointer checks before cifs_buf_release. Found by coverity analyzer. Signed-off-by: Steve French (sfrench@us.ibm.com)
2005-07-21[CIFS] Add compat with SFU (part 2)Steve French
Creating FIFOs to non-Unix servers (with cifs mounts for which sfu option was specified) now works. Signed-off-by: Steve French (sfrench@us.ibm.com) Thanks to Martin Koeppe for his assistance
2005-07-14[CIFS] Add compat with SFU (part 1)Steve French
This should help the case of creating fifos and other special files to servers which do not support the Unix extensions. Signed-off-by: Steve French (sfrench@us.ibm.com) Thanks to Martin Koeppe for his suggestions and good analysis
