Fixes Samba bugzilla bug # 4182
Rename by handle failures (retry after rename by path) were not
being returned back.
Signed-off-by: Steve French <sfrench@us.ibm.com>
Since cifs_unlink can also be called from rename path and there
was one report of oops am making the extra check for null inode.
heavy stress.
This patch converts the inode semaphore to a mutex. I have tested it on
XFS and compiled as much as one can consider on an ia64. Anyway your
luck with it might be different.
Modified-by: Ingo Molnar <mingo@elte.hu>
(finished the conversion)
Signed-off-by: Jes Sorensen <jes@sgi.com>
This patch add EXPORT_SYMBOL(filemap_write_and_wait) and use it.
See mm/filemap.c:
And changes the filemap_write_and_wait() and filemap_write_and_wait_range().
Current filemap_write_and_wait() doesn't wait if filemap_fdatawrite()
returns error. However, even if filemap_fdatawrite() returned an
error, it may have submitted the partially data pages to the device.
(e.g. in the case of -ENOSPC)
<quotation>
Andrew Morton writes,
If filemap_fdatawrite() returns an error, this might be due to some
I/O problem: dead disk, unplugged cable, etc. Given the generally
crappy quality of the kernel's handling of such exceptions, there's a
good chance that the filemap_fdatawait() will get stuck in D state
forever.
</quotation>
So, this patch doesn't wait if filemap_fdatawrite() returns the -EIO.
Trond, could you please review the nfs part? Especially I'm not sure,
nfs must use the "filemap_fdatawrite(inode->i_mapping) == 0", or not.
Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no>
assembling smb requests when setuids and Linux protocol extensions enabled
and in checking more matching sessions in multiuser mount mode.
Pointed out by Shaggy.
disabled. Also set mode, uid, gid better on mkdir and create for the
case when Unix Extensions is not enabled and setuids is enabled. This is
necessary to fix the hole in which chown could be allowed for non-root
users in some cases if root mounted, and also to display the mode and uid
properly in some cases.
fix cifs negative dentries so they are freed faster (not requiring
umount or readdir e.g.) so the client recognizes the new file on
the server more quickly.
so it does not return EACCESS (unless server really returns that).
Fix the case in which readdir reset file type when SFU mount option
specified.
Also fix sfu related functions to not request EAs (xattrs) when not
configured in Kconfig
FIFOs) created by SFU (part 2 of 2).
Thanks to Martin Koeppe for useful analysis.
created by SFU (part 1 of 2).
for all mounts just that particular mount.
Found by Arjan Vand de Ven
Add cifs extended stats configure option and reduce experimental code.
need to get in ahead of it that depend on that file handle. Fixes
occassional bad file handle errors on write with heavy use multiple process
cases.
Signed-off-by: Steve French (sfrench@us.ibm.com)
Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com>
ME, and do not set ctime unless explicitly requested with atime and/or
mtime (it gets thrown away by most servers anyway as there is no way to set
this via posix).
begin implementation of Win9x style set file size via open then
write of zero bytes.
Handle small negotiated read sizes (under 4K) and finish up
read and write support.
This argument was added in a recent patch, but is unnecessary, since
the superblock is easily obtained from the dentry.
legacy getattr (lookup).
will eventually (or should eventually) be common code for jfs, smbfs,
etc. but in the meantime is small enough and necessary when mounting
case insensitive to Windows (nocase).
Signed-off-by: Shaggy (shaggy@austin.ibm.com)
over the wire (to help the case when applications break with cifs mandatory
lock behavior. Add part one of mount option for requesting case
insensitive path name matching.
Creating FIFOs to non-Unix servers (with cifs mounts for which sfu option
was specified) now works.
Thanks to Martin Koeppe for his assistance
Signed-off-by: Steve French@sfrench@us.ibm.com
Signed-off-by: Jeremy Allison (jra@samba.org)
existing,
newly created, file.
Samba bugzilla: 2697
infrastructure for it.
Let it rip!
