When we obtain tcon from cifs_sb, we use cifs_sb_tlink() to first obtain
tlink which also grabs a reference to it. We do not drop this reference
to tlink once we are done with the call.
The patch fixes this issue by instead passing tcon as a parameter and
avoids having to obtain a reference to the tlink. A lookup for the tcon
is already made in the calling functions and this way we avoid having to
re-run the lookup. This is also consistent with the argument list for
other similar calls for M-F symlinks.
We should also return an ENOSYS when we do not find a protocol specific
function to lookup the MF Symlink data.
Signed-off-by: Sachin Prabhu <sprabhu@redhat.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
CC: Stable <stable@kernel.org>
Signed-off-by: Steve French <smfrench@gmail.com>
Now we treat any reparse point as a symbolic link and map it to a Unix
one that is not true in a common case due to many reparse point types
supported by SMB servers.
Distinguish reparse point types into two groups:
1) that can be accessed directly through a reparse point
(junctions, deduplicated files, NFS symlinks);
2) that need to be processed manually (Windows symbolic links, DFS);
and map only Windows symbolic links to Unix ones.
Cc: <stable@vger.kernel.org>
Acked-by: Jeff Layton <jlayton@redhat.com>
Reported-and-tested-by: Joao Correia <joaomiguelcorreia@gmail.com>
Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru>
Since we don't get info about the number of links from the readdir
linfo levels, stat() will return 0 for st_nlink, and in particular,
samba re-exported shares will show directories as files (as samba is
keying off st_nlink before evaluating how to set the dos modebits)
when doing a dir or ls.
Copy nlink to the inode, unless it wasn't provided. Provide
sane values if we don't have an existing one and none was provided.
Signed-off-by: Jim McDonough <jmcd@samba.org>
Reviewed-by: David Disseldorp <ddiss@samba.org>
Merge more patches from Andrew Morton:
"The rest of MM. Plus one misc cleanup"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (35 commits)
mm/Kconfig: add MMU dependency for MIGRATION.
kernel: replace strict_strto*() with kstrto*()
mm, thp: count thp_fault_fallback anytime thp fault fails
thp: consolidate code between handle_mm_fault() and do_huge_pmd_anonymous_page()
thp: do_huge_pmd_anonymous_page() cleanup
thp: move maybe_pmd_mkwrite() out of mk_huge_pmd()
mm: cleanup add_to_page_cache_locked()
thp: account anon transparent huge pages into NR_ANON_PAGES
truncate: drop 'oldsize' truncate_pagecache() parameter
mm: make lru_add_drain_all() selective
memcg: document cgroup dirty/writeback memory statistics
memcg: add per cgroup writeback pages accounting
memcg: check for proper lock held in mem_cgroup_update_page_stat
memcg: remove MEMCG_NR_FILE_MAPPED
memcg: reduce function dereference
memcg: avoid overflow caused by PAGE_ALIGN
memcg: rename RESOURCE_MAX to RES_COUNTER_MAX
memcg: correct RESOURCE_MAX to ULLONG_MAX
mm: memcg: do not trap chargers with full callstack on OOM
mm: memcg: rework and document OOM waiting and wakeup
truncate_pagecache() doesn't care about old size since commit
cedabed49b39 ("vfs: Fix vmtruncate() regression"). Let's drop it.
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
that prepare the code to handle different types of SMB2 leases.
Signed-off-by: Pavel Shilovsky <pshilovsky@samba.org>
that allows to access files through symlink created on a server.
Certain servers may not set the NumberOfLinks field in query file/path
info responses. In such a case, cifs_inode_needs_reval() assumes that
all regular files are hardlinks and triggers revalidation, leading to
excessive and unnecessary network traffic.
This change hardcodes cf_nlink (and subsequently i_nlink) when not
returned by the server, similar to what already occurs in cifs_mkdir().
Signed-off-by: David Disseldorp <ddiss@suse.de>
It's generally not safe to reset the inode ops once they've been set. In
the case where the inode was originally thought to be a directory and
then later found to be a DFS referral, this can lead to an oops when we
try to trigger an inode op on it after changing the ops to the blank
referral operations.
Reported-and-Tested-by: Sachin Prabhu <sprabhu@redhat.com>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
It's not obvious from reading the macro names that these macros
are for debugging. Convert the names to a single more typical
kernel style cifs_dbg macro.
cERROR(1, ...) -> cifs_dbg(VFS, ...)
cFYI(1, ...) -> cifs_dbg(FYI, ...)
cFYI(DBG2, ...) -> cifs_dbg(NOISY, ...)
Move the terminating format newline from the macro to the call site.
Add CONFIG_CIFS_DEBUG function cifs_vfs_err to emit the
"CIFS VFS: " prefix for VFS messages.
Size is reduced ~ 1% when CONFIG_CIFS_DEBUG is set (default y)
$ size fs/cifs/cifs.ko*
265245 2525 132 267902 4167e fs/cifs/cifs.ko.new
268359 2525 132 271016 422a8 fs/cifs/cifs.ko.old
Other miscellaneous changes around these conversions:
o Miscellaneous typo fixes
o Add terminating \n's to almost all formats and remove them
from the macros to be more kernel style like. A few formats
previously had defective \n's
o Remove unnecessary OOM messages as kmalloc() calls dump_stack
o Coalesce formats to make grep easier,
added missing spaces when coalescing formats
o Use %s, __func__ instead of embedded function name
o Removed unnecessary "cifs: " prefixes
o Convert kzalloc with multiply to kcalloc
o Remove unused cifswarn macro
NT_SHARING_VIOLATION errors are mapped to ETXTBSY which is unexpected
for operations such as unlink where we can hit these errors.
The patch maps the error NT_SHARING_VIOLATION to EBUSY instead. The
patch also replaces all instances of ETXTBSY in
cifs_rename_pending_delete() with EBUSY.
Signed-off-by: Steve French <sfrench@us.ibm.com>
cifs_rename_pending_delete() attempts to silly rename file using
CIFSSMBRenameOpenFile(). This uses the SET_FILE_INFORMATION TRANS2
command with information level set to the passthru info-level
SMB_SET_FILE_RENAME_INFORMATION.
We need to check to make sure that the server support passthru
info-levels before attempting the silly rename or else we will fail to
rename the file.
Fix check for error condition after setting attributes with
CIFSSMBSetFileInfo().
Reviewed-by: Pavel Shilovsky <piastry@etersoft.ru>
I'm not sure why, but the hlist for each entry iterators were conceived
list_for_each_entry(pos, head, member)
The hlist ones were greedy and wanted an extra parameter:
hlist_for_each_entry(tpos, pos, head, member)
Why did they need an extra pos parameter? I'm not quite sure. Not only
they don't really need it, it also prevents the iterator from looking
exactly like the list iterator, which is unfortunate.
Besides the semantic patch, there was some manual work required:
- Fix up the actual hlist iterators in linux/list.h
- Fix up the declaration of other iterators based on the hlist ones.
- A very small amount of places were using the 'node' parameter, this
was modified to use 'obj->member' instead.
- Coccinelle didn't handle the hlist_for_each_entry_safe iterator
properly, so those had to be fixed up manually.
The semantic patch which is mostly the work of Peter Senna Tschudin is here:
iterator name hlist_for_each_entry, hlist_for_each_entry_continue, hlist_for_each_entry_from, hlist_for_each_entry_rcu, hlist_for_each_entry_rcu_bh, hlist_for_each_entry_continue_rcu_bh, for_each_busy_worker, ax25_uid_for_each, ax25_for_each, inet_bind_bucket_for_each, sctp_for_each_hentry, sk_for_each, sk_for_each_rcu, sk_for_each_from, sk_for_each_safe, sk_for_each_bound, hlist_for_each_entry_safe, hlist_for_each_entry_continue_rcu, nr_neigh_for_each, nr_neigh_for_each_safe, nr_node_for_each, nr_node_for_each_safe, for_each_gfn_indirect_valid_sp, for_each_gfn_sp, for_each_host;
type T;
expression a,c,d,e;
identifier b;
statement S;
-T b;
<+... when != b
hlist_for_each_entry(a,
- b,
c, d) S
hlist_for_each_entry_continue(a,
- b,
c) S
hlist_for_each_entry_from(a,
- b,
c) S
hlist_for_each_entry_rcu(a,
- b,
c, d) S
hlist_for_each_entry_rcu_bh(a,
- b,
c, d) S
hlist_for_each_entry_continue_rcu_bh(a,
- b,
c) S
for_each_busy_worker(a, c,
- b,
d) S
ax25_uid_for_each(a,
- b,
c) S
ax25_for_each(a,
- b,
c) S
inet_bind_bucket_for_each(a,
- b,
c) S
sctp_for_each_hentry(a,
- b,
c) S
sk_for_each(a,
- b,
c) S
sk_for_each_rcu(a,
- b,
c) S
sk_for_each_from
-(a, b)
+(a)
S
+ sk_for_each_from(a) S
sk_for_each_safe(a,
- b,
c, d) S
sk_for_each_bound(a,
- b,
c) S
hlist_for_each_entry_safe(a,
- b,
c, d, e) S
hlist_for_each_entry_continue_rcu(a,
- b,
c) S
nr_neigh_for_each(a,
- b,
c) S
nr_neigh_for_each_safe(a,
- b,
c, d) S
nr_node_for_each(a,
- b,
c) S
nr_node_for_each_safe(a,
- b,
c, d) S
- for_each_gfn_sp(a, c, d, b) S
+ for_each_gfn_sp(a, c, d) S
- for_each_gfn_indirect_valid_sp(a, c, d, b) S
+ for_each_gfn_indirect_valid_sp(a, c, d) S
for_each_host(a,
- b,
c) S
for_each_host_safe(a,
- b,
c, d) S
for_each_mesh_entry(a,
- b,
c, d) S
[akpm@linux-foundation.org: drop bogus change from net/ipv4/raw.c]
[akpm@linux-foundation.org: drop bogus hunk from net/ipv6/raw.c]
[akpm@linux-foundation.org: checkpatch fixes]
[akpm@linux-foundation.org: fix warnings]
[akpm@linux-foudnation.org: redo intrusive kvm changes]
Tested-by: Peter Senna Tschudin <peter.senna@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
Pull vfs pile (part one) from Al Viro:
"Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent
locking violations, etc.
The most visible changes here are death of FS_REVAL_DOT (replaced with
"has ->d_weak_revalidate()") and a new helper getting from struct file
to inode. Some bits of preparation to xattr method interface changes.
Misc patches by various people sent this cycle *and* ocfs2 fixes from
several cycles ago that should've been upstream right then.
PS: the next vfs pile will be xattr stuff."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits)
saner proc_get_inode() calling conventions
proc: avoid extra pde_put() in proc_fill_super()
fs: change return values from -EACCES to -EPERM
fs/exec.c: make bprm_mm_init() static
ocfs2/dlm: use GFP_ATOMIC inside a spin_lock
ocfs2: fix possible use-after-free with AIO
ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path
get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero
target: writev() on single-element vector is pointless
export kernel_write(), convert open-coded instances
fs: encode_fh: return FILEID_INVALID if invalid fid_type
kill f_vfsmnt
vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op
nfsd: handle vfs_getattr errors in acl protocol
switch vfs_getattr() to struct path
default SET_PERSONALITY() in linux/elf.h
ceph: prepopulate inodes only when request is aborted
d_hash_and_lookup(): export, switch open-coded instances
9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate()
9p: split dropping the acls from v9fs_set_create_acl()
In cifs_unix_to_basic_fattr only update the cifs_fattr with an id if
it is valid after conversion.
Cc: Steve French <smfrench@gmail.com>
Use INVALID_UID and INVALID_GID instead of NO_CHANGE_64 to indicate
the value should not be changed.
In cifs_fill_unix_set_info convert from kuids and kgids into uids and
gids that will fit in FILE_UNIX_BASIC_INFO.
Update id_mode_to_cifs_acl to take a kuid_t and a kgid_t.
Replace NO_CHANGE_32 with INVALID_UID and INVALID_GID, and tests for
NO_CHANGE_32 with uid_valid and gid_valid.
Carefully unpack the value returned from request_key. memcpy the
value into the expected type. The convert the uid/gid into a
kuid/kgid. And then only if the result is a valid kuid or kgid update
fuid/fgid.
The cifs protocol has a 64bit space for uids and gids, while linux
only supports a 32bit space today. Instead of silently truncating
64bit cifs ids, replace cifs ids that do not fit in the 32bit linux
id space with the default uid and gids for the cifs mount.
If we're using cifsacl, then we don't want to override the uid/gid with
the current uid/gid, since that would prevent you from being able to
upcall for this info.
Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
Rebased and resending the patch.
Path based queries can fail for lack of access, especially during lookup
during open.
open itself would actually succeed becasue of back up intent bit
but queries (either path or file handle based) do not have a means to
specifiy backup intent bit.
So query the file info during lookup using
trans2 / findfirst / file_id_full_dir_info
to obtain file info as well as file_id/inode value.
Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
Acked-by: Jeff Layton <jlayton@samba.org>
Rename inode pointers for better clarity. Move the d_instantiate call to
the end of the function to prevent other tasks from seeing it before
we've finished constructing it. Since we should have exclusive access to
the inode at this point, remove the spinlock around i_nlink update.
and make cifs_get_file_info(_unix) calls static.
This is help us to extend the code for future protocols that can use
another fid mechanism (as SMB2 that has it divided into two parts:
persistent and violatile).
Also rename variables and refactor the code around the changes.
Reviewed-by: Jeff Layton <jlayton@samba.org>
that can cause warning messages. Pavel had initially
suggested a smaller patch around drop_nlink, after
a similar problem was discovered NFS. Protecting
additional places where nlink is touched was
suggested by Jeff Layton and is included in this.
Reviewed-by: Pavel Shilovsky <pshilovsky@samba.org>
Since both CIFS and SMB2 use ses->capabilities (server->capabilities)
field but flags are different we should make such checks protocol
independent.
Currently we do inc/drop_nlink for a parent directory for every
mkdir/rmdir calls. That's wrong when Unix extensions are disabled
because in this case a server doesn't follow the same semantic and
returns the old value on the next QueryInfo request. As the result,
we update our value with the server one and then decrement it on
every rmdir call - go to negative nlink values.
Fix this by removing inc/drop_nlink for the parent directory from
mkdir/rmdir, setting it for a revalidation and ignoring NumberOfLinks
for directories when Unix extensions are disabled.
vfs_mkdir() gets int, but immediately drops everything that might not
fit into umode_t and that's the only caller of ->mkdir()...
Replace remaining direct i_nlink updates with a new set_nlink()
updater function.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
We should call cifs_all_info_to_fattr in rc == 0 case only.
Cc: <stable@kernel.org>
Now build security descriptor to change either owner or group at the
server. Initially security descriptor was built to change only
(D)ACL, that functionality has been extended.
When either an Owner or a Group of a file object at the server is changed,
rest of security descriptor remains same (DACL etc.).
To set security descriptor, it is necessary to open that file
with permission bits of either WRITE_DAC if DACL is being modified or
WRITE_OWNER (Take Ownership) if Owner or Group is being changed.
It is the server that decides whether a set security descriptor with
either owner or group change succeeds or not.
Regression from 2.6.39...
The delimiters in the prefixpath are not being converted based on
whether posix paths are in effect. Fixes:
https://bugzilla.redhat.com/show_bug.cgi?id=727834
Reported-and-Tested-by: Iain Arnell <iarnell@gmail.com>
Reported-by: Patrick Oltmann <patrick.oltmann@gmx.net>
Cc: Pavel Shilovsky <piastryyy@gmail.com>
Cc: stable@kernel.org
secMode to sec_mode
and
cifsTconInfo to cifs_tcon
and
cifsSesInfo to cifs_ses
Add rwpidforward mount option that switches on a mode when we forward
pid of a process who opened a file to any read and write operation.
This can prevent applications like WINE from failing on read or write
operation on a previously locked file region from the same netfd from
another process if we use mandatory brlock style.
It is actual for WINE because during a run of WINE program two processes
work on the same netfd - share the same file struct between several VFS
fds:
1) WINE-server does open and lock;
2) WINE-application does read and write.
Now we point superblock to a server share root and set a root dentry
appropriately. This let us share superblock between mounts like
//server/sharename/foo/bar and //server/sharename/foo further.
We need it to make them work with mandatory locking style because
we can fail in a situation like when kernel need to flush dirty pages
and there is a lock held by a process who opened file.
Fix to earlier "Simplify invalidate part (try #6)" patch
That patch caused problems with connectathon test 5.
Simplify many places when we call cifs_revalidate/invalidate to make
it do what it exactly needs.
