commit 22783155f4bf956c346a81624ec9258930a6fe06 upstream.
Fixes problem pointed out by Pavel in discussions about commit
729c0c9dd55204f0c9a823ac8a7bfa83d36c7e78
Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com>
Signed-off-by: Steve French <stfrench@microsoft.com>
Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com>
CC: Stable <stable@vger.kernel.org> # 3.18.x+
they used to be used, but...
new method: ->get_link(); replacement of ->follow_link(). The differences
are:
* inode and dentry are passed separately
* might be called both in RCU and non-RCU mode;
the former is indicated by passing it a NULL dentry.
* when called that way it isn't allowed to block
and should return ERR_PTR(-ECHILD) if it needs to be called
in non-RCU mode.
It's a flagday change - the old method is gone, all in-tree instances
converted. Conversion isn't hard; said that, so far very few instances
do not immediately bail out when called in RCU mode. That'll change
in the next commits.
Pull vfs updates from Al Viro:
"In this pile: pathname resolution rewrite.
- recursion in link_path_walk() is gone.
- nesting limits on symlinks are gone (the only limit remaining is
that the total amount of symlinks is no more than 40, no matter how
nested).
- "fast" (inline) symlinks are handled without leaving rcuwalk mode.
- stack footprint (independent of the nesting) is below kilobyte now,
about on par with what it used to be with one level of nested
symlinks and ~2.8 times lower than it used to be in the worst case.
- struct nameidata is entirely private to fs/namei.c now (not even
opaque pointers are being passed around).
- ->follow_link() and ->put_link() calling conventions had been
changed; all in-tree filesystems converted, out-of-tree should be
able to follow reasonably easily.
For out-of-tree conversions, see Documentation/filesystems/porting
for details (and in-tree filesystems for examples of conversion).
That has sat in -next since mid-May, seems to survive all testing
without regressions and merges clean with v4.1"
* 'for-linus-1' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (131 commits)
turn user_{path_at,path,lpath,path_dir}() into static inlines
namei: move saved_nd pointer into struct nameidata
inline user_path_create()
inline user_path_parent()
namei: trim do_last() arguments
namei: stash dfd and name into nameidata
namei: fold path_cleanup() into terminate_walk()
namei: saner calling conventions for filename_parentat()
namei: saner calling conventions for filename_create()
namei: shift nameidata down into filename_parentat()
namei: make filename_lookup() reject ERR_PTR() passed as name
namei: shift nameidata inside filename_lookup()
namei: move putname() call into filename_lookup()
namei: pass the struct path to store the result down into path_lookupat()
namei: uninline set_root{,_rcu}()
namei: be careful with mountpoint crossings in follow_dotdot_rcu()
Documentation: remove outdated information from automount-support.txt
get rid of assorted nameidata-related debris
lustre: kill unused helper
lustre: kill unused macro (LOOKUP_CONTINUE)
its only use is getting passed to nd_jump_link(), which can obtain
it from current->nameidata
a) instead of storing the symlink body (via nd_set_link()) and returning
an opaque pointer later passed to ->put_link(), ->follow_link() _stores_
that opaque pointer (into void * passed by address by caller) and returns
the symlink body. Returning ERR_PTR() on error, NULL on jump (procfs magic
symlinks) and pointer to symlink body for normal symlinks. Stored pointer
is ignored in all cases except the last one.
Storing NULL for opaque pointer (or not storing it at all) means no call
of ->put_link().
b) the body used to be passed to ->put_link() implicitly (via nameidata).
Now only the opaque pointer is. In the cases when we used the symlink body
to free stuff, ->follow_link() now should store it as opaque pointer in addition
to returning it.
Cifs client has problem with reserved chars filename.
[BUG1] : several functions handle incorrect value of mapchars
- cifs_sb->mnt_cifs_flags & CIFS_MOUNT_MAP_SPECIAL_CHR);
+ cifs_remap(cifs_sb));
[BUG2] : forget to convert reserved chars when creating SymbolicLink.
- CIFSUnixCreateSymLink() calls cifs_strtoUTF16
+ CIFSUnixCreateSymLink() calls cifsConvertToUTF16() with remap
[BUG3] : forget to convert reserved chars when getting SymbolicLink.
- CIFSSMBUnixQuerySymLink() calls cifs_strtoUTF16
+ CIFSSMBUnixQuerySymLink() calls cifsConvertToUTF16() with remap
[BUG4] : /proc/mounts don't show "mapposix" when using mapposix mount option
+ cifs_sb->mnt_cifs_flags & CIFS_MOUNT_MAP_SFM_CHR)
+ seq_puts(s, ",mapposix");
Reported-by: t.wede@kw-reneg.de
Reported-by: Nakajima Akira <nakajima.akira@nttcom.co.jp>
Signed-off-by: Nakajima Akira <nakajima.akira@nttcom.co.jp>
Signed-off-by: Carl Schaefer <schaefer@trilug.org>
Signed-off-by: Steve French <smfrench@gmail.com>
that's the bulk of filesystem drivers dealing with inodes of their own
Signed-off-by: Steven French <smfrench@gmail.com>
This is a bigger patch, but its size is mostly due to
a single change for how we check for remapping illegal characters
in file names - a lot of repeated, small changes to
the way callers request converting file names.
The final patch in the series does the following:
1) changes default behavior for cifs to be more intuitive.
Currently we do not map by default to seven reserved characters,
ie those valid in POSIX but not in NTFS/CIFS/SMB3/Windows,
unless a mount option (mapchars) is specified. Change this
to by default always map and map using the SFM maping
(like the Mac uses) unless the server negotiates the CIFS Unix
Extensions (like Samba does when mounting with the cifs protocol)
when the remapping of the characters is unnecessary. This should
help SMB3 mounts in particular since Samba will likely be
able to implement this mapping with its new "vfs_fruit" module
as it will be doing for the Mac.
2) if the user specifies the existing "mapchars" mount option then
use the "SFU" (Microsoft Services for Unix, SUA) style mapping of
the seven characters instead.
3) if the user specifies "nomapposix" then disable SFM/MAC style mapping
(so no character remapping would be used unless the user specifies
"mapchars" on mount as well, as above).
4) change all the places in the code that check for the superblock
flag on the mount which is set by mapchars and passed in on all
path based operation and change it to use a small function call
instead to set the mapping type properly (and check for the
mapping type in the cifs unicode functions)
Adds support on SMB2.1 and SMB3 mounts for emulation of symlinks
via the "Minshall/French" symlink format already used for cifs
mounts when mfsymlinks mount option is used (and also used by Apple).
http://wiki.samba.org/index.php/UNIX_Extensions#Minshall.2BFrench_symlinks
This second patch adds support to query them (recognize them as symlinks
and read them). Third version of patch makes minor corrections
to error handling.
Reviewed-by: Stefan Metzmacher <metze@samba.org>
This first patch adds support to create them. The next patch will
add support for recognizing them and reading them. Although CIFS/SMB3
have other types of symlinks, in the many use cases they aren't
practical (e.g. either require cifs only mounts with unix extensions
to Samba, or require the user to be Administrator to Windows for SMB3).
This also helps enable running additional xfstests over SMB3 (since some
xfstests directly or indirectly require symlink support).
CC: Stefan Metzmacher <metze@samba.org>
If the mfsymlinks file size has changed (e.g. the file no longer
represents an emulated symlink) we were not returning an error properly.
We were not checking for symlink support properly for SMB2/SMB3
mounts so could oops when mounted with mfsymlinks when try
to create symlink when mfsymlinks on smb2/smb3 mounts
Cc: <stable@vger.kernel.org> # 3.14+
CC: Sachin Prabhu <sprabhu@redhat.com>
commit d81b8a40e2ece0a9ab57b1fe1798e291e75bf8fc
("CIFS: Cleanup cifs open codepath")
changed disposition to FILE_OPEN.
Signed-off-by: Björn Baumbach <bb@sernet.de>
Signed-off-by: Stefan Metzmacher <metze@samba.org>
Cc: <stable@vger.kernel.org> # v3.14+
Cc: Pavel Shilovsky <piastry@etersoft.ru>
Cc: Steve French <sfrench@samba.org>
MF Symlinks are regular files containing content in a specified format.
The function couldbe_mf_symlink() checks the mode for a set S_IFREG bit
as a test to confirm that it is a regular file. This bit is also set for
other filetypes and simply checking for this bit being set may return
false positives.
We ensure that we are actually checking for a regular file by using the
S_ISREG macro to test instead.
Signed-off-by: Sachin Prabhu <sprabhu@redhat.com>
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Reported-by: Neil Brown <neilb@suse.de>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Rename CIFSSMBOpen to CIFS_open and make it take
cifs_open_parms structure as a parm.
Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru>
Unix extensions rigth now are only applicable to smb1 operations.
Move the check and subsequent unix extension call to the smb1
specific call to query_symlink() ie. cifs_query_symlink().
This patch makes cosmetic changes. We group similar functions together
and separate out the protocol specific functions.
Add a new protocol ops function create_mf_symlink and have
create_mf_symlink() use it.
This patchset moves the MFSymlink operations completely to the
ops structure so that we only use the right protocol versions when
querying or creating MFSymlinks.
We have an existing protocol specific call query_mf_symlink() created
for check_mf_symlink which can also be used for query_mf_symlink().
Clean up camel case in functionnames.
Rename open_query_close_cifs_symlink to cifs_query_mf_symlink() to make
the name more consistent with other protocol version specific functions.
We also pass tcon as an argument to the function. This is already
available in the calling functions and we can avoid having to make an
unnecessary lookup.
Fix a potential memory leak in the cifs_hardlink() error handling path.
Detected by Coverity: CID 728510, CID 728511.
Signed-off-by: Christian Engelmayer <cengelma@gmx.at>
When we obtain tcon from cifs_sb, we use cifs_sb_tlink() to first obtain
tlink which also grabs a reference to it. We do not drop this reference
to tlink once we are done with the call.
The patch fixes this issue by instead passing tcon as a parameter and
avoids having to obtain a reference to the tlink. A lookup for the tcon
is already made in the calling functions and this way we avoid having to
re-run the lookup. This is also consistent with the argument list for
other similar calls for M-F symlinks.
We should also return an ENOSYS when we do not find a protocol specific
function to lookup the MF Symlink data.
CC: Stable <stable@kernel.org>
duplicated to hell and back...
that allows to access files through symlink created on a server.
Acked-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Pavel Shilovsky <pshilovsky@samba.org>
When use of symlinks is enabled (mounting with mfsymlinks option) to
non-Samba servers, we always tried to use cifs, even when we
were mounted with SMB2 or SMB3, which causes the server to drop the
network connection.
This patch separates out the protocol specific operations for cifs from
the code which recognizes symlinks, and fixes the problem where
with SMB2 mounts we attempt cifs operations to open and read
symlinks. The next patch will add support for SMB2 for opening
and reading symlinks. Additional followon patches will address
the similar problem creating symlinks.
It's not obvious from reading the macro names that these macros
are for debugging. Convert the names to a single more typical
kernel style cifs_dbg macro.
cERROR(1, ...) -> cifs_dbg(VFS, ...)
cFYI(1, ...) -> cifs_dbg(FYI, ...)
cFYI(DBG2, ...) -> cifs_dbg(NOISY, ...)
Move the terminating format newline from the macro to the call site.
Add CONFIG_CIFS_DEBUG function cifs_vfs_err to emit the
"CIFS VFS: " prefix for VFS messages.
Size is reduced ~ 1% when CONFIG_CIFS_DEBUG is set (default y)
$ size fs/cifs/cifs.ko*
265245 2525 132 267902 4167e fs/cifs/cifs.ko.new
268359 2525 132 271016 422a8 fs/cifs/cifs.ko.old
Other miscellaneous changes around these conversions:
o Miscellaneous typo fixes
o Add terminating \n's to almost all formats and remove them
from the macros to be more kernel style like. A few formats
previously had defective \n's
o Remove unnecessary OOM messages as kmalloc() calls dump_stack
o Coalesce formats to make grep easier,
added missing spaces when coalescing formats
o Use %s, __func__ instead of embedded function name
o Removed unnecessary "cifs: " prefixes
o Convert kzalloc with multiply to kcalloc
o Remove unused cifswarn macro
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Correct spelling typo in printk within various drivers.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
that can cause warning messages. Pavel had initially
suggested a smaller patch around drop_nlink, after
a similar problem was discovered NFS. Protecting
additional places where nlink is touched was
suggested by Jeff Layton and is included in this.
Reviewed-by: Pavel Shilovsky <pshilovsky@samba.org>
Since both CIFS and SMB2 use ses->capabilities (server->capabilities)
field but flags are different we should make such checks protocol
independent.
Those macros add a newline on their own, so there's not any need to
embed one in the message itself.
Replace direct i_nlink updates with the respective updater function
(inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count).
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Add mount options backupuid and backugid.
It allows an authenticated user to access files with the intent to back them
up including their ACLs, who may not have access permission but has
"Backup files and directories user right" on them (by virtue of being part
of the built-in group Backup Operators.
When mount options backupuid is specified, cifs client restricts the
use of backup intents to the user whose effective user id is specified
along with the mount option.
When mount options backupgid is specified, cifs client restricts the
use of backup intents to the users whose effective user id belongs to the
group id specified along with the mount option.
If an authenticated user is not part of the built-in group Backup Operators
at the server, access to such files is denied, even if allowed by the client.
Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
Check return codes of crypto api calls and either log an error or log
an error and return from the calling function with error.
secMode to sec_mode
and
cifsTconInfo to cifs_tcon
and
cifsSesInfo to cifs_ses
Add rwpidforward mount option that switches on a mode when we forward
pid of a process who opened a file to any read and write operation.
This can prevent applications like WINE from failing on read or write
operation on a previously locked file region from the same netfd from
another process if we use mandatory brlock style.
It is actual for WINE because during a run of WINE program two processes
work on the same netfd - share the same file struct between several VFS
fds:
1) WINE-server does open and lock;
2) WINE-application does read and write.
We need it to make them work with mandatory locking style because
we can fail in a situation like when kernel need to flush dirty pages
and there is a lock held by a process who opened file.
make modules C=2 M=fs/cifs CF=-D__CHECK_ENDIAN__
Found for example:
CHECK fs/cifs/cifssmb.c
fs/cifs/cifssmb.c:728:22: warning: incorrect type in assignment (different base types)
fs/cifs/cifssmb.c:728:22: expected unsigned short [unsigned] [usertype] Tid
fs/cifs/cifssmb.c:728:22: got restricted __le16 [usertype] <noident>
fs/cifs/cifssmb.c:1883:45: warning: incorrect type in assignment (different base types)
fs/cifs/cifssmb.c:1883:45: expected long long [signed] [usertype] fl_start
fs/cifs/cifssmb.c:1883:45: got restricted __le64 [usertype] start
fs/cifs/cifssmb.c:1884:54: warning: restricted __le64 degrades to integer
fs/cifs/cifssmb.c:1885:58: warning: restricted __le64 degrades to integer
fs/cifs/cifssmb.c:1886:43: warning: incorrect type in assignment (different base types)
fs/cifs/cifssmb.c:1886:43: expected unsigned int [unsigned] fl_pid
fs/cifs/cifssmb.c:1886:43: got restricted __le32 [usertype] pid
In checking new smb2 code for missing endian conversions, I noticed
some endian errors had crept in over the last few releases into the
cifs code (symlink, ntlmssp, posix lock, and also a less problematic warning
in fscache). A followon patch will address a few smb2 endian
problems.
fs/cifs/link.c: In function ‘symlink_hash’:
fs/cifs/link.c:58:3: warning: ‘rc’ may be used uninitialized in this
function [-Wuninitialized]
fs/cifs/smbencrypt.c: In function ‘mdfour’:
fs/cifs/smbencrypt.c:61:3: warning: ‘rc’ may be used uninitialized in this
Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
Replaced md4 hashing function local to cifs module with kernel crypto APIs.
As a result, md4 hashing function and its supporting functions in
file md4.c are not needed anymore.
Cleaned up function declarations, removed forward function declarations,
and removed a header file that is being deleted from being included.
Verified that sec=ntlm/i, sec=ntlmv2/i, and sec=ntlmssp/i work correctly.
Replace remaining use of md5 hash functions local to cifs module
Remove header and source file containing those local functions.
Reduce some branches and memory accesses in dcache lookup by adding dentry
flags to indicate common d_ops are set, rather than having to check them.
This saves a pointer memory access (dentry->d_op) in common path lookup
situations, and saves another pointer load and branch in cases where we
have d_op but not the particular operation.
Patched with:
git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
cifsFileInfo needs a pointer to a tcon, but it doesn't currently hold a
reference to it. Change it to keep a pointer to a tcon_link instead and
hold a reference to it.
That will keep the tcon from being freed until the file is closed.
Eventually, we'll need to track the use of tcons on a per-sb basis, so that
we know when it's ok to tear them down. Begin this conversion by adding a
new "tcon_link" struct and accessors that get it. For now, the core data
structures are untouched -- cifs_sb still just points to a single tcon and
the pointers are just cast to deal with the accessor functions. A later
patch will flesh this out.
