path: root/fs/cifs/smbencrypt.c
2017-01-06cifs: Fix smbencrypt() to stop pointing a scatterlist at the stackAndy Lutomirski
commit 06deeec77a5a689cc94b21a8a91a76e42176685d upstream. smbencrypt() points a scatterlist to the stack, which is breaks if CONFIG_VMAP_STACK=y. Fix it by switching to crypto_cipher_encrypt_one(). The new code should be considerably faster as an added benefit. This code is nearly identical to some code that Eric Biggers suggested. Reported-by: Eric Biggers <ebiggers3@gmail.com> Signed-off-by: Andy Lutomirski <luto@kernel.org> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-01-27cifs: Use skcipherHerbert Xu
This patch replaces uses of blkcipher with skcipher. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2015-01-19cifs: use memzero_explicit to clear stack bufferGiel van Schijndel
When leaving a function use memzero_explicit instead of memset(0) to clear stack allocated buffers. memset(0) may be optimized away. This particular buffer is highly likely to contain sensitive data which we shouldn't leak (it's named 'passwd' after all). Signed-off-by: Giel van Schijndel <me@mortis.eu> Acked-by: Herbert Xu <herbert@gondor.apana.org.au> Reported-at: http://www.viva64.com/en/b/0299/ Reported-by: Andrey Karpov Reported-by: Svyatoslav Razmyslov Signed-off-by: Steve French <steve.french@primarydata.com>
2014-10-16Remap reserved posix characters by default (part 3/3)Steve French
This is a bigger patch, but its size is mostly due to a single change for how we check for remapping illegal characters in file names - a lot of repeated, small changes to the way callers request converting file names. The final patch in the series does the following: 1) changes default behavior for cifs to be more intuitive. Currently we do not map by default to seven reserved characters, ie those valid in POSIX but not in NTFS/CIFS/SMB3/Windows, unless a mount option (mapchars) is specified. Change this to by default always map and map using the SFM maping (like the Mac uses) unless the server negotiates the CIFS Unix Extensions (like Samba does when mounting with the cifs protocol) when the remapping of the characters is unnecessary. This should help SMB3 mounts in particular since Samba will likely be able to implement this mapping with its new "vfs_fruit" module as it will be doing for the Mac. 2) if the user specifies the existing "mapchars" mount option then use the "SFU" (Microsoft Services for Unix, SUA) style mapping of the seven characters instead. 3) if the user specifies "nomapposix" then disable SFM/MAC style mapping (so no character remapping would be used unless the user specifies "mapchars" on mount as well, as above). 4) change all the places in the code that check for the superblock flag on the mount which is set by mapchars and passed in on all path based operation and change it to use a small function call instead to set the mapping type properly (and check for the mapping type in the cifs unicode functions) Signed-off-by: Steve French <smfrench@gmail.com>
2013-05-04[CIFS] cifs: Rename cERROR and cFYI to cifs_dbgJoe Perches
It's not obvious from reading the macro names that these macros are for debugging. Convert the names to a single more typical kernel style cifs_dbg macro. cERROR(1, ...) -> cifs_dbg(VFS, ...) cFYI(1, ...) -> cifs_dbg(FYI, ...) cFYI(DBG2, ...) -> cifs_dbg(NOISY, ...) Move the terminating format newline from the macro to the call site. Add CONFIG_CIFS_DEBUG function cifs_vfs_err to emit the "CIFS VFS: " prefix for VFS messages. Size is reduced ~ 1% when CONFIG_CIFS_DEBUG is set (default y) $ size fs/cifs/cifs.ko* text data bss dec hex filename 265245 2525 132 267902 4167e fs/cifs/cifs.ko.new 268359 2525 132 271016 422a8 fs/cifs/cifs.ko.old Other miscellaneous changes around these conversions: o Miscellaneous typo fixes o Add terminating \n's to almost all formats and remove them from the macros to be more kernel style like. A few formats previously had defective \n's o Remove unnecessary OOM messages as kmalloc() calls dump_stack o Coalesce formats to make grep easier, added missing spaces when coalescing formats o Use %s, __func__ instead of embedded function name o Removed unnecessary "cifs: " prefixes o Convert kzalloc with multiply to kcalloc o Remove unused cifswarn macro Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-07-23cifs: remove extraneous newlines from cERROR and cFYI callsJeff Layton
Those macros add a newline on their own, so there's not any need to embed one in the message itself. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-01-18CIFS: Rename *UCS* functions to *UTF16*Steve French
to reflect the unicode encoding used by CIFS protocol. Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Acked-by: Jeff Layton <jlayton@samba.org> Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
2011-11-10cifs: Fix sparse warning when calling cifs_strtoUCSSteve French
Fix sparse endian check warning while calling cifs_strtoUCS CHECK fs/cifs/smbencrypt.c fs/cifs/smbencrypt.c:216:37: warning: incorrect type in argument 1 (different base types) fs/cifs/smbencrypt.c:216:37: expected restricted __le16 [usertype] *<noident> fs/cifs/smbencrypt.c:216:37: got unsigned short *<noident> Signed-off-by: Steve French <smfrench@gmail.com> Acked-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com
2011-10-29cifs: Assume passwords are encoded according to iocharset (try #2)Shirish Pargaonkar
Re-posting a patch originally posted by Oskar Liljeblad after rebasing on 3.2. Modify cifs to assume that the supplied password is encoded according to iocharset. Before this patch passwords would be treated as raw 8-bit data, which made authentication with Unicode passwords impossible (at least passwords with characters > 0xFF). The previous code would as a side effect accept passwords encoded with ISO 8859-1, since Unicode < 0x100 basically is ISO 8859-1. Software which relies on that will no longer support password chars > 0x7F unless it also uses iocharset=iso8859-1. (mount.cifs does not care about the encoding so it will work as expected.) Signed-off-by: Oskar Liljeblad <oskar@osk.mine.nu> Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Pavel Shilovsky <piastry@etersoft.ru> Tested-by: A <nimbus1_03087@yahoo.com> Signed-off-by: Steve French <smfrench@gmail.com>
2011-10-12cifs: clean up unused encryption codeShirish Pargaonkar
Remove unsed #if 0 encryption code. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2011-07-25cifs: Cleanup: check return codes of crypto api callsShirish Pargaonkar
Check return codes of crypto api calls and either log an error or log an error and return from the calling function with error. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-06-24cifs: free blkcipher in smbhashJeff Layton
This is currently leaked in the rc == 0 case. Reported-by: J. Bruce Fields <bfields@fieldses.org> Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-05-19[CIFS] Use ecb des kernel crypto APIs instead ofSteve French
local cifs functions (repost) Using kernel crypto APIs for DES encryption during LM and NT hash generation instead of local functions within cifs. Source file smbdes.c is deleted sans four functions, one of which uses ecb des functionality provided by kernel crypto APIs. Remove function SMBOWFencrypt. Add return codes to various functions such as calc_lanman_hash, SMBencrypt, and SMBNTencrypt. Includes fix noticed by Dan Carpenter. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> CC: Dan Carpenter <error27@gmail.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-31cifs: fix two compiler warning about uninitialized varsJeff Layton
fs/cifs/link.c: In function ‘symlink_hash’: fs/cifs/link.c:58:3: warning: ‘rc’ may be used uninitialized in this function [-Wuninitialized] fs/cifs/smbencrypt.c: In function ‘mdfour’: fs/cifs/smbencrypt.c:61:3: warning: ‘rc’ may be used uninitialized in this function [-Wuninitialized] Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-27cifs: More crypto cleanup (try #2)Shirish Pargaonkar
Replaced md4 hashing function local to cifs module with kernel crypto APIs. As a result, md4 hashing function and its supporting functions in file md4.c are not needed anymore. Cleaned up function declarations, removed forward function declarations, and removed a header file that is being deleted from being included. Verified that sec=ntlm/i, sec=ntlmv2/i, and sec=ntlmssp/i work correctly. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-25[CIFS] Replace cifs md5 hashing functions with kernel crypto APIsSteve French
Replace remaining use of md5 hash functions local to cifs module with kernel crypto APIs. Remove header and source file containing those local functions. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2008-12-26cifs: have calc_lanman_hash take more granular argsJeff Layton
cifs: have calc_lanman_hash take more granular args We need to use this routine to encrypt passwords associated with the tcon too. Don't assume that the password will be attached to the smb_session. Also, make some of the values in the lower encryption functions const since they aren't changed. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-04-29[CIFS] convert usage of implicit booleans to boolSteve French
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-11-05[CIFS] Fix walking out end of cifs daclSteve French
Acked-by: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-10-25[CIFS] acl support part 6Steve French
Acked-by: Shirish Pargaonkar <shirishp@us.ibm.com> CC: Cyrill Gorcunov <gorcunov@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-07-13[CIFS] whitespace/formatting fixesSteve French
This should be the last big batch of whitespace/formatting fixes. checkpatch warnings for the cifs directory are down about 90% and many of the remaining ones are harder to remove or make the code harder to read. Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-07-07[CIFS] more whitespace cleanupSteve French
2006-09-28[CIFS] More removing of unused functionsSteve French
2006-09-28[CIFS] Remove unused prototypesSteve French
2006-09-28[CIFS] Remove static and unused symbolsSteve French
Most cases of the ones found by Shaggy by "make namespacecheck" could be removed or made static Ack: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-05-31[CIFS] Support for setting up SMB sessions to legacy lanman serversSteve French
