path: root/fs/cifs
2018-02-17CIFS: zero sensitive data when freeingAurelien Aptel
commit 97f4b7276b829a8927ac903a119bef2f963ccc58 upstream. also replaces memset()+kfree() by kzfree(). Signed-off-by: Aurelien Aptel <aaptel@suse.com> Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-17cifs: Fix autonegotiate security settings mismatchDaniel N Pettersson
commit 9aca7e454415f7878b28524e76bebe1170911a88 upstream. Autonegotiation gives a security settings mismatch error if the SMB server selects an SMBv3 dialect that isn't SMB3.02. The exact error is "protocol revalidation - security settings mismatch". This can be tested using Samba v4.2 or by setting the global Samba setting max protocol = SMB3_00. The check that fails in smb3_validate_negotiate is the dialect verification of the negotiate info response. This is because it tries to verify against the protocol_id in the global smbdefault_values. The protocol_id in smbdefault_values is SMB3.02. In SMB2_negotiate the protocol_id in smbdefault_values isn't updated, it is global so it probably shouldn't be, but server->dialect is. This patch changes the check in smb3_validate_negotiate to use server->dialect instead of server->vals->protocol_id. The patch works with autonegotiate and when using a specific version in the vers mount option. Signed-off-by: Daniel N Pettersson <danielnp@axis.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-02-17cifs: Fix missing put_xid in cifs_file_strict_mmapMatthew Wilcox
commit f04a703c3d613845ae3141bfaf223489de8ab3eb upstream. If cifs_zap_mapping() returned an error, we would return without putting the xid that we got earlier. Restructure cifs_file_strict_mmap() and cifs_file_mmap() to be more similar to each other and have a single point of return that always puts the xid. Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-11-08cifs: check MaxPathNameComponentLength != 0 before using itRonnie Sahlberg
commit f74bc7c6679200a4a83156bb89cbf6c229fe8ec0 upstream. And fix tcon leak in error path. Signed-off-by: Ronnie Sahlberg <lsahlber@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: David Disseldorp <ddiss@samba.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-18CIFS: Reconnect expired SMB sessionsPavel Shilovsky
commit 511c54a2f69195b28afb9dd119f03787b1625bb4 upstream. According to the MS-SMB2 spec (3.2.5.1.6) once the client receives STATUS_NETWORK_SESSION_EXPIRED error code from a server it should reconnect the current SMB session. Currently the client doesn't do that. This can result in subsequent client requests failing by the server. The patch adds an additional logic to the demultiplex thread to identify expired sessions and reconnect them. Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05SMB3: Don't ignore O_SYNC/O_DSYNC and O_DIRECT flagsSteve French
commit 1013e760d10e614dc10b5624ce9fc41563ba2e65 upstream. Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05SMB: Validate negotiate (to protect against downgrade) even if signing offSteve French
commit 0603c96f3af50e2f9299fa410c224ab1d465e0f9 upstream. As long as signing is supported (ie not a guest user connection) and connection is SMB3 or SMB3.02, then validate negotiate (protect against man in the middle downgrade attacks). We had been doing this only when signing was required, not when signing was just enabled, but this more closely matches recommended SMB3 behavior and is better security. Suggested by Metze. Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Jeremy Allison <jra@samba.org> Acked-by: Stefan Metzmacher <metze@samba.org> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05SMB3: Warn user if trying to sign connection that authenticated as guestSteve French
commit c721c38957fb19982416f6be71aae7b30630d83b upstream. It can be confusing if user ends up authenticated as guest but they requested signing (server will return error validating signed packets) so add log message for this. Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05Fix SMB3.1.1 guest authentication to SambaSteve French
commit 23586b66d84ba3184b8820277f3fc42761640f87 upstream. Samba rejects SMB3.1.1 dialect (vers=3.1.1) negotiate requests from the kernel client due to the two byte pad at the end of the negotiate contexts. Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05cifs: release auth_key.response for reconnect.Shu Wang
commit f5c4ba816315d3b813af16f5571f86c8d4e897bd upstream. There is a race that cause cifs reconnect in cifs_mount, - cifs_mount - cifs_get_tcp_session - [ start thread cifs_demultiplex_thread - cifs_read_from_socket: -ECONNABORTED - DELAY_WORK smb2_reconnect_server ] - cifs_setup_session - [ smb2_reconnect_server ] auth_key.response was allocated in cifs_setup_session, and will release when the session destoried. So when session re- connect, auth_key.response should be check and released. Tested with my system: CIFS VFS: Free previous auth_key.response = ffff8800320bbf80 A simple auth_key.response allocation call trace: - cifs_setup_session - SMB2_sess_setup - SMB2_sess_auth_rawntlmssp_authenticate - build_ntlmssp_auth_blob - setup_ntlmv2_rsp Signed-off-by: Shu Wang <shuwang@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-05cifs: release cifs root_cred after exit_cifsShu Wang
commit 94183331e815617246b1baa97e0916f358c794bb upstream. memory leak was found by kmemleak. exit_cifs_spnego should be called before cifs module removed, or cifs root_cred will not be released. kmemleak report: unreferenced object 0xffff880070a3ce40 (size 192): backtrace: kmemleak_alloc+0x4a/0xa0 kmem_cache_alloc+0xc7/0x1d0 prepare_kernel_cred+0x20/0x120 init_cifs_spnego+0x2d/0x170 [cifs] 0xffffffffc07801f3 do_one_initcall+0x51/0x1b0 do_init_module+0x60/0x1fd load_module+0x161e/0x1b60 SYSC_finit_module+0xa9/0x100 SyS_finit_module+0xe/0x10 Signed-off-by: Shu Wang <shuwang@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-07CIFS: remove endian related sparse warningSteve French
commit 6e3c1529c39e92ed64ca41d53abadabbaa1d5393 upstream. Recent patch had an endian warning ie cifs: return ENAMETOOLONG for overlong names in cifs_open()/cifs_lookup() Signed-off-by: Steve French <smfrench@gmail.com> CC: Ronnie Sahlberg <lsahlber@redhat.com> Acked-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-07CIFS: Fix maximum SMB2 header sizePavel Shilovsky
commit 9e37b1784f2be9397a903307574ee565bbadfd75 upstream. Currently the maximum size of SMB2/3 header is set incorrectly which leads to hanging of directory listing operations on encrypted SMB3 connections. Fix this by setting the maximum size to 170 bytes that is calculated as RFC1002 length field size (4) + transform header size (52) + SMB2 header size (64) + create response size (56). Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Steve French <smfrench@gmail.com> Acked-by: Sachin Prabhu <sprabhu@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30cifs: return ENAMETOOLONG for overlong names in cifs_open()/cifs_lookup()Ronnie Sahlberg
commit d3edede29f74d335f81d95a4588f5f136a9f7dcf upstream. Add checking for the path component length and verify it is <= the maximum that the server advertizes via FileFsAttributeInformation. With this patch cifs.ko will now return ENAMETOOLONG instead of ENOENT when users to access an overlong path. To test this, try to cd into a (non-existing) directory on a CIFS share that has a too long name: cd /mnt/aaaaaaaaaaaaaaa... and it now should show a good error message from the shell: bash: cd: /mnt/aaaaaaaaaaaaaaaa...aaaaaa: File name too long rh bz 1153996 Signed-off-by: Ronnie Sahlberg <lsahlber@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-08-30cifs: Fix df output for users with quota limitsSachin Prabhu
commit 42bec214d8bd432be6d32a1acb0a9079ecd4d142 upstream. The df for a SMB2 share triggers a GetInfo call for FS_FULL_SIZE_INFORMATION. The values returned are used to populate struct statfs. The problem is that none of the information returned by the call contains the total blocks available on the filesystem. Instead we use the blocks available to the user ie. quota limitation when filling out statfs.f_blocks. The information returned does contain Actual free units on the filesystem and is used to populate statfs.f_bfree. For users with quota enabled, it can lead to situations where the total free space reported is more than the total blocks on the system ending up with df reports like the following # df -h /mnt/a Filesystem Size Used Avail Use% Mounted on //192.168.22.10/a 2.5G -2.3G 2.5G - /mnt/a To fix this problem, we instead populate both statfs.f_bfree with the same value as statfs.f_bavail ie. CallerAvailableAllocationUnits. This is similar to what is done already in the code for cifs and df now reports the quota information for the user used to mount the share. # df --si /mnt/a Filesystem Size Used Avail Use% Mounted on //192.168.22.10/a 2.7G 101M 2.6G 4% /mnt/a Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Signed-off-by: Pierguido Lambri <plambri@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-29CIFS: Improve readdir verbosityPavel Shilovsky
commit dcd87838c06f05ab7650b249ebf0d5b57ae63e1e upstream. Downgrade the loglevel for SMB2 to prevent filling the log with messages if e.g. readdir was interrupted. Also make SMB2 and SMB1 codepaths do the same logging during readdir. Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20CIFS: add misssing SFM mapping for doublequoteBjörn Jacke
commit 85435d7a15294f9f7ef23469e6aaf7c5dfcc54f0 upstream. SFM is mapping doublequote to 0xF020 Without this patch creating files with doublequote fails to Windows/Mac Signed-off-by: Bjoern Jacke <bjacke@samba.org> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20cifs: fix CIFS_IOC_GET_MNT_INFO oopsDavid Disseldorp
commit d8a6e505d6bba2250852fbc1c1c86fe68aaf9af3 upstream. An open directory may have a NULL private_data pointer prior to readdir. Fixes: 0de1f4c6f6c0 ("Add way to query server fs info for smb3") Signed-off-by: David Disseldorp <ddiss@suse.de> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20CIFS: fix oplock break deadlocksRabin Vincent
commit 3998e6b87d4258a70df358296d6f1c7234012bfe upstream. When the final cifsFileInfo_put() is called from cifsiod and an oplock break work is queued, lockdep complains loudly: ============================================= [ INFO: possible recursive locking detected ] 4.11.0+ #21 Not tainted --------------------------------------------- kworker/0:2/78 is trying to acquire lock: ("cifsiod"){++++.+}, at: flush_work+0x215/0x350 but task is already holding lock: ("cifsiod"){++++.+}, at: process_one_work+0x255/0x8e0 other info that might help us debug this: Possible unsafe locking scenario: CPU0 ---- lock("cifsiod"); lock("cifsiod"); *** DEADLOCK *** May be due to missing lock nesting notation 2 locks held by kworker/0:2/78: #0: ("cifsiod"){++++.+}, at: process_one_work+0x255/0x8e0 #1: ((&wdata->work)){+.+...}, at: process_one_work+0x255/0x8e0 stack backtrace: CPU: 0 PID: 78 Comm: kworker/0:2 Not tainted 4.11.0+ #21 Workqueue: cifsiod cifs_writev_complete Call Trace: dump_stack+0x85/0xc2 __lock_acquire+0x17dd/0x2260 ? match_held_lock+0x20/0x2b0 ? trace_hardirqs_off_caller+0x86/0x130 ? mark_lock+0xa6/0x920 lock_acquire+0xcc/0x260 ? lock_acquire+0xcc/0x260 ? flush_work+0x215/0x350 flush_work+0x236/0x350 ? flush_work+0x215/0x350 ? destroy_worker+0x170/0x170 __cancel_work_timer+0x17d/0x210 ? ___preempt_schedule+0x16/0x18 cancel_work_sync+0x10/0x20 cifsFileInfo_put+0x338/0x7f0 cifs_writedata_release+0x2a/0x40 ? cifs_writedata_release+0x2a/0x40 cifs_writev_complete+0x29d/0x850 ? preempt_count_sub+0x18/0xd0 process_one_work+0x304/0x8e0 worker_thread+0x9b/0x6a0 kthread+0x1b2/0x200 ? process_one_work+0x8e0/0x8e0 ? kthread_create_on_node+0x40/0x40 ret_from_fork+0x31/0x40 This is a real warning. Since the oplock is queued on the same workqueue this can deadlock if there is only one worker thread active for the workqueue (which will be the case during memory pressure when the rescuer thread is handling it). Furthermore, there is at least one other kind of hang possible due to the oplock break handling if there is only worker. (This can be reproduced without introducing memory pressure by having passing 1 for the max_active parameter of cifsiod.) cifs_oplock_break() can wait indefintely in the filemap_fdatawait() while the cifs_writev_complete() work is blocked: sysrq: SysRq : Show Blocked State task PC stack pid father kworker/0:1 D 0 16 2 0x00000000 Workqueue: cifsiod cifs_oplock_break Call Trace: __schedule+0x562/0xf40 ? mark_held_locks+0x4a/0xb0 schedule+0x57/0xe0 io_schedule+0x21/0x50 wait_on_page_bit+0x143/0x190 ? add_to_page_cache_lru+0x150/0x150 __filemap_fdatawait_range+0x134/0x190 ? do_writepages+0x51/0x70 filemap_fdatawait_range+0x14/0x30 filemap_fdatawait+0x3b/0x40 cifs_oplock_break+0x651/0x710 ? preempt_count_sub+0x18/0xd0 process_one_work+0x304/0x8e0 worker_thread+0x9b/0x6a0 kthread+0x1b2/0x200 ? process_one_work+0x8e0/0x8e0 ? kthread_create_on_node+0x40/0x40 ret_from_fork+0x31/0x40 dd D 0 683 171 0x00000000 Call Trace: __schedule+0x562/0xf40 ? mark_held_locks+0x29/0xb0 schedule+0x57/0xe0 io_schedule+0x21/0x50 wait_on_page_bit+0x143/0x190 ? add_to_page_cache_lru+0x150/0x150 __filemap_fdatawait_range+0x134/0x190 ? do_writepages+0x51/0x70 filemap_fdatawait_range+0x14/0x30 filemap_fdatawait+0x3b/0x40 filemap_write_and_wait+0x4e/0x70 cifs_flush+0x6a/0xb0 filp_close+0x52/0xa0 __close_fd+0xdc/0x150 SyS_close+0x33/0x60 entry_SYSCALL_64_fastpath+0x1f/0xbe Showing all locks held in the system: 2 locks held by kworker/0:1/16: #0: ("cifsiod"){.+.+.+}, at: process_one_work+0x255/0x8e0 #1: ((&cfile->oplock_break)){+.+.+.}, at: process_one_work+0x255/0x8e0 Showing busy workqueues and worker pools: workqueue cifsiod: flags=0xc pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1 in-flight: 16:cifs_oplock_break delayed: cifs_writev_complete, cifs_echo_request pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=0s workers=3 idle: 750 3 Fix these problems by creating a a new workqueue (with a rescuer) for the oplock break work. Signed-off-by: Rabin Vincent <rabinv@axis.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20cifs: fix CIFS_ENUMERATE_SNAPSHOTS oopsDavid Disseldorp
commit 6026685de33b0db5b2b6b0e9b41b3a1a3261033c upstream. As with 618763958b22, an open directory may have a NULL private_data pointer prior to readdir. CIFS_ENUMERATE_SNAPSHOTS must check for this before dereference. Fixes: 834170c85978 ("Enable previous version support") Signed-off-by: David Disseldorp <ddiss@suse.de> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20cifs: fix leak in FSCTL_ENUM_SNAPS response handlingDavid Disseldorp
commit 0e5c795592930d51fd30d53a2e7b73cba022a29b upstream. The server may respond with success, and an output buffer less than sizeof(struct smb_snapshot_array) in length. Do not leak the output buffer in this case. Fixes: 834170c85978 ("Enable previous version support") Signed-off-by: David Disseldorp <ddiss@suse.de> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20CIFS: fix mapping of SFM_SPACE and SFM_PERIODBjörn Jacke
commit b704e70b7cf48f9b67c07d585168e102dfa30bb4 upstream. - trailing space maps to 0xF028 - trailing period maps to 0xF029 This fix corrects the mapping of file names which have a trailing character that would otherwise be illegal (period or space) but is allowed by POSIX. Signed-off-by: Bjoern Jacke <bjacke@samba.org> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20SMB3: Work around mount failure when using SMB3 dialect to MacsSteve French
commit 7db0a6efdc3e990cdfd4b24820d010e9eb7890ad upstream. Macs send the maximum buffer size in response on ioctl to validate negotiate security information, which causes us to fail the mount as the response buffer is larger than the expected response. Changed ioctl response processing to allow for padding of validate negotiate ioctl response and limit the maximum response size to maximum buffer size. Signed-off-by: Steve French <steve.french@primarydata.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20Set unicode flag on cifs echo request to avoid Mac errorSteve French
commit 26c9cb668c7fbf9830516b75d8bee70b699ed449 upstream. Mac requires the unicode flag to be set for cifs, even for the smb echo request (which doesn't have strings). Without this Mac rejects the periodic echo requests (when mounting with cifs) that we use to check if server is down Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-20Fix match_prepath()Sachin Prabhu
commit cd8c42968ee651b69e00f8661caff32b0086e82d upstream. Incorrect return value for shares not using the prefix path means that we will never match superblocks for these shares. Fixes: commit c1d8b24d1819 ("Compare prepaths when comparing superblocks") Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-08Handle mismatched open callsSachin Prabhu
commit 38bd49064a1ecb67baad33598e3d824448ab11ec upstream. A signal can interrupt a SendReceive call which result in incoming responses to the call being ignored. This is a problem for calls such as open which results in the successful response being ignored. This results in an open file resource on the server. The patch looks into responses which were cancelled after being sent and in case of successful open closes the open fids. For this patch, the check is only done in SendReceive2() RH-bz: 1403319 Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com> Acked-by: Sachin Prabhu <sprabhu@redhat.com> Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-27CIFS: remove bad_network_name flagGermano Percossi
commit a0918f1ce6a43ac980b42b300ec443c154970979 upstream. STATUS_BAD_NETWORK_NAME can be received during node failover, causing the flag to be set and making the reconnect thread always unsuccessful, thereafter. Once the only place where it is set is removed, the remaining bits are rendered moot. Removing it does not prevent "mount" from failing when a non existent share is passed. What happens when the share really ceases to exist while the share is mounted is undefined now as much as it was before. Signed-off-by: Germano Percossi <germano.percossi@citrix.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-27cifs: Do not send echoes before Negotiate is completeSachin Prabhu
commit 62a6cfddcc0a5313e7da3e8311ba16226fe0ac10 upstream. commit 4fcd1813e640 ("Fix reconnect to not defer smb3 session reconnect long after socket reconnect") added support for Negotiate requests to be initiated by echo calls. To avoid delays in calling echo after a reconnect, I added the patch introduced by the commit b8c600120fc8 ("Call echo service immediately after socket reconnect"). This has however caused a regression with cifs shares which do not have support for echo calls to trigger Negotiate requests. On connections which need to call Negotiation, the echo calls trigger an error which triggers a reconnect which in turn triggers another echo call. This results in a loop which is only broken when an operation is performed on the cifs share. For an idle share, it can DOS a server. The patch uses the smb_operation can_echo() for cifs so that it is called only if connection has been already been setup. kernel bz: 194531 Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Tested-by: Jonathan Liu <net147@gmail.com> Acked-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21CIFS: store results of cifs_reopen_file to avoid infinite waitGermano Percossi
commit 1fa839b4986d648b907d117275869a0e46c324b9 upstream. This fixes Continuous Availability when errors during file reopen are encountered. cifs_user_readv and cifs_user_writev would wait for ever if results of cifs_reopen_file are not stored and for later inspection. In fact, results are checked and, in case of errors, a chain of function calls leading to reads and writes to be scheduled in a separate thread is skipped. These threads will wake up the corresponding waiters once reads and writes are done. However, given the return value is not stored, when rc is checked for errors a previous one (always zero) is inspected instead. This leads to pending reads/writes added to the list, making cifs_user_readv and cifs_user_writev wait for ever. Signed-off-by: Germano Percossi <germano.percossi@citrix.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-21CIFS: reconnect thread reschedule itselfGermano Percossi
commit 18ea43113f5b74a97dd4be9bddbac10d68b1a6ce upstream. In case of error, smb2_reconnect_server reschedule itself with a delay, to avoid being too aggressive. Signed-off-by: Germano Percossi <germano.percossi@citrix.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-04-12Reset TreeId to zero on SMB2 TREE_CONNECTJan-Marek Glogowski
commit 806a28efe9b78ffae5e2757e1ee924b8e50c08ab upstream. Currently the cifs module breaks the CIFS specs on reconnect as described in http://msdn.microsoft.com/en-us/library/cc246529.aspx: "TreeId (4 bytes): Uniquely identifies the tree connect for the command. This MUST be 0 for the SMB2 TREE_CONNECT Request." Signed-off-by: Jan-Marek Glogowski <glogow@fbihome.de> Reviewed-by: Aurelien Aptel <aaptel@suse.com> Tested-by: Aurelien Aptel <aaptel@suse.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-15fs: Better permission checking for submountsEric W. Biederman
commit 93faccbbfa958a9668d3ab4e30f38dd205cee8d8 upstream. To support unprivileged users mounting filesystems two permission checks have to be performed: a test to see if the user allowed to create a mount in the mount namespace, and a test to see if the user is allowed to access the specified filesystem. The automount case is special in that mounting the original filesystem grants permission to mount the sub-filesystems, to any user who happens to stumble across the their mountpoint and satisfies the ordinary filesystem permission checks. Attempting to handle the automount case by using override_creds almost works. It preserves the idea that permission to mount the original filesystem is permission to mount the sub-filesystem. Unfortunately using override_creds messes up the filesystems ordinary permission checks. Solve this by being explicit that a mount is a submount by introducing vfs_submount, and using it where appropriate. vfs_submount uses a new mount internal mount flags MS_SUBMOUNT, to let sget and friends know that a mount is a submount so they can take appropriate action. sget and sget_userns are modified to not perform any permission checks on submounts. follow_automount is modified to stop using override_creds as that has proven problemantic. do_mount is modified to always remove the new MS_SUBMOUNT flag so that we know userspace will never by able to specify it. autofs4 is modified to stop using current_real_cred that was put in there to handle the previous version of submount permission checking. cifs is modified to pass the mountpoint all of the way down to vfs_submount. debugfs is modified to pass the mountpoint all of the way down to trace_automount by adding a new parameter. To make this change easier a new typedef debugfs_automount_t is introduced to capture the type of the debugfs automount function. Fixes: 069d5ac9ae0d ("autofs: Fix automounts by using current_real_cred()->uid") Fixes: aeaa4a79ff6a ("fs: Call d_automount with the filesystems creds") Reviewed-by: Trond Myklebust <trond.myklebust@primarydata.com> Reviewed-by: Seth Forshee <seth.forshee@canonical.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-03-12CIFS: Fix splice read for non-cached filesPavel Shilovsky
commit 9c25702cee1405099f982894c865c163de7909a8 upstream. Currently we call copy_page_to_iter() for uncached reading into a pipe. This is wrong because it treats pages as VFS cache pages and copies references rather than actual data. When we are trying to read from the pipe we end up calling page_cache_pipe_buf_confirm() which returns -ENODATA. This error is translated into 0 which is returned to a user. This issue is reproduced by running xfs-tests suite (generic test #249) against mount points with "cache=none". Fix it by mapping pages manually and calling copy_to_iter() that copies data into the pipe. Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09cifs: initialize file_info_lockRabin Vincent
commit 81ddd8c0c5e1cb41184d66567140cb48c53eb3d1 upstream. Reviewed-by: Jeff Layton <jlayton@redhat.com> file_info_lock is not initalized in initiate_cifs_search(), leading to the following splat after a simple "mount.cifs ... dir && ls dir/": BUG: spinlock bad magic on CPU#0, ls/486 lock: 0xffff880009301110, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0 CPU: 0 PID: 486 Comm: ls Not tainted 4.9.0 #27 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996) ffffc900042f3db0 ffffffff81327533 0000000000000000 ffff880009301110 ffffc900042f3dd0 ffffffff810baf75 ffff880009301110 ffffffff817ae077 ffffc900042f3df0 ffffffff810baff6 ffff880009301110 ffff880008d69900 Call Trace: [<ffffffff81327533>] dump_stack+0x65/0x92 [<ffffffff810baf75>] spin_dump+0x85/0xe0 [<ffffffff810baff6>] spin_bug+0x26/0x30 [<ffffffff810bb159>] do_raw_spin_lock+0xe9/0x130 [<ffffffff8159ad2f>] _raw_spin_lock+0x1f/0x30 [<ffffffff8127e50d>] cifs_closedir+0x4d/0x100 [<ffffffff81181cfd>] __fput+0x5d/0x160 [<ffffffff81181e3e>] ____fput+0xe/0x10 [<ffffffff8109410e>] task_work_run+0x7e/0xa0 [<ffffffff81002512>] exit_to_usermode_loop+0x92/0xa0 [<ffffffff810026f9>] syscall_return_slowpath+0x49/0x50 [<ffffffff8159b484>] entry_SYSCALL_64_fastpath+0xa7/0xa9 Fixes: 3afca265b5f53a0 ("Clarify locking of cifs file and tcon structures and make more granular") Signed-off-by: Rabin Vincent <rabinv@axis.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06CIFS: Fix a possible memory corruption in push locksPavel Shilovsky
commit e3d240e9d505fc67f8f8735836df97a794bbd946 upstream. If maxBuf is not 0 but less than a size of SMB2 lock structure we can end up with a memory corruption. Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06CIFS: Decrease verbosity of ioctl callPavel Shilovsky
commit b0a752b5ce76bd1d8b733a53757c3263511dcb69 upstream. Reviewed-by: Aurelien Aptel <aaptel@suse.com> Acked-by: Sachin Prabhu <sprabhu@redhat.com> Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06CIFS: Fix a possible double locking of mutex during reconnectPavel Shilovsky
commit 96a988ffeb90dba33a71c3826086fe67c897a183 upstream. With the current code it is possible to lock a mutex twice when a subsequent reconnects are triggered. On the 1st reconnect we reconnect sessions and tcons and then persistent file handles. If the 2nd reconnect happens during the reconnecting of persistent file handles then the following sequence of calls is observed: cifs_reopen_file -> SMB2_open -> small_smb2_init -> smb2_reconnect -> cifs_reopen_persistent_file_handles -> cifs_reopen_file (again!). So, we are trying to acquire the same cfile->fh_mutex twice which is wrong. Fix this by moving reconnecting of persistent handles to the delayed work (smb2_reconnect_server) and submitting this work every time we reconnect tcon in SMB2 commands handling codepath. This can also lead to corruption of a temporary file list in cifs_reopen_persistent_file_handles() because we can recursively call this function twice. Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06CIFS: Fix missing nls unload in smb2_reconnect()Pavel Shilovsky
commit 4772c79599564bd08ee6682715a7d3516f67433f upstream. Acked-by: Sachin Prabhu <sprabhu@redhat.com> Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06CIFS: Fix a possible memory corruption during reconnectPavel Shilovsky
commit 53e0e11efe9289535b060a51d4cf37c25e0d0f2b upstream. We can not unlock/lock cifs_tcp_ses_lock while walking through ses and tcon lists because it can corrupt list iterator pointers and a tcon structure can be released if we don't hold an extra reference. Fix it by moving a reconnect process to a separate delayed work and acquiring a reference to every tcon that needs to be reconnected. Also do not send an echo request on newly established connections. Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-01-06cifs: Fix smbencrypt() to stop pointing a scatterlist at the stackAndy Lutomirski
commit 06deeec77a5a689cc94b21a8a91a76e42176685d upstream. smbencrypt() points a scatterlist to the stack, which is breaks if CONFIG_VMAP_STACK=y. Fix it by switching to crypto_cipher_encrypt_one(). The new code should be considerably faster as an added benefit. This code is nearly identical to some code that Eric Biggers suggested. Reported-by: Eric Biggers <ebiggers3@gmail.com> Signed-off-by: Andy Lutomirski <luto@kernel.org> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-11-28CIFS: iterate over posix acl xattr entry correctly in ACL_to_cifs_posix()Eryu Guan
Commit 2211d5ba5c6c ("posix_acl: xattr representation cleanups") removes the typedefs and the zero-length a_entries array in struct posix_acl_xattr_header, and uses bare struct posix_acl_xattr_header and struct posix_acl_xattr_entry directly. But it failed to iterate over posix acl slots when converting posix acls to CIFS format, which results in several test failures in xfstests (generic/053 generic/105) when testing against a samba v1 server, starting from v4.9-rc1 kernel. e.g. [root@localhost xfstests]# diff -u tests/generic/105.out /root/xfstests/results//generic/105.out.bad --- tests/generic/105.out 2016-09-19 16:33:28.577962575 +0800 +++ /root/xfstests/results//generic/105.out.bad 2016-10-22 15:41:15.201931110 +0800 @@ -1,3 +1,4 @@ QA output created by 105 -rw-r--r-- root +setfacl: subdir: Invalid argument -rw-r--r-- root Fix it by introducing a new "ace" var, like what cifs_copy_posix_acl() does, and iterating posix acl xattr entries over it in the for loop. Signed-off-by: Eryu Guan <guaneryu@gmail.com> Signed-off-by: Steve French <smfrench@gmail.com>
2016-11-28Call echo service immediately after socket reconnectSachin Prabhu
Commit 4fcd1813e640 ("Fix reconnect to not defer smb3 session reconnect long after socket reconnect") changes the behaviour of the SMB2 echo service and causes it to renegotiate after a socket reconnect. However under default settings, the echo service could take up to 120 seconds to be scheduled. The patch forces the echo service to be called immediately resulting a negotiate call being made immediately on reconnect. Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Steve French <smfrench@gmail.com>
2016-11-28CIFS: Fix BUG() in calc_seckey()Sachin Prabhu
Andy Lutromirski's new virtually mapped kernel stack allocations moves kernel stacks the vmalloc area. This triggers the bug kernel BUG at ./include/linux/scatterlist.h:140! at calc_seckey()->sg_init() Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com>
2016-10-14CIFS: Retrieve uid and gid from special sid if enabledSteve French
New mount option "idsfromsid" indicates to cifs.ko that it should try to retrieve the uid and gid owner fields from special sids. This patch adds the code to parse the owner sids in the ACL to see if they match, and if so populate the uid and/or gid from them. This is faster than upcalling for them and asking winbind, and is a fairly common case, and is also helpful when cifs.upcall and idmapping is not configured. Signed-off-by: Steve French <steve.french@primarydata.com> Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2016-10-14CIFS: Add new mount option to set owner uid and gid from special sids in aclSteve French
Add "idsfromsid" mount option to indicate to cifs.ko that it should try to retrieve the uid and gid owner fields from special sids in the ACL if present. This first patch just adds the parsing for the mount option. Signed-off-by: Steve French <steve.french@primarydata.com> Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2016-10-13CIFS: Reset read oplock to NONE if we have mandatory locks after reopenPavel Shilovsky
We are already doing the same thing for an ordinary open case: we can't keep read oplock on a file if we have mandatory byte-range locks because pagereading can conflict with these locks on a server. Fix it by setting oplock level to NONE. Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Steve French <smfrench@gmail.com>
2016-10-13CIFS: Fix persistent handles re-opening on reconnectPavel Shilovsky
openFileList of tcon can be changed while cifs_reopen_file() is called that can lead to an unexpected behavior when we return to the loop. Fix this by introducing a temp list for keeping all file handles that need to be reopen. Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com> Signed-off-by: Steve French <smfrench@gmail.com>
2016-10-13SMB2: Separate RawNTLMSSP authentication from SMB2_sess_setupSachin Prabhu
We split the rawntlmssp authentication into negotiate and authencate parts. We also clean up the code and add helpers. Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2016-10-13SMB2: Separate Kerberos authentication from SMB2_sess_setupSachin Prabhu
Add helper functions and split Kerberos authentication off SMB2_sess_setup. Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2016-10-13Expose cifs module parameters in sysfsGermano Percossi
/sys/module/cifs/parameters should display the three other module load time configuration settings for cifs.ko Signed-off-by: Germano Percossi <germano.percossi@citrix.com> Signed-off-by: Steve French <steve.french@primarydata.com>
