path: root/fs/cifs
2013-11-16Merge branch 'for-linus' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "A set of cifs fixes most important of which is Pavel's fix for some problems with handling Windows reparse points and also the security fix for setfacl over a cifs mount to Samba removing part of the ACL. Both of these fixes are for stable as well. Also added most of copychunk (copy offload) support to cifs although I expect a final patch in that series (to fix handling of larger files) in a few days (had to hold off on that in order to incorporate some additional code review feedback). Also added support for O_DIRECT on forcedirectio mounts (needed in order to run some of the server benchmarks over cifs and smb2/smb3 mounts)" * 'for-linus' of git://git.samba.org/sfrench/cifs-2.6: [CIFS] Warn if SMB3 encryption required by server setfacl removes part of ACL when setting POSIX ACLs to Samba [CIFS] Set copychunk defaults CIFS: SMB2/SMB3 Copy offload support (refcopy) phase 1 cifs: Use data structures to compute NTLMv2 response offsets [CIFS] O_DIRECT opens should work on directio mounts cifs: don't spam the logs on unexpected lookup errors cifs: change ERRnomem error mapping from ENOMEM to EREMOTEIO CIFS: Fix symbolic links usage
2013-11-15[CIFS] Warn if SMB3 encryption required by serverSteve French
We do not support SMB3 encryption yet, warn if server responds that SMB3 encryption is mandatory. Signed-off-by: Steve French <smfrench@gmail.com>
2013-11-15setfacl removes part of ACL when setting POSIX ACLs to SambaSteve French
setfacl over cifs mounts can remove the default ACL when setting the (non-default part of) the ACL and vice versa (we were leaving at 0 rather than setting to -1 the count field for the unaffected half of the ACL. For example notice the setfacl removed the default ACL in this sequence: steven@steven-GA-970A-DS3:~/cifs-2.6$ getfacl /mnt/test-dir ; setfacl -m default:user:test:rwx,user:test:rwx /mnt/test-dir getfacl: Removing leading '/' from absolute path names user::rwx group::r-x other::r-x default:user::rwx default:user:test:rwx default:group::r-x default:mask::rwx default:other::r-x steven@steven-GA-970A-DS3:~/cifs-2.6$ getfacl /mnt/test-dir getfacl: Removing leading '/' from absolute path names user::rwx user:test:rwx group::r-x mask::rwx other::r-x CC: Stable <stable@kernel.org> Signed-off-by: Steve French <smfrench@gmail.com> Acked-by: Jeremy Allison <jra@samba.org>
2013-11-15[CIFS] Set copychunk defaultsSteve French
Patch 2 of the copy chunk series (the final patch will use these to handle copies of files larger than the chunk size. We set the same defaults that Windows and Samba expect for CopyChunk. Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: David Disseldorp <ddiss@samba.org>
2013-11-14CIFS: SMB2/SMB3 Copy offload support (refcopy) phase 1Steve French
This first patch adds the ability for us to do a server side copy (ie fast copy offloaded to the server to perform, aka refcopy) "cp --reflink" of one file to another located on the same server. This is much faster than traditional copy (which requires reading and writing over the network and extra memcpys). This first version is not going to be copy files larger than about 1MB (to Samba) until I add support for multiple chunks and for autoconfiguring the chunksize. It includes: 1) processing of the ioctl 2) marshalling and sending the SMB2/SMB3 fsctl over the network 3) simple parsing of the response It does not include yet (these will be in followon patches to come soon): 1) support for multiple chunks 2) support for autoconfiguring and remembering the chunksize 3) Support for the older style copychunk which Samba 4.1 server supports (because this requires write permission on the target file, which cp does not give you, apparently per-posix). This may require a distinct tool (other than cp) and other ioctl to implement. Reviewed-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <smfrench@gmail.com>
2013-11-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: "All kinds of stuff this time around; some more notable parts: - RCU'd vfsmounts handling - new primitives for coredump handling - files_lock is gone - Bruce's delegations handling series - exportfs fixes plus misc stuff all over the place" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (101 commits) ecryptfs: ->f_op is never NULL locks: break delegations on any attribute modification locks: break delegations on link locks: break delegations on rename locks: helper functions for delegation breaking locks: break delegations on unlink namei: minor vfs_unlink cleanup locks: implement delegations locks: introduce new FL_DELEG lock flag vfs: take i_mutex on renamed file vfs: rename I_MUTEX_QUOTA now that it's not used for quotas vfs: don't use PARENT/CHILD lock classes for non-directories vfs: pull ext4's double-i_mutex-locking into common code exportfs: fix quadratic behavior in filehandle lookup exportfs: better variable name exportfs: move most of reconnect_path to helper function exportfs: eliminate unused "noprogress" counter exportfs: stop retrying once we race with rename/remove exportfs: clear DISCONNECTED on all parents sooner exportfs: more detailed comment for path_reconnect ...
2013-11-11cifs: Use data structures to compute NTLMv2 response offsetsTim Gardner
A bit of cleanup plus some gratuitous variable renaming. I think using structures instead of numeric offsets makes this code much more understandable. Also added a comment about current time range expected by the server. Acked-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Shirish Pargaonkar <spargaonkar@suse.com> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-11-11[CIFS] O_DIRECT opens should work on directio mountsSteve French
Opens on current cifs/smb2/smb3 mounts with O_DIRECT flag fail even when caching is disabled on the mount. This was reported by those running SMB2 benchmarks who need to be able to pass O_DIRECT on many of their open calls to reduce caching effects, but would also be needed by other applications. When mounting with forcedirectio ("cache=none") cifs and smb2/smb3 do not go through the page cache and thus opens with O_DIRECT flag should work (when posix extensions are negotiated we even are able to send the flag to the server). This patch fixes that in a simple way. The 9P client has a similar situation (caching is often disabled) and takes the same approach to O_DIRECT support ie works if caching disabled, but if client caching enabled it fails with EINVAL. A followon idea for a future patch as Pavel noted, could be that files opened with O_DIRECT could cause us to change inode->i_fop on the fly from cifs_file_strict_ops to cifs_file_direct_ops which would allow us to support this on non-forcedirectio mounts (cache=strict and cache=loose) as well. Reviewed-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <smfrench@gmail.com>
2013-11-11cifs: don't spam the logs on unexpected lookup errorsJeff Layton
Andrey reported that he was seeing cifs.ko spam the logs with messages like this: CIFS VFS: Unexpected lookup error -26 He was listing the root directory of a server and hitting an error when trying to QUERY_PATH_INFO against hiberfil.sys and pagefile.sys. The right fix would be to switch the lookup code over to using FIND_FIRST, but until then we really don't need to report this at a level of KERN_ERR. Convert this message over to FYI level. Reported-by: "Andrey Shernyukov" <andreysh@nioch.nsc.ru> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-11-11cifs: change ERRnomem error mapping from ENOMEM to EREMOTEIOJeff Layton
Sometimes, the server will report an error that basically indicates that it's running out of resources. These include these under SMB1: NT_STATUS_NO_MEMORY NT_STATUS_SECTION_TOO_BIG NT_STATUS_TOO_MANY_PAGING_FILES ...and this one under SMB2: STATUS_NO_MEMORY Currently, this gets mapped to ENOMEM by the client, but that's confusing as an ENOMEM error is typically an indicator that the client is out of memory. Change these errors to instead map to EREMOTEIO to indicate that the problem is actually server-side and not on the client. Reported-by: "ISHIKAWA,chiaki" <ishikawa@yk.rim.or.jp> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-11-11CIFS: Fix symbolic links usagePavel Shilovsky
Now we treat any reparse point as a symbolic link and map it to a Unix one that is not true in a common case due to many reparse point types supported by SMB servers. Distinguish reparse point types into two groups: 1) that can be accessed directly through a reparse point (junctions, deduplicated files, NFS symlinks); 2) that need to be processed manually (Windows symbolic links, DFS); and map only Windows symbolic links to Unix ones. Cc: <stable@vger.kernel.org> Acked-by: Jeff Layton <jlayton@redhat.com> Reported-and-tested-by: Joao Correia <joaomiguelcorreia@gmail.com> Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <smfrench@gmail.com>
2013-11-08Merge branch 'for-linus' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS updates from Steve French: "Includes a couple of fixes, plus changes to make multiplex identifiers easier to read and correlate with network traces, and a set of enhancements for SMB3 dialect. Also adds support for per-file compression for both cifs and smb2/smb3 ("chattr +c filename). Should have at least one other merge request ready by next week with some new SMB3 security features and copy offload support" * 'for-linus' of git://git.samba.org/sfrench/cifs-2.6: Query network adapter info at mount time for debugging Fix unused variable warning when CIFS POSIX disabled Allow setting per-file compression via CIFS protocol Query File System Alignment Query device characteristics at mount time from server on SMB2/3 not just on cifs mounts cifs: Send a logoff request before removing a smb session cifs: Make big endian multiplex ID sequences monotonic on the wire cifs: Remove redundant multiplex identifier check from check_smb_hdr() Query file system attributes from server on SMB2, not just cifs, mounts Allow setting per-file compression via SMB2/3 Fix corrupt SMB2 ioctl requests
2013-11-08Merge tag 'nfs-for-3.13-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfsLinus Torvalds
Pull NFS client updates from Trond Myklebust: "Highlights include: - Changes to the RPC socket code to allow NFSv4 to turn off timeout+retry: * Detect TCP connection breakage through the "keepalive" mechanism - Add client side support for NFSv4.x migration (Chuck Lever) - Add support for multiple security flavour arguments to the "sec=" mount option (Dros Adamson) - fs-cache bugfixes from David Howells: * Fix an issue whereby caching can be enabled on a file that is open for writing - More NFSv4 open code stable bugfixes - Various Labeled NFS (selinux) bugfixes, including one stable fix - Fix buffer overflow checking in the RPCSEC_GSS upcall encoding" * tag 'nfs-for-3.13-1' of git://git.linux-nfs.org/projects/trondmy/linux-nfs: (68 commits) NFSv4.2: Remove redundant checks in nfs_setsecurity+nfs4_label_init_security NFSv4: Sanity check the server reply in _nfs4_server_capabilities NFSv4.2: encode_readdir - only ask for labels when doing readdirplus nfs: set security label when revalidating inode NFSv4.2: Fix a mismatch between Linux labeled NFS and the NFSv4.2 spec NFS: Fix a missing initialisation when reading the SELinux label nfs: fix oops when trying to set SELinux label nfs: fix inverted test for delegation in nfs4_reclaim_open_state SUNRPC: Cleanup xs_destroy() SUNRPC: close a rare race in xs_tcp_setup_socket. SUNRPC: remove duplicated include from clnt.c nfs: use IS_ROOT not DCACHE_DISCONNECTED SUNRPC: Fix buffer overflow checking in gss_encode_v0_msg/gss_encode_v1_msg SUNRPC: gss_alloc_msg - choose _either_ a v0 message or a v1 message SUNRPC: remove an unnecessary if statement nfs: Use PTR_ERR_OR_ZERO in 'nfs/nfs4super.c' nfs: Use PTR_ERR_OR_ZERO in 'nfs41_callback_up' function nfs: Remove useless 'error' assignment sunrpc: comment typo fix SUNRPC: Add correct rcu_dereference annotation in rpc_clnt_set_transport ...
2013-11-02Query network adapter info at mount time for debuggingSteve French
When CONFIG_CIFS_STATS2 enabled query adapter info for debugging It is easy now in SMB3 to query the information about the server's network interfaces (and at least Windows 8 and above do this, if not other clients) there are some useful pieces of information you can get including: - all of the network interfaces that the server advertises (not just the one you are mounting over), and with SMB3 supporting multichannel this helps with more than just failover (also aggregating multiple sockets under one mount) - whether the adapter supports RSS (useful to know if you want to estimate whether setting up two or more socket connections to the same address is going to be faster due to RSS offload in the adapter) - whether the server supports RDMA - whether the server has IPv6 interfaces (if you connected over IPv4 but prefer IPv6 e.g.) - what the link speed is (you might want to reconnect over a higher speed interface if available) (Of course we could also rerequest this on every mount cheaplly to the same server, as Windows apparently does, so we can update the adapter info on new mounts, and also on every reconnect if the network interface drops temporarily - so we don't have to rely on info from the first mount to this server) It is trivial to request this information - and certainly will be useful when we get to the point of doing multichannel (and eventually RDMA), but some of this (linkspeed etc.) info may help for debugging in the meantime. Enable this request when CONFIG_CIFS_STATS2 is on (only for smb3 mounts since it is an SMB3 or later ioctl). Signed-off-by: Steve French <smfrench@gmail.com>
2013-11-02Fix unused variable warning when CIFS POSIX disabledSteve French
Fix unused variable warning when CONFIG_CIFS_POSIX disabled. fs/cifs/ioctl.c: In function 'cifs_ioctl': >> fs/cifs/ioctl.c:40:8: warning: unused variable 'ExtAttrMask' [-Wunused-variable] __u64 ExtAttrMask = 0; ^ Pointed out by 0-DAY kernel build testing backend Signed-off-by: Steve French <smfrench@gmail.com>
2013-11-02Allow setting per-file compression via CIFS protocolSteve French
An earlier patch allowed setting the per-file compression flag "chattr +c filename" on an smb2 or smb3 mount, and also allowed lsattr to return whether a file on a cifs, or smb2/smb3 mount was compressed. This patch extends the ability to set the per-file compression flag to the cifs protocol, which uses a somewhat different IOCTL mechanism than SMB2, although the payload (the flags stored in the compression_state) are the same. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-11-02Query File System AlignmentSteven French
In SMB3 it is now possible to query the file system alignment info, and the preferred (for performance) sector size and whether the underlying disk has no seek penalty (like SSD). Query this information at mount time for SMB3, and make it visible in /proc/fs/cifs/DebugData for debugging purposes. This alignment information and preferred sector size info will be helpful for the copy offload patches to setup the right chunks in the CopyChunk requests. Presumably the knowledge that the underlying disk is SSD could also help us make better readahead and writebehind decisions (something to look at in the future). Signed-off-by: Steve French <smfrench@gmail.com>
2013-11-02Query device characteristics at mount time from server on SMB2/3 not just on ↵Steven French
cifs mounts Currently SMB2 and SMB3 mounts do not query the device information at mount time from the server as is done for cifs. These can be useful for debugging. This is a minor patch, that extends the previous one (which added ability to query file system attributes at mount time - this returns the device characteristics - also via in /proc/fs/cifs/DebugData) Signed-off-by: Steve French <smfrench@gmail.com>
2013-11-02cifs: Send a logoff request before removing a smb sessionShirish Pargaonkar
Send a smb session logoff request before removing smb session off of the list. On a signed smb session, remvoing a session off of the list before sending a logoff request results in server returning an error for lack of smb signature. Never seen an error during smb logoff, so as per MS-SMB2 3.2.5.1, not sure how an error during logoff should be retried. So for now, if a server returns an error to a logoff request, log the error and remove the session off of the list. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-11-02cifs: Make big endian multiplex ID sequences monotonic on the wireTim Gardner
The multiplex identifier (MID) in the SMB header is only ever used by the client, in conjunction with PID, to match responses from the server. As such, the endianess of the MID is not important. However, When tracing packet sequences on the wire, protocol analyzers such as wireshark display MID as little endian. It is much more informative for the on-the-wire MID sequences to match debug information emitted by the CIFS driver. Therefore, one should write and read MID in the SMB header assuming it is always little endian. Observed from wireshark during the protocol negotiation and session setup: Multiplex ID: 256 Multiplex ID: 256 Multiplex ID: 512 Multiplex ID: 512 Multiplex ID: 768 Multiplex ID: 768 After this patch on-the-wire MID values begin at 1 and increase monotonically. Introduce get_next_mid64() for the internal consumers that use the full 64 bit multiplex identifier. Introduce the helpers get_mid() and compare_mid() to make the endian translation clear. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Tim Gardner <timg@tpi.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-10-28cifs: Remove redundant multiplex identifier check from check_smb_hdr()Tim Gardner
The only call site for check_smb_header() assigns 'mid' from the SMB packet, which is then checked again in check_smb_header(). This seems like redundant redundancy. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Tim Gardner <timg@tpi.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-10-28Query file system attributes from server on SMB2, not just cifs, mountsSteve French
Currently SMB2 and SMB3 mounts do not query the file system attributes from the server at mount time as is done for cifs. These can be useful for debugging. Signed-off-by: Steve French <smfrench@gmail.com>
2013-10-28Allow setting per-file compression via SMB2/3Steve French
Allow cifs/smb2/smb3 to return whether or not a file is compressed via lsattr, and allow SMB2/SMB3 to set the per-file compression flag ("chattr +c filename" on an smb3 mount). Windows users often set the compressed flag (it can be done from the desktop and file manager). David Disseldorp has patches to Samba server to support this (at least on btrfs) which are complementary to this Signed-off-by: Steve French <smfrench@gmail.com>
2013-10-28Fix corrupt SMB2 ioctl requestsSteve French
We were off by one calculating the length of ioctls in some cases because the protocol specification for SMB2 ioctl includes a mininum one byte payload but not all SMB2 ioctl requests actually have a data buffer to send. We were also not zeroing out the return buffer (in case of error this is helpful). Signed-off-by: Steve French <smfrench@gmail.com>
2013-10-24cifs: rcu-delay unload_nls() and freeing sbiAl Viro
makes ->d_hash(), ->d_compare() and ->permission() safety in RCU mode independent from vfsmount_lock. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-10-24new helper: kfree_put_link()Al Viro
duplicated to hell and back... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-10-14cifs: ntstatus_to_dos_map[] is not terminatedTim Gardner
Functions that walk the ntstatus_to_dos_map[] array could run off the end. For example, ntstatus_to_dos() loops while ntstatus_to_dos_map[].ntstatus is not 0. Granted, this is mostly theoretical, but could be used as a DOS attack if the error code in the SMB header is bogus. [Might consider adding to stable, as this patch is low risk - Steve] Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-10-07cifs: Allow LANMAN auth method for servers supporting unencapsulated ↵Sachin Prabhu
authentication methods This allows users to use LANMAN authentication on servers which support unencapsulated authentication. The patch fixes a regression where users using plaintext authentication were no longer able to do so because of changed bought in by patch 3f618223dc0bdcbc8d510350e78ee2195ff93768 https://bugzilla.redhat.com/show_bug.cgi?id=1011621 Reported-by: Panos Kavalagios <Panagiotis.Kavalagios@eurodyn.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-10-07cifs: Fix inability to write files >2GB to SMB2/3 sharesJan Klos
When connecting to SMB2/3 shares, maximum file size is set to non-LFS maximum in superblock. This is due to cap_large_files bit being different for SMB1 and SMB2/3 (where it is just an internal flag that is not negotiated and the SMB1 one corresponds to multichannel capability, so maybe LFS works correctly if server sends 0x08 flag) while capabilities are checked always for the SMB1 bit in cifs_read_super(). The patch fixes this by checking for the correct bit according to the protocol version. CC: Stable <stable@kernel.org> Signed-off-by: Jan Klos <honza.klos@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-10-06cifs: Avoid umount hangs with smb2 when server is unresponsiveShirish Pargaonkar
Do not send SMB2 Logoff command when reconnecting, the way smb1 code base works. Also, no need to wait for a credit for an echo command when one is already in flight. Without these changes, umount command hangs if the server is unresponsive e.g. hibernating. Signed-off-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@us.ibm.com>
2013-10-05do not treat non-symlink reparse points as valid symlinksSteve French
Windows 8 and later can create NFS symlinks (within reparse points) which we were assuming were normal NTFS symlinks and thus reporting corrupt paths for. Add check for reparse points to make sure that they really are normal symlinks before we try to parse the pathname. We also should not be parsing other types of reparse points (DFS junctions etc) as if they were a symlink so return EOPNOTSUPP on those. Also fix endian errors (we were not parsing symlink lengths as little endian). This fixes commit d244bf2dfbebfded05f494ffd53659fa7b1e32c1 which implemented follow link for non-Unix CIFS mounts CC: Stable <stable@kernel.org> Reviewed-by: Andrew Bartlett <abartlet@samba.org> Signed-off-by: Steve French <smfrench@gmail.com>
2013-10-04Merge branch 'for-linus' of git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
Pull CIFS fixes from Steve French: "Small set of cifs fixes. Most important is Jeff's fix that works around disconnection problems which can be caused by simultaneous use of user space tools (starting a long running smbclient backup then doing a cifs kernel mount) or multiple cifs mounts through a NAT, and Jim's fix to deal with reexport of cifs share. I expect to send two more cifs fixes next week (being tested now) - fixes to address an SMB2 unmount hang when server dies and a fix for cifs symlink handling of Windows "NFS" symlinks" * 'for-linus' of git://git.samba.org/sfrench/cifs-2.6: [CIFS] update cifs.ko version [CIFS] Remove ext2 flags that have been moved to fs.h [CIFS] Provide sane values for nlink cifs: stop trying to use virtual circuits CIFS: FS-Cache: Uncache unread pages in cifs_readpages() before freeing them
2013-09-27FS-Cache: Provide the ability to enable/disable cookiesDavid Howells
Provide the ability to enable and disable fscache cookies. A disabled cookie will reject or ignore further requests to: Acquire a child cookie Invalidate and update backing objects Check the consistency of a backing object Allocate storage for backing page Read backing pages Write to backing pages but still allows: Checks/waits on the completion of already in-progress objects Uncaching of pages Relinquishment of cookies Two new operations are provided: (1) Disable a cookie: void fscache_disable_cookie(struct fscache_cookie *cookie, bool invalidate); If the cookie is not already disabled, this locks the cookie against other dis/enablement ops, marks the cookie as being disabled, discards or invalidates any backing objects and waits for cessation of activity on any associated object. This is a wrapper around a chunk split out of fscache_relinquish_cookie(), but it reinitialises the cookie such that it can be reenabled. All possible failures are handled internally. The caller should consider calling fscache_uncache_all_inode_pages() afterwards to make sure all page markings are cleared up. (2) Enable a cookie: void fscache_enable_cookie(struct fscache_cookie *cookie, bool (*can_enable)(void *data), void *data) If the cookie is not already enabled, this locks the cookie against other dis/enablement ops, invokes can_enable() and, if the cookie is not an index cookie, will begin the procedure of acquiring backing objects. The optional can_enable() function is passed the data argument and returns a ruling as to whether or not enablement should actually be permitted to begin. All possible failures are handled internally. The cookie will only be marked as enabled if provisional backing objects are allocated. A later patch will introduce these to NFS. Cookie enablement during nfs_open() is then contingent on i_writecount <= 0. can_enable() checks for a race between open(O_RDONLY) and open(O_WRONLY/O_RDWR). This simplifies NFS's cookie handling and allows us to get rid of open(O_RDONLY) accidentally introducing caching to an inode that's open for writing already. One operation has its API modified: (3) Acquire a cookie. struct fscache_cookie *fscache_acquire_cookie( struct fscache_cookie *parent, const struct fscache_cookie_def *def, void *netfs_data, bool enable); This now has an additional argument that indicates whether the requested cookie should be enabled by default. It doesn't need the can_enable() function because the caller must prevent multiple calls for the same netfs object and it doesn't need to take the enablement lock because no one else can get at the cookie before this returns. Signed-off-by: David Howells <dhowells@redhat.com
2013-09-25[CIFS] update cifs.ko versionSteve French
To 2.02 Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-25[CIFS] Remove ext2 flags that have been moved to fs.hSteve French
These flags were unused by cifs and since the EXT flags have been moved to common code in uapi/linux/fs.h we won't need to have a cifs specific copy. Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-21[CIFS] Provide sane values for nlinkJim McDonough
Since we don't get info about the number of links from the readdir linfo levels, stat() will return 0 for st_nlink, and in particular, samba re-exported shares will show directories as files (as samba is keying off st_nlink before evaluating how to set the dos modebits) when doing a dir or ls. Copy nlink to the inode, unless it wasn't provided. Provide sane values if we don't have an existing one and none was provided. Signed-off-by: Jim McDonough <jmcd@samba.org> Reviewed-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: David Disseldorp <ddiss@samba.org> Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-18Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "atomic_open-related fixes (Miklos' series, with EEXIST-related parts replaced with fix in fs/namei.c:atomic_open() instead of messing with the instances) + race fix in autofs + leak on failure exit in 9p" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: 9p: don't forget to destroy inode cache if fscache registration fails atomic_open: take care of EEXIST in no-open case with O_CREAT|O_EXCL in fs/namei.c vfs: don't set FILE_CREATED before calling ->atomic_open() nfs: set FILE_CREATED gfs2: set FILE_CREATED cifs: fix filp leak in cifs_atomic_open() vfs: improve i_op->atomic_open() documentation autofs4: close the races around autofs4_notify_daemon()
2013-09-18cifs: stop trying to use virtual circuitsJeff Layton
Currently, we try to ensure that we use vcnum of 0 on the first established session on a connection and then try to use a different vcnum on each session after that. This is a little odd, since there's no real reason to use a different vcnum for each SMB session. I can only assume there was some confusion between SMB sessions and VCs. That's somewhat understandable since they both get created during SESSION_SETUP, but the documentation indicates that they are really orthogonal. The comment on max_vcs in particular looks quite misguided. An SMB session is already uniquely identified by the SMB UID value -- there's no need to again uniquely ID with a VC. Furthermore, a vcnum of 0 is a cue to the server that it should release any resources that were previously held by the client. This sounds like a good thing, until you consider that: a) it totally ignores the fact that other programs on the box (e.g. smbclient) might have connections established to the server. Using a vcnum of 0 causes them to get kicked off. b) it causes problems with NAT. If several clients are connected to the same server via the same NAT'ed address, whenever one connects to the server it kicks off all the others, which then reconnect and kick off the first one...ad nauseum. I don't see any reason to ignore the advice in "Implementing CIFS" which has a comprehensive treatment of virtual circuits. In there, it states "...and contrary to the specs the client should always use a VcNumber of one, never zero." Have the client just use a hardcoded vcnum of 1, and stop abusing the special behavior of vcnum 0. Reported-by: Sauron99@gmx.de <sauron99@gmx.de> Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Volker Lendecke <vl@samba.org> Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-18CIFS: FS-Cache: Uncache unread pages in cifs_readpages() before freeing themDavid Howells
In cifs_readpages(), we may decide we don't want to read a page after all - but the page may already have passed through fscache_read_or_alloc_pages() and thus have marks and reservations set. Thus we have to call fscache_readpages_cancel() or fscache_uncache_page() on the pages we're returning to clear the marks. NFS, AFS and 9P should be unaffected by this as they call read_cache_pages() which does the cleanup for you. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-16cifs: fix filp leak in cifs_atomic_open()Miklos Szeredi
If an error occurs after having called finish_open() then fput() needs to be called on the already opened file. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Steve French <sfrench@samba.org> Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-09-13cifs: Avoid calling unlock_page() twice in cifs_readpage() when using fscacheSachin Prabhu
When reading a single page with cifs_readpage(), we make a call to fscache_read_or_alloc_page() which once done, asynchronously calls the completion function cifs_readpage_from_fscache_complete(). This completion function unlocks the page once it has been populated from cache. The module then attempts to unlock the page a second time in cifs_readpage() which leads to warning messages. In case of a successful call to fscache_read_or_alloc_page() we should skip the second unlock_page() since this will be called by the cifs_readpage_from_fscache_complete() once the page has been populated by fscache. With the modifications to cifs_readpage_worker(), we will need to re-grab the page lock in cifs_write_begin(). The problem was first noticed when testing new fscache patches for cifs. https://bugzilla.redhat.com/show_bug.cgi?id=1005737 Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-13cifs: Do not take a reference to the page in cifs_readpage_worker()Sachin Prabhu
We do not need to take a reference to the pagecache in cifs_readpage_worker() since the calling function will have already taken one before passing the pointer to the page as an argument to the function. Signed-off-by: Sachin Prabhu <sprabhu@redhat.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-12Merge branch 'akpm' (patches from Andrew Morton)Linus Torvalds
Merge more patches from Andrew Morton: "The rest of MM. Plus one misc cleanup" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (35 commits) mm/Kconfig: add MMU dependency for MIGRATION. kernel: replace strict_strto*() with kstrto*() mm, thp: count thp_fault_fallback anytime thp fault fails thp: consolidate code between handle_mm_fault() and do_huge_pmd_anonymous_page() thp: do_huge_pmd_anonymous_page() cleanup thp: move maybe_pmd_mkwrite() out of mk_huge_pmd() mm: cleanup add_to_page_cache_locked() thp: account anon transparent huge pages into NR_ANON_PAGES truncate: drop 'oldsize' truncate_pagecache() parameter mm: make lru_add_drain_all() selective memcg: document cgroup dirty/writeback memory statistics memcg: add per cgroup writeback pages accounting memcg: check for proper lock held in mem_cgroup_update_page_stat memcg: remove MEMCG_NR_FILE_MAPPED memcg: reduce function dereference memcg: avoid overflow caused by PAGE_ALIGN memcg: rename RESOURCE_MAX to RES_COUNTER_MAX memcg: correct RESOURCE_MAX to ULLONG_MAX mm: memcg: do not trap chargers with full callstack on OOM mm: memcg: rework and document OOM waiting and wakeup ...
2013-09-12truncate: drop 'oldsize' truncate_pagecache() parameterKirill A. Shutemov
truncate_pagecache() doesn't care about old size since commit cedabed49b39 ("vfs: Fix vmtruncate() regression"). Let's drop it. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-09-09CIFS: Respect epoch value from create lease context v2Pavel Shilovsky
that force a client to purge cache pages when a server requests it. Signed-off-by: Pavel Shilovsky <pshilovsky@samba.org> Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-09CIFS: Add create lease v2 context for SMB3Pavel Shilovsky
2013-09-09CIFS: Move parsing lease buffer to ops structPavel Shilovsky
2013-09-09CIFS: Move creating lease buffer to ops structPavel Shilovsky
to make adding new types of lease buffers easier. Signed-off-by: Pavel Shilovsky <pshilovsky@samba.org> Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-09CIFS: Store lease state itself rather than a mapped oplock valuePavel Shilovsky
and separate smb20_operations struct. Signed-off-by: Pavel Shilovsky <pshilovsky@samba.org> Signed-off-by: Steve French <smfrench@gmail.com>
2013-09-08CIFS: Replace clientCanCache* bools with an integerPavel Shilovsky
that prepare the code to handle different types of SMB2 leases. Signed-off-by: Pavel Shilovsky <pshilovsky@samba.org> Signed-off-by: Steve French <smfrench@gmail.com>
