commit 97f4b7276b829a8927ac903a119bef2f963ccc58 upstream.
also replaces memset()+kfree() by kzfree().
Signed-off-by: Aurelien Aptel <aaptel@suse.com>
Signed-off-by: Steve French <smfrench@gmail.com>
Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
commit 9aca7e454415f7878b28524e76bebe1170911a88 upstream.
Autonegotiation gives a security settings mismatch error if the SMB
server selects an SMBv3 dialect that isn't SMB3.02. The exact error is
"protocol revalidation - security settings mismatch".
This can be tested using Samba v4.2 or by setting the global Samba
setting max protocol = SMB3_00.
The check that fails in smb3_validate_negotiate is the dialect
verification of the negotiate info response. This is because it tries
to verify against the protocol_id in the global smbdefault_values. The
protocol_id in smbdefault_values is SMB3.02.
In SMB2_negotiate the protocol_id in smbdefault_values isn't updated,
it is global so it probably shouldn't be, but server->dialect is.
This patch changes the check in smb3_validate_negotiate to use
server->dialect instead of server->vals->protocol_id. The patch works
with autonegotiate and when using a specific version in the vers mount
option.
Signed-off-by: Daniel N Pettersson <danielnp@axis.com>
commit f04a703c3d613845ae3141bfaf223489de8ab3eb upstream.
If cifs_zap_mapping() returned an error, we would return without putting
the xid that we got earlier. Restructure cifs_file_strict_mmap() and
cifs_file_mmap() to be more similar to each other and have a single
point of return that always puts the xid.
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
commit f74bc7c6679200a4a83156bb89cbf6c229fe8ec0 upstream.
And fix tcon leak in error path.
Signed-off-by: Ronnie Sahlberg <lsahlber@redhat.com>
Reviewed-by: David Disseldorp <ddiss@samba.org>
commit 511c54a2f69195b28afb9dd119f03787b1625bb4 upstream.
According to the MS-SMB2 spec (3.2.5.1.6) once the client receives
STATUS_NETWORK_SESSION_EXPIRED error code from a server it should
reconnect the current SMB session. Currently the client doesn't do
that. This can result in subsequent client requests failing by
the server. The patch adds an additional logic to the demultiplex
thread to identify expired sessions and reconnect them.
Signed-off-by: Pavel Shilovsky <pshilov@microsoft.com>
commit 1013e760d10e614dc10b5624ce9fc41563ba2e65 upstream.
Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com>
commit 0603c96f3af50e2f9299fa410c224ab1d465e0f9 upstream.
As long as signing is supported (ie not a guest user connection) and
connection is SMB3 or SMB3.02, then validate negotiate (protect
against man in the middle downgrade attacks). We had been doing this
only when signing was required, not when signing was just enabled,
but this more closely matches recommended SMB3 behavior and is
better security. Suggested by Metze.
Reviewed-by: Jeremy Allison <jra@samba.org>
Acked-by: Stefan Metzmacher <metze@samba.org>
commit c721c38957fb19982416f6be71aae7b30630d83b upstream.
It can be confusing if user ends up authenticated as guest but they
requested signing (server will return error validating signed packets)
so add log message for this.
commit 23586b66d84ba3184b8820277f3fc42761640f87 upstream.
Samba rejects SMB3.1.1 dialect (vers=3.1.1) negotiate requests from
the kernel client due to the two byte pad at the end of the negotiate
contexts.
commit f5c4ba816315d3b813af16f5571f86c8d4e897bd upstream.
There is a race that cause cifs reconnect in cifs_mount,
- cifs_mount
- cifs_get_tcp_session
- [ start thread cifs_demultiplex_thread
- cifs_read_from_socket: -ECONNABORTED
- DELAY_WORK smb2_reconnect_server ]
- cifs_setup_session
- [ smb2_reconnect_server ]
auth_key.response was allocated in cifs_setup_session, and
will release when the session destoried. So when session re-
connect, auth_key.response should be check and released.
Tested with my system:
CIFS VFS: Free previous auth_key.response = ffff8800320bbf80
A simple auth_key.response allocation call trace:
- SMB2_sess_setup
- SMB2_sess_auth_rawntlmssp_authenticate
- build_ntlmssp_auth_blob
- setup_ntlmv2_rsp
Signed-off-by: Shu Wang <shuwang@redhat.com>
commit 94183331e815617246b1baa97e0916f358c794bb upstream.
memory leak was found by kmemleak. exit_cifs_spnego
should be called before cifs module removed, or
cifs root_cred will not be released.
kmemleak report:
unreferenced object 0xffff880070a3ce40 (size 192):
backtrace:
kmemleak_alloc+0x4a/0xa0
kmem_cache_alloc+0xc7/0x1d0
prepare_kernel_cred+0x20/0x120
init_cifs_spnego+0x2d/0x170 [cifs]
0xffffffffc07801f3
do_one_initcall+0x51/0x1b0
do_init_module+0x60/0x1fd
load_module+0x161e/0x1b60
SYSC_finit_module+0xa9/0x100
SyS_finit_module+0xe/0x10
commit 6e3c1529c39e92ed64ca41d53abadabbaa1d5393 upstream.
Recent patch had an endian warning ie
cifs: return ENAMETOOLONG for overlong names in cifs_open()/cifs_lookup()
CC: Ronnie Sahlberg <lsahlber@redhat.com>
Acked-by: Pavel Shilovsky <pshilov@microsoft.com>
commit 9e37b1784f2be9397a903307574ee565bbadfd75 upstream.
Currently the maximum size of SMB2/3 header is set incorrectly which
leads to hanging of directory listing operations on encrypted SMB3
connections. Fix this by setting the maximum size to 170 bytes that
is calculated as RFC1002 length field size (4) + transform header
size (52) + SMB2 header size (64) + create response size (56).
Acked-by: Sachin Prabhu <sprabhu@redhat.com>
commit d3edede29f74d335f81d95a4588f5f136a9f7dcf upstream.
Add checking for the path component length and verify it is <= the maximum
that the server advertizes via FileFsAttributeInformation.
With this patch cifs.ko will now return ENAMETOOLONG instead of ENOENT
when users to access an overlong path.
To test this, try to cd into a (non-existing) directory on a CIFS share
that has a too long name:
cd /mnt/aaaaaaaaaaaaaaa...
and it now should show a good error message from the shell:
bash: cd: /mnt/aaaaaaaaaaaaaaaa...aaaaaa: File name too long
rh bz 1153996
commit 42bec214d8bd432be6d32a1acb0a9079ecd4d142 upstream.
The df for a SMB2 share triggers a GetInfo call for
FS_FULL_SIZE_INFORMATION. The values returned are used to populate
struct statfs.
The problem is that none of the information returned by the call
contains the total blocks available on the filesystem. Instead we use
the blocks available to the user ie. quota limitation when filling out
statfs.f_blocks. The information returned does contain Actual free units
on the filesystem and is used to populate statfs.f_bfree. For users with
quota enabled, it can lead to situations where the total free space
reported is more than the total blocks on the system ending up with df
reports like the following
# df -h /mnt/a
Filesystem Size Used Avail Use% Mounted on
//192.168.22.10/a 2.5G -2.3G 2.5G - /mnt/a
To fix this problem, we instead populate both statfs.f_bfree with the
same value as statfs.f_bavail ie. CallerAvailableAllocationUnits. This
is similar to what is done already in the code for cifs and df now
reports the quota information for the user used to mount the share.
# df --si /mnt/a
//192.168.22.10/a 2.7G 101M 2.6G 4% /mnt/a
Signed-off-by: Sachin Prabhu <sprabhu@redhat.com>
Signed-off-by: Pierguido Lambri <plambri@redhat.com>
commit dcd87838c06f05ab7650b249ebf0d5b57ae63e1e upstream.
Downgrade the loglevel for SMB2 to prevent filling the log
with messages if e.g. readdir was interrupted. Also make SMB2
and SMB1 codepaths do the same logging during readdir.
commit 85435d7a15294f9f7ef23469e6aaf7c5dfcc54f0 upstream.
SFM is mapping doublequote to 0xF020
Without this patch creating files with doublequote fails to Windows/Mac
Signed-off-by: Bjoern Jacke <bjacke@samba.org>
commit d8a6e505d6bba2250852fbc1c1c86fe68aaf9af3 upstream.
An open directory may have a NULL private_data pointer prior to readdir.
Fixes: 0de1f4c6f6c0 ("Add way to query server fs info for smb3")
Signed-off-by: David Disseldorp <ddiss@suse.de>
commit 3998e6b87d4258a70df358296d6f1c7234012bfe upstream.
When the final cifsFileInfo_put() is called from cifsiod and an oplock
break work is queued, lockdep complains loudly:
[ INFO: possible recursive locking detected ]
4.11.0+ #21 Not tainted
kworker/0:2/78 is trying to acquire lock:
("cifsiod"){++++.+}, at: flush_work+0x215/0x350
but task is already holding lock:
("cifsiod"){++++.+}, at: process_one_work+0x255/0x8e0
Possible unsafe locking scenario:
CPU0
lock("cifsiod");
lock("cifsiod");
*** DEADLOCK ***
May be due to missing lock nesting notation
2 locks held by kworker/0:2/78:
#0: ("cifsiod"){++++.+}, at: process_one_work+0x255/0x8e0
#1: ((&wdata->work)){+.+...}, at: process_one_work+0x255/0x8e0
stack backtrace:
CPU: 0 PID: 78 Comm: kworker/0:2 Not tainted 4.11.0+ #21
Workqueue: cifsiod cifs_writev_complete
Call Trace:
dump_stack+0x85/0xc2
__lock_acquire+0x17dd/0x2260
? match_held_lock+0x20/0x2b0
? trace_hardirqs_off_caller+0x86/0x130
? mark_lock+0xa6/0x920
lock_acquire+0xcc/0x260
? lock_acquire+0xcc/0x260
? flush_work+0x215/0x350
flush_work+0x236/0x350
? destroy_worker+0x170/0x170
__cancel_work_timer+0x17d/0x210
? ___preempt_schedule+0x16/0x18
cancel_work_sync+0x10/0x20
cifsFileInfo_put+0x338/0x7f0
cifs_writedata_release+0x2a/0x40
? cifs_writedata_release+0x2a/0x40
cifs_writev_complete+0x29d/0x850
? preempt_count_sub+0x18/0xd0
process_one_work+0x304/0x8e0
worker_thread+0x9b/0x6a0
kthread+0x1b2/0x200
? process_one_work+0x8e0/0x8e0
? kthread_create_on_node+0x40/0x40
ret_from_fork+0x31/0x40
This is a real warning. Since the oplock is queued on the same
workqueue this can deadlock if there is only one worker thread active
for the workqueue (which will be the case during memory pressure when
the rescuer thread is handling it).
Furthermore, there is at least one other kind of hang possible due to
the oplock break handling if there is only worker. (This can be
reproduced without introducing memory pressure by having passing 1 for
the max_active parameter of cifsiod.) cifs_oplock_break() can wait
indefintely in the filemap_fdatawait() while the cifs_writev_complete()
work is blocked:
sysrq: SysRq : Show Blocked State
task PC stack pid father
kworker/0:1 D 0 16 2 0x00000000
Workqueue: cifsiod cifs_oplock_break
Call Trace:
__schedule+0x562/0xf40
? mark_held_locks+0x4a/0xb0
schedule+0x57/0xe0
io_schedule+0x21/0x50
wait_on_page_bit+0x143/0x190
? add_to_page_cache_lru+0x150/0x150
__filemap_fdatawait_range+0x134/0x190
? do_writepages+0x51/0x70
filemap_fdatawait_range+0x14/0x30
filemap_fdatawait+0x3b/0x40
cifs_oplock_break+0x651/0x710
kthread+0x1b2/0x200
dd D 0 683 171 0x00000000
Call Trace:
? mark_held_locks+0x29/0xb0
schedule+0x57/0xe0
filemap_write_and_wait+0x4e/0x70
cifs_flush+0x6a/0xb0
filp_close+0x52/0xa0
__close_fd+0xdc/0x150
SyS_close+0x33/0x60
entry_SYSCALL_64_fastpath+0x1f/0xbe
Showing all locks held in the system:
2 locks held by kworker/0:1/16:
#0: ("cifsiod"){.+.+.+}, at: process_one_work+0x255/0x8e0
#1: ((&cfile->oplock_break)){+.+.+.}, at: process_one_work+0x255/0x8e0
Showing busy workqueues and worker pools:
workqueue cifsiod: flags=0xc
pwq 0: cpus=0 node=0 flags=0x0 nice=0 active=1/1
in-flight: 16:cifs_oplock_break
delayed: cifs_writev_complete, cifs_echo_request
pool 0: cpus=0 node=0 flags=0x0 nice=0 hung=0s workers=3 idle: 750 3
Fix these problems by creating a a new workqueue (with a rescuer) for
the oplock break work.
Signed-off-by: Rabin Vincent <rabinv@axis.com>
commit 6026685de33b0db5b2b6b0e9b41b3a1a3261033c upstream.
As with 618763958b22, an open directory may have a NULL private_data
pointer prior to readdir. CIFS_ENUMERATE_SNAPSHOTS must check for this
before dereference.
Fixes: 834170c85978 ("Enable previous version support")
commit 0e5c795592930d51fd30d53a2e7b73cba022a29b upstream.
The server may respond with success, and an output buffer less than
sizeof(struct smb_snapshot_array) in length. Do not leak the output
buffer in this case.
commit b704e70b7cf48f9b67c07d585168e102dfa30bb4 upstream.
- trailing space maps to 0xF028
- trailing period maps to 0xF029
This fix corrects the mapping of file names which have a trailing character
that would otherwise be illegal (period or space) but is allowed by POSIX.
commit 7db0a6efdc3e990cdfd4b24820d010e9eb7890ad upstream.
Macs send the maximum buffer size in response on ioctl to validate
negotiate security information, which causes us to fail the mount
as the response buffer is larger than the expected response.
Changed ioctl response processing to allow for padding of validate
negotiate ioctl response and limit the maximum response size to
maximum buffer size.
Signed-off-by: Steve French <steve.french@primarydata.com>
commit 26c9cb668c7fbf9830516b75d8bee70b699ed449 upstream.
Mac requires the unicode flag to be set for cifs, even for the smb
echo request (which doesn't have strings).
Without this Mac rejects the periodic echo requests (when mounting
with cifs) that we use to check if server is down
commit cd8c42968ee651b69e00f8661caff32b0086e82d upstream.
Incorrect return value for shares not using the prefix path means that
we will never match superblocks for these shares.
Fixes: commit c1d8b24d1819 ("Compare prepaths when comparing superblocks")
commit 38bd49064a1ecb67baad33598e3d824448ab11ec upstream.
A signal can interrupt a SendReceive call which result in incoming
responses to the call being ignored. This is a problem for calls such as
open which results in the successful response being ignored. This
results in an open file resource on the server.
The patch looks into responses which were cancelled after being sent and
in case of successful open closes the open fids.
For this patch, the check is only done in SendReceive2()
RH-bz: 1403319
commit a0918f1ce6a43ac980b42b300ec443c154970979 upstream.
STATUS_BAD_NETWORK_NAME can be received during node failover,
causing the flag to be set and making the reconnect thread
always unsuccessful, thereafter.
Once the only place where it is set is removed, the remaining
bits are rendered moot.
Removing it does not prevent "mount" from failing when a non
existent share is passed.
What happens when the share really ceases to exist while the
share is mounted is undefined now as much as it was before.
Signed-off-by: Germano Percossi <germano.percossi@citrix.com>
commit 62a6cfddcc0a5313e7da3e8311ba16226fe0ac10 upstream.
commit 4fcd1813e640 ("Fix reconnect to not defer smb3 session reconnect
long after socket reconnect") added support for Negotiate requests to
be initiated by echo calls.
To avoid delays in calling echo after a reconnect, I added the patch
introduced by the commit b8c600120fc8 ("Call echo service immediately
after socket reconnect").
This has however caused a regression with cifs shares which do not have
support for echo calls to trigger Negotiate requests. On connections
which need to call Negotiation, the echo calls trigger an error which
triggers a reconnect which in turn triggers another echo call. This
results in a loop which is only broken when an operation is performed on
the cifs share. For an idle share, it can DOS a server.
The patch uses the smb_operation can_echo() for cifs so that it is
called only if connection has been already been setup.
kernel bz: 194531
Tested-by: Jonathan Liu <net147@gmail.com>
commit 1fa839b4986d648b907d117275869a0e46c324b9 upstream.
This fixes Continuous Availability when errors during
file reopen are encountered.
cifs_user_readv and cifs_user_writev would wait for ever if
results of cifs_reopen_file are not stored and for later inspection.
In fact, results are checked and, in case of errors, a chain
of function calls leading to reads and writes to be scheduled in
a separate thread is skipped.
These threads will wake up the corresponding waiters once reads
and writes are done.
However, given the return value is not stored, when rc is checked
for errors a previous one (always zero) is inspected instead.
This leads to pending reads/writes added to the list, making
cifs_user_readv and cifs_user_writev wait for ever.
commit 18ea43113f5b74a97dd4be9bddbac10d68b1a6ce upstream.
In case of error, smb2_reconnect_server reschedule itself
with a delay, to avoid being too aggressive.
commit 806a28efe9b78ffae5e2757e1ee924b8e50c08ab upstream.
Currently the cifs module breaks the CIFS specs on reconnect as
described in http://msdn.microsoft.com/en-us/library/cc246529.aspx:
"TreeId (4 bytes): Uniquely identifies the tree connect for the
command. This MUST be 0 for the SMB2 TREE_CONNECT Request."
Signed-off-by: Jan-Marek Glogowski <glogow@fbihome.de>
Reviewed-by: Aurelien Aptel <aaptel@suse.com>
Tested-by: Aurelien Aptel <aaptel@suse.com>
commit 93faccbbfa958a9668d3ab4e30f38dd205cee8d8 upstream.
To support unprivileged users mounting filesystems two permission
checks have to be performed: a test to see if the user allowed to
create a mount in the mount namespace, and a test to see if
the user is allowed to access the specified filesystem.
The automount case is special in that mounting the original filesystem
grants permission to mount the sub-filesystems, to any user who
happens to stumble across the their mountpoint and satisfies the
ordinary filesystem permission checks.
Attempting to handle the automount case by using override_creds
almost works. It preserves the idea that permission to mount
the original filesystem is permission to mount the sub-filesystem.
Unfortunately using override_creds messes up the filesystems
ordinary permission checks.
Solve this by being explicit that a mount is a submount by introducing
vfs_submount, and using it where appropriate.
vfs_submount uses a new mount internal mount flags MS_SUBMOUNT, to let
sget and friends know that a mount is a submount so they can take appropriate
action.
sget and sget_userns are modified to not perform any permission checks
on submounts.
follow_automount is modified to stop using override_creds as that
has proven problemantic.
do_mount is modified to always remove the new MS_SUBMOUNT flag so
that we know userspace will never by able to specify it.
autofs4 is modified to stop using current_real_cred that was put in
there to handle the previous version of submount permission checking.
cifs is modified to pass the mountpoint all of the way down to vfs_submount.
debugfs is modified to pass the mountpoint all of the way down to
trace_automount by adding a new parameter. To make this change easier
a new typedef debugfs_automount_t is introduced to capture the type of
the debugfs automount function.
Fixes: 069d5ac9ae0d ("autofs: Fix automounts by using current_real_cred()->uid")
Fixes: aeaa4a79ff6a ("fs: Call d_automount with the filesystems creds")
Reviewed-by: Trond Myklebust <trond.myklebust@primarydata.com>
Reviewed-by: Seth Forshee <seth.forshee@canonical.com>
commit 9c25702cee1405099f982894c865c163de7909a8 upstream.
Currently we call copy_page_to_iter() for uncached reading into a pipe.
This is wrong because it treats pages as VFS cache pages and copies references
rather than actual data. When we are trying to read from the pipe we end up
calling page_cache_pipe_buf_confirm() which returns -ENODATA. This error
is translated into 0 which is returned to a user.
This issue is reproduced by running xfs-tests suite (generic test #249)
against mount points with "cache=none". Fix it by mapping pages manually
and calling copy_to_iter() that copies data into the pipe.
commit 81ddd8c0c5e1cb41184d66567140cb48c53eb3d1 upstream.
Reviewed-by: Jeff Layton <jlayton@redhat.com>
file_info_lock is not initalized in initiate_cifs_search(), leading to the
following splat after a simple "mount.cifs ... dir && ls dir/":
BUG: spinlock bad magic on CPU#0, ls/486
lock: 0xffff880009301110, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0
CPU: 0 PID: 486 Comm: ls Not tainted 4.9.0 #27
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996)
ffffc900042f3db0 ffffffff81327533 0000000000000000 ffff880009301110
ffffc900042f3dd0 ffffffff810baf75 ffff880009301110 ffffffff817ae077
ffffc900042f3df0 ffffffff810baff6 ffff880009301110 ffff880008d69900
Call Trace:
[<ffffffff81327533>] dump_stack+0x65/0x92
[<ffffffff810baf75>] spin_dump+0x85/0xe0
[<ffffffff810baff6>] spin_bug+0x26/0x30
[<ffffffff810bb159>] do_raw_spin_lock+0xe9/0x130
[<ffffffff8159ad2f>] _raw_spin_lock+0x1f/0x30
[<ffffffff8127e50d>] cifs_closedir+0x4d/0x100
[<ffffffff81181cfd>] __fput+0x5d/0x160
[<ffffffff81181e3e>] ____fput+0xe/0x10
[<ffffffff8109410e>] task_work_run+0x7e/0xa0
[<ffffffff81002512>] exit_to_usermode_loop+0x92/0xa0
[<ffffffff810026f9>] syscall_return_slowpath+0x49/0x50
[<ffffffff8159b484>] entry_SYSCALL_64_fastpath+0xa7/0xa9
Fixes: 3afca265b5f53a0 ("Clarify locking of cifs file and tcon structures and make more granular")
commit e3d240e9d505fc67f8f8735836df97a794bbd946 upstream.
If maxBuf is not 0 but less than a size of SMB2 lock structure
we can end up with a memory corruption.
commit b0a752b5ce76bd1d8b733a53757c3263511dcb69 upstream.
commit 96a988ffeb90dba33a71c3826086fe67c897a183 upstream.
With the current code it is possible to lock a mutex twice when
a subsequent reconnects are triggered. On the 1st reconnect we
reconnect sessions and tcons and then persistent file handles.
If the 2nd reconnect happens during the reconnecting of persistent
file handles then the following sequence of calls is observed:
cifs_reopen_file -> SMB2_open -> small_smb2_init -> smb2_reconnect
-> cifs_reopen_persistent_file_handles -> cifs_reopen_file (again!).
So, we are trying to acquire the same cfile->fh_mutex twice which
is wrong. Fix this by moving reconnecting of persistent handles to
the delayed work (smb2_reconnect_server) and submitting this work
every time we reconnect tcon in SMB2 commands handling codepath.
This can also lead to corruption of a temporary file list in
cifs_reopen_persistent_file_handles() because we can recursively
call this function twice.
commit 4772c79599564bd08ee6682715a7d3516f67433f upstream.
commit 53e0e11efe9289535b060a51d4cf37c25e0d0f2b upstream.
We can not unlock/lock cifs_tcp_ses_lock while walking through ses
and tcon lists because it can corrupt list iterator pointers and
a tcon structure can be released if we don't hold an extra reference.
Fix it by moving a reconnect process to a separate delayed work
and acquiring a reference to every tcon that needs to be reconnected.
Also do not send an echo request on newly established connections.
commit 06deeec77a5a689cc94b21a8a91a76e42176685d upstream.
smbencrypt() points a scatterlist to the stack, which is breaks if
CONFIG_VMAP_STACK=y.
Fix it by switching to crypto_cipher_encrypt_one(). The new code
should be considerably faster as an added benefit.
This code is nearly identical to some code that Eric Biggers
suggested.
Reported-by: Eric Biggers <ebiggers3@gmail.com>
Signed-off-by: Andy Lutomirski <luto@kernel.org>
Acked-by: Jeff Layton <jlayton@redhat.com>
Commit 2211d5ba5c6c ("posix_acl: xattr representation cleanups")
removes the typedefs and the zero-length a_entries array in struct
posix_acl_xattr_header, and uses bare struct posix_acl_xattr_header
and struct posix_acl_xattr_entry directly.
But it failed to iterate over posix acl slots when converting posix
acls to CIFS format, which results in several test failures in
xfstests (generic/053 generic/105) when testing against a samba v1
server, starting from v4.9-rc1 kernel. e.g.
[root@localhost xfstests]# diff -u tests/generic/105.out /root/xfstests/results//generic/105.out.bad
--- tests/generic/105.out 2016-09-19 16:33:28.577962575 +0800
+++ /root/xfstests/results//generic/105.out.bad 2016-10-22 15:41:15.201931110 +0800
@@ -1,3 +1,4 @@
QA output created by 105
-rw-r--r-- root
+setfacl: subdir: Invalid argument
-rw-r--r-- root
Fix it by introducing a new "ace" var, like what
cifs_copy_posix_acl() does, and iterating posix acl xattr entries
over it in the for loop.
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
Commit 4fcd1813e640 ("Fix reconnect to not defer smb3 session reconnect
long after socket reconnect") changes the behaviour of the SMB2 echo
service and causes it to renegotiate after a socket reconnect. However
under default settings, the echo service could take up to 120 seconds to
be scheduled.
The patch forces the echo service to be called immediately resulting a
negotiate call being made immediately on reconnect.
Andy Lutromirski's new virtually mapped kernel stack allocations moves
kernel stacks the vmalloc area. This triggers the bug
kernel BUG at ./include/linux/scatterlist.h:140!
at calc_seckey()->sg_init()
New mount option "idsfromsid" indicates to cifs.ko that
it should try to retrieve the uid and gid owner fields
from special sids. This patch adds the code to parse the owner
sids in the ACL to see if they match, and if so populate the
uid and/or gid from them. This is faster than upcalling for
them and asking winbind, and is a fairly common case, and is
also helpful when cifs.upcall and idmapping is not configured.
Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
Add "idsfromsid" mount option to indicate to cifs.ko that it should
try to retrieve the uid and gid owner fields from special sids in the
ACL if present. This first patch just adds the parsing for the mount
option.
We are already doing the same thing for an ordinary open case:
we can't keep read oplock on a file if we have mandatory byte-range
locks because pagereading can conflict with these locks on a server.
Fix it by setting oplock level to NONE.
openFileList of tcon can be changed while cifs_reopen_file() is called
that can lead to an unexpected behavior when we return to the loop.
Fix this by introducing a temp list for keeping all file handles that
need to be reopen.
We split the rawntlmssp authentication into negotiate and
authencate parts. We also clean up the code and add helpers.
Add helper functions and split Kerberos authentication off
SMB2_sess_setup.
/sys/module/cifs/parameters should display the three
other module load time configuration settings for cifs.ko
