path: root/fs/coda/dir.c
2016-10-10Merge remote-tracking branch 'ovl/rename2' into for-linusAl Viro
2016-09-27fs: Replace CURRENT_TIME_SEC with current_time() for inode timestampsDeepa Dinamani
CURRENT_TIME_SEC is not y2038 safe. current_time() will be transitioned to use 64 bit time along with vfs in a separate patch. There is no plan to transistion CURRENT_TIME_SEC to use y2038 safe time interfaces. current_time() will also be extended to use superblock range checking parameters when range checking is introduced. This works because alloc_super() fills in the the s_time_gran in super block to NSEC_PER_SEC. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-27fs: rename "rename2" i_op to "rename"Miklos Szeredi
Generated patch: sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2` sed -i "s/\brename2\b/rename/g" `git grep -wl rename2` Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-09-27fs: make remaining filesystems use .rename2Miklos Szeredi
This is trivial to do: - add flags argument to foo_rename() - check if flags is zero - assign foo_rename() to .rename2 instead of .rename This doesn't mean it's impossible to support RENAME_NOREPLACE for these filesystems, but it is not trivial, like for local filesystems. RENAME_NOREPLACE must guarantee atomicity (i.e. it shouldn't be possible for a file to be created on one host while it is overwritten by rename on another host). Filesystems converted: 9p, afs, ceph, coda, ecryptfs, kernfs, lustre, ncpfs, nfs, ocfs2, orangefs. After this, we can get rid of the duplicate interfaces for rename. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: David Howells <dhowells@redhat.com> [AFS] Acked-by: Mike Marshall <hubcap@omnibond.com> Cc: Eric Van Hensbergen <ericvh@gmail.com> Cc: Ilya Dryomov <idryomov@gmail.com> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Cc: Tyler Hicks <tyhicks@canonical.com> Cc: Oleg Drokin <oleg.drokin@intel.com> Cc: Trond Myklebust <trond.myklebust@primarydata.com> Cc: Mark Fasheh <mfasheh@suse.com>
2016-05-02introduce a parallel variant of ->iterate()Al Viro
New method: ->iterate_shared(). Same arguments as in ->iterate(), called with the directory locked only shared. Once all filesystems switch, the old one will be gone. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-22wrappers for ->i_mutex accessAl Viro
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested}, inode_foo(inode) being mutex_foo(&inode->i_mutex). Please, use those for access to ->i_mutex; over the coming cycle ->i_mutex will become rwsem, with ->lookup() done with it held only shared. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-22VFS: (Scripted) Convert S_ISLNK/DIR/REG(dentry->d_inode) to d_is_*(dentry)David Howells
Convert the following where appropriate: (1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry). (2) S_ISREG(dentry->d_inode) to d_is_reg(dentry). (3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more complicated than it appears as some calls should be converted to d_can_lookup() instead. The difference is whether the directory in question is a real dir with a ->lookup op or whether it's a fake dir with a ->d_automount op. In some circumstances, we can subsume checks for dentry->d_inode not being NULL into this, provided we the code isn't in a filesystem that expects d_inode to be NULL if the dirent really *is* negative (ie. if we're going to use d_inode() rather than d_backing_inode() to get the inode pointer). Note that the dentry type field may be set to something other than DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS manages the fall-through from a negative dentry to a lower layer. In such a case, the dentry type of the negative union dentry is set to the same as the type of the lower dentry. However, if you know d_inode is not NULL at the call site, then you can use the d_is_xxx() functions even in a filesystem. There is one further complication: a 0,0 chardev dentry may be labelled DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was intended for special directory entry types that don't have attached inodes. The following perl+coccinelle script was used: use strict; my @callers; open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') || die "Can't grep for S_ISDIR and co. callers"; @callers = <$fd>; close($fd); unless (@callers) { print "No matches\n"; exit(0); } my @cocci = ( '@@', 'expression E;', '@@', '', '- S_ISLNK(E->d_inode->i_mode)', '+ d_is_symlink(E)', '', '@@', 'expression E;', '@@', '', '- S_ISDIR(E->d_inode->i_mode)', '+ d_is_dir(E)', '', '@@', 'expression E;', '@@', '', '- S_ISREG(E->d_inode->i_mode)', '+ d_is_reg(E)' ); my $coccifile = "tmp.sp.cocci"; open($fd, ">$coccifile") || die $coccifile; print($fd "$_\n") || die $coccifile foreach (@cocci); close($fd); foreach my $file (@callers) { chomp $file; print "Processing ", $file, "\n"; system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 || die "spatch failed"; } [AV: overlayfs parts skipped] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-17fs/coda/dir.c: forward declaration clean-upFabian Frederick
- Move operation structures to avoid forward declarations. - Fix some checkpatch warnings: WARNING: Missing a blank line after declarations + struct inode *host_inode = file_inode(host_file); + mutex_lock(&host_inode->i_mutex); ERROR: that open brace { should be on the previous line +const struct dentry_operations coda_dentry_operations = +{ ERROR: that open brace { should be on the previous line +const struct inode_operations coda_dir_inode_operations = +{ Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-12-11coda_venus_readdir(): use file_inode()Al Viro
2014-10-31new helper: is_root_inode()Al Viro
replace open-coded instances Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-08-08fs/coda: use linux/uaccess.hFabian Frederick
Fix checkpatch warning WARNING: Use #include <linux/uaccess.h> instead of <asm/uaccess.h> Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06fs/coda: use __func__Fabian Frederick
Replace all function names by __func__ in pr_foo() Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06fs/coda: logging prefix uniformizationFabian Frederick
- Add pr_fmt based on module name. - Remove Coda: coda: from pr_foo() Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-06fs/coda: replace printk by pr_foo()Fabian Frederick
No level printk converted to pr_warn or pr_info Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Jan Harkes <jaharkes@cs.cmu.edu> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-09coda_revalidate_inode(): switch to passing inode...Al Viro
2013-10-24file->f_op is never NULL...Al Viro
2013-07-05helper for reading ->d_countAl Viro
2013-06-29coda: don't bother with find_inode_number()Al Viro
the fallback it's using for dcache misses is actually the same value we would've used for inumber anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29[readdir] convert codaAl Viro
2013-06-29[readdir] introduce ->iterate(), ctx->pos, dir_emit()Al Viro
New method - ->iterate(file, ctx). That's the replacement for ->readdir(); it takes callback from ctx->actor, uses ctx->pos instead of file->f_pos and calls dir_emit(ctx, ...) instead of filldir(data, ...). It does *not* update file->f_pos (or look at it, for that matter); iterate_dir() does the update. Note that dir_emit() takes the offset from ctx->pos (and eventually filldir_t will lose that argument). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-22new helper: file_inode(file)Al Viro
2012-07-14don't pass nameidata to ->create()Al Viro
boolean "does it have to be exclusive?" flag is passed instead; Local filesystem should just ignore it - the object is guaranteed not to be there yet. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata * to ->d_revalidate()Al Viro
Just the lookup flags. Die, bastard, die... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-10coda: switch coda_cnode_make() to sane API as well, clean coda_lookup()Al Viro
2012-01-10coda: deal correctly with allocation failure from coda_cnode_makectl()Al Viro
lookup should fail with ENOMEM, not silently make dentry negative. Switched to saner calling conventions, while we are at it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch ->create() to umode_tAl Viro
vfs_create() ignores everything outside of 16bit subset of its mode argument; switching it to umode_t is obviously equivalent and it's the only caller of the method Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch vfs_mkdir() and ->mkdir() to umode_tAl Viro
vfs_mkdir() gets int, but immediately drops everything that might not fit into umode_t and that's the only caller of ->mkdir()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-02filesystems: add missing nlink wrappersMiklos Szeredi
Replace direct i_nlink updates with the respective updater function (inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-07-20don't open-code parent_ino() in assorted ->readdir()Al Viro
2011-07-20coda_venus_readdir(): use offsetof()Al Viro
2011-07-20->permission() sanitizing: don't pass flags to ->permission()Al Viro
not used by the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-28coda: remove unnecessary dentry_unhash on rmdir, dir renameSage Weil
Coda has no problems with references to unlinked directories. CC: Jan Harkes <jaharkes@cs.cmu.edu> CC: coda@cs.cmu.edu CC: codalist@coda.cs.cmu.edu Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rename_dir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each rename method (except gfs2 and xfs) so that it can be dealt with on a per-fs basis. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-12take coda-private headers out of include/linuxAl Viro
2011-01-12switch codaAl Viro
Coda ->d_revalidate() actually checks for root, ->d_delete() is irrelevant. So we can use the same d_op for all coda dentries Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-07fs: provide rcu-walk aware permission i_opsNick Piggin
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: rcu-walk aware d_revalidate methodNick Piggin
Require filesystems be aware of .d_revalidate being called in rcu-walk mode (nd->flags & LOOKUP_RCU). For now do a simple push down, returning -ECHILD from all implementations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache scale dentry refcountNick Piggin
Make d_count non-atomic and protect it with d_lock. This allows us to ensure a 0 refcount dentry remains 0 without dcache_lock. It is also fairly natural when we start protecting many other dentry members with d_lock. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_delete semanticsNick Piggin
Change d_delete from a dentry deletion notification to a dentry caching advise, more like ->drop_inode. Require it to be constant and idempotent, and not take d_lock. This is how all existing filesystems use the callback anyway. This makes fine grained dentry locking of dput and dentry lru scanning much simpler. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25Coda: push BKL regions into coda_upcall()Yoshihisa Abe
Now that shared inode state is locked using the cii->c_lock, the BKL is only used to protect the upcall queues used to communicate with the userspace cache manager. The remaining state is all local and we can push the lock further down into coda_upcall(). Signed-off-by: Yoshihisa Abe <yoshiabe@cs.cmu.edu> Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-25Coda: add spin lock to protect accesses to struct coda_inode_info.Yoshihisa Abe
We mostly need it to protect cached user permissions. The c_flags field is advisory, reading the wrong value is harmless and in the worst case we hit a slow path where we have to make an extra upcall to the userspace cache manager when revalidating a dentry or inode. Signed-off-by: Yoshihisa Abe <yoshiabe@cs.cmu.edu> Signed-off-by: Jan Harkes <jaharkes@cs.cmu.edu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-03-27constify dentry_operations: misc filesystemsAl Viro
2008-10-23[PATCH] move executable checking into ->permission()Miklos Szeredi
For execute permission on a regular files we need to check if file has any execute bits at all, regardless of capabilites. This check is normally performed by generic_permission() but was also added to the case when the filesystem defines its own ->permission() method. In the latter case the filesystem should be responsible for performing this check. Move the check from inode_permission() inside filesystems which are not calling generic_permission(). Create a helper function execute_ok() that returns true if the inode is a directory or if any execute bits are present in i_mode. Also fix up the following code: - coda control file is never executable - sysctl files are never executable - hfs_permission seems broken on MAY_EXEC, remove - hfsplus_permission is eqivalent to generic_permission(), remove Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2008-07-26[PATCH] sanitize ->permission() prototypeAl Viro
* kill nameidata * argument; map the 3 bits in ->flags anybody cares about to new MAY_... ones and pass with the mask. * kill redundant gfs2_iop_permission() * sanitize ecryptfs_permission() * fix remaining places where ->permission() instances might barf on new MAY_... found in mask. The obvious next target in that direction is permission(9) folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
