path: root/fs/compat.c
2016-09-27compat: remove compat_printk()Arnd Bergmann
After 7e8e385aaf6e ("x86/compat: Remove sys32_vm86_warning"), this function has become unused, so we can remove it as well. Link: http://lkml.kernel.org/r/20160617142903.3070388-1-arnd@arndb.de Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org>
2016-09-27fs: compat: remove redundant check of nr_segsShawn Lin
nr_segs should never be less than zero as its type is unsigned long, so let's remove this check. Signed-off-by: Shawn Lin <shawn.lin@rock-chips.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-24Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 updates from Ted Ts'o: "Fix a number of bugs, most notably a potential stale data exposure after a crash and a potential BUG_ON crash if a file has the data journalling flag enabled while it has dirty delayed allocation blocks that haven't been written yet. Also fix a potential crash in the new project quota code and a maliciously corrupted file system. In addition, fix some DAX-specific bugs, including when there is a transient ENOSPC situation and races between writes via direct I/O and an mmap'ed segment that could lead to lost I/O. Finally the usual set of miscellaneous cleanups" * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (23 commits) ext4: pre-zero allocated blocks for DAX IO ext4: refactor direct IO code ext4: fix race in transient ENOSPC detection ext4: handle transient ENOSPC properly for DAX dax: call get_blocks() with create == 1 for write faults to unwritten extents ext4: remove unmeetable inconsisteny check from ext4_find_extent() jbd2: remove excess descriptions for handle_s ext4: remove unnecessary bio get/put ext4: silence UBSAN in ext4_mb_init() ext4: address UBSAN warning in mb_find_order_for_block() ext4: fix oops on corrupted filesystem ext4: fix check of dqget() return value in ext4_ioctl_setproject() ext4: clean up error handling when orphan list is corrupted ext4: fix hang when processing corrupted orphaned inode list ext4: remove trailing \n from ext4_warning/ext4_error calls ext4: fix races between changing inode journal mode and ext4_writepages ext4: handle unwritten or delalloc buffers before enabling data journaling ext4: fix jbd2 handle extension in ext4_ext_truncate_extend_restart() ext4: do not ask jbd2 to write data for delalloc buffers jbd2: add support for avoiding data writes during transaction commits ...
2016-05-02give readdir(2)/getdents(2)/etc. uniform exclusion with lseek()Al Viro
same as read() on regular files has, and for the same reason. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-04-23ext4: allow readdir()'s of large empty directories to be interruptedTheodore Ts'o
If a directory has a large number of empty blocks, iterating over all of them can take a long time, leading to scheduler warnings and users getting irritated when they can't kill a process in the middle of one of these long-running readdir operations. Fix this by adding checks to ext4_readdir() and ext4_htree_fill_tree(). This was reverted earlier due to a typo in the original commit where I experimented with using signal_pending() instead of fatal_signal_pending(). The test was in the wrong place if we were going to return signal_pending() since we would end up returning duplicant entries. See 9f2394c9be47 for a more detailed explanation. Added fix as suggested by Linus to check for signal_pending() in in the filldir() functions. Reported-by: Benjamin LaHaise <bcrl@kvack.org> Google-Bug-Id: 27880676 Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2016-01-04saner calling conventions for copy_mount_options()Al Viro
let it just return NULL, pointer to kernel copy or ERR_PTR(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-31vfs: make first argument of dir_context.actor typedMiklos Szeredi
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-09vfs: move getname() from callers to do_mount()Seunghun Lee
It would make more sense to pass char __user * instead of char * in callers of do_mount() and do getname() inside do_mount(). Suggested-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Seunghun Lee <waydi1@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-09fs: namespace: suppress 'may be used uninitialized' warningsTim Gardner
The gcc version 4.9.1 compiler complains Even though it isn't possible for these variables to not get initialized before they are used. fs/namespace.c: In function ‘SyS_mount’: fs/namespace.c:2720:8: warning: ‘kernel_dev’ may be used uninitialized in this function [-Wmaybe-uninitialized] ret = do_mount(kernel_dev, kernel_dir->name, kernel_type, flags, ^ fs/namespace.c:2699:8: note: ‘kernel_dev’ was declared here char *kernel_dev; ^ fs/namespace.c:2720:8: warning: ‘kernel_type’ may be used uninitialized in this function [-Wmaybe-uninitialized] ret = do_mount(kernel_dev, kernel_dir->name, kernel_type, flags, ^ fs/namespace.c:2697:8: note: ‘kernel_type’ was declared here char *kernel_type; ^ Fix the warnings by simplifying copy_mount_string() as suggested by Al Viro. Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-04-22locks: rename file-private locks to "open file description locks"Jeff Layton
File-private locks have been merged into Linux for v3.15, and *now* people are commenting that the name and macro definitions for the new file-private locks suck. ...and I can't even disagree. The names and command macros do suck. We're going to have to live with these for a long time, so it's important that we be happy with the names before we're stuck with them. The consensus on the lists so far is that they should be rechristened as "open file description locks". The name isn't a big deal for the kernel, but the command macros are not visually distinct enough from the traditional POSIX lock macros. The glibc and documentation folks are recommending that we change them to look like F_OFD_{GETLK|SETLK|SETLKW}. That lessens the chance that a programmer will typo one of the commands wrong, and also makes it easier to spot this difference when reading code. This patch makes the following changes that I think are necessary before v3.15 ships: 1) rename the command macros to their new names. These end up in the uapi headers and so are part of the external-facing API. It turns out that glibc doesn't actually use the fcntl.h uapi header, but it's hard to be sure that something else won't. Changing it now is safest. 2) make the the /proc/locks output display these as type "OFDLCK" Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Carlos O'Donell <carlos@redhat.com> Cc: Stefan Metzmacher <metze@samba.org> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Frank Filz <ffilzlnx@mindspring.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Jeff Layton <jlayton@redhat.com>
2014-04-04Merge branch 'locks-3.15' of git://git.samba.org/jlayton/linuxLinus Torvalds
Pull file locking updates from Jeff Layton: "Highlights: - maintainership change for fs/locks.c. Willy's not interested in maintaining it these days, and is OK with Bruce and I taking it. - fix for open vs setlease race that Al ID'ed - cleanup and consolidation of file locking code - eliminate unneeded BUG() call - merge of file-private lock implementation" * 'locks-3.15' of git://git.samba.org/jlayton/linux: locks: make locks_mandatory_area check for file-private locks locks: fix locks_mandatory_locked to respect file-private locks locks: require that flock->l_pid be set to 0 for file-private locks locks: add new fcntl cmd values for handling file private locks locks: skip deadlock detection on FL_FILE_PVT locks locks: pass the cmd value to fcntl_getlk/getlk64 locks: report l_pid as -1 for FL_FILE_PVT locks locks: make /proc/locks show IS_FILE_PVT locks as type "FLPVT" locks: rename locks_remove_flock to locks_remove_file locks: consolidate checks for compatible filp->f_mode values in setlk handlers locks: fix posix lock range overflow handling locks: eliminate BUG() call when there's an unexpected lock on file close locks: add __acquires and __releases annotations to locks_start and locks_stop locks: remove "inline" qualifier from fl_link manipulation functions locks: clean up comment typo locks: close potential race between setlease and open MAINTAINERS: update entry for fs/locks.c
2014-04-02Merge branch 'x86-x32-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull compat time conversion changes from Peter Anvin: "Despite the branch name this is really neither an x86 nor an x32-specific patchset, although it the implementation of the discussions that followed the x32 security hole a few months ago. This removes get/put_compat_timespec/val() and replaces them with compat_get/put_timespec/val() which are savvy as to the current status of COMPAT_USE_64BIT_TIME. It removes several unused and/or incorrect/misleading functions (like compat_put_timeval_convert which doesn't in fact do any conversion) and also replaces several open-coded implementations what is now called compat_convert_timespec() with that function" * 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: compat: Fix sparse address space warnings compat: Get rid of (get|put)_compat_time(val|spec)
2014-03-31locks: add new fcntl cmd values for handling file private locksJeff Layton
Due to some unfortunate history, POSIX locks have very strange and unhelpful semantics. The thing that usually catches people by surprise is that they are dropped whenever the process closes any file descriptor associated with the inode. This is extremely problematic for people developing file servers that need to implement byte-range locks. Developers often need a "lock management" facility to ensure that file descriptors are not closed until all of the locks associated with the inode are finished. Additionally, "classic" POSIX locks are owned by the process. Locks taken between threads within the same process won't conflict with one another, which renders them useless for synchronization between threads. This patchset adds a new type of lock that attempts to address these issues. These locks conflict with classic POSIX read/write locks, but have semantics that are more like BSD locks with respect to inheritance and behavior on close. This is implemented primarily by changing how fl_owner field is set for these locks. Instead of having them owned by the files_struct of the process, they are instead owned by the filp on which they were acquired. Thus, they are inherited across fork() and are only released when the last reference to a filp is put. These new semantics prevent them from being merged with classic POSIX locks, even if they are acquired by the same process. These locks will also conflict with classic POSIX locks even if they are acquired by the same process or on the same file descriptor. The new locks are managed using a new set of cmd values to the fcntl() syscall. The initial implementation of this converts these values to "classic" cmd values at a fairly high level, and the details are not exposed to the underlying filesystem. We may eventually want to push this handing out to the lower filesystem code but for now I don't see any need for it. Also, note that with this implementation the new cmd values are only available via fcntl64() on 32-bit arches. There's little need to add support for legacy apps on a new interface like this. Signed-off-by: Jeff Layton <jlayton@redhat.com>
2014-03-06fs/compat: convert to COMPAT_SYSCALL_DEFINE with changing parameter typesHeiko Carstens
Some fs compat system calls have unsigned long parameters instead of compat_ulong_t. In order to allow the COMPAT_SYSCALL_DEFINE macro generate code that performs proper zero and sign extension convert all 64 bit parameters their corresponding 32 bit counterparts. compat_sys_io_getevents() is a bit different: the non-compat version has signed parameters for the "min_nr" and "nr" parameters while the compat version has unsigned parameters. So change this as well. For all practical purposes this shouldn't make any difference (doesn't fix a real bug). Also introduce a generic compat_aio_context_t type which can be used everywhere. The access_ok() check within compat_sys_io_getevents() got also removed since the non-compat sys_io_getevents() should be able to handle everything anyway. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2014-03-06fs/compat: convert to COMPAT_SYSCALL_DEFINEHeiko Carstens
Convert all compat system call functions where all parameter types have a size of four or less than four bytes, or are pointer types to COMPAT_SYSCALL_DEFINE. The implicit casts within COMPAT_SYSCALL_DEFINE will perform proper zero and sign extension to 64 bit of all parameters if needed. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2014-03-04compat: let architectures define __ARCH_WANT_COMPAT_SYS_GETDENTS64Heiko Carstens
For architecture dependent compat syscalls in common code an architecture must define something like __ARCH_WANT_<WHATEVER> if it wants to use the code. This however is not true for compat_sys_getdents64 for which architectures must define __ARCH_OMIT_COMPAT_SYS_GETDENTS64 if they do not want the code. This leads to the situation where all architectures, except mips, get the compat code but only x86_64, arm64 and the generic syscall architectures actually use it. So invert the logic, so that architectures actively must do something to get the compat code. This way a couple of architectures get rid of otherwise dead code. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2014-02-02compat: Get rid of (get|put)_compat_time(val|spec)H. Peter Anvin
We have two APIs for compatiblity timespec/val, with confusingly similar names. compat_(get|put)_time(val|spec) *do* handle the case where COMPAT_USE_64BIT_TIME is set, whereas (get|put)_compat_time(val|spec) do not. This is an accident waiting to happen. Clean it up by favoring the full-service version; the limited version is replaced with double-underscore versions static to kernel/compat.c. A common pattern is to convert a struct timespec to kernel format in an allocation on the user stack. Unfortunately it is open-coded in several places. Since this allocation isn't actually needed if COMPAT_USE_64BIT_TIME is true (since user format == kernel format) encapsulate that whole pattern into the function compat_convert_timespec(). An equivalent function should be written for struct timeval if it is needed in the future. Finally, get rid of compat_(get|put)_timeval_convert(): each was only used once, and the latter was not even doing what the function said (no conversion actually was being done.) Moving the conversion into compat_sys_settimeofday() itself makes the code much more similar to sys_settimeofday() itself. v3: Remove unused compat_convert_timeval(). v2: Drop bogus "const" in the destination argument for compat_convert_time*(). Cc: Mauro Carvalho Chehab <m.chehab@samsung.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Hans Verkuil <hans.verkuil@cisco.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Manfred Spraul <manfred@colorfullife.com> Cc: Mateusz Guzik <mguzik@redhat.com> Cc: Rafael Aquini <aquini@redhat.com> Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Catalin Marinas <catalin.marinas@arm.com> Cc: Will Deacon <will.deacon@arm.com> Tested-by: H.J. Lu <hjl.tools@gmail.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2013-06-29[readdir] constify ->actorAl Viro
2013-06-29[readdir] introduce ->iterate(), ctx->pos, dir_emit()Al Viro
New method - ->iterate(file, ctx). That's the replacement for ->readdir(); it takes callback from ctx->actor, uses ctx->pos instead of file->f_pos and calls dir_emit(ctx, ...) instead of filldir(data, ...). It does *not* update file->f_pos (or look at it, for that matter); iterate_dir() does the update. Note that dir_emit() takes the offset from ctx->pos (and eventually filldir_t will lose that argument). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-06-29[readdir] introduce iterate_dir() and dir_contextAl Viro
iterate_dir(): new helper, replacing vfs_readdir(). struct dir_context: contains the readdir callback (and will get more stuff in it), embedded into whatever data that callback wants to deal with; eventually, we'll be passing it to ->readdir() replacement instead of (data,filldir) pair. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-07aio: don't include aio.h in sched.hKent Overstreet
Faster kernel compiles by way of fewer unnecessary includes. [akpm@linux-foundation.org: fix fallout] [akpm@linux-foundation.org: fix build] Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Zach Brown <zab@redhat.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jens Axboe <axboe@kernel.dk> Cc: Asai Thambi S P <asamymuthupa@micron.com> Cc: Selvan Mani <smani@micron.com> Cc: Sam Bradshaw <sbradshaw@micron.com> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Benjamin LaHaise <bcrl@kvack.org> Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-04kill fs/read_write.hAl Viro
fs/compat.c doesn't need it anymore, so let's just move the remaining contents (two typedefs) into fs/read_write.c Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull compat cleanup from Al Viro: "Mostly about syscall wrappers this time; there will be another pile with patches in the same general area from various people, but I'd rather push those after both that and vfs.git pile are in." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: syscalls.h: slightly reduce the jungles of macros get rid of union semop in sys_semctl(2) arguments make do_mremap() static sparc: no need to sign-extend in sync_file_range() wrapper ppc compat wrappers for add_key(2) and request_key(2) are pointless x86: trim sys_ia32.h x86: sys32_kill and sys32_mprotect are pointless get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC merge compat sys_ipc instances consolidate compat lookup_dcookie() convert vmsplice to COMPAT_SYSCALL_DEFINE switch getrusage() to COMPAT_SYSCALL_DEFINE switch epoll_pwait to COMPAT_SYSCALL_DEFINE convert sendfile{,64} to COMPAT_SYSCALL_DEFINE switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect make HAVE_SYSCALL_WRAPPERS unconditional consolidate cond_syscall and SYSCALL_ALIAS declarations teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long get rid of duplicate logics in __SC_....[1-6] definitions
2013-04-09switch compat readv/writev variants to COMPAT_SYSCALL_DEFINEAl Viro
... and take to fs/read_write.c Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-09lift sb_start_write/sb_end_write out of ->aio_write()Al Viro
2013-03-12Fix: compat_rw_copy_check_uvector() misuse in aio, readv, writev, and ↵Mathieu Desnoyers
security keys Looking at mm/process_vm_access.c:process_vm_rw() and comparing it to compat_process_vm_rw() shows that the compatibility code requires an explicit "access_ok()" check before calling compat_rw_copy_check_uvector(). The same difference seems to appear when we compare fs/read_write.c:do_readv_writev() to fs/compat.c:compat_do_readv_writev(). This subtle difference between the compat and non-compat requirements should probably be debated, as it seems to be error-prone. In fact, there are two others sites that use this function in the Linux kernel, and they both seem to get it wrong: Now shifting our attention to fs/aio.c, we see that aio_setup_iocb() also ends up calling compat_rw_copy_check_uvector() through aio_setup_vectored_rw(). Unfortunately, the access_ok() check appears to be missing. Same situation for security/keys/compat.c:compat_keyctl_instantiate_key_iov(). I propose that we add the access_ok() check directly into compat_rw_copy_check_uvector(), so callers don't have to worry about it, and it therefore makes the compat call code similar to its non-compat counterpart. Place the access_ok() check in the same location where copy_from_user() can trigger a -EFAULT error in the non-compat code, so the ABI behaviors are alike on both compat and non-compat. While we are here, fix compat_do_readv_writev() so it checks for compat_rw_copy_check_uvector() negative return values. And also, fix a memory leak in compat_keyctl_instantiate_key_iov() error handling. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-03-03convert vmsplice to COMPAT_SYSCALL_DEFINEAl Viro
2013-03-03switch epoll_pwait to COMPAT_SYSCALL_DEFINEAl Viro
2013-03-03convert sendfile{,64} to COMPAT_SYSCALL_DEFINEAl Viro
2013-03-03switch signalfd{,4}() to COMPAT_SYSCALL_DEFINEAl Viro
2013-02-03switch timerfd compat syscalls to COMPAT_SYSCALL_DEFINEAl Viro
... and move them over to fs/timerfd.c. Cleaner and easier that way... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-02-03switch compat_sys_open* to COMPAT_SYSCALL_DEFINEAl Viro
2012-10-12vfs: define struct filename and have getname() return itJeff Layton
getname() is intended to copy pathname strings from userspace into a kernel buffer. The result is just a string in kernel space. It would however be quite helpful to be able to attach some ancillary info to the string. For instance, we could attach some audit-related info to reduce the amount of audit-related processing needed. When auditing is enabled, we could also call getname() on the string more than once and not need to recopy it from userspace. This patchset converts the getname()/putname() interfaces to return a struct instead of a string. For now, the struct just tracks the string in kernel space and the original userland pointer for it. Later, we'll add other information to the struct as it becomes convenient. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-02compat: fs: Generic compat_sys_sendfile implementationCatalin Marinas
This function is used by sparc, powerpc and arm64 for compat support. The patch adds a generic implementation which calls do_sendfile() directly and avoids set_fs(). The sparc architecture has wrappers for the sign extensions while powerpc relies on the compiler to do the this. The patch adds wrappers for powerpc to handle the u32->int type conversion. compat_sys_sendfile64() can be replaced by a sys_sendfile() call since compat_loff_t has the same size as off_t on a 64-bit system. On powerpc, the patch also changes the 64-bit sendfile call from sys_sendile64 to sys_sendfile. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: David S. Miller <davem@davemloft.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-26switch simple cases of fget_light to fdgetAl Viro
2012-08-20vfs: missed source of ->f_pos racesAl Viro
compat_sys_{read,write}v() need the same "pass a copy of file->f_pos" thing as sys_{read,write}{,v}(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-06-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal Pull third pile of signal handling patches from Al Viro: "This time it's mostly helpers and conversions to them; there's a lot of stuff remaining in the tree, but that'll either go in -rc2 (isolated bug fixes, ideally via arch maintainers' trees) or will sit there until the next cycle." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal: x86: get rid of calling do_notify_resume() when returning to kernel mode blackfin: check __get_user() return value whack-a-mole with TIF_FREEZE FRV: Optimise the system call exit path in entry.S [ver #2] FRV: Shrink TIF_WORK_MASK [ver #2] FRV: Prevent syscall exit tracing and notify_resume at end of kernel exceptions new helper: signal_delivered() powerpc: get rid of restore_sigmask() most of set_current_blocked() callers want SIGKILL/SIGSTOP removed from set set_restore_sigmask() is never called without SIGPENDING (and never should be) TIF_RESTORE_SIGMASK can be set only when TIF_SIGPENDING is set don't call try_to_freeze() from do_signal() pull clearing RESTORE_SIGMASK into block_sigmask() sh64: failure to build sigframe != signal without handler openrisc: tracehook_signal_handler() is supposed to be called on success new helper: sigmask_to_save() new helper: restore_saved_sigmask() new helpers: {clear,test,test_and_clear}_restore_sigmask() HAVE_RESTORE_SIGMASK is defined on all architectures now
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs changes from Al Viro. "A lot of misc stuff. The obvious groups: * Miklos' atomic_open series; kills the damn abuse of ->d_revalidate() by NFS, which was the major stumbling block for all work in that area. * ripping security_file_mmap() and dealing with deadlocks in the area; sanitizing the neighborhood of vm_mmap()/vm_munmap() in general. * ->encode_fh() switched to saner API; insane fake dentry in mm/cleancache.c gone. * assorted annotations in fs (endianness, __user) * parts of Artem's ->s_dirty work (jff2 and reiserfs parts) * ->update_time() work from Josef. * other bits and pieces all over the place. Normally it would've been in two or three pull requests, but signal.git stuff had eaten a lot of time during this cycle ;-/" Fix up trivial conflicts in Documentation/filesystems/vfs.txt (the 'truncate_range' inode method was removed by the VM changes, the VFS update adds an 'update_time()' method), and in fs/btrfs/ulist.[ch] (due to sparse fix added twice, with other changes nearby). * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (95 commits) nfs: don't open in ->d_revalidate vfs: retry last component if opening stale dentry vfs: nameidata_to_filp(): don't throw away file on error vfs: nameidata_to_filp(): inline __dentry_open() vfs: do_dentry_open(): don't put filp vfs: split __dentry_open() vfs: do_last() common post lookup vfs: do_last(): add audit_inode before open vfs: do_last(): only return EISDIR for O_CREAT vfs: do_last(): check LOOKUP_DIRECTORY vfs: do_last(): make ENOENT exit RCU safe vfs: make follow_link check RCU safe vfs: do_last(): use inode variable vfs: do_last(): inline walk_component() vfs: do_last(): make exit RCU safe vfs: split do_lookup() Btrfs: move over to use ->update_time fs: introduce inode operation ->update_time reiserfs: get rid of resierfs_sync_super reiserfs: mark the superblock as dirty a bit later ...
2012-06-01HAVE_RESTORE_SIGMASK is defined on all architectures nowAl Viro
Everyone either defines it in arch thread_info.h or has TIF_RESTORE_SIGMASK and picks default set_restore_sigmask() in linux/thread_info.h. Kill the ifdefs, slap #error in linux/thread_info.h to catch breakage when new ones get merged. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-31aio/vfs: cleanup of rw_copy_check_uvector() and compat_rw_copy_check_uvector()Christopher Yeoh
A cleanup of rw_copy_check_uvector and compat_rw_copy_check_uvector after changes made to support CMA in an earlier patch. Rather than having an additional check_access parameter to these functions, the first paramater type is overloaded to allow the caller to specify CHECK_IOVEC_ONLY which means check that the contents of the iovec are valid, but do not check the memory that they point to. This is used by process_vm_readv/writev where we need to validate that a iovec passed to the syscall is valid but do not want to check the memory that it points to at this point because it refers to an address space in another process. Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-29switch readdir/getdents to fget_light/fput_lightAl Viro
2012-05-15userns: Convert stat to return values mapped from kuids and kgidsEric W. Biederman
- Store uids and gids with kuid_t and kgid_t in struct kstat - Convert uid and gids to userspace usable values with from_kuid and from_kgid Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-03-29Merge branch 'x86-x32-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x32 support for x86-64 from Ingo Molnar: "This tree introduces the X32 binary format and execution mode for x86: 32-bit data space binaries using 64-bit instructions and 64-bit kernel syscalls. This allows applications whose working set fits into a 32 bits address space to make use of 64-bit instructions while using a 32-bit address space with shorter pointers, more compressed data structures, etc." Fix up trivial context conflicts in arch/x86/{Kconfig,vdso/vma.c} * 'x86-x32-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (71 commits) x32: Fix alignment fail in struct compat_siginfo x32: Fix stupid ia32/x32 inversion in the siginfo format x32: Add ptrace for x32 x32: Switch to a 64-bit clock_t x32: Provide separate is_ia32_task() and is_x32_task() predicates x86, mtrr: Use explicit sizing and padding for the 64-bit ioctls x86/x32: Fix the binutils auto-detect x32: Warn and disable rather than error if binutils too old x32: Only clear TIF_X32 flag once x32: Make sure TS_COMPAT is cleared for x32 tasks fs: Remove missed ->fds_bits from cessation use of fd_set structs internally fs: Fix close_on_exec pointer in alloc_fdtable x32: Drop non-__vdso weak symbols from the x32 VDSO x32: Fix coding style violations in the x32 VDSO code x32: Add x32 VDSO support x32: Allow x32 to be configured x32: If configured, add x32 system calls to system call tables x32: Handle process creation x32: Signal-related system calls x86: Add #ifdef CONFIG_COMPAT to <asm/sys_ia32.h> ...
2012-02-28fs: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-02-20compat: Create compat_sys_p{read,write}v64H. J. Lu
For 32-bit ABIs which have real 64-bit registers, we don't want to break the position argument into two. However, we still need compat support to deal with 32-bit pointers, so we can't just use sys_p{read,write} directly. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2012-02-13vfs: fix compat_sys_stat() handling of overflows in st_nlinkAl Viro
Massaged cp_compat_stat() into form closer to cp_new_stat(); the only real issue had been in handling of st_nlink overflows - native 32bit stat(2) returns -EOVERFLOW in such situations, compat one silently loses upper bits. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch open and mkdir syscalls to umode_tAl Viro
2012-01-03vfs: new helper - vfs_ustat()Al Viro
... and bury user_get_super()/statfs_by_dentry() - they are purely internal now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-10-31Cross Memory AttachChristopher Yeoh
The basic idea behind cross memory attach is to allow MPI programs doing intra-node communication to do a single copy of the message rather than a double copy of the message via shared memory. The following patch attempts to achieve this by allowing a destination process, given an address and size from a source process, to copy memory directly from the source process into its own address space via a system call. There is also a symmetrical ability to copy from the current process's address space into a destination process's address space. - Use of /proc/pid/mem has been considered, but there are issues with using it: - Does not allow for specifying iovecs for both src and dest, assuming preadv or pwritev was implemented either the area read from or written to would need to be contiguous. - Currently mem_read allows only processes who are currently ptrace'ing the target and are still able to ptrace the target to read from the target. This check could possibly be moved to the open call, but its not clear exactly what race this restriction is stopping (reason appears to have been lost) - Having to send the fd of /proc/self/mem via SCM_RIGHTS on unix domain socket is a bit ugly from a userspace point of view, especially when you may have hundreds if not (eventually) thousands of processes that all need to do this with each other - Doesn't allow for some future use of the interface we would like to consider adding in the future (see below) - Interestingly reading from /proc/pid/mem currently actually involves two copies! (But this could be fixed pretty easily) As mentioned previously use of vmsplice instead was considered, but has problems. Since you need the reader and writer working co-operatively if the pipe is not drained then you block. Which requires some wrapping to do non blocking on the send side or polling on the receive. In all to all communication it requires ordering otherwise you can deadlock. And in the example of many MPI tasks writing to one MPI task vmsplice serialises the copying. There are some cases of MPI collectives where even a single copy interface does not get us the performance gain we could. For example in an MPI_Reduce rather than copy the data from the source we would like to instead use it directly in a mathops (say the reduce is doing a sum) as this would save us doing a copy. We don't need to keep a copy of the data from the source. I haven't implemented this, but I think this interface could in the future do all this through the use of the flags - eg could specify the math operation and type and the kernel rather than just copying the data would apply the specified operation between the source and destination and store it in the destination. Although we don't have a "second user" of the interface (though I've had some nibbles from people who may be interested in using it for intra process messaging which is not MPI). This interface is something which hardware vendors are already doing for their custom drivers to implement fast local communication. And so in addition to this being useful for OpenMPI it would mean the driver maintainers don't have to fix things up when the mm changes. There was some discussion about how much faster a true zero copy would go. Here's a link back to the email with some testing I did on that: http://marc.info/?l=linux-mm&m=130105930902915&w=2 There is a basic man page for the proposed interface here: http://ozlabs.org/~cyeoh/cma/process_vm_readv.txt This has been implemented for x86 and powerpc, other architecture should mainly (I think) just need to add syscall numbers for the process_vm_readv and process_vm_writev. There are 32 bit compatibility versions for 64-bit kernels. For arch maintainers there are some simple tests to be able to quickly verify that the syscalls are working correctly here: http://ozlabs.org/~cyeoh/cma/cma-test-20110718.tgz Signed-off-by: Chris Yeoh <yeohc@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Cc: <linux-man@vger.kernel.org> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
