commit 9280cdd6fe5b8287a726d24cc1d558b96c8491d7 upstream.
cmd in COMPATIBLE_IOCTL is always a u32, so cast it so there isn't a
warning about an overflow in XFORM.
Signed-off-by: Mark Charlebois <charlebm@gmail.com>
Signed-off-by: Behan Webster <behanw@converseincode.com>
Signed-off-by: Matthias Kaehlcke <mka@chromium.org>
Cc: Nathan Chancellor <natechancellor@gmail.com>
Watchdog core now handles those ioctls centrally, so we want 64 bit
support, too.
Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com>
Cc: linux-fsdevel@vger.kernel.org
Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
Acked-by: Guenter Roeck <linux@roeck-us.net>
Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
The CEC ioctls didn't have compat32 support, so they returned -ENOTTY
when used in a 32 bit application on a 64 bit kernel.
Since all the CEC ioctls are 32-bit compatible adding support for this
API is trivial.
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
We want those fixes in here as well.
Compat ioctl is already introduced in drivers/char/ppdev.c in order to
fix y2038 issue for PP[GS]ETTIME. There is no need to define these
here.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
Tested-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com>
Signed-off-by: Bamvor Jian Zhang <bamvor.zhangjian@linaro.org>
The HCIUARTGETDEVICE, HCIUARTSETFLAGS and HCIUARTGETFLAGS ioctl are
missing the COMPATIBLE_IOCTL declaration.
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
Pull misc vfs updates from Al Viro:
"All kinds of stuff. That probably should've been 5 or 6 separate
branches, but by the time I'd realized how large and mixed that bag
had become it had been too close to -final to play with rebasing.
Some fs/namei.c cleanups there, memdup_user_nul() introduction and
switching open-coded instances, burying long-dead code, whack-a-mole
of various kinds, several new helpers for ->llseek(), assorted
cleanups and fixes from various people, etc.
One piece probably deserves special mention - Neil's
lookup_one_len_unlocked(). Similar to lookup_one_len(), but gets
called without ->i_mutex and tries to avoid ever taking it. That, of
course, means that it's not useful for any directory modifications,
but things like getting inode attributes in nfds readdirplus are fine
with that. I really should've asked for moratorium on lookup-related
changes this cycle, but since I hadn't done that early enough... I
*am* asking for that for the coming cycle, though - I'm going to try
and get conversion of i_mutex to rwsem with ->lookup() done under lock
taken shared.
There will be a patch closer to the end of the window, along the lines
of the one Linus had posted last May - mechanical conversion of
->i_mutex accesses to inode_lock()/inode_unlock()/inode_trylock()/
inode_is_locked()/inode_lock_nested(). To quote Linus back then:
| This is an automated patch using
| sed 's/mutex_lock(&\(.*\)->i_mutex)/inode_lock(\1)/'
| sed 's/mutex_unlock(&\(.*\)->i_mutex)/inode_unlock(\1)/'
| sed 's/mutex_lock_nested(&\(.*\)->i_mutex,[ ]*I_MUTEX_\([A-Z0-9_]*\))/inode_lock_nested(\1, I_MUTEX_\2)/'
| sed 's/mutex_is_locked(&\(.*\)->i_mutex)/inode_is_locked(\1)/'
| sed 's/mutex_trylock(&\(.*\)->i_mutex)/inode_trylock(\1)/'
| with a very few manual fixups
I'm going to send that once the ->i_mutex-affecting stuff in -next
gets mostly merged (or when Linus says he's about to stop taking
merges)"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
nfsd: don't hold i_mutex over userspace upcalls
fs:affs:Replace time_t with time64_t
fs/9p: use fscache mutex rather than spinlock
proc: add a reschedule point in proc_readfd_common()
logfs: constify logfs_block_ops structures
fcntl: allow to set O_DIRECT flag on pipe
fs: __generic_file_splice_read retry lookup on AOP_TRUNCATED_PAGE
fs: xattr: Use kvfree()
[s390] page_to_phys() always returns a multiple of PAGE_SIZE
nbd: use ->compat_ioctl()
fs: use block_device name vsprintf helper
lib/vsprintf: add %*pg format specifier
fs: use gendisk->disk_name where possible
poll: plug an unused argument to do_poll
amdkfd: don't open-code memdup_user()
cdrom: don't open-code memdup_user()
rsxx: don't open-code memdup_user()
mtip32xx: don't open-code memdup_user()
[um] mconsole: don't open-code memdup_user_nul()
[um] hostaudio: don't open-code memdup_user()
Pull vfs copy_file_range updates from Al Viro:
"Several series around copy_file_range/CLONE"
* 'work.copy_file_range' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
btrfs: use new dedupe data function pointer
vfs: hoist the btrfs deduplication ioctl to the vfs
vfs: wire up compat ioctl for CLONE/CLONE_RANGE
cifs: avoid unused variable and label
nfsd: implement the NFSv4.2 CLONE operation
nfsd: Pass filehandle to nfs4_preprocess_stateid_op()
vfs: pull btrfs clone API to vfs layer
locks: new locks_mandatory_area calling convention
vfs: Add vfs_copy_file_range() support for pagecache copies
btrfs: add .copy_file_range file operation
x86: add sys_copy_file_range to syscall tables
vfs: add copy_file_range syscall and vfs helper
This replaces all code in fs/compat_ioctl.c that translated
ioctl arguments into a in-kernel structure, then performed
do_ioctl under set_fs(KERNEL_DS), with code that allocates
data on the user stack and can call the VFS ioctl handler
under USER_DS.
This is done as a hardening measure because the caller
does not know what kind of ioctl handler will be invoked,
only that no corresponding compat_ioctl handler exists and
what the ioctl command number is. The accidental
invocation of an unlocked_ioctl handler that unexpectedly
calls copy_to_user could be a severe security issue.
Signed-off-by: Jann Horn <jann@thejh.net>
In code in fs/compat_ioctl.c that translates ioctl arguments
into a in-kernel structure, then performs sys_ioctl, possibly
under set_fs(KERNEL_DS), this commit changes the sys_ioctl
calls to do_ioctl calls. do_ioctl is a new function that does
the same thing as sys_ioctl, but doesn't look up the fd again.
This change is made to avoid (potential) security issues
because of ioctl handlers that accept one of the ioctl
commands I2C_FUNCS, VIDEO_GET_EVENT, MTIOCPOS, MTIOCGET,
TIOCGSERIAL, TIOCSSERIAL, RTC_IRQP_READ, RTC_EPOCH_READ.
This can happen for multiple reasons:
- The ioctl command number could be reused.
- The ioctl handler might not check the full ioctl
command. This is e.g. true for drm_ioctl.
- The ioctl handler is very special, e.g. cuse_file_ioctl
The real issue is that set_fs(KERNEL_DS) is used here,
but that's fixed in a separate commit
"compat_ioctl: don't call do_ioctl under set_fs(KERNEL_DS)".
This change mitigates potential security issues by
preventing a race that permits invocation of
unlocked_ioctl handlers under KERNEL_DS through compat
code even if a corresponding compat_ioctl handler exists.
So far, no way has been identified to use this to damage
kernel memory without having CAP_SYS_ADMIN in the init ns
(with the capability, doing reads/writes at arbitrary
kernel addresses should be easy through CUSE's ioctl
handler with FUSE_IOCTL_UNRESTRICTED set).
[AV: two missed sys_ioctl() taken care of]
Hoist the btrfs EXTENT_SAME ioctl up to the VFS and make the name
more systematic (FIDEDUPERANGE).
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
The ioctl is named I2C_RDWR for "I2C read/write". But references to it
were misspelled "rdrw". Fix them.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
The FITRIM ioctl has the same arguments on 32-bit and 64-bit
architectures, so we can add it to the list of compatible ioctls and
drop it from compat_ioctl method of various filesystems.
Signed-off-by: Mikulas Patocka <mpatocka@redhat.com>
Cc: Ted Ts'o <tytso@google.com>
This is needed if user space wants to know supported bnep features
by kernel, e.g. if kernel supports sending response to bnep setup
control message. By now there is no possibility to know supported
features by kernel in case of bnep. Ioctls allows only to add connection,
delete connection, get connection list, get connection info. Adding
connection if it's possible (establishing network device connection) is
equivalent to starting bnep session. Bnep session handles data queue of
transmit, receive messages over bnep channel. It means that if we add
connection the received/transmitted data will be parsed immediately. In
case of get bnep features we want to know before session start, if we
should leave setup data on socket queue and let kernel to handle with it,
or in case of no setup handling support, if we should pull this message
and handle setup response within user space.
Signed-off-by: Grzegorz Kolodziejczyk <grzegorz.kolodziejczyk@tieto.com>
All the HCI sockets and ioctl based definitions have been in a global
header file that also includes all the HCI protocol structures. To
make this a bit cleaner, move them into its own file.
This also adjusts fs/compat_ioctl.c to only include this new file
and not all the protocol structures that are not needed.
Some fs compat system calls have unsigned long parameters instead of
compat_ulong_t.
In order to allow the COMPAT_SYSCALL_DEFINE macro generate code that
performs proper zero and sign extension convert all 64 bit parameters
their corresponding 32 bit counterparts.
compat_sys_io_getevents() is a bit different: the non-compat version
has signed parameters for the "min_nr" and "nr" parameters while the
compat version has unsigned parameters.
So change this as well. For all practical purposes this shouldn't make
any difference (doesn't fix a real bug).
Also introduce a generic compat_aio_context_t type which can be used
everywhere.
The access_ok() check within compat_sys_io_getevents() got also removed
since the non-compat sys_io_getevents() should be able to handle
everything anyway.
We cap "nmsgs" at I2C_RDRW_IOCTL_MAX_MSGS (42) but the current code
allows negative values. It's harmless but it makes my static checker
upset so I've made nsmgs unsigned.
Fix warnings about unused local typedefs (reported by gcc 4.8).
Signed-off-by: Han Shen (shenhan@google.com)
Change-Id: I4bccc234f1390daa808d2b309ed112e20c0ac096
This merges the tty changes in 3.7-rc3 into tty-next
The compat ioctl for VIDEO_SET_SPU_PALETTE was missing an error check
while converting ioctl arguments. This could lead to leaking kernel
stack contents into userspace.
Patch extracted from existing fix in grsecurity.
Cc: Brad Spengler <spender@grsecurity.net>
Cc: PaX Team <pageexec@freemail.hu>
Cc: <stable@vger.kernel.org>
This patch defines new ioctl codes TIOCGPKT, TIOCGPTLCK,
TIOCGEXCL for fetching pty's packet mode and locking state,
and exclusive mode of tty.
[ No real handlers for the codes though, this will be
addressed in another patch for easier review and
bisectability ]
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
CC: Alan Cox <alan@lxorguk.ukuu.org.uk>
CC: "H. Peter Anvin" <hpa@zytor.com>
CC: Pavel Emelyanov <xemul@parallels.com>
CC: Jiri Slaby <jslaby@suse.cz>
Pull vfs update from Al Viro:
- big one - consolidation of descriptor-related logics; almost all of
that is moved to fs/file.c
(BTW, I'm seriously tempted to rename the result to fd.c. As it is,
we have a situation when file_table.c is about handling of struct
file and file.c is about handling of descriptor tables; the reasons
are historical - file_table.c used to be about a static array of
struct file we used to have way back).
A lot of stray ends got cleaned up and converted to saner primitives,
disgusting mess in android/binder.c is still disgusting, but at least
doesn't poke so much in descriptor table guts anymore. A bunch of
relatively minor races got fixed in process, plus an ext4 struct file
leak.
- related thing - fget_light() partially unuglified; see fdget() in
there (and yes, it generates the code as good as we used to have).
- also related - bits of Cyrill's procfs stuff that got entangled into
that work; _not_ all of it, just the initial move to fs/proc/fd.c and
switch of fdinfo to seq_file.
- Alex's fs/coredump.c spiltoff - the same story, had been easier to
take that commit than mess with conflicts. The rest is a separate
pile, this was just a mechanical code movement.
- a few misc patches all over the place. Not all for this cycle,
there'll be more (and quite a few currently sit in akpm's tree)."
Fix up trivial conflicts in the android binder driver, and some fairly
simple conflicts due to two different changes to the sock_alloc_file()
interface ("take descriptor handling from sock_alloc_file() to callers"
vs "net: Providing protocol type via system.sockprotoname xattr of
/proc/PID/fd entries" adding a dentry name to the socket)
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits)
MAX_LFS_FILESIZE should be a loff_t
compat: fs: Generic compat_sys_sendfile implementation
fs: push rcu_barrier() from deactivate_locked_super() to filesystems
btrfs: reada_extent doesn't need kref for refcount
coredump: move core dump functionality into its own file
coredump: prevent double-free on an error path in core dumper
usb/gadget: fix misannotations
fcntl: fix misannotations
ceph: don't abuse d_delete() on failure exits
hypfs: ->d_parent is never NULL or negative
vfs: delete surplus inode NULL check
switch simple cases of fget_light to fdget
new helpers: fdget()/fdput()
switch o2hb_region_dev_write() to fget_light()
proc_map_files_readdir(): don't bother with grabbing files
make get_file() return its argument
vhost_set_vring(): turn pollstart/pollstop into bool
switch prctl_set_mm_exe_file() to fget_light()
switch xfs_find_handle() to fget_light()
switch xfs_swapext() to fget_light()
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input
Pull input updates from Dmitry Torokhov:
"A few drivers were updated with device tree bindings and others got a
few small cleanups and fixes."
Fix trivial conflict in drivers/input/keyboard/omap-keypad.c due to
changes clashing with a whitespace cleanup.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: (28 commits)
Input: wacom - mark Intuos5 pad as in-prox when touching buttons
Input: synaptics - adjust threshold for treating position values as negative
Input: hgpk - use %*ph to dump small buffer
Input: gpio_keys_polled - fix dt pdata->nbuttons
Input: Add KD[GS]KBDIACRUC ioctls to the compatible list
Input: omap-keypad - fixed formatting
Input: tegra - move platform data header
Input: wacom - add support for EMR on Cintiq 24HD touch
Input: s3c2410_ts - make s3c_ts_pmops const
Input: samsung-keypad - use of_get_child_count() helper
Input: samsung-keypad - use of_match_ptr()
Input: uinput - fix formatting
Input: uinput - specify exact bit sizes on userspace APIs
Input: uinput - mark failed submission requests as free
Input: uinput - fix race that can block nonblocking read
Input: uinput - return -EINVAL when read buffer size is too small
Input: uinput - take event lock when fetching events from buffer
Input: get rid of MATCH_BIT() macro
Input: rotary-encoder - add DT bindings
Input: rotary-encoder - constify platform data pointers
Wrap the use of TIOCSRS485 and TIOCGRS485 in #ifdef so that we avoid
adding undefined IOCTLs to the ioctl pointer list as compatible
ioctls.
This change was motivated by a build error on a MIPS build.
tree: git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty.git
tty-next
head: ac57e7f38ea6fe7358cd0b7a2f2d21aef5ab70cd
commit: 84c3b84860440a9e3a3666c14112f41311b8f623 [10/16] compat_ioctl:
Add RS-485 IOCTLs to the list
config: mips-fuloong2e_defconfig
All related error/warning messages:
fs/compat_ioctl.c:869:1: error: 'TIOCSRS485' undeclared here (not in a
function)
fs/compat_ioctl.c:870:1: error: 'TIOCGRS485' undeclared here (not in a
function)
vim +869 fs/compat_ioctl.c
863 COMPATIBLE_IOCTL(TIOCSPGRP)
864 COMPATIBLE_IOCTL(TIOCGPGRP)
865 COMPATIBLE_IOCTL(TIOCGPTN)
866 COMPATIBLE_IOCTL(TIOCSPTLCK)
867 COMPATIBLE_IOCTL(TIOCSERGETLSR)
868 COMPATIBLE_IOCTL(TIOCSIG)
> 869 COMPATIBLE_IOCTL(TIOCSRS485)
870 COMPATIBLE_IOCTL(TIOCGRS485)
871 #ifdef TCGETS2
872 COMPATIBLE_IOCTL(TCGETS2)
Reported-by: Fengguang Wu <fengguang.wu@intel.com>
Signed-off-by: Jaeden Amero <jaeden.amero@ni.com>
The RS-485 TIOCSRS485 and TIOCGRS485 ioctls are 32-bit compatible, so
in order to call them on 64-bit systems from 32-bit user mode, we add
them to the ioctl pointer list as compatible ioctls.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Allow handling of Unicode compose sequences by 32-bit apps on a 64-bit
system. The issue has been reported in <http://bugs.debian.org/540534>
and <http://lists.altlinux.org/pipermail/kbd/2009-December/000235.html>.
A formal check of the two affected ioctls in drivers/char/vt_ioctl.c
(introduced in 04c71976) and a test using x86 kbd 1.15.1 on a so patched
x86_64 kernel both confirm that KD[GS]KBDIACRUC are ioctl32()
compatible.
Signed-off-by: Michael Schutte <michi@uiae.at>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker:
"Fix up files in fs/ and lib/ dirs to only use module.h if they really
need it.
These are trivial in scope vs the work done previously. We now have
things where any few remaining cleanups can be farmed out to arch or
subsystem maintainers, and I have done so when possible. What is
remaining here represents the bits that don't clearly lie within a
single arch/subsystem boundary, like the fs dir and the lib dir.
Some duplicate includes arising from overlapping fixes from
independent subsystem maintainer submissions are also quashed."
Fix up trivial conflicts due to clashes with other include file cleanups
(including some due to the previous bug.h cleanup pull).
* tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
lib: reduce the use of module.h wherever possible
fs: reduce the use of module.h wherever possible
includecheck: delete any duplicate instances of module.h
Since all that include/linux/if_ppp.h does is #include <linux/ppp-ioctl.h>,
this replaces the occurrences of #include <linux/if_ppp.h> with
#include <linux/ppp-ioctl.h>.
It also corrects an error in Documentation/networking/l2tp.txt, where
it referenced include/linux/if_ppp.h as the source of some definitions
that are actually now defined in include/linux/if_pppol2tp.h.
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map
them onto including export.h -- or if the file isn't even
using those, then just delete the include. Fix up any implicit
include dependencies that were being masked by module.h along
the way.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (655 commits)
[media] revert patch: HDIC HD29L2 DMB-TH USB2.0 reference design driver
mb86a20s: Add a few more register settings at the init seq
mb86a20s: Group registers into the same line
[media] [PATCH] don't reset the delivery system on DTV_CLEAR
[media] [BUG] it913x-fe fix typo error making SNR levels unstable
[media] cx23885: Query the CX25840 during enum_input for status
[media] cx25840: Add support for g_input_status
[media] rc-videomate-m1f.c Rename to match remote controler name
[media] drivers: media: au0828: Fix dependency for VIDEO_AU0828
[media] convert drivers/media/* to use module_platform_driver()
[media] drivers: video: cx231xx: Fix dependency for VIDEO_CX231XX_DVB
[media] Exynos4 JPEG codec v4l2 driver
[media] doc: v4l: selection: choose pixels as units for selection rectangles
[media] v4l: s5p-tv: mixer: fix setup of VP scaling
[media] v4l: s5p-tv: mixer: add support for selection API
[media] v4l: emulate old crop API using extended crop/compose API
[media] doc: v4l: add documentation for selection API
[media] doc: v4l: add binary images for selection API
[media] v4l: add support for selection api
[media] hd29l2: fix review findings
We're doing some odd things there, which already messes up various users
(see the net/socket.c code that this removes), and it was going to add
yet more crud to the block layer because of the incorrect error code
translation.
ENOIOCTLCMD is not an error return that should be returned to user mode
from the "ioctl()" system call, but it should *not* be translated as
EINVAL ("Invalid argument"). It should be translated as ENOTTY
("Inappropriate ioctl for device").
That EINVAL confusion has apparently so permeated some code that the
block layer actually checks for it, which is sad. We continue to do so
for now, but add a big comment about how wrong that is, and we should
remove it entirely eventually. In the meantime, this tries to keep the
changes localized to just the EINVAL -> ENOTTY fix, and removing code
that makes it harder to do the right thing.
Only the ioctl core should see the DVBv3 compat stuff, as its
contents are not available anymore to the drivers.
As fs/compat_ioctl also handles DVBv3 ioctl's, it needs those
definitions:
fs/compat_ioctl.c:1345: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’
fs/compat_ioctl.c:1345: error: array type has incomplete element type
fs/compat_ioctl.c:1345: error: initializer element is not constant
fs/compat_ioctl.c:1345: error: (near initialization for ‘ioctl_pointer[462]’)
fs/compat_ioctl.c:1346: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_parameters’
fs/compat_ioctl.c:1346: error: array type has incomplete element type
fs/compat_ioctl.c:1346: error: initializer element is not constant
fs/compat_ioctl.c:1346: error: (near initialization for ‘ioctl_pointer[463]’)
fs/compat_ioctl.c:1347: error: invalid application of ‘sizeof’ to incomplete type ‘struct dvb_frontend_event’
fs/compat_ioctl.c:1347: error: array type has incomplete element type
fs/compat_ioctl.c:1347: error: initializer element is not constant
fs/compat_ioctl.c:1347: error: (near initialization for ‘ioctl_pointer[464]’)
Reported-by: Michael Krufky <mkrufky@linuxtv.org>
fixes following error seen on x86_64 kernel:
ioctl32(openl2tpd:7480): Unknown cmd fd(14) cmd(80487436){t:'t';sz:72} arg(ffa7e6c0) on socket:[105094]
The argument (struct pppol2tp_ioc_stats) uses "aligned_u64" and thus doesn't need
fixups.
Cc: James Chapman <jchapman@katalix.com>
On Linux x86_64 host with 32bit userspace, running
qemu or even just "qemu-img create -f qcow2 some.img 1G"
causes a kernel warning:
ioctl32(qemu-img:5296): Unknown cmd fd(3) cmd(00005326){t:'S';sz:0} arg(7fffffff) on some.img
ioctl32(qemu-img:5296): Unknown cmd fd(3) cmd(801c0204){t:02;sz:28} arg(fff77350) on some.img
ioctl 00005326 is CDROM_DRIVE_STATUS,
ioctl 801c0204 is FDGETPRM.
The warning appears because the Linux compat-ioctl handler for these
ioctls only applies to block devices, while qemu also uses the ioctls on
plain files.
Signed-off-by: Johannes Stezenbach <js@sig21.net>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (36 commits)
serial: apbuart: Fixup apbuart_console_init()
TTY: Add tty ioctl to figure device node of the system console.
tty: add 'active' sysfs attribute to tty0 and console device
drivers: serial: apbuart: Handle OF failures gracefully
Serial: Avoid unbalanced IRQ wake disable during resume
tty: fix typos/errors in tty_driver.h comments
pch_uart : fix warnings for 64bit compile
8250: fix uninitialized FIFOs
ip2: fix compiler warning on ip2main_pci_tbl
specialix: fix compiler warning on specialix_pci_tbl
rocket: fix compiler warning on rocket_pci_ids
8250: add a UPIO_DWAPB32 for 32 bit accesses
8250: use container_of() instead of casting
serial: omap-serial: Add support for kernel debugger
serial: fix pch_uart kconfig & build
drivers: char: hvc: add arm JTAG DCC console support
RS485 documentation: add 16C950 UART description
serial: ifx6x60: fix memory leak
serial: ifx6x60: free IRQ on error
Serial: EG20T: add PCH_UART driver
Fixed up conflicts in drivers/serial/apbuart.c with evil merge that
makes the code look fairly sane (unlike either side).
There's no sense on keeping it on 2.6.38, as nobody is using it
anymore, at the kernel tree, and installing it at the userspace
API.
As two deprecated drivers still need it, move it to their internal
directories.
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl>
This has been in the SuSE kernels for a very long time.
Signed-off-by: Werner Fink <werner@suse.de>
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
This merges the staging-next tree to Linus's tree and resolves
some conflicts that were present due to changes in other trees that were
affected by files here.
RAW_SETBIND and RAW_GETBIND 32bit versions are fscked in interesting ways.
1) fs/compat_ioctl.c has COMPATIBLE_IOCTL(RAW_SETBIND) followed by
HANDLE_IOCTL(RAW_SETBIND, raw_ioctl). The latter is ignored.
2) on amd64 (and itanic) the damn thing is broken - we have int + u64 + u64
and layouts on i386 and amd64 are _not_ the same. raw_ioctl() would
work there, but it's never called due to (1). As it is, i386 /sbin/raw
definitely doesn't work on amd64 boxen.
3) switching to raw_ioctl() as is would *not* work on e.g. sparc64 and ppc64,
which would be rather sad, seeing that normal userland there is 32bit.
The thing is, slapping __packed on the struct in question does not DTRT -
it eliminates *all* padding. The real solution is to use compat_u64.
4) of course, all that stuff has no business being outside of raw.c in the
first place - there should be ->compat_ioctl() for /dev/rawctl instead of
messing with compat_ioctl.c.
[arnd@arndb.de: port to 2.6.36]
smbfs has been scheduled for removal in 2.6.27, so
maybe we can now move it to drivers/staging on the
way out.
smbfs still uses the big kernel lock and nobody
is going to fix that, so we should be getting
rid of it soon.
This removes the 32 bit compat mount and ioctl
handling code, which is implemented in common fs
code, and moves all smbfs related files into
drivers/staging/smbfs.
Acked-by: Jeff Layton <jlayton@redhat.com>
The last user is gone, so we can safely remove this
Cc: John Kacur <jkacur@redhat.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (68 commits)
U6715 16550A serial driver support
Char: nozomi, set tty->driver_data appropriately
Char: nozomi, fix tty->count counting
serial: max3107: Fix gpiolib support
hsu: call PCI pm hooks in suspend/resume function
hsu: some code cleanup
hsu: add a periodic timer to check dma rx channel
hsu: driver for Medfield High Speed UART device
mxser: remove unnesesary NULL check
serial: add support for OX16PCI958 card
serial: 68328serial.c: remove dead (ALMA_ANS | DRAGONIXVZ | M68EZ328ADS)
timbuart: use __devinit and __devexit macros for probe and remove
serial: MMIO32 support for 8250_early.c
serial: mcf: don't take spinlocks in already protected functions
serial: general fixes in the serial_rs485 structure
serial: fix missing bit coverage of ASYNC_FLAGS
serial: "altera_uart: simplify altera_uart_console_putc()" checkpatch fixes
serial: crisv10: formatting of pointers in printk()
vt: Fix warning: statement with no effect due to vt_kern.h
tty_io: remove casts from void*
