path: root/fs/configfs
2007-10-16implement simple fs aopsNick Piggin
Implement new aops for some of the simpler filesystems. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10configfs: config item dependancies.Joel Becker
Sometimes other drivers depend on particular configfs items. For example, ocfs2 mounts depend on a heartbeat region item. If that region item is removed with rmdir(2), the ocfs2 mount must BUG or go readonly. Not happy. This provides two additional API calls: configfs_depend_item() and configfs_undepend_item(). A client driver can call configfs_depend_item() on an existing item to tell configfs that it is depended on. configfs will then return -EBUSY from rmdir(2) for that item. When the item is no longer depended on, the client driver calls configfs_undepend_item() on it. These API cannot be called underneath any configfs callbacks, as they will conflict. They can block and allocate. A client driver probably shouldn't calling them of its own gumption. Rather it should be providing an API that external subsystems call. How does this work? Imagine the ocfs2 mount process. When it mounts, it asks for a heart region item. This is done via a call into the heartbeat code. Inside the heartbeat code, the region item is looked up. Here, the heartbeat code calls configfs_depend_item(). If it succeeds, then heartbeat knows the region is safe to give to ocfs2. If it fails, it was being torn down anyway, and heartbeat can gracefully pass up an error. [ Fixed some bad whitespace in configfs.txt. --Mark ] Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-10configfs: accessing item hierarchy during rmdir(2)Joel Becker
Add a notification callback, ops->disconnect_notify(). It has the same prototype as ->drop_item(), but it will be called just before the item linkage is broken. This way, configfs users who want to do work while the object is still in the heirarchy have a chance. Client drivers will still need to config_item_put() in their ->drop_item(), if they implement it. They need do nothing in ->disconnect_notify(). They don't have to provide it if they don't care. But someone who wants to be notified before ci_parent is set to NULL can now be notified. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-10[PATCH] configsfs buffer: use mutexJohannes Berg
Seems copied from sysfs, but I don't see a reason here nor there to use a semaphore instead of a mutex. Convert. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-10configfs: Convert subsystem semaphore to mutexJoel Becker
Convert the su_sem member of struct configfs_subsystem to a struct mutex, as that's what it is. Also convert all the users and update Documentation/configfs.txt and Documentation/configfs_example.c accordingly. [ Conflict in fs/dlm/config.c with commit 3168b0780d06ace875696f8a648d04d6089654e5 manually resolved. --Mark ] Inspired-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-10[PATCH] configfs+dlm: Rename config_group_find_obj and state semantics clearlySatyam Sharma
Configfs being based upon sysfs code, config_group_find_obj() is probably so named because of the similar kset_find_obj() in sysfs. However, "kobject"s in sysfs become "config_item"s in configfs, so let's call it config_group_find_item() instead, for sake of uniformity, and make corresponding change in the users of this function. BTW a crucial difference between kset_find_obj and config_group_find_item is in locking expectations. kset_find_obj does its locking by itself, but config_group_find_item expects the *caller* to do the locking. The reason for this: kset's have their own locks, config_group's don't but instead rely on the subsystem mutex. And, subsystem needn't necessarily be around when config_group_find_item() is called. So let's state these locking semantics explicitly, and rectify the comment, otherwise bugs could continue to occur in future, as they did in the past (refer commit d82b8191e238 in gfs2-2.6-fixes.git). [ I also took the opportunity to fix some bad whitespace and double-empty lines. --Joel ] [ Conflict in fs/dlm/config.c with commit 3168b0780d06ace875696f8a648d04d6089654e5 manually resolved. --Mark ] Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: David Teigland <teigland@redhat.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-10configfs: misc cleanupsSatyam Sharma
1. item.c:config_item_cleanup() is a private function (only called by config_item_release() in same file). However, it is spuriously exported in include/linux/configfs.h, so remove that export and make it static in item.c. Also, it is no longer exported / interface function, so no need to give comment for this function (the comment was stating obvious thing, anyway). 2. Kernel-doc comment format does not allow empty line between end of comment and start of function (declaration line). There were several such spurious empty lines in item.c, so fix them. fs/configfs/item.c | 15 +++------------ include/linux/configfs.h | 1 - 2 files changed, 3 insertions(+), 13 deletions(-) Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-10configfs: consistent attribute sizeJoel Becker
The attribute store/show code currently limits attributes at PAGE_SIZE. This code comes from sysfs, where it still works that way. However, PAGE_SIZE is not constant. A 16k attribute string works on ia64 but not on x86. Really a subsystem shouldn't allow different attribute sizes based on platform. As such, limit all simple attributes to 4k. This works on all platforms, and is consistent with all current code. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09use simple_read_from_buffer() in fs/Akinobu Mita
Cleanup using simple_read_from_buffer() in binfmt_misc, configfs, and sysfs. Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Joel Becker <joel.becker@oracle.com> Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02remove "struct subsystem" as it is no longer neededGreg Kroah-Hartman
We need to work on cleaning up the relationship between kobjects, ksets and ktypes. The removal of 'struct subsystem' is the first step of this, especially as it is not really needed at all. Thanks to Kay for fixing the bugs in this patch. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-14configfs: add missing mutex_unlock()Joel Becker
d_alloc() failure in configfs_register_subsystem() would fail to unlock the mutex taken above. Reorganize the exit path to ensure the unlock happens. Reported-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-02-11[PATCH] Transform kmem_cache_alloc()+memset(0) -> kmem_cache_zalloc().Robert P. J. Day
Replace appropriate pairs of "kmem_cache_alloc()" + "memset(0)" with the corresponding "kmem_cache_zalloc()" call. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Andi Kleen <ak@muc.de> Cc: Roland McGrath <roland@redhat.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Acked-by: Joel Becker <Joel.Becker@oracle.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Jan Kara <jack@ucw.cz> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: James Morris <jmorris@namei.org> Cc: Chris Wright <chrisw@sous-sol.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-07configfs: Zero terminate data in configfs attribute writes.Joel Becker
Attributes in configfs are text files. As such, most handlers expect to be able to call functions like simple_strtoul() without checking the bounds of the buffer. Change the call to zero terminate the buffer before calling the client's ->store() method. This does reduce the attribute size from PAGE_SIZE to PAGE_SIZE-1. Also, change get_zeroed_page() to alloc_page(), as we are handling the termination. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-08[PATCH] configfs: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the configfs filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-01configfs: make configfs_dirent_exists() staticAdrian Bunk
This patch makes the needlessly global configfs_dirent_exists() static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01configfs: mutex_lock_nested() fixMark Fasheh
configfs_unregister_subsystem() nests a pair of inode i_mutex acquisitions, and thus needs annotation via mutex_lock_nested(). Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-10-20configfs: handle kzalloc() failure in check_perm()Chandra Seetharaman
check_perm() does not drop the reference to the module when kzalloc() failure occurs. Signed-Off-By: Chandra Seetharaman <sekharan@us.ibm.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-10-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6: (292 commits) [GFS2] Fix endian bug for de_type [GFS2] Initialize SELinux extended attributes at inode creation time. [GFS2] Move logging code into log.c (mostly) [GFS2] Mark nlink cleared so VFS sees it happen [GFS2] Two redundant casts removed [GFS2] Remove uneeded endian conversion [GFS2] Remove duplicate sb reading code [GFS2] Mark metadata reads for blktrace [GFS2] Remove iflags.h, use FS_ [GFS2] Fix code style/indent in ops_file.c [GFS2] streamline-generic_file_-interfaces-and-filemap gfs fix [GFS2] Remove readv/writev methods and use aio_read/aio_write instead (gfs bits) [GFS2] inode-diet: Eliminate i_blksize from the inode structure [GFS2] inode_diet: Replace inode.u.generic_ip with inode.i_private (gfs) [GFS2] Fix typo in last patch [GFS2] Fix direct i/o logic in filemap.c [GFS2] Fix bug in Makefiles for lock modules [GFS2] Remove (extra) fs_subsys declaration [GFS2/DLM] Fix trailing whitespace [GFS2] Tidy up meta_io code ...
2006-10-03[PATCH] pr_debug: configfs: use size_t length modifier in pr_debug format ↵Zach Brown
argument configfs: use size_t length modifier in pr_debug format argument Signed-off-by: Zach Brown <zach.brown@oracle.com> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02Merge branch 'master' into gfs2Steven Whitehouse
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-28Merge branch 'master' into gfs2Steven Whitehouse
2006-09-27[PATCH] fs: Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to kzalloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25[GFS2] Fix up merge of Linus' kernel into GFS2Steven Whitehouse
This fixes up a couple of conflicts when merging up with Linus' latest kernel. This will hopefully allow GFS2 to be more easily merged into forthcoming -mm and FC kernels due to the "one line per header" format now used for the kernel headers. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Conflicts: include/linux/Kbuild include/linux/kernel.h
2006-09-20configfs: Prevent duplicate subsystem names.Joel Becker
For all child objects, creation comes through mkdir(2), so duplicate names are prevented. Subsystems, though, are registered by client drivers at init_module()/__init time. This patch prevents duplicate subsystem names. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-07-03Merge rsync://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6Steven Whitehouse
Conflicts: include/linux/kernel.h
2006-06-29configfs: Clear up a few extra spaces where there should be TABs.Joel Becker
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] fs: use list_move()Akinobu Mita
This patch converts the combination of list_del(A) and list_add(A, B) to list_move(A, B) under fs/. Cc: Ian Kent <raven@themaw.net> Acked-by: Joel Becker <joel.becker@oracle.com> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Hans Reiser <reiserfs-dev@namesys.com> Cc: Urban Widmark <urban@teststation.com> Acked-by: David Howells <dhowells@redhat.com> Acked-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-24Merge branch 'master' of /home/trondmy/kernel/linux-2.6/Trond Myklebust
Conflicts: fs/nfs/inode.c fs/super.c Fix conflicts between patch 'NFS: Split fs/nfs/inode.c' and patch 'VFS: Permit filesystem to override root dentry on mount'
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-09VFS: Unexport do_kern_mount() and clean up simple_pin_fs()Trond Myklebust
Replace all module uses with the new vfs_kern_mount() interface, and fix up simple_pin_fs(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-05-25Merge branch 'master'Steven Whitehouse
2006-05-17configfs: configfs_mkdir() failed to cleanup linkage.Joel Becker
If configfs_mkdir() errored in certain ways after the parent<->child linkage was already created, it would not undo the linkage. Also, comment the reference counting for clarity. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-05-17configfs: Fix a reference leak in configfs_mkdir().Joel Becker
configfs_mkdir() failed to release the working parent reference in most exit paths. Also changed the exit path for readability. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-04-21Merge branch 'master'Steven Whitehouse
2006-04-10[PATCH] Bogus NULL pointer check in fs/configfs/dir.cEric Sesterhenn
We check the "group" pointer after we dereference it. This check is bogus, as it cannot be NULL coming in. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-03-31Merge branch 'master'Steven Whitehouse
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-23Merge branch 'master'Steven Whitehouse
2006-02-03[PATCH] BUG_ON() Conversion in fs/configfs/Eric Sesterhenn / snakebyte
this changes if() BUG(); constructs to BUG_ON() which is cleaner, contains unlikely() and can better optimized away. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-02-03configfs: Add permission and ownership to configfs objects.Joel Becker
configfs always made item and attribute ownership root.root and permissions based on a umask of 022. Add ->setattr() to allow chown(2)/chmod(2), and persist the changes for the lifetime of the items and attributes. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-01-18[DLM] Export config_group_find_obj for use by the DLMDavid Teigland
Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
