commit 351e5d869e5ac10cb40c78b5f2d7dfc816ad4587 upstream.
Configfs abuses symlink(2). Unlike the normal filesystems, it
wants the target resolved at symlink(2) time, like link(2) would've
done. The problem is that ->symlink() is called with the parent
directory locked exclusive, so resolving the target inside the
->symlink() is easily deadlocked.
Short of really ugly games in sys_symlink() itself, all we can
do is to unlock the parent before resolving the target and
relock it after. However, that invalidates the checks done
by the caller of ->symlink(), so we have to
* check that dentry is still where it used to be
(it couldn't have been moved, but it could've been unhashed)
* recheck that it's still negative (somebody else
might've successfully created a symlink with the same name
while we were looking the target up)
* recheck the permissions on the parent directory.
Cc: stable@vger.kernel.org
commit b0841eefd9693827afb9888235e26ddd098f9cef upstream.
Make sure that attribute methods are not called after the item
has been removed from the tree. To do so, we
* at the point of no return in removals, grab ->frag_sem
exclusive and mark the fragment dead.
* call the methods of attributes with ->frag_sem taken
shared and only after having verified that the fragment is still
alive.
The main benefit is for method instances - they are
guaranteed that the objects they are accessing *and* all ancestors
are still there. Another win is that we don't need to bother
with extra refcount on config_item when opening a file -
the item will be alive for as long as it stays in the tree, and
we won't touch it/attributes/any associated data after it's
commit 47320fbe11a6059ae502c9c16b668022fdb4cf76 upstream.
Refcounted, hangs of configfs_dirent, created by operations that add
fragments to configfs tree (mkdir and configfs_register_{subsystem,group}).
Will be used in the next commit to provide exclusion between fragment
removal and ->show/->store calls.
commit f19e4ed1e1edbfa3c9ccb9fed17759b7d6db24c6 upstream.
revert cc57c07343bd "configfs: fix registered group removal"
It was an attempt to handle something that fundamentally doesn't
work - configfs_register_group() should never be done in a part
of tree that can be rmdir'ed. And in mainline it never had been,
so let's not borrow trouble; the fix was racy anyway, it would take
a lot more to make that work and desired semantics is not clear.
commit ff4dd081977da56566a848f071aed8fa92d604a1 upstream.
simplifies the ->read()/->write()/->release() instances nicely
commit 3f6928c347707a65cee10a9f54b85ad5fb078b3f upstream.
Bool initializations should use true and false. Bool tests don't need
comparisons.
Signed-off-by: Thomas Meyer <thomas@m3y3r.de>
[ Upstream commit f6122ed2a4f9c9c1c073ddf6308d1b2ac10e0781 ]
In the vfs_statx() context, during path lookup, the dentry gets
added to sd->s_dentry via configfs_attach_attr(). In the end,
vfs_statx() kills the dentry by calling path_put(), which invokes
configfs_d_iput(). Ideally, this dentry must be removed from
sd->s_dentry but it doesn't if the sd->s_count >= 3. As a result,
sd->s_dentry is holding reference to a stale dentry pointer whose
memory is already freed up. This results in use-after-free issue,
when this stale sd->s_dentry is accessed later in
configfs_readdir() path.
This issue can be easily reproduced, by running the LTP test case -
sh fs_racer_file_list.sh /config
(https://github.com/linux-test-project/ltp/blob/master/testcases/kernel/fs/racer/fs_racer_file_list.sh)
Fixes: 76ae281f6307 ('configfs: fix race between dentry put and lookup')
Signed-off-by: Sahitya Tummala <stummala@codeaurora.org>
[ Upstream commit 35399f87e271f7cf3048eab00a421a6519ac8441 ]
In configfs_register_group(), if create_default_group() failed, we
forget to unlink the group. It will left a invalid item in the parent list,
which may trigger the use-after-free issue seen below:
BUG: KASAN: use-after-free in __list_add_valid+0xd4/0xe0 lib/list_debug.c:26
Read of size 8 at addr ffff8881ef61ae20 by task syz-executor.0/5996
CPU: 1 PID: 5996 Comm: syz-executor.0 Tainted: G C 5.0.0+ #5
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1 04/01/2014
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0xa9/0x10e lib/dump_stack.c:113
print_address_description+0x65/0x270 mm/kasan/report.c:187
kasan_report+0x149/0x18d mm/kasan/report.c:317
__list_add include/linux/list.h:60 [inline]
list_add_tail include/linux/list.h:93 [inline]
link_obj+0xb0/0x190 fs/configfs/dir.c:759
link_group+0x1c/0x130 fs/configfs/dir.c:784
configfs_register_group+0x56/0x1e0 fs/configfs/dir.c:1751
configfs_register_default_group+0x72/0xc0 fs/configfs/dir.c:1834
? 0xffffffffc1be0000
iio_sw_trigger_init+0x23/0x1000 [industrialio_sw_trigger]
do_one_initcall+0xbc/0x47d init/main.c:887
do_init_module+0x1b5/0x547 kernel/module.c:3456
load_module+0x6405/0x8c10 kernel/module.c:3804
__do_sys_finit_module+0x162/0x190 kernel/module.c:3898
do_syscall_64+0x9f/0x450 arch/x86/entry/common.c:290
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x462e99
Code: f7 d8 64 89 02 b8 ff ff ff ff c3 66 0f 1f 44 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 c7 c1 bc ff ff ff f7 d8 64 89 01 48
RSP: 002b:00007f494ecbcc58 EFLAGS: 00000246 ORIG_RAX: 0000000000000139
RAX: ffffffffffffffda RBX: 000000000073bf00 RCX: 0000000000462e99
RDX: 0000000000000000 RSI: 0000000020000180 RDI: 0000000000000003
RBP: 00007f494ecbcc70 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000246 R12: 00007f494ecbd6bc
R13: 00000000004bcefa R14: 00000000006f6fb0 R15: 0000000000000004
Allocated by task 5987:
set_track mm/kasan/common.c:87 [inline]
__kasan_kmalloc.constprop.3+0xa0/0xd0 mm/kasan/common.c:497
kmalloc include/linux/slab.h:545 [inline]
kzalloc include/linux/slab.h:740 [inline]
configfs_register_default_group+0x4c/0xc0 fs/configfs/dir.c:1829
0xffffffffc1bd0023
Freed by task 5987:
__kasan_slab_free+0x130/0x180 mm/kasan/common.c:459
slab_free_hook mm/slub.c:1429 [inline]
slab_free_freelist_hook mm/slub.c:1456 [inline]
slab_free mm/slub.c:3003 [inline]
kfree+0xe1/0x270 mm/slub.c:3955
configfs_register_default_group+0x9a/0xc0 fs/configfs/dir.c:1836
0xffffffffc1bd0023
The buggy address belongs to the object at ffff8881ef61ae00
which belongs to the cache kmalloc-192 of size 192
The buggy address is located 32 bytes inside of
192-byte region [ffff8881ef61ae00, ffff8881ef61aec0)
The buggy address belongs to the page:
page:ffffea0007bd8680 count:1 mapcount:0 mapping:ffff8881f6c03000 index:0xffff8881ef61a700
flags: 0x2fffc0000000200(slab)
raw: 02fffc0000000200 ffffea0007ca4740 0000000500000005 ffff8881f6c03000
raw: ffff8881ef61a700 000000008010000c 00000001ffffffff 0000000000000000
page dumped because: kasan: bad access detected
Memory state around the buggy address:
ffff8881ef61ad00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ffff8881ef61ad80: 00 00 00 00 00 00 00 00 fc fc fc fc fc fc fc fc
>ffff8881ef61ae00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
ffff8881ef61ae80: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc
ffff8881ef61af00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb
Fixes: 5cf6a51e6062 ("configfs: allow dynamic group creation")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
commit 1823342a1f2b47a4e6f5667f67cd28ab6bc4d6cd upstream.
gcc 8.1.0 complains:
fs/configfs/symlink.c:67:3: warning:
'strncpy' output truncated before terminating nul copying as many
bytes from a string as its length
fs/configfs/symlink.c: In function 'configfs_get_link':
fs/configfs/symlink.c:63:13: note: length computed here
Using strncpy() is indeed less than perfect since the length of data to
be copied has already been determined with strlen(). Replace strncpy()
with memcpy() to address the warning and optimize the code a little.
Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu@cybertrust.co.jp>
[ Upstream commit cc57c07343bd071cdf1915a91a24ab7d40c9b590 ]
This patch fixes a bug where configfs_register_group had added
a group in a tree, and userspace has done a rmdir on a dir somewhere
above that group and we hit a kernel crash. The problem is configfs_rmdir
will detach everything under it and unlink groups on the default_groups
list. It will not unlink groups added with configfs_register_group so when
configfs_unregister_group is called to drop its references to the group/items
we crash when we try to access the freed dentrys.
The patch just adds a check for if a rmdir has been done above
us and if so just does the unlink part of unregistration.
Sorry if you are getting this multiple times. I thouhgt I sent
this to some of you and lkml, but I do not see it.
Signed-off-by: Mike Christie <mchristi@redhat.com>
commit ba80aa909c99802c428682c352b0ee0baac0acd3 upstream.
This patch closes a long standing race in configfs between
the creation of a new symlink in create_link(), while the
symlink target's config_item is being concurrently removed
via configfs_rmdir().
This can happen because the symlink target's reference
is obtained by config_item_get() in create_link() before
the CONFIGFS_USET_DROPPING bit set by configfs_detach_prep()
during configfs_rmdir() shutdown is actually checked..
This originally manifested itself on ppc64 on v4.8.y under
heavy load using ibmvscsi target ports with Novalink API:
[ 7877.289863] rpadlpar_io: slot U8247.22L.212A91A-V1-C8 added
[ 7879.893760] ------------[ cut here ]------------
[ 7879.893768] WARNING: CPU: 15 PID: 17585 at ./include/linux/kref.h:46 config_item_get+0x7c/0x90 [configfs]
[ 7879.893811] CPU: 15 PID: 17585 Comm: targetcli Tainted: G O 4.8.17-customv2.22 #12
[ 7879.893812] task: c00000018a0d3400 task.stack: c0000001f3b40000
[ 7879.893813] NIP: d000000002c664ec LR: d000000002c60980 CTR: c000000000b70870
[ 7879.893814] REGS: c0000001f3b43810 TRAP: 0700 Tainted: G O (4.8.17-customv2.22)
[ 7879.893815] MSR: 8000000000029033 <SF,EE,ME,IR,DR,RI,LE> CR: 28222242 XER: 00000000
[ 7879.893820] CFAR: d000000002c664bc SOFTE: 1
GPR00: d000000002c60980 c0000001f3b43a90 d000000002c70908 c0000000fbc06820
GPR04: c0000001ef1bd900 0000000000000004 0000000000000001 0000000000000000
GPR08: 0000000000000000 0000000000000001 d000000002c69560 d000000002c66d80
GPR12: c000000000b70870 c00000000e798700 c0000001f3b43ca0 c0000001d4949d40
GPR16: c00000014637e1c0 0000000000000000 0000000000000000 c0000000f2392940
GPR20: c0000001f3b43b98 0000000000000041 0000000000600000 0000000000000000
GPR24: fffffffffffff000 0000000000000000 d000000002c60be0 c0000001f1dac490
GPR28: 0000000000000004 0000000000000000 c0000001ef1bd900 c0000000f2392940
[ 7879.893839] NIP [d000000002c664ec] config_item_get+0x7c/0x90 [configfs]
[ 7879.893841] LR [d000000002c60980] check_perm+0x80/0x2e0 [configfs]
[ 7879.893842] Call Trace:
[ 7879.893844] [c0000001f3b43ac0] [d000000002c60980] check_perm+0x80/0x2e0 [configfs]
[ 7879.893847] [c0000001f3b43b10] [c000000000329770] do_dentry_open+0x2c0/0x460
[ 7879.893849] [c0000001f3b43b70] [c000000000344480] path_openat+0x210/0x1490
[ 7879.893851] [c0000001f3b43c80] [c00000000034708c] do_filp_open+0xfc/0x170
[ 7879.893853] [c0000001f3b43db0] [c00000000032b5bc] do_sys_open+0x1cc/0x390
[ 7879.893856] [c0000001f3b43e30] [c000000000009584] system_call+0x38/0xec
[ 7879.893856] Instruction dump:
[ 7879.893858] 409d0014 38210030 e8010010 7c0803a6 4e800020 3d220000 e94981e0 892a0000
[ 7879.893861] 2f890000 409effe0 39200001 992a0000 <0fe00000> 4bffffd0 60000000 60000000
[ 7879.893866] ---[ end trace 14078f0b3b5ad0aa ]---
To close this race, go ahead and obtain the symlink's target
config_item reference only after the existing CONFIGFS_USET_DROPPING
check succeeds.
This way, if configfs_rmdir() wins create_link() will return -ENONET,
and if create_link() wins configfs_rmdir() will return -EBUSY.
Reported-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com>
Tested-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com>
current_fs_time() uses struct super_block* as an argument.
As per Linus's suggestion, this is changed to take struct
inode* as a parameter instead. This is because the function
is primarily meant for vfs inode timestamps.
Also the function was renamed as per Arnd's suggestion.
Change all calls to current_fs_time() to use the new
current_time() function instead. current_fs_time() will be
deleted.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
The check for writing more than cb_max_size bytes does not 'goto out' so
it is a no-op which allows users to vmalloc an arbitrary amount.
Fixes: 03607ace807b ("configfs: implement binary attributes")
Cc: stable@kernel.org
Signed-off-by: Phil Turnbull <phil.turnbull@oracle.com>
A confgifs attribute's show() callback is called once the first time
the user attempts to read from it. If it returns an error, that
error is returned to the user. However, the open file's
buffer_needs_fill is still set to zero and consecutive read() calls
will find an empty buffer that doesn't need filling and return 0 to
the user. This could give the user the wrong impression that the
attribute was read successfully.
Fix this by not setting buffer_needs_fill if show() returns an error,
making consecutive read() calls call show() again and either get an
error again or get data.
Signed-off-by: Tal Shorer <tal.shorer@gmail.com>
The simple_write_to_buffer() already increments the @ppos on success,
see fs/libfs.c simple_write_to_buffer() comment:
On success, the number of bytes written is returned and the offset @ppos
advanced by this number, or negative value is returned on error.
If the configfs_write_bin_file() is invoked with @count smaller than the
total length of the written binary file, it will be invoked multiple times.
Since configfs_write_bin_file() increments @ppos on success, after calling
simple_write_to_buffer(), the @ppos is incremented twice.
Subsequent invocation of configfs_write_bin_file() will result in the next
piece of data being written to the offset twice as long as the length of
the previous write, thus creating buffer with "holes" in it.
The simple testcase using DTO follows:
$ mkdir /sys/kernel/config/device-tree/overlays/1
$ dd bs=1 if=foo.dtbo of=/sys/kernel/config/device-tree/overlays/1/dtbo
Without this patch, the testcase will result in twice as big buffer in the
kernel, which is then passed to the cfs_overlay_item_dtbo_write() .
Cc: Geert Uytterhoeven <geert+renesas@glider.be>
Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
ta-da!
The main issue is the lack of down_write_killable(), so the places
like readdir.c switched to plain inode_lock(); once killable
variants of rwsem primitives appear, that'll be dealt with.
lockdep side also might need more work
grab a reference to dentry we'd got the sucker from, and return
that dentry via *wait, rather than just returning the address of
->i_mutex.
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time
ago with promise that one day it will be possible to implement page
cache with bigger chunks than PAGE_SIZE.
This promise never materialized. And unlikely will.
We have many places where PAGE_CACHE_SIZE assumed to be equal to
PAGE_SIZE. And it's constant source of confusion on whether
PAGE_CACHE_* or PAGE_* constant should be used in a particular case,
especially on the border between fs and mm.
Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much
breakage to be doable.
Let's stop pretending that pages in page cache are special. They are
not.
The changes are pretty straight-forward:
- <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>;
- PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN};
- page_cache_get() -> get_page();
- page_cache_release() -> put_page();
This patch contains automated changes generated with coccinelle using
script below. For some reason, coccinelle doesn't patch header files.
I've called spatch for them manually.
The only adjustment after coccinelle is revert of changes to
PAGE_CAHCE_ALIGN definition: we are going to drop it later.
There are few places in the code where coccinelle didn't reach. I'll
fix them manually in a separate patch. Comments and documentation also
will be addressed with the separate patch.
virtual patch
expression E;
- E << (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
expression E;
- E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT)
+ E
- PAGE_CACHE_SHIFT
+ PAGE_SHIFT
- PAGE_CACHE_SIZE
+ PAGE_SIZE
- PAGE_CACHE_MASK
+ PAGE_MASK
expression E;
- PAGE_CACHE_ALIGN(E)
+ PAGE_ALIGN(E)
expression E;
- page_cache_get(E)
+ get_page(E)
expression E;
- page_cache_release(E)
+ put_page(E)
Pull vfs updates from Al Viro:
- Preparations of parallel lookups (the remaining main obstacle is the
need to move security_d_instantiate(); once that becomes safe, the
rest will be a matter of rather short series local to fs/*.c
- preadv2/pwritev2 series from Christoph
- assorted fixes
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (32 commits)
splice: handle zero nr_pages in splice_to_pipe()
vfs: show_vfsstat: do not ignore errors from show_devname method
dcache.c: new helper: __d_add()
don't bother with __d_instantiate(dentry, NULL)
untangle fsnotify_d_instantiate() a bit
uninline d_add()
replace d_add_unique() with saner primitive
quota: use lookup_one_len_unlocked()
cifs_get_root(): use lookup_one_len_unlocked()
nfs_lookup: don't bother with d_instantiate(dentry, NULL)
kill dentry_unhash()
ceph_fill_trace(): don't bother with d_instantiate(dn, NULL)
autofs4: don't bother with d_instantiate(dentry, NULL) in ->lookup()
configfs: move d_rehash() into configfs_create() for regular files
ceph: don't bother with d_rehash() in splice_dentry()
namei: teach lookup_slow() to skip revalidate
namei: massage lookup_slow() to be usable by lookup_one_len_unlocked()
lookup_one_len_unlocked(): use lookup_dcache()
namei: simplify invalidation logics in lookup_dcache()
namei: change calling conventions for lookup_{fast,slow} and follow_managed()
... and turn it into d_add in there
Replace the current NULL-terminated array of default groups with a linked
list. This gets rid of lots of nasty code to size and/or dynamically
allocate the array.
While we're at it also provide a conveniant helper to remove the default
groups.
Acked-by: Felipe Balbi <balbi@kernel.org> [drivers/usb/gadget]
Acked-by: Joel Becker <jlbec@evilplan.org>
Acked-by: Nicholas Bellinger <nab@linux-iscsi.org>
Reviewed-by: Sagi Grimberg <sagig@mellanox.com>
CURRENT_TIME macro is not appropriate for filesystems as it
doesn't use the right granularity for filesystem timestamps.
Use current_fs_time() instead.
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested},
inode_foo(inode) being mutex_foo(&inode->i_mutex).
Please, use those for access to ->i_mutex; over the coming cycle
->i_mutex will become rwsem, with ->lookup() done with it held
only shared.
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"The highlights this round include:
- Introduce configfs support for unlocked configfs_depend_item()
(krzysztof + andrezej)
- Conversion of usb-gadget target driver to new function registration
interface (andrzej + sebastian)
- Enable qla2xxx FC target mode support for Extended Logins (himansu +
giridhar)
- Enable qla2xxx FC target mode support for Exchange Offload (himansu +
giridhar)
- Add qla2xxx FC target mode irq affinity notification + selective
command queuing. (quinn + himanshu)
- Fix iscsi-target deadlock in se_node_acl configfs deletion (sagi +
nab)
- Convert se_node_acl configfs deletion + se_node_acl->queue_depth to
proper se_session->sess_kref + target_get_session() usage. (hch +
sagi + nab)
- Fix long-standing race between se_node_acl->acl_kref get and
get_initiator_node_acl() lookup. (hch + nab)
- Fix target/user block-size handling, and make sure netlink reaches
all network namespaces (sheng + andy)
Note there is an outstanding bug-fix series for remote I_T nexus port
TMR LUN_RESET has been posted and still being tested, and will likely
become post -rc1 material at this point"
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (56 commits)
scsi: qla2xxxx: avoid type mismatch in comparison
target/user: Make sure netlink would reach all network namespaces
target: Obtain se_node_acl->acl_kref during get_initiator_node_acl
target: Convert ACL change queue_depth se_session reference usage
iscsi-target: Fix potential dead-lock during node acl delete
ib_srpt: Convert acl lookup to modern get_initiator_node_acl usage
tcm_fc: Convert acl lookup to modern get_initiator_node_acl usage
tcm_fc: Wait for command completion before freeing a session
target: Fix a memory leak in target_dev_lba_map_store()
target: Support aborting tasks with a 64-bit tag
usb/gadget: Remove set-but-not-used variables
target: Remove an unused variable
target: Fix indentation in target_core_configfs.c
target/user: Allow user to set block size before enabling device
iser-target: Fix non negative ERR_PTR isert_device_get usage
target/fcoe: Add tag support to tcm_fc
qla2xxx: Check for online flag instead of active reset when transmitting responses
qla2xxx: Set all queues to 4k
qla2xxx: Disable ZIO at start time.
qla2xxx: Move atioq to a different lock to reduce lock contention
Pull configfs updates from Christoph Hellwig:
"I'm assisting Joel as co-maintainer and patch monkey now, and you will
see pull reuquests from me for a while.
Besides the MAINTAINERS update there is just a single change, which
adds support for binary attributes to configfs, which are very similar
to the sysfs binary attributes. Thanks to Pantelis Antoniou!
You will see another actually bigger set of configfs changes in the
SCSI target pull from Nic - those were merged before this new tree
even existed"
* tag 'configfs-for-linus' of git://git.infradead.org/users/hch/configfs:
configfs: add myself as co-maintainer, updated git tree
ConfigFS lacked binary attributes up until now. This patch
introduces support for binary attributes in a somewhat similar
manner of sysfs binary attributes albeit with changes that
fit the configfs usage model.
Problems that configfs binary attributes fix are everything that
requires a binary blob as part of the configuration of a resource,
such as bitstream loading for FPGAs, DTBs for dynamically created
devices etc.
Look at Documentation/filesystems/configfs/configfs.txt for internals
and howto use them.
This patch is against linux-next as of today that contains
Christoph's configfs rework.
Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
[hch: folded a fix from Geert Uytterhoeven <geert+renesas@glider.be>]
[hch: a few tiny updates based on review feedback]
all callers are better off with kfree_put_link()
This change is necessary for the SCSI target usb gadget composed with
configfs. In this case configfs will be used for two different purposes:
to compose a usb gadget and to configure the target part. If an instance
of tcm function is created in $CONFIGFS_ROOT/usb_gadget/<gadget>/functions
a tpg can be created in $CONFIGFS_ROOT/target/usb_gadget/<wwn>/, but after
a tpg is created the tcm function must not be removed until its
corresponding tpg is gone. While the configfs_depend/undepend_item() are
meant exactly for creating this kind of dependencies, they are not suitable
if the other kernel subsystem happens to be another subsystem in configfs,
so this patch adds unlocked versions meant for configfs callbacks.
Above description has been provided by:
Andrzej Pietrasiewicz <andrzej.p@samsung.com>
In configfs_depend_item() we have to consider two possible cases:
1) When we are called to depend another item in the same subsystem
as caller
In this case we should skip locking configfs root as we know
that configfs is in valid state and our subsystem will not
be unregistered during this call.
2) When we are called to depend item in different subsystem than
our caller
In this case we are also sure that configfs is in valid state
but we have to lock root of configfs to avoid unregistration
of target's subsystem. As it is other than caller's subsystem,
there may be nothing what protects us against unregistration
of that subsystem.
Signed-off-by: Krzysztof Opasiak <k.opasiak@samsung.com>
configfs_depend_item() is quite complicated and should
be split up into smaller functions. This also allow to
share this code with other functions.
subsys parameter is never used by configfs_undepend_item()
so there is no point in passing it to this function.
new method: ->get_link(); replacement of ->follow_link(). The differences
are:
* inode and dentry are passed separately
* might be called both in RCU and non-RCU mode;
the former is indicated by passing it a NULL dentry.
* when called that way it isn't allowed to block
and should return ERR_PTR(-ECHILD) if it needs to be called
in non-RCU mode.
It's a flagday change - the old method is gone, all in-tree instances
converted. Conversion isn't hard; said that, so far very few instances
do not immediately bail out when called in RCU mode. That'll change
in the next commits.
This patchset introduces IIO software triggers, offers a way of configuring
them via configfs and adds the IIO hrtimer based interrupt source to be used
with software triggers.
The architecture is now split in 3 parts, to remove all IIO trigger specific
parts from IIO configfs core:
(1) IIO configfs - creates the root of the IIO configfs subsys.
(2) IIO software triggers - software trigger implementation, dynamically
creating /config/iio/triggers group.
(3) IIO hrtimer trigger - is the first interrupt source for software triggers
(with syfs to follow). Each trigger type can implement its own set of
attributes.
Lockdep seems to be happy with the locking in configfs patch.
This patch (of 5):
We don't want to hardcode default groups at subsystem
creation time. We export:
* configfs_register_group
* configfs_unregister_group
to allow drivers to programatically create/destroy groups
later, after module init time.
This is needed for IIO configfs support.
(akpm: the other 4 patches to be merged via the IIO tree)
Signed-off-by: Daniel Baluta <daniel.baluta@intel.com>
Suggested-by: Lars-Peter Clausen <lars@metafoo.de>
Cc: Hartmut Knaack <knaack.h@gmx.de>
Cc: Octavian Purdila <octavian.purdila@intel.com>
Cc: Paul Bolle <pebolle@tiscali.nl>
Cc: Adriana Reus <adriana.reus@intel.com>
Cc: Cristina Opriceana <cristina.opriceana@gmail.com>
Cc: Peter Meerwald <pmeerw@pmeerw.net>
Remove the old show_attribute and store_attribute methods and update
the documentation. Also replace the two C samples with a single new
one in the proper samples directory where people expect to find it.
Add methods to struct configfs_attribute to directly show and store
attributes without adding boilerplate code to every user. In addition
to the methods this also adds 3 helper macros to define read/write,
read-only and write-only attributes with a single line of code.
Reviewed-by: Nicholas Bellinger <nab@linux-iscsi.org>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Some modules call config_item_init_type_name() and config_group_init_type_name()
with parameter "name" directly controlled by userspace. These two
functions call config_item_set_name() with this name used as a format
string, which can be used to leak information such as content of the
stack to userspace.
For example, make_netconsole_target() in netconsole module calls
config_item_init_type_name() with the name of a newly-created directory.
This means that the following commands give some unexpected output, with
configfs mounted in /sys/kernel/config/ and on a system with a
configured eth0 ethernet interface:
# modprobe netconsole
# mkdir /sys/kernel/config/netconsole/target_%lx
# echo eth0 > /sys/kernel/config/netconsole/target_%lx/dev_name
# echo 1 > /sys/kernel/config/netconsole/target_%lx/enabled
# dmesg |tail -n1
[ 142.697668] netconsole: target (target_ffffffffc0ae8080) is
enabled, disable to update parameters
The directory name is correct but %lx has been interpreted in the
internal item name, displayed here in the error message used by
store_dev_name() in drivers/net/netconsole.c.
To fix this, update every caller of config_item_set_name to use "%s"
when operating on untrusted input.
This issue was found using -Wformat-security gcc flag, once a __printf
attribute has been added to config_item_set_name().
Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org>
Acked-by: Felipe Balbi <balbi@ti.com>
Pull more vfs updates from Al Viro:
"Assorted VFS fixes and related cleanups (IMO the most interesting in
that part are f_path-related things and Eric's descriptor-related
stuff). UFS regression fixes (it got broken last cycle). 9P fixes.
fs-cache series, DAX patches, Jan's file_remove_suid() work"
[ I'd say this is much more than "fixes and related cleanups". The
file_table locking rule change by Eric Dumazet is a rather big and
fundamental update even if the patch isn't huge. - Linus ]
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits)
9p: cope with bogus responses from server in p9_client_{read,write}
p9_client_write(): avoid double p9_free_req()
9p: forgetting to cancel request on interrupted zero-copy RPC
dax: bdev_direct_access() may sleep
block: Add support for DAX reads/writes to block devices
dax: Use copy_from_iter_nocache
dax: Add block size note to documentation
fs/file.c: __fget() and dup2() atomicity rules
fs/file.c: don't acquire files->file_lock in fd_install()
fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation
vfs: avoid creation of inode number 0 in get_next_ino
namei: make set_root_rcu() return void
make simple_positive() public
ufs: use dir_pages instead of ufs_dir_pages()
pagemap.h: move dir_pages() over there
remove the pointless include of lglock.h
fs: cleanup slight list_entry abuse
xfs: Correctly lock inode when removing suid and file capabilities
fs: Call security_ops->inode_killpriv on truncate
fs: Provide function telling whether file_remove_privs() will do anything
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace updates from Eric Biederman:
"Long ago and far away when user namespaces where young it was realized
that allowing fresh mounts of proc and sysfs with only user namespace
permissions could violate the basic rule that only root gets to decide
if proc or sysfs should be mounted at all.
Some hacks were put in place to reduce the worst of the damage could
be done, and the common sense rule was adopted that fresh mounts of
proc and sysfs should allow no more than bind mounts of proc and
sysfs. Unfortunately that rule has not been fully enforced.
There are two kinds of gaps in that enforcement. Only filesystems
mounted on empty directories of proc and sysfs should be ignored but
the test for empty directories was insufficient. So in my tree
directories on proc, sysctl and sysfs that will always be empty are
created specially. Every other technique is imperfect as an ordinary
directory can have entries added even after a readdir returns and
shows that the directory is empty. Special creation of directories
for mount points makes the code in the kernel a smidge clearer about
it's purpose. I asked container developers from the various container
projects to help test this and no holes were found in the set of mount
points on proc and sysfs that are created specially.
This set of changes also starts enforcing the mount flags of fresh
mounts of proc and sysfs are consistent with the existing mount of
proc and sysfs. I expected this to be the boring part of the work but
unfortunately unprivileged userspace winds up mounting fresh copies of
proc and sysfs with noexec and nosuid clear when root set those flags
on the previous mount of proc and sysfs. So for now only the atime,
read-only and nodev attributes which userspace happens to keep
consistent are enforced. Dealing with the noexec and nosuid
attributes remains for another time.
This set of changes also addresses an issue with how open file
descriptors from /proc/<pid>/ns/* are displayed. Recently readlink of
/proc/<pid>/fd has been triggering a WARN_ON that has not been
meaningful since it was added (as all of the code in the kernel was
converted) and is not now actively wrong.
There is also a short list of issues that have not been fixed yet that
I will mention briefly.
It is possible to rename a directory from below to above a bind mount.
At which point any directory pointers below the renamed directory can
be walked up to the root directory of the filesystem. With user
namespaces enabled a bind mount of the bind mount can be created
allowing the user to pick a directory whose children they can rename
to outside of the bind mount. This is challenging to fix and doubly
so because all obvious solutions must touch code that is in the
performance part of pathname resolution.
As mentioned above there is also a question of how to ensure that
developers by accident or with purpose do not introduce exectuable
files on sysfs and proc and in doing so introduce security regressions
in the current userspace that will not be immediately obvious and as
such are likely to require breaking userspace in painful ways once
they are recognized"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace:
vfs: Remove incorrect debugging WARN in prepend_path
mnt: Update fs_fully_visible to test for permanently empty directories
sysfs: Create mountpoints with sysfs_create_mount_point
sysfs: Add support for permanently empty directories to serve as mount points.
kernfs: Add support for always empty directories.
proc: Allow creating permanently empty directories that serve as mount points
sysctl: Allow creating permanently empty directories that serve as mountpoints.
fs: Add helper functions for permanently empty directories.
vfs: Ignore unlocked mounts in fs_fully_visible
mnt: Modify fs_fully_visible to deal with locked ro nodev and atime
mnt: Refactor the logic for mounting sysfs and proc in a user namespace
This allows for better documentation in the code and
it allows for a simpler and fully correct version of
fs_fully_visible to be written.
The mount points converted and their filesystems are:
/sys/hypervisor/s390/ s390_hypfs
/sys/kernel/config/ configfs
/sys/kernel/debug/ debugfs
/sys/firmware/efi/efivars/ efivarfs
/sys/fs/fuse/connections/ fusectl
/sys/fs/pstore/ pstore
/sys/kernel/tracing/ tracefs
/sys/fs/cgroup/ cgroup
/sys/kernel/security/ securityfs
/sys/fs/selinux/ selinuxfs
/sys/fs/smackfs/ smackfs
config_item_init() is only used in item.c
Signed-off-by: Fabian Frederick <fabf@skynet.be>
similar to kfree_put_link()
only one instance looks at that argument at all; that sole
exception wants inode rather than dentry.
its only use is getting passed to nd_jump_link(), which can obtain
it from current->nameidata
a) instead of storing the symlink body (via nd_set_link()) and returning
an opaque pointer later passed to ->put_link(), ->follow_link() _stores_
that opaque pointer (into void * passed by address by caller) and returns
the symlink body. Returning ERR_PTR() on error, NULL on jump (procfs magic
symlinks) and pointer to symlink body for normal symlinks. Stored pointer
is ignored in all cases except the last one.
Storing NULL for opaque pointer (or not storing it at all) means no call
of ->put_link().
b) the body used to be passed to ->put_link() implicitly (via nameidata).
Now only the opaque pointer is. In the cases when we used the symlink body
to free stuff, ->follow_link() now should store it as opaque pointer in addition
to returning it.
We need this earlier in the boot process to allow various subsystems to
use configfs (e.g Industrial IIO).
Also, debugfs is at core_initcall level and configfs should be on the same
level from infrastructure point of view.
that's the bulk of filesystem drivers dealing with inodes of their own
