path: root/fs/configfs
2013-11-21configfs: fix race between dentry put and lookupJunxiao Bi
A race window in configfs, it starts from one dentry is UNHASHED and end before configfs_d_iput is called. In this window, if a lookup happen, since the original dentry was UNHASHED, so a new dentry will be allocated, and then in configfs_attach_attr(), sd->s_dentry will be updated to the new dentry. Then in configfs_d_iput(), BUG_ON(sd->s_dentry != dentry) will be triggered and system panic. sys_open: sys_close: ... fput dput dentry_kill __d_drop <--- dentry unhashed here, but sd->dentry still point to this dentry. lookup_real configfs_lookup configfs_attach_attr---> update sd->s_dentry to new allocated dentry here. d_kill configfs_d_iput <--- BUG_ON(sd->s_dentry != dentry) triggered here. To fix it, change configfs_d_iput to not update sd->s_dentry if sd->s_count > 2, that means there are another dentry is using the sd beside the one that is going to be put. Use configfs_dirent_lock in configfs_attach_attr to sync with configfs_d_iput. With the following steps, you can reproduce the bug. 1. enable ocfs2, this will mount configfs at /sys/kernel/config and fill configure in it. 2. run the following script. while [ 1 ]; do cat /sys/kernel/config/cluster/$your_cluster_name/idle_timeout_ms > /dev/null; done & while [ 1 ]; do cat /sys/kernel/config/cluster/$your_cluster_name/idle_timeout_ms > /dev/null; done & Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-11-15consolidate simple ->d_delete() instancesAl Viro
Rename simple_delete_dentry() to always_delete_dentry() and export it. Export simple_dentry_operations, while we are at it, and get rid of their duplicates Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-07-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs stuff from Al Viro: "O_TMPFILE ABI changes, Oleg's fput() series, misc cleanups, including making simple_lookup() usable for filesystems with non-NULL s_d_op, which allows us to get rid of quite a bit of ugliness" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: sunrpc: now we can just set ->s_d_op cgroup: we can use simple_lookup() now efivarfs: we can use simple_lookup() now make simple_lookup() usable for filesystems that set ->s_d_op configfs: don't open-code d_alloc_name() __rpc_lookup_create_exclusive: pass string instead of qstr rpc_create_*_dir: don't bother with qstr llist: llist_add() can use llist_add_batch() llist: fix/simplify llist_add() and llist_add_batch() fput: turn "list_head delayed_fput_list" into llist_head fs/file_table.c:fput(): add comment Safer ABI for O_TMPFILE
2013-07-14configfs: don't open-code d_alloc_name()Al Viro
2013-07-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull third set of VFS updates from Al Viro: "Misc stuff all over the place. There will be one more pile in a couple of days" This is an "evil merge" that also uses the new d_count helper in fs/configfs/dir.c, missed by commit 84d08fa888e7 ("helper for reading ->d_count") * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: ncpfs: fix error return code in ncp_parse_options() locks: move file_lock_list to a set of percpu hlist_heads and convert file_lock_lock to an lglock seq_file: add seq_list_*_percpu helpers f2fs: fix readdir incorrectness mode_t whack-a-mole... lustre: kill the pointless wrapper helper for reading ->d_count
2013-07-03configfs: use capped length for ->store_attribute()Dan Carpenter
The difference between "count" and "len" is that "len" is capped at 4095. Changing it like this makes it match how sysfs_write_file() is implemented. This is a static analysis patch. I haven't found any store_attribute() functions where this change makes a difference. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-06-29[readdir] convert configfsAl Viro
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile (part one) from Al Viro: "Assorted stuff - cleaning namei.c up a bit, fixing ->d_name/->d_parent locking violations, etc. The most visible changes here are death of FS_REVAL_DOT (replaced with "has ->d_weak_revalidate()") and a new helper getting from struct file to inode. Some bits of preparation to xattr method interface changes. Misc patches by various people sent this cycle *and* ocfs2 fixes from several cycles ago that should've been upstream right then. PS: the next vfs pile will be xattr stuff." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (46 commits) saner proc_get_inode() calling conventions proc: avoid extra pde_put() in proc_fill_super() fs: change return values from -EACCES to -EPERM fs/exec.c: make bprm_mm_init() static ocfs2/dlm: use GFP_ATOMIC inside a spin_lock ocfs2: fix possible use-after-free with AIO ocfs2: Fix oops in ocfs2_fast_symlink_readpage() code path get_empty_filp()/alloc_file() leave both ->f_pos and ->f_version zero target: writev() on single-element vector is pointless export kernel_write(), convert open-coded instances fs: encode_fh: return FILEID_INVALID if invalid fid_type kill f_vfsmnt vfs: kill FS_REVAL_DOT by adding a d_weak_revalidate dentry op nfsd: handle vfs_getattr errors in acl protocol switch vfs_getattr() to struct path default SET_PERSONALITY() in linux/elf.h ceph: prepopulate inodes only when request is aborted d_hash_and_lookup(): export, switch open-coded instances 9p: switch v9fs_set_create_acl() to inode+fid, do it before d_instantiate() 9p: split dropping the acls from v9fs_set_create_acl() ...
2013-02-22new helper: file_inode(file)Al Viro
2013-02-21configfs: move the dereference below the NULL testWei Yongjun
The dereference should be moved below the NULL test. spatch with a semantic match is used to found this. (http://coccinelle.lip6.fr/) Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-17lseek: the "whence" argument is called "whence"Andrew Morton
But the kernel decided to call it "origin" instead. Fix most of the sites. Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-09-18userns: Convert configfs to use kuid and kgid where appropriateEric W. Biederman
Cc: Joel Becker <jlbec@evilplan.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20make configfs_pin_fs() return root dentry on successAl Viro
... and make configfs_mnt static Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20configfs: configfs_create_dir() has parent dentry in dentry->d_parentAl Viro
no need to play sick games with parent item, internal mount, etc. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20configfs: sanitize configfs_create()Al Viro
2012-03-20configfs: kill configfs_sbAl Viro
2012-03-20configfs: don't bother with checks for mkdir/rmdir/unlink/symlink in rootAl Viro
just give root directory separate inode_operations without all those methods... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-01-03configfs: convert to umode_tAl Viro
2012-01-03switch vfs_mkdir() and ->mkdir() to umode_tAl Viro
vfs_mkdir() gets int, but immediately drops everything that might not fit into umode_t and that's the only caller of ->mkdir()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03vfs: live vfsmounts never have NULL ->mnt_sbAl Viro
2012-01-03vfs: for usbfs, etc. internal vfsmounts ->mnt_sb->s_root == ->mnt_rootAl Viro
2011-12-13configfs: register_filesystem() called too earlyAl Viro
2011-09-27doc: fix broken referencesPaul Bolle
There are numerous broken references to Documentation files (in other Documentation files, in comments, etc.). These broken references are caused by typo's in the references, and by renames or removals of the Documentation files. Some broken references are simply odd. Fix these broken references, sometimes by dropping the irrelevant text they were part of. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-28configfs: remove unnecessary dentry_unhash on rmdir, dir renameSage Weil
configfs does not have problems with references to unlinked directories. CC: Joel Becker <jlbec@evilplan.org> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (25 commits) cifs: remove unnecessary dentry_unhash on rmdir/rename_dir ocfs2: remove unnecessary dentry_unhash on rmdir/rename_dir exofs: remove unnecessary dentry_unhash on rmdir/rename_dir nfs: remove unnecessary dentry_unhash on rmdir/rename_dir ext2: remove unnecessary dentry_unhash on rmdir/rename_dir ext3: remove unnecessary dentry_unhash on rmdir/rename_dir ext4: remove unnecessary dentry_unhash on rmdir/rename_dir btrfs: remove unnecessary dentry_unhash in rmdir/rename_dir ceph: remove unnecessary dentry_unhash calls vfs: clean up vfs_rename_other vfs: clean up vfs_rename_dir vfs: clean up vfs_rmdir vfs: fix vfs_rename_dir for FS_RENAME_DOES_D_MOVE filesystems libfs: drop unneeded dentry_unhash vfs: update dentry_unhash() comment vfs: push dentry_unhash on rename_dir into file systems vfs: push dentry_unhash on rmdir into file systems vfs: remove dget() from dentry_unhash() vfs: dentry_unhash immediately prior to rmdir vfs: Block mmapped writes while the fs is frozen ...
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-18configfs: Fix race between configfs_readdir() and configfs_d_iput()Joel Becker
configfs_readdir() will use the existing inode numbers of inodes in the dcache, but it makes them up for attribute files that aren't currently instantiated. There is a race where a closing attribute file can be tearing down at the same time as configfs_readdir() is trying to get its inode number. We want to get the inode number of open attribute files, because they should match while instantiated. We can't lock down the transition where dentry->d_inode is set to NULL, so we just check for NULL there. We can, however, ensure that an inode we find isn't iput() in configfs_d_iput() until after we've accessed it. Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-05-18configfs: Don't try to d_delete() negative dentries.Joel Becker
When configfs is faking mkdir() on its subsystem or default group objects, it starts by adding a negative dentry. It then tries to instantiate the group. If that should fail, it must clean up after itself. I was using d_delete() here, but configfs_attach_group() promises to return an empty dentry on error. d_delete() explodes with the entry dentry. Let's try d_drop() instead. The unhashing is what we want for our dentry. Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-01-16configfs: change depends -> select SYSFSNicholas Bellinger
This patch changes configfs to select SYSFS to fix the following: warning: (TARGET_CORE && GFS2_FS) selects CONFIGFS_FS which has unmet direct dependencies (SYSFS) Reported-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Acked-by: Joel Becker <jlbec@evilplan.org>
2011-01-12switch configfsAl Viro
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache rationalise dget variantsNick Piggin
dget_locked was a shortcut to avoid the lazy lru manipulation when we already held dcache_lock (lru manipulation was relatively cheap at that point). However, how that the lru lock is an innermost one, we never hold it at any caller, so the lock cost can now be avoided. We already have well working lazy dcache LRU, so it should be fine to defer LRU manipulations to scan time. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache remove dcache_lockNick Piggin
dcache_lock no longer protects anything. remove it. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache scale d_unhashedNick Piggin
Protect d_unhashed(dentry) condition with d_lock. This means keeping DCACHE_UNHASHED bit in synch with hash manipulations. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache scale dentry refcountNick Piggin
Make d_count non-atomic and protect it with d_lock. This allows us to ensure a 0 refcount dentry remains 0 without dcache_lock. It is also fairly natural when we start protecting many other dentry members with d_lock. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_delete semanticsNick Piggin
Change d_delete from a dentry deletion notification to a dentry caching advise, more like ->drop_inode. Require it to be constant and idempotent, and not take d_lock. This is how all existing filesystems use the callback anyway. This makes fine grained dentry locking of dput and dentry lru scanning much simpler. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07config fs: avoid switching ->d_op on live dentryNick Piggin
Switching d_op on a live dentry is racy in general, so avoid it. In this case it is a negative dentry, which is safer, but there are still concurrent ops which may be called on d_op in that case (eg. d_revalidate). So in general a filesystem may not do this. Fix configfs so as not to do this. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-10-29convert get_sb_single() usersAl Viro
2010-10-25fs: do not assign default i_ino in new_inodeChristoph Hellwig
Instead of always assigning an increasing inode number in new_inode move the call to assign it into those callers that actually need it. For now callers that need it is estimated conservatively, that is the call is added to all filesystems that do not assign an i_ino by themselves. For a few more filesystems we can avoid assigning any inode number given that they aren't user visible, and for others it could be done lazily when an inode number is actually needed, but that's left for later patches. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-06-04fix setattr error handling in sysfs, configfsNick Piggin
sysfs and configfs setattr functions have error cases after the generic inode's attributes have been changed. Fix consistency by changing the generic inode attributes only when it is guaranteed to succeed. Signed-off-by: Nick Piggin <npiggin@suse.de> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-05-27fs: convert simple fs to new truncateNick Piggin
Convert simple filesystems: ramfs, configfs, sysfs, block_dev to new truncate sequence. Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-15Fix the regression created by "set S_DEAD on unlink()..." commitAl Viro
1) i_flags simply doesn't work for mount/unlink race prevention; we may have many links to file and rm on one of those obviously shouldn't prevent bind on top of another later on. To fix it right way we need to mark _dentry_ as unsuitable for mounting upon; new flag (DCACHE_CANT_MOUNT) is protected by d_flags and i_mutex on the inode in question. Set it (with dont_mount(dentry)) in unlink/rmdir/etc., check (with cant_mount(dentry)) in places in namespace.c that used to check for S_DEAD. Setting S_DEAD is still needed in places where we used to set it (for directories getting killed), since we rely on it for readdir/rmdir race prevention. 2) rename()/mount() protection has another bogosity - we unhash the target before we'd checked that it's not a mountpoint. Fixed. 3) ancient bogosity in pivot_root() - we locked i_mutex on the right directory, but checked S_DEAD on the different (and wrong) one. Noticed and fixed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-14Fix configfs leakAl Viro
2009-09-11writeback: add name to backing_dev_infoJens Axboe
This enables us to track who does what and print info. Its main use is catching dirty inodes on the default_backing_dev_info, so we can fix that up. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-30configfs: Rework configfs_depend_item() locking and make lockdep happyLouis Rilling
configfs_depend_item() recursively locks all inodes mutex from configfs root to the target item, which makes lockdep unhappy. The purpose of this recursive locking is to ensure that the item tree can be safely parsed and that the target item, if found, is not about to leave. This patch reworks configfs_depend_item() locking using configfs_dirent_lock. Since configfs_dirent_lock protects all changes to the configfs_dirent tree, and protects tagging of items to be removed, this lock can be used instead of the inodes mutex lock chain. This needs that the check for dependents be done atomically with CONFIGFS_USET_DROPPING tagging. Now lockdep looks happy with configfs. [ Lifted the setting of s_type into configfs_new_dirent() to satisfy the atomic setting of CONFIGFS_USET_CREATING -- Joel ] Signed-off-by: Louis Rilling <louis.rilling@kerlabs.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
