path: root/fs/coredump.c
2013-09-11coredump: add new %P variable in core_patternStéphane Graber
Add a new %P variable to be used in core_pattern. This variable contains the global PID (PID in the init namespace) as %p contains the PID in the current namespace which isn't always what we want. The main use for this is to make it easier to handle crashes that happened within a container. With that new variables it's possible to have the crashes dumped into the container or forwarded to the host with the right PID (from the host's point of view). Signed-off-by: Stéphane Graber <stgraber@ubuntu.com> Reported-by: Hans Feldt <hans.feldt@ericsson.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Andy Whitcroft <apw@canonical.com> Acked-by: Serge E. Hallyn <serge.hallyn@ubuntu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03coredump: '% at the end' shouldn't bypass core_uses_pid logicOleg Nesterov
"goto end" should not bypass the "Backward compatibility with core_uses_pid" code, move this label up. While at it, - It is ugly to copy '|' into cn->corename and then inc the pointer for argv_split(). Change format_corename() to increment pat_ptr instead. - Remove the dead "if (*pat_ptr == 0)" in format_corename(), we already checked it is not zero. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Colin Walters <walters@verbum.org> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Lennart Poettering <mzxreary@0pointer.de> Cc: Lucas De Marchi <lucas.de.marchi@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03coredump: kill call_count, add core_name_sizeOleg Nesterov
Imho, "atomic_t call_count" is ugly and should die. It buys nothing and in fact it can grow more than necessary, expand doesn't check if it was already incremented by another task. Kill it, and introduce "static int core_name_size" updated by expand_corename(). This is obviously racy too but harmless, and core_name_size never grows for no reason. We do not bother to to calculate the "right" new size, we simply do kmalloc(size_we_need) and use ksize() to rely on kmalloc_index's decision. Finally change format_corename() to use expand_corename(), krealloc(NULL) is fine. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Colin Walters <walters@verbum.org> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Lennart Poettering <mzxreary@0pointer.de> Cc: Lucas De Marchi <lucas.de.marchi@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03coredump: kill cn_escape(), introduce cn_esc_printf()Oleg Nesterov
The usage of cn_escape() looks really annoying, imho this sequence needs a wrapper. And it is buggy. If cn_printf() does expand_corename() cn_escape() writes to the freed memory. Introduce cn_esc_printf() which hopefully does this all right. It records the index before cn_vprintf(), not "char *" which is no longer valid (in general) after krealloc(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Colin Walters <walters@verbum.org> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Lennart Poettering <mzxreary@0pointer.de> Cc: Lucas De Marchi <lucas.de.marchi@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03coredump: cn_vprintf() has no reason to call vsnprintf() twiceOleg Nesterov
cn_vprintf() looks really overcomplicated and sub-optimal. We do not need vsnprintf(NULL) to calculate the size we need, we can simply try to print into the current buffer and expand/retry only if necessary. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Colin Walters <walters@verbum.org> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Lennart Poettering <mzxreary@0pointer.de> Cc: Lucas De Marchi <lucas.de.marchi@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03coredump: introduce cn_vprintf()Oleg Nesterov
Turn cn_printf(...) into cn_vprintf(va_list args), reintroduce cn_printf() as a trivial wrapper. This simplifies the next change and cn_vprintf() will have more callers. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Colin Walters <walters@verbum.org> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Lennart Poettering <mzxreary@0pointer.de> Cc: Lucas De Marchi <lucas.de.marchi@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-03coredump: format_corename() can leak cn->corenameOleg Nesterov
do_coredump() assumes that format_corename() can only fail if expand_corename() fails and frees cn->corename. This is not true, for example cn_print_exe_file() can fail and in this case nobody frees cn->corename. Change do_coredump() to always do kfree(cn->corename) after it calls format_corename() (NULL is fine), change expand_corename() to do nothing if kmalloc() fails. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Colin Walters <walters@verbum.org> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Lennart Poettering <mzxreary@0pointer.de> Cc: Lucas De Marchi <lucas.de.marchi@gmail.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-05-04do_coredump(): don't wait for thaw if coredump has already been interruptedAl Viro
2013-05-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull VFS updates from Al Viro, Misc cleanups all over the place, mainly wrt /proc interfaces (switch create_proc_entry to proc_create(), get rid of the deprecated create_proc_read_entry() in favor of using proc_create_data() and seq_file etc). 7kloc removed. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits) don't bother with deferred freeing of fdtables proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h proc: Make the PROC_I() and PDE() macros internal to procfs proc: Supply a function to remove a proc entry by PDE take cgroup_open() and cpuset_open() to fs/proc/base.c ppc: Clean up scanlog ppc: Clean up rtas_flash driver somewhat hostap: proc: Use remove_proc_subtree() drm: proc: Use remove_proc_subtree() drm: proc: Use minor->index to label things, not PDE->name drm: Constify drm_proc_list[] zoran: Don't print proc_dir_entry data in debug reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show() proc: Supply an accessor for getting the data from a PDE's parent airo: Use remove_proc_subtree() rtl8192u: Don't need to save device proc dir PDE rtl8187se: Use a dir under /proc/net/r8180/ proc: Add proc_mkdir_data() proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h} proc: Move PDE_NET() to fs/proc/proc_net.c ...
2013-04-30coredump: change wait_for_dump_helpers() to use wait_event_interruptible()Oleg Nesterov
wait_for_dump_helpers() calls wake_up/kill_fasync from inside the wait_event-like loop. This is not needed and in fact this is not strictly correct, we can/should do this only once after we change pipe->writers. We could even check if it becomes zero. Change this code to use use wait_event_interruptible(), this can also help to make this wait freezable. With this patch we check pipe->readers without pipe_lock(), this is fine. Once we see pipe->readers == 1 we know that the handler decremented the counter, this is all we need. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Mandeep Singh Baines <msb@chromium.org> Cc: Neil Horman <nhorman@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30coredump: factor out the setting of PF_DUMPCOREOleg Nesterov
Cleanup. Every linux_binfmt->core_dump() sets PF_DUMPCORE, move this into zap_threads() called by do_coredump(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Mandeep Singh Baines <msb@chromium.org> Cc: Neil Horman <nhorman@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30coredump: introduce dump_interrupted()Oleg Nesterov
By discussion with Mandeep. Change dump_write(), dump_seek() and do_coredump() to check signal_pending() and abort if it is true. dump_seek() does this only before f_op->llseek(), otherwise it relies on dump_write(). We need this change to ensure that the coredump won't delay suspend, and to ensure it reacts to SIGKILL "quickly enough", a core dump can take a lot of time. In particular this can help oom-killer. We add the new trivial helper, dump_interrupted() to add the comments and to simplify the potential freezer changes. Perhaps it will have more callers. Ideally it should do try_to_freeze() but then we need the unpleasant changes in dump_write() and wait_for_dump_helpers(). It is not trivial to change dump_write() to restart if f_op->write() fails because of freezing(). We need to handle the short writes, we need to clear TIF_SIGPENDING (and we can't rely on recalc_sigpending() unless we change it to check PF_DUMPCORE). And if the buggy f_op->write() sets TIF_SIGPENDING we can not distinguish this case from the race with freeze_task() + __thaw_task(). So we simply accept the fact that the freezer can truncate a core-dump but at least you can reliably suspend. Hopefully we can tolerate this unlikely case and the necessary complications doesn't worth a trouble. But if we decide to make the coredumping freezable later we can do this on top of this change. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Acked-by: Mandeep Singh Baines <msb@chromium.org> Cc: Neil Horman <nhorman@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30coredump: sanitize the setting of signal->group_exit_codeOleg Nesterov
Now that the coredumping process can be SIGKILL'ed, the setting of ->group_exit_code in do_coredump() can race with complete_signal() and SIGKILL or 0x80 can be "lost", or wait(status) can report status == SIGKILL | 0x80. But the main problem is that it is not clear to me what should we do if binfmt->core_dump() succeeds but SIGKILL was sent, that is why this patch comes as a separate change. This patch adds 0x80 if ->core_dump() succeeds and the process was not killed. But perhaps we can (should?) re-set ->group_exit_code changed by SIGKILL back to "siginfo->si_signo |= 0x80" in case when core_dumped == T. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Tested-by: Mandeep Singh Baines <msb@chromium.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Neil Horman <nhorman@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Roland McGrath <roland@hack.frob.com> Cc: Tejun Heo <tj@kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30coredump: ensure that SIGKILL always kills the dumping threadOleg Nesterov
prepare_signal() blesses SIGKILL sent to the dumping process but this signal can be "lost" anyway. The problems is, complete_signal() sees SIGNAL_GROUP_EXIT and skips the "kill them all" logic. And even if the dumping process is single-threaded (so the target is always "correct"), the group-wide SIGKILL is not recorded in task->pending and thus __fatal_signal_pending() won't be true. A multi-threaded case has even more problems. And even ignoring all technical details, SIGNAL_GROUP_EXIT doesn't look right to me. This coredumping process is not exiting yet, it can do a lot of work dumping the core. With this patch the dumping process doesn't have SIGNAL_GROUP_EXIT, we set signal->group_exit_task instead. This makes signal_group_exit() true and thus this should equally close the races with exit/exec/stop but allows to kill the dumping thread reliably. Notes: - It is not clear what should we do with ->group_exit_code if the dumper was killed, see the next change. - we need more (hopefully straightforward) changes to ensure that SIGKILL actually interrupts the coredump. Basically we need to check __fatal_signal_pending() in dump_write() and dump_seek(). Signed-off-by: Oleg Nesterov <oleg@redhat.com> Tested-by: Mandeep Singh Baines <msb@chromium.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Neil Horman <nhorman@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Roland McGrath <roland@hack.frob.com> Cc: Tejun Heo <tj@kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30coredump: only SIGKILL should interrupt the coredumping taskOleg Nesterov
There are 2 well known and ancient problems with coredump/signals, and a lot of related bug reports: - do_coredump() clears TIF_SIGPENDING but of course this can't help if, say, SIGCHLD comes after that. In this case the coredump can fail unexpectedly. See for example wait_for_dump_helper()->signal_pending() check but there are other reasons. - At the same time, dumping a huge core on the slow media can take a lot of time/resources and there is no way to kill the coredumping task reliably. In particular this is not oom_kill-friendly. This patch tries to fix the 1st problem, and makes the preparation for the next changes. We add the new SIGNAL_GROUP_COREDUMP flag set by zap_threads() to indicate that this process dumps the core. prepare_signal() checks this flag and nacks any signal except SIGKILL. Note that this check tries to be conservative, in the long term we should probably treat the SIGNAL_GROUP_EXIT case equally but this needs more discussion. See marc.info/?l=linux-kernel&m=120508897917439 Notes: - recalc_sigpending() doesn't check SIGNAL_GROUP_COREDUMP. The patch assumes that dump_write/etc paths should never call it, but we can change it as well. - There is another source of TIF_SIGPENDING, freezer. This will be addressed separately. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Tested-by: Mandeep Singh Baines <msb@chromium.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Neil Horman <nhorman@redhat.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Roland McGrath <roland@hack.frob.com> Cc: Tejun Heo <tj@kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30usermodehelper: split remaining calls to call_usermodehelper_fns()Lucas De Marchi
These are the only users of call_usermodehelper_fns(). This function suffers from not being able to determine if the cleanup is called. Even if in this places the cleanup pointer is NULL, convert them to use the separate call_usermodehelper_setup() + call_usermodehelper_exec() functions so we can remove the _fns variant. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: Oleg Nesterov <oleg@redhat.com> Cc: David Howells <dhowells@redhat.com> Cc: James Morris <james.l.morris@oracle.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Tejun Heo <tj@kernel.org> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-04-30coredump: remove trailling whitespaceLucas De Marchi
2013-04-09pipe: set file->private_data to ->i_pipeAl Viro
simplify get_pipe_info(), while we are at it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2013-04-09lift sb_start_write() out of ->write()Al Viro
2013-02-27coredump: remove redundant defines for dumpable statesKees Cook
The existing SUID_DUMP_* defines duplicate the newer SUID_DUMPABLE_* defines introduced in 54b501992dd2 ("coredump: warn about unsafe suid_dumpable / core_pattern combo"). Remove the new ones, and use the prior values instead. Signed-off-by: Kees Cook <keescook@chromium.org> Reported-by: Chen Gang <gang.chen@asianux.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Alan Cox <alan@linux.intel.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Doug Ledford <dledford@redhat.com> Cc: Serge Hallyn <serge.hallyn@canonical.com> Cc: James Morris <james.l.morris@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-22new helper: file_inode(file)Al Viro
2012-11-29do_coredump(): get rid of pt_regs argumentAl Viro
2012-10-16fix a leak in replace_fd() usersAl Viro
replace_fd() began with "eats a reference, tries to insert into descriptor table" semantics; at some point I'd switched it to much saner current behaviour ("try to insert into descriptor table, grabbing a new reference if inserted; caller should do fput() in any case"), but forgot to update the callers. Mea culpa... [Spotted by Pavel Roskin, who has really weird system with pipe-fed coredumps as part of what he considers a normal boot ;-)] Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-06coredump: pass siginfo_t* to do_coredump() and below, not merely signrDenys Vlasenko
This is a preparatory patch for the introduction of NT_SIGINFO elf note. With this patch we pass "siginfo_t *siginfo" instead of "int signr" to do_coredump() and put it into coredump_params. It will be used by the next patch. Most changes are simple s/signr/siginfo->si_signo/. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Reviewed-by: Oleg Nesterov <oleg@redhat.com> Cc: Amerigo Wang <amwang@redhat.com> Cc: "Jonathan M. Foote" <jmfoote@cert.org> Cc: Roland McGrath <roland@hack.frob.com> Cc: Pedro Alves <palves@redhat.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06coredump: add support for %d=__get_dumpable() in core nameOleg Nesterov
Some coredump handlers want to create a core file in a way compatible with standard behavior. Standard behavior with fs.suid_dumpable = 2 is to create core file with uid=gid=0. However, there was no way for coredump handler to know that the process being dumped was suid'ed. This patch adds the new %d specifier for format_corename() which simply reports __get_dumpable(mm->flags), this is compatible with /proc/sys/fs/suid_dumpable we already have. Addresses https://bugzilla.redhat.com/show_bug.cgi?id=787135 Developed during a discussion with Denys Vlasenko. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Denys Vlasenko <vda.linux@googlemail.com> Cc: Alex Kelly <alex.page.kelly@gmail.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Cong Wang <amwang@redhat.com> Cc: Jiri Moskovcak <jmoskovc@redhat.com> Acked-by: Neil Horman <nhorman@tuxdriver.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-06coredump: update coredump-related headersAlex Kelly
Create a new header file, fs/coredump.h, which contains functions only used by the new coredump.c. It also moves do_coredump to the include/linux/coredump.h header file, for consistency. Signed-off-by: Alex Kelly <alex.page.kelly@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-10-02coredump: move core dump functionality into its own fileAlex Kelly
This prepares for making core dump functionality optional. The variable "suid_dumpable" and associated functions are left in fs/exec.c because they're used elsewhere, such as in ptrace. Signed-off-by: Alex Kelly <alex.page.kelly@gmail.com> Reviewed-by: Josh Triplett <josh@joshtriplett.org> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
