This is the 4.14.164 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm64/kernel/cpu_errata.c
arch/arm64/kvm/hyp/tlb.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpio/gpio-vf610.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/core/block.c
drivers/mmc/core/queue.h
drivers/mmc/host/sdhci-esdhc-imx.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
include/net/tcp.h
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
[ Upstream commit eeacfdc68a104967162dfcba60f53f6f5b62a334 ]
Replace some BUG_ON()s with WARN_ON_ONCE() and returning an error code,
and move the check for len divisible by FS_CRYPTO_BLOCK_SIZE into
fscrypt_crypt_block() so that it's done for both encryption and
decryption, not just encryption.
Reviewed-by: Chandan Rajendra <chandan@linux.ibm.com>
commit 5858bdad4d0d0fc18bf29f34c3ac836e0b59441f upstream.
The directory may have been removed when entering
fscrypt_ioctl_set_policy(). If so, the empty_dir() check will return
error for ext4 file system.
ext4_rmdir() sets i_size = 0, then ext4_empty_dir() reports an error
because 'inode->i_size < EXT4_DIR_REC_LEN(1) + EXT4_DIR_REC_LEN(2)'. If
the fs is mounted with errors=panic, it will trigger a panic issue.
Add the check IS_DEADDIR() to fix this problem.
Fixes: 9bd8212f981e ("ext4 crypto: add encryption policy and password salt support")
Cc: <stable@vger.kernel.org> # v4.1+
Signed-off-by: Hongjie Fang <hongjiefang@asrmicro.com>
fscrypt starts several async. crypto ops and waiting for them to
complete. Move it over to generic code doing the same.
Signed-off-by: Gilad Ben-Yossef <gilad@benyossef.com>
(cherry picked from commit d0082e1a7c8dfee55b06e442f137097230a1102a)
[ Upstream commit 36dd26e0c8d42699eeba87431246c07c28075bae ]
Improve fscrypt read performance by switching the decryption workqueue
from bound to unbound. With the bound workqueue, when multiple bios
completed on the same CPU, they were decrypted on that same CPU. But
with the unbound queue, they are now decrypted in parallel on any CPU.
Although fscrypt read performance can be tough to measure due to the
many sources of variation, this change is most beneficial when
decryption is slow, e.g. on CPUs without AES instructions. For example,
I timed tarring up encrypted directories on f2fs. On x86 with AES-NI
instructions disabled, the unbound workqueue improved performance by
about 25-35%, using 1 to NUM_CPUs jobs with 4 or 8 CPUs available. But
with AES-NI enabled, performance was unchanged to within ~2%.
I also did the same test on a quad-core ARM CPU using xts-speck128-neon
encryption. There performance was usually about 10% better with the
unbound workqueue, bringing it closer to the unencrypted speed.
The unbound workqueue may be worse in some cases due to worse locality,
but I think it's still the better default. dm-crypt uses an unbound
workqueue by default too, so this change makes fscrypt match.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit a0b3bc855374c50b5ea85273553485af48caf2f7 upstream.
fscrypt_initialize(), which allocates the global bounce page pool when
an encrypted file is first accessed, uses "double-checked locking" to
try to avoid locking fscrypt_init_mutex. However, it doesn't use any
memory barriers, so it's theoretically possible for a thread to observe
a bounce page pool which has not been fully initialized. This is a
classic bug with "double-checked locking".
While "only a theoretical issue" in the latest kernel, in pre-4.8
kernels the pointer that was checked was not even the last to be
initialized, so it was easily possible for a crash (NULL pointer
dereference) to happen. This was changed only incidentally by the large
refactor to use fs/crypto/.
Solve both problems in a trivial way that can easily be backported: just
always take the mutex. It's theoretically less efficient, but it
shouldn't be noticeable in practice as the mutex is only acquired very
briefly once per encrypted file.
Later I'd like to make this use a helper macro like DO_ONCE(). However,
DO_ONCE() runs in atomic context, so we'd need to add a new macro that
allows blocking.
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
When an fscrypt-encrypted file is opened, we request the file's master
key from the keyrings service as a logon key, then access its payload.
However, a revoked key has a NULL payload, and we failed to check for
this. request_key() *does* skip revoked keys, but there is still a
window where the key can be revoked before we acquire its semaphore.
Fix it by checking for a NULL payload, treating it like a key which was
already revoked at the time it was requested.
Fixes: 88bd6ccdcdd6 ("ext4 crypto: add encryption key management facilities")
Reviewed-by: James Morris <james.l.morris@oracle.com>
Cc: <stable@vger.kernel.org> [v4.1+]
This way we don't need a block_device structure to submit I/O. The
block_device has different life time rules from the gendisk and
request_queue and is usually only available when the block device node
is open. Other callers need to explicitly create one (e.g. the lightnvm
passthrough code, or the new nvme multipathing code).
For the actual I/O path all that we need is the gendisk, which exists
once per block device. But given that the block layer also does
partition remapping we additionally need a partition index, which is
used for said remapping in generic_make_request.
Note that all the block drivers generally want request_queue or
sometimes the gendisk, so this removes a layer of indirection all
over the stack.
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"The first major feature for ext4 this merge window is the largedir
feature, which allows ext4 directories to support over 2 billion
directory entries (assuming ~64 byte file names; in practice, users
will run into practical performance limits first.) This feature was
originally written by the Lustre team, and credit goes to Artem
Blagodarenko from Seagate for getting this feature upstream.
The second major major feature allows ext4 to support extended
attribute values up to 64k. This feature was also originally from
Lustre, and has been enhanced by Tahsin Erdogan from Google with a
deduplication feature so that if multiple files have the same xattr
value (for example, Windows ACL's stored by Samba), only one copy will
be stored on disk for encoding and caching efficiency.
We also have the usual set of bug fixes, cleanups, and optimizations"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (47 commits)
ext4: fix spelling mistake: "prellocated" -> "preallocated"
ext4: fix __ext4_new_inode() journal credits calculation
ext4: skip ext4_init_security() and encryption on ea_inodes
fs: generic_block_bmap(): initialize all of the fields in the temp bh
ext4: change fast symlink test to not rely on i_blocks
ext4: require key for truncate(2) of encrypted file
ext4: don't bother checking for encryption key in ->mmap()
ext4: check return value of kstrtoull correctly in reserved_clusters_store
ext4: fix off-by-one fsmap error on 1k block filesystems
ext4: return EFSBADCRC if a bad checksum error is found in ext4_find_entry()
ext4: return EIO on read error in ext4_find_entry
ext4: forbid encrypting root directory
ext4: send parallel discards on commit completions
ext4: avoid unnecessary stalls in ext4_evict_inode()
ext4: add nombcache mount option
ext4: strong binding of xattr inode references
ext4: eliminate xattr entry e_hash recalculation for removes
ext4: reserve space for xattr entries/names
quota: add get_inode_usage callback to transfer multi-inode charges
ext4: xattr inode deduplication
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/fscrypt
Pull fscrypt updates from Ted Ts'o:
"Add support for 128-bit AES and some cleanups to fscrypt"
* tag 'fscrypt_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/fscrypt:
fscrypt: make ->dummy_context() return bool
fscrypt: add support for AES-128-CBC
fscrypt: inline fscrypt_free_filename()
ea_inode feature allows creating extended attributes that are up to
64k in size. Update __ext4_new_inode() to pick increased credit limits.
To avoid overallocating too many journal credits, update
__ext4_xattr_set_credits() to make a distinction between xattr create
vs update. This helps __ext4_new_inode() because all attributes are
known to be new, so we can save credits that are normally needed to
delete old values.
Also, have fscrypt specify its maximum context size so that we don't
end up allocating credits for 64k size.
Signed-off-by: Tahsin Erdogan <tahsin@google.com>
fscrypt provides facilities to use different encryption algorithms which
are selectable by userspace when setting the encryption policy. Currently,
only AES-256-XTS for file contents and AES-256-CBC-CTS for file names are
implemented. This is a clear case of kernel offers the mechanism and
userspace selects a policy. Similar to what dm-crypt and ecryptfs have.
This patch adds support for using AES-128-CBC for file contents and
AES-128-CBC-CTS for file name encryption. To mitigate watermarking
attacks, IVs are generated using the ESSIV algorithm. While AES-CBC is
actually slightly less secure than AES-XTS from a security point of view,
there is more widespread hardware support. Using AES-CBC gives us the
acceptable performance while still providing a moderate level of security
for persistent storage.
Especially low-powered embedded devices with crypto accelerators such as
CAAM or CESA often only support AES-CBC. Since using AES-CBC over AES-XTS
is basically thought of a last resort, we use AES-128-CBC over AES-256-CBC
since it has less encryption rounds and yields noticeable better
performance starting from a file size of just a few kB.
Signed-off-by: Daniel Walter <dwalter@sigma-star.at>
[david@sigma-star.at: addressed review comments]
Signed-off-by: David Gstir <david@sigma-star.at>
Reviewed-by: Eric Biggers <ebiggers@google.com>
fscrypt_free_filename() only needs to do a kfree() of crypto_buf.name,
which works well as an inline function. We can skip setting the various
pointers to NULL, since no user cares about it (the name is always freed
just before it goes out of scope).
Reviewed-by: David Gstir <david@sigma-star.at>
Replace bi_error with a new bi_status to allow for a clear conversion.
Note that device mapper overloaded bi_error with a private value, which
we'll have to keep arround at least for now and thus propagate to a
proper blk_status_t value.
Signed-off-by: Jens Axboe <axboe@fb.com>
Introduce a helper function fscrypt_match_name() which tests whether a
fscrypt_name matches a directory entry. Also clean up the magic numbers
and document things properly.
When accessing an encrypted directory without the key, userspace must
operate on filenames derived from the ciphertext names, which contain
arbitrary bytes. Since we must support filenames as long as NAME_MAX,
we can't always just base64-encode the ciphertext, since that may make
it too long. Currently, this is solved by presenting long names in an
abbreviated form containing any needed filesystem-specific hashes (e.g.
to identify a directory block), then the last 16 bytes of ciphertext.
This needs to be sufficient to identify the actual name on lookup.
However, there is a bug. It seems to have been assumed that due to the
use of a CBC (ciphertext block chaining)-based encryption mode, the last
16 bytes (i.e. the AES block size) of ciphertext would depend on the
full plaintext, preventing collisions. However, we actually use CBC
with ciphertext stealing (CTS), which handles the last two blocks
specially, causing them to appear "flipped". Thus, it's actually the
second-to-last block which depends on the full plaintext.
This caused long filenames that differ only near the end of their
plaintexts to, when observed without the key, point to the wrong inode
and be undeletable. For example, with ext4:
# echo pass | e4crypt add_key -p 16 edir/
# seq -f "edir/abcdefghijklmnopqrstuvwxyz012345%.0f" 100000 | xargs touch
# find edir/ -type f | xargs stat -c %i | sort | uniq | wc -l
100000
# sync
# echo 3 > /proc/sys/vm/drop_caches
# keyctl new_session
2004
# rm -rf edir/
rm: cannot remove 'edir/_A7nNFi3rhkEQlJ6P,hdzluhODKOeWx5V': Structure needs cleaning
To fix this, when presenting long encrypted filenames, encode the
second-to-last block of ciphertext rather than the last 16 bytes.
Although it would be nice to solve this without depending on a specific
encryption mode, that would mean doing a cryptographic hash like SHA-256
which would be much less efficient. This way is sufficient for now, and
it's still compatible with encryption modes like HEH which are strong
pseudorandom permutations. Also, changing the presented names is still
allowed at any time because they are only provided to allow applications
to do things like delete encrypted directories. They're not designed to
be used to persistently identify files --- which would be hard to do
anyway, given that they're encrypted after all.
For ease of backports, this patch only makes the minimal fix to both
ext4 and f2fs. It leaves ubifs as-is, since ubifs doesn't compare the
ciphertext block yet. Follow-on patches will clean things up properly
and make the filesystems use a shared helper function.
Fixes: 5de0b4d0cd15 ("ext4 crypto: simplify and speed up filename encryption")
Reported-by: Gwendal Grignou <gwendal@chromium.org>
Cc: stable@vger.kernel.org
To mitigate some types of offline attacks, filesystem encryption is
designed to enforce that all files in an encrypted directory tree use
the same encryption policy (i.e. the same encryption context excluding
the nonce). However, the fscrypt_has_permitted_context() function which
enforces this relies on comparing struct fscrypt_info's, which are only
available when we have the encryption keys. This can cause two
incorrect behaviors:
1. If we have the parent directory's key but not the child's key, or
vice versa, then fscrypt_has_permitted_context() returned false,
causing applications to see EPERM or ENOKEY. This is incorrect if
the encryption contexts are in fact consistent. Although we'd
normally have either both keys or neither key in that case since the
master_key_descriptors would be the same, this is not guaranteed
because keys can be added or removed from keyrings at any time.
2. If we have neither the parent's key nor the child's key, then
fscrypt_has_permitted_context() returned true, causing applications
to see no error (or else an error for some other reason). This is
incorrect if the encryption contexts are in fact inconsistent, since
in that case we should deny access.
To fix this, retrieve and compare the fscrypt_contexts if we are unable
to set up both fscrypt_infos.
While this slightly hurts performance when accessing an encrypted
directory tree without the key, this isn't a case we really need to be
optimizing for; access *with* the key is much more important.
Furthermore, the performance hit is barely noticeable given that we are
already retrieving the fscrypt_context and doing two keyring searches in
fscrypt_get_encryption_info(). If we ever actually wanted to optimize
this case we might start by caching the fscrypt_contexts.
Cc: stable@vger.kernel.org # 4.0+
This commit exposes the necessary constants and structures for a
userspace program to pass filesystem encryption keys into the keyring.
The fscrypt_key structure was already part of the kernel ABI, this
change just makes it so programs no longer have to redeclare these
structures (like e4crypt in e2fsprogs currently does).
Note that we do not expose the other FS_*_KEY_SIZE constants as they are
not necessary. Only XTS is supported for contents_encryption_mode, so
currently FS_MAX_KEY_SIZE bytes of key material must always be passed to
the kernel.
This commit also removes __packed from fscrypt_key as it does not
contain any implicit padding and does not refer to an on-disk structure.
Signed-off-by: Joe Richey <joerichey@google.com>
The functions in fs/crypto/*.c are only called by filesystems configured
with encryption support. Since the ->get_context(), ->set_context(),
and ->empty_dir() operations are always provided in that case (and must
be, otherwise there would be no way to get/set encryption policies, or
in the case of ->get_context() even access encrypted files at all),
there is no need to check for these operations being NULL and we can
remove these unneeded checks.
Reviewed-by: Richard Weinberger <richard@nod.at>
Pull fscrypto fixes from Ted Ts'o:
"A code cleanup and bugfix for fs/crypto"
* tag 'fscrypt-for-linus_stable' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/fscrypt:
fscrypt: eliminate ->prepare_context() operation
fscrypt: remove broken support for detecting keyring key revocation
The only use of the ->prepare_context() fscrypt operation was to allow
ext4 to evict inline data from the inode before ->set_context().
However, there is no reason why this cannot be done as simply the first
step in ->set_context(), and in fact it makes more sense to do it that
way because then the policy modes and flags get validated before any
real work is done. Therefore, merge ext4_prepare_context() into
ext4_set_context(), and remove ->prepare_context().
Filesystem encryption ostensibly supported revoking a keyring key that
had been used to "unlock" encrypted files, causing those files to become
"locked" again. This was, however, buggy for several reasons, the most
severe of which was that when key revocation happened to be detected for
an inode, its fscrypt_info was immediately freed, even while other
threads could be using it for encryption or decryption concurrently.
This could be exploited to crash the kernel or worse.
This patch fixes the use-after-free by removing the code which detects
the keyring key having been revoked, invalidated, or expired. Instead,
an encrypted inode that is "unlocked" now simply remains unlocked until
it is evicted from memory. Note that this is no worse than the case for
block device-level encryption, e.g. dm-crypt, and it still remains
possible for a privileged user to evict unused pages, inodes, and
dentries by running 'sync; echo 3 > /proc/sys/vm/drop_caches', or by
simply unmounting the filesystem. In fact, one of those actions was
already needed anyway for key revocation to work even somewhat sanely.
This change is not expected to break any applications.
In the future I'd like to implement a real API for fscrypt key
revocation that interacts sanely with ongoing filesystem operations ---
waiting for existing operations to complete and blocking new operations,
and invalidating and sanitizing key material and plaintext from the VFS
caches. But this is a hard problem, and for now this bug must be fixed.
This bug affected almost all versions of ext4, f2fs, and ubifs
encryption, and it was potentially reachable in any kernel configured
with encryption support (CONFIG_EXT4_ENCRYPTION=y,
CONFIG_EXT4_FS_ENCRYPTION=y, CONFIG_F2FS_FS_ENCRYPTION=y, or
CONFIG_UBIFS_FS_ENCRYPTION=y). Note that older kernels did not use the
shared fs/crypto/ code, but due to the potential security implications
of this bug, it may still be worthwhile to backport this fix to them.
Fixes: b7236e21d55f ("ext4 crypto: reorganize how we store keys in the inode")
Cc: stable@vger.kernel.org # v4.2+
Acked-by: Michael Halcrow <mhalcrow@google.com>
rcu_dereference_key() and user_key_payload() are currently being used in
two different, incompatible ways:
(1) As a wrapper to rcu_dereference() - when only the RCU read lock used
to protect the key.
(2) As a wrapper to rcu_dereference_protected() - when the key semaphor is
used to protect the key and the may be being modified.
Fix this by splitting both of the key wrappers to produce:
(1) RCU accessors for keys when caller has the key semaphore locked:
dereference_key_locked()
user_key_payload_locked()
(2) RCU accessors for keys when caller holds the RCU read lock:
dereference_key_rcu()
user_key_payload_rcu()
This should fix following warning in the NFS idmapper
[ INFO: suspicious RCU usage. ]
4.10.0 #1 Tainted: G W
./include/keys/user-type.h:53 suspicious rcu_dereference_protected() usage!
rcu_scheduler_active = 2, debug_locks = 0
1 lock held by mount.nfs/5987:
#0: (rcu_read_lock){......}, at: [<d000000002527abc>] nfs_idmap_get_key+0x15c/0x420 [nfsv4]
stack backtrace:
CPU: 1 PID: 5987 Comm: mount.nfs Tainted: G W 4.10.0 #1
Call Trace:
dump_stack+0xe8/0x154 (unreliable)
lockdep_rcu_suspicious+0x140/0x190
nfs_idmap_get_key+0x380/0x420 [nfsv4]
nfs_map_name_to_uid+0x2a0/0x3b0 [nfsv4]
decode_getfattr_attrs+0xfac/0x16b0 [nfsv4]
decode_getfattr_generic.constprop.106+0xbc/0x150 [nfsv4]
nfs4_xdr_dec_lookup_root+0xac/0xb0 [nfsv4]
rpcauth_unwrap_resp+0xe8/0x140 [sunrpc]
call_decode+0x29c/0x910 [sunrpc]
__rpc_execute+0x140/0x8f0 [sunrpc]
rpc_run_task+0x170/0x200 [sunrpc]
nfs4_call_sync_sequence+0x68/0xa0 [nfsv4]
_nfs4_lookup_root.isra.44+0xd0/0xf0 [nfsv4]
nfs4_lookup_root+0xe0/0x350 [nfsv4]
nfs4_lookup_root_sec+0x70/0xa0 [nfsv4]
nfs4_find_root_sec+0xc4/0x100 [nfsv4]
nfs4_proc_get_rootfh+0x5c/0xf0 [nfsv4]
nfs4_get_rootfh+0x6c/0x190 [nfsv4]
nfs4_server_common_setup+0xc4/0x260 [nfsv4]
nfs4_create_server+0x278/0x3c0 [nfsv4]
nfs4_remote_mount+0x50/0xb0 [nfsv4]
mount_fs+0x74/0x210
vfs_kern_mount+0x78/0x220
nfs_do_root_mount+0xb0/0x140 [nfsv4]
nfs4_try_mount+0x60/0x100 [nfsv4]
nfs_fs_mount+0x5ec/0xda0 [nfs]
mount_fs+0x74/0x210
do_mount+0x254/0xf70
SyS_mount+0x94/0x100
system_call+0x38/0xe0
Reported-by: Jan Stancek <jstancek@redhat.com>
Tested-by: Jan Stancek <jstancek@redhat.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
When a completion is declared on-stack we have to use
COMPLETION_INITIALIZER_ONSTACK().
Fixes: 0b81d07790726 ("fs crypto: move per-file encryption from f2fs
tree to fs/crypto")
Signed-off-by: Richard Weinberger <richard@nod.at>
Previously, each filesystem configured without encryption support would
define all the public fscrypt functions to their notsupp_* stubs. This
list of #defines had to be updated in every filesystem whenever a change
was made to the public fscrypt functions. To make things more
maintainable now that we have three filesystems using fscrypt, split the
old header fscrypto.h into several new headers. fscrypt_supp.h contains
the real declarations and is included by filesystems when configured
with encryption support, whereas fscrypt_notsupp.h contains the inline
stubs and is included by filesystems when configured without encryption
support. fscrypt_common.h contains common declarations needed by both.
res is assigned to sizeof(ctx), however, this is unused and res
is updated later on without that assigned value to res ever being
used. Remove this redundant assignment.
Fixes CoverityScan CID#1395546 "Unused value"
There was an unnecessary amount of complexity around requesting the
filesystem-specific key prefix. It was unclear why; perhaps it was
envisioned that different instances of the same filesystem type could
use different key prefixes, or that key prefixes could be binary.
However, neither of those things were implemented or really make sense
at all. So simplify the code by making key_prefix a const char *.
Currently, the test_dummy_encryption ext4 mount option, which exists
only to test encrypted I/O paths with xfstests, overrides all
per-inode encryption keys with a fixed key.
This change minimizes test_dummy_encryption-specific code path changes
by supplying a fake context for directories which are not encrypted
for use when creating new directories, files, or symlinks. This
allows us to properly exercise the keyring lookup, derivation, and
context inheritance code paths.
Before mounting a file system using test_dummy_encryption, userspace
must execute the following shell commands:
mode='\x00\x00\x00\x00'
raw="$(printf ""\\\\x%02x"" $(seq 0 63))"
if lscpu | grep "Byte Order" | grep -q Little ; then
size='\x40\x00\x00\x00'
else
size='\x00\x00\x00\x40'
fi
key="${mode}${raw}${size}"
keyctl new_session
echo -n -e "${key}" | keyctl padd logon fscrypt:4242424242424242 @s
That way we can get rid of the direct dependency on CONFIG_BLOCK.
Fixes: d475a507457b ("ubifs: Add skeleton for fscrypto")
Reported-by: Randy Dunlap <rdunlap@infradead.org>
It was possible for the ->get_context() operation to fail with a
specific error code, which was then not returned to the caller of
FS_IOC_SET_ENCRYPTION_POLICY or FS_IOC_GET_ENCRYPTION_POLICY. Make sure
to pass through these error codes. Also reorganize the code so that
->get_context() only needs to be called one time when setting an
encryption policy, and handle contexts of unrecognized sizes more
appropriately.
Several warning messages were not rate limited and were user-triggerable
from FS_IOC_SET_ENCRYPTION_POLICY. These shouldn't really have been
there in the first place, but either way they aren't as useful now that
the error codes have been improved. So just remove them.
As part of an effort to clean up fscrypt-related error codes, make
FS_IOC_SET_ENCRYPTION_POLICY fail with EEXIST when the file already uses
a different encryption policy. This is more descriptive than EINVAL,
which was ambiguous with some of the other error cases.
I am not aware of any users who might be relying on the previous error
code of EINVAL, which was never documented anywhere.
This failure case will be exercised by an xfstest.
FS_IOC_SET_ENCRYPTION_POLICY fail with ENOTDIR when the file descriptor
does not refer to a directory. This is more descriptive than EINVAL,
code of EINVAL, which was never documented anywhere, and in some buggy
kernels did not exist at all as the S_ISDIR() check was missing.
attempting to create a file in an encrypted directory that hasn't been
"unlocked" fail with ENOKEY. Previously, several error codes were used
for this case, including ENOENT, EACCES, and EPERM, and they were not
consistent between and within filesystems. ENOKEY is a better choice
because it expresses that the failure is due to lacking the encryption
key. It also matches the error code returned when trying to open an
encrypted regular file without the key.
inconsistent error codes, which were never documented anywhere.
Attempting to link a device node, named pipe, or socket file into an
encrypted directory through rename(2) or link(2) always failed with
EPERM. This happened because fscrypt_has_permitted_context() saw that
the file was unencrypted and forbid creating the link. This behavior
was unexpected because such files are never encrypted; only regular
files, directories, and symlinks can be encrypted.
To fix this, make fscrypt_has_permitted_context() always return true on
special files.
This will be covered by a test in my encryption xfstests patchset.
Commit f1c131b45410a: "crypto: xts - Convert to skcipher" now fails
the setkey operation if the AES key is the same as the tweak key.
Previously this check was only done if FIPS mode is enabled. Now this
check is also done if weak key checking was requested. This is
reasonable, but since we were using the dummy key which was a constant
series of 0x42 bytes, it now caused dummy encrpyption test mode to
fail.
Fix this by using 0x42... and 0x24... for the two keys, so they are
different.
Fixes: f1c131b45410a202eb45cc55980a7a9e4e4b4f40
... to better explain its purpose after introducing in-place encryption
without bounce buffer.
Since fscrypt users can now indicated if fscrypt_encrypt_page() should
use a bounce page, we can delay the bounce page pool initialization util
it is really needed. That is until fscrypt_operations has no
FS_CFLG_OWN_PAGES flag set.
Rename the FS_CFLG_INPLACE_ENCRYPTION flag to FS_CFLG_OWN_PAGES which,
when set, indicates that the fs uses pages under its own control as
opposed to writeback pages which require locking and a bounce buffer for
encryption.
- Improve documentation
- Add BUG_ON(len == 0) to avoid accidental switch of offs and len
parameters
- Improve variable names for readability
In case of in-place encryption fscrypt_ctx was allocated but never
released. Since we don't need it for in-place encryption, we skip
allocating it.
Fixes: 1c7dcf69eea3 ("fscrypt: Add in-place encryption mode")
Actually use the fs-provided index instead of always using page->index
which is only set for page-cache pages.
Fixes: 9c4bb8a3a9b4 ("fscrypt: Let fs select encryption index/tweak")
The fscrypt_initalize() function isn't used outside fs/crypto, so
there's no point making it be an exported symbol.
To avoid namespace collisions, rename get_crypt_info() to
fscrypt_get_crypt_info(). The function is only used inside the
fs/crypto directory, so declare it in the new header file,
fscrypt_private.h.
Multiple bugs were recently fixed in the "set encryption policy" ioctl.
To make it clear that fscrypt_process_policy() and fscrypt_get_policy()
implement ioctls and therefore their implementations must take standard
security and correctness precautions, rename them to
fscrypt_ioctl_set_policy() and fscrypt_ioctl_get_policy(). Make the
latter take in a struct file * to make it consistent with the former.
SHA256 and ENCRYPTED_KEYS are not needed. CTR shouldn't be needed
either, but I left it for now because it was intentionally added by
commit 71dea01ea2ed ("ext4 crypto: require CONFIG_CRYPTO_CTR if ext4
encryption is enabled"). So it sounds like there may be a dependency
problem elsewhere, which I have not been able to identify specifically,
that must be solved before CTR can be removed.
With the new (in 4.9) option to use a virtually-mapped stack
(CONFIG_VMAP_STACK), stack buffers cannot be used as input/output for
the scatterlist crypto API because they may not be directly mappable to
struct page. get_crypt_info() was using a stack buffer to hold the
output from the encryption operation used to derive the per-file key.
Fix it by using a heap buffer.
This bug could most easily be observed in a CONFIG_DEBUG_SG kernel
because this allowed the BUG in sg_set_buf() to be triggered.
struct page. For short filenames, fname_encrypt() was encrypting a
stack buffer holding the padded filename. Fix it by encrypting the
filename in-place in the output buffer, thereby making the temporary
buffer unnecessary.
