commit 81be24d263dbeddaba35827036d6f6787a59c2c3 upstream.
It's not hard to trigger a bunch of d_invalidate() on the same
dentry in parallel. They end up fighting each other - any
dentry picked for removal by one will be skipped by the rest
and we'll go for the next iteration through the entire
subtree, even if everything is being skipped. Morevoer, we
immediately go back to scanning the subtree. The only thing
we really need is to dissolve all mounts in the subtree and
as soon as we've nothing left to do, we can just unhash the
dentry and bugger off.
commit 1dbd449c9943e3145148cc893c2461b72ba6fef0 upstream.
The nr_dentry_unused per-cpu counter tracks dentries in both the LRU
lists and the shrink lists where the DCACHE_LRU_LIST bit is set.
The shrink_dcache_sb() function moves dentries from the LRU list to a
shrink list and subtracts the dentry count from nr_dentry_unused. This
is incorrect as the nr_dentry_unused count will also be decremented in
shrink_dentry_list() via d_shrink_del().
To fix this double decrement, the decrement in the shrink_dcache_sb()
function is taken out.
Fixes: 4e717f5c1083 ("list_lru: remove special case function list_lru_dispose_all."
Cc: stable@kernel.org
Signed-off-by: Waiman Long <longman@redhat.com>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
[ Upstream commit 6cd00a01f0c1ae6a852b09c59b8dd55cc6c35d1d ]
Since only dentry->d_name.len + 1 bytes out of DNAME_INLINE_LEN bytes
are initialized at __d_alloc(), we can't copy the whole size
unconditionally.
WARNING: kmemcheck: Caught 32-bit read from uninitialized memory (ffff8fa27465ac50)
636f6e66696766732e746d70000000000010000000000000020000000188ffff
i i i i i i i i i i i i i u u u u u u u u u u i i i i i u u u u
RIP: 0010:take_dentry_name_snapshot+0x28/0x50
RSP: 0018:ffffa83000f5bdf8 EFLAGS: 00010246
RAX: 0000000000000020 RBX: ffff8fa274b20550 RCX: 0000000000000002
RDX: ffffa83000f5be40 RSI: ffff8fa27465ac50 RDI: ffffa83000f5be60
RBP: ffffa83000f5bdf8 R08: ffffa83000f5be48 R09: 0000000000000001
R10: ffff8fa27465ac00 R11: ffff8fa27465acc0 R12: ffff8fa27465ac00
R13: ffff8fa27465acc0 R14: 0000000000000000 R15: 0000000000000000
FS: 00007f79737ac8c0(0000) GS:ffffffff8fc30000(0000) knlGS:0000000000000000
CR2: ffff8fa274c0b000 CR3: 0000000134aa7002 CR4: 00000000000606f0
vfs_rename+0x128/0x870
SyS_rename+0x3b2/0x3d0
entry_SYSCALL_64_fastpath+0x1a/0xa4
0xffffffffffffffff
Link: http://lkml.kernel.org/r/201709131912.GBG39012.QMJLOVFSFFOOtH@I-love.SAKURA.ne.jp
Cc: Vegard Nossum <vegard.nossum@gmail.com>
commit 4c0d7cd5c8416b1ef41534d19163cb07ffaa03ab upstream.
RCU pathwalk relies upon the assumption that anything that changes
->d_inode of a dentry will invalidate its ->d_seq. That's almost
true - the one exception is that the final dput() of already unhashed
dentry does *not* touch ->d_seq at all. Unhashing does, though,
so for anything we'd found by RCU dcache lookup we are fine.
Unfortunately, we can *start* with an unhashed dentry or jump into
it.
We could try and be careful in the (few) places where that could
happen. Or we could just make the final dput() invalidate the damn
thing, unhashed or not. The latter is much simpler and easier to
backport, so let's do it that way.
Reported-by: "Dae R. Jeong" <threeearcat@gmail.com>
Cc: stable@vger.kernel.org
commit 90bad5e05bcdb0308cfa3d3a60f5c0b9c8e2efb3 upstream.
Since mountpoint crossing can happen without leaving lazy mode,
root dentries do need the same protection against having their
memory freed without RCU delay as everything else in the tree.
It's partially hidden by RCU delay between detaching from the
mount tree and dropping the vfsmount reference, but the starting
point of pathwalk can be on an already detached mount, in which
case umount-caused RCU delay has already passed by the time the
lazy pathwalk grabs rcu_read_lock(). If the starting point
happens to be at the root of that vfsmount *and* that vfsmount
covers the entire filesystem, we get trouble.
Fixes: 48a066e72d97 ("RCU'd vsfmounts")
[ Upstream commit 8cc07c808c9d595e81cbe5aad419b7769eb2e5c9 ]
i_dir_seq is subject to concurrent modification by a cmpxchg or
store-release operation, so ensure that the relaxed access in
d_alloc_parallel uses READ_ONCE.
Reported-by: Peter Zijlstra <peterz@infradead.org>
[ Upstream commit 015555fd4d2930bc0c86952c46ad88b3392f66e4 ]
If d_alloc_parallel runs concurrently with __d_add, it is possible for
d_alloc_parallel to continuously retry whilst i_dir_seq has been
incremented to an odd value by __d_add:
CPU0:
__d_add
n = start_dir_add(dir);
cmpxchg(&dir->i_dir_seq, n, n + 1) == n
CPU1:
d_alloc_parallel
retry:
seq = smp_load_acquire(&parent->d_inode->i_dir_seq) & ~1;
hlist_bl_lock(b);
bit_spin_lock(0, (unsigned long *)b); // Always succeeds
CPU0:
__d_lookup_done(dentry)
hlist_bl_lock
bit_spin_lock(0, (unsigned long *)b); // Never succeeds
CPU1:
if (unlikely(parent->d_inode->i_dir_seq != seq)) {
hlist_bl_unlock(b);
goto retry;
Since the simple bit_spin_lock used to implement hlist_bl_lock does not
provide any fairness guarantees, then CPU1 can starve CPU0 of the lock
and prevent it from reaching end_dir_add(dir), therefore CPU1 cannot
exit its retry loop because the sequence number always has the bottom
bit set.
This patch resolves the livelock by not taking hlist_bl_lock in
d_alloc_parallel if the sequence counter is odd, since any subsequent
masked comparison with i_dir_seq will fail anyway.
Reported-by: Naresh Madhusudana <naresh.madhusudana@arm.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
commit 1e2e547a93a00ebc21582c06ca3c6cfea2a309ee upstream.
For anything NFS-exported we do _not_ want to unlock new inode
before it has grown an alias; original set of fixes got the
ordering right, but missed the nasty complication in case of
lockdep being enabled - unlock_new_inode() does
lockdep_annotate_inode_mutex_key(inode)
which can only be done before anyone gets a chance to touch
->i_mutex. Unfortunately, flipping the order and doing
unlock_new_inode() before d_instantiate() opens a window when
mkdir can race with open-by-fhandle on a guessed fhandle, leading
to multiple aliases for a directory inode and all the breakage
that follows from that.
Correct solution: a new primitive (d_instantiate_new())
combining these two in the right order - lockdep annotate, then
d_instantiate(), then the rest of unlock_new_inode(). All
combinations of d_instantiate() with unlock_new_inode() should
be converted to that.
Cc: stable@kernel.org # 2.6.29 and later
Tested-by: Mike Marshall <hubcap@omnibond.com>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
[ Upstream commit 61647823aa920e395afcce4b57c32afb51456cab ]
d_move() will call __d_drop() and then __d_rehash()
on the dentry being moved. This creates a small window
when the dentry appears to be unhashed. Many tests
of d_unhashed() are made under ->d_lock and so are safe
from racing with this window, but some aren't.
In particular, getcwd() calls d_unlinked() (which calls
d_unhashed()) without d_lock protection, so it can race.
This races has been seen in practice with lustre, which uses d_move() as
part of name lookup. See:
https://jira.hpdd.intel.com/browse/LU-9735
It could race with a regular rename(), and result in ENOENT instead
of either the 'before' or 'after' name.
The race can be demonstrated with a simple program which
has two threads, one renaming a directory back and forth
while another calls getcwd() within that directory: it should never
fail, but does. See:
https://patchwork.kernel.org/patch/9455345/
We could fix this race by taking d_lock and rechecking when
d_unhashed() reports true. Alternately when can remove the window,
which is the approach this patch takes.
___d_drop() is introduce which does *not* clear d_hash.pprev
so the dentry still appears to be hashed. __d_drop() calls
___d_drop(), then clears d_hash.pprev.
__d_move() now uses ___d_drop() and only clears d_hash.pprev
when not rehashing.
Signed-off-by: NeilBrown <neilb@suse.com>
commit 3b821409632ab778d46e807516b457dfa72736ed upstream.
In case when dentry passed to lock_parent() is protected from freeing only
by the fact that it's on a shrink list and trylock of parent fails, we
could get hit by __dentry_kill() (and subsequent dentry_kill(parent))
between unlocking dentry and locking presumed parent. We need to recheck
that dentry is alive once we lock both it and parent *and* postpone
rcu_read_unlock() until after that point. Otherwise we could return
a pointer to struct dentry that already is rcu-scheduled for freeing, with
->d_lock held on it; caller's subsequent attempt to unlock it can end
up with memory corruption.
Cc: stable@vger.kernel.org # 3.12+, counting backports
commit 49d31c2f389acfe83417083e1208422b4091cd9e upstream.
take_dentry_name_snapshot() takes a safe snapshot of dentry name;
if the name is a short one, it gets copied into caller-supplied
structure, otherwise an extra reference to external name is grabbed
(those are never modified). In either case the pointer to stable
string is stored into the same structure.
dentry must be held by the caller of take_dentry_name_snapshot(),
but may be freely dropped afterwards - the snapshot will stay
until destroyed by release_dentry_name_snapshot().
Intended use:
struct name_snapshot s;
take_dentry_name_snapshot(&s, dentry);
access s.name
release_dentry_name_snapshot(&s);
Replaces fsnotify_oldname_...(), gets used in fsnotify to obtain the name
to pass down with event.
commit b17c070fb624cf10162cf92ea5e1ec25cd8ac176 upstream.
__list_lru_walk_one() acquires nlru spin lock (nlru->lock) for longer
duration if there are more number of items in the lru list. As per the
current code, it can hold the spin lock for upto maximum UINT_MAX
entries at a time. So if there are more number of items in the lru
list, then "BUG: spinlock lockup suspected" is observed in the below
path:
spin_bug+0x90
do_raw_spin_lock+0xfc
_raw_spin_lock+0x28
list_lru_add+0x28
dput+0x1c8
path_put+0x20
terminate_walk+0x3c
path_lookupat+0x100
filename_lookup+0x6c
user_path_at_empty+0x54
SyS_faccessat+0xd0
el0_svc_naked+0x24
This nlru->lock is acquired by another CPU in this path -
d_lru_shrink_move+0x34
dentry_lru_isolate_shrink+0x48
__list_lru_walk_one.isra.10+0x94
list_lru_walk_node+0x40
shrink_dcache_sb+0x60
do_remount_sb+0xbc
do_emergency_remount+0xb0
process_one_work+0x228
worker_thread+0x2e0
kthread+0xf4
ret_from_fork+0x10
Fix this lockup by reducing the number of entries to be shrinked from
the lru list to 1024 at once. Also, add cond_resched() before
processing the lru list again.
Link: http://marc.info/?t=149722864900001&r=1&w=2
Link: http://lkml.kernel.org/r/1498707575-2472-1-git-send-email-stummala@codeaurora.org
Signed-off-by: Sahitya Tummala <stummala@codeaurora.org>
Suggested-by: Jan Kara <jack@suse.cz>
Suggested-by: Vladimir Davydov <vdavydov.dev@gmail.com>
Acked-by: Vladimir Davydov <vdavydov.dev@gmail.com>
Cc: Alexander Polakov <apolyakov@beget.ru>
commit 3895dbf8985f656675b5bde610723a29cbce3fa7 upstream.
Protecting the mountpoint hashtable with namespace_sem was sufficient
until a call to umount_mnt was added to mntput_no_expire. At which
point it became possible for multiple calls of put_mountpoint on
the same hash chain to happen on the same time.
Kristen Johansen <kjlx@templeofstupid.com> reported:
> This can cause a panic when simultaneous callers of put_mountpoint
> attempt to free the same mountpoint. This occurs because some callers
> hold the mount_hash_lock, while others hold the namespace lock. Some
> even hold both.
> In this submitter's case, the panic manifested itself as a GP fault in
> put_mountpoint() when it called hlist_del() and attempted to dereference
> a m_hash.pprev that had been poisioned by another thread.
Al Viro observed that the simple fix is to switch from using the namespace_sem
to the mount_lock to protect the mountpoint hash table.
I have taken Al's suggested patch moved put_mountpoint in pivot_root
(instead of taking mount_lock an additional time), and have replaced
new_mountpoint with get_mountpoint a function that does the hash table
lookup and addition under the mount_lock. The introduction of get_mounptoint
ensures that only the mount_lock is needed to manipulate the mountpoint
hashtable.
d_set_mounted is modified to only set DCACHE_MOUNTED if it is not
already set. This allows get_mountpoint to use the setting of
DCACHE_MOUNTED to ensure adding a struct mountpoint for a dentry
happens exactly once.
Fixes: ce07d891a089 ("mnt: Honor MNT_LOCKED when detaching mounts")
Reported-by: Krister Johansen <kjlx@templeofstupid.com>
Suggested-by: Al Viro <viro@ZenIV.linux.org.uk>
Acked-by: Al Viro <viro@ZenIV.linux.org.uk>
Pull more vfs updates from Al Viro:
"Assorted cleanups and fixes.
In the "trivial API change" department - ->d_compare() losing 'parent'
argument"
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
cachefiles: Fix race between inactivating and culling a cache object
9p: use clone_fid()
9p: fix braino introduced in "9p: new helper - v9fs_parent_fid()"
vfs: make dentry_needs_remove_privs() internal
vfs: remove file_needs_remove_privs()
vfs: fix deadlock in file_remove_privs() on overlayfs
get rid of 'parent' argument of ->d_compare()
cifs, msdos, vfat, hfs+: don't bother with parent in ->d_compare()
affs ->d_compare(): don't bother with ->d_inode
fold _d_rehash() and __d_rehash() together
fold dentry_rcuwalk_invalidate() into its only remaining caller
Pull qstr constification updates from Al Viro:
"Fairly self-contained bunch - surprising lot of places passes struct
qstr * as an argument when const struct qstr * would suffice; it
complicates analysis for no good reason.
I'd prefer to feed that separately from the assorted fixes (those are
in #for-linus and with somewhat trickier topology)"
* 'work.const-qstr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
qstr: constify instances in adfs
qstr: constify instances in lustre
qstr: constify instances in f2fs
qstr: constify instances in ext2
qstr: constify instances in vfat
qstr: constify instances in procfs
qstr: constify instances in fuse
qstr constify instances in fs/dcache.c
qstr: constify instances in nfs
qstr: constify instances in ocfs2
qstr: constify instances in autofs4
qstr: constify instances in hfs
qstr: constify instances in hfsplus
qstr: constify instances in logfs
qstr: constify dentry_init_security
The only place where we feed to __d_rehash() something other than
d_hash(dentry->d_name.hash) is __d_move(), where we give it d_hash
of another dentry. Postpone rehashing until we'd switched the
names and we are rid of that exception, along with the need to
keep _d_rehash() and __d_rehash() separate.
Pull vfs updates from Al Viro:
Probably the most interesting part long-term is ->d_init() - that will
have a bunch of followups in (at least) ceph and lustre, but we'll
need to sort the barrier-related rules before it can get used for
really non-trivial stuff.
Another fun thing is the merge of ->d_iput() callers (dentry_iput()
and dentry_unlink_inode()) and a bunch of ->d_compare() ones (all
except the one in __d_lookup_lru())"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (26 commits)
fs/dcache.c: avoid soft-lockup in dput()
vfs: new d_init method
vfs: Update lookup_dcache() comment
bdev: get rid of ->bd_inodes
Remove last traces of ->sync_page
new helper: d_same_name()
dentry_cmp(): use lockless_dereference() instead of smp_read_barrier_depends()
vfs: clean up documentation
vfs: document ->d_real()
vfs: merge .d_select_inode() into .d_real()
unify dentry_iput() and dentry_unlink_inode()
binfmt_misc: ->s_root is not going anywhere
drop redundant ->owner initializations
ufs: get rid of redundant checks
orangefs: constify inode_operations
missed comment updates from ->direct_IO() prototype change
file_inode(f)->i_mapping is f->f_mapping
trim fsnotify hooks a bit
debugfs: ->d_parent is never NULL or negative
This changes the vfs dentry hashing to mix in the parent pointer at the
_beginning_ of the hash, rather than at the end.
That actually improves both the hash and the code generation, because we
can move more of the computation to the "static" part of the dcache
setup, and do less at lookup runtime.
It turns out that a lot of other hash users also really wanted to mix in
a base pointer as a 'salt' for the hash, and so the slightly extended
interface ends up working well for other cases too.
Users that want a string hash that is purely about the string pass in a
'salt' pointer of NULL.
* merge branch 'salted-string-hash':
fs/dcache.c: Save one 32-bit multiply in dcache lookup
vfs: make the string hashes salt the hash
We triggered soft-lockup under stress test which
open/access/write/close one file concurrently on more than
five different CPUs:
WARN: soft lockup - CPU#0 stuck for 11s! [who:30631]
[<ffffffc0003986f8>] dput+0x100/0x298
[<ffffffc00038c2dc>] terminate_walk+0x4c/0x60
[<ffffffc00038f56c>] path_lookupat+0x5cc/0x7a8
[<ffffffc00038f780>] filename_lookup+0x38/0xf0
[<ffffffc000391180>] user_path_at_empty+0x78/0xd0
[<ffffffc0003911f4>] user_path_at+0x1c/0x28
[<ffffffc00037d4fc>] SyS_faccessat+0xb4/0x230
->d_lock trylock may failed many times because of concurrently
operations, and dput() may execute a long time.
Fix this by replacing cpu_relax() with cond_resched().
dput() used to be sleepable, so make it sleepable again
should be safe.
Cc: <stable@vger.kernel.org>
Signed-off-by: Wei Fang <fangwei1@huawei.com>
Allow filesystem to initialize dentry at allocation time.
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs into work.misc
lockless_dereference() was added which can be used in place of
hard-coding smp_read_barrier_depends().
Signed-off-by: He Kuang <hekuang@huawei.com>
The two methods essentially do the same: find the real dentry/inode
belonging to an overlay dentry. The difference is in the usage:
vfs_open() uses ->d_select_inode() and expects the function to perform
copy-up if necessary based on the open flags argument.
file_dentry() uses ->d_real() passing in the overlay dentry as well as the
underlying inode.
vfs_rename() uses ->d_select_inode() but passes zero flags. ->d_real()
with a zero inode would have worked just as well here.
This patch merges the functionality of ->d_select_inode() into ->d_real()
by adding an 'open_flags' argument to the latter.
[Al Viro] Make the signature of d_real() match that of ->d_real() again.
And constify the inode argument, while we are at it.
Check for d_unhashed() while searching in in-lookup hash was absolutely
wrong. Worse, it masked a deadlock on dget() done under bitlock that
nests inside ->d_lock. Thanks to J. R. Okajima for spotting it.
Spotted-by: "J. R. Okajima" <hooanon05g@gmail.com>
Wearing-brown-paperbag: Al Viro <viro@zeniv.linux.org.uk>
Noe that we're mixing in the parent pointer earlier, we
don't need to use hash_32() to mix its bits. Instead, we can
just take the msbits of the hash value directly.
For those applications which use the partial_name_hash(),
move the multiply to end_name_hash.
Signed-off-by: George Spelvin <linux@sciencehorizons.net>
We always mixed in the parent pointer into the dentry name hash, but we
did it late at lookup time. It turns out that we can simplify that
lookup-time action by salting the hash with the parent pointer early
instead of late.
A few other users of our string hashes also wanted to mix in their own
pointers into the hash, and those are updated to use the same mechanism.
Hash users that don't have any particular initial salt can just use the
NULL pointer as a no-salt.
Cc: Vegard Nossum <vegard.nossum@oracle.com>
Cc: George Spelvin <linux@sciencehorizons.net>
d_walk() relies upon the tree not getting rearranged under it without
rename_lock being touched. And we do grab rename_lock around the
places that change the tree topology. Unfortunately, branch reordering
is just as bad from d_walk() POV and we have two places that do it
without touching rename_lock - one in handling of cursors (for ramfs-style
directories) and another in autofs. autofs one is a separate story; this
commit deals with the cursors.
* mark cursor dentries explicitly at allocation time
* make __dentry_kill() leave ->d_child.next pointing to the next
non-cursor sibling, making sure that it won't be moved around unnoticed
before the parent is relocked on ascend-to-parent path in d_walk().
* make d_walk() skip cursors explicitly; strictly speaking it's
not necessary (all callbacks we pass to d_walk() are no-ops on cursors),
but it makes analysis easier.
Ascend-to-parent logics in d_walk() depends on all encountered child
dentries not getting freed without an RCU delay. Unfortunately, in
quite a few cases it is not true, with hard-to-hit oopsable race as
the result.
Fortunately, the fix is simiple; right now the rule is "if it ever
been hashed, freeing must be delayed" and changing it to "if it
ever had a parent, freeing must be delayed" closes that hole and
covers all cases the old rule used to cover. Moreover, pipes and
sockets remain _not_ covered, so we do not introduce RCU delay in
the cases which are the reason for having that delay conditional
in the first place.
Cc: stable@vger.kernel.org # v3.2+ (and watch out for __d_materialise_dentry())
There is a lot of duplication between dentry_unlink_inode() and dentry_iput().
The only real difference is that dentry_unlink_inode() bumps ->d_seq and
dentry_iput() doesn't. The argument of the latter is known to have been
unhashed, so anybody who might've found it in RCU lookup would already be
doomed to a ->d_seq mismatch. And we want to avoid pointless smp_rmb() there.
This patch makes dentry_unlink_inode() bump ->d_seq only for hashed dentries.
It's safe (d_delete() calls that sucker only if we are holding the only
reference to dentry, so rehash is not going to happen) and it allows
to use dentry_unlink_inode() in __dentry_kill() and get rid of dentry_iput().
The interesting question here is profiling; it *is* a hot path, and extra
conditional jumps in there might or might not be painful.
fsnotify_d_move()/__fsnotify_d_instantiate()/__fsnotify_update_dcache_flags()
are identical to each other, regardless of the config.
Pull string hash improvements from George Spelvin:
"This series does several related things:
- Makes the dcache hash (fs/namei.c) useful for general kernel use.
(Thanks to Bruce for noticing the zero-length corner case)
- Converts the string hashes in <linux/sunrpc/svcauth.h> to use the
above.
- Avoids 64-bit multiplies in hash_64() on 32-bit platforms. Two
32-bit multiplies will do well enough.
- Rids the world of the bad hash multipliers in hash_32.
This finishes the job started in commit 689de1d6ca95 ("Minimal
fix-up of bad hashing behavior of hash_64()")
The vast majority of Linux architectures have hardware support for
32x32-bit multiply and so derive no benefit from "simplified"
multipliers.
The few processors that do not (68000, h8/300 and some models of
Microblaze) have arch-specific implementations added. Those
patches are last in the series.
- Overhauls the dcache hash mixing.
The patch in commit 0fed3ac866ea ("namei: Improve hash mixing if
CONFIG_DCACHE_WORD_ACCESS") was an off-the-cuff suggestion.
Replaced with a much more careful design that's simultaneously
faster and better. (My own invention, as there was noting suitable
in the literature I could find. Comments welcome!)
- Modify the hash_name() loop to skip the initial HASH_MIX(). This
would let us salt the hash if we ever wanted to.
- Sort out partial_name_hash().
The hash function is declared as using a long state, even though
it's truncated to 32 bits at the end and the extra internal state
contributes nothing to the result. And some callers do odd things:
- fs/hfs/string.c only allocates 32 bits of state
- fs/hfsplus/unicode.c uses it to hash 16-bit unicode symbols not bytes
- Modify bytemask_from_count to handle inputs of 1..sizeof(long)
rather than 0..sizeof(long)-1. This would simplify users other
than full_name_hash"
Special thanks to Bruce Fields for testing and finding bugs in v1. (I
learned some humbling lessons about "obviously correct" code.)
On the arch-specific front, the m68k assembly has been tested in a
standalone test harness, I've been in contact with the Microblaze
maintainers who mostly don't care, as the hardware multiplier is never
omitted in real-world applications, and I haven't heard anything from
the H8/300 world"
* 'hash' of git://ftp.sciencehorizons.net/linux:
h8300: Add <asm/hash.h>
microblaze: Add <asm/hash.h>
m68k: Add <asm/hash.h>
<linux/hash.h>: Add support for architecture-specific functions
fs/namei.c: Improve dcache hash function
Eliminate bad hash multipliers from hash_32() and hash_64()
Change hash_64() return value to 32 bits
<linux/sunrpc/svcauth.h>: Define hash_str() in terms of hashlen_string()
fs/namei.c: Add hashlen_string() function
Pull out string hash to <linux/stringhash.h>
We'd like to make more use of the highly-optimized dcache hash functions
throughout the kernel, rather than have every subsystem create its own,
and a function that hashes basic null-terminated strings is required
for that.
(The name is to emphasize that it returns both hash and length.)
It's actually useful in the dcache itself, specifically d_alloc_name().
Other uses in the next patch.
full_name_hash() is also tweaked to make it more generally useful:
1) Take a "char *" rather than "unsigned char *" argument, to
be consistent with hash_name().
2) Handle zero-length inputs. If we want more callers, we don't want
to make them worry about corner cases.
Pull misc vfs cleanups from Al Viro:
"Assorted cleanups and fixes all over the place"
coredump: only charge written data against RLIMIT_CORE
coredump: get rid of coredump_params->written
ecryptfs_lookup(): try either only encrypted or plaintext name
ecryptfs: avoid multiple aliases for directories
bpf: reject invalid names right in ->lookup()
__d_alloc(): treat NULL name as QSTR("/", 1)
mtd: switch ubi_open_volume_path() to vfs_stat()
mtd: switch open_mtd_by_chdev() to use of vfs_stat()
ta-da!
The main issue is the lack of down_write_killable(), so the places
like readdir.c switched to plain inode_lock(); once killable
variants of rwsem primitives appear, that'll be dealt with.
lockdep side also might need more work
If we *do* run into an in-lookup match, we need to wait for it to
cease being in-lookup. Fortunately, we do have unused space in
in-lookup dentries - d_lru is never looked at until it stops being
in-lookup.
So we can stash a pointer to wait_queue_head from stack frame of
the caller of ->lookup(). Some precautions are needed while
waiting, but it's not that hard - we do hold a reference to dentry
we are waiting for, so it can't go away. If it's found to be
in-lookup the wait_queue_head is still alive and will remain so
at least while ->d_lock is held. Moreover, the condition we
are waiting for becomes true at the same point where everything
on that wq gets woken up, so we can just add ourselves to the
queue once.
d_alloc_parallel() gets a pointer to wait_queue_head_t from its
caller; lookup_slow() adjusted, d_add_ci() taught to use
d_alloc_parallel() if the dentry passed to it happens to be
in-lookup one (i.e. if it's been called from the parallel lookup).
That's pretty much it - all that remains is to switch ->i_mutex
to rwsem and have lookup_slow() take it shared.
We will need to be able to check if there is an in-lookup
dentry with matching parent/name. Right now it's impossible,
but as soon as start locking directories shared such beasts
will appear.
Add a secondary hash for locating those. Hash chains go through
the same space where d_alias will be once it's not in-lookup anymore.
Search is done under the same bitlock we use for modifications -
with the primary hash we can rely on d_rehash() into the wrong
chain being the worst that could happen, but here the pointers are
buggered once it's removed from the chain. On the other hand,
the chains are not going to be long and normally we'll end up
adding to the chain anyway. That allows us to avoid bothering with
->d_lock when doing the comparisons - everything is stable until
removed from chain.
New helper: d_alloc_parallel(). Right now it allocates, verifies
that no hashed and in-lookup matches exist and adds to in-lookup
hash.
Returns ERR_PTR() for error, hashed match (in the unlikely case it's
been found) or new dentry. In-lookup matches trigger BUG() for
now; that will change in the next commit when we introduce waiting
for ongoing lookup to finish. Note that in-lookup matches won't be
possible until we actually go for shared locking.
lookup_slow() switched to use of d_alloc_parallel().
Again, these commits are separated only for making it easier to
review. All this machinery will start doing something useful only
when we go for shared locking; it's just that the combination is
too large for my taste.
We'll need to verify that there's neither a hashed nor in-lookup
dentry with desired parent/name before adding to in-lookup set.
One possible solution would be to hold the parent's ->d_lock through
both checks, but while the in-lookup set is relatively small at any
time, dcache is not. And holding the parent's ->d_lock through
something like __d_lookup_rcu() would suck too badly.
So we leave the parent's ->d_lock alone, which means that we watch
out for the following scenario:
* we verify that there's no hashed match
* existing in-lookup match gets hashed by another process
* we verify that there's no in-lookup matches and decide
that everything's fine.
Solution: per-directory kinda-sorta seqlock, bumped around the times
we hash something that used to be in-lookup or move (and hash)
something in place of in-lookup. Then the above would turn into
* read the counter
* do dcache lookup
* if no matches found, check for in-lookup matches
* if there had been none of those either, check if the
counter has changed; repeat if it has.
The "kinda-sorta" part is due to the fact that we don't have much spare
space in inode. There is a spare word (shared with i_bdev/i_cdev/i_pipe),
so the counter part is not a problem, but spinlock is a different story.
We could use the parent's ->d_lock, and it would be less painful in
terms of contention, for __d_add() it would be rather inconvenient to
grab; we could do that (using lock_parent()), but...
Fortunately, we can get serialization on the counter itself, and it
might be a good idea in general; we can use cmpxchg() in a loop to
get from even to odd and smp_store_release() from odd to even.
This commit adds the counter and updating logics; the readers will be
added in the next commit.
marked as such when (would be) parallel lookup is about to pass them
to actual ->lookup(); unmarked when
* __d_add() is about to make it hashed, positive or not.
* __d_move() (from d_splice_alias(), directly or via
__d_unalias()) puts a preexisting dentry in its place
* in caller of ->lookup() if it has escaped all of the
above. Bug (WARN_ON, actually) if it reaches the final dput()
or d_instantiate() while still marked such.
As the result, we are guaranteed that for as long as the flag is
set, dentry will
* remain negative unhashed with positive refcount
* never have its ->d_alias looked at
* never have its ->d_lru looked at
* never have its ->d_parent and ->d_name changed
Right now we have at most one such for any given parent directory.
With parallel lookups that restriction will weaken to
* only exist when parent is locked shared
* at most one with given (parent,name) pair (comparison of
names is according to ->d_compare())
* only exist when there's no hashed dentry with the same
(parent,name)
Transition will take the next several commits; unfortunately, we'll
only be able to switch to rwsem at the end of this series. The
reason for not making it a single patch is to simplify review.
New primitives: d_in_lookup() (a predicate checking if dentry is in
the in-lookup state) and d_lookup_done() (tells the system that
we are done with lookup and if it's still marked as in-lookup, it
should cease to be such).
This series fixes bugs in nfs and ext4 due to 4bacc9c9234c ("overlayfs:
Make f_path always point to the overlay and f_inode to the underlay").
Regular files opened on overlayfs will result in the file being opened on
the underlying filesystem, while f_path points to the overlayfs
mount/dentry.
This confuses filesystems which get the dentry from struct file and assume
it's theirs.
Add a new helper, file_dentry() [*], to get the filesystem's own dentry
from the file. This checks file->f_path.dentry->d_flags against
DCACHE_OP_REAL, and returns file->f_path.dentry if DCACHE_OP_REAL is not
set (this is the common, non-overlayfs case).
In the uncommon case it will call into overlayfs's ->d_real() to get the
underlying dentry, matching file_inode(file).
The reason we need to check against the inode is that if the file is copied
up while being open, d_real() would return the upper dentry, while the open
file comes from the lower dentry.
[*] If possible, it's better simply to use file_inode() instead.
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
Tested-by: Goldwyn Rodrigues <rgoldwyn@suse.com>
Reviewed-by: Trond Myklebust <trond.myklebust@primarydata.com>
Cc: <stable@vger.kernel.org> # v4.2
Cc: Daniel Axtens <dja@axtens.net>
d_add() with inode->i_lock already held; common to d_add() and
d_splice_alias(). All ->lookup() instances that end up hashing
the dentry they are given will hash it here.
This almost completes the preparations to parallel lookups
proper - the only remaining bit is taking security_d_instantiate()
past d_rehash() and doing rehashing without dropping ->d_lock.
it's a no-op - bumping ->d_seq is pointless there.
