path: root/fs/dcache.c
2015-08-21dcache: Reduce the scope of i_lock in d_splice_aliasEric W. Biederman
i_lock is only needed until __d_find_any_alias calls dget on the alias dentry. After that the reference to new ensures that dentry_kill and d_delete will not remove the inode from the dentry, and remove the dentry from the inode->d_entry list. The inode i_lock came to be held over the the __d_move calls in d_splice_alias through a series of introduction of locks with increasing smaller scope. First it was the dcache_lock, then it was the dcache_inode_lock, and finally inode->i_lock. Furthermore inode->i_lock is not held over any other calls to d_move or __d_move so it can not provide any meaningful rename protection. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-08-21dcache: Handle escaped paths in prepend_pathEric W. Biederman
A rename can result in a dentry that by walking up d_parent will never reach it's mnt_root. For lack of a better term I call this an escaped path. prepend_path is called by four different functions __d_path, d_absolute_path, d_path, and getcwd. __d_path only wants to see paths are connected to the root it passes in. So __d_path needs prepend_path to return an error. d_absolute_path similarly wants to see paths that are connected to some root. Escaped paths are not connected to any mnt_root so d_absolute_path needs prepend_path to return an error greater than 1. So escaped paths will be treated like paths on lazily unmounted mounts. getcwd needs to prepend "(unreachable)" so getcwd also needs prepend_path to return an error. d_path is the interesting hold out. d_path just wants to print something, and does not care about the weird cases. Which raises the question what should be printed? Given that <escaped_path>/<anything> should result in -ENOENT I believe it is desirable for escaped paths to be printed as empty paths. As there are not really any meaninful path components when considered from the perspective of a mount tree. So tweak prepend_path to return an empty path with an new error code of 3 when it encounters an escaped path. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-08-07fs, file table: reinit files_stat.max_files after deferred memory initialisationMel Gorman
Dave Hansen reported the following; My laptop has been behaving strangely with 4.2-rc2. Once I log in to my X session, I start getting all kinds of strange errors from applications and see this in my dmesg: VFS: file-max limit 8192 reached The problem is that the file-max is calculated before memory is fully initialised and miscalculates how much memory the kernel is using. This patch recalculates file-max after deferred memory initialisation. Note that using memory hotplug infrastructure would not have avoided this problem as the value is not recalculated after memory hot-add. 4.1: files_stat.max_files = 6582781 4.2-rc2: files_stat.max_files = 8192 4.2-rc2 patched: files_stat.max_files = 6562467 Small differences with the patch applied and 4.1 but not enough to matter. Signed-off-by: Mel Gorman <mgorman@suse.de> Reported-by: Dave Hansen <dave.hansen@intel.com> Cc: Nicolai Stange <nicstange@gmail.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Alex Ng <alexng@microsoft.com> Cc: Fengguang Wu <fengguang.wu@intel.com> Cc: Peter Zijlstra (Intel) <peterz@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-12freeing unlinked file indefinitely delayedAl Viro
Normally opening a file, unlinking it and then closing will have the inode freed upon close() (provided that it's not otherwise busy and has no remaining links, of course). However, there's one case where that does *not* happen. Namely, if you open it by fhandle with cold dcache, then unlink() and close(). In normal case you get d_delete() in unlink(2) notice that dentry is busy and unhash it; on the final dput() it will be forcibly evicted from dcache, triggering iput() and inode removal. In this case, though, we end up with *two* dentries - disconnected (created by open-by-fhandle) and regular one (used by unlink()). The latter will have its reference to inode dropped just fine, but the former will not - it's considered hashed (it is on the ->s_anon list), so it will stay around until the memory pressure will finally do it in. As the result, we have the final iput() delayed indefinitely. It's trivial to reproduce - void flush_dcache(void) { system("mount -o remount,rw /"); } static char buf[20 * 1024 * 1024]; main() { int fd; union { struct file_handle f; char buf[MAX_HANDLE_SZ]; } x; int m; x.f.handle_bytes = sizeof(x); chdir("/root"); mkdir("foo", 0700); fd = open("foo/bar", O_CREAT | O_RDWR, 0600); close(fd); name_to_handle_at(AT_FDCWD, "foo/bar", &x.f, &m, 0); flush_dcache(); fd = open_by_handle_at(AT_FDCWD, &x.f, O_RDWR); unlink("foo/bar"); write(fd, buf, sizeof(buf)); system("df ."); /* 20Mb eaten */ close(fd); system("df ."); /* should've freed those 20Mb */ flush_dcache(); system("df ."); /* should be the same as #2 */ } will spit out something like Filesystem 1K-blocks Used Available Use% Mounted on /dev/root 322023 303843 1131 100% / Filesystem 1K-blocks Used Available Use% Mounted on /dev/root 322023 303843 1131 100% / Filesystem 1K-blocks Used Available Use% Mounted on /dev/root 322023 283282 21692 93% / - inode gets freed only when dentry is finally evicted (here we trigger than by remount; normally it would've happened in response to memory pressure hell knows when). Cc: stable@vger.kernel.org # v2.6.38+; earlier ones need s/kill_it/unhash_it/ Acked-by: J. Bruce Fields <bfields@fieldses.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted VFS fixes and related cleanups (IMO the most interesting in that part are f_path-related things and Eric's descriptor-related stuff). UFS regression fixes (it got broken last cycle). 9P fixes. fs-cache series, DAX patches, Jan's file_remove_suid() work" [ I'd say this is much more than "fixes and related cleanups". The file_table locking rule change by Eric Dumazet is a rather big and fundamental update even if the patch isn't huge. - Linus ] * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits) 9p: cope with bogus responses from server in p9_client_{read,write} p9_client_write(): avoid double p9_free_req() 9p: forgetting to cancel request on interrupted zero-copy RPC dax: bdev_direct_access() may sleep block: Add support for DAX reads/writes to block devices dax: Use copy_from_iter_nocache dax: Add block size note to documentation fs/file.c: __fget() and dup2() atomicity rules fs/file.c: don't acquire files->file_lock in fd_install() fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation vfs: avoid creation of inode number 0 in get_next_ino namei: make set_root_rcu() return void make simple_positive() public ufs: use dir_pages instead of ufs_dir_pages() pagemap.h: move dir_pages() over there remove the pointless include of lglock.h fs: cleanup slight list_entry abuse xfs: Correctly lock inode when removing suid and file capabilities fs: Call security_ops->inode_killpriv on truncate fs: Provide function telling whether file_remove_privs() will do anything ...
2015-07-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace updates from Eric Biederman: "Long ago and far away when user namespaces where young it was realized that allowing fresh mounts of proc and sysfs with only user namespace permissions could violate the basic rule that only root gets to decide if proc or sysfs should be mounted at all. Some hacks were put in place to reduce the worst of the damage could be done, and the common sense rule was adopted that fresh mounts of proc and sysfs should allow no more than bind mounts of proc and sysfs. Unfortunately that rule has not been fully enforced. There are two kinds of gaps in that enforcement. Only filesystems mounted on empty directories of proc and sysfs should be ignored but the test for empty directories was insufficient. So in my tree directories on proc, sysctl and sysfs that will always be empty are created specially. Every other technique is imperfect as an ordinary directory can have entries added even after a readdir returns and shows that the directory is empty. Special creation of directories for mount points makes the code in the kernel a smidge clearer about it's purpose. I asked container developers from the various container projects to help test this and no holes were found in the set of mount points on proc and sysfs that are created specially. This set of changes also starts enforcing the mount flags of fresh mounts of proc and sysfs are consistent with the existing mount of proc and sysfs. I expected this to be the boring part of the work but unfortunately unprivileged userspace winds up mounting fresh copies of proc and sysfs with noexec and nosuid clear when root set those flags on the previous mount of proc and sysfs. So for now only the atime, read-only and nodev attributes which userspace happens to keep consistent are enforced. Dealing with the noexec and nosuid attributes remains for another time. This set of changes also addresses an issue with how open file descriptors from /proc/<pid>/ns/* are displayed. Recently readlink of /proc/<pid>/fd has been triggering a WARN_ON that has not been meaningful since it was added (as all of the code in the kernel was converted) and is not now actively wrong. There is also a short list of issues that have not been fixed yet that I will mention briefly. It is possible to rename a directory from below to above a bind mount. At which point any directory pointers below the renamed directory can be walked up to the root directory of the filesystem. With user namespaces enabled a bind mount of the bind mount can be created allowing the user to pick a directory whose children they can rename to outside of the bind mount. This is challenging to fix and doubly so because all obvious solutions must touch code that is in the performance part of pathname resolution. As mentioned above there is also a question of how to ensure that developers by accident or with purpose do not introduce exectuable files on sysfs and proc and in doing so introduce security regressions in the current userspace that will not be immediately obvious and as such are likely to require breaking userspace in painful ways once they are recognized" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: vfs: Remove incorrect debugging WARN in prepend_path mnt: Update fs_fully_visible to test for permanently empty directories sysfs: Create mountpoints with sysfs_create_mount_point sysfs: Add support for permanently empty directories to serve as mount points. kernfs: Add support for always empty directories. proc: Allow creating permanently empty directories that serve as mount points sysctl: Allow creating permanently empty directories that serve as mountpoints. fs: Add helper functions for permanently empty directories. vfs: Ignore unlocked mounts in fs_fully_visible mnt: Modify fs_fully_visible to deal with locked ro nodev and atime mnt: Refactor the logic for mounting sysfs and proc in a user namespace
2015-07-01vfs: Remove incorrect debugging WARN in prepend_pathEric W. Biederman
The warning message in prepend_path is unclear and outdated. It was added as a warning that the mechanism for generating names of pseudo files had been removed from prepend_path and d_dname should be used instead. Unfortunately the warning reads like a general warning, making it unclear what to do with it. Remove the warning. The transition it was added to warn about is long over, and I added code several years ago which in rare cases causes the warning to fire on legitimate code, and the warning is now firing and scaring people for no good reason. Cc: stable@vger.kernel.org Reported-by: Ivan Delalande <colona@arista.com> Reported-by: Omar Sandoval <osandov@osandov.com> Fixes: f48cfddc6729e ("vfs: In d_path don't call d_dname on a mount point") Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2015-06-22Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner: "A rather largish update for everything time and timer related: - Cache footprint optimizations for both hrtimers and timer wheel - Lower the NOHZ impact on systems which have NOHZ or timer migration disabled at runtime. - Optimize run time overhead of hrtimer interrupt by making the clock offset updates smarter - hrtimer cleanups and removal of restrictions to tackle some problems in sched/perf - Some more leap second tweaks - Another round of changes addressing the 2038 problem - First step to change the internals of clock event devices by introducing the necessary infrastructure - Allow constant folding for usecs/msecs_to_jiffies() - The usual pile of clockevent/clocksource driver updates The hrtimer changes contain updates to sched, perf and x86 as they depend on them plus changes all over the tree to cleanup API changes and redundant code, which got copied all over the place. The y2038 changes touch s390 to remove the last non 2038 safe code related to boot/persistant clock" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (114 commits) clocksource: Increase dependencies of timer-stm32 to limit build wreckage timer: Minimize nohz off overhead timer: Reduce timer migration overhead if disabled timer: Stats: Simplify the flags handling timer: Replace timer base by a cpu index timer: Use hlist for the timer wheel hash buckets timer: Remove FIFO "guarantee" timers: Sanitize catchup_timer_jiffies() usage hrtimer: Allow hrtimer::function() to free the timer seqcount: Introduce raw_write_seqcount_barrier() seqcount: Rename write_seqcount_barrier() hrtimer: Fix hrtimer_is_queued() hole hrtimer: Remove HRTIMER_STATE_MIGRATE selftest: Timers: Avoid signal deadlock in leap-a-day timekeeping: Copy the shadow-timekeeper over the real timekeeper last clockevents: Check state instead of mode in suspend/resume path selftests: timers: Add leap-second timer edge testing to leap-a-day.c ntp: Do leapsecond adjustment in adjtimex read path time: Prevent early expiry of hrtimers[CLOCK_REALTIME] at the leap second edge ntp: Introduce and use SECS_PER_DAY macro instead of 86400 ...
2015-06-19overlayfs: Make f_path always point to the overlay and f_inode to the underlayDavid Howells
Make file->f_path always point to the overlay dentry so that the path in /proc/pid/fd is correct and to ensure that label-based LSMs have access to the overlay as well as the underlay (path-based LSMs probably don't need it). Using my union testsuite to set things up, before the patch I see: [root@andromeda union-testsuite]# bash 5</mnt/a/foo107 [root@andromeda union-testsuite]# ls -l /proc/$$/fd/ ... lr-x------. 1 root root 64 Jun 5 14:38 5 -> /a/foo107 [root@andromeda union-testsuite]# stat /mnt/a/foo107 ... Device: 23h/35d Inode: 13381 Links: 1 ... [root@andromeda union-testsuite]# stat -L /proc/$$/fd/5 ... Device: 23h/35d Inode: 13381 Links: 1 ... After the patch: [root@andromeda union-testsuite]# bash 5</mnt/a/foo107 [root@andromeda union-testsuite]# ls -l /proc/$$/fd/ ... lr-x------. 1 root root 64 Jun 5 14:22 5 -> /mnt/a/foo107 [root@andromeda union-testsuite]# stat /mnt/a/foo107 ... Device: 23h/35d Inode: 40346 Links: 1 ... [root@andromeda union-testsuite]# stat -L /proc/$$/fd/5 ... Device: 23h/35d Inode: 40346 Links: 1 ... Note the change in where /proc/$$/fd/5 points to in the ls command. It was pointing to /a/foo107 (which doesn't exist) and now points to /mnt/a/foo107 (which is correct). The inode accessed, however, is the lower layer. The union layer is on device 25h/37d and the upper layer on 24h/36d. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-06-19seqcount: Rename write_seqcount_barrier()Peter Zijlstra
I'll shortly be introducing another seqcount primitive that's useful to provide ordering semantics and would like to use the write_seqcount_barrier() name for that. Seeing how there's only one user of the current primitive, lets rename it to invalidate, as that appears what its doing. While there, employ lockdep_assert_held() instead of assert_spin_locked() to not generate debug code for regular kernels. Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: ktkhai@parallels.com Cc: rostedt@goodmis.org Cc: juri.lelli@gmail.com Cc: pang.xunlei@linaro.org Cc: Oleg Nesterov <oleg@redhat.com> Cc: wanpeng.li@linux.intel.com Cc: Paul McKenney <paulmck@linux.vnet.ibm.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: umgwanakikbuti@gmail.com Link: http://lkml.kernel.org/r/20150611124743.279926217@infradead.org Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2015-05-28d_walk() might skip too muchAl Viro
when we find that a child has died while we'd been trying to ascend, we should go into the first live sibling itself, rather than its sibling. Off-by-one in question had been introduced in "deal with deadlock in d_walk()" and the fix needs to be backported to all branches this one has been backported to. Cc: stable@vger.kernel.org # 3.2 and later Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-15VFS: Impose ordering on accesses of d_inode and d_flagsDavid Howells
Impose ordering on accesses of d_inode and d_flags to avoid the need to do this: if (!dentry->d_inode || d_is_negative(dentry)) { when this: if (d_is_negative(dentry)) { should suffice. This check is especially problematic if a dentry can have its type field set to something other than DENTRY_MISS_TYPE when d_inode is NULL (as in unionmount). What we really need to do is stick a write barrier between setting d_inode and setting d_flags and a read barrier between reading d_flags and reading d_inode. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-11dcache: return -ESTALE not -EBUSY on distributed fs raceJ. Bruce Fields
On a distributed filesystem it's possible for lookup to discover that a directory it just found is already cached elsewhere in the directory heirarchy. The dcache won't let us keep the directory in both places, so we have to move the dentry to the new location from the place we previously had it cached. If the parent has changed, then this requires all the same locks as we'd need to do a cross-directory rename. But we're already in lookup holding one parent's i_mutex, so it's too late to acquire those locks in the right order. The (unreliable) solution in __d_unalias is to trylock() the required locks and return -EBUSY if it fails. I see no particular reason for returning -EBUSY, and -ESTALE is already the result of some other lookup races on NFS. I think -ESTALE is the more helpful error return. It also allows us to take advantage of the logic Jeff Layton added in c6a9428401c0 "vfs: fix renameat to retry on ESTALE errors" and ancestors, which hopefully resolves some of these errors before they're returned to userspace. I can reproduce these cases using NFS with: ssh root@$client ' mount -olookupcache=pos '$server':'$export' /mnt/ mkdir /mnt/TO mkdir /mnt/DIR touch /mnt/DIR/test.txt while true; do strace -e open cat /mnt/DIR/test.txt 2>&1 | grep EBUSY done ' ssh root@$server ' while true; do mv $export/DIR $export/TO/DIR mv $export/TO/DIR $export/DIR done ' It also helps to add some other concurrent use of the directory on the client (e.g., "ls /mnt/TO"). And you can replace the server-side mv's by client-side mv's that are repeatedly killed. (If the client is interrupted while waiting for the RENAME response then it's left with a dentry that has to go under one parent or the other, but it doesn't yet know which.) Acked-by: Jeff Layton <jlayton@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-22VFS: Split DCACHE_FILE_TYPE into regular and special typesDavid Howells
Split DCACHE_FILE_TYPE into DCACHE_REGULAR_TYPE (dentries representing regular files) and DCACHE_SPECIAL_TYPE (representing blockdev, chardev, FIFO and socket files). d_is_reg() and d_is_special() are added to detect these subtypes and d_is_file() is left as the union of the two. This allows a number of places that use S_ISREG(dentry->d_inode->i_mode) to use d_is_reg(dentry) instead. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-22VFS: Add a fallthrough flag for marking virtual dentriesDavid Howells
Add a DCACHE_FALLTHRU flag to indicate that, in a layered filesystem, this is a virtual dentry that covers another one in a lower layer that should be used instead. This may be recorded on medium if directory integration is stored there. The flag can be set with d_set_fallthru() and tested with d_is_fallthru(). Original-author: Valerie Aurora <vaurora@redhat.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc VFS updates from Al Viro: "This cycle a lot of stuff sits on topical branches, so I'll be sending more or less one pull request per branch. This is the first pile; more to follow in a few. In this one are several misc commits from early in the cycle (before I went for separate branches), plus the rework of mntput/dput ordering on umount, switching to use of fs_pin instead of convoluted games in namespace_unlock()" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: switch the IO-triggering parts of umount to fs_pin new fs_pin killing logics allow attaching fs_pin to a group not associated with some superblock get rid of the second argument of acct_kill() take count and rcu_head out of fs_pin dcache: let the dentry count go down to zero without taking d_lock pull bumping refcount into ->kill() kill pin_put() mode_t whack-a-mole: chelsio file->f_path.dentry is pinned down for as long as the file is open... get rid of lustre_dump_dentry() gut proc_register() a bit kill d_validate() ncpfs: get rid of d_validate() nonsense selinuxfs: don't open-code d_genocide()
2015-02-13fs: dcache: manually unpoison dname after allocation to shut up kasan's reportsAndrey Ryabinin
We need to manually unpoison rounded up allocation size for dname to avoid kasan's reports in dentry_string_cmp(). When CONFIG_DCACHE_WORD_ACCESS=y dentry_string_cmp may access few bytes beyound requested in kmalloc() size. dentry_string_cmp() relates on that fact that dentry allocated using kmalloc and kmalloc internally round up allocation size. So this is not a bug, but this makes kasan to complain about such accesses. To avoid such reports we mark rounded up allocation size in shadow as accessible. Signed-off-by: Andrey Ryabinin <a.ryabinin@samsung.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Cc: Konstantin Serebryany <kcc@google.com> Cc: Dmitry Chernenkov <dmitryc@google.com> Signed-off-by: Andrey Konovalov <adech.fo@gmail.com> Cc: Yuri Gribov <tetra2005@gmail.com> Cc: Konstantin Khlebnikov <koct9i@gmail.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Hansen <dave.hansen@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12list_lru: add helpers to isolate itemsVladimir Davydov
Currently, the isolate callback passed to the list_lru_walk family of functions is supposed to just delete an item from the list upon returning LRU_REMOVED or LRU_REMOVED_RETRY, while nr_items counter is fixed by __list_lru_walk_one after the callback returns. Since the callback is allowed to drop the lock after removing an item (it has to return LRU_REMOVED_RETRY then), the nr_items can be less than the actual number of elements on the list even if we check them under the lock. This makes it difficult to move items from one list_lru_one to another, which is required for per-memcg list_lru reparenting - we can't just splice the lists, we have to move entries one by one. This patch therefore introduces helpers that must be used by callback functions to isolate items instead of raw list_del/list_move. These are list_lru_isolate and list_lru_isolate_move. They not only remove the entry from the list, but also fix the nr_items counter, making sure nr_items always reflects the actual number of elements on the list if checked under the appropriate lock. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Tejun Heo <tj@kernel.org> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Dave Chinner <david@fromorbit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-02-12list_lru: introduce list_lru_shrink_{count,walk}Vladimir Davydov
Kmem accounting of memcg is unusable now, because it lacks slab shrinker support. That means when we hit the limit we will get ENOMEM w/o any chance to recover. What we should do then is to call shrink_slab, which would reclaim old inode/dentry caches from this cgroup. This is what this patch set is intended to do. Basically, it does two things. First, it introduces the notion of per-memcg slab shrinker. A shrinker that wants to reclaim objects per cgroup should mark itself as SHRINKER_MEMCG_AWARE. Then it will be passed the memory cgroup to scan from in shrink_control->memcg. For such shrinkers shrink_slab iterates over the whole cgroup subtree under the target cgroup and calls the shrinker for each kmem-active memory cgroup. Secondly, this patch set makes the list_lru structure per-memcg. It's done transparently to list_lru users - everything they have to do is to tell list_lru_init that they want memcg-aware list_lru. Then the list_lru will automatically distribute objects among per-memcg lists basing on which cgroup the object is accounted to. This way to make FS shrinkers (icache, dcache) memcg-aware we only need to make them use memcg-aware list_lru, and this is what this patch set does. As before, this patch set only enables per-memcg kmem reclaim when the pressure goes from memory.limit, not from memory.kmem.limit. Handling memory.kmem.limit is going to be tricky due to GFP_NOFS allocations, and it is still unclear whether we will have this knob in the unified hierarchy. This patch (of 9): NUMA aware slab shrinkers use the list_lru structure to distribute objects coming from different NUMA nodes to different lists. Whenever such a shrinker needs to count or scan objects from a particular node, it issues commands like this: count = list_lru_count_node(lru, sc->nid); freed = list_lru_walk_node(lru, sc->nid, isolate_func, isolate_arg, &sc->nr_to_scan); where sc is an instance of the shrink_control structure passed to it from vmscan. To simplify this, let's add special list_lru functions to be used by shrinkers, list_lru_shrink_count() and list_lru_shrink_walk(), which consolidate the nid and nr_to_scan arguments in the shrink_control structure. This will also allow us to avoid patching shrinkers that use list_lru when we make shrink_slab() per-memcg - all we will have to do is extend the shrink_control structure to include the target memcg and make list_lru_shrink_{count,walk} handle this appropriately. Signed-off-by: Vladimir Davydov <vdavydov@parallels.com> Suggested-by: Dave Chinner <david@fromorbit.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Michal Hocko <mhocko@suse.cz> Cc: Greg Thelen <gthelen@google.com> Cc: Glauber Costa <glommer@gmail.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-01-25dcache: let the dentry count go down to zero without taking d_lockLinus Torvalds
We can be more aggressive about this, if we are clever and careful. This is subtle. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-01-25kill d_validate()Al Viro
no users left Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-12-08Merge branch 'iov_iter' into for-nextAl Viro
2014-11-19vfs: fix reference leak in d_prune_aliases()Yan, Zheng
In "d_prune_alias(): just lock the parent and call __dentry_kill()" the old dget + d_drop + dput has been replaced with lock_parent + __dentry_kill; unfortunately, dput() does more than just killing dentry - it also drops the reference to parent. New variant leaks that reference and needs dput(parent) after killing the child off. Signed-off-by: Yan, Zheng <zyan@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-11-19dcache: fix kmemcheck warning in switch_namesMikulas Patocka
This patch fixes kmemcheck warning in switch_names. The function switch_names swaps inline names of two dentries. It swaps full arrays d_iname, no matter how many bytes are really used by the strings. Reading data beyond string ends results in kmemcheck warning. We fix the bug by marking both arrays as fully initialized. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: stable@vger.kernel.org # v3.15 Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-11-19merge d_materialise_unique() into d_splice_alias()Al Viro
2014-11-19d_add_ci() should just accept a hashed exact match if it finds oneAl Viro
2014-11-03deal with deadlock in d_walk()Al Viro
... by not hitting rename_retry for reasons other than rename having happened. In other words, do _not_ restart when finding that between unlocking the child and locking the parent the former got into __dentry_kill(). Skip the killed siblings instead... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-11-03move d_rcu from overlapping d_child to overlapping d_aliasAl Viro
2014-10-23fix inode leaks on d_splice_alias() failure exitsAl Viro
d_splice_alias() callers expect it to either stash the inode reference into a new alias, or drop the inode reference. That makes it possible to just return d_splice_alias() result from ->lookup() instance, without any extra housekeeping required. Unfortunately, that should include the failure exits. If d_splice_alias() returns an error, it leaves the dentry it has been given negative and thus it *must* drop the inode reference. Easily fixed, but it goes way back and will need backporting. Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-12take dname_external() into fs/dcache.cAl Viro
never used outside and it's too low-level for legitimate uses outside of fs/dcache.c anyway Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-09dcache: Fix no spaces at the start of a line in dcache.cDaeseok Youn
Fixed coding style in dcache.c Signed-off-by: Daeseok Youn <daeseok.youn@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-09dcache.c: call ->d_prune() regardless of d_unhashed()Al Viro
the only in-tree instance checks d_unhashed() anyway, out-of-tree code can preserve the current behaviour by adding such check if they want it and we get an ability to use it in cases where we *want* to be notified of killing being inevitable before ->d_lock is dropped, whether it's unhashed or not. In particular, autofs would benefit from that. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-09d_prune_alias(): just lock the parent and call __dentry_kill()Al Viro
The only reason for games with ->d_prune() was __d_drop(), which was needed only to force dput() into killing the sucker off. Note that lock_parent() can be called under ->i_lock and won't drop it, so dentry is safe from somebody managing to kill it under us - it won't happen while we are holding ->i_lock. __dentry_kill() is called only with ->d_lockref.count being 0 (here and when picked from shrink list) or 1 (dput() and dropping the ancestors in shrink_dentry_list()), so it will never be called twice - the first thing it's doing is making ->d_lockref.count negative and once that happens, nothing will increment it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-09vfs: Make d_invalidate return voidEric W. Biederman
Now that d_invalidate can no longer fail, stop returning a useless return code. For the few callers that checked the return code update remove the handling of d_invalidate failure. Reviewed-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-09vfs: Merge check_submounts_and_drop and d_invalidateEric W. Biederman
Now that d_invalidate is the only caller of check_submounts_and_drop, expand check_submounts_and_drop inline in d_invalidate. Reviewed-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-09vfs: Lazily remove mounts on unlinked files and directories.Eric W. Biederman
With the introduction of mount namespaces and bind mounts it became possible to access files and directories that on some paths are mount points but are not mount points on other paths. It is very confusing when rm -rf somedir returns -EBUSY simply because somedir is mounted somewhere else. With the addition of user namespaces allowing unprivileged mounts this condition has gone from annoying to allowing a DOS attack on other users in the system. The possibility for mischief is removed by updating the vfs to support rename, unlink and rmdir on a dentry that is a mountpoint and by lazily unmounting mountpoints on deleted dentries. In particular this change allows rename, unlink and rmdir system calls on a dentry without a mountpoint in the current mount namespace to succeed, and it allows rename, unlink, and rmdir performed on a distributed filesystem to update the vfs cache even if when there is a mount in some namespace on the original dentry. There are two common patterns of maintaining mounts: Mounts on trusted paths with the parent directory of the mount point and all ancestory directories up to / owned by root and modifiable only by root (i.e. /media/xxx, /dev, /dev/pts, /proc, /sys, /sys/fs/cgroup/{cpu, cpuacct, ...}, /usr, /usr/local). Mounts on unprivileged directories maintained by fusermount. In the case of mounts in trusted directories owned by root and modifiable only by root the current parent directory permissions are sufficient to ensure a mount point on a trusted path is not removed or renamed by anyone other than root, even if there is a context where the there are no mount points to prevent this. In the case of mounts in directories owned by less privileged users races with users modifying the path of a mount point are already a danger. fusermount already uses a combination of chdir, /proc/<pid>/fd/NNN, and UMOUNT_NOFOLLOW to prevent these races. The removable of global rename, unlink, and rmdir protection really adds nothing new to consider only a widening of the attack window, and fusermount is already safe against unprivileged users modifying the directory simultaneously. In principle for perfect userspace programs returning -EBUSY for unlink, rmdir, and rename of dentires that have mounts in the local namespace is actually unnecessary. Unfortunately not all userspace programs are perfect so retaining -EBUSY for unlink, rmdir and rename of dentries that have mounts in the current mount namespace plays an important role of maintaining consistency with historical behavior and making imperfect userspace applications hard to exploit. v2: Remove spurious old_dentry. v3: Optimized shrink_submounts_and_drop Removed unsued afs label v4: Simplified the changes to check_submounts_and_drop Do not rename check_submounts_and_drop shrink_submounts_and_drop Document what why we need atomicity in check_submounts_and_drop Rely on the parent inode mutex to make d_revalidate and d_invalidate an atomic unit. v5: Refcount the mountpoint to detach in case of simultaneous renames. Reviewed-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-09vfs: More precise tests in d_invalidateEric W. Biederman
The current comments in d_invalidate about what and why it is doing what it is doing are wildly off-base. Which is not surprising as the comments date back to last minute bug fix of the 2.2 kernel. The big fat lie of a comment said: If it's a directory, we can't drop it for fear of somebody re-populating it with children (even though dropping it would make it unreachable from that root, we still might repopulate it if it was a working directory or similar). [AV] What we really need to avoid is multiple dentry aliases of the same directory inode; on all filesystems that have ->d_revalidate() we either declare all positive dentries always valid (and thus never fed to d_invalidate()) or use d_materialise_unique() and/or d_splice_alias(), which take care of alias prevention. The current rules are: - To prevent mount point leaks dentries that are mount points or that have childrent that are mount points may not be be unhashed. - All dentries may be unhashed. - Directories may be rehashed with d_materialise_unique check_submounts_and_drop implements this already for well maintained remote filesystems so implement the current rules in d_invalidate by just calling check_submounts_and_drop. The one difference between d_invalidate and check_submounts_and_drop is that d_invalidate must respect it when a d_revalidate method has earlier called d_drop so preserve the d_unhashed check in d_invalidate. Reviewed-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-09vfs: Document the effect of d_revalidate on d_find_aliasEric W. Biederman
d_drop or check_submounts_and_drop called from d_revalidate can result in renamed directories with child dentries being unhashed. These renamed and drop directory dentries can be rehashed after d_materialise_unique uses d_find_alias to find them. Reviewed-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-10-09Allow sharing external names after __d_move()Al Viro
* external dentry names get a small structure prepended to them (struct external_name). * it contains an atomic refcount, matching the number of struct dentry instances that have ->d_name.name pointing to that external name. The first thing free_dentry() does is decrementing refcount of external name, so the instances that are between the call of free_dentry() and RCU-delayed actual freeing do not contribute. * __d_move(x, y, false) makes the name of x equal to the name of y, external or not. If y has an external name, extra reference is grabbed and put into x->d_name.name. If x used to have an external name, the reference to the old name is dropped and, should it reach zero, freeing is scheduled via kfree_rcu(). * free_dentry() in dentry with external name decrements the refcount of that name and, should it reach zero, does RCU-delayed call that will free both the dentry and external name. Otherwise it does what it used to do, except that __d_free() doesn't even look at ->d_name.name; it simply frees the dentry. All non-RCU accesses to dentry external name are safe wrt freeing since they all should happen before free_dentry() is called. RCU accesses might run into a dentry seen by free_dentry() or into an old name that got already dropped by __d_move(); however, in both cases dentry must have been alive and refer to that name at some point after we'd done rcu_read_lock(), which means that any freeing must be still pending. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-29missing data dependency barrier in prepend_name()Al Viro
AFAICS, prepend_name() is broken on SMP alpha. Disclaimer: I don't have SMP alpha boxen to reproduce it on. However, it really looks like the race is real. CPU1: d_path() on /mnt/ramfs/<255-character>/foo CPU2: mv /mnt/ramfs/<255-character> /mnt/ramfs/<63-character> CPU2 does d_alloc(), which allocates an external name, stores the name there including terminating NUL, does smp_wmb() and stores its address in dentry->d_name.name. It proceeds to d_add(dentry, NULL) and d_move() old dentry over to that. ->d_name.name value ends up in that dentry. In the meanwhile, CPU1 gets to prepend_name() for that dentry. It fetches ->d_name.name and ->d_name.len; the former ends up pointing to new name (64-byte kmalloc'ed array), the latter - 255 (length of the old name). Nothing to force the ordering there, and normally that would be OK, since we'd run into the terminating NUL and stop. Except that it's alpha, and we'd need a data dependency barrier to guarantee that we see that store of NUL __d_alloc() has done. In a similar situation dentry_cmp() would survive; it does explicit smp_read_barrier_depends() after fetching ->d_name.name. prepend_name() doesn't and it risks walking past the end of kmalloc'ed object and possibly oops due to taking a page fault in kernel mode. Cc: stable@vger.kernel.org # 3.12+ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-27vfs: Don't exchange "short" filenames unconditionally.Mikhail Efremov
Only exchange source and destination filenames if flags contain RENAME_EXCHANGE. In case if executable file was running and replaced by other file /proc/PID/exe should still show correct file name, not the old name of the file by which it was replaced. The scenario when this bug manifests itself was like this: * ALT Linux uses rpm and start-stop-daemon; * during a package upgrade rpm creates a temporary file for an executable to rename it upon successful unpacking; * start-stop-daemon is run subsequently and it obtains the (nonexistant) temporary filename via /proc/PID/exe thus failing to identify the running process. Note that "long" filenames (> DNAiME_INLINE_LEN) are still exchanged without RENAME_EXCHANGE and this behaviour exists long enough (should be fixed too apparently). So this patch is just an interim workaround that restores behavior for "short" names as it was before changes introduced by commit da1ce0670c14 ("vfs: add cross-rename"). See https://lkml.org/lkml/2014/9/7/6 for details. AV: the comments about being more careful with ->d_name.hash than with ->d_name.name are from back in 2.3.40s; they became obsolete by 2.3.60s, when we started to unhash the target instead of swapping hash chain positions followed by d_delete() as we used to do when dcache was first introduced. Acked-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: linux-fsdevel@vger.kernel.org Cc: stable@vger.kernel.org Fixes: da1ce0670c14 "vfs: add cross-rename" Signed-off-by: Mikhail Efremov <sem@altlinux.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-27fold swapping ->d_name.hash into switch_names()Linus Torvalds
and do it along with ->d_name.len there Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-26fold unlocking the children into dentry_unlock_parents_for_move()Al Viro
... renaming it into dentry_unlock_for_move() and making it more symmetric with dentry_lock_for_move(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-26kill __d_materialise_dentry()Al Viro
it folds into __d_move() now Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-26__d_materialise_dentry(): flip the order of argumentsAl Viro
... thus making it much closer to (now unreachable, BTW) IS_ROOT(dentry) case in __d_move(). A bit more and it'll fold in. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-26__d_move(): fold manipulations with ->d_child/->d_subdirsAl Viro
list_del() + list_add() is a slightly pessimised list_move() list_del() + INIT_LIST_HEAD() is a slightly pessimised list_del_init() Interleaving those makes the resulting code even worse. And harder to follow... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-26don't open-code d_rehash() in d_materialise_unique()Al Viro
... and get rid of duplicate BUG_ON() there Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-09-26pull rehashing and unlocking the target dentry into __d_materialise_dentry()Al Viro
2014-09-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "double iput() on failure exit in lustre, racy removal of spliced dentries from ->s_anon in __d_materialise_dentry() plus a bunch of assorted RCU pathwalk fixes" The RCU pathwalk fixes end up fixing a couple of cases where we incorrectly dropped out of RCU walking, due to incorrect initialization and testing of the sequence locks in some corner cases. Since dropping out of RCU walk mode forces the slow locked accesses, those corner cases slowed down quite dramatically. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: be careful with nd->inode in path_init() and follow_dotdot_rcu() don't bugger nd->seq on set_root_rcu() from follow_dotdot_rcu() fix bogus read_seqretry() checks introduced in b37199e move the call of __d_drop(anon) into __d_materialise_unique(dentry, anon) [fix] lustre: d_make_root() does iput() on dentry allocation failure
2014-09-13move the call of __d_drop(anon) into __d_materialise_unique(dentry, anon)Al Viro
and lock the right list there Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
