commit 5467a68cbf6884c9a9d91e2a89140afb1839c835 upstream.
For lockless accesses to dentries we don't have pinned we rely
(among other things) upon having an RCU delay between dropping
the last reference and actually freeing the memory.
On the other hand, for things like pipes and sockets we neither
do that kind of lockless access, nor want to deal with the
overhead of an RCU delay every time a socket gets closed.
So delay was made optional - setting DCACHE_RCUACCESS in ->d_flags
made sure it would happen. We tried to avoid setting it unless
we knew we need it. Unfortunately, that had led to recurring
class of bugs, in which we missed the need to set it.
We only really need it for dentries that are created by
d_alloc_pseudo(), so let's not bother with trying to be smart -
just make having an RCU delay the default. The ones that do
*not* get it set the replacement flag (DCACHE_NORCU) and we'd
better use that sparingly. d_alloc_pseudo() is the only
such user right now.
FWIW, the race that finally prompted that switch had been
between __lock_parent() of immediate subdirectory of what's
currently the root of a disconnected tree (e.g. from
open-by-handle in progress) racing with d_splice_alias()
elsewhere picking another alias for the same inode, either
on outright corrupted fs image, or (in case of open-by-handle
on NFS) that subdirectory having been just moved on server.
It's not easy to hit, so the sky is not falling, but that's
not the first race on similar missed cases and the logics
for settinf DCACHE_RCUACCESS has gotten ridiculously
convoluted.
Cc: stable@vger.kernel.org
The current dentry number tracking code doesn't distinguish between
positive & negative dentries. It just reports the total number of
dentries in the LRU lists.
As excessive number of negative dentries can have an impact on system
performance, it will be wise to track the number of positive and
negative dentries separately.
This patch adds tracking for the total number of negative dentries in
the system LRU lists and reports it in the 5th field in the
/proc/sys/fs/dentry-state file. The number, however, does not include
negative dentries that are in flight but not in the LRU yet as well as
those in the shrinker lists which are on the way out anyway.
The number of positive dentries in the LRU lists can be roughly found by
subtracting the number of negative dentries from the unused count.
Matthew Wilcox had confirmed that since the introduction of the
dentry_stat structure in 2.1.60, the dummy array was there, probably for
future extension. They were not replacements of pre-existing fields.
So no sane applications that read the value of /proc/sys/fs/dentry-state
will do dummy thing if the last 2 fields of the sysctl parameter are not
zero. IOW, it will be safe to use one of the dummy array entry for
negative dentry count.
Signed-off-by: Waiman Long <longman@redhat.com>
The nr_dentry_unused per-cpu counter tracks dentries in both the LRU
lists and the shrink lists where the DCACHE_LRU_LIST bit is set.
The shrink_dcache_sb() function moves dentries from the LRU list to a
shrink list and subtracts the dentry count from nr_dentry_unused. This
is incorrect as the nr_dentry_unused count will also be decremented in
shrink_dentry_list() via d_shrink_del().
To fix this double decrement, the decrement in the shrink_dcache_sb()
function is taken out.
Fixes: 4e717f5c1083 ("list_lru: remove special case function list_lru_dispose_all."
Cc: stable@kernel.org
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Move remaining definitions and declarations from include/linux/bootmem.h
into include/linux/memblock.h and remove the redundant header.
The includes were replaced with the semantic patch below and then
semi-automated removal of duplicated '#include <linux/memblock.h>
- #include <linux/bootmem.h>
+ #include <linux/memblock.h>
[sfr@canb.auug.org.au: dma-direct: fix up for the removal of linux/bootmem.h]
Link: http://lkml.kernel.org/r/20181002185342.133d1680@canb.auug.org.au
[sfr@canb.auug.org.au: powerpc: fix up for removal of linux/bootmem.h]
Link: http://lkml.kernel.org/r/20181005161406.73ef8727@canb.auug.org.au
[sfr@canb.auug.org.au: x86/kaslr, ACPI/NUMA: fix for linux/bootmem.h removal]
Link: http://lkml.kernel.org/r/20181008190341.5e396491@canb.auug.org.au
Link: http://lkml.kernel.org/r/1536927045-23536-30-git-send-email-rppt@linux.vnet.ibm.com
Signed-off-by: Mike Rapoport <rppt@linux.vnet.ibm.com>
Cc: Chris Zankel <chris@zankel.net>
Cc: Greentime Hu <green.hu@gmail.com>
Cc: Guan Xuetao <gxt@pku.edu.cn>
Cc: "James E.J. Bottomley" <jejb@parisc-linux.org>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Ley Foon Tan <lftan@altera.com>
Cc: Mark Salter <msalter@redhat.com>
Cc: Matt Turner <mattst88@gmail.com>
Cc: Michael Ellerman <mpe@ellerman.id.au>
Cc: Palmer Dabbelt <palmer@sifive.com>
Cc: Paul Burton <paul.burton@mips.com>
Cc: Richard Kuo <rkuo@codeaurora.org>
Cc: Richard Weinberger <richard@nod.at>
Cc: Rich Felker <dalias@libc.org>
Cc: Russell King <linux@armlinux.org.uk>
Cc: Serge Semin <fancer.lancer@gmail.com>
Cc: Vineet Gupta <vgupta@synopsys.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
We can use the newly introduced kmalloc-reclaimable-X caches, to allocate
external names in dcache, which will take care of the proper accounting
automatically, and also improve anti-fragmentation page grouping.
This effectively reverts commit f1782c9bc547 ("dcache: account external
names as indirectly reclaimable memory") and instead passes
__GFP_RECLAIMABLE to kmalloc(). The accounting thus moves from
NR_INDIRECTLY_RECLAIMABLE_BYTES to NR_SLAB_RECLAIMABLE, which is also
considered in MemAvailable calculation and overcommit decisions.
Link: http://lkml.kernel.org/r/20180731090649.16028-4-vbabka@suse.cz
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Acked-by: Mel Gorman <mgorman@techsingularity.net>
Acked-by: Roman Gushchin <guro@fb.com>
Cc: Christoph Lameter <cl@linux.com>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Laura Abbott <labbott@redhat.com>
Cc: Matthew Wilcox <willy@infradead.org>
Cc: Michal Hocko <mhocko@kernel.org>
Cc: Sumit Semwal <sumit.semwal@linaro.org>
Cc: Vijayanand Jitta <vjitta@codeaurora.org>
Since only dentry->d_name.len + 1 bytes out of DNAME_INLINE_LEN bytes
are initialized at __d_alloc(), we can't copy the whole size
unconditionally.
WARNING: kmemcheck: Caught 32-bit read from uninitialized memory (ffff8fa27465ac50)
636f6e66696766732e746d70000000000010000000000000020000000188ffff
i i i i i i i i i i i i i u u u u u u u u u u i i i i i u u u u
RIP: 0010:take_dentry_name_snapshot+0x28/0x50
RSP: 0018:ffffa83000f5bdf8 EFLAGS: 00010246
RAX: 0000000000000020 RBX: ffff8fa274b20550 RCX: 0000000000000002
RDX: ffffa83000f5be40 RSI: ffff8fa27465ac50 RDI: ffffa83000f5be60
RBP: ffffa83000f5bdf8 R08: ffffa83000f5be48 R09: 0000000000000001
R10: ffff8fa27465ac00 R11: ffff8fa27465acc0 R12: ffff8fa27465ac00
R13: ffff8fa27465acc0 R14: 0000000000000000 R15: 0000000000000000
FS: 00007f79737ac8c0(0000) GS:ffffffff8fc30000(0000) knlGS:0000000000000000
CR2: ffff8fa274c0b000 CR3: 0000000134aa7002 CR4: 00000000000606f0
vfs_rename+0x128/0x870
SyS_rename+0x3b2/0x3d0
entry_SYSCALL_64_fastpath+0x1a/0xa4
0xffffffffffffffff
Link: http://lkml.kernel.org/r/201709131912.GBG39012.QMJLOVFSFFOOtH@I-love.SAKURA.ne.jp
Cc: Vegard Nossum <vegard.nossum@gmail.com>
Pull misc vfs updates from Al Viro:
"Misc cleanups from various folks all over the place
I expected more fs/dcache.c cleanups this cycle, so that went into a
separate branch. Said cleanups have missed the window, so in the
hindsight it could've gone into work.misc instead. Decided not to
cherry-pick, thus the 'work.dcache' branch"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: dcache: Use true and false for boolean values
fold generic_readlink() into its only caller
fs: shave 8 bytes off of struct inode
fs: Add more kernel-doc to the produced documentation
fs: Fix attr.c kernel-doc
removed extra extern file_fdatawait_range
* 'work.dcache' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
kill dentry_update_name_case()
Pull vfs icache updates from Al Viro:
- NFS mkdir/open_by_handle race fix
- analogous solution for FUSE, replacing the one currently in mainline
- new primitive to be used when discarding halfway set up inodes on
failed object creation; gives sane warranties re icache lookups not
returning such doomed by still not freed inodes. A bunch of
filesystems switched to that animal.
- Miklos' fix for last cycle regression in iget5_locked(); -stable will
need a slightly different variant, unfortunately.
- misc bits and pieces around things icache-related (in adfs and jfs).
* 'work.mkdir' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
jfs: don't bother with make_bad_inode() in ialloc()
adfs: don't put inodes into icache
new helper: inode_fake_hash()
vfs: don't evict uninitialized inode
jfs: switch to discard_new_inode()
ext2: make sure that partially set up inodes won't be returned by ext2_iget()
udf: switch to discard_new_inode()
ufs: switch to discard_new_inode()
btrfs: switch to discard_new_inode()
new primitive: discard_new_inode()
kill d_instantiate_no_diralias()
nfs_instantiate(): prevent multiple aliases for directory inode
RCU pathwalk relies upon the assumption that anything that changes
->d_inode of a dentry will invalidate its ->d_seq. That's almost
true - the one exception is that the final dput() of already unhashed
dentry does *not* touch ->d_seq at all. Unhashing does, though,
so for anything we'd found by RCU dcache lookup we are fine.
Unfortunately, we can *start* with an unhashed dentry or jump into
it.
We could try and be careful in the (few) places where that could
happen. Or we could just make the final dput() invalidate the damn
thing, unhashed or not. The latter is much simpler and easier to
backport, so let's do it that way.
Reported-by: "Dae R. Jeong" <threeearcat@gmail.com>
Since mountpoint crossing can happen without leaving lazy mode,
root dentries do need the same protection against having their
memory freed without RCU delay as everything else in the tree.
It's partially hidden by RCU delay between detaching from the
mount tree and dropping the vfsmount reference, but the starting
point of pathwalk can be on an already detached mount, in which
case umount-caused RCU delay has already passed by the time the
lazy pathwalk grabs rcu_read_lock(). If the starting point
happens to be at the root of that vfsmount *and* that vfsmount
covers the entire filesystem, we get trouble.
Fixes: 48a066e72d97 ("RCU'd vsfmounts")
Return statements in functions returning bool should use true or false
instead of an integer value.
This issue was detected with the help of Coccinelle.
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
We don't want open-by-handle picking half-set-up in-core
struct inode from e.g. mkdir() having failed halfway through.
In other words, we don't want such inodes returned by iget_locked()
on their way to extinction. However, we can't just have them
unhashed - otherwise open-by-handle immediately *after* that would've
ended up creating a new in-core inode over the on-disk one that
is in process of being freed right under us.
Solution: new flag (I_CREATING) set by insert_inode_locked() and
removed by unlock_new_inode() and a new primitive (discard_new_inode())
to be used by such halfway-through-setup failure exits instead of
unlock_new_inode() / iput() combinations. That primitive unlocks new
inode, but leaves I_CREATING in place.
iget_locked() treats finding an I_CREATING inode as failure
(-ESTALE, once we sort out the error propagation).
insert_inode_locked() treats the same as instant -EBUSY.
ilookup() treats those as icache miss.
[Fix by Dan Carpenter <dan.carpenter@oracle.com> folded in]
The only user is fuse_create_new_entry(), and there it's used to
mitigate the same mkdir/open-by-handle race as in nfs_mkdir().
The same solution applies - unhash the mkdir argument, then
call d_splice_alias() and if that returns a reference to preexisting
alias, dput() and report success. ->mkdir() argument left unhashed
negative with the preexisting alias moved in the right place is just
fine from the ->mkdir() callers point of view.
Cc: Miklos Szeredi <miklos@szeredi.hu>
the last user is gone
Spotted-by: Richard Weinberger <richard@nod.at>
"Misc bits and pieces not fitting into anything more specific"
vfs: delete unnecessary assignment in vfs_listxattr
Documentation: filesystems: update filesystem locking documentation
vfs: namei: use path_equal() in follow_dotdot()
fs.h: fix outdated comment about file flags
__inode_security_revalidate() never gets NULL opt_dentry
make xattr_getsecurity() static
vfat: simplify checks in vfat_lookup()
get rid of dead code in d_find_alias()
it's SB_BORN, not MS_BORN...
msdos_rmdir(): kill BS comment
remove rpc_rmdir()
fs: avoid fdput() after failed fdget() in vfs_dedupe_file_range()
Pull dcache updates from Al Viro:
"This is the first part of dealing with livelocks etc around
shrink_dcache_parent()."
restore cond_resched() in shrink_dcache_parent()
dput(): turn into explicit while() loop
dcache: move cond_resched() into the end of __dentry_kill()
d_walk(): kill 'finish' callback
d_invalidate(): unhash immediately
All "try disconnected alias if nothing else fits" logics in d_find_alias()
got accidentally disabled by Neil a while ago; for most of the callers it
was the right thing to do, so fixes belong in few callers that *do* want
disconnected aliases. This just takes the now-dead code in d_find_alias()
out.
For anything NFS-exported we do _not_ want to unlock new inode
before it has grown an alias; original set of fixes got the
ordering right, but missed the nasty complication in case of
lockdep being enabled - unlock_new_inode() does
lockdep_annotate_inode_mutex_key(inode)
which can only be done before anyone gets a chance to touch
->i_mutex. Unfortunately, flipping the order and doing
unlock_new_inode() before d_instantiate() opens a window when
mkdir can race with open-by-fhandle on a guessed fhandle, leading
to multiple aliases for a directory inode and all the breakage
that follows from that.
Correct solution: a new primitive (d_instantiate_new())
combining these two in the right order - lockdep annotate, then
d_instantiate(), then the rest of unlock_new_inode(). All
combinations of d_instantiate() with unlock_new_inode() should
be converted to that.
Cc: stable@kernel.org # 2.6.29 and later
Tested-by: Mike Marshall <hubcap@omnibond.com>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
No need to mess with gotos when the code yielded by straight while()
isn't any worse...
cond_resched() in shrink_dentry_list() is too early
no users left
Once that is done, we can just hunt mountpoints down one by one;
no new mountpoints can be added from now on, so we don't need
anything tricky in finish() callback, etc.
As previously reported (https://patchwork.kernel.org/patch/8642031/)
it's possible to call shrink_dentry_list with a large number of dentries
(> 10000). This, in turn, could trigger the softlockup detector and
possibly trigger a panic. In addition to the unmount path being
vulnerable to this scenario, at SuSE we've observed similar situation
happening during process exit on processes that touch a lot of dentries.
Here is an excerpt from a crash dump. The number after the colon are
the number of dentries on the list passed to shrink_dentry_list:
PID 99760: 10722
PID 107530: 215
PID 108809: 24134
PID 108877: 21331
PID 141708: 16487
So we want to kill between 15k-25k dentries without yielding.
And one possible call stack looks like:
4 [ffff8839ece41db0] _raw_spin_lock at ffffffff8152a5f8
5 [ffff8839ece41db0] evict at ffffffff811c3026
6 [ffff8839ece41dd0] __dentry_kill at ffffffff811bf258
7 [ffff8839ece41df0] shrink_dentry_list at ffffffff811bf593
8 [ffff8839ece41e18] shrink_dcache_parent at ffffffff811bf830
9 [ffff8839ece41e50] proc_flush_task at ffffffff8120dd61
10 [ffff8839ece41ec0] release_task at ffffffff81059ebd
11 [ffff8839ece41f08] do_exit at ffffffff8105b8ce
12 [ffff8839ece41f78] sys_exit at ffffffff8105bd53
13 [ffff8839ece41f80] system_call_fastpath at ffffffff81532909
While some of the callers of shrink_dentry_list do use cond_resched,
this is not sufficient to prevent softlockups. So just move
cond_resched into shrink_dentry_list from its callers.
David said: I've found hundreds of occurrences of warnings that we emit
when need_resched stays set for a prolonged period of time with the
stack trace that is included in the change log.
Link: http://lkml.kernel.org/r/1521718946-31521-1-git-send-email-nborisov@suse.com
Signed-off-by: Nikolay Borisov <nborisov@suse.com>
Reviewed-by: Andrew Morton <akpm@linux-foundation.org>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Goldwyn Rodrigues <rgoldwyn@suse.de>
Cc: Jeff Mahoney <jeffm@suse.com>
Cc: Davidlohr Bueso <dave@stgolabs.net>
I received a report about suspicious growth of unreclaimable slabs on
some machines. I've found that it happens on machines with low memory
pressure, and these unreclaimable slabs are external names attached to
dentries.
External names are allocated using generic kmalloc() function, so they
are accounted as unreclaimable. But they are held by dentries, which
are reclaimable, and they will be reclaimed under the memory pressure.
In particular, this breaks MemAvailable calculation, as it doesn't take
unreclaimable slabs into account. This leads to a silly situation, when
a machine is almost idle, has no memory pressure and therefore has a big
dentry cache. And the resulting MemAvailable is too low to start a new
workload.
To address the issue, the NR_INDIRECTLY_RECLAIMABLE_BYTES counter is
used to track the amount of memory, consumed by external names. The
counter is increased in the dentry allocation path, if an external name
structure is allocated; and it's decreased in the dentry freeing path.
To reproduce the problem I've used the following Python script:
import os
for iter in range (0, 10000000):
try:
name = ("/some_long_name_%d" % iter) + "_" * 220
os.stat(name)
except Exception:
pass
Without this patch:
$ cat /proc/meminfo | grep MemAvailable
MemAvailable: 7811688 kB
$ python indirect.py
MemAvailable: 2753052 kB
With the patch:
MemAvailable: 7809516 kB
MemAvailable: 7749144 kB
[guro@fb.com: fix indirectly reclaimable memory accounting for CONFIG_SLOB]
Link: http://lkml.kernel.org/r/20180312194140.19517-1-guro@fb.com
[guro@fb.com: fix indirectly reclaimable memory accounting]
Link: http://lkml.kernel.org/r/20180313125701.7955-1-guro@fb.com
Link: http://lkml.kernel.org/r/20180305133743.12746-5-guro@fb.com
Signed-off-by: Roman Gushchin <guro@fb.com>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Mel Gorman <mgorman@techsingularity.net>
Currently d_move(from, to) does the following:
* name/parent of from <- old name/parent of to, from hashed there
* to is unhashed
* name of to is preserved
* if from used to be detached, to gets detached
* if from used to be attached, parent of to <- old parent of from.
That's both user-visibly bogus and complicates reasoning a lot.
Much saner semantics would be
* name/parent of from <- name/parent of to, from hashed there.
* to is unhashed
* name/parent of to is unchanged.
The price, of course, is that old parent of from might lose a reference.
However,
* all potentially cross-directory callers of d_move() have both
parents pinned directly; typically, dentries themselves are grabbed
only after we have grabbed and locked both parents. IOW, the decrement
of old parent's refcount in case of d_move() won't reach zero.
* __d_move() from d_splice_alias() is done to detached alias.
No refcount decrements in that case
* __d_move() from __d_unalias() *can* get the refcount to zero.
So let's grab a reference to alias' old parent before calling __d_unalias()
and dput() it after we'd dropped rename_lock.
That does make d_splice_alias() potentially blocking. However, it has
no callers in non-sleepable contexts (and the case where we'd grown
that dget/dput pair is _very_ rare, so performance is not an issue).
Another thing that needs adjustment is unlocking in the end of __d_move();
folded it in. And cleaned the remnants of bogus ordering from the
"lock them in the beginning" counterpart - it's never been right and
now (well, for 7 years now) we have that thing always serialized on
rename_lock anyway.
Those parts of fs/dcache.c are pretty much self-contained.
shrink_dentry_list() holds dentry->d_lock and needs to acquire
dentry->d_inode->i_lock. This cannot be done with a spin_lock()
operation because it's the reverse of the regular lock order.
To avoid ABBA deadlocks it is done with a trylock loop.
Trylock loops are problematic in two scenarios:
1) PREEMPT_RT converts spinlocks to 'sleeping' spinlocks, which are
preemptible. As a consequence the i_lock holder can be preempted
by a higher priority task. If that task executes the trylock loop
it will do so forever and live lock.
2) In virtual machines trylock loops are problematic as well. The
VCPU on which the i_lock holder runs can be scheduled out and a
task on a different VCPU can loop for a whole time slice. In the
worst case this can lead to starvation. Commits 47be61845c77
("fs/dcache.c: avoid soft-lockup in dput()") and 046b961b45f9
("shrink_dentry_list(): take parent's d_lock earlier") are
addressing exactly those symptoms.
Avoid the trylock loop by using dentry_kill(). When pruning ancestors,
the same code applies that is used to kill a dentry in dput(). This
also has the benefit that the locking order is now the same. First
the inode is locked, then the parent.
Signed-off-by: John Ogness <john.ogness@linutronix.de>
In case when trylock in there fails, deal with it directly in
dentry_kill(). Note that in cases when we drop and retake
->d_lock, we need to recheck whether to retain the dentry.
Another thing is that dropping/retaking ->d_lock might have
ended up with negative dentry turning into positive; that,
of course, can happen only once...
Turn the "trylock failed" part into uninlined __lock_parent().
all remaining callers hold either a reference or ->i_lock
In case of trylock failure don't re-add to the list - drop the locks
and carefully get them in the right order. For shrink_dentry_list(),
somebody having grabbed a reference to dentry means that we can
kick it off-list, so if we find dentry being modified under us we
don't need to play silly buggers with retries anyway - off the list
it is.
The locking logics taken out into a helper of its own; lock_parent()
is no longer used for dentries that can be killed under us.
[fix from Eric Biggers folded]
just grab ->i_lock first; we have a positive dentry, nothing's going
to happen to inode
A subsequent patch will modify dentry_kill() to call lock_parent().
Move the dentry_kill() implementation "as is" below lock_parent()
first. This will help simplify the review of the subsequent patch
with dentry_kill() changes.
Commit 0d98439ea3c6 ("vfs: use lockred "dead" flag to mark unrecoverably
dead dentries") removed the `ref' parameter in dentry_kill() but its
documentation remained. Remove it.
... and reorder it with making d_unhashed() true.
i_dir_seq is subject to concurrent modification by a cmpxchg or
store-release operation, so ensure that the relaxed access in
d_alloc_parallel uses READ_ONCE.
Reported-by: Peter Zijlstra <peterz@infradead.org>
If d_alloc_parallel runs concurrently with __d_add, it is possible for
d_alloc_parallel to continuously retry whilst i_dir_seq has been
incremented to an odd value by __d_add:
CPU0:
__d_add
n = start_dir_add(dir);
cmpxchg(&dir->i_dir_seq, n, n + 1) == n
CPU1:
d_alloc_parallel
retry:
seq = smp_load_acquire(&parent->d_inode->i_dir_seq) & ~1;
hlist_bl_lock(b);
bit_spin_lock(0, (unsigned long *)b); // Always succeeds
CPU0:
__d_lookup_done(dentry)
hlist_bl_lock
bit_spin_lock(0, (unsigned long *)b); // Never succeeds
CPU1:
if (unlikely(parent->d_inode->i_dir_seq != seq)) {
hlist_bl_unlock(b);
goto retry;
Since the simple bit_spin_lock used to implement hlist_bl_lock does not
provide any fairness guarantees, then CPU1 can starve CPU0 of the lock
and prevent it from reaching end_dir_add(dir), therefore CPU1 cannot
exit its retry loop because the sequence number always has the bottom
bit set.
This patch resolves the livelock by not taking hlist_bl_lock in
d_alloc_parallel if the sequence counter is odd, since any subsequent
masked comparison with i_dir_seq will fail anyway.
Reported-by: Naresh Madhusudana <naresh.madhusudana@arm.com>
Acked-by: Peter Zijlstra (Intel) <peterz@infradead.org>
Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com>
In case when dentry passed to lock_parent() is protected from freeing only
by the fact that it's on a shrink list and trylock of parent fails, we
could get hit by __dentry_kill() (and subsequent dentry_kill(parent))
between unlocking dentry and locking presumed parent. We need to recheck
that dentry is alive once we lock both it and parent *and* postpone
rcu_read_unlock() until after that point. Otherwise we could return
a pointer to struct dentry that already is rcu-scheduled for freeing, with
->d_lock held on it; caller's subsequent attempt to unlock it can end
up with memory corruption.
Cc: stable@vger.kernel.org # 3.12+, counting backports
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull overlayfs updates from Miklos Szeredi:
"This work from Amir adds NFS export capability to overlayfs. NFS
exporting an overlay filesystem is a challange because we want to keep
track of any copy-up of a file or directory between encoding the file
handle and decoding it.
This is achieved by indexing copied up objects by lower layer file
handle. The index is already used for hard links, this patchset
extends the use to NFS file handle decoding"
* 'overlayfs-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs: (51 commits)
ovl: check ERR_PTR() return value from ovl_encode_fh()
ovl: fix regression in fsnotify of overlay merge dir
ovl: wire up NFS export operations
ovl: lookup indexed ancestor of lower dir
ovl: lookup connected ancestor of dir in inode cache
ovl: hash non-indexed dir by upper inode for NFS export
ovl: decode pure lower dir file handles
ovl: decode indexed dir file handles
ovl: decode lower file handles of unlinked but open files
ovl: decode indexed non-dir file handles
ovl: decode lower non-dir file handles
ovl: encode lower file handles
ovl: copy up before encoding non-connectable dir file handle
ovl: encode non-indexed upper file handles
ovl: decode connected upper dir file handles
ovl: decode pure upper file handles
ovl: encode pure upper file handles
ovl: document NFS export
vfs: factor out helpers d_instantiate_anon() and d_alloc_anon()
ovl: store 'has_upper' and 'opaque' as bit flags
git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux
Pull hardened usercopy whitelisting from Kees Cook:
"Currently, hardened usercopy performs dynamic bounds checking on slab
cache objects. This is good, but still leaves a lot of kernel memory
available to be copied to/from userspace in the face of bugs.
To further restrict what memory is available for copying, this creates
a way to whitelist specific areas of a given slab cache object for
copying to/from userspace, allowing much finer granularity of access
control.
Slab caches that are never exposed to userspace can declare no
whitelist for their objects, thereby keeping them unavailable to
userspace via dynamic copy operations. (Note, an implicit form of
whitelisting is the use of constant sizes in usercopy operations and
get_user()/put_user(); these bypass all hardened usercopy checks since
these sizes cannot change at runtime.)
This new check is WARN-by-default, so any mistakes can be found over
the next several releases without breaking anyone's system.
The series has roughly the following sections:
- remove %p and improve reporting with offset
- prepare infrastructure and whitelist kmalloc
- update VFS subsystem with whitelists
- update SCSI subsystem with whitelists
- update network subsystem with whitelists
- update process memory with whitelists
- update per-architecture thread_struct with whitelists
- update KVM with whitelists and fix ioctl bug
- mark all other allocations as not whitelisted
- update lkdtm for more sensible test overage"
* tag 'usercopy-v4.16-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/kees/linux: (38 commits)
lkdtm: Update usercopy tests for whitelisting
usercopy: Restrict non-usercopy caches to size 0
kvm: x86: fix KVM_XEN_HVM_CONFIG ioctl
kvm: whitelist struct kvm_vcpu_arch
arm: Implement thread_struct whitelist for hardened usercopy
arm64: Implement thread_struct whitelist for hardened usercopy
x86: Implement thread_struct whitelist for hardened usercopy
fork: Provide usercopy whitelisting for task_struct
fork: Define usercopy region in thread_stack slab caches
fork: Define usercopy region in mm_struct slab caches
net: Restrict unwhitelisted proto caches to size 0
sctp: Copy struct sctp_sock.autoclose to userspace using put_user()
sctp: Define usercopy region in SCTP proto slab cache
caif: Define usercopy region in caif proto slab cache
ip: Define usercopy region in IP proto slab cache
net: Define usercopy region in struct proto slab cache
scsi: Define usercopy region in scsi_sense_cache slab cache
cifs: Define usercopy region in cifs_request slab cache
vxfs: Define usercopy region in vxfs_inode slab cache
ufs: Define usercopy region in ufs_inode_cache slab cache
Merge KASAN word-at-a-time fixups from Andrey Ryabinin.
The word-at-a-time optimizations have caused headaches for KASAN, since
the whole point is that we access byte streams in bigger chunks, and
KASAN can be unhappy about the potential extra access at the end of the
string.
We used to have a horrible hack in dcache, and then people got
complaints from the strscpy() case. This fixes it all up properly, by
adding an explicit helper for the "access byte stream one word at a
time" case.
* emailed patches from Andrey Ryabinin <aryabinin@virtuozzo.com>:
fs: dcache: Revert "manually unpoison dname after allocation to shut up kasan's reports"
fs/dcache: Use read_word_at_a_time() in dentry_string_cmp()
lib/strscpy: Shut up KASAN false-positives in strscpy()
compiler.h: Add read_word_at_a_time() function.
compiler.h, kasan: Avoid duplicating __read_once_size_nocheck()
kasan's reports"
This reverts commit df4c0e36f1b1782b0611a77c52cc240e5c4752dd.
It's no longer needed since dentry_string_cmp() now uses
read_word_at_a_time() to avoid kasan's reports.
Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com>
dentry_string_cmp() performs the word-at-a-time reads from 'cs' and may
read slightly more than it was requested in kmallac(). Normally this
would make KASAN to report out-of-bounds access, but this was
workarounded by commit df4c0e36f1b1 ("fs: dcache: manually unpoison
dname after allocation to shut up kasan's reports").
This workaround is not perfect, since it allows out-of-bounds access to
dentry's name for all the code, not just in dentry_string_cmp().
So it would be better to use read_word_at_a_time() instead and revert
commit df4c0e36f1b1.
"Neil Brown's d_move()/d_path() race fix"
VFS: close race between getcwd() and d_move()
